SOURCE: OAG
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
NOTE: It finally updated!!!
Already deferring start dates it appears
2D BOS-PAP FEB 0.3>0[0.3] MAR 0.3>0.1[0]
2D BOS-SDQ FEB 0.3>0[0.3] MAR 0.3>0.0[0]
2D GYE-LAX FEB 0.3>0[0.3] MAR 0.3>0.1[0]
2D GYE-MIA FEB 0.9>0.6[0.9] MAR 0.8>0.6[0]
2D MIA-SDQ FEB 0.5>0.1[0.4]
2D PHL-SDQ FEB 0.2>0[0.3] MAR 0.3>0.0[0]
3M FLL-GGT FEB 0.2>0[0.7]
**4B BNA-GLH FEB 0>0.8[0] MAR 0>0.9[0] APR 0>0.9[0] MAY 0>0.8[0] JUN 0>0.9[0]
4B BOS-MSS FEB 1.0>1.5[0]
4B BWI-MSS JUN 1.0>0.5[0]
4B DFW-GLH FEB 0>1.7[0] MAR 0>1.7[1.9] APR 0>1.7[2] MAY 0>1.7[1.9] JUN 0>1.7[2]
**4B PHX-PRC MAR 0>1.7[0] APR 0>1.7[0] MAY 0>1.7[0] JUN 0>1.7[0] JUL 0>1.7[0]
9K ACK-EWB JUN 0.4>1.4[1.0] JUL 0.8>1.8[1.1] AUG 0.8>1.8[1.2] SEP 0.8>1.8[1.3]
9K STL-UIN AUG 1.3>1.6[3]
9X HNL-JHM APR 0>2[5] MAY 0>2[5] JUN 0>2[5] JUL 0>2[5] AUG 0>2[3] SEP 0>2[3]
9X HNL-LNY FEB 1.7>3[1.9] MAR 1.7>3[0] APR 0>3[0] MAY 0>3[0] JUN 0>3[0] JUL 0>3[0] AUG 0>3[2] SEP 0>3[2]
9X HNL-MKK APR 0>10[9] MAY 0>10[8] JUN 0>10[12] JUL 0>10[11] AUG 0>10[12] SEP 0>10[12]
9X LNY-OGG APR 0>3[2] MAY 0>3[1.9] JUN 0>3[2] JUL 0>3[1.9] AUG 0>3[2] SEP 0>3[2]
9X MKK-OGG APR 0>9[8] MAY 0>9[7] JUL 0>9[8] AUG 0>9[11] SEP 0>9[11]
**AA AEX-CLT APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
AA ANU-MIA APR 2>1.0[2] MAY 2>1.0[1.9]
AA AUA-CLT JUN 2>3[0] JUL 2>3[0.9] AUG 1.4>2[0.6] SEP 0.8>1.7[0.8]
AA AUS-DFW FEB 6>5[11]
AA BGI-MIA APR 2>1.1[3] MAY 2>1.0[2] JUN 3>1.0[0.7] JUL 3>1.0[0.9] AUG 3>1.5[1.0]
AA BOS-LAX MAR 5>3[4]
AA CLT-ELH JUN 0.3>0.9[0] JUL 0.3>1.0[0] AUG 0.2>0.5[0]
**AA CLT-LFT APR 0>1.9[0] MAY 0>2[0] JUN 0>2[0] JUL 0>2[0] AUG 0>2[0] SEP 0>2[0]
AA CLT-PUJ JUN 2>3[0] JUL 2>3[0] AUG 1.5>3[1.0] SEP 1.1>1.9[0.8]
AA CLT-SDQ JUN 0.2>0.4[0]
*AA CLT-STT JUN 1.0>1.9[0] JUL 1.0>2.0[0.9] AUG 1.0>1.5[0.5]
*AA CLT-STX JUN 0.1>0.9[0] JUL 0.2>1.0[0] AUG 0.1>0.5[0]
AA CUR-MIA APR 2.0>1.0[2] MAY 2>1.0[0] JUN 2>1.0[0.7] JUL 2>1.0[0.9] AUG 1.5>1.0[1.0]
**AA DAB-DFW APR 0.2>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>0.5[0]
AA DEN-DFW FEB 7>6[12]
AA DFW-MBJ JUN 1.3>1.9[0] JUL 1.3>2[0.9] AUG 0.7>1.0[0.5]
AA DFW-PUJ JUN 0.1>0.9[0] JUL 0.2>1.0[0] AUG 0.1>0.5[0]
AA DFW-SFO MAR 8>7[8]
AA DFW-SGU APR 0.1>0.9[1.0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.4] SEP 0>1.0[0]
AA DFW-SLC FEB 4>3[7]
AA DFW-STT JUN 0.1>0.9[0] JUL 0.2>1.0[0] AUG 0.1>0.5[0]
AA GRB-ORD FEB 1.0>0.7[3]
AA HAV-MIA FEB 5>4[6]
AA JFK-STT APR 0.1>1.0[0.1] MAY 0.2>1.0[0] JUN 0.1>1.0[0] JUL 0.2>1.0[0] AUG 0.1>0.5[0]
AA KIN-MIA JUN 3>2[0.7] JUL 3>2[0.9] AUG 3>2[1.9] SEP 3>2[2]
AA LAS-ORD FEB 1.2>0.9[4]
AA MCI-PHL FEB 0.4>0.6[3]
AA MIA-POP JUN 1.0>1.9[0.7] JUL 1.0>2[0.9] AUG 1.0>1.5[1.0]
AA MIA-PTP JUN 0.1>0.5[0] JUL 0.2>0.5[0] AUG 0>0.3[0.1]
AA MIA-SKB APR 1.7>1.0[1.7] MAY 1.7>1.0[0.9] JUN 2.0>1.0[0.7] JUL 2>1.0[0.1] AUG 1.5>1.0[0.1]
AA MIA-UVF APR 2>1.0[2] MAY 2>1.0[1.6]
AA PHL-PUJ APR 0.1>1.0[0.1] MAY 0.2>1.0[0] JUN 0.1>1.0[0] JUL 0.2>1.0[0] AUG 0.6>1.1[0]
AA PHL-STT JUN 0.2>1.0[0] JUL 0.2>1.0[0] AUG 0.1>0.5[0]
AC ATL-YYZ FEB 2>0[4] MAR 4>0[4] APR 4>2[4]
AC AUS-YYZ FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 1.0>0.6[1.2]
AC BDL-YUL APR 1.0>0.6[0.8]
AC BDL-YYZ APR 2>1.3[2.0]
AC BNA-YYZ FEB 1.3>0[2] MAR 2>0[1.9] APR 2>1.3[2]
AC BOS-YHZ FEB 1.2>0[2] MAR 1.9>0[1.7] APR 1.9>1.2[1.9]
AC BOS-YOW FEB 1.2>0[2] MAR 1.9>0[1.4] APR 1.9>1.2[1.5]
AC BOS-YUL FEB 3>0.4[4] MAR 4>0.4[4] APR 4>3[4]
AC BOS-YYZ FEB 5>0.9[8] MAR 8>0.8[7] APR 8>5[8]
AC BWI-YUL FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 1.0>0.6[1.0]
AC BWI-YYZ FEB 1.9>0[3] MAR 3>0[3] APR 3>1.9[3]
AC CLE-YYZ FEB 2>0[4] MAR 4>0[4] APR 4>2[4]
AC CLT-YYZ FEB 1.3>0[2] MAR 2>0[1.9] APR 2>1.3[2]
AC CMH-YYZ FEB 2>0[4] MAR 4>0[3] APR 4>2[4]
AC CVG-YYZ FEB 1.7>0[3] MAR 3>0[3] APR 3>1.7[3]
AC DCA-YOW FEB 1.1>0[1.9] MAR 1.7>0[1.9] APR 1.7>1.1[2]
