https://aviation-safety.net/wikibase/24 ... OeGD-HNb3g
toobz wrote:I assume the pilots knew beforehand? Is there an indicator?
Varsity1 wrote:toobz wrote:I assume the pilots knew beforehand? Is there an indicator?
They will get a gear unlocked light, but they won't know the actual position of the gear.
ikolkyo wrote:Thought they fixed this ages ago.
WesternDC6B wrote:You engineering types, please forgive my ignorance. Why would one want to fill your mode to be with the wheels turn 90°? It seems to me that upon landing once those wheels hit the ground it would put a very high stress on the airframe itself. Second, why not a failure mode with the wheel straightahead and locked? To me it makes more sense. Thank you.
zeke wrote:The steering on the A320 is hydraulic, in order for it to be straight there must be hydraulic pressure to the steering. However the failure modes can be hydraulic or mechanical so you are not always guaranteed to have steering.
The 90 degree position gives certainty, the aircraft will not turn. There will be no runway excursion. The outcome is safe and predictable.
WesternDC6B wrote:zeke wrote:The steering on the A320 is hydraulic, in order for it to be straight there must be hydraulic pressure to the steering. However the failure modes can be hydraulic or mechanical so you are not always guaranteed to have steering.
I’m still wondering: How much stress does this put on the airframe itself? It seems to me the wheel sideways is going to create an awful lot of upward and backward stress on parts. Or, are airframes tougher than I thought they were? To everyone who’s answering my questions, thank you very much.
WesternDC6B wrote:I’m still wondering: How much stress does this put on the airframe itself? It seems to me the wheel sideways is going to create an awful lot of upward and backward stress on parts. Or, are airframes tougher than I thought they were? To everyone who’s answering my questions, thank you very much.
flyiguy wrote:I’d say Airbus needs to reassess their nose landing gear struts on their A320 fleets and sub fleets. This seems to be to coincidental. But that’s just my thoughts.
FLY
asdf wrote:WesternDC6B wrote:You engineering types, please forgive my ignorance. Why would one want to fill your mode to be with the wheels turn 90°? It seems to me that upon landing once those wheels hit the ground it would put a very high stress on the airframe itself. Second, why not a failure mode with the wheel straightahead and locked? To me it makes more sense. Thank you.
in a 90 degree position this is simply a rubber pin
it does not harm the direction the plane moves because there is no wheel turning
so it will stay pretty much @ the center line
in a 0 degree position the frontwheel turns
it will deflect the planes direction because the wheel never ever steers completely straigh ahead
a turning but fixed frontwheel would be more difficult to handle
DarkSnowyNight wrote:A32x nose gears are specifically designed to fail in a 90 degree off center if there is *snip* loss of associated Hyd pressure to the NLG. This is to prevent the aircraft from skidding off the runway upon landing.
toobz wrote:Terrifying. Thanks!
Wacker1000 wrote:DarkSnowyNight wrote:A32x nose gears are specifically designed to fail in a 90 degree off center if there is *snip* loss of associated Hyd pressure to the NLG. This is to prevent the aircraft from skidding off the runway upon landing.
No. Just no. If you lose the green (or yellow on later aircraft) system, the gear does not turn 90 degrees. It stays straight and you use the rudder and differential braking to steer then a tug comes and gets the aircraft.
cbphoto wrote:This has nothing to do with any sort of Hydraulic leak that many on here seem to think.
One theory is the A320 series has a notoriously weak nose gear when it comes to pushback issues, and could have been caused by a prior pushback issue. It might have been damaged due to a pushback being commenced with the brakes on, or the nose wheel went out of the pushback turn radius limits. Either way, it could have been caused by damage to the nose wheel prior to this flight. I know at my company pushback malfunctions are a hot topic item and we had a 319s nose wheel go sideways on a pushback due to pushback malfunction on a flight a few days prior.
