enilria
OAG Changes 2/2/2021:AA DABPHL;AS Cuts EWRSJC,LAXORD,PHLSFO,PAE-BOI/PDX,More;F9 Axes 31 Routes;SY Expands;UA SJT;WN
Tue Feb 02, 2021 3:13 pm
FAQ
SOURCE: OAG
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
NOTE: Back on time this week, hopefully that's a permanent change.
2E HOM-KEB MAR 0>4[0] APR 0>4[0.5] MAY 0>4[0.5] JUN 0>4[0.5] JUL 0>4[0.5] AUG 0>4[0.5] SEP 0>4[0.5]
2E HOM-PGM MAR 0>7[0] APR 0>7[0] MAY 0>7[0] JUN 0>7[0] JUL 0>7[0] AUG 0>7[0] SEP 0>7[0]
2E HOM-SOV MAR 0>4[0] APR 0>4[0.5] MAY 0>4[0.5] JUN 0>4[0.5] JUL 0>4[0.5] AUG 0>4[0.5] SEP 0>4[0.5]
2E KEB-PGM MAR 0>4[0] APR 0>4[0.5] MAY 0>4[0.5] JUN 0>4[0.5] JUL 0>4[0.5] AUG 0>4[0.5] SEP 0>4[0.5]
2E PGM-SOV MAR 0>4[0] APR 0>4[0.5] MAY 0>4[0.5] JUN 0>4[0.5] JUL 0>4[0.5] AUG 0>4[0.5] SEP 0>4[0.5]
2O ADQ-AKK MAR 0>0.4[0] APR 0>0.4[0.7] MAY 0>0.4[0.7]
2O ADQ-KLN MAR 0>0.9[0] APR 0>0.9[1.9] MAY 0>0.8[1.8]
2O ADQ-KYK MAR 0>0.5[0] APR 0>0.4[0] MAY 0>0.4[0]
2O ADQ-OLH MAR 0>1.9[0] MAY 0>1.7[1.8]
3M CHS-MCO MAR 0.3>0.5[0.3]
3M CHS-TPA MAR 0.2>0.5[0.2]
3M ELH-FLL MAR 0.2>0.9[0.2]
3M EYW-FLL MAR 0.5>1.1[0.5]
3M EYW-MCO MAR 1.0>1.4[1.0]
3M EYW-TPA MAR 0.8>1.8[0.8]
3M FLL-GGT MAR 0.3>0.5[0.3]
3M FLL-JAX MAR 0.1>0.4[0.2]
3M FLL-MCO MAR 1.1>1.3[0.9]
3M FLL-MHH MAR 0>0.5[0] APR 0.3>0.6[0.9] MAY 0.3>0.6[0.4] JUN 0.3>0.5[0.5] JUL 0.3>0.6[0.4] AUG 0.3>0.5[0.8] SEP 0.3>0.6[0.1]
**3M FLL-SAV APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0]
3M FLL-TLH MAR 0.3>0.5[0.3]
3M FLL-TPA MAR 0.7>1.0[0.7]
3M JAX-TPA MAR 0>0.4[0.2]
3M MCO-PNS MAR 0.8>1.0[0.8]
3M NAS-TPA MAR 0>0.2[0]
3M PNS-TPA MAR 0.3>0.8[0.3]
**3M SAV-TPA APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0]
3M TLH-TPA MAR 0>0.4[0]
4B ABQ-CNM JUN 0>0.2[2]
4B ATL-MSL MAR 0.5>2[0.5] APR 0.5>2[4] MAY 0.5>2[4]
*4B BNA-MSL MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0]
4B BWI-MSS JUN 0.5>1.0[0]
*4B CDR-RAP MAR 0>0.7[0] APR 0>0.7[0] MAY 0>0.7[0] JUN 0>0.7[0]
4B CEZ-DEN MAR 1.9>3[1.9] APR 1.9>3[3] MAY 1.8>3[3]
4B CEZ-PHX MAR 0>0.9[0]
4B DEN-MCK MAR 1.0>1.7[1.0] APR 1.0>1.7[2] MAY 1.0>1.7[1.9] JUN 1.0>1.7[2]
