330lover wrote:Hi there,
since Jan. 13, SAS A333 LN-RKM has been operating (mostly double) daily flights between BRU and BHX v.v.
Probably related to Covid19 vaccination transportation, but can anyone confirm?
ba319-131 wrote:I thought I read it was car parts /
Rare movement to be seen at Birmingham is this SAS A330 operating a series of cargo flights through the month of January moving car parts between Brussels - Birmingham - Brussels twice daily.
JibberJim wrote:A plane needs to be used because of delays at the road/ferry route disrupting just-in-time production, I imagine the initial contract was more protection due to the risk of disruption, we'll find out in Feb if the road's are clear enough to stop the waste of the plane trip (or maybe it really is cheaper!)
peterinlisbon wrote:People from Birmingham are known to be crazy about Belgian waffles. Finally someone has tapped that neglected market.
Aesma wrote:The carbon footprint of these cars will be horrendous.
airzona11 wrote:[*]Aesma wrote:The carbon footprint of these cars will be horrendous.
A333 full of cargo is a lot of cargo. Is that inefficient?
mxaxai wrote:Given the city pair BRU - BHX, what's the most likely manufacturer to ask for these flights? Toyota? Jaguar?
If there is just one anecdote that succinctly sums up the problems that Brexit and the threat of tariffs pose to the UK car industry, it is this: the story behind the crankshaft used in the BMW Mini, which crosses the Channel three times in a 2,000-mile journey before the finished car rolls off the production line.
A cast of the raw crankshaft – the part of the car that translates the movement of the pistons into the rotational motion required to move the vehicle – is made by a supplier based in France.
From there it is shipped to BMW’s Hams Hall plant in Warwickshire, where it is drilled and milled into shape. When that job is complete, each crankshaft is then sent back across the Channel to Munich, where it inserted into the engine.
raylee67 wrote:The effect of Brexit. Cargo is moved too slowly now across the tunnel due to checks and documents, etc.
TC957 wrote:Interesting that SAS have obtained this work for their otherwise dormant A333's, as opposed for example VS. Love to know the story behind how SAS got this contract.
seansasLCY wrote:raylee67 wrote:The effect of Brexit. Cargo is moved too slowly now across the tunnel due to checks and documents, etc.
Wasn’t it actually linked to the delays caused by covid and the French border closure?
airsmiles wrote:airzona11 wrote:[*]Aesma wrote:The carbon footprint of these cars will be horrendous.
How much does an A333 carry compared to a couple of 40t trucks and with what carbon footprint? Interesting comparison.
jamesontheroad wrote:Could it be Mini, in Oxford? Mini was a well known example of a British car manufacturer who shuttled parts back and forth across the Channel between different plants. A twice daily shuttle to an airport like Brussels could be serving two flows to France and Germany.
Source (March 2017): https://www.theguardian.com/business/20 ... SApp_OtherIf there is just one anecdote that succinctly sums up the problems that Brexit and the threat of tariffs pose to the UK car industry, it is this: the story behind the crankshaft used in the BMW Mini, which crosses the Channel three times in a 2,000-mile journey before the finished car rolls off the production line.
airsmiles wrote:If that’s how cars are made these days, I’d argue that it’s a failure of modern manufacturing and environmentally indefensible. Common sense alone would highlight so many trips backwards and forwards is creating so many potential failures in the process. Maybe it’s time to reassess what makes sense.
It's got to use about 3000 liters of fuel each way, versus about 100 liters in a truck. So about 30 times as much.
raggi wrote:It's got to use about 3000 liters of fuel each way, versus about 100 liters in a truck. So about 30 times as much.
100 liters is not enough to carry a payload of more than 40 tons about 600 km by truck...
mxaxai wrote:airsmiles wrote:If that’s how cars are made these days, I’d argue that it’s a failure of modern manufacturing and environmentally indefensible. Common sense alone would highlight so many trips backwards and forwards is creating so many potential failures in the process. Maybe it’s time to reassess what makes sense.