AC DCA-YUL FEB 1.3>0[2] MAR 2>0[1.9] APR 2>1.3[2]
AC DCA-YYZ FEB 3>0.9[4] MAR 4>1.0[4] APR 4>3[4]
AC DEN-YUL FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 1.0>0.6[1.0]
AC DEN-YVR FEB 1.3>0[2] MAR 2>0[1.7] APR 2>1.3[2]
AC DEN-YYZ FEB 1.4>0.4[2] MAR 2.0>0.3[1.9] APR 2>1.3[2]
AC DFW-YUL FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 1.0>0.6[1.0]
AC DFW-YVR FEB 0.6>0[1.1] MAR 1.0>0[0] APR 1.0>0.6[1.0]
AC DFW-YYZ FEB 1.9>0[3] MAR 3>0[3] APR 3>1.9[3]
AC DTW-YYZ FEB 2>0[4] MAR 3>0[4] APR 4>2[4]
AC EWR-YOW FEB 1.6>0[3] MAR 3>0[2] APR 3>1.7[3]
AC EWR-YUL FEB 3>1.9[4] MAR 4>1.9[3]
AC EWR-YVR FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 1.0>0.6[1.0]
AC EWR-YYC FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 1.0>0.6[1.0]
AC EWR-YYZ FEB 5>2[7] MAR 6>1.9[6] APR 6>5[7]
AC FLL-YOW FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 0.8>0.4[1.0]
AC FLL-YUL FEB 3>1.0[5] MAR 5>2[4]
AC FLL-YYZ FEB 2>0.7[4] MAR 4>0.7[3] APR 3>2[5]
AC HNL-YVR FEB 0.7>0[1.1] MAR 1.1>0[0.9] APR 1.7>1.3[1.0]
AC IAD-YUL FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 1.0>0.6[1.0]
AC IAD-YYZ FEB 1.6>0[2] MAR 2>0[1.9] APR 2>1.3[2]
AC IAH-YUL FEB 1.4>0[2] MAR 2>0[1.9] APR 2>1.3[2]
AC IAH-YYC MAR 0.2>0[1.9] APR 2>1.3[2]
AC IAH-YYZ FEB 2>0[3] MAR 3>0[3] APR 3>1.8[3]
AC KOA-YVR FEB 0.5>0[0.8] MAR 0.7>0[0.3] APR 0.4>0.2[0.3]
AC LAS-YUL FEB 1.3>0[2] MAR 2>0[1.7] APR 2>1.3[2]
AC LAS-YVR FEB 1.3>0[2] MAR 2>0[0.9] APR 2>1.3[1.0]
AC LAS-YYC FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 1.0>0.6[1.0]
AC LAS-YYZ FEB 1.3>0[2] MAR 2>0[1.9] APR 2>1.3[2]
AC LAX-YUL FEB 1.3>0[2] MAR 2>0[1.7] APR 2>1.3[2]
AC LAX-YVR FEB 4>0.7[5] MAR 5>1.0[5] APR 5>4[5]
AC LAX-YYC FEB 1.3>0[2] MAR 2>0[0.9] APR 2>1.3[1.0]
AC LAX-YYZ FEB 3>0.4[4] MAR 4>0.4[4] APR 4>3[4]
AC LGA-YUL FEB 5>0.9[8] MAR 8>1.0[7] APR 8>5[8]
AC LGA-YYZ FEB 8>2[13] MAR 12>1.9[11] APR 12>8[12]
AC MCI-YYZ FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 1.0>0.6[1.0]
AC MCO-YHZ FEB 0.6>0[1.1] MAR 1.0>0[0.8] APR 1.0>0.6[1.1]
AC MCO-YOW FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 1.0>0.6[1.0]
AC MCO-YUL FEB 1.7>0[3] MAR 3>0[2] APR 2>1.3[3]
AC MCO-YYZ FEB 3>0[5] MAR 5>0[4] APR 3>1.9[6]
AC MEM-YYZ FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 1.0>0.6[1.0]
AC MIA-YUL FEB 1.0>0[2] MAR 2>0[1.2] APR 2>1.3[2]
AC MIA-YYZ FEB 2>0[4] MAR 4>0[3] APR 2>1.3[5]
AC MKE-YYZ FEB 1.1>0[1.9] MAR 1.7>0[1.6] APR 1.7>1.1[1.7]
AC MSP-YYZ FEB 1.9>0[3] MAR 3>0[2] APR 3>1.9[3]
AC MSY-YYZ FEB 1.3>0[2] MAR 1.9>0[1.9] APR 2>1.3[2]
AC OGG-YVR FEB 0.7>0.1[1.2] MAR 1.1>0.2[0.9] APR 1.7>1.1[1.0]
AC OGG-YYC FEB 0.5>0.1[0.6]
AC ORD-YUL FEB 3>1.0[4] MAR 4>2.0[4]
AC ORD-YVR FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 1.0>0.6[1.0]
AC ORD-YYZ FEB 6>1.9[8] MAR 8>3[7] APR 8>6[8]
AC PBI-YUL FEB 0.6>0[1.0] MAR 0.9>0[0.9] APR 0.6>0.3[1.0]
AC PBI-YYZ FEB 1.3>0[2] MAR 2>0[1.7] APR 1.4>0.6[2]
AC PDX-YVR FEB 3>0[4] MAR 4>0[4] APR 4>3[4]
AC PDX-YYC FEB 0.5>0[0.9] MAR 0.9>0[0.8] APR 0.9>0.6[0.8]
AC PHL-YUL FEB 1.3>0[2] MAR 2>0[1.7] APR 2>1.3[1.9]
AC PHL-YYZ FEB 2>0[4] MAR 4>0[4] APR 4>2[4]
AC PHX-YUL FEB 0.4>0[0.6] MAR 0.6>0[0.4] APR 0.6>0.4[0.7]
AC PHX-YVR FEB 0.6>0[1.1] MAR 1.0>0.2[0.9] APR 1.0>0.7[1.0]
AC PHX-YYC FEB 0.6>0.3[0.7] MAR 0.7>0.2[0.8] APR 1.0>0.8[1.0]
AC PHX-YYZ FEB 1.0>0[2] MAR 2>0[0.9] APR 2>1.3[1.6]
AC PIT-YUL FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 1.0>0.6[1.0]
AC PIT-YYZ FEB 1.9>0[3] MAR 3>0[3] APR 3>1.8[3]
AC PSP-YVR FEB 0.6>0[1.1] MAR 1.0>0[0.7] APR 1.0>0.6[1.0]
AC PSP-YYZ FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 0.9>0.5[1.0]
AC RDU-YUL FEB 0.6>0[1.1] MAR 1.0>0[0.8] APR 1.0>0.6[1.0]
AC RDU-YYZ FEB 1.9>0[3] MAR 3>0[3] APR 3>1.9[3]
AC RSW-YUL FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 1.0>0.6[1.0]
