lightsaber wrote:Timeline is quite agressive for a new engine. Possible, but agressive.
Lightsaber
JonesNL wrote:12 seat difference seems too low for an extra variant. Also, new engine would raise the development cost a lot, which OEM has the money to pay for this?
Armadillo1 wrote:new wing can decrease thrust needed for plane
any tips for folding wingtips?
tommy1808 wrote:Since folding wingtips are now acceptable I'd be surprised if they leave 36m Gates behind.
Best regards
Thomas
VSMUT wrote:tommy1808 wrote:Since folding wingtips are now acceptable I'd be surprised if they leave 36m Gates behind.
Best regards
Thomas
Hang on, only 1 aircraft has made use of them so far, it is several years delayed and struggling to sell. How can you consider that "acceptable"? IMO, they will make do with a traditional wing. The risk is too great for a narrowbody. Too much complexity, cost, weight and too many daily cycles. It is easier to justify on a 442 mio USD ULH'er that will see less than 1 cycle per day, than it is for a narrowbody that will easily see 15 cycles a day in a highly competitive market.
Lightsaber
Opus99 wrote:The folding wingtip has nothing to do with the aircrafts sales or lack thereof.
Opus99 wrote:What he’s eluding to is on said aircraft it works very well. If it can give you the extra efficiency whilst maintaining the same gate. Why not? The folding wingtip also didn’t cause the delays. In fact it’s been bulletproof so far
Opus99 wrote:A322 sounds like a good proposition. So this is a clean sheet right? Not a derivative?
IMO they should wait and launch a clean sheet when the engine tech is ready. I think lightsaber can give us more clarity on if and when the engine tech will be ready to provide significant gains. Boeing’s next narrow body will be a clean sheet, and Boeing will spend a lot of money to make that jet very good (hopefully) Airbus ought to beat that jet with the position they’re in. But not by extending the life of a current jet
Noise wrote:Any crew rest areas?
VSMUT wrote:Opus99 wrote:The folding wingtip has nothing to do with the aircrafts sales or lack thereof.
No, but it will on a short haul aircraft. Those carriers are nickel-and-diming their aircraft orders. Expensive and heavy folding gear won't be an advantage.Opus99 wrote:What he’s eluding to is on said aircraft it works very well. If it can give you the extra efficiency whilst maintaining the same gate. Why not? The folding wingtip also didn’t cause the delays. In fact it’s been bulletproof so far
It's still to be seen if it works well. I could give you several reasons why it would be a bad idea, mostly involving hitting stuff with them when the crew forgets them. The pace of short haul flying is way higher than for long haul jets. There are no relief pilots, crews are more fatigued, more inexperienced pilots etc. It is going to happen way more than for the 777-9.
Opus99 wrote:VSMUT wrote:Opus99 wrote:The folding wingtip has nothing to do with the aircrafts sales or lack thereof.
I understand your points. But I mean if you’re hitting stuff with them then that’s more your skills than the plane. I’m not saying extremely long wings. But the issues you’ve raised are part of the reason why the wings fold back up automatically and you can’t take off with the wings folded up. You put systems in place to minimise the cost of human error. If when on the ground the wings are the same length as the current a320. There’s no reason you should be hitting it, especially if it folds back automatically. Then again if there’s no use for it then don’t put it. But if it gives you proper fuel burn advantage then use it. If not don’t
I would argue against it for a different reason. Just comes back to incrementalism. Get a composite wing first. Non-trivial weight benefits there that improve fuel burn. Engineer it to be optimal for slightly larger/heavier frames (A321-sized rather than A320-sized) and maybe ever so slightly longer stage lengths (questionable but would make sense when considering A220 taking over the smaller frame market) to enable further stretch plans. Folding wingtips could be in another iteration or release.
Folding wingtips have a bigger business case on long-haul. Most A320-family flying is still significantly under 3 hour stage lengths. Why risk it for minimal benefits?
willfinn wrote:Having listened to the podcast, both Rollins and Hamilton seem to regard the launch of an A322 hypothetical; there are clear ifs involved.
R. and H. seemed to direct the discussion into market outlook and product strategy. Indeed, an A322 could be a compelling proposition to Airbus operators seeking less-expensive lift, but given the financial circumstances — both airlines’ and OEMs’ — this sort of spending of capital is a no-go.
Also, ”an all-new engine” is very different from ”a more powerful engine”. Composite wings could end up being wingtip extensions à la A330neo.
Let’s hope the extra 12 seats are a result of an extra frame, not a result of cramming in more slim-line seats into the existing fuselage...
Airbus will launch if they are forced to launch.
flyingclrs727 wrote:If they're replacing the wing for the largest model, why not for the rest of the A320NEO lineup? A rewinged slightly stretched A320NEO could be a 737-8 killer.
zkojq wrote:IMO I could see Airbus doing the initial planning work for this aircraft and keeping it up its sleeve incase Boeing actually develops something that's a true rival to the A321neoXLR. Until that happens there's little benefit in developing such an aircraft since the A321neo owns that market already.
