CRJockey wrote:FluidFlow wrote:morrisond wrote:
But a tight light 2 class 2x3x2 does not have more volume than a 3x3 when you adjust for similar capacity. The 2x3x2 actually has about 9% less skin and 2% less internal volume - that extra seat being basically in the bulge is a very efficient cost in volume - basically the decrease in length of the cabin more than offsets the increased width of a tight 2x3x2.. The penalty in aisle space is only about 1.4x for two 17" aisles vs one 19" aisle.
Boeing is calling it a 2 Class aircraft (according the AVWeek article). I think Boeing is seeing the writing on the wall and they know by the time this aircraft arrives COMAC could be a major player. They will have a very hard time competing with them for airlines that are all Y or Y-. An all Y NMA has about 1% less Skin and 6.5% more internal volume. They need to differentiate themselves as Calhoun has stated.
A 168x183" cross section gets you containers than can carry about 50% more than an LD3-45 offset by the reduced cabin length - so probably about 20-25% more cargo capacity than the 3x3.
So you compromise the optimal shape (now a sphere is the perfect shape, but for an aircraft it is more or less a circle) to not gain any volume just to have an aisle? Why would you do that if you no not want more seats? So if you aim at the same capacity then you do not need any special shape. The point is, that if you compare a 240 seats circle with a 240 seats ovoid (or whatever weird shape you go for), you only add complexity without any additional capacity. This does not help the case. To make it worth while you need to increase capacity what also needs more MTOW, what makes the design heavier.
And for the containers:
If it does not take LD3-45s it is dead in the water. There are billions invested in automated cargo systems that take LD3-45 (or the wide body version of the LD3 and LD2 containers). So no one will accept different shapes and sizes just because Boeing builds a strange shaped pax aircraft.
That means the shorter cabin would lead to actually less cargo capacity because you can carry less containers.
The only other option would than be to bulk load to use the wider cargo bay but that would make turn around times horrible because bulk loading long haul operations where we have more checked luggage would be a nightmare (operational).
You excellently put in writing why I can't really get a grip of this thread.
Seemingly design decisions are thrown around as if suddenly typical constraints of tube & wing, aluminum and / or CFRP have materially changed.
Suddenly stubby planes are shown to be a good solution, when they traditionally have been awful from a revenue potential vs. cost perspective.
Suddenly comfort is a thing again, when neither the industry, nor the most important average consumer has shown any appetite to pay real cash for any amount of comfort improvement. Nobody in the real world is paying a dime more to fly A320 vs. 737, or A350 vs. 787 to gain an inch of seat width.
Suddenly we are advocating complex forms, disregarding basic requirements of material load distribution patterns or talking them down as being mitigated by "new materials". And those same complex forms are now suddenly heavily 3D-printed on a large industrial scale to not only enable those very forms, but to also bring production cost down so significantly, that it shall be one of the most important competitive advantages of the new plane.
And at the same time, we advocate using new, non-compatible containers or go back to the future via bulk loading.
I have my doubts.
FluidFlow wrote:morrisond wrote:FluidFlow wrote:The thing is, you can not have single aisle operating cost with two aisle. That is physically not possible. Under the assumption you have all the tech available and can choose your product, the moment one gets bigger than the other you need more material, what makes the frame heavier, what leads to bigger wings and engines, what makes the frame heavier, what leads to stronger gears, what makes the frame heavier, etc.
So from the moment you add volume you also add weight. Now of course the additional volume allows for additional seats to spread the cost, but your operational costs will be higher.
So an empty 2-3-2 aircraft will be more expensive to fly than an empty 3-3 aircraft if both are at the same tech level.
If the 2-3-2 should fly further then it will be even more at a disadvantage on direct competing routes.
Now if one thinks you can overcome that with an aircraft designed towards pure pax operation and just design as much cargo hold away as possible, that will make up a bit but it also reduces the sales potential in certain regions.