AC RSW-YYZ FEB 1.6>0.1[3] MAR 3>0.4[2] APR 2>1.4[4]
AC SAN-YVR FEB 1.9>0[3] MAR 3>0[3] APR 3>1.9[3]
AC SAN-YYZ FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 1.0>0.6[1.0]
AC SEA-YVR FEB 4>0.8[6] MAR 6>1.0[6] APR 6>4[6]
AC SEA-YYZ FEB 0.6>0[1.0] MAR 1.0>0[0.9] APR 1.0>0.6[1.0]
AC SFO-YEG FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 1.0>0.6[1.0]
AC SFO-YUL FEB 0.6>0[2] MAR 2.0>0[0.9] APR 2.0>1.3[2]
AC SFO-YVR FEB 3>0.6[5] MAR 5>1.0[4] APR 5>4[5]
AC SFO-YYC FEB 1.3>0[2] MAR 2>0[0.9] APR 2>1.3[1.0]
AC SFO-YYZ FEB 3>0[5] MAR 5>0[3] APR 4>3[4]
AC SJC-YVR FEB 1.9>0[3] MAR 3>0[3] APR 3>1.9[3]
AC SMF-YVR FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 1.0>0.6[0.9]
AC SRQ-YYZ FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 0.7>0.4[1.0]
AC STL-YYZ FEB 1.9>0[3] MAR 3>0[3] APR 3>1.9[3]
AC TPA-YHZ FEB 0.6>0[1.1] MAR 1.0>0[0.6] APR 0.8>0.4[1.0]
AC TPA-YOW FEB 0.5>0[0.8] MAR 0.7>0[0.5] APR 0.4>0.2[0.7]
AC TPA-YUL FEB 0.6>0[1.1] MAR 1.0>0[0.9] APR 0.9>0.5[1.1]
AC TPA-YYZ FEB 1.3>0[2] MAR 2>0[1.7] APR 2>1.3[2]
AF CDG-IAD FEB 0.7>0.4[0.9]
AM JFK-MTY APR 1.0>0[1.0] MAY 1.0>0[0.7]
AM LAS-MTY APR 0.3>0[0.3] MAY 0.3>0[0]
AM LAX-MTY APR 1.0>0[1.0] MAY 1.0>0[0.7]
AS BZN-PDX FEB 1.0>0.6[1.1]
AS CUN-PDX MAR 0.3>0[0]
AS CUN-SAN MAR 0.5>0[0]
AS DAL-LAX MAR 1.8>2[2]
AS GDL-SJC MAR 1.0>0[1.0]
AS HNL-LAX MAR 0.6>1.0[0.8]
AS LAS-LAX MAR 1.7>3[3]
AS LAX-LIR MAR 0.7>0.9[0.9]
AS LAX-LTO MAR 0.6>0.4[0.9]
AS LAX-MZT MAR 0.6>0.4[0.8]
AS LAX-PVR MAR 1.5>1.1[1.0]
AS LAX-SJO MAR 0.9>0.4[0.5]
AS LAX-STS FEB 1.3>1.0[2]
AS LAX-TPA FEB 0.9>0.7[1.1]
AS LAX-ZIH MAR 0.7>0.4[0.9]
AS LIH-SEA FEB 0.9>0.6[1.9]
AS OGG-PDX MAR 1.4>1.8[1.9]
AS PDX-PVR MAR 0.9>0[0.9]
**AS PDX-SBP MAR 0.5>0[0] APR 1.0>0[0] MAY 1.0>0[0] JUN 1.0>0.5[0]
AS PDX-SJD MAR 0.8>0[0.9]
AS PDX-STS FEB 0.3>0[2]
AS PDX-YVR MAR 0.5>0[0.9]
AS PSP-RNO FEB 0.7>0.5[0.7]
AS PVR-SAN MAR 0.7>0.4[0.4]
AS PVR-SFO MAR 1.0>0[1.1]
AS PVR-SJC MAR 0.8>0[0]
I said these were pretty questionable from the gitgo
**AS SAN-SBA MAR 0.5>0[0] APR 1.0>0[0] MAY 1.0>0[0] JUN 1.0>0.5[0]
**AS SAN-SBP MAR 0.5>0[0.9] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0.5[0]
AS SAN-SJD MAR 1.5>0.6[1.0]
AS SAN-STS FEB 0.9>0.6[1.1]
AS SEA-YEG MAR 1.1>0[2]
AS SEA-YLW MAR 0.8>0[1.9]
AS SEA-YVR MAR 3>1.8[6]
AS SEA-YYC MAR 1.1>0[2]
AS SEA-YYJ MAR 1.4>0[3]
AS SJC-SJD MAR 1.1>0[0.8]
AY HEL-JFK MAY 1.0>0.6[0]
AY HEL-LAX MAY 0.4>0[0]
AY HEL-ORD MAY 1.0>0.6[0] JUN 1.0>0.7[0]
B6 ATL-BOS FEB 0.6>0.4[1.7]
B6 ATL-EWR FEB 1.7>1.1[3]
B6 AUS-EWR FEB 0.8>0.5[1.0]
B6 AUS-FLL FEB 0.6>0.4[1.0]
B6 AUS-JFK FEB 0.7>0.4[1.6]
B6 AUS-LAX FEB 1.4>1.1[1.9]
**B6 BOG-JFK FEB 0>0.3[0] MAR 0>0.5[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
B6 BOS-CHS FEB 0.8>0.6[1.7]
B6 BOS-LAX FEB 3>1.8[4]
B6 BUF-MCO FEB 0.5>0.3[1.0]
B6 CUN-LAX FEB 0.8>0.5[1.2]
B6 CUN-SFO FEB 0.4>0.2[0.6]
B6 DCA-FLL FEB 1.5>0.9[3]
B6 DCA-MCO FEB 1.6>1.0[2]
B6 DCA-PBI FEB 0.5>0.2[1.1]
B6 DCA-TPA FEB 0.6>0.4[1.0]
B6 DTW-JFK FEB 0.4>0.2[1.1]
B6 EWR-RDU FEB 1.7>1.0[3]
B6 EWR-SFO FEB 0.4>0[1.1]
B6 FLL-PVD FEB 0.5>0.3[0.9]
B6 FLL-RIC FEB 0.7>1.2[2.0]
B6 FLL-UIO FEB 0.9>0.4[1.0]
B6 JFK-LAX FEB 3>2[5]
B6 JFK-PAP FEB 1.6>1.0[1.9]
B6 JFK-PBI FEB 1.4>1.8[3]
B6 JFK-PTP MAR 0.4>0[0.4] APR 0.4>0[0.4]
B6 JFK-SFO FEB 2>1.0[3]
B6 LAX-PBI FEB 0.5>0.2[1.0]
B6 LAX-SLC FEB 0.8>0.4[1.1]
B6 RDU-RSW FEB 0.4>0.2[1.0]
BA ATL-LHR FEB 0.3>0[0.5]
BA AUS-LHR MAR 0.5>0.1[0.9]
BA BNA-LHR MAR 0.4>0.0[0.7]
BA BOS-LHR MAR 2>1.1[3]
BA DEN-LHR FEB 0.3>0[0.8] MAR 0.7>0.5[0.9]
BA EWR-LHR MAR 1.0>0.1[1.7]
BA JFK-LHR FEB 1.6>1.0[3] MAR 3>2[7]
BA LAS-LHR FEB 0.3>0[1.1] MAR 1.0>0.5[0.9]
BA LAX-LHR MAR 2>1.2[3]
BA LGW-MCO MAR 0.4>0.1[0.9]
BA LGW-TPA MAR 0.7>0.1[0.8]
BA LHR-MCO FEB 0.6>0[1.1] MAR 1.0>0.5[0]
BA LHR-MSY MAR 0.4>0.1[0.7]
BA LHR-ORD MAR 2>1.1[1.8]
BA LHR-PHL FEB 0.4>0[1.1] MAR 1.0>0.5[1.4]
