Anonz263x wrote:If the horizontal stabilisers trim were not touched on Alaska flight 261, would they have not crashed as I did read that the horizontal stabiliser being freed caused it to pitch down or would it have failed any ways regardless if the trim wasnt touched and the pilots avoided trying to free it?
cedarjet wrote:The crew were criticised because of a couple of lines on the CVR about trying to be test pilots, and in answer to your question, it is possible the tail might have held together if they hadn’t touched anything but the aeroplane was basically unflyable. Really awful accident. Shame on Alaska Airlines because it really was related to cost cutting and insufficient maintenance (albeit of course that like the pilots experimenting, if they’d known the outcome of their actions I’m sure they wouldn’t have taken that path).
KFLLCFII wrote:Anonz263x wrote:If the horizontal stabilisers trim were not touched on Alaska flight 261, would they have not crashed as I did read that the horizontal stabiliser being freed caused it to pitch down or would it have failed any ways regardless if the trim wasnt touched and the pilots avoided trying to free it?
The jackscrew issue was a hole in the ground waiting to happen.
It just happened to be Alaska 261.
WayexTDI wrote:KFLLCFII wrote:Anonz263x wrote:If the horizontal stabilisers trim were not touched on Alaska flight 261, would they have not crashed as I did read that the horizontal stabiliser being freed caused it to pitch down or would it have failed any ways regardless if the trim wasnt touched and the pilots avoided trying to free it?
Basically, the structural integrity of the jackscrew was hanging by a thread; I know it's a very bad pun, but it pretty summarizes it.
Had they not touch the trim, the jackscrew might have held... MAYBE.
But, a burst of wind on final might have popped it as well.
FlyHappy wrote:It seems crazy to lay any criticism at the feet of the pilots, only being clairvoyant could they have avoided touching the trim. They did so in conjunction with direct consultation in real time with company engineering.
CitizenJustin wrote:When did the pilots first notice the problem? I’m assuming the incoming flight had no issues? This is one of those truly haunting accidents. I can’t help but think what the passengers must have gone through.
Aside from the people that lost their lives, I find the treatment of the mechanic whistleblower to be particularly egregious. Profits over people mentality will never change until such a time that whistleblowers are more rewarded vs punished. The fact that he called for jackscrew replacement a mere 5 years after the aircraft was delivered (yes, disputed by a subsequent mechanic), and 3 years before the crash, strongly suggests a serious problem with the maintenance culture.
The FAA didn't shine, either.
tu204 wrote:Pretty sure IF they knew what the problem was they could have landed it safely.
In particular slower speeds to reduce the load on the jackscrew. Plus wouldn't extending flaps a bit create a nose-up tendency that would have partially lessened the nose-down attitude due to the trim being stuck?
SteelChair wrote:I've always wondered if had just accepted that the stab was jammed, if they could have landed the aircraft at an extremely high speed ala Delta 37. Especially if they had enough fuel (unlikely) to get to Edward's long dry lake bed runway.