There is a reason that no aircraft sits between the A321 and 787-8 in size and even there the 787-8 is suboptimal. Regulations on seating configurations just make dead space super expensive to build for no gain thats why 3-4-3>3-3-3>2-4-2>2-3-2. Also everything that can not take the containers avialable now is by design a failure. Cargo will not change, not for decades. We still use the same containers on ships as ever (thats how it seams, it is that long), and they fit on trucks as well. Same goes for Airfreight. The system is so interconnected, you can not move away from it anymore.
WIederling wrote:FluidFlow wrote:And for the containers:
Difficult to say.
If Boeing manages to convert their 737 bulk loading customers to containerized they might be able to introduce a new form factor.
compare the 767: it introduced the LD2/LD8 box afair ( where the A300 fit an existing box:LD3), a new box style.
Airbus NB introduced the LD3-45 type an adaption of the basic LD3. essentially a new type too.
All taken a new type or not may be dependent on the market Oompf Boeing can excert.
CRJockey wrote:brindabella wrote:seahawk wrote:A 6 abreast would never have the same capacity without being too long. It also has an inferior product with 100% more middle seats. Boeing needs to be daring and I think airlines are really wanting the MOM.
Indeed.
I haven't seen it quoted for quite some years however BA themselves used to say that they had learned their lesson from the 757-300 - "it was just too long"
(This is for RPT of course - the 753 seemed to work extremely well for non-sked Ops).
I joined an airline circa 1990 which was a very satisfied 767 operator.
When I queried why they had never used the 757, the answer was:
"Uneconomic. Carries 30-40 fewer passengers than the 767 but takes as long - OR LONGER to turn around".
Which is exactly the space into which an A322 would launch, as far as I can see.
cheers
You make a good point in general, I am just not sure how applicable it is in the MOM context.
Turn around times are less and less important the longer your average stage length gets. Lets be clear here, MOM won't be flying JFK - MIA, LHR - FRA or MAD - WAW anymore than todays large widebodies do. MOM will be flying MAN - PHL, MUC - PHX and the likes. Turn times won't be deal breakers here, as intercont flying has an inherent disadvantage in A/C usage during 24h to hit preferential departure times for consumers. If the 753 had reliable 5000NM over ground range even in unfavorable winds, it would be far more a plane busting hubs than 787 ever was. Not that I believe in busting hubs...
Taxi645 wrote:WIederling wrote:FluidFlow wrote:And for the containers:
Difficult to say.
Actually, thinking a bit more on it, a new container could be a key to success for a new Boeing 3x3 cross section. If Boeing would be able to enforce a new container, they might be able to do quite the coop. Their chances of succeeding at such would be an order of magnitude bigger with a single 3x3 cross section compared to having different fuselage cross sections for NMA and NSA. If they were able to launch a lower and wider container than the LD3-43, that would open up a whole avenue of opportunity for them against the A320 (and less important the MC-21 as well). Possibly enough advantage to be able to survive through the ramp up face against a 60+/month A320 rate.
If they would be able to enforce a lower and wider container, combined with a circular MC-21 sized 3x3 cross section, they would be able to lower the floor and thus hugely increase the available headspace. That could mean that, based on the 4.06 m MC-21 diameter (again identical circumference/wetted area as the A320) the width of the cabin at head height could be about 13 cm / 5'' wider than the A320 with practically the same wetted area. That means that you can do 74 cm / 29” aisle with 737/787 seat width (at seat height it would even be about 15 cm / 6’’ wider). On top of that one would make better use of the cargo part of the cross section with less dead space.
If Boeing would be able to pull that off, they might even put the A320 in trouble. The MC-21 would not be able to do the same because it's floor is already fixed in design to serve LD3-45. They didn't have the cloud to do the same trick Boeing might be able to do. It would have an around 30 cm / 12'' wider and much taller cabin than the 757, providing a completely different medium haul cabin experience.
