enilria
OAG Changes 1/27/2021:3M to GSP;AA JFK-ATH/TLV;DL LGA-EYW/HHH/MYR,JFK-ACK/MVY;F9 New Routes;NK MCO-PAP/SDQ;WN FAT/SBA
Wed Jan 27, 2021 12:56 pm
FAQ
SOURCE: OAG
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
NOTE: I don't know whether this move to Wednesday is permanent or just some temporary problems on the schedule provider side. So, it is what it is.
2D GEO-MIA FEB 0.2>0[0.3] MAR 0.3>0[0]
2D GYE-MIA FEB 0.6>0.3[0.9]
2D JFK-PAP FEB 0.3>0[0.3] MAR 0.3>0[0]
2D JFK-SDQ MAR 0.3>0.0[0]
**3M GSP-JAX APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0]
**3M GSP-MCO APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0]
**3M GSP-TPA APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0]
3M JAX-TPA MAR 0.2>0[0]
4B CDR-DEN FEB 1.8>1.0[2]
4B PHX-SOW FEB 2>1.3[2] APR 2>1.4[3] MAY 2>1.4[3] JUN 0>1.8[3] JUL 0>1.8[3]
7H ANC-DLG JUL 1.8>2[0] AUG 2>3[0]
9K BNA-MWA MAY 0>1.4[1.7]
9K BNA-OWB MAY 0>1.4[1.9]
9K IRK-STL FEB 0.9>0[3] MAY 0>2[3]
9K MBL-ORD FEB 1.7>0[1.9] MAY 0>1.7[0]
9K ORD-UIN FEB 0.9>0[1.3] MAY 0>1.2[3]
9K OWB-STL MAY 0>0.7[1.0]
9K STL-UIN FEB 1.3>0[1.4] MAY 0>1.3[3] AUG 1.6>1.3[3]
9X HNL-LNY FEB 3>6[1.9] MAR 3>6[0] APR 3>6[0] MAY 3>6[0] JUN 3>6[0] JUL 3>6[0] AUG 3>6[2] SEP 3>6[2]
9X KOA-OGG FEB 6>7[6] MAR 6>7[0] APR 6>7[12] MAY 6>7[11] JUN 6>7[12] JUL 6>7[11] AUG 6>7[7] SEP 6>7[6]
AA ABE-CLT MAR 4>3[3]
AA ABQ-DFW MAR 8>6[6]
AA ABQ-LAX MAR 3>0[3]
AA ABQ-ORD MAR 1.3>0.7[1.7]
AA ABQ-PHX MAR 2>3[4]
AA ACT-DFW MAR 4>2[4]
AA AEX-DFW MAR 3>1.9[3]
AA AGS-DCA MAR 0.9>0.5[0.8]
AA ALB-DCA MAR 3>0.5[4]
AA ALB-ORD MAR 1.5>0.8[3]
AA ALB-PHL MAR 3>0.7[4]
AA ALO-ORD MAR 1.4>0.8[1.8]
AA AMA-DFW MAR 6>3[6]
AA AMS-DFW MAR 0.3>0[0]
AA ART-PHL MAR 0.4>0[1.9]
I wonder why the change of heart? B6 deal?
**AA ATH-JFK JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
AA ATL-CLT MAR 8>6[7]
AA ATL-DCA MAR 4>1.4[3]
AA ATL-DFW MAR 8>6[7]
AA ATL-LAX MAR 2>0[3]
AA ATL-LGA MAR 5>0[5]
AA ATL-MIA MAR 6>4[6]
AA ATL-ORD MAR 3>1.0[3]
AA ATL-PHL MAR 5>0.9[4]
AA ATL-PHX MAR 1.9>0.9[1.0]
AA ATW-ORD MAR 2>1.6[3]
AA AUA-PHL MAR 1.0>0.6[1.0]
AA AUS-BOS MAR 0.8>0[0]
AA AUS-DFW MAR 10>7[10]
AA AUS-JFK MAR 0.5>0[1.8]
AA AUS-LAX MAR 2>0.9[3]
AA AUS-MIA MAR 3>1.8[3]
AA AUS-ORD MAR 2>0.6[3]
AA AUS-PHL MAR 1.7>0.1[1.6]
AA AUS-PHX MAR 4>3[4]
AA AUS-SJC MAR 1.5>0[0]
AA AVL-DFW MAR 1.1>1.9[0.9]
AA AVL-LGA MAR 0.9>0[0.3]
AA AVL-PHL MAR 0.5>0[0.9]
AA AVP-ORD MAR 1.3>0.8[1.5]
AA AZO-ORD MAR 2>0.8[3]
AA BDL-DCA MAR 5>0.5[5]
AA BDL-DFW MAR 1.9>1.0[0.8]
AA BDL-LAX MAR 0.5>0[0]
AA BDL-ORD MAR 3>0.9[3]
AA BDL-PHL MAR 3>0.7[4]
AA BFL-PHX MAR 3>4[3]
AA BGR-CLT MAR 1.0>1.9[0]
AA BGR-DCA MAR 3>0.5[2]
AA BGR-PHL MAR 2.0>0.8[4]
AA BHM-CLT MAR 6>5[7]
AA BHM-DCA MAR 2>0.5[3]
AA BHM-DFW MAR 5>4[5]
AA BHM-MIA MAR 1.1>0.5[1.9]
AA BHM-ORD MAR 1.3>0[1.6]
AA BHM-PHL MAR 1.0>0[1.8]
AA BMI-ORD MAR 2>0.9[3]
AA BNA-DCA MAR 4>0.5[4]
AA BNA-DFW MAR 8>6[7]
AA BNA-JFK MAR 0.9>0[1.9]
AA BNA-LAX MAR 1.9>0[1.8]
AA BNA-LGA MAR 4>0[4]
AA BNA-MIA MAR 3>2[2]
AA BNA-ORD MAR 4>1.6[7] MAY 9>8[8]
AA BNA-PHL MAR 4>1.1[3]
AA BOI-ORD MAR 0.7>0.9[0]
AA BOS-CLT MAR 7>6[8]
AA BOS-DCA MAR 10>4[9] APR 13>12[11]
AA BOS-DFW MAR 6>3[5]
AA BOS-IND MAR 0.7>0[0]
AA BOS-JFK MAR 1.0>0[3]
AA BOS-LAX MAR 3>0[4]
AA BOS-LGA MAR 9>0.5[9]
AA BOS-MIA MAR 5>3[6]
AA BOS-ORD MAR 5>0.3[5]
AA BOS-PHL MAR 11>0.9[10]
AA BOS-PHX MAR 3>1.9[4]
AA BOS-RDU MAR 3>0[0]
AA BTR-CLT MAR 3>1.9[3]
AA BTV-CLT MAR 3>2[2]
AA BTV-DCA MAR 2>0.8[3]
AA BTV-PHL MAR 3>1.0[4]
AA BUF-DCA MAR 3>0[3]
AA BUF-ORD MAR 2>0.5[3]
AA BUF-PHL MAR 4>1.1[5]
AA BUR-PHX MAR 5>2[4]
AA BWI-CLT MAR 7>4[7]
AA BWI-DFW MAR 4>3[2]
AA BWI-JFK MAR 1.3>0[0.9] MAY 1.6>1.1[1.2]
AA BWI-MIA MAR 1.4>0.7[1.3]
AA BWI-ORD MAR 3>1.8[3]
AA BWI-PHL MAR 1.5>0[3]
AA BZE-MIA MAR 1.8>0.9[1.9]
AA BZN-ORD MAR 0.8>1.0[0.9]
AA CAE-DCA MAR 2>0.5[3]
AA CAE-DFW MAR 3>1.6[2]
AA CAE-LGA MAR 0.6>0[0.8]
AA CAE-PHL MAR 0.6>0.4[2]
AA CAK-DCA MAR 0.7>0[0.9]
AA CAK-LGA MAR 0.6>0[0.8]
AA CAK-ORD MAR 0.5>0[1.9]
AA CHA-DCA MAR 0.8>0[0.8]
AA CHO-LGA MAR 1.4>0[1.8]
AA CHO-ORD MAR 1.6>0[3]
AA CHO-PHL MAR 0.5>0[1.7]
AA CHS-DCA MAR 4>0.9[4]
AA CHS-LGA MAR 0.2>0[0.9]
AA CHS-PHL MAR 3>0.8[3]
AA CID-CLT MAR 3>1.9[3]
AA CID-DFW MAR 4>3[3]
AA CID-ORD MAR 4>1.6[5]
AA CLE-DCA MAR 3>1.0[2]
AA CLE-DFW MAR 5>3[2]
AA CLE-JFK MAR 0.2>0[0]
AA CLE-LGA MAR 3>0[3]
AA CLE-MIA MAR 1.6>0.8[3]
AA CLE-ORD MAR 3>1.3[5] MAY 7>6[6]
AA CLE-PHL MAR 5>1.1[4]
AA CLL-DFW MAR 0.9>0.6[3]
AA CLT-CMH MAR 7>6[7]
AA CLT-CRW MAR 4>3[4]
AA CLT-DAY MAR 6>4[5]
AA CLT-DCA MAR 8>6[8]
AA CLT-DEN MAR 6>5[4]
AA CLT-DSM MAR 3>2.0[4]
AA CLT-EWN MAR 5>2[4]
AA CLT-EWR MAR 8>5[7]
AA CLT-EYW MAR 5>6[5]
AA CLT-FLL MAR 8>7[8]
AA CLT-FLO MAR 3>1.1[3]
AA CLT-FSD FEB 0.9>0.6[1.1] MAR 1.0>1.7[0]
AA CLT-GGT MAR 0.9>0[0.2]
AA CLT-HHH MAR 3>4[3]
AA CLT-HPN MAR 3>2[4]
AA CLT-HTS MAR 3>1.6[3]
AA CLT-IAD MAR 6>3[6]
AA CLT-IAH MAR 4>3[4]
AA CLT-ILM MAR 8>7[8]
AA CLT-IND MAR 7>6[7]
AA CLT-ITH MAR 1.8>0.9[0.2]
AA CLT-LGA MAR 9>5[9]
AA CLT-MCO MAR 10>9[11]
AA CLT-MDT MAR 4>5[6]
AA CLT-MHT MAR 4>3[4]
AA CLT-MIA MAR 7>8[8]
AA CLT-MSP MAR 4>3[4]
AA CLT-OKC MAR 2>3[3]
AA CLT-OMA MAR 3>2.0[3]
AA CLT-ORD MAR 9>6[8]
AA CLT-ORF MAR 7>6[8]
AA CLT-PGV MAR 3>1.8[3]
AA CLT-PHF MAR 6>3[4]
AA CLT-PHL MAR 8>7[8]
AA CLT-PHX MAR 8>6[7]
AA CLT-PIT MAR 8>5[7]
AA CLT-PWM MAR 3>1.8[3]
AA CLT-ROA MAR 6>5[7]
AA CLT-ROC MAR 4>3[3]
AA CLT-SAN MAR 4>2[4]
AA CLT-SAV MAR 8>7[7]
AA CLT-SBY MAR 3>1.8[3]
AA CLT-SDF MAR 7>6[7]
AA CLT-SEA MAR 4>2[3]
AA CLT-SFO MAR 5>2[4]