BA LHR-PHX FEB 0.3>0[0.8] MAR 0.7>0.5[0.9]
BA LHR-SAN MAR 0.5>0.1[0.9]
BA LHR-SFO FEB 1.0>0.4[1.2]
**BF EWR-ORY FEB 0.5>0[0.7] MAR 0.7>0[0] JUL 0.6>1.0[0.7] AUG 0.6>1.0[1.0] SEP 0.5>0.8[1.0]
BR SEA-TPE FEB 0.4>0.2[0.6]
BW JFK-MBJ FEB 1.0>0[1.1] MAR 1.0>0.6[0.9]
DI AUS-LGW JUN 0.4>0[0] JUL 0.5>0[0.2] AUG 0.4>0[0] SEP 0.4>0[0]
DI BOS-LGW APR 0.6>0[1.0] MAY 0.9>0[1.0] JUN 1.3>0[0] JUL 1.3>0[0.5] AUG 1.3>0[0] SEP 1.1>0[0]
DI DEN-LGW APR 0.4>0[0.1] MAY 0.5>0[0.4] JUN 0.6>0[0] JUL 0.5>0[0.2] AUG 0.6>0[0] SEP 0.5>0[0]
DI JFK-LGW MAR 0.3>0[2] APR 2>0[3] MAY 2>0[2] JUN 3>0[0] JUL 3>0[1.4] AUG 3>0[0] SEP 3>0[0]
DI LAX-LGW APR 0.9>0[1.0] MAY 1.4>0[1.1] JUN 1.4>0[0] JUL 1.5>0[0.6] AUG 1.4>0[0] SEP 1.4>0[0]
DI LGW-MCO APR 1.3>0[0.9] MAY 0.9>0[1.0] JUN 0.9>0[0] JUL 1.0>0[0.4] AUG 1.0>0[0] SEP 0.7>0[0]
DI LGW-MIA APR 1.0>0[1.0] MAY 0.9>0[1.0] JUN 0.9>0[0] JUL 1.0>0[0.5] AUG 1.0>0[0] SEP 0.8>0[0]
DI LGW-SFO APR 0.6>0[0.6] MAY 0.7>0[0.7] JUN 1.0>0[0] JUL 1.0>0[0.5] AUG 1.0>0[0] SEP 0.9>0[0]
Looks like ANC/FAI are the BZN of 2021
**DL ANC-ATL JUN 0>1.0[0] JUL 0>1.0[0] SEP 0>1.0[0]
*DL ANC-MSP JUN 1.0>3[0.3] JUL 1.0>3[0] AUG 1.0>3[3] SEP 1.0>3[1.2]
*DL ANC-SEA APR 3>4[3] MAY 3>5[3] JUN 3>6[1.6] JUL 3>6[3] AUG 3>6[5] SEP 3>6[3]
DL ANU-ATL MAR 0.5>0.3[0.2]
**DL ATL-BZN APR 0>1.0[0.7] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
DL ATL-CUN MAR 7>6[5]
DL ATL-ELH MAR 1.0>0.5[0.5]
DL ATL-GCM MAR 1.0>0[1.2]
DL ATL-GGT MAR 1.0>0.5[0.9]
DL ATL-GIG MAR 1.0>0.6[0.9]
DL ATL-HND MAR 1.0>0.5[0]
**DL ATL-JAC JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
DL ATL-LIR MAR 1.9>1.5[1.9]
DL ATL-NAS MAR 3>1.9[4]
DL ATL-PTY MAR 1.0>0.6[0.9]
DL ATL-PVR MAR 1.9>1.0[1.0]
**DL ATL-RNO APR 0>1.0[0.6] MAY 0>1.0[0.5] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
**DL ATL-RTB MAR 0.3>0[0.2] APR 0.3>0[0.1] MAY 0.3>0[0.1]
DL ATL-SJO MAR 2>1.5[2]
DL ATL-UIO FEB 1.0>0.7[1.1] MAR 1.0>0.7[0.9]
DL BOS-CMH MAR 1.6>2[2]
DL BOS-CUN MAR 1.0>0.7[0.9]
DL BOS-RIC MAR 1.0>1.2[2]
DL CUN-JFK MAR 3>2[3]
DL DTW-HND MAR 1.0>0.5[0]
DL DTW-MBJ MAR 1.0>0.5[1.1]
DL DTW-SJD APR 1.0>0.1[0.9]
DL DUB-JFK MAR 0>0.4[0.8]
**DL FAI-MSP JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
DL HND-LAX MAR 1.0>0[0.9]
DL HND-SEA MAR 1.0>0.5[0]
DL ICN-SEA MAR 1.2>0.9[0.8]
**DL JAC-MSP JUN 0>1.0[0] JUL 0>1.0[0] SEP 0>1.0[0.1]
*DL JFK-LOS FEB 0.6>0[0.6] MAR 0.5>0[0.4]
DL JFK-MAD MAR 0>0.4[0.5]
DL JFK-MXP MAR 0.7>0.5[0.9]
DL JFK-NAS MAR 1.0>0.5[1.9]
DL JFK-PLS MAR 1.0>0.5[0.8]
DL MSP-YWG FEB 2>1.0[4]
DY AUS-CDG JUN 0.4>0[0] JUL 0.5>0[0.2] AUG 0.4>0[0]
DY BOS-CDG JUN 0.4>0[0] JUL 0.4>0[0.4] AUG 0.4>0[0] SEP 0.4>0[0]
DY CDG-DEN JUN 0.4>0[0] JUL 0.5>0[0.3] AUG 0.4>0[0] SEP 0.4>0[0]
DY CDG-JFK APR 0.9>0[0.9] MAY 0.9>0[0.9] JUN 1.0>0[0] JUL 1.0>0[0.7] AUG 1.0>0[0] SEP 0.9>0[0]
DY CDG-LAX APR 0.8>0[1.0] MAY 0.9>0[1.1] JUN 1.0>0[0] JUL 1.0>0[0.6] AUG 1.0>0[0] SEP 0.9>0[0]
DY CDG-MCO JUN 0.3>0[0] JUL 0.3>0[0.1] AUG 0.3>0[0]
EI BOS-DUB FEB 1.1>0.8[1.6] MAR 1.5>1.1[1.2]
EI BOS-SNN FEB 0.5>0[0.9] MAR 0.9>0.0[0.7]
EI DUB-EWR FEB 0.5>0[0.9] MAR 0.9>0[0.7]
EI DUB-JFK FEB 1.5>1.0[2] MAR 2>1.1[1.9]
EI DUB-ORD MAR 1.6>1.0[1.2]
EI JFK-SNN FEB 0.5>0[0.9] MAR 0.9>0[0.5]
EK JFK-MXP MAR 0.5>0[0.9]
F9 DEN-GEG FEB 0.1>0.4[0.0]
FJ LAX-NAN MAR 1.0>0[0.9]
FJ NAN-SFO MAR 0.3>0[0.3]
G4 AZA-FAR AUG 0.1>0.3[0.5]
G4 LAS-MFE JUN 0.8>0.5[0]
G4 SFB-USA JUL 0.3>0.1[0.7]
HA HNL-LIH MAR 13>12[17]
HA HNL-OGG FEB 11>9[19]
HA LIH-OGG FEB 1.0>0[3]
LA CUN-MIA MAR 0>0.3[0.2]
LA LIM-MCO MAR 0>0.2[0.9]
LH ATL-FRA MAR 0.5>0.1[0.8]
LH CLT-MUC MAR 0.5>0.1[0.9]
LH DTW-FRA MAR 0.5>0.1[0.9]
LH EWR-MUC MAR 0.7>0.5[0.9]
LH FRA-IAD MAR 1.0>0.7[0.9]
LH FRA-JFK MAR 1.2>0.9[1.7]
LH FRA-MCO MAR 0.5>0.2[0.9]
LH FRA-PHL MAR 0.5>0.1[0.8]
LH MUC-ORD MAR 0.9>0.6[0.9]
LX MIA-ZRH MAR 0.6>0.2[1.9]
Schedule extension. July vs prior year is the most useable.