Taxi645 wrote:Again, some are too focused on capacity vs. market. If a smaller plane with the same range can serve the same market because it can offset it's smaller size with way lower costs (variable as well as acquisition cost) the market will be well served. If you have a 3x3 that can do 5.200 Nm, it does not have to seat widebody capacity, because it will be so cheap it doesn't matter for the vast majority of missions.
morrisond wrote:Taxi645 wrote:WIederling wrote:
Difficult to say.
Neat idea - but I doubt that a wider container would be lower. I'm assuming for an NMA it's about 30" wider (in the largest part) but probably keeping the same height - maybe a few inches higher - but keeping the same height would make it more common with LD3-45.
Funny thing when you do the math on a 2x3x2 with two 17" Aisles (Only 1" less than 777X) vs a 3x3 of the same capacity - due to the 2x3x2 being shorter the aisle area floor penalty is only about 40% - and equivalent to an 27" aisle in a 3x3. That is a no-brainer trade - any airline would take the 2 aisle for a lot better turnover and circulation in the cabin.
morrisond wrote:Taxi645 wrote:Again, some are too focused on capacity vs. market. If a smaller plane with the same range can serve the same market because it can offset it's smaller size with way lower costs (variable as well as acquisition cost) the market will be well served. If you have a 3x3 that can do 5.200 Nm, it does not have to seat widebody capacity, because it will be so cheap it doesn't matter for the vast majority of missions.
You are not going to use a 150 seat aircraft on JFK-MIA in 2040 - where will you get the slots?
"because it will be so cheap it doesn't matter for the vast majority of missions."
JonesNL wrote:Well, it can become really elegant if they introduce an single aisle NMA, which later can be downscaled to an NSA with a different wingbox, wing and tail. This way they have 1 cockpit, tube and production method for the 150-300 seat segment.
morrisond wrote:However a future NSA with the same cross section but smaller wing/wingbox/tail and engines and equivalent to 322+ plus in size will be flying JFK-MIA and turn times could be very important.
FiscAutTecGarte wrote:I agree with Market/Route has to be the focus. I'm not sure I understand the obsession with 5000nm+ distances...
4000nm gets you from Frankfurt Germany to Atlanta Georgia.
4300nm gets you from London to Calcutta, or Miami to Hawaii, or Halifax to Mexico City
5000nm gets you from Manchester to Johannesburgh, Istanbul to Tokyo
5200nm gets you Oslo to Pratoria
These are really long flights... exagerrated a bit.... Why does the NMA/NSA need to approach such long distances? With all that capability it will be rather comprimised for uhhhhh, middle of the market missions, no?
Do we really need to fly this far with just 250 people? Is this really the Market? Even a A321XLR is not going to fly any more than 200pax to 4500nm.. or 240pax to 4000nm... under the best of conditions.
The only thing Calhoun said that we can glean anything meaningful from is they were attacking the A321XLR family....... That gives us mission profile of 200-240pax 3500 to 4500nm.... and I don't know if you go after the niche 4500nm... that's what you have 788,789,7810 for.... (or you cede the handful of missions where carriers think they fly 200pax to 4500nm profitably to the A321XLR)
Universally, once you start going over 4000nm you are on a different continent from where you started (the Halifax to Mexico City was an extreme example where you actually stay on the same continent).
You make NMA/NSA too capable and you leave MAX to server the market and continuing to loose to A321 at 200-240pax < 2500nm....
anyway, just thoughts...
Taxi645 wrote:morrisond wrote:Taxi645 wrote:Again, some are too focused on capacity vs. market. If a smaller plane with the same range can serve the same market because it can offset it's smaller size with way lower costs (variable as well as acquisition cost) the market will be well served. If you have a 3x3 that can do 5.200 Nm, it does not have to seat widebody capacity, because it will be so cheap it doesn't matter for the vast majority of missions.
You are not going to use a 150 seat aircraft on JFK-MIA in 2040 - where will you get the slots?"because it will be so cheap it doesn't matter for the vast majority of missions."