AA CLT-SLC MAR 2>1.4[0.8]
AA CLT-SRQ MAR 4>5[4]
AA CLT-TRI MAR 5>3[5]
AA CLT-VPS MAR 3>6[5]
AA CLT-YUL MAR 1.8>0[1.9]
AA CLT-YYZ MAR 5>1.0[5]
AA CMH-DCA MAR 3>1.0[4]
AA CMH-DFW MAR 5>4[3]
AA CMH-JFK MAR 0.5>0[0.9]
AA CMH-LAX MAR 1.5>0[0.9]
AA CMH-LGA MAR 5>0[5]
AA CMH-ORD MAR 5>1.5[8] MAY 9>8[7]
AA CMH-PHL MAR 5>0.9[4]
AA CMH-PHX MAR 1.9>1.0[1.3]
AA CMI-ORD MAR 3>0.7[4]
AA COS-DFW MAR 6>5[4]
AA COS-ORD MAR 0.6>0[0]
AA COU-DFW MAR 3>1.8[2]
AA COU-ORD MAR 2>0[2]
AA CRW-PHL MAR 0.2>0[0.9]
AA CUN-ORD MAR 3>2[2.0]
AA CUR-MIA MAR 0.9>0.6[1.9]
AA CVG-DCA MAR 2>0[2]
AA CVG-JFK MAR 0.4>0[0.9]
AA CVG-LGA MAR 1.4>0[1.7]
AA CVG-ORD MAR 4>0.9[6] MAY 8>7[6]
AA CVG-PHL MAR 4>1.6[4]
AA CWA-ORD MAR 2>0.6[3]
AA DAB-PHL MAR 0.9>0.5[0]
AA DAY-DCA MAR 3>0.5[3]
AA DAY-DFW MAR 3>2[3]
AA DAY-LGA MAR 2>0[2]
AA DAY-ORD MAR 1.9>0.1[3]
AA DAY-PHL MAR 1.2>0.6[4]
AA DBQ-ORD MAR 2>0.9[3]
AA DCA-DFW MAR 9>5[9]
AA DCA-DSM MAR 1.4>0[1.7]
AA DCA-DTW MAR 2>0.9[2]
AA DCA-EYW MAR 0.2>1.0[1.4]
AA DCA-GRR MAR 1.5>0.8[1.7]
AA DCA-GSO MAR 2>0[2]
AA DCA-GSP MAR 2>0[2]
AA DCA-HPN MAR 4>0[4]
AA DCA-HSV MAR 3>0.5[3]
AA DCA-ILM MAR 0.9>0.6[0.9]
AA DCA-IND MAR 5>1.0[5]
AA DCA-JAX MAR 3>0.3[4]
AA DCA-JFK MAR 0.4>0[1.9]
AA DCA-LAN MAR 0.7>0[0.9]
AA DCA-LAX MAR 1.9>1.0[1.9]
AA DCA-LGA MAR 10>5[9]
AA DCA-LIT MAR 0.9>0[0.9]
AA DCA-MCI MAR 2>0.5[2]
AA DCA-MCO MAR 4>1.6[4]
AA DCA-MEM MAR 2>0.2[3]
AA DCA-MGM MAR 0.9>0[0.9]
AA DCA-MHT MAR 2>0.5[4]
AA DCA-MIA MAR 8>4[8]
AA DCA-MSP MAR 2>0.4[2]
AA DCA-MSY MAR 4>0.5[4]
AA DCA-MYR MAR 0.6>0.9[0.5]
AA DCA-NAS MAR 0.2>0[0.3]
AA DCA-OKC MAR 0.9>0[0.9]
AA DCA-ORD MAR 6>2[8]
AA DCA-ORF MAR 2>0.6[3]
AA DCA-PBI MAR 0.8>1.0[2]
AA DCA-PHX MAR 3>1.0[3]
AA DCA-PIT MAR 3>0.9[4]
AA DCA-PNS MAR 1.7>1.2[1.9]
AA DCA-PVD MAR 6>0.6[6]
AA DCA-PWM MAR 4>0.9[4]
AA DCA-RDU MAR 5>0.5[6]
AA DCA-ROC MAR 2>0[3]
AA DCA-SAV MAR 1.4>0.3[2]
AA DCA-SDF MAR 2>0.6[3]
AA DCA-SRQ MAR 1.0>0.8[1.0]
AA DCA-STL MAR 3>0[3]
AA DCA-SYR MAR 3>0.5[3]
AA DCA-TLH MAR 0.8>0[0.9]
AA DCA-TPA MAR 4>1.3[3]
AA DCA-TYS MAR 2>0.6[3]
AA DCA-XNA MAR 0.8>0[0.8]
AA DCA-YYZ MAR 1.7>0[1.7]
AA DEN-DFW MAR 11>7[8]
AA DEN-MIA MAR 1.4>2[1.9]
AA DEN-ORD MAR 3>1.9[3]
AA DEN-PHL MAR 3>0.5[0.5]
AA DEN-PHX MAR 4>3[3]
AA DFW-DRT MAR 1.2>1.6[1.8]
AA DFW-DTW MAR 5>4[4]
AA DFW-EVV MAR 1.3>1.8[1.8]
AA DFW-EWR MAR 4>2.0[4]
AA DFW-FAY MAR 0.9>0.6[0]
AA DFW-GCM MAR 0.9>0.3[0.3]
AA DFW-GJT MAR 4>3[3]
AA DFW-GPT MAR 0.7>2.0[2]
AA DFW-GRI MAR 2>1.9[1.8]
AA DFW-GSO MAR 3>2[1.8]
AA DFW-GSP MAR 3>2[2]
AA DFW-GUC MAR 1.1>0.9[1.0]
AA DFW-HKG MAR 0.9>0.2[0.9]
AA DFW-HOU MAR 7>3[7]
AA DFW-HSV MAR 6>5[4]
AA DFW-IAD MAR 2>1.5[3]
AA DFW-IAH MAR 8>6[8]
AA DFW-ICN MAR 0.5>0.7[0.9]
AA DFW-JAN MAR 6>4[5]
AA DFW-JFK MAR 1.7>0[0.9]
AA DFW-JLN MAR 3>1.9[1.8]
AA DFW-LAS MAR 12>10[10]
AA DFW-LAW MAR 4>3[3]
AA DFW-LAX MAR 13>9[13]
AA DFW-LBB MAR 6>5[6]
AA DFW-LFT MAR 4>2[3]
AA DFW-LGA MAR 11>5[10]
AA DFW-LIT MAR 6>4[7]
AA DFW-MAD MAR 0.9>0.2[0.8]
AA DFW-MAF MAR 5>4[6]
AA DFW-MCO MAR 11>8[9]
AA DFW-MEM MAR 7>6[7]
AA DFW-MIA MAR 11>8[9]
AA DFW-MRY MAR 0.8>1.8[0]
AA DFW-MSP MAR 6>4[4]
AA DFW-MSY MAR 8>6[6]
AA DFW-MTY MAR 5>4[5]
AA DFW-OKC MAR 8>6[8]
AA DFW-ONT MAR 6>5[5]
AA DFW-ORD MAR 12>6[12]
AA DFW-ORF MAR 3>2.0[1.7]
AA DFW-PBI MAR 3>4[3]
AA DFW-PDX MAR 5>3[3]
AA DFW-PHL MAR 9>5[7]
AA DFW-PHX MAR 11>9[11]
AA DFW-PIT MAR 5>4[3]
AA DFW-PUJ MAR 0>0.9[0.2]
AA DFW-PVG MAR 0.9>0.2[0.8]
AA DFW-RDU MAR 5>4[4]
AA DFW-RIC MAR 3>1.9[2]
AA DFW-RNO MAR 3>4[2.0]
AA DFW-ROW MAR 3>1.8[3]
AA DFW-RSW MAR 4>5[4]
AA DFW-SAF MAR 5>3[3]
AA DFW-SAN MAR 9>6[8]
AA DFW-SAT MAR 10>8[10]
AA DFW-SBP MAR 1.9>1.0[1.8]
AA DFW-SDF MAR 6>5[4]
AA DFW-SEA MAR 9>5[6]
AA DFW-SFO MAR 7>4[8] APR 10>9[9]
AA DFW-SHV MAR 7>5[5]
AA DFW-SJC MAR 4>3[4]
AA DFW-SLC MAR 6>5[6]
AA DFW-SMF MAR 5>4[4]
AA DFW-SNA MAR 8>6[7]
AA DFW-STS MAR 0.8>0[0]
AA DFW-SUX MAR 0.8>0[0.9]
AA DFW-SWO MAR 2>0.9[1.8]
AA DFW-TRI MAR 1.9>1.0[1.8]
AA DFW-TUL MAR 8>5[8]
AA DFW-TUS MAR 7>6[6]
AA DFW-TXK MAR 3>2[3]
AA DFW-TYR MAR 2>3[4]
AA DFW-XNA MAR 7>4[8]
AA DFW-YUL MAR 0.9>0[0.9]
AA DFW-YVR MAR 2>1.0[0.9]
AA DFW-YYZ MAR 3>0.9[2]
AA DSM-ORD MAR 4>1.7[6]
AA DSM-PHL MAR 0.9>0[0.9]
AA DTW-LGA MAR 4>0[4]
AA DTW-MIA MAR 1.4>0[1.9]
AA DTW-ORD MAR 3>1.1[5] MAY 6>5[5]
AA DTW-PHL MAR 5>1.6[4]
AA DTW-PHX MAR 1.8>1.0[3]
AA EGE-JFK MAR 0.4>0.7[0.9]
AA EGE-LAX MAR 0.9>0.7[0.9]
AA EGE-ORD MAR 0.6>1.0[0.9]
AA EGE-PHX MAR 1.0>0.8[0]
AA ELP-LAX MAR 3>0[3]
AA ELP-ORD MAR 0.9>0.2[1.8]
AA ELP-PHX MAR 2>1.4[5]
AA ERI-ORD MAR 0.4>0[0]
AA EVV-ORD MAR 1.5>0[1.9]
AA EWR-MIA MAR 3>5[4]
AA EWR-ORD MAR 4>0.9[4]
AA EWR-PHX MAR 4>0[2]
AA EYW-MIA MAR 2>1.8[4]
AA EZE-JFK MAR 0.9>0.1[0.9]
AA FAT-PHX MAR 5>3[5]
AA FLL-ORD MAR 1.8>0.9[3]
AA FLL-PHL MAR 4>3[3]
AA FNT-ORD MAR 1.8>1.2[3]
AA GCM-MIA MAR 1.0>0.7[2]
AA GCM-ORD MAR 0.2>0[0.3]
AA GCM-PHL MAR 0.2>0[0.2]
AA GGT-MIA MAR 1.5>0[1.9]
AA GJT-PHX MAR 3>2[3]
AA GNV-MIA MAR 0.8>0[1.8]
AA GRR-MIA FEB 1.0>0.7[0.8]
AA GRR-ORD MAR 5>2[5]
AA GRU-JFK MAR 0.9>0.1[0.9]
AA GSO-LGA MAR 1.9>0[3]
AA GSO-MIA MAR 1.2>0.5[1.7]
AA GSO-ORD MAR 1.5>0.7[1.7]
AA GSO-PHL MAR 1.6>0.9[3]
AA GSP-MIA MAR 1.4>0[1.7]
AA GSP-ORD MAR 1.8>0.6[1.6]
AA GSP-PHL MAR 1.4>0.5[3]
AA HNL-PHX MAR 1.0>1.9[1.0]
AA HPN-ORD MAR 1.9>0[1.8]
AA HSV-ORD MAR 1.2>0[1.7]
AA IAD-LAX MAR 0.5>0[0.9]
AA IAH-LAX MAR 1.0>0[3]
AA IAH-MIA MAR 4>2[4]
AA IAH-ORD MAR 1.6>1.0[2] MAY 4>3[2]
AA IAH-PHL MAR 2>0.1[2]
AA IAH-PHX MAR 3>2[3]
AA ICT-ORD MAR 1.7>0.5[3]
AA ILM-LGA MAR 2>0[3]
AA ILM-PHL MAR 0.7>0.4[1.9]
AA IND-JFK MAR 0.4>0[0.9]