4B IWD-ORD MAR 1.5>2[1.5] JUN 1.5>2[0]
4B PHX-SOW APR 1.4>2[3] MAY 1.4>2[3] JUN 1.8>3[3] JUL 1.8>3[3]
*4P ACY-AVP MAR 0>0.7[0] APR 0>0.7[0] MAY 0>0.7[0] JUN 0>0.7[0] JUL 0>0.7[0] AUG 0>0.7[0] SEP 0>0.7[0]
*4P AVP-BWI MAR 0>0.7[0] APR 0>0.7[0] MAY 0>0.7[0] JUN 0>0.7[0] JUL 0>0.7[0] AUG 0>0.7[0] SEP 0>0.7[0]
4W CIK-FYU MAR 0>0.4[0] APR 0>0.5[0.4] MAY 0>0.4[0.5] JUL 0>0.5[0.4] SEP 0>0.5[0.4]
4W FAI-FYU MAR 0>0.8[0] APR 0>0.9[0.8] MAY 0>0.8[0.9] JUN 0>0.9[1.4] JUL 0>0.9[1.7] AUG 0>0.8[1.8] SEP 0>0.9[1.4]
4W FAI-TAL MAR 0>0.4[0] APR 0>0.5[0.4] MAY 0>0.4[0.5] JUL 0>0.5[0.4] SEP 0>0.5[0.4]
7H ANC-ENA MAR 3>4[3]
7H ANC-SNP JUN 0.2>0.4[0.4]
7H ANC-UNK MAR 0.2>0.5[0.2] MAY 0.2>0.4[1.0]
8V AET-BTT MAR 0>0.5[0] JUL 0>0.5[0.8] AUG 0>0.5[0.8] SEP 0>0.5[0.9]
8V AKP-FAI MAY 1.4>1.7[1.7] JUL 1.4>1.7[1.7] AUG 1.4>1.7[1.7]
8V ARC-VEE MAR 0.7>0.9[0.7] APR 0.7>0.9[1.0] MAY 0.7>0.9[0.9] JUN 0.7>0.9[1.0] JUL 0.7>0.9[0.9] AUG 0.7>0.9[0.9] SEP 0.7>0.9[0.9]
8V BTT-FAI MAR 0>0.5[0] JUL 0>0.5[0.8] AUG 0>0.5[0.8] SEP 0>0.5[0.9]
8V CIK-FYU MAR 0.7>1.0[0.7] APR 0.7>1.0[1.0] MAY 0.7>1.0[1.0] JUN 0.7>1.0[1.0] JUL 0.7>1.0[1.0] AUG 0.7>1.0[1.0] SEP 0.7>1.0[1.0]
8V FAI-FYU MAR 2>3[2] APR 2>3[3] MAY 2>3[3] JUN 2>3[3] JUL 2>3[3] AUG 2>3[3] SEP 2>3[3]
9K ACK-BOS SEP 8>10[9]
9K ACK-EWB MAR 0>0.6[0] APR 0>0.6[0.9] MAY 0>0.5[0.8] JUN 1.4>3[1.0] JUL 1.8>3[1.1] AUG 1.8>3[1.2] SEP 1.8>3[1.3]
9K ACK-HPN JUN 1.0>1.6[0.3]
9K ACK-HYA APR 4>5[7] MAY 3>5[7] SEP 9>10[13]
9K ACK-JFK SEP 0.8>1.0[1.0]
9K AUG-BOS SEP 3>4[4]
9K BHB-BOS MAY 2>3[3] JUN 0>6[3] SEP 6>8[1.0]
9K BIL-GDV SEP 1.5>2[2]
9K BIL-GGW SEP 1.5>2[2]
9K BIL-HVR SEP 1.5>2[2]
9K BIL-OLF SEP 1.5>2[2]
9K BIL-SDY SEP 4>5[5]
9K BNA-MWA MAY 1.4>1.7[1.7] JUL 1.4>1.7[1.7] AUG 1.4>1.7[1.7]
9K BNA-OWB MAR 1.5>2[1.5] APR 1.5>2[2] MAY 1.4>2[1.9] JUN 1.5>2[2] JUL 1.4>2[1.9] AUG 1.4>2[2] SEP 1.5>2[0]
9K BOS-LEB MAR 3>4[3] APR 1.3>4[4] MAY 1.3>4[4] JUN 2>4[5] JUL 2>4[4] AUG 3>4[4] SEP 0.8>4[4]
9K BOS-MVY APR 1.6>2[4] MAY 1.5>2[4] SEP 9>10[7]
9K BOS-PVC APR 0.8>2[3] MAY 0.8>2[0] JUN 3>5[4] JUL 4>5[5] AUG 4>5[5] SEP 3>5[3]
