steex wrote:I don't know for certain without seeing what you've seen, but I believe what this reflects is departures utilizing 28R from N5 in west flow. This operation allows 28C to be used for arrivals, which can then do an end-around taxi via P and EE to reach the terminals without crossing the active departure runway. This still allows something like 9,700' of runway from the shortened 28R for departures, which is ample for a vast majority of operations (and if they were using 28C, which is not typically a departure runway in west flow, its 10,800' would also be plenty).
It would be accommodated if a heavy departure needed or requested the full length of 28R, but minimizing the interaction between arrival and departure traffic both reduces controller workload and enhances safety.
william wrote:I think its a brilliant operations move. Keeps the landing flow continuous and no aircraft crossing in front an aircraft waiting for takeoff. ATL and DFW have end of runway taxiways on part of their configurations, I wander why the FAA does not incorporate this into their operations.
ORD14R wrote:Would 28C ever be used for departures during snow?
freakyrat wrote:Before ORD reconfigured the Runways they would also sterilize a part of RWY 32R and use it as a taxiway for aircraft landing on 28R. They would run takeoffs on 32R as aircraft coming off of 28R would pass behind them turning into the ramp.
as739x wrote:And O'hare controllers always got a kick when I requested for 28R full length.....in a Caravan!.
mpdpilot wrote:I have always thought O'Hare was fascinating with all their unique operations.
Before the new runway layout started taking shape they would often depart off 32L at T10.
While I am sure not the only airport that does this, I do feel like O'Hare does it more than other airports, is that true?
jetblastdubai wrote:mpdpilot wrote:I have always thought O'Hare was fascinating with all their unique operations.
Pre-new runways, ORD used over 20 different landing runway configurations depending on the wind, ceiling, visibility and runway condition (wet/dry) or a combination of factors.
When the winds allowed, 32L from T10 was probably the most common departure runway. It allowed us to free-roll departures while landing on the old 9R (10L) or old 27L (28R). Most importantly, it eliminated the need to cross a landing runway. From T-10 the remaining runway was 8,800'
DXB departs 12R from K3, K4 and K5 (when possible) to avoid a separation penalty with 12L arrivals, even in VFR. Unless things have changed since I left DXB, it was determined locally that departing from the full length of 12R was too close to the threshold of 12L to be considered separate runways even though there were parallel and did not intersect. A 12R full length departure could not roll if a 12L arrival was within 2 miles from touchdown. From K3,4 or 5 there was no restriction.
mpdpilot wrote:
Also, on the topic of departures off 28C/10C, do they use that runway during times of high cross-wind? A few weeeks back they were doing arrivals on the 22s and departing on 28C instead of 28R at N5.
mpdpilot wrote:freakyrat wrote:Before ORD reconfigured the Runways they would also sterilize a part of RWY 32R and use it as a taxiway for aircraft landing on 28R. They would run takeoffs on 32R as aircraft coming off of 28R would pass behind them turning into the ramp.
I think you meant 32L as there was no good way to taxi around 28R (also I believe it was 27R back then) for departure. Though I am sure if aircraft were arriving on 9L they could use 32R to exit.
Also, for nostalgia purposes, the old layout:
http://commons.wikimedia.org/wiki/File:ORD_airport_map.gif
I'm no controller, just a casual observer, but I have noticed this happen quite regularly when landing the 22's. Not sure the reason for it though, perhaps someone more in the know can satiate my thirst for knowledge.
Armadillo1 wrote:is there any restrictions to cross runway behind taking off to avoid engines blow?
NWAJT8D wrote:Two weeks ago a 777 took off on 28R full length and so did we (CRJ7) right behind it. I wondered why we didn't go from N5 like everyone else but then the wake turbulence avoidance lesson from ground school came back to me. Another time in an E145 we taxied onto 28R via N4, did a U-turn on the runway in front of everyone else lined up at N5, and took off from there. Fun times at O'Hare.
richiemo wrote:Great, thx for info team. I guess this is part of the beauty of having a 13,000 ft runway (28R). Are there any other similar setups at any other US airports, i.e. where departing flights launch from somewhere other than a threshold? I've been flying for years and I've never seen it. Denver maybe?
leader1 wrote:richiemo wrote:Great, thx for info team. I guess this is part of the beauty of having a 13,000 ft runway (28R). Are there any other similar setups at any other US airports, i.e. where departing flights launch from somewhere other than a threshold? I've been flying for years and I've never seen it. Denver maybe?
Many do. Some that come to mind are:
-JFK 31L at Taxiway KE when two departure runways are available.
-EWR 22R at Taxiway W pretty much all the time to avoid conflict with Runway 11/29. Only Asian flights will request the full runway.
-CDG for most flights to save taxi time.
-DXB as mentioned above.
Added: Sorry...you asked about US airports. I added those two because they're busy and relevant to the discussion.
gabik001 wrote:ORD14R wrote:Would 28C ever be used for departures during snow?
It was used plenty of times during a maintenance of 28R (snowplowing and runway cleaning). Same was with 10C. We will see tomorrow, it might be used for a while. I got plenty of shots of "Asian outflow" (mostly of Asian airlines and Asian direction departure series between 11am-1pm) from 28C with blowing snow because of jetblast. Will try tomorrow from the hills.
maps4ltd wrote:gabik001 wrote:ORD14R wrote:Would 28C ever be used for departures during snow?
10C was used this morning a bit while 10L was closed for plowing.
AmricanShamrok wrote:Fascinating thread. I've often wondered about the different configurations (particularly when the 22s are in use). For info, this is the planned usage of runways at full build-out:
https://www.oharenoise.org/sitemedia/do ... 041218.pdf
mpdpilot wrote:Is the intersection departure information published anywhere? I couldn't find anything in KORD FAA charts. I feel like the FAA would have that listed somewhere but maybe not?
leader1 wrote:Many do. Some that come to mind are:
Crackshot wrote:mpdpilot wrote:Is the intersection departure information published anywhere? I couldn't find anything in KORD FAA charts. I feel like the FAA would have that listed somewhere but maybe not?
I don't think so. I have a subscription that provides me access to Jeppesen charts, and I've never seen a US one with published intersection lengths. Dunno about LIDO.