AA IND-LAX MAR 1.7>0[1.4]
AA IND-LGA MAR 1.6>0[1.9]
AA IND-ORD MAR 5>1.3[6]
AA IND-PHL MAR 5>1.0[4]
AA IND-PHX MAR 1.9>1.0[1.7]
AA JAC-LAX MAR 0.7>0.9[0.7]
AA JAX-MIA MAR 4>2[5]
AA JAX-ORD MAR 2>0.5[1.5]
AA JAX-PHL MAR 2>0.8[2.0]
AA JFK-LAS MAR 0.4>0[0]
AA JFK-LAX MAR 6>2[10]
AA JFK-LIR MAR 0>0.4[0.2]
AA JFK-ORD MAR 2>0[0.9]
AA JFK-ORF MAR 0.8>0[0.9]
AA JFK-PHL MAR 1.2>0[0]
AA JFK-PHX MAR 3>0.6[4]
AA JFK-PIT MAY 0.7>0.5[1.2]
AA JFK-RDU MAR 0.2>0[1.9]
AA JFK-SAN MAR 0.7>0[0.4]
AA JFK-SAT MAR 0.9>0[0.9]
AA JFK-SFO MAR 2>0.7[4]
AA JFK-SJD MAR 0.9>0.6[0]
AA JFK-SJO MAR 0.9>0.4[0.9]
**AA JFK-TLV MAY 0>0.8[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
AA JLN-ORD MAR 0.8>0[1.5]
AA LAN-ORD MAR 1.4>0.9[1.9]
AA LAP-PHX MAR 0.4>0.1[0]
AA LAS-LAX MAR 6>2[8]
AA LAS-MIA MAR 2>1.8[3]
AA LAS-ORD MAR 3>2[3]
AA LAS-PHL MAR 4>1.4[1.9]
AA LAS-PHX MAR 6>5[6]
AA LAX-LHR MAR 0.3>0.1[1.7]
AA LAX-LIH MAR 1.7>1.0[1.1]
AA LAX-MCO MAR 3>0[3]
AA LAX-MEX MAR 0.5>1.0[0.9]
AA LAX-MIA MAR 8>4[7]
AA LAX-MSY MAR 1.5>0[1.1]
AA LAX-OKC MAR 1.8>0[1.9]
AA LAX-OMA MAR 1.8>0[1.9]
AA LAX-ORD MAR 7>2[8]
AA LAX-PDX MAR 1.9>0[3]
AA LAX-PHL MAR 6>2[6]
AA LAX-RDU MAR 1.0>0[0.6]
AA LAX-RNO MAR 4>0.7[5]
AA LAX-SAT MAR 3>0[1.7]
AA LAX-SEA MAR 3>0[3]
AA LAX-SFO MAR 6>1.1[7] APR 7>6[8]
AA LAX-SJC MAR 5>0[5]
AA LAX-SLC MAR 2>1.6[4]
AA LAX-SMF MAR 4>0[4]
AA LAX-STL MAR 1.4>0[1.9]
AA LAX-STS MAR 0.8>0[0]
AA LAX-TUL MAR 0.9>0[0.9]
AA LAX-TUS MAR 2>0[3]
AA LAX-XNA MAR 1.8>0[0.9]
AA LEX-ORD MAR 1.9>0.8[2]
AA LEX-PHL MAR 0.6>0.3[1.7]
AA LGA-MCO MAR 1.6>0[1.9]
AA LGA-MEM MAR 1.5>0[1.6]
AA LGA-MIA MAR 11>4[10]
AA LGA-MSP MAR 2>0[1.6]
AA LGA-OKC MAR 0.8>0[0]
AA LGA-ORD MAR 9>2[9]
AA LGA-ORF MAR 3>0[1.7]
AA LGA-PHL MAR 3>0[3]
AA LGA-PIT MAR 5>0[6]
AA LGA-PWM MAR 1.6>0[1.5]
AA LGA-RDU MAR 5>0[6]
AA LGA-RIC MAR 2>0[4]
AA LGA-ROA MAR 0.8>0[0.9]
AA LGA-SDF MAR 1.3>0[1.6]
AA LGA-STL MAR 3>0[2]
AA LGA-XNA MAR 1.5>0[1.5]
AA LGA-YUL MAR 1.9>0[3]
AA LGA-YYZ MAR 2>0[3]
AA LGB-PHX MAR 1.5>2[3]
AA LHR-MIA MAR 0.9>0.2[1.9]
AA LIT-ORD MAR 1.4>0.2[2]
AA LSE-ORD MAR 1.9>1.4[3]
AA MBJ-PHL MAR 1.9>1.5[1.9]
AA MCI-ORD MAR 4>0.9[5] MAY 7>5[4] JUN 7>6[1.3]
AA MCI-PHL FEB 0.6>0.9[3] MAR 2>0.2[1.9]
AA MCO-MIA MAR 10>4[6]
AA MCO-ORD MAR 3>2[5]
AA MCO-PHL MAR 7>4[6]
AA MCO-PHX MAR 3>1.6[3]
AA MDT-ORD MAR 2>0.6[3]
AA MDT-PHL MAR 2>1.3[5]
AA MEM-MIA MAR 0.9>1.7[1.9]
AA MEM-ORD MAR 1.5>1.0[3] MAY 5>4[3]
AA MEM-PHL MAR 1.9>0[1.3]
AA MHK-ORD MAR 2>0[1.8]
AA MHT-ORD MAR 1.4>0.9[0.9]
AA MHT-PHL MAR 3>1.3[4]
AA MIA-MSP MAR 1.3>0[1.7]
AA MIA-MSY MAR 3>1.8[4]
AA MIA-MTY MAR 0.9>0[0.9]
AA MIA-NAS MAR 5>3[7]
AA MIA-OKC MAR 0.7>0[0.9]
AA MIA-OMA MAR 0.3>0.6[0.8]
AA MIA-ORD MAR 7>4[9]
AA MIA-ORF MAR 2>1.4[3]
AA MIA-PHL MAR 5>3[5]
AA MIA-PIT MAR 2>0.9[3]
AA MIA-PNS MAR 1.5>0.4[3]
AA MIA-POS MAR 1.9>1.0[2]
AA MIA-RDU MAR 4>2[3]
AA MIA-RIC MAR 1.5>0.7[1.9]
AA MIA-SAV MAR 1.2>0.8[1.9]
AA MIA-SDF MAR 1.7>0.8[1.9]
AA MIA-SEA MAR 0.7>0.5[0.9]
AA MIA-SKB MAR 0.9>0.4[1.6]
AA MIA-STL MAR 2.0>0.9[3]
AA MIA-TLH MAR 2>1.1[4]
AA MIA-TPA MAR 7>5[4]
AA MIA-TYS MAR 1.3>0[1.7]
AA MIA-XNA MAR 0.6>0[0.9]
AA MIA-YUL MAR 0.9>0[0.9]
AA MIA-YYZ MAR 3>0[1.3]
AA MKE-ORD MAR 3>1.5[4]
AA MKE-PHL MAR 1.7>0.8[2]
AA MKE-PHX MAR 1.9>0.9[1.7]
AA MLI-ORD MAR 1.1>0.6[3]
AA MQT-ORD MAR 1.0>0.7[0.9]
AA MSN-ORD MAR 5>1.6[5]
AA MSN-PHL MAR 0.4>0[1.8]
AA MSP-ORD MAR 4>1.3[5]
AA MSP-PHL MAR 3>0.3[1.5]
AA MSP-PHX MAR 4>2[3]
AA MSY-ORD MAR 1.1>0.3[2]
AA MSY-PHL MAR 3>0.9[1.0]
AA MSY-PHX MAR 0.8>1.7[0.9]
AA MTJ-ORD MAR 0.6>0.9[0.6]
AA MYR-PHL MAR 1.2>0.6[0.9]
AA NAS-PHL MAR 1.1>0.5[1.1]
AA OGG-PHX MAR 1.1>1.9[1.0]
AA OKC-ORD MAR 1.8>0.6[3]
AA OKC-PHX MAR 1.1>2[1.6]
AA OMA-ORD MAR 3>1.3[4]
AA OMA-PHX MAR 1.1>1.9[0.9]
AA ONT-PHX MAR 5>3[4]
AA ORD-PBI MAR 1.4>1.9[3]
AA ORD-PDX MAR 1.5>0.5[0.9]
AA ORD-PHL MAR 10>3[7]
AA ORD-PHX MAR 8>5[8]
AA ORD-PIA MAR 2>0.6[3]
AA ORD-PIT MAR 3>1.1[4]
AA ORD-PVD MAR 1.7>0.7[1.7]
AA ORD-PWM MAR 1.5>0[0]
AA ORD-RDU MAR 3>1.2[3]
AA ORD-RIC MAR 3>0.7[2]
AA ORD-RNO MAR 1.7>0[0]
AA ORD-ROC MAR 3>0.4[3]
AA ORD-RST MAR 2>0.9[3]
AA ORD-RSW MAR 3>2[4]
AA ORD-SAN MAR 3>1.4[3]
AA ORD-SAT MAR 2>0[1.9]
AA ORD-SDF MAR 3>0.9[4]
AA ORD-SEA MAR 3>0.8[1.6]
AA ORD-SFO MAR 4>1.6[4]
AA ORD-SGF MAR 3>0.6[4]
AA ORD-SJC MAR 1.7>0[0.9]
AA ORD-SMF MAR 1.0>0[0.9]
AA ORD-SNA MAR 3>0.7[3]
AA ORD-SRQ FEB 1.3>0.9[1.1]
AA ORD-STL MAR 3>1.3[5] MAY 7>6[5]
AA ORD-SUX MAR 1.9>0.5[2]
AA ORD-SYR MAR 3>1.2[4]
AA ORD-TOL MAR 2>0[3]
AA ORD-TUL MAR 0.9>0.4[2]
AA ORD-TUS MAR 1.5>0.7[1.9]
AA ORD-TVC MAR 4>2[3]
AA ORD-TYS MAR 1.9>0.3[1.6]
AA ORD-XNA MAR 3>0.3[5]
AA ORD-YUL MAR 1.8>0[1.9]
AA ORD-YYC MAR 1.0>0[0.9]
AA ORD-YYZ MAR 3>0[5] MAY 5>4[3]
AA ORF-PHL MAR 4>1.3[5]
AA PBI-PHL MAR 4>1.3[3]
AA PDX-PHX MAR 4>3[2]
AA PHF-PHL MAR 0.9>0[1.8]
AA PHL-PHX MAR 6>4[7]
AA PHL-PIT MAR 5>1.2[4]
AA PHL-PLS MAR 0.2>0[0.3]
AA PHL-PVD MAR 3>0.9[4]
AA PHL-PWM MAR 4>1.0[5]
AA PHL-RDU FEB 1.4>1.6[6] MAR 6>0.6[4]
AA PHL-RIC MAR 5>1.3[5]
AA PHL-ROC MAR 3>1.0[4]
AA PHL-RSW MAR 4>1.5[4]
AA PHL-SAN MAR 3>0.5[1.8]
AA PHL-SAV MAR 0.5>1.2[2.0]
AA PHL-SBY MAR 1.4>0.7[1.8]
AA PHL-SCE MAR 2>0.7[4]
AA PHL-SDF MAR 2>0.3[1.9]
AA PHL-SEA MAR 3>0[0.7]
AA PHL-SFO MAR 5>0.5[4]
AA PHL-SRQ MAR 0.1>0.6[1.0]
AA PHL-STL MAR 4>0.8[3]
AA PHL-SYR MAR 2>1.1[5]
AA PHL-TPA MAR 5>1.2[4]
AA PHL-YUL MAR 1.8>0.4[1.7]
AA PHL-YYZ MAR 1.5>1.0[3]
AA PHX-PIT MAR 1.0>0.1[1.6]
AA PHX-PSP MAR 5>4[5]
AA PHX-RDU MAR 1.0>0[0.9]
AA PHX-ROW MAR 0.7>0[0.9]
AA PHX-SAF MAR 0.9>0[1.6]
AA PHX-SAN MAR 5>4[6]
AA PHX-SAT MAR 4>3[3]