NK ACY-ATL JUN 0.3>1.0[0.0] JUL 0>1.0[0] SEP 0>0.2[0]
NK ACY-FLL JUN 0.8>3[0.9] JUL 0>3[0] SEP 0>0.7[0.9]
NK ACY-MYR JUN 0.3>1.0[0.6] JUL 0>1.3[0.4] AUG 0>1.5[1.2] SEP 0>0.3[0.1]
NK ACY-RSW JUN 0.3>1.0[0.6] JUL 0>1.0[0] SEP 0>0.2[0.3]
NK ACY-TPA JUN 0.3>1.0[0.7] JUL 0>1.0[0] SEP 0>0.2[0.3]
NK ATL-AUS JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0]
NK ATL-BOS JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.6]
NK ATL-BWI JUN 0.8>3[0.9] JUL 0>3[0.5] SEP 0>0.7[0.9]
NK ATL-CLE JUN 0.3>1.0[0.6] JUL 0>1.0[0.3] SEP 0>0.2[0.8]
NK ATL-DFW JUN 0.5>2[0.9] JUL 0>2[0.5] SEP 0>0.5[1.0]
NK ATL-DTW JUN 0.8>3[1.0] JUL 0>3[1.0] SEP 0>0.7[1.0]
NK ATL-EWR JUN 0.5>2[0.9] JUL 0>2[0] SEP 0>0.5[1.0]
NK ATL-FLL JUN 1.6>6[1.5] JUL 0>6[0.5] AUG 0>6[5] SEP 0>1.4[2]
NK ATL-IAH JUN 0.3>1.0[0.6] JUL 0>1.0[0] SEP 0>0.2[0.8]
NK ATL-LAS JUN 0.5>2[0] JUL 0>2[0.4] AUG 0>2[1.9] SEP 0>0.5[0.8]
NK ATL-LAX JUN 0.5>2[0] JUL 0>2[0.5] SEP 0>0.5[2]
NK ATL-MCO JUN 0.5>2[0.6] JUL 0>2[0.5] AUG 0>2[1.9] SEP 0>0.5[0.8]
NK ATL-MSP JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.7]
NK ATL-ORD JUN 0.3>1.0[0.6] JUL 0>1.0[0.5] SEP 0>0.2[1.0]
NK ATL-PHL JUN 0.3>1.0[0.6] JUL 0>1.0[0] SEP 0>0.2[1.0]
NK ATL-TPA JUN 0.5>2[0.9] JUL 0>2[0] AUG 0>2[1.9] SEP 0>0.5[0.8]
NK AUS-BNA JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.9] SEP 0>0.2[0]
NK AUS-BWI JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0]
NK AUS-CUN JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.5] SEP 0>0.2[0]
NK AUS-DEN JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0]
NK AUS-DTW JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0]
NK AUS-EWR JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0]
NK AUS-FLL JUN 0.3>1.0[0.6] JUL 0>1.0[0] SEP 0>0.2[0.7]
NK AUS-LAS JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.9] SEP 0>0.2[0.5]
NK AUS-LAX JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.7]
NK AUS-MCO JUN 0.4>1.9[0.9] JUL 0>2[0.4] AUG 0>2[1.5] SEP 0>0.5[0.7]
NK AUS-MSY JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0]
NK AUS-ORD JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0]
NK AXM-FLL JUN 0.1>0.4[0] JUL 0>0.4[0] AUG 0>0.5[0]
NK BAQ-FLL JUN 0.1>0.4[0] JUL 0>0.4[0] AUG 0>0.5[0]
NK BDL-FLL JUN 0.5>2[0] JUL 0>2[0.4] AUG 0>2[1.0] SEP 0>0.5[0.2]
NK BDL-MCO JUN 0.5>2[0] JUL 0>2[0] SEP 0>0.5[0.6]
NK BDL-MYR JUN 0.5>1.3[0.6] JUL 0>1.8[0.2] SEP 0>0.5[0.6]
NK BGA-FLL JUN 0.1>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0]
NK BNA-BWI JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0]
NK BNA-CUN JUN 0.1>0.4[0] JUL 0>0.4[0] AUG 0>0.5[0.4]
NK BNA-EWR JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.1]
NK BNA-FLL JUN 0.4>1.9[0.6] JUL 0>2[0.3] AUG 0>2[1.0] SEP 0>0.5[0.4]
NK BNA-LAS JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.9] SEP 0>0.2[0.5]
NK BNA-LAX JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.8]
NK BNA-MCO JUN 0.4>1.9[0.6] JUL 0>2[0.4] AUG 0>2[1.4] SEP 0>0.5[0.3]
NK BNA-MSY JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.9] SEP 0>0.2[0]
NK BNA-TPA JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0]
NK BOG-FLL JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[1.0]
NK BOG-MCO JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0.3]
NK BOS-BWI JUN 1.1>4[0] JUL 0>4[0] SEP 0>0.9[1.4]
NK BOS-CLE JUL 0>0.6[0] SEP 0>0.2[0]
NK BOS-DFW JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0]
NK BOS-DTW JUL 0>0.6[0] SEP 0>0.2[0]
NK BOS-EWR JUN 0.5>2[0] JUL 0>2[0] AUG 0>2[0] SEP 0>0.5[0]
NK BOS-FLL JUN 0.5>2[0.8] JUL 0>2[0.4] SEP 0>0.5[0.7]
NK BOS-LAS JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.6]
NK BOS-MCO JUN 0.5>2[0.5] JUL 0>2[0] SEP 0>0.5[0.7]
NK BOS-MSY JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0]
NK BOS-MYR JUN 0.3>1.0[0.6] JUL 0>1.5[0.3] AUG 0>1.5[1.7] SEP 0>0.4[0.6]
NK BOS-ORD JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.3]
NK BQN-FLL JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.9]
NK BQN-MCO JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.9]
NK BUR-LAS JUN 0.3>1.0[0.6] JUL 0>1.0[0.4] AUG 0>1.0[1.8] SEP 0>0.2[0.5]
NK BWI-CLT JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.9] SEP 0>0.2[0]
NK BWI-CUN JUN 0.3>1.0[0] JUL 0>1.0[0.1] AUG 0>1.0[0.9] SEP 0>0.2[0]
NK BWI-DEN JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0]
NK BWI-DFW JUN 0.3>1.0[0.5] JUL 0>1.0[0] SEP 0>0.2[0.6]
NK BWI-DTW JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0]
NK BWI-FLL JUN 1.1>4[0.9] JUL 0>4[0] SEP 0>0.9[1.0]
NK BWI-IAH JUN 0.3>1.0[0.6] JUL 0>1.0[0] SEP 0>0.2[0.1]
NK BWI-LAS JUN 0.3>1.0[0.5] JUL 0>1.0[0] SEP 0>0.2[0.7]
NK BWI-LAX JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[1.0]
NK BWI-MBJ JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.9] SEP 0>0.2[0]
NK BWI-MCO JUN 0.8>3[1.0] JUL 0>3[0.5] AUG 0>3[4] SEP 0>0.7[1.0]
NK BWI-MSP JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0]