9K BOS-PWM SEP 3>4[0]
9K BOS-RKD SEP 3>4[5]
9K BOS-RUT SEP 2>3[0]
9K HPN-LEB MAR 0.9>2[0.9] APR 0.5>2[2] MAY 0.4>2[1.9] JUN 0.8>2[1.2] JUL 0.9>2[1.0] AUG 0.9>2[2] SEP 0.9>2[2]
9K HPN-MVY JUN 1.0>1.2[0.3]
9K HPN-PVC JUN 0>0.2[0] SEP 0>0.2[0.3]
9K IRK-STL MAR 2>3[2] APR 2>3[3] MAY 2>3[3] JUN 2>3[3] JUL 2>3[3] AUG 2>3[3] SEP 2>3[3]
9K JFK-MVY SEP 0.8>1.0[1.0]
9K MBL-ORD MAY 1.7>3[0]
9K MWA-STL APR 3>4[4] JUN 3>4[4] AUG 3>4[3] SEP 3>4[0]
9K ORD-UIN MAR 1.2>3[1.2] APR 1.2>3[3] MAY 1.2>3[3] JUN 1.2>3[3] JUL 1.2>3[3] AUG 1.2>3[3] SEP 1.2>3[0]
9K OWB-STL MAR 0.7>1.0[0.7] APR 0.7>1.0[1.0] MAY 0.7>1.0[1.0] JUN 0.7>1.0[1.0] JUL 0.7>1.0[1.0] AUG 0.7>1.0[1.0] SEP 0.7>1.0[0]
9K STL-UIN MAR 1.3>3[1.3] APR 1.3>3[3] MAY 1.3>3[3] JUN 1.3>3[3] JUL 1.3>3[3] AUG 1.3>3[3] SEP 1.3>3[0]
9X BWI-DUJ MAR 1.5>2[1.5] MAY 0>2[1.9]
9X BWI-MGW MAR 1.5>2[1.5] MAY 0>2[1.9]
9X DFW-ELD MAR 0.7>1.7[0.7] APR 0>1.7[1.8] MAY 0>1.7[1.6]
9X DFW-HOT MAR 1.8>3[1.8] MAY 0>3[2]
9X DFW-HRO APR 0>1.7[1.6] MAY 0>1.7[1.6]
9X DSI-MEM MAR 0>0.3[0]
9X DSI-TPA MAR 0>0.3[0]
9X HNL-MKK MAR 11>12[11] APR 10>11[9] MAY 10>11[8] JUN 10>11[12] JUL 10>11[11] AUG 10>11[12] SEP 10>11[12]
9X HRO-MEM APR 0>0.9[1.0] MAY 0>0.8[1.0]
9X PBI-TPA MAR 0>2[0]
Increases to MAR schedule
AA ABE-ORD MAR 0.6>0.9[0.6]
AA ABI-DFW MAR 4>5[3]
AA ABQ-ORD MAR 0.7>0.9[1.3]
*AA ACK-PHL JUN 0>0.9[0] JUL 0.2>1.0[0] AUG 0.1>1.0[0.2] SEP 0>0.3[0.1]
AA ACT-DFW MAR 2>4[4]
AA AEX-DFW MAR 1.9>4[3]
AA ALB-PHL MAR 0.7>2[3] MAY 5>6[6]
AA AMA-DFW MAR 3>5[6]
AA AMS-PHL APR 1.0>0[1.0]
AA ART-PHL MAR 0>1.7[0.4] MAY 1.6>2[1.9]
AA ASE-ORD MAR 1.5>2[1.7]
AA ATL-CLT MAR 6>7[8]
AA ATL-DFW MAR 6>7[8]
AA ATL-ORD MAR 1.0>3[3]
AA ATL-PHL MAR 0.9>2[5]
AA ATW-ORD MAR 1.6>1.9[2]
AA AUS-BOS MAY 1.6>2[0]
AA AUS-DFW MAR 7>8[10]
AA AUS-ORD MAR 0.6>1.0[2]
AA AUS-PHL MAR 0.1>0.8[1.7]
AA AVP-ORD MAR 0.8>1.0[1.3]
AA BDL-PHL MAR 0.7>2[3]
AA BGR-PHL MAR 0.8>2[2.0]
AA BHM-DFW MAR 4>5[5]
AA BHM-MIA MAR 0.5>1.0[1.1]
AA BHM-ORD MAR 0>0.8[1.3]
AA BNA-MIA MAR 2>3[3]
AA BNA-ORD MAR 1.6>4[4] MAY 8>9[8]
AA BNA-PHL MAR 1.1>2[4]