Virtually all products involve such logistics. A product is assembled from various parts, and each parts undergoes multiple work steps from the raw material before delivery to the assembly line. It's cheaper (and potentially even more environmentally friendly) to focus certain steps at one plant and simply ship the 'finished' part, instead of maintaining the required tools at multiple sites worldwide.
In the case of the crankshaft, the French supplier has all the tools for this specific work step that produces the semi-finished shaft. They acquire the metal en-masse from somewhere and produce crank-shafts (and other semi-finished parts) for multiple customers and applications.
BMW in Warwickshire then has the drills and mills for the final work steps that finish the shaft so that it can be inserted into the engine. They do the same work on other parts, some of which are used for assembly in Warwickshire, others are shipped to other assembly lines.
Finally, Munich is chosen for final assembly of the engine because they have experienced workers, they have the assembly line all set up, and it's a convenient location to gather all the other parts that form the engine.
If you wanted to avoid all this international shipping, you'd have to use aluminum sourced in the UK, pour it into a shaft in the UK, do milling and drilling there, and have an assembly line nearby as well. Those cars would then only be sold in the UK. For even less transport, you'd require UK-made furnaces, mills, drills, assembly robots, welding machines, etc. Now repeat this for the other 194 countries worldwide.
Modern products require complex production methods in any case. Logistics are the easiest part.
smithhaddon123 wrote:@airsmiles
You are absolutely right and it's depressing to see such a miniscule number of people that share your point of view.
airsmiles wrote:If everything that’s produced in the world is made like that, it’s not difficult to see why the environmental disaster that’s unfolding is happening. Perhaps it’s time to consider whether the logistics should be properly accounted for, rather than just produce the cheapest parts in cost terms. It’s off topic really, so I’ll leave it there. At least SAS are getting some benefit.
mxaxai wrote:airsmiles wrote:If everything that’s produced in the world is made like that, it’s not difficult to see why the environmental disaster that’s unfolding is happening. Perhaps it’s time to consider whether the logistics should be properly accounted for, rather than just produce the cheapest parts in cost terms. It’s off topic really, so I’ll leave it there. At least SAS are getting some benefit.
Matter of fact is that natural resources are only found in a few locations. Same applies to the required knowledge and tools to produce things. Logistics are mandatory unless you happen to have everything you need in your own backyard, and know how to do everything yourself.
Whether just-in-time production is a good idea is an entirely different matter. Perishable items like pharmaceuticals, fresh fruit or fish have to be flown sometimes but I doubt that they're the primary cargo on these particular flights...
Jalap wrote:TC957 wrote:Interesting that SAS have obtained this work for their otherwise dormant A333's, as opposed for example VS. Love to know the story behind how SAS got this contract.
Virgin also has a daily cargo rotation to Brussels, using both A350's and 787's: https://www.aviation24.be/airlines/virgin-atlantic/virgin-atlantic-increases-cargo-only-flying-by-60-in-january-2021-and-emphasises-the-london-brussels-route/
TC957 wrote:Jalap wrote:TC957 wrote:Interesting that SAS have obtained this work for their otherwise dormant A333's, as opposed for example VS. Love to know the story behind how SAS got this contract.
Yes, I know, which is why I thought VS could have bid for that extra BHX rotation and done something like LHR-BRU-BHX-BRU-LHR. I realize those sort of flights aren't what A350's and 787's are supposed to do, but why not given the current passenger downturn.
CometOrbit wrote:airsmiles wrote:If that’s how cars are made these days, I’d argue that it’s a failure of modern manufacturing and environmentally indefensible. Common sense alone would highlight so many trips backwards and forwards is creating so many potential failures in the process. Maybe it’s time to reassess what makes sense.
It's exactly how Airbus makes its planes, with air transport shifting partially-complete components between the various manufacturing sites, using their Beluga freighters.
Most people regard that as a highly efficient method of operation (and the logistics are highly optimised for the job).
How otherwise would Airbus wings from Broughton in the UK get to France/Germany for final assembly?