AA PHX-SBA MAR 5>3[4]
AA PHX-SBP MAR 4>3[3]
AA PHX-SEA MAR 4>3[2]
AA PHX-SFO FEB 1.8>1.3[5] MAR 5>3[3]
AA PHX-SGU MAR 2.0>3[3]
AA PHX-SJC MAR 4>3[4]
AA PHX-SLC MAR 5>4[4]
AA PHX-SMF MAR 5>2[3]
AA PHX-YUM MAR 4>5[5]
AA PIT-RDU MAR 1.0>0[0.9]
AC PBI-YUL APR 0.3>0[1.0]
AC PBI-YYZ APR 0.6>0[2]
AC SFO-YVR FEB 0.6>1.0[5]
AM JFK-MEX FEB 2>1.0[2]
AR EZE-JFK APR 0.9>0[0.5] MAY 0.8>0[0.2] JUN 0.9>0.1[0]
AR EZE-MIA APR 1.4>0.9[2] MAY 1.5>0.9[0.6] JUN 1.4>0.9[0.7]
AS GDL-LAX MAR 1.0>0.7[0.9]
AS JAC-SJC MAR 0.3>0[0]
AS MSO-SFO MAR 0.5>0[0] APR 1.0>0[0] MAY 1.0>0.4[0]
AS MSO-SJC MAR 0.5>0[0] APR 1.0>0[0] MAY 1.0>0.4[0]
AS PSP-RNO FEB 0.5>0[0.7] MAR 0.6>0[0] APR 0.3>0[0]
Looks like AS continues to prune intra-CA, only shortly after expanding it
**AS PSP-SJC FEB 1.1>0[1.9] MAR 1.8>0[0] APR 2.0>0[0] MAY 1.6>0[0] JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0.8[0]
AT CMN-JFK JUL 1.4>1.7[1.5]
AV BOG-IAD FEB 1.0>0.7[2]
AV BOG-JFK FEB 2>1.5[3]
AV BOG-MIA FEB 2>1.2[4]
AV EWR-SAL FEB 0.4>0.2[1.1]
AV MIA-SAL FEB 0.6>0.4[1.1]
AZ FCO-JFK MAR 1.0>0.7[1.9]
BW FLL-KIN FEB 1.0>0.8[1.1]
CM BOS-PTY FEB 0.4>0.1[0.4]
CM DEN-PTY FEB 0.4>0.2[0.4]
CM JFK-PTY FEB 3>2[3]
CM LAX-PTY FEB 1.5>1.0[1.6]
CM MCO-PTY FEB 3>1.6[3]
CM MIA-PTY FEB 4>3[5]
DL ABE-ATL MAR 3>1.5[2]
DL ABQ-ATL MAR 2.0>1.5[1.6]
**DL ACK-JFK JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
DL AGS-ATL MAR 7>5[7]
DL ALB-ATL MAR 3>1.6[3]
DL ANC-SLC MAR 1.0>0[0]
DL APN-DTW MAR 0.9>1.6[0.9]
DL APN-PLN MAR 0.7>0[0.7]
DL ATL-ATW MAR 1.9>0.9[1.7]
DL ATL-AUS MAR 8>7[7]
DL ATL-AVL MAR 7>5[6]
DL ATL-BDL MAR 6>4[6]
DL ATL-BHM MAR 9>6[8]
DL ATL-BNA MAR 10>7[9]
DL ATL-BOI MAR 1.0>0.5[0]
DL ATL-BOS MAR 12>7[9]
DL ATL-BTR MAR 5>4[5]
DL ATL-BUF MAR 4>1.9[3]
DL ATL-BWI MAR 9>6[9]
DL ATL-CAE MAR 7>5[8]
DL ATL-CHA MAR 6>5[9] APR 9>8[10]
DL ATL-CHO MAR 4>1.9[4]
DL ATL-CHS MAR 10>8[9]
DL ATL-CID MAR 0>0.8[1.9]
DL ATL-CLT MAR 9>7[8]
DL ATL-CMH MAR 7>6[7]
DL ATL-DAB MAR 5>4[5]
DL ATL-DAY MAR 4>3[4]
DL ATL-DCA MAR 11>7[10]
DL ATL-DFW MAR 8>7[8]
DL ATL-EWR MAR 9>8[9]
DL ATL-EZE MAR 1.0>0.5[0.9]
DL ATL-FAY MAR 4>3[4]
DL ATL-FLL MAR 14>12[13]
DL ATL-FSD MAR 0>0.9[0.8]
DL ATL-FWA MAR 3>2[3]
DL ATL-GEG MAR 1.0>0.6[0]
DL ATL-GNV MAR 6>3[7]
DL ATL-GPT MAR 4>3[4]
DL ATL-GRR MAR 4>3[4]
DL ATL-GSO MAR 7>5[7]
DL ATL-GSP MAR 7>6[8]
DL ATL-GTR MAR 3>1.9[3]
DL ATL-HOU MAR 6>5[5]
DL ATL-HPN MAR 6>3[6]
DL ATL-HSV MAR 7>5[7]
DL ATL-IAD MAR 7>4[6]
DL ATL-IND MAR 8>6[8]
DL ATL-JAC MAR 0.9>1.1[0.7]
DL ATL-JAN MAR 7>4[7]
DL ATL-JAX MAR 11>9[10]
DL ATL-JFK MAR 7>5[7]
DL ATL-LAS MAR 8>7[7]
DL ATL-LEX MAR 7>5[7]
DL ATL-LGA MAR 15>7[13] JUN 15>16[4] JUL 15>16[5] AUG 15>16[10] SEP 15>16[8]
DL ATL-LIT MAR 6>4[6]
DL ATL-MCI MAR 7>6[7]
DL ATL-MCO MAR 16>14[15]
DL ATL-MEM MAR 10>6[8]
DL ATL-MGM MAR 5>3[6]
DL ATL-MKE MAR 6>4[6]
DL ATL-MLI MAR 2>1.7[3]
DL ATL-MLU MAR 3>2[3]
DL ATL-MOB MAR 6>3[6]
DL ATL-MSP MAR 11>8[10]
DL ATL-MSY MAR 9>7[9] JUL 10>11[3] AUG 10>11[7]
DL ATL-MYR MAR 4>3[4]
DL ATL-OAJ MAR 4>3[3]
DL ATL-OKC MAR 6>4[5]
DL ATL-ONT MAR 3>1.5[1.6]
DL ATL-ORD MAR 8>6[9]
DL ATL-PHL MAR 8>7[9]
DL ATL-PHX MAR 8>7[6]
DL ATL-PIT MAR 7>5[7]
DL ATL-PNS MAR 7>6[7]
DL ATL-PSP MAR 0.9>0[0.5]
DL ATL-PVD MAR 3>1.6[3]
DL ATL-RDU MAR 10>8[10]
DL ATL-RIC MAR 8>6[8]
DL ATL-RNO MAR 1.0>0.6[0.3]
DL ATL-ROA MAR 4>2[4]
DL ATL-ROC MAR 3>1.9[3]
DL ATL-RSW MAR 10>9[7]
DL ATL-SAN MAR 5>3[4]
DL ATL-SAT MAR 7>5[6]
DL ATL-SAV MAR 9>7[9]
DL ATL-SBN MAR 3>2[3]
DL ATL-SDF MAR 8>6[8]
DL ATL-SEA MAR 7>5[5]
DL ATL-SFO MAR 7>4[6]
DL ATL-SGF MAR 3>2[4]
DL ATL-SHV MAR 5>4[5]
DL ATL-SLC MAR 10>9[7]
DL ATL-SNA MAR 3>1.5[3]
DL ATL-SRQ MAR 8>7[5]
DL ATL-STL MAR 7>5[7]
DL ATL-SYR MAR 3>1.9[3]
DL ATL-TLH MAR 6>4[7]
DL ATL-TPA MAR 13>12[12]
DL ATL-TRI MAR 5>3[5]
DL ATL-TUL MAR 4>3[4]
DL ATL-TUS MAR 3>2[2]
DL ATL-TYS MAR 8>7[8]
DL ATL-VLD MAR 1.3>4[3]
DL ATL-XNA MAR 5>4[5]
DL ATL-YYZ MAR 6>1.7[6]
DL ATW-DTW MAR 3>2[3]
DL ATW-MSP MAR 3>2[3]
DL AUS-BOS MAR 1.7>0.9[0.8]
DL AUS-JFK MAR 2>1.9[3]
DL AUS-MSP MAR 1.9>3[1.7]
DL AUS-SEA MAR 1.8>0.5[0.8]
DL AZO-DTW MAR 4>3[4]
DL AZO-MSP MAR 0.7>0[0.8] APR 0.7>0.5[1.5]
DL BDL-DTW MAR 5>3[4]
DL BDL-MSP MAR 3>1.7[3]
DL BGM-DTW MAR 3>1.0[1.7]
DL BHM-DTW MAR 1.0>0.6[2]
DL BIL-MSP MAR 3>1.0[1.7]
DL BNA-BOS MAR 3>1.0[2]
DL BNA-DTW MAR 5>4[4]
DL BNA-JFK MAR 1.9>0[3]
DL BNA-LGA MAR 5>2[4]
DL BNA-SEA MAR 0.8>0.5[0.8]
DL BNA-SLC MAR 0.8>1.6[1.6]
DL BOI-MSP MAR 1.9>1.5[1.5]
DL BOI-SEA MAR 6>4[6]
DL BOI-SLC MAR 5>4[5]
DL BOS-CHS MAR 0.7>0[0.9]
DL BOS-CLE MAR 3>0.8[2]
DL BOS-CMH MAR 2>0[2]
DL BOS-CVG MAR 4>0.5[3]
DL BOS-DCA MAR 4>0[5]
DL BOS-DTW MAR 6>3[5]
DL BOS-EWR MAR 3>0[4]
DL BOS-IND MAR 3>0[2]
DL BOS-JAX MAR 2>0[1.7]
DL BOS-JFK MAR 6>1.7[6]
DL BOS-LAS MAR 0.9>0[0.9]
DL BOS-LGA MAR 13>2[12]
DL BOS-MKE MAR 1.5>0[1.6]
DL BOS-MSP MAR 6>2[5]
DL BOS-ORD MAR 3>0[4]
DL BOS-PBI MAR 1.0>0[1.4]
DL BOS-PHL MAR 4>0[5]
DL BOS-RDU MAR 5>1.9[5]
DL BOS-RIC MAR 1.2>0.4[2]
DL BOS-RSW MAR 1.9>0[1.4]
DL BOS-SEA MAR 4>1.4[1.4]
DL BOS-SFO MAR 1.0>0[0.9]
DL BOS-SLC MAR 2.0>1.5[1.8]
DL BOS-TPA MAR 3>1.9[2]
DL BTV-DTW MAR 3>1.7[2]
DL BTV-JFK MAR 1.8>0.9[1.8]
DL BTV-LGA MAR 1.7>0[1.6]
DL BUF-DTW MAR 4>3[4]
DL BUF-JFK MAR 4>2[4]
DL BUF-LGA MAR 3>0[3]
DL BWI-DTW MAR 4>3[4]
DL BWI-JFK MAR 3>0[4]
DL BWI-MSP MAR 3>1.8[3]
DL BWI-SLC MAR 0.9>0.5[0.9]
DL BZN-LAX MAR 0.7>1.0[0.2]
DL BZN-MSP MAR 3>1.6[1.9]
DL CAE-LGA MAR 1.6>0[1.5]
DL CDG-DTW MAR 1.0>0[0.9]
DL CHA-LGA MAR 0.8>0[0.7]
DL CHO-LGA MAR 2>0[2]
DL CHS-DTW MAR 3>1.6[0]
DL CHS-LGA MAR 3>1.0[2]