CaptainHaresh wrote:I've seen some of those seals leak prematurely and apparently it's a part that many MRO's don't keep in stores as we once had an A320 go AOG over this. I laughed at a maintenance manager who was seriously trying to convince an engineer to rob a similar looking seal off a BAe146. That's how you end up with this kind of ... problem.
I wonder if the nose gear needs to be replaced after this, there could be enough force to bend the whole strut.
DarkSnowyNight wrote:False, as is clearly indicated by these incidents, for a start. As well, and as previously mentioned, the BSCU does turn the NLG upon extension to ensure operability. This turn is initiated by pressurizing Hyd Pwr and unlocking a cam. This is needed to pressurize, but primarily only to turn it back to center.
Flow2706 wrote:DarkSnowyNight wrote:False, as is clearly indicated by these incidents, for a start. As well, and as previously mentioned, the BSCU does turn the NLG upon extension to ensure operability. This turn is initiated by pressurizing Hyd Pwr and unlocking a cam. This is needed to pressurize, but primarily only to turn it back to center.
I don’t know the maintenance manuals but this can’t be exactly true. I agree that there is are failure modes that will result in the nose wheel being 90 degrees from the center position, but most hydraulic or nose wheel steering failures won’t result in these failure modes. If you loose the green hydraulic system and perform a gravity gear extension (or perform a gravity gear extension for other failures) there is no hydraulic pressure present in the landing gear. Still in these failure modes, the nose wheel will be centred and directional control will be ensured by the rudder and if needed differential braking. However nose wheel steering will not be available after a gear gravity extension.
DarkSnowyNight wrote:Wacker1000 wrote:DarkSnowyNight wrote:A32x nose gears are specifically designed to fail in a 90 degree off center if there is *snip* loss of associated Hyd pressure to the NLG. This is to prevent the aircraft from skidding off the runway upon landing.
False, as is clearly indicated by these incidents, for a start. As well, and as previously mentioned, the BSCU does turn the NLG upon extension to ensure operability. This turn is initiated by pressurizing Hyd Pwr and unlocking a cam. This is needed to pressurize, but primarily only to turn it back to center. That is what is being verified. If that fails, there is not enough Hyd pwr to overcome aerodynamic loads and the wheel stays in the 90 degree offset position. As well, the centering cam rotates to a flat area. Again, this is purposeful as the NLG now acts the same as a rubber stopper in front of a roller skate would. Both what is taught in Level II & III systems classes from Airbus and experience say I am right. Unless you have a very specific reference that shows otherwise —I already know what the answer to that is—, you may assume you have just learned something.
See NTSB report NYC99IA062 excerpt below:
Additionally, during landing gear extension, the brake and
steering control unit (BSCU) would have been energized and hydraulic pressure would have been
directed toward the steering servo valve. The BSCU would have then commanded a small rotation of
the nose wheel to check for proper movement. Any disagreement between the commanded position and
actual position of the nose wheel would have deactivated the nose wheel steering. However, if
hydraulic pressure had bypassed the steering control valve, there would have been continued
pressurization to the servo valve, and because of the servo valve's inherent offset, in-flight
rotation of the nose wheels.
Procedures existed for removal of hydraulic pressure from the steering control module. However,
once the nosewheel strut had deflected 90 degrees, the centering cam would have been rotated to a
flat area, and would have been incapable of overriding the 3,000 PSI hydraulic system, and
returning the nose wheels to a centered position.
Wacker1000 wrote:Loss of a green system on a non-enhanced aircraft will cause loss of manual extension and nose wheel steering.
DarkSnowyNight wrote:Wacker1000 wrote:Loss of a green system on a non-enhanced aircraft will cause loss of manual extension and nose wheel steering.
Again, not true. Loss of Green and Yellow, and/or PTU. This is also venturing into territory that is not statistically relevant, and clearly nowhere near what has happened here or in previous related incidents. You are speaking about something who's failure mode is so different that it cannot be properly related to what happened here. Or with JetBlue292. Or with AW2811, or with any of the others where this occurred. In fact, for that sort of total loss, I am not aware of any incidents that were not also collisions or bombings...