NK BWI-MSY JUN 0.3>1.0[0.5] JUL 0>1.0[0] SEP 0>0.2[0]
NK BWI-MYR JUN 0.4>1.1[0.6] JUL 0>1.8[0] AUG 0>2[1.9] SEP 0>0.5[0.6]
NK BWI-ORD JUN 0.3>1.0[0.6] JUL 0>1.0[0.5] AUG 0>1.0[1.9] SEP 0>0.2[0.4]
NK BWI-SAL JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.9] SEP 0>0.2[0]
NK BWI-SJU JUN 0.5>2.0[0] JUL 0>2.0[0] AUG 0>2.0[1.9] SEP 0>0.5[0.8]
NK BWI-TPA JUN 0.3>1.4[0.5] JUL 0>1.6[0] AUG 0>1.5[2.0] SEP 0>0.4[0.2]
NK CAK-MCO JUN 0.3>1.0[0.5] JUL 0>1.0[0.2] SEP 0>0.2[0.7]
NK CAP-FLL JUN 0.1>0.4[0] JUL 0>0.4[0] AUG 0>0.5[0]
NK CLE-DFW JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.7]
NK CLE-EWR JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.1]
NK CLE-FLL JUN 0.5>2[0.9] JUL 0>2[0] AUG 0>2[1.9] SEP 0>0.5[0.8]
NK CLE-LAS JUN 0.5>2[0.5] JUL 0>2[0] AUG 0>2[1.9] SEP 0>0.5[0.8]
NK CLE-LAX JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.8]
NK CLE-MCO JUN 0.5>2[0.9] JUL 0>2[0.4] AUG 0>2[3] SEP 0>0.5[0.7]
NK CLE-MSY JUN 0.1>0.4[0] JUL 0>0.4[0] AUG 0>0.5[0.4]
NK CLE-MYR JUN 0.3>1.0[0.5] JUL 0>1.6[0] AUG 0>1.5[1.8] SEP 0>0.4[0.6]
NK CLE-TPA JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.6]
NK CLO-FLL JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[1.0]
NK CLT-EWR JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.1]
NK CLT-FLL JUN 0.3>1.0[0.6] JUL 0>1.0[0.3] SEP 0>0.2[0.5]
NK CLT-MCO JUN 0.3>1.0[0.6] JUL 0>1.0[0] SEP 0>0.2[0.6]
NK CMH-FLL JUN 0.3>1.0[0.6] JUL 0>1.0[0] SEP 0>0.2[0.7]
NK CMH-LAS JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.6]
NK CMH-MCO JUN 0.5>2[0.9] JUL 0>2[0.4] AUG 0>2[1.0] SEP 0>0.5[0.7]
NK CMH-MSY JUN 0.1>0.4[0] JUL 0>0.4[0] AUG 0>0.5[0.4]
NK CMH-MYR JUN 0.1>0.4[0] JUL 0>0.4[0] AUG 0>0.5[0.3]
NK CRW-MCO JUN 0.1>0.4[0] JUL 0>0.4[0.1] AUG 0>0.5[0.4]
NK CTG-FLL JUN 0.1>0.6[0] JUL 0>0.6[0] AUG 0>0.5[0]
NK CTG-MCO JUN 0.1>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0]
NK CUN-DFW JUN 0.3>1.0[0] JUL 0>1.0[0.2] SEP 0>0.2[0]
NK CUN-DTW JUN 0.3>1.0[0] JUL 0>1.0[0.1] AUG 0>1.0[0.9] SEP 0>0.2[0]
NK CUN-FLL JUN 0.3>1.7[0] JUL 0>2[0] AUG 0>2[1.0] SEP 0>0.5[1.0]
NK CUN-IAH JUN 0.3>1.7[0] JUL 0>2[0] AUG 0>2[1.0] SEP 0>0.5[0.2]
NK CUN-MCO JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
NK CUN-ORD JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0]
NK CUN-PHL JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.9] SEP 0>0.2[0]
NK CUN-PIT JUN 0.1>0.4[0] JUL 0>0.4[0] AUG 0>0.5[0.4]
NK DEN-DTW JUN 0.3>1.0[0.0] JUL 0>1.0[0] SEP 0>0.2[0.7]
NK DEN-IAH JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.7]
NK DEN-LAS JUN 0.5>2[0.9] JUL 0>2[0.5] AUG 0>2[1.9] SEP 0>0.5[0.8]
NK DEN-LAX JUN 0.5>2[0] JUL 0>2[0] AUG 0>2[1.0] SEP 0>0.5[0.8]
NK DEN-MSP JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.8]
NK DEN-ORD JUN 0.3>1.0[0.1] JUL 0>1.0[0.3] AUG 0>1.0[1.9] SEP 0>0.2[1.0]
NK DFW-DTW JUN 0.3>1.0[0.7] JUL 0>1.0[0.4] AUG 0>1.0[1.4] SEP 0>0.2[1.0]
NK DFW-FLL JUN 0.8>3[0.6] JUL 0>3[0] SEP 0>0.7[1.0]
NK DFW-LAS JUN 1.1>4[0.5] JUL 0>4[0] SEP 0>0.9[1.8]
NK DFW-LAX JUN 1.1>4[0.6] JUL 0>4[0.5] SEP 0>0.9[2]
NK DFW-LGA JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.7]
NK DFW-MCO JUN 0.5>3[0.6] JUL 0>3[0.5] SEP 0>0.7[0.8]
NK DFW-MSY JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.3]
NK DFW-MYR JUL 0>0.4[0] AUG 0>0.5[0.4]
NK DFW-ORD JUN 0.5>2[0] JUL 0>2[0.5] AUG 0>2[1.9] SEP 0>0.5[0.8]
NK DFW-PHL JUN 0.3>1.0[0] JUL 0>1.0[0.4] SEP 0>0.2[0.7]
NK DFW-PHX JUN 0.3>1.0[0.8] JUL 0>1.0[0.3] SEP 0>0.2[1.0]
NK DFW-SAN JUN 0.3>0.5[0] JUL 0>1.0[0] SEP 0>0.2[0.3]
NK DFW-SJD JUL 0>0.6[0] AUG 0>0.6[0.5]
NK DFW-TPA JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.6]
NK DTW-FLL JUN 0.8>3[0.9] JUL 0>3[0.2] SEP 0>0.7[0.8]
NK DTW-IAH JUN 0.3>1.0[0.2] JUL 0>1.0[0] SEP 0>0.2[0.7]
NK DTW-LAS JUN 1.1>4[1.0] JUL 0>4[1.0] SEP 0>0.9[1.1]
NK DTW-LAX JUN 0.5>2[0.1] JUL 0>2[0.5] SEP 0>0.5[1.0]
NK DTW-LGA JUN 0.5>2[1.8] JUL 0>2[0.4] AUG 0>2[1.9] SEP 0>0.5[0]
NK DTW-MCI JUN 0.3>1.0[0.6] JUL 0>1.0[0.4] AUG 0>1.0[0.9] SEP 0>0.2[0]
NK DTW-MCO JUN 1.1>4[0.7] JUL 0>4[0.5] AUG 0>4[3] SEP 0>0.9[0.8]
NK DTW-MSP JUN 0.3>1.0[0.6] JUL 0>1.0[0.3] SEP 0>0.2[0]
NK DTW-MSY JUN 0.3>1.0[0.9] JUL 0>1.0[0] SEP 0>0.2[0.3]
NK DTW-MYR JUN 0.4>1.9[0.7] JUL 0>2[0.3] AUG 0>2[1.1] SEP 0>0.5[0.7]
NK DTW-OAK JUL 0>0.6[0] SEP 0>0.2[0]
NK DTW-PHL JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.7]
NK DTW-SAN JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.3]
NK DTW-SEA JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.9] SEP 0>0.2[0]
NK DTW-TPA JUN 0.3>1.0[0.8] JUL 0>1.0[0.4] AUG 0>1.0[1.1] SEP 0>0.2[0.6]
NK EWR-FLL JUN 1.1>4[0.9] JUL 0>4[0.7] AUG 0>4[2] SEP 0>0.9[1.3]
NK EWR-IAH JUN 0.3>1.0[0.6] JUL 0>1.0[0] SEP 0>0.2[0.7]
NK EWR-LAS JUN 0.5>2[0] JUL 0>2[0] AUG 0>2[1.0] SEP 0>0.5[0.8]
NK EWR-MCO JUN 1.1>4[0.9] JUL 0>4[0] SEP 0>0.9[1.3]
NK EWR-MSY JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.9] SEP 0>0.2[0]
NK EWR-MYR JUN 0.8>3[0.9] JUL 0>3[0] SEP 0>0.7[0.9]