Revelation wrote:It's clear Airbus has been working on a new wing going back a few years now. We have references from Airbus saying just that in our older A322 threads.
Given a new wing, I'm not sure you'd need a more power, kind of like the 777x is a stretch with a new wing and doesn't need more power.
I agree that the core issue is that the industry as a whole is losing so much money it'll be hard to justify the project any time soon.
Airbus is having no problem shipping A321XLR as fast as they can make them based on pre-COVID orders, and under current conditions I doubt they could extract much of a premium for A322 so the business case for spending $billions on bringing A322 to market won't close any time soon.
Opus99 wrote:VSMUT wrote:tommy1808 wrote:Since folding wingtips are now acceptable I'd be surprised if they leave 36m Gates behind.
Best regards
Thomas
The folding wingtip has nothing to do with the aircrafts sales or lack thereof. What he’s eluding to is on said aircraft it works very well. If it can give you the extra efficiency whilst maintaining the same gate. Why not? The folding wingtip also didn’t cause the delays. In fact it’s been bulletproof so far
MIflyer12 wrote:Noise wrote:Any crew rest areas?
Why? What's leading you to think this is a 12-14 hour aircraft?
lightsaber wrote:What is needed is far less wing loading for an A321 and A322 (stretch). Due to real estate limits at major airports, I think all new wings will get folding wingtips.
Lightsaber
But when? Even just a new wing requires a billion euros just for the factory plus R&D effort. It is easy to spend other people's money... tougher when there must be a business case.
“The Wing of Tomorrow Programme started life a number of years ago and is the biggest research and technology programme taking place in the whole of Airbus globally,” stated Airbus’ Head of the Wing of Tomorrow programme, Sue Partridge.
tommy1808 wrote:Folding wingtips are not hard, they have been around for a long time. Building them in a way that saves fuel on top of gate space AND airlines buying it, that is new. Otherwise the 777 MK1 would have kicked the trend of. As long as there are no control surfaces outside the fold complexity is on the level of a door, and the A320 obviously doesn't need control surfaces outside the current wing.
debonair wrote:I thought that the A330-800/900 is the direct replacement for the A330ceo. Why would Airbus invest, especially during these hard times, in a modified A330-200 and running seperate production lines, when the A330neo is already certified?
Revelation wrote:lightsaber wrote:What is needed is far less wing loading for an A321 and A322 (stretch). Due to real estate limits at major airports, I think all new wings will get folding wingtips.
When indeed is the big question.
The spending on it has started back in 2015: https://www.airbus.com/newsroom/news/en ... uture.html
And it's not a small spend:“The Wing of Tomorrow Programme started life a number of years ago and is the biggest research and technology programme taking place in the whole of Airbus globally,” stated Airbus’ Head of the Wing of Tomorrow programme, Sue Partridge.
Ref: https://www.aero-mag.com/airbus-aircraf ... elopments/
The real question is: when will they decide to reap the harvest of all that spending?
Unfortunately COVID has made that decision a lot harder than it would have been without COVID.
Revelation wrote:tommy1808 wrote:Folding wingtips are not hard, they have been around for a long time. Building them in a way that saves fuel on top of gate space AND airlines buying it, that is new. Otherwise the 777 MK1 would have kicked the trend of. As long as there are no control surfaces outside the fold complexity is on the level of a door, and the A320 obviously doesn't need control surfaces outside the current wing.
I hope it does not come across as snarky to point out that technology has not stayed the same since the 90s. The benefits of longer and thinner wings are clearer now. 777 was aluminum, new wings will be fiber.
VSMUT wrote:It's still to be seen if it works well. I could give you several reasons why it would be a bad idea, mostly involving hitting stuff with them when the crew forgets them. The pace of short haul flying is way higher than for long haul jets. There are no relief pilots, crews are more fatigued, more inexperienced pilots etc. It is going to happen way more than for the 777-9.
lightsaber wrote:Revelation wrote:lightsaber wrote:What is needed is far less wing loading for an A321 and A322 (stretch). Due to real estate limits at major airports, I think all new wings will get folding wingtips.
Airbus knows what to do. I put in factory cost + R&D as I don't know how far along they are (it could be a year from start of manufacturing or as much as 3 years).
As you note, a tough decision.
VV wrote:What exactly is an A322?
milhaus wrote:To Varsity1: A32ONEO is lighter than 737-8, OEW is 44,3T and MAX was 45,07T. It is maybe little bit less without MAX name now.
DenverTed wrote:VV wrote:What exactly is an A322?
Following the convention of A318, A319, A320, A321, I assume A322 means a longer fuselage if nothing else.
IMHO, no announcement until more A321xLRs sell. We don't want to pull a Sinclair (announce the next great thing too early and have the market wait, not buying the current product because the next is so much better). I would even build the factory first.
Lightsaber