Who is talking about 150 seats? A ~50m 3x3 would be sufficient.
What you're missing is this would provide a 74 cm / 29'' aisle and have 100% cross section commonality between NSA and NMA. No one is going to want 2x 17'' aisle if you can have practically the same boarding speed and much more comfort flexibility with a cabin that can offer one 29'' aisle and has 100% cross section commonality with NSA and the same wetted area as an A320.
CRJockey wrote:morrisond wrote:However a future NSA with the same cross section but smaller wing/wingbox/tail and engines and equivalent to 322+ plus in size will be flying JFK-MIA and turn times could be very important.
I always thought the US is so frequency driven? No, not even in 2040 will MIA - JFK be flown by 15-20 daily frequencies with 250 seats.
MOM is a transatlantic, transcontinental tool. MOM will be abused, like so many other planes, for shorter trunk routes on some rare occasions. It will not be built for those occasions.
morrisond wrote:
This is really making me laugh. So I show that you basically get that extra aisle for more than free (in terms of Volume and skin area) and somehow that is a negative?
As most of the production will be automated - more complex parts won't really add that much more cost.
morrisond wrote:CRJockey wrote:morrisond wrote:However a future NSA with the same cross section but smaller wing/wingbox/tail and engines and equivalent to 322+ plus in size will be flying JFK-MIA and turn times could be very important.
Thats why you build an NSA then with the same cross section.
DenverTed wrote:If weight is a big issue stopping twin aisle, how is weight justified to use a 4K range aircraft on 1K routes? Why not use a lighter aircraft tailored to 2K range? Even though weight is a big deal, it's only one factor, hence why I think Boeing will go twin aisle on a 200 seater, and 2-2-2 is not out of the question.
TheSonntag wrote:I did not read all pages, but to me doing a clean sheet design with a kerosene-burning plane seems a very conservative design. I believe this is rather disappointing. Granted, the hydrogen infrastructure isn't there yet. But the design should then at least be designed to be easily derivable to hydrogern.
Nice, laughing is good for your soul.
Apart from that, getting things "for free" sounds to good to be true. That implies, it isn't actually free on an aircraft level. Or it most probably would have been implemented quite a while ago.
And your prediction, that more complex parts won't add that much more cost (what is not much more?) due to automation (what automation?) is quite vague. No offense, really not. It just stands a bit as a lone statement.
Yeah, the stubby one.
Personally I would take 2 x17" which is only 1" less than 777X - and the aisles would consume less floor space than your 29" aisle and the aircraft would have have less wetted area by about 2% - I think it's a better trade.
No reason you couldn't use the smaller (volume) cross section for NSA as well.
Teardrops are pretty aero vs pencils.
Sorry - I thought you meant smaller in terms of Capacity.
BTW an equivalent 2x3x2 to that 50M 3x3 would be around 44M and have about 9% less skin area and 2-3% Less internal volume - does that make it larger?
Taxi645 wrote:TheSonntag wrote:I did not read all pages, but to me doing a clean sheet design with a kerosene-burning plane seems a very conservative design. I believe this is rather disappointing. Granted, the hydrogen infrastructure isn't there yet. But the design should then at least be designed to be easily derivable to hydrogern.
I think that would largely depend on how synthetic fuel will develop from a cost and sustainability viewpoint. If SAF would become a realistic option, than aircraft wise, not much if anything would have to change.
TheSonntag wrote:Taxi645 wrote:TheSonntag wrote:I did not read all pages, but to me doing a clean sheet design with a kerosene-burning plane seems a very conservative design. I believe this is rather disappointing. Granted, the hydrogen infrastructure isn't there yet. But the design should then at least be designed to be easily derivable to hydrogern.
Yes, however the efficiency of synthetic fuel is considerably worse than that of Hydrogen (which already is bad compared to batteries, which however are unsuitable for large aeroplanes).