DL CID-DTW MAR 2>0.8[3]
DL CID-MSP MAR 3>2[3]
DL CIU-DTW MAR 0.8>1.0[0.8]
DL CLE-DTW MAR 6>3[4] APR 7>6[5]
DL CLE-JFK MAR 3>0[4]
DL CLE-LGA MAR 5>0.8[4]
DL CLE-MSP MAR 4>3[3]
DL CLT-JFK MAR 3>0[3]
DL CLT-LGA MAR 7>2[6]
DL CMH-DTW MAR 6>4[5] APR 7>6[6]
DL CMH-JFK MAR 3>0[3]
DL CMH-LGA MAR 5>2[5]
DL COS-SLC MAR 1.9>3[1.9]
DL CVG-DCA MAR 3>0.5[2]
DL CVG-DTW MAR 5>4[4]
DL CVG-EWR MAR 2>0.5[2]
DL CVG-JFK MAR 0.9>0[1.9]
DL CVG-LAS MAR 1.0>0.6[0.9]
DL CVG-LAX MAR 0.9>0.5[0.9]
DL CVG-LGA MAR 5>1.4[5]
DL CVG-MSP MAR 4>3[4]
DL CVG-ORD APR 4>3[4]
DL CWA-DTW MAR 1.5>0.9[1.6]
DL CWA-MSP MAR 1.9>1.4[1.7]
DL DCA-DTW MAR 6>3[6]
DL DCA-JFK MAR 4>1.8[4]
DL DCA-LGA MAR 8>1.8[7]
DL DCA-MSP MAR 5>2[5]
DL DEN-JFK MAR 1.8>0.9[1.9]
DL DEN-LGA MAR 1.8>1.0[1.6]
DL DEN-MSP MAR 6>5[4]
DL DEN-SEA MAR 4>3[4]
DL DEN-SLC MAR 6>4[4]
DL DFW-DTW MAR 5>4[4]
DL DFW-LAX MAR 3>2[3]
DL DFW-LGA MAR 5>3[5]
DL DSM-DTW MAR 3>1.4[3]
DL DSM-MSP MAR 4>3[4]
DL DSM-SLC MAR 1.0>0[0.7]
DL DTW-ELM MAR 4>1.4[4]
DL DTW-EVV MAR 3>0.9[2]
DL DTW-EWR MAR 5>3[5]
DL DTW-FWA MAR 3>1.9[3]
DL DTW-GSO MAR 3>0.6[3]
DL DTW-GSP MAR 3>1.2[3]
DL DTW-HPN MAR 3>0[3]
DL DTW-IND MAR 6>4[6]
DL DTW-ITH MAR 2>1.0[1.9]
DL DTW-JFK MAR 3>1.9[4]
DL DTW-LAN MAR 4>3[4]
DL DTW-LAS MAR 6>5[4]
DL DTW-LEX MAR 3>1.4[3]
DL DTW-LGA MAR 7>3[6]
DL DTW-LSE MAR 0.7>1.0[0.9]
DL DTW-MBS MAR 4>3[4]
DL DTW-MCI MAR 4>2[3]
DL DTW-MEM MAR 3>1.7[2]
DL DTW-MKE MAR 5>2[4]
DL DTW-MQT MAR 1.4>1.0[0.9] APR 1.9>1.5[1.6]
DL DTW-MSN MAR 4>3[4]
DL DTW-MSP MAR 7>5[7]
DL DTW-MSY MAR 3>0.6[2]
DL DTW-OMA MAR 3>1.3[2]
DL DTW-ORD MAR 6>4[6]
DL DTW-PDX MAR 1.0>0[0.6]
DL DTW-PHL MAR 5>4[4]
DL DTW-PIT MAR 5>3[4]
DL DTW-PVD MAR 3>0[3]
DL DTW-RDU MAR 5>4[3]
DL DTW-RIC MAR 2>1.3[3]
DL DTW-SAN MAR 3>1.5[1.6]
DL DTW-SAT MAR 3>1.8[1.6]
DL DTW-SCE MAR 2>0.8[1.9]
DL DTW-SDF MAR 4>2[3]
DL DTW-SFO MAR 4>2[3]
DL DTW-SLC MAR 6>4[4]
DL DTW-STL MAR 5>3[4]
DL DTW-TVC MAR 3>1.9[4]
DL DTW-TYS MAR 4>1.3[3]
DL DTW-YUL MAR 3>1.0[3]
DL DTW-YYZ MAR 4>3[4]
DL EUG-SLC MAR 3>1.8[1.7]
DL EWR-MSP MAR 4>3[4]
DL EWR-RDU MAR 3>0[2]
DL EWR-SLC MAR 1.8>1.0[1.7]
**DL EYW-LGA APR 0>1.3[0.1] MAY 0>2[0] JUN 0>2[0] JUL 0>2[0] AUG 0>2[0] SEP 0>0.4[0]
DL FAR-MSP MAR 6>5[6]
DL FCA-MSP MAR 0.8>1.8[0.9]
DL GEG-MSP MAR 1.9>1.5[1.5]
DL GEG-SEA MAR 8>5[7]
DL GFK-MSP MAR 5>3[4] APR 6>4[5]
DL GRR-MSP MAR 4>2[4]
DL GSO-LGA MAR 4>0[3]
DL GSP-LGA MAR 2>0[2]
**DL HHH-LGA MAR 0>1.6[0] APR 0>1.1[0] MAY 0>1.7[0] JUN 0>1.7[0] JUL 0>1.7[0] AUG 0>1.7[0] SEP 0>0.3[0]
DL HLN-SLC MAR 2>1.8[3]
DL HNL-LAX MAR 4>3[3]
DL HNL-MSP MAR 1.0>0.7[0.7]
DL IAD-JFK MAR 1.2>0[3]
DL IAD-MSP MAR 3>1.7[2]
DL IAD-SEA MAR 1.8>0[0.7]
DL IAD-SLC MAR 1.0>0.5[0.7]
DL IAH-JFK MAR 1.9>0[1.9]
DL IAH-LGA MAR 4>1.6[4]
DL IAH-MSP MAR 5>3[4]
DL ICT-MSP MAR 3>1.7[1.7]
DL IDA-SLC MAR 3>4[4]
DL IND-JFK MAR 1.3>0[1.9]
DL IND-LGA MAR 4>1.0[4]
DL IND-MSP MAR 4>2[4]
DL IND-SEA MAR 0.8>0[0.7]
DL JAC-MSP MAR 0.8>1.0[0]
DL JAX-JFK MAR 3>1.5[3]
DL JAX-LGA MAR 3>0[3]
DL JFK-LAS MAR 4>1.5[4]
DL JFK-LAX MAR 8>6[8]
DL JFK-MCO MAR 4>5[4]
DL JFK-MSP MAR 4>1.9[4]
DL JFK-MSY MAR 3>1.5[3]
**DL JFK-MVY JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
DL JFK-ORD MAR 2>1.9[4]
DL JFK-ORF MAR 3>0[3]
DL JFK-PBI MAR 0.9>0[1.0]
DL JFK-PDX MAR 1.0>0[0.9]
DL JFK-PIT MAR 3>0[3]
DL JFK-PWM MAR 1.9>0[1.9]
DL JFK-RDU MAR 5>3[4]
DL JFK-RIC MAR 3>0[3]
DL JFK-SAN MAR 3>0.9[2]
DL JFK-SAT MAR 1.0>0[0.9]
DL JFK-SAV MAR 1.9>1.5[1.7]
DL JFK-SFO MAR 6>2[6]
DL JFK-SJC MAR 0.8>0[0.6]
DL JFK-SYR MAR 1.8>2[1.9]
DL JFK-TPA MAR 4>3[4]
DL JFK-YYZ MAR 2>0[3]
DL LAS-LAX MAR 4>3[6]
DL LAS-SEA MAR 5>3[5]
DL LAX-MCI MAR 1.7>0[1.6]
DL LAX-MEM MAR 0.8>0.5[0.7]
DL LAX-MSY MAR 3>1.5[3]
DL LAX-OGG MAR 2.0>1.4[1.5]
DL LAX-PDX MAR 4>3[4]
DL LAX-PHX MAR 4>3[5]
DL LAX-PVR FEB 1.7>1.1[2]
DL LAX-RDU MAR 0.9>0.5[0.9]
DL LAX-SAT MAR 1.5>1.0[1.6]
DL LAX-SEA MAR 7>5[7]
DL LAX-SFO MAR 6>3[6]
DL LAX-SJC MAR 4>1.9[5]
DL LAX-SLC MAR 7>5[7]
DL LEX-LGA MAR 0.8>0[0.7]
DL LGA-MCI MAR 4>1.0[3]
DL LGA-MEM MAR 3>0[2]
DL LGA-MIA MAR 5>4[4]
DL LGA-MKE MAR 4>0.8[4]
DL LGA-MSN MAR 2>0[2]
DL LGA-MSP MAR 6>2[6]
DL LGA-MSY MAR 3>1.0[2]
**DL LGA-MYR MAR 0>0.6[0] APR 0>0.6[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
DL LGA-OMA MAR 2>0[1.5]
DL LGA-ORD MAR 12>4[10]
DL LGA-ORF MAR 4>1.0[4]
DL LGA-PIT MAR 6>1.4[6]
DL LGA-PWM MAR 3>1.0[3]
DL LGA-RDU MAR 7>2[6]
DL LGA-RIC MAR 4>1.6[4]
DL LGA-ROC MAR 3>0[3]
DL LGA-RSW MAR 2>1.6[3]
DL LGA-SAV MAR 3>0[1.6]
DL LGA-SDF MAR 3>0[2]
DL LGA-STL MAR 5>1.0[5]
DL LGA-SYR MAR 2>0[2]
DL LGA-TPA MAR 4>3[3]
DL LGA-TYS MAR 2>0[2]
DL LGA-XNA MAR 0.8>0[0.7]
DL LGB-SLC MAR 5>2[4]
DL MCI-MSP MAR 5>3[5]
DL MCI-SEA MAR 1.0>0[0.8]
DL MCI-SLC MAR 3>1.4[2]
DL MEM-MSP MAR 3>1.9[2]
DL MFR-SLC MAR 3>1.7[1.7]
DL MIA-SLC MAR 1.0>1.5[0]
DL MKE-MSP MAR 5>3[5]
DL MKE-SEA MAR 0.8>0[0.8]
DL MOT-MSP MAR 4>5[4]
DL MSN-MSP MAR 4>3[5]
DL MSO-MSP MAR 1.0>1.8[0.7]
DL MSP-MSY MAR 1.0>0.6[1.4]
DL MSP-OMA MAR 6>3[6]
DL MSP-ORD MAR 6>3[6]
DL MSP-PDX MAR 4>2[3]
DL MSP-PHL MAR 5>3[3]
DL MSP-PHX MAR 8>7[6]
DL MSP-PIT MAR 4>1.7[3]
DL MSP-RDU MAR 3>1.7[3]
DL MSP-SAN MAR 4>3[3]
DL MSP-SAT MAR 3>1.9[1.6]
DL MSP-SDF MAR 3>1.0[1.7]
DL MSP-SEA MAR 6>4[5]
DL MSP-SFO MAR 5>3[4]
DL MSP-SLC MAR 6>4[4]
DL MSP-SMF MAR 1.8>1.0[0.7]
DL MSP-SNA MAR 3>1.0[2]
DL MSP-STL MAR 5>3[5]
DL MSP-YWG MAR 4>1.0[4]
DL MSP-YYC MAR 3>1.8[3]
DL OKC-SLC MAR 1.4>1.7[1.6]
DL ORD-SEA MAR 3>1.0[3]
DL ORD-SLC MAR 4>2[3]
DL PDX-SEA MAR 6>5[7]
DL PSC-SEA MAR 4>3[3]
DL RDM-SLC MAR 3>1.7[1.7]
DL RDU-SEA MAR 1.0>0.5[0.9]