NK EWR-PBI JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
NK EWR-RSW JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.5]
NK EWR-SJU JUN 0.5>2.0[0] JUL 0>2.0[0] AUG 0>2.0[1.9] SEP 0>0.5[1.0]
NK EWR-TPA JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.7]
NK FLL-GUA JUN 0.4>1.9[0] JUL 0>2[0] AUG 0>2[1.5] SEP 0>0.5[1.0]
NK FLL-GYE JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[1.0]
NK FLL-IAH JUN 0.5>2[0.8] JUL 0>2[0.3] SEP 0>0.5[1.0]
NK FLL-IND JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
NK FLL-KIN JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.9] SEP 0>0.2[0.4]
NK FLL-LAS JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[1.0]
NK FLL-LAX JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[1.0]
NK FLL-LBE JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.1]
NK FLL-LGA JUN 1.1>4[0.9] JUL 0>4[0] SEP 0>0.9[1.3]
NK FLL-LIM JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.9] SEP 0>0.2[0.1]
NK FLL-MBJ JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.8]
NK FLL-MCO JUN 0.5>2[0.0] JUL 0>2[0] SEP 0>0.5[0]
NK FLL-MDE JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[1.0]
NK FLL-MGA JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[1.0]
NK FLL-MSP JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
NK FLL-MSY JUN 0.5>2[1.0] JUL 0>2[0.5] AUG 0>2[1.9] SEP 0>0.5[0.4]
NK FLL-MYR JUN 0.5>2[0.6] JUL 0>2[0] AUG 0>2[1.9] SEP 0>0.5[0.2]
NK FLL-ORD JUN 0.8>3[1.0] JUL 0>3[1.0] SEP 0>0.7[1.3]
NK FLL-PAP JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.8]
NK FLL-PHL JUN 0.8>3[1.0] JUL 0>3[0.4] AUG 0>3[4] SEP 0>0.7[1.0]
NK FLL-PIT JUN 0.5>2[0.9] JUL 0>2[0.3] AUG 0>2[1.9] SEP 0>0.5[0.7]
NK FLL-PTY JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[1.0]
NK FLL-RDU JUN 0.3>1.0[0.5] JUL 0>1.0[0.4] SEP 0>0.2[0.6]
NK FLL-RIC JUN 0.3>1.0[0.5] JUL 0>1.0[0] SEP 0>0.2[0.5]
NK FLL-SAL JUN 0.3>1.7[0] JUL 0>2[0] AUG 0>2[1.2] SEP 0>0.5[1.0]
NK FLL-SAP JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[1.0]
NK FLL-SDQ JUN 0.5>2[0] JUL 0>2[0] AUG 0>2[1.9] SEP 0>0.5[1.0]
NK FLL-SJO JUN 0.3>1.7[0] JUL 0>2[0] AUG 0>2[1.9] SEP 0>0.5[1.0]
NK FLL-SJU JUN 0.8>3.0[0.8] JUL 0>3.0[0.4] AUG 0>3.0[2.0] SEP 0>0.7[1.0]
NK FLL-STI JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.5] SEP 0>0.2[0.6]
NK FLL-TPA JUN 0.5>2[0] JUL 0>2[0] SEP 0>0.5[0]
NK GSO-MCO JUN 0.1>0.6[0] JUL 0>0.6[0.4] AUG 0>0.5[0]
NK GUA-MCO JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.9] SEP 0>0.2[0]
NK IAG-MYR JUN 0.1>0.6[0.3] JUL 0>0.6[0] AUG 0>0.5[0.4]
NK IAH-LAS JUN 0.8>3[0.7] JUL 0>3[0.7] SEP 0>0.7[0.8]
NK IAH-LAX JUN 0.8>3[0.6] JUL 0>3[0] SEP 0>0.7[1.3]
NK IAH-MYR JUN 0.1>0.4[0] JUL 0>0.4[0] AUG 0>0.5[0.3]
NK IAH-OAK JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.6]
NK IAH-ORD JUN 0.5>2[0.1] JUL 0>2[0.3] SEP 0>0.5[0.7]
NK IAH-SAL JUN 0.1>0.4[0] JUL 0>0.4[0] AUG 0>0.5[0.4]
NK IAH-SAP JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.4] SEP 0>0.2[0]
NK IAH-SJD JUN 0.1>0.9[0] JUL 0>1.0[0] AUG 0>1.0[0.5] SEP 0>0.2[0]
NK IND-LAS JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.4]
NK IND-MCO JUN 0.3>1.0[0.6] JUL 0>1.0[0.4] SEP 0>0.2[0.4]
NK IND-RSW JUN 0.1>0.6[0] JUL 0>0.6[0] AUG 0>0.5[0.9]
NK IND-TPA JUN 0.1>0.4[0] JUL 0>0.4[0] AUG 0>0.5[1.0]
NK LAS-LAX JUN 0.5>3[0.6] JUL 0>3[0.5] SEP 0>0.7[1.0]
NK LAS-MCI JUN 0.3>1.7[0.9] JUL 0>2[0.4] AUG 0>2[1.9] SEP 0>0.5[0.6]
NK LAS-MCO JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.7]
NK LAS-MSP JUN 0.5>2[0] JUL 0>2[0] AUG 0>2[1.0] SEP 0>0.5[0.7]
NK LAS-MSY JUN 0.3>1.3[0.6] JUL 0>1.4[0] AUG 0>1.5[0.9] SEP 0>0.3[0.5]
NK LAS-OAK JUN 1.1>4[0.7] JUL 0>4[0.4] SEP 0>0.9[1.2]
NK LAS-ORD JUN 0.8>3[0.8] JUL 0>3[0.7] SEP 0>0.7[2]
NK LAS-PDX JUN 0.5>3[0.6] JUL 0>3[0.4] SEP 0>0.7[0.8]
NK LAS-PHL JUN 0.3>1.0[0.0] JUL 0>1.0[0] SEP 0>0.2[0.7]
NK LAS-PIT JUN 0.3>1.0[0.5] JUL 0>1.0[0] SEP 0>0.2[0.7]
NK LAS-SAN JUN 0.8>3[0.8] JUL 0>3[0.4] SEP 0>0.7[1.1]
NK LAS-SEA JUN 0.8>3[1.0] JUL 0>3[0.5] SEP 0>0.7[1.1]
NK LAS-SMF JUN 0.5>2[0.6] JUL 0>2[0.4] AUG 0>2[3] SEP 0>0.5[0.9]
NK LAS-SNA JUN 0.5>2[0] JUL 0>2[0] AUG 0>2[0] SEP 0>0.5[0]
NK LAS-TPA JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.7]
NK LAX-MCI JUN 0.3>1.0[0.5] JUL 0>1.0[0] SEP 0>0.2[1.0]
NK LAX-MSP JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.1]
NK LAX-MSY JUN 0.3>1.4[0.5] JUL 0>1.6[0] AUG 0>1.5[1.0] SEP 0>0.4[0.6]
NK LAX-OAK JUN 0.5>2[0.9] JUL 0>2[0] AUG 0>2[1.9] SEP 0>0.5[0.8]
NK LAX-ORD JUN 0.5>2[1.0] JUL 0>2[1.0] SEP 0>0.5[2]
NK LAX-PHL JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.7]
NK LAX-PIT JUN 0.3>1.0[0.6] JUL 0>1.0[0] AUG 0>1.0[1.9] SEP 0>0.2[0.5]
NK LAX-SJD JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
NK LBE-MCO JUN 0.3>1.0[0.6] JUL 0>1.0[0.4] SEP 0>0.2[0.1]
NK LGA-MCO JUN 0.3>1.7[0.9] JUL 0>2[0] AUG 0>2[1.0] SEP 0>0.5[0.7]
NK LGA-MYR JUN 0.5>2[0.6] JUL 0>2[0] SEP 0>0.5[0.7]
NK LGA-ORD JUN 0.3>1.7[0] JUL 0>2[0] AUG 0>2[1.0] SEP 0>0.5[0.7]