However, I agree that synthetic fuel is easier to integrate into the existing system. However, even with most modern designs, even a clean-sheet aeroplane, a gas turbine remains rather inefficient. It doesn't get better with synthetic fuels.
Advantage circular MC21 sized 3x3 with lowered floor vs oval
- Flexibility in seat width vs aisle width. (both short haul boarding speed and medium haul seat width comfort possible).
- Very comfortable economy possible vs. only 737 width possible.
- No ultra narrow 17’’ aisles
- No floor in compression
- Much more cargo space
- Shared cross section with NSA (you can forget about a 2x3x2 737-7 sized aircraft)
- Both would need a new container.
Basically it is the same basic concept as the oval, just without going as far as putting the floor in compression while maintaining shared NMA/NSA cross section. Further more keep in mind that the oval shape has even more of a cabin width at head height disadvantage than circular already has in relation to the taller than wide A320. You're not gaining back all the width you gain in actual usable cabin width, because the width head height will be the limiting factor. That's where a new container with less would help out, because you put the passenger in a more advantageous position in relation to the curvature of the side wall.
I post this, but since you posted about 300 posts about how you consider the oval to be superior I don't expect you to objectively consider what I said and I don't have an interest in a repetitive discussion.
With appropriately sized wings and tail so it doesn't seem so stubby - a teardrop is more aero than a pencil.
BTW an equivalent 2x3x2 to that 50M 3x3 would be around 44M and have about 9% less skin area and 2-3% Less internal volume - does that make it larger?morrisond wrote:Taxi645 wrote:
Nope, as noted in the configuration thread the 232 that you envisage compared directly to an A321 plus one row or approximately 246 pax at max capacity.
viewtopic.php?f=5&t=1457749
The required 285max capacity would put the length of the 2-3-2 at around 47.5m. The increased weight per pax in the fuselage is 7+%. A rounded view as to how this affects overall performance can be found here from analysis last year.
viewtopic.php?t=1440759
All you have to do to make the concept work is hold two distinct concepts in your head at a time and only pick the variables that are best to make the numbers work.
Fred
Sent from my iPad using Tapatalk
morrisond wrote:I did use the same capacity, did you also use the same seat width?flipdewaf wrote:morrisond wrote:
Fred
I was comparing 3x3 and 2x3x2 at same capacity.
morrisond wrote:Or to make the concept work - you have to make sure some basic assumptions like appropriate end lengths are used.
Cdydatzigs wrote:So it would seem all of this boils down to two things: (1) Boeing needs a clean-sheet 737 replacement (2) The market wants/needs a 757/767 replacement
As much as Boeing would love for it to be the case, methinks you cannot achieve both with a single aircraft type. A super long single-aisle isn't going to cut it, nor will a stubby double-aisle. This will have to be two different airplanes.
But it's not an Oval. If Boeing was going to do a 3x3 they would be crazy to do anything larger than A320.
I didn't say it wouldn't work, I said it is a drawback.So an 18" aisle works for 777x - but one inch less for an aircraft that will be in the air less than half the stage length of 777x doesn't? Ok then make them 18" and they use the same floor space as a 29" aisle.
The reason the 737-7 and A319 are dead is not because of their geometry, but because the new found SFC improvement have made them uncompetitive based on their legacy MTOW designs. That would be different with a clean sheet which would reinstate a meaningful range advantage for the smallest model. See the table listed above.The 737-7 size is dead anyways by - 2035 738 might be as well.
morrisond wrote:
More complex parts won't add much more cost due to automation as Human labour costs will be much lower. Just look at what is happening with Fan Blades and turbine parts
planecane wrote:Does 2-2-2 ever make any sense if you are going twin aisle? 2-3-2 at least gets you one more seat per row so the same capacity can be 16% shorter. I would assume the extra weight and wetted area from the one additional seat would easily be offset by the reduced length.