DL RDU-SLC MAR 1.0>0.6[0.9]
DL SAN-SEA MAR 5>3[4]
DL SEA-SFO MAR 7>3[5]
DL SEA-SJC MAR 6>3[5]
DL SEA-SLC MAR 8>5[6]
DL SEA-SMF MAR 4>3[4]
DL SEA-SNA MAR 5>1.9[3]
DL SEA-YVR MAR 5>1.9[5]
DL SGU-SLC MAR 4>5[4]
DL SLC-STL MAR 3>1.6[1.7]
DL SLC-SUN MAR 4>3[3]
DL SLC-YYC MAR 0.9>0[0.9]
EI BDL-DUB FEB 0.3>0[0.5] MAR 0.5>0[0.4]
EI DUB-IAD FEB 0.5>0[1.0] MAR 1.0>0.6[0.5]
EI DUB-LAX FEB 0.3>0[0.7] MAR 0.7>0[0.5]
EI DUB-MCO FEB 0.3>0[0.6] MAR 0.5>0.0[0.5]
EI DUB-PHL FEB 0.5>0[0.9] MAR 0.9>0[0.4]
EI DUB-SEA FEB 0.3>0[0.7] MAR 0.7>0[0.4]
EI DUB-SFO FEB 0.5>0[1.1] MAR 1.0>0.1[0.9]
F2 KIS-MDR FEB 0>0.6[0] MAR 0>0.5[0] APR 0>0.6[0] MAY 0>0.6[0] JUN 0>0.5[0] JUL 0>0.6[0] AUG 0>0.6[0] SEP 0>0.5[0]
F2 MDR-WIL JUL 4>3[0] AUG 4>3[0] SEP 4>3[0]
F9 ABQ-DEN MAR 0>0.3[0.4]
F9 ALB-MCO MAR 0.8>0.5[0.5]
F9 ALB-TPA MAR 0.4>0.1[0]
F9 ATL-CVG MAR 0.5>0.1[0]
F9 ATL-DEN MAR 1.0>1.6[0.9]
F9 ATL-EWR MAR 0.8>0.2[0.9]
F9 ATL-ISP MAR 0.4>0.1[0.4]
F9 ATL-PHL MAR 1.8>1.4[0.5]
F9 ATL-RDU MAR 0.8>0.5[0.9]
F9 ATL-SLC MAR 0.4>0.1[0.4]
F9 ATL-TPA MAR 0.8>0.2[0.4]
F9 ATL-TTN MAR 0.8>0.4[0.9]
F9 AUS-LAS MAR 0.9>0.6[0.9]
F9 AUS-MCO MAR 0.9>0.4[0.4]
F9 AUS-MIA MAR 0.5>0.1[0]
F9 AUS-SAN MAR 0.4>0.1[0.4]
F9 AUS-SLC MAR 0.5>0.1[0.5]
F9 BDL-MIA MAR 0.4>0.1[0.3]
F9 BIL-DEN MAR 0.2>0.0[0.4]
F9 BNA-DEN MAR 0.9>0.5[0.4]
F9 BNA-MCO MAR 0.9>0.6[0.9]
F9 BOS-MIA MAR 1.0>0.7[0.4]
F9 BOS-RSW MAR 0.5>0.1[0]
F9 BOS-SJU MAR 0.8>0.2[0]
F9 BOS-TPA MAR 0.4>0.1[0]
F9 BUF-MCO MAR 1.2>0.8[0.8]
F9 BUF-MIA MAR 0.3>0.1[0]
F9 BWI-MCO MAR 0.9>0.6[0.5]
F9 BWI-MIA MAR 0.0>0.3[0]
F9 BWI-SJU MAR 0.8>0.2[0]
F9 CHS-PHL MAR 0.0>0.2[0]
F9 CLE-PBI MAR 0.4>0.1[0.5]
F9 CLE-TPA MAR 1.8>1.2[1.9]
F9 CLT-LAS MAR 0.8>0.2[0.9]
F9 CLT-MCO MAR 0.9>0.7[0.9]
F9 CLT-TTN MAR 0.5>0.1[0.5]
F9 COS-MCO MAR 0.2>0.0[0.4]
F9 CUN-EWR MAR 0.5>0.1[0]
F9 CVG-DEN MAR 1.4>1.0[0.5]
F9 CVG-DFW MAR 0.5>0.1[0]
F9 CVG-MCO MAR 3>2.0[1.5]
F9 CVG-MIA MAR 0.6>0.4[0.4]
*F9 CVG-MSY APR 0.1>0.3[0.3] MAY 0>0.3[0.2] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0]
F9 CVG-RSW MAR 1.6>1.1[1.2]
F9 CVG-TPA MAR 1.5>1.0[0.5]
F9 DCA-DEN MAR 3>2[3]
F9 DEN-DTW MAR 0>0.3[0]
F9 DEN-FAR MAR 0.0>0.3[0]
F9 DEN-GRR MAR 0>0.3[0]
F9 DEN-ICT MAR 0.0>0.2[0.5]
F9 DEN-IND MAR 0.9>0.6[0.5]
F9 DEN-LAS MAR 4>3[4]
F9 DEN-MSY MAR 0.9>0.6[0.5]
F9 DEN-ORD MAR 1.0>1.3[0.9]
F9 DEN-PNS MAR 0.5>0.3[0.3]
F9 DEN-SEA MAR 0.6>0.8[0.4]
F9 DEN-SMF MAR 0.9>0.5[0.4]
F9 DEN-SNA MAR 1.0>1.5[0.9]
F9 DEN-TUL MAR 0.1>0.3[0]
F9 DFW-MCO MAR 0.9>0.5[0.5]
F9 DFW-PHL MAR 0.4>0.1[0.5]
F9 DTW-LAS MAR 0.9>0.6[0.9]
F9 DTW-MIA MAR 0.9>0.5[0.5]
F9 DTW-PHX MAR 0.8>0.2[0.5]
F9 EWR-MIA MAR 1.8>1.2[1.9]
F9 EWR-MYR MAR 0.4>0.1[0]
F9 EWR-PBI MAR 0.8>0.2[0.9]
F9 EWR-PHX MAR 0.8>0.2[0.9]
F9 EWR-RSW MAR 0.4>0.1[0]
**F9 GEG-LAS MAY 0>0.3[0.5] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0]
F9 IAD-MCO MAR 0.9>0.5[0.4]
F9 IND-MCO MAR 0.9>0.6[0.5]
F9 ISP-LAS MAR 0.4>0.2[0]
F9 ISP-MCO MAR 3>1.6[1.7]
F9 ISP-MIA MAR 0.9>0.6[0]
F9 ISP-PBI MAR 1.7>0.8[0.9]
F9 ISP-RSW MAR 0.9>0.7[0.9]
F9 ISP-TPA MAR 1.5>0.6[0.9]
F9 JAX-PHL MAR 0.5>0.4[0.4]
F9 LAS-LAX MAR 0.8>1.6[0.9]
F9 LAS-MIA APR 0.8>1.0[1.0] MAY 0.7>1.0[1.0] JUN 0.7>1.0[0] JUL 0.7>1.0[0.2] AUG 0.7>1.0[0.3] SEP 0.7>1.0[0.0]
F9 LAS-SAN MAR 0.8>1.6[0.9]
F9 LAS-SJC MAR 1.7>0.6[0.5]
F9 LAS-SLC MAR 1.8>1.0[0.6]
*F9 LAS-TPA APR 0.4>1.0[1.0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
F9 LAX-MCO MAR 0.8>0.2[0]
F9 MCO-MIA MAR 1.0>1.6[0]
F9 MCO-MKE MAR 0.9>1.1[0.9]
F9 MCO-MSP MAR 0.4>0.8[0.5]
F9 MCO-MSY MAR 0.9>0.5[0.4]
F9 MCO-ONT MAR 0.6>0.8[0.9]
F9 MCO-PHL MAR 5>3[3]
**F9 MCO-PHX MAR 0>0.7[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
F9 MCO-PVD MAR 1.6>1.0[0.9]
F9 MCO-RDU MAR 0.9>1.5[0.9]
**F9 MCO-SAN MAR 0>0.8[0.9] MAY 0>1.0[0.7] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
F9 MCO-SDF MAR 0>0.2[0.4]
F9 MCO-STL MAR 1.7>1.2[0.9]
F9 MCO-SYR MAR 0.5>0.8[0.5]
F9 MIA-PHL MAR 3>1.3[0.9]
**F9 MIA-PUJ MAR 0>0.2[0] APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0]
F9 MIA-PVD MAR 0.5>0.1[0]
F9 MIA-RDU MAR 0.9>0.6[0.9]
F9 MIA-SDQ FEB 0.3>0[0.5]
F9 MIA-TTN MAR 0.9>0.4[0]
F9 MKE-RSW MAR 0.5>0.7[0.9]
F9 MKE-TPA MAR 0.5>0.8[0.9]
F9 MSP-RSW MAR 0>0.3[0.4]
**F9 MSP-TPA APR 0.2>0.6[0.6] MAY 0>0.6[0.2] JUN 0>0.6[0] JUL 0>0.6[0] AUG 0>0.6[0] SEP 0>0.6[0]
F9 MSY-PHL MAR 0.9>0.6[0.4]
F9 MYR-PHL MAR 0>0.2[0]
F9 ORD-TPA MAR 0.5>0.8[0.7]
F9 PBI-PHL MAR 0.9>0.4[0.5]
F9 PBI-TTN MAR 0.9>0.5[1.3]
F9 PHL-PHX MAR 0.8>0.2[0]
F9 PHL-RSW MAR 1.8>1.1[1.9]
F9 PHL-SAV MAR 0.1>0.3[0]
F9 PHL-TPA MAR 3>1.4[1.9]
F9 PHX-SFO MAR 0.1>0.7[0]
F9 PHX-SJC MAR 0.6>0.4[0]
F9 PVD-TPA MAR 0.8>0.4[0.5] APR 0.6>0.4[0.6] AUG 0.2>0.4[0] SEP 0>0.4[0]
F9 PWM-RSW MAR 0.4>0.8[0.5]
F9 RDU-TTN MAR 0.5>0.1[0.5]
F9 RSW-TTN MAR 0.9>0.6[0.9]
F9 SRQ-TTN MAR 0.5>0.1[0.5]
F9 TPA-TTN MAR 0.8>0.5[0.9]
G4 AZA-FAR AUG 0.3>0.1[0.5]
G4 AZA-PVU AUG 0.8>0.6[1.8]
*HA AKL-HNL APR 0.4>0[0.4] MAY 0.4>0[0] JUN 0.4>0[0]
*HA BNE-HNL APR 0.4>0[0.4] MAY 0.4>0[0] JUN 0.4>0[0]
*HA HNL-SYD APR 1.0>0[0.7] MAY 1.0>0[0] JUN 1.0>0[0]
IB JFK-MAD FEB 0.6>0.3[1.1]
KL AMS-IAD APR 1.0>0.8[1.0]
KL AMS-JFK APR 3>2[2]
KL AMS-LAS APR 0.6>0.1[0.4]
KL AMS-MSP APR 0.6>0.1[0.6]
KL AMS-SFO APR 1.7>0.7[1.1]
KL AMS-SLC APR 0.4>0.1[0.0]
LA LAX-SCL APR 1.0>0.4[0.6] MAY 1.0>0.5[0.0] JUN 1.0>0.4[1.0] JUL 1.0>0.7[0.9] AUG 1.0>0.7[1.0] SEP 1.0>0.7[1.0]
LF BNA-TUP APR 0>1.9[3] MAY 0>1.9[2] JUN 0>1.9[3] JUL 0>1.9[2] AUG 0>1.9[3] SEP 0>1.9[3]
LY EWR-TLV FEB 0.9>0.5[1.5]
NK FLL-MGA FEB 1.0>0.7[1.1]
NK LAS-SNA MAY 2>3[0]