AA BOG-DFW MAR 1.0>0.1[1.0]
AA BOG-MIA MAR 3>1.5[3]
AA BOS-CLT MAR 6>7[7]
AA BOS-DCA MAR 4>6[10] APR 12>14[11]
AA BOS-DFW MAR 3>4[6]
AA BOS-JFK APR 2>3[3]
AA BOS-LGA MAR 0.5>1.7[9]
AA BOS-MIA MAR 3>5[5]
AA BOS-ORD MAR 0.3>3[5]
AA BOS-PHL MAR 0.9>4[11]
AA BRO-DFW MAR 2>4[2]
AA BTR-DFW MAR 4>5[4]
AA BTV-PHL MAR 1.0>2[3]
AA BUF-ORD MAR 0.5>1.0[2] MAY 3>4[4]
AA BUF-PHL MAR 1.1>2[4]
AA BWI-CLT MAR 4>5[7]
AA BWI-JFK APR 1.5>1.9[1.0] MAY 1.1>2[1.2] AUG 1.6>2[3]
AA BWI-MIA MAR 0.7>1.0[1.4]
AA BWI-ORD MAR 1.8>3[3]
AA CAE-DFW MAR 1.6>2[3]
AA CAE-PHL MAR 0.4>0.9[0.6]
AA CAK-PHL MAR 0.5>1.0[0.4]
AA CHS-MIA MAR 1.4>1.9[1.6]
AA CHS-PHL MAR 0.8>2[3]
AA CLE-ORD MAR 1.3>3[3] MAY 6>7[6]
AA CLE-PHL MAR 1.1>1.6[5]
AA CLL-DFW MAR 0.6>3[0.9]
AA CLT-EVV MAR 1.6>2[1.8]
AA CLT-FLO MAR 1.1>1.5[3]
AA CLT-IAD MAR 3>4[6]
AA CLT-LYH MAR 5>6[5]
AA CLT-ORD MAR 6>8[9]
AA CLT-SDQ JUN 0.4>1.0[0] JUL 0.2>1.0[0] AUG 0.1>0.5[0]
AA CLT-SXM AUG 1.1>1.4[0.6] SEP 0.1>0.7[0.1]
AA CMH-JFK MAY 0.8>1.0[0.2]
AA CMH-MIA MAR 1.5>2[1.7]
AA CMH-ORD MAR 1.5>3[5] MAY 8>9[7]
AA CMH-PHL MAR 0.9>1.9[5]
AA CRP-DFW MAR 5>7[5]
AA CUN-MIA JUN 6>5[1.7] JUL 6>5[3] AUG 6>5[3] SEP 5>4[3]
AA CUN-PHL APR 1.9>3[2] MAY 2>3[1.9]
AA CUN-PHX APR 1.0>2.0[1.0] MAY 1.0>2[1.0]
AA CUR-MIA MAR 0.6>0.9[0.9]
AA CVG-ORD MAR 0.9>1.9[4] APR 7>8[7] MAY 7>8[6] SEP 7>8[7]
AA CVG-PHL MAR 1.6>2[4]
AA CWA-ORD MAR 0.6>1.0[2]
AA CZM-MIA JUN 0.1>0.9[0] JUL 0.2>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
**AA DAB-PHL JUN 0>0.9[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.3[0]
AA DAY-ORD MAR 0.1>0.9[1.9]
AA DAY-PHL MAR 0.6>1.5[1.2]
AA DCA-DSM MAR 0>0.5[1.4]
AA DCA-JAX MAR 0.3>0.7[3]
AA DCA-MEM MAR 0.2>0.6[2]
AA DCA-NAS JUN 0.2>0.9[0] JUL 0.3>1.0[0] AUG 0.3>0.6[0]
AA DCA-ORD MAR 2>3[6]
AA DCA-ORF MAR 0.6>1.0[2]
AA DCA-PHL MAR 1.4>1.9[1.7]
AA DCA-PNS MAR 1.2>1.6[1.7]
AA DCA-SAV MAR 0.3>0.6[1.4]
AA DCA-SRQ MAR 0.8>1.0[1.0]
AA DCA-TPA MAR 1.3>1.5[4]
AA DEN-LAX MAR 1.4>3[1.6]
AA DEN-ORD MAR 1.9>3[3]
AA DEN-PHL MAR 0.5>0.7[3]
AA DFW-ECP MAR 2>3[3]
AA DFW-ELP MAR 7>8[7]
AA DFW-EYW MAR 1.6>2[2.0]