NK MBJ-MCO JUN 0.1>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0.4]
NK MCI-MCO JUN 0.3>1.0[0.9] JUL 0>1.0[0.4] AUG 0>1.0[1.3] SEP 0>0.2[0.7]
NK MCI-MYR JUN 0.1>0.4[0] JUL 0>0.4[0] AUG 0>0.5[0.3]
NK MCO-MDE JUN 0.1>0.4[0] JUL 0>0.4[0] AUG 0>0.5[0]
NK MCO-MSP JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.3]
NK MCO-MSY JUN 0.5>2[0.6] JUL 0>2[0] AUG 0>2[1.9] SEP 0>0.5[0.6]
NK MCO-MYR JUN 0.1>0.4[0] JUL 0>0.4[0] AUG 0>0.5[0.3]
NK MCO-ORD JUN 0.5>2[0.9] JUL 0>2[0.5] AUG 0>2[1.0] SEP 0>0.5[0.7]
NK MCO-PHL JUN 0.8>3[1.0] JUL 0>3[0.5] SEP 0>0.7[1.3]
NK MCO-PUJ JUN 0.1>0.4[0] JUL 0>0.4[0] AUG 0>0.5[0]
NK MCO-RDU JUN 0.3>1.0[0.6] JUL 0>1.0[0] AUG 0>1.0[1.9] SEP 0>0.2[0]
NK MCO-RIC JUN 0.3>1.0[0.6] JUL 0>1.0[0.4] SEP 0>0.2[0]
NK MCO-SJO JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.9] SEP 0>0.2[0]
NK MCO-SJU JUN 1.1>4[1.0] JUL 0>4[0.5] AUG 0>4[3.9] SEP 0>0.9[2.3]
NK MSP-MYR JUN 0.1>0.4[0] JUL 0>0.4[0] AUG 0>0.5[0.3]
NK MSY-ORD JUN 0.3>1.0[0.6] JUL 0>1.0[0] SEP 0>0.2[0.3]
NK MSY-PHL JUN 0.1>0.6[0] JUL 0>0.6[0] AUG 0>0.5[0.6]
NK MSY-RDU JUN 0.3>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0.9] SEP 0>0.2[0]
NK MSY-SAP JUN 0.1>0.4[0] JUL 0>0.4[0] AUG 0>0.5[0.4]
NK MSY-TPA JUN 0.3>1.0[0.9] JUL 0>1.0[0] SEP 0>0.2[0.1]
NK MYR-ORD JUN 0.3>1.0[0.7] JUL 0>1.0[0.2] SEP 0>0.2[0.7]
NK MYR-PHL JUN 0.4>1.4[0.6] JUL 0>1.4[0] AUG 0>1.5[1.0] SEP 0>0.3[0.7]
NK MYR-PIT JUN 0.4>1.2[0.5] JUL 0>1.6[0] AUG 0>1.5[1.7] SEP 0>0.4[0.7]
NK OAK-ORD JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.4]
NK OAK-SNA JUN 0.5>2[0] JUL 0>2[0] AUG 0>2[0] SEP 0>0.5[0]
NK ORD-RSW JUN 0.3>1.0[0.1] JUL 0>1.0[0.4] SEP 0>0.2[0.6]
NK ORD-SAN JUN 0.3>1.0[0] JUL 0>1.0[0] SEP 0>0.2[0.7]
NK ORD-TPA JUN 0.3>1.0[0.5] JUL 0>1.0[0.4] SEP 0>0.2[0.7]
NK PHL-SJU JUN 0.5>2.0[0.5] JUL 0>2.0[0] AUG 0>2.0[1.9] SEP 0>0.5[1.0]
NK PHX-SNA APR 0.4>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
NK SMF-SNA MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
OS ORD-VIE MAR 0.4>0.2[0.7]
PD BOS-YTZ FEB 0.9>0[3] MAR 3>0[3]
PD EWR-YTZ FEB 2>0[8] MAR 7>0[7]
PD IAD-YTZ MAR 0.9>0[0.7]
PD MDW-YTZ FEB 0.6>0[2] MAR 2>0[1.9]
QR ATL-DOH APR 1.0>0[1.0] MAY 1.0>0[1.0]
RJ AMM-DTW AUG 0>0.3[0.4]
RJ AMM-JFK JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0]
RJ AMM-ORD APR 1.0>0.6[0.9] MAY 1.0>0.7[0.9] SEP 1.0>0.7[1.1]
RJ DTW-YUL JUL 0.3>0[0.1] AUG 0.3>0[0]
SY MSP-PSP FEB 1.0>0.6[1.0]
TB BRU-MIA APR 0>0.3[0] JUN 0>0.3[0.2] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0]
TN CDG-LAX MAR 0.4>0[0.4]
TN LAX-PPT MAR 0.6>0.4[1.1]
TS FLL-YUL MAR 0.6>0.1[0.9] APR 0.6>0.2[1.0]
UA AUS-IAH JUL 10>9[1.9] SEP 10>9[8]
UA BZN-IAH MAR 0.3>0.8[0.7]
UA CHS-DEN APR 1.0>2[1.0]
**UA DEN-HOB MAR 0.8>0[0.8] APR 1.0>0[0.9] MAY 1.0>0[0.8]
**UA DEN-MMH FEB 0.5>0[0.6] MAR 0.5>0[0.9]
UA EWR-JAC MAR 0.8>0.2[0.9]
UA EWR-PQI MAR 0.9>0.6[1.6]
UA GRU-ORD MAR 0.2>0.4[0.9]
UA IAH-SAL FEB 2.0>3[2]
UA JFK-LAX FEB 1.7>0.0[1.9] MAR 1.7>0.9[0]
UA JFK-SFO FEB 1.7>0.0[1.9] MAR 1.7>0.9[0]
**UA LAX-MMH FEB 0.8>0[0.9] MAR 0.9>0[0.9]
**UA MMH-SFO FEB 0.5>0[0.5] MAR 0.5>0[0.9]
**UA SFO-STS APR 1.0>0[1.0] MAY 1.0>0[1.0]
VB CUN-IAH FEB 0.3>0[0.3]
VB CUN-MIA FEB 1.0>0[0] MAR 1.0>0[0]
VB LAX-MEX FEB 0.4>0[0.4]
VB MEX-ORD FEB 0.3>0[0.3]
VH MDE-MIA FEB 1.0>0.7[1.5]
**WN LIH-OAK MAR 0.7>0[0.4] APR 1.0>0[0.9] MAY 1.0>0[1.0]
**WN LIH-SJC MAR 0.7>0[0.5] APR 1.0>0[1.0] MAY 1.0>0[1.0]
WS ATL-YYC MAR 0.8>0[0.9]
WS AZA-YYC APR 0.2>0[0.3]
WS BNA-YYZ MAR 0.7>0[0.8]
WS BOS-YYZ MAR 1.5>0[1.9] APR 1.9>0.3[2]
WS DEN-YYC APR 0.3>0[0.5]
WS FLL-YYC FEB 0.3>0[0.2] MAR 0.2>0[0.3] APR 0.2>0[0.3]
WS FLL-YYZ FEB 2>0[3]
WS HNL-YVR FEB 1.6>0.1[1.9]
WS HNL-YYC FEB 0.4>0.1[0.4]
WS IAH-YYC MAR 1.4>0[1.6] APR 1.6>0.3[1.8]
WS JFK-YYC APR 0.8>0.2[0.9]
WS KOA-YVR FEB 0.8>0.1[1.0]
WS LAX-YEG FEB 0.8>0[0.9] MAR 0.8>0[0.9]
WS LAX-YVR FEB 2>0[3]
WS LAX-YYC FEB 1.6>0.3[1.9]
WS LAX-YYZ FEB 0.8>0[1.0] MAR 0.9>0.7[0.9]
WS LGA-YYZ MAR 5>0.3[6]
WS MCO-YHZ FEB 0.3>0[0.2] MAR 0.2>0[0.4] APR 0.2>0[0.4]
WS MCO-YOW FEB 0.4>0[0.4] MAR 0.4>0[0.4] APR 0.4>0[0.4]
WS MCO-YWG FEB 0.3>0[0.3] MAR 0.3>0[0.3] APR 0.3>0[0.3]
WS MCO-YYZ FEB 2>0.1[3] MAR 2>1.9[2]
WS OGG-YEG FEB 0.3>0[0.3] MAR 0.3>0[0]
WS OGG-YVR FEB 1.6>0.1[2.0]
WS OGG-YYC FEB 0.7>0.1[0.8]
WS PHX-YEG FEB 1.3>0[1.4]
WS PHX-YLW FEB 0.3>0[0.3] MAR 0.3>0[0.2] APR 0.2>0[0.3]
WS PHX-YQR FEB 0.3>0[0.3] MAR 0.3>0[0.4] APR 0.2>0[0.4]
WS PHX-YVR FEB 0.8>0[1.0]
WS PHX-YWG FEB 0.3>0[0.3] MAR 0.3>0[0.3] APR 0.2>0[0.3]
WS PHX-YXE FEB 0.4>0[0.4] MAR 0.4>0[0.4] APR 0.3>0[0.4]
WS PHX-YYC FEB 3>0.6[3]
WS PHX-YYZ FEB 0.5>0[0.6] MAR 0.5>0[0.5] APR 0.5>0[0.6]
WS PSP-YEG FEB 0.8>0[1.0]
WS PSP-YVR FEB 1.8>0[2]
WS PSP-YWG FEB 0.2>0[0.2] MAR 0.2>0[0.3] APR 0.2>0[0.3]
WS PSP-YYC FEB 2>0.2[3]
WS RSW-YYZ FEB 1.4>0.2[1.6]
WS SAN-YVR MAY 0.3>0[0.1]
WS SAN-YYC MAR 0.7>0[0.8] APR 0.7>0.1[0.9]
WS SNA-YVR MAR 0.9>0[0.9]
WS TPA-YYZ MAR 0.9>0[0.9] APR 1.0>0.1[1.2]
X4 GST-JNU APR 0>1.7[3] MAY 0>2[3]