NK LBE-RSW MAR 0.4>0.2[0.5]
*NK LBE-TPA MAR 0.3>0[0.3] APR 0.2>0[0.5]
**NK MCO-PAP MAR 0>0.3[0] APR 0>0.4[0] MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.5[0] AUG 0>0.4[0]
**NK MCO-SDQ MAR 0>0.4[0] APR 0>0.6[0] MAY 0>0.6[0] JUN 0>0.6[0] JUL 0>0.5[0] AUG 0>0.6[0]
NK MCO-STT MAR 0.5>1.0[0.4] APR 0.4>1.0[0.5] MAY 0.4>1.0[0.4] JUN 0.4>1.0[0] JUL 0.4>1.0[0] AUG 0.5>1.0[0.5]
NK PHX-SNA APR 1.0>0.7[0] MAY 1.0>0.5[0]
NZ AKL-HNL APR 0.6>0[0.5] MAY 0.5>0[0.6] JUN 0.6>0[0]
NZ AKL-IAH APR 0.8>0[0.9] MAY 0.7>0[0.7] JUN 0.7>0[0]
NZ AKL-LAX APR 1.7>0.3[2] MAY 1.6>0.3[1.7] JUN 1.6>0.3[0.4]
NZ AKL-ORD APR 0.4>0[0.4] MAY 0.4>0[0.4] JUN 0.4>0[0]
NZ AKL-SFO APR 0.7>0[0.9] MAY 0.7>0[0.7] JUN 0.7>0[0]
PR LAX-MNL FEB 0.9>0.6[1.3]
PR MNL-SFO FEB 0.6>0.3[0.9]
PS JFK-KBP APR 0.7>0.1[0.8]
QR ATL-DOH JUN 1.0>0.6[0] JUL 1.0>0.5[1.0] AUG 1.0>0.6[0] SEP 1.0>0.6[0]
QR BOS-DOH JUN 1.0>0.4[0] JUL 1.0>0.4[1.0] AUG 1.0>0.4[1.0] SEP 1.0>0.4[1.0]
More than daily!?
*QR DFW-DOH MAR 1.0>1.5[0.9] APR 1.0>1.4[1.0] MAY 1.0>1.4[1.0] JUN 1.0>1.5[0.5] JUL 1.0>1.4[1.0] AUG 1.0>1.4[1.0] SEP 1.0>1.4[1.0]
QR DOH-IAH MAR 0.7>0.9[0.9] APR 0.7>1.0[1.0] MAY 0.7>1.0[1.0]
QR DOH-MIA APR 0>0.3[1.0] MAY 0>0.3[0.7] JUN 1.0>0.3[0] JUL 1.0>0.5[0.7] AUG 1.0>0.4[0] SEP 1.0>0.4[0]
QR DOH-ORD APR 1.0>1.4[1.0] MAY 1.0>1.5[0.7] JUN 1.0>1.4[0.5] JUL 1.0>1.5[1.0] AUG 1.0>1.4[1.0] SEP 1.0>1.4[1.0]
QR DOH-PHL JUN 1.0>0.5[0] JUL 1.0>0.6[1.0] AUG 1.0>0.6[0] SEP 1.0>0.6[0]
SQ FRA-JFK APR 1.0>0[1.0]
SQ JFK-SIN APR 0>1.0[0]
SQ SFO-SIN APR 1.4>2[2]
SY HRL-MSP MAR 0.5>0.9[0.7]
SY MSP-SMF JUN 0.3>0[0.1] JUL 0.3>0[0.3] AUG 0.2>0[0.3]
TP EWR-LIS MAR 1.1>0.8[0.6]
TP IAD-LIS MAR 0.5>0.2[0.6] APR 1.6>1.0[0.7] MAY 1.6>1.0[0.0] JUN 1.6>1.0[0.3] JUL 1.5>1.0[0.8] AUG 1.6>1.0[0.3] SEP 1.6>1.0[0.4]
TP LIS-MIA APR 1.3>1.0[1.3] MAY 1.3>1.0[0.3] JUN 1.3>1.0[0.6] JUL 1.3>1.0[1.5] AUG 1.3>1.0[0.5] SEP 1.3>1.0[0.4]
TS FLL-YYZ MAR 0.6>0[0.7] APR 0.6>0[0.7]
TS MCO-YUL MAR 0.3>0[0.4] APR 0.3>0[0.4]
TS MCO-YYZ MAR 0.3>0[0.4] APR 0.3>0[0.4]
UA AUA-IAD MAR 0.8>0.6[0.2]
UA AUA-ORD MAR 0.8>0.2[0.8]
UA AUS-IAH AUG 10>9[9]
UA BLR-SFO MAY 0.8>0.1[0]
UA BRO-IAH APR 3>4[4]
UA BTR-IAH APR 6>7[7]
UA CDG-ORD MAR 0.2>0.5[0.7]
UA CRP-IAH APR 6>7[7]
UA DEN-DIK MAR 1.5>0.9[1.9]
UA DEN-PBI APR 0>1.0[0.2]
UA DEN-PNS APR 0>0.5[0.1]
UA DEN-SRQ APR 0>0.9[0.1]
UA DEN-VPS APR 0>0.5[0.1]
UA EWR-JAC FEB 0.6>0.4[0.8]
*UA EWR-JNB APR 1.0>0[0] MAY 1.0>0[0]
UA EWR-MTJ MAR 0.6>0.2[0.7]
UA IAH-ICT APR 3>4[4]
UA IAH-PNS APR 4>5[5]
UA IAH-RTB FEB 1.0>0.5[1.2]
UA LAX-PVR FEB 1.0>0.6[1.3]
UA LAX-SJD FEB 0.9>0.6[1.5]
UA PVR-SFO FEB 1.0>0.6[1.0]
UA SFO-SJD FEB 1.0>0.6[1.1]
VS ATL-LHR FEB 0.9>0.4[1.1]
**WN DEN-FAT APR 0>0.2[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>0.5[0]
**WN DEN-SBA APR 0>0.6[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>0.5[0]
**WN FAT-LAS APR 0>0.6[0] MAY 0>3[0] JUN 0>3[0] JUL 0>3[0] AUG 0>1.5[0]
**WN LAS-SBA APR 0>1.9[0] MAY 0>3[0] JUN 0>3[0] JUL 0>3[0] AUG 0>1.5[0]
**WN OAK-SBA APR 0>0.6[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>0.5[0]
WS FLL-YYZ MAR 2>0[2] APR 2>0.1[3]
WS HNL-YVR MAR 1.5>0[2] APR 1.8>0.2[3]
WS KOA-YVR MAR 0.7>0[0.9] APR 0.8>0[1.0]
panam330
Re: OAG Changes 1/27/2021:3M to GSP;AA JFK-ATH/TLV;DL LGA-EYW/HHH/MYR,JFK-ACK/MVY;F9 New Routes;NK MCO-PAP/SDQ;WN FAT/SB
Wed Jan 27, 2021 1:31 pm
WN 3 dailies from FAT/SBA-LAS. That’s... ambitious.
Oilman
Wed Jan 27, 2021 1:32 pm
Thanks for posting this! I don’t know California. Why would SBA get a flight to another California destination and not FAT?
Edit: I’m referring to the new WN service.
RicFlyer
Wed Jan 27, 2021 1:34 pm
Thanks for all the work you put into this every week!!
LASVegan
Wed Jan 27, 2021 1:35 pm
As always, thank you for this Enilria!
usairways85
Wed Jan 27, 2021 1:58 pm
AA at PHL in March looks very similar to Jan/Feb, not too surprising
ScottB
Wed Jan 27, 2021 2:44 pm
Geography. Fresno-Oakland takes under three hours by car. Santa Barbara-Oakland is closer to five hours.
Shields
Wed Jan 27, 2021 2:49 pm
Thanks for this!
Any idea why DL uses JFK for ACK and MVY as opposed to LGA? Is Delta relying more on connections from the west coast than O/D travellers (which, presumably, would prefer LGA)?
phatfarmlines
3M is slowly rebuilding the regional Florida-Southeast network that was a core part of DH's (Independence Air) network, later duplicated by DL Connection as a competitive response. Let's see if this works in the long-term with the right frequency and fleet type.
Interesting adds to Hispaniola. B6 last flew MCO-PAP on the E190, and NK will join B6 and F9 on MCO-SDQ.
Chuska
Wed Jan 27, 2021 2:56 pm
Some of the AA frequencies are still off, I would double check with AA.com. AA is adding a new late night bank out of PHX (2230) so markets like ABQ-PHX and ELP-PHX increase from 3 to 4 on Mar 4.Cant seem to narrow down whats causing it. Looks like many markets do show correctly though.
ChrisNH38
Wed Jan 27, 2021 3:13 pm
I can’t remember the last time AA flew non-stop BOS-LAX. My March trip has, just today, been routed through PHX westbound and Charlotte eastbound. Meanwhile, DL keeps their BOS-LAX flights going, and I wonder whether loyalty on that route will now shift from historically dominant AA to DL.
https://my.flightradar24.com/ChrisNH
freakyrat
Wed Jan 27, 2021 3:20 pm
"DL ATL-SBN MAR 3>2[3]" Delta will still operate 3 daily ATL-SBN on Sun, Mon, Thu and Fri. They will operate 2 daily on Tue, Wed and Sat.