I guess the only way I could see it making any sense to do 2-2-2 would be if the design was 3-3 with 18" seats and 28" aisle and there was an optional 2-2-2 configuration with 17" seats and two 17" aisles. Basically trade seat width comfort for no middle seat and somewhat faster boarding and deplaning. Also, I'd think a 2-2-2 would cause the overhead bins to be an issue since they'd have to not protrude past 34" when open.
morrisond wrote:The 737-7 size is dead anyways by - 2035
The point of this cross section - as others have pointed out above is that it could be the cross section for NSA as well and range up to 300 seats. It also differentiates Boeing as the premium product against COMAC which will be a much larger threat by EIS and Airbus if they do not go clean sheet (and they could easily do something like this 2x3x2 and would have more room to do so given they have the A220 - then they have 5W, 7W and 9W assuming A330 death - which is perfect).
For the container size the market will adapt - as others have pointed out many of there existing 737 Customers do not have the cargo handling equipment yet anyways - if the Cross section is also used for NSA then you are talking about an installed base of easily over 10,000 frames in the 2030's and 2040's. Some more Cargo Handling equipment won't be an issue. No reason you won't be able to put an LD3-45 in it either. - Less Capacity - but packed full for LR missions you might be Cargo limited anyways. Short Haul you don't need that much space in the belly.
In any case a new Container is not a show stopper.
FiscAutTecGarte wrote:Why does the NMA/NSA need to approach such long distances? With all that capability it will be rather comprimised for uhhhhh, middle of the market missions, no?
TheSonntag wrote:Yes, however the efficiency of synthetic fuel is considerably worse than that of Hydrogen (which already is bad compared to batteries, which however are unsuitable for large aeroplanes).
flipdewaf wrote:morrisond wrote:I did use the same capacity, did you also use the same seat width?flipdewaf wrote:
Fred
I was comparing 3x3 and 2x3x2 at same capacity.morrisond wrote:Or to make the concept work - you have to make sure some basic assumptions like appropriate end lengths are used.
Yes, I would absolutely agree. I would use a standard constant to avoid confusion, much barter than muddying waters by special pleading.
Fred
I can give you two data points directly to your example, that point to the contrary.
In 2011, a fanblade for the CF6-80C2 made from good old titanium did cost about 30.000 USD new.
A complete overhaul of the highest thrust variant -D1F was about three million USD, plus or minus half a million depending on scope of work.
In 2012, a fanblade for the GE90-110, manufactured in layered CFRP with metal leading edge, arguably the much more complex part, cost more than 100k USD per piece.
Overhaul workscopes for the large diameter GE90s can easily be 10 Mio USD. Arguably, the GE90 is a much more complex engine in order to extract the higher efficiency.
No, neither fan blades and especially not turbine blades or vanes are getting cheaper by any stretch of the imagination.
Free volume does nothing for an aircraft. A ballon and a bowling ball also have the same volume but one flies when you fill it with helium.
No and Boeing can not force a wider container just like that, especially because every aircraft designed after 1980 uses LD3(-45s). They are all transferable from one to another and even into feeder aircraft. We will be stuck with them, they even load LD3s into the 747s even though they woule have LD1s .The LD2 is somewhat an oddball here.
A new container would drive costs into oblivion because if you want to buy the new aircraft you would also have to buy new cargo equipment. Thats not what a lean aircraft does.
Also using a stunby aircraft for the 240pax market means everything below is conceeded to the competitors.
And also the shorter the aircraft the bigger the tail what means that all the bigger versions need a new tail so you have two tails or a bad compromise at one end of the spectrum. This all adds cost.
So we really should just listen to Calhoun: Boeing targets the A321 family. So 180-200 two class with up to 4500nm range. If Boeing can do that with 85t MTOW it will be an aircraft selling 10‘000 copies.
If Boeing builds a 240 two class 150t aircraft they might sell 1500 tops and take 500 away from the 787.
Now where would the big shareholders (that control the board) put their money?