MIflyer12
I don't believe it was THAT long ago, but with covid-reduced frequencies and routes, AA stepping back from LAX, and relying on B6 for more JFK/BOS flying, this is what you get.
cschleic
Wed Jan 27, 2021 3:28 pm
Connections?
jb1087xna
Wed Jan 27, 2021 3:30 pm
Thanks for pulling this together as always!!
Looks like most days of the week are actually flat to LY...6 and 5 flights respectively. Some specific days are lower though, which seem to be pulling the average down. Solid schedules for both areas again now and LIT even gets back 2 mainline flights in MAR.
enilria
Wed Jan 27, 2021 3:48 pm
OTOH, 1 RT on an extremely short route is generally considered to be ill-advised, so be careful what you wish for.
I see news that airlines think traffic is coming back faster than thought, BUT TSA data looks pretty poor and the new intl restrictions are another kick in the teeth. I don't see how demand can be coming back much.
Shields wrote:
Thanks for this!
There's only one logical answer. California connects. I have to assume there are a lot of Cali people with properties out there.
I think the logic must be that the new travel restrictions are more likely to hurt leisure rather than ethnic.
I'm going to say what I've been saying. It is not something I can fix. If you can find a common thread like the same equipment type is always missing or the same operator (OO for example) is always impacted I can get it reported it to the provider. Absent that I don't have enough information to do anything about it. Nobody has identified a common thread. Also, many of the times I have checked as a reader's request I have not found the error on the airline website, it was instead just confusion about day of week operation. So until somebody can tell me something like "AA/OO flights on E135s are mostly missing but only for March" I can't go any further with it. Just saying "AA is wrong" or "this route is wrong" doesn't find a pattern that can be addressed. They won't fix it "whac-a-mole" style. It needs to be an identified pattern.
cschleic wrote:
Connections?
I think it's a combination of local traffic, chasing leisure demand, and using these to fill empty connecting seats at LAS that were probably full in the past.
tphuang
Wed Jan 27, 2021 3:59 pm
Keep in mind that B6 runs the most number of flights here an they are going to be coordinating schedule with AA going forward.
SANFan
Wed Jan 27, 2021 4:13 pm
Looks like SJC and PSP are taking it on the chin this week. How is SJC doing overall in The Recovery?
AS seems to be handling March a bit more piecemeal than they did February; this is the second week in a row that they've made some cuts for March. Reminder: their March sked doesn't kick in until the 18th so we're just within 2 months now. (That's why so many fractional counts.) I expect the big March "adjustment" for AS will occur sometime around mid-February but maybe much of it will be done before then....
PSP surprises me as it certainly is mostly leisure and I would expect, especially considering Spring Break is in March this year, that it would be a good market. And, AS just can't seem to make PSP-SJC work permanently; seems to me it's been gone and back several times in the past years...
bb
AmericanAir88
Wed Jan 27, 2021 4:54 pm
F9 seems to be doing well. More additions to various routes and not many suspension. How are they doing in general?
Also, AA JFK-LAS still is not back :(
flyfresno
Wed Jan 27, 2021 5:32 pm
Can't speak to SBA, but FAT can and will support it (partially at the expense of Allegiant). LAS is a major connecting point, and the potential O&D has not been realized on that route. I foresee O&D to LAS doubling once demand picks back up.
Edit: Typos...sorry!
nc3rd
Wed Jan 27, 2021 5:34 pm
No one is doing well.
The views written above are mine and mine alone and do not represent any official information from any airline or company
Dominion301
Wed Jan 27, 2021 5:39 pm
bb
The new Biden administration is now telling people 'stay home', which is drastically different messaging than a couple of weeks ago. Almost certainly having an impact on cancellations. That and a ridiculous amount of capacity was being thrown at PSP, even in good times. Everyone had the same target on their dart board.
FATFlyer
Wed Jan 27, 2021 5:55 pm
Just to expand on that.
Allegiant currently plans to return to a 12X weekly schedule on FAT-LAS beginning in two weeks. (2X daily for 5 days/wk and 1X on 2 days) That is basically its pre-COVID schedule for only O&D since G4 has no connections
WN should capture some of that traffic, along with adding passengers connecting at LAS, and some market stimulation. It does not seem an overly ambitous schedule to offer.
"Travel is fatal to prejudice, bigotry, and narrow-mindedness." - Mark Twain
AmericanAir88
Wed Jan 27, 2021 7:49 pm
I should have clarified. I meant to say that F9 seems to be doing better than anticipated on certain routes. Probably from the increased demand to FL and Vegas.
Of course no airline is doing well, but from a micro point of view there are some glimpses of hope.
nc3rd
Wed Jan 27, 2021 7:59 pm
I wouldnt confuse dart boarding new routes with success thought. F9 has a history of adding new routes with much fanfare, while quietly closing an equal number.
MIflyer12
Wed Jan 27, 2021 8:01 pm
Understood, and thanks for the detailed explanation. Until somebody else can point to a more reliable, single data source I have to suggest we just learn to live with it.
SANFan
Wed Jan 27, 2021 8:06 pm
Are we expecting it back?
AS (apparently) has picked up SAN-JFK which in all likelihood AA has also dropped for good. And of course AA's other "partner", JetBlue, also serves the market. IMO, AA will not be missed.
Blue also serves JFK-LAS so that may take care of that route's coverage for AA by one of their partners. Remember that AS inherited LAS-JFK from Virgin but after a while dropped it. Will AS re-enter that market now that AA is out of it? I doubt it.
bb
AC4500
Wed Jan 27, 2021 8:43 pm
enilria wrote:
More than daily!?
I guess they're pretty confident in the success of partnering with AA. Still seems like way too much capacity though. It looks like the new flight will operate 3x weekly (Tue, Wed, Sat), making DFW-DOH 10x weekly total flights.
AS PDX-LAX: 737 MAX 9
QX LAX-PDX: E175
Ishrion
Wed Jan 27, 2021 8:51 pm
AC4500 wrote:
enilria wrote:
More than daily!?
To be honest, Qatar increasing DOH-DFW seems more like a retaliatory response against Emirates.
On January 11, Emirates announced it would resume DXB-DFW with 3x weekly flights from March 2. Ten days later, Qatar announced it would increase DFW with 3 additional weekly flights conveniently also starting March 2.
hiflyeras
Wed Jan 27, 2021 9:08 pm
bb
I believe AS said they weren't interested in returning to JFK-LAS. But AA has dropped flying out of LAX that I can see AS being interested in...stay tuned?
CIDFlyer
Wed Jan 27, 2021 9:12 pm
Nice to see DL finally add back CID-ATL and FSD-ATL
Wed Jan 27, 2021 9:13 pm
I'd expect that WN will stimulate traffic on FAT-LAS and will add a good amount of connecting traffic. I find it interesting that the first weekend after WN arrives is now being priced well above the promotion fare of $39. There's $59 and $89 showing today. As we've seen many times in the past when LAS flights are added, they fill up quick with the party all weekend crowd.
flyfresno
Wed Jan 27, 2021 9:23 pm
A lot of excitement it would seem over the new flights. The question, like many new and shiny things in Fresno is, will it last? How many new restaurants have opened with long lines for the first couple of months, only to close a year or two later for lack of business? Obviously airlines are not the same as restaurants, but I am definitely adding "cautiously" to "optimistic" when it comes to my expectations about Southwest at FAT. IMO, Southwest is hoping all these new markets work out, but probably expects at least a couple to not.
enilria
Wed Jan 27, 2021 9:37 pm
bb
We are supposed to discuss this somewhere else on a.net, and I'm no sure where that is, but FYI that this just happened. Please discuss wherever that place on a.net is.
https://simpleflying.com/biden-domestic-flight-testing/
Sadly yes
My opinion prior to this week was that F9 was gutting their schedule more than almost anybody, and now it looks like they have relaxed that, but I haven't looked at their overall ASMs.
tomaheath
Wed Jan 27, 2021 10:11 pm
I would of thought AA would be all over that. Who’s bigger in LAX AA or DL?
“Live Free Or Die” General John Stark
SESGDL
Wed Jan 27, 2021 10:14 pm
DL has taken the lead by a wide margin from a departures standpoint post-Covid, however, due to DL's blocked middle seats policy, the gap with actual capacity is likely smaller.
Jeremy
rjbesikof
Wed Jan 27, 2021 10:15 pm
In the this thread and in AA's schedule modification this weekend, I saw that AA added back LAX-AUS for march. What this tells me is that they are not planning to completely throw out LAX as a hub. Why did they pick AUS over other non hub routes (like BNA or MCO)?
N649DL
Wed Jan 27, 2021 10:25 pm
DL stopping EWR-RDU? I still see it's bookable on the website in April.
WN732
Wed Jan 27, 2021 10:28 pm
[code][/code]
O&D is plentiful on AUS-California. There are tons of Californian's here, the tech sector is huge and continuing to grow in AUS - most of those jobs and industries have ties to California.
chicawgo
Wed Jan 27, 2021 10:49 pm
The weirdest thing is that it even applies to mainline in several cases. See LAXORD for example.
AmericanAir88
Thu Jan 28, 2021 12:18 am
My thoughts exactly. I am a fan of CID. It honestly deserves more routes. ATL-CID was always full pre-pandemic.
jfklganyc
Thu Jan 28, 2021 12:54 am
Shields wrote:
Thanks for this!
Because of B6 using JFK, most of the traffic from those islands flows to JFK rather than LGA. Surprising but true
AmericanAir88
Thu Jan 28, 2021 12:56 am
bb
Its a running gag I use as it was my most flown route. The route always did well and I hope for one day it to return.
I honestly just miss the glory days of AA at JFK.
SANFan
Thu Jan 28, 2021 2:02 am
I agree. AA flew SAN-JFK for 60 years, uninterrupted, until now. I'm sure it was one of SAN's first nonstop transcons, if not THE first. I'm very sorry to see it gone, along with AA's hub in NYC...
bb
AmericanAir88
Thu Jan 28, 2021 2:24 am
bb
They could rebuild post-pandemic. I still have hope for AA. I definitely see SAN and LAS coming back.
There was always something special about AA at JFK.
Nicknuzzii
Thu Jan 28, 2021 2:52 am
That’s just for March.
madg
Thu Jan 28, 2021 3:48 am
AA Starts MLB-DFW Saturday Flights in a few weeks & goes up to 4 flights a day from MLB-CLT in March. I think the Additional, CLT flight is just for March.
umichman
Thu Jan 28, 2021 4:11 am
The route has not been flown since early on when Covid hit. This is just as extension of the many existing Covid schedule cuts with the big DL March schedule update this past weekend. More than likely, it will get cut again for April when they load the April schedule next month unless things improve dramatically. This routine has been going on for quite some time now so everyone should be familiar with it. There's probably a decent chance it will return at some point since it has not be cut through the end-of-schedule. RDU-AUS/CLE/CMH/PIT were cut all the way through the end-of-schedule last month (you won't find them no matter how far you look out). So it's safe to say the odds of those routes actually returning any time soon are quite a bit lower -- viewtopic.php?f=3&t=1455253
rjbesikof
Thu Jan 28, 2021 5:13 am
[quote="enilria"]FAQ
Why are SQ going double daily on SIN-SFO? If they are that means UA will not be rushing to re add SIN service.