AA DFW-FAY MAR 0.6>0.9[0.9]
AA DFW-GGG MAR 1.1>3[1.3]
AA DFW-GPT MAR 2.0>3[0.7]
AA DFW-GRK MAR 5>7[5]
AA DFW-GSO MAR 2>3[3]
AA DFW-GUC MAR 0.9>1.1[1.1]
*AA DFW-HKG MAR 0.2>0[0.9] APR 1.0>0[0]
AA DFW-HOU MAR 3>5[7]
AA DFW-IAD MAR 1.5>1.9[2]
AA DFW-IAH MAR 6>9[8]
AA DFW-ICN APR 1.0>1.9[1.0]
AA DFW-IND MAR 5>6[5]
AA DFW-LAX MAR 9>11[13]
AA DFW-LBB MAR 5>7[6]
AA DFW-LFT MAR 2>3[4]
AA DFW-LIT MAR 4>7[6]
AA DFW-LRD MAR 2>3[2]
AA DFW-MAF MAR 4>6[5]
AA DFW-MCI MAR 6>7[7]
AA DFW-MEM MAR 6>7[7]
AA DFW-MSP MAR 4>5[6]
AA DFW-MZT MAR 0.8>1.0[1.0] APR 0.2>0.4[1.0]
AA DFW-OKC MAR 6>7[8]
AA DFW-ORD MAR 6>7[12]
AA DFW-PKX APR 1.0>0[0]
*AA DFW-PVG MAR 0.2>0[0.9] APR 1.0>0[0]
AA DFW-SAN MAR 6>7[9]
AA DFW-SEA MAR 5>6[9]
AA DFW-SFO MAR 4>6[7] APR 9>11[9]
AA DFW-SGF MAR 6>7[6]
AA DFW-SJT MAR 3>5[3]
AA DFW-SPS MAR 2>3[2]
AA DFW-TYR MAR 3>5[2]
AA DFW-XNA MAR 4>6[7]
AA DSM-MIA MAR 0>0.3[0]
AA DSM-ORD MAR 1.7>3[4]
AA DTW-ORD MAR 1.1>3[3] MAY 5>6[5]
AA DTW-PHL MAR 1.6>2[5]
AA EGE-JFK MAR 0.7>1.0[0.4]
AA EGE-LAX MAR 0.7>1.0[0.9]
AA EGE-PHX MAR 0.8>1.0[1.0]
AA ELH-MIA MAR 0.9>1.9[0.9] APR 1.0>1.3[2] JUN 0.9>1.1[0.7] AUG 0.4>0.6[0.6]
AA ELP-ORD MAR 0.2>1.0[0.9]
AA ELP-PHX MAR 1.4>3[2]
AA EYW-MIA MAR 1.8>3[2]
**AA EYW-PHL MAR 0.9>1.1[1.0] APR 0.2>1.0[1.0] MAY 0.2>1.0[1.0] JUN 0.1>1.0[0.7] JUL 0.2>1.0[0.7] AUG 0.1>1.0[0.7] SEP 0>1.0[0.3]
AA FAR-ORD MAR 1.5>1.9[1.8]
AA FLL-ORD MAR 0.9>1.9[1.8]
AA FNT-ORD MAR 1.2>1.7[1.8]
AA FPO-MIA MAR 0.5>1.0[0.5]
AA FSD-ORD MAR 1.5>1.9[1.5]
AA FWA-PHL MAR 0.3>1.0[0.5]
AA GGT-MIA MAR 0>1.0[1.5]
AA GRB-ORD MAR 2>3[3]
AA GRR-MIA MAR 0.6>1.0[0.8]
AA GRR-PHL MAR 0.6>1.3[0.6]
AA GSO-MIA MAR 0.5>1.0[1.2]
AA GSO-ORD MAR 0.7>1.0[1.5]
AA GSP-ORD MAR 0.6>0.9[1.8]
AA GSP-PHL MAR 0.5>0.8[1.4]
AA HDN-ORD MAR 0.8>1.0[0.8]
**AA HHH-PHL JUN 0.1>0.9[0] JUL 0.2>1.0[0] AUG 0.1>1.0[0.2] SEP 0>0.3[0.1]
**AA HVN-PHL MAR 0>0.7[0]
AA IAH-LAX APR 3>4[3]
AA IAH-MIA MAR 2>4[4]
AA IAH-ORD MAR 1.0>1.9[1.6] MAY 3>4[2]
AA IAH-PHL MAR 0.1>1.5[2]
AA IAH-PHX MAR 2>3[3]
AA ICN-SEA APR 0>0.3[0]
AA ICT-ORD MAR 0.5>1.0[1.7]
AA ILM-PHL MAR 0.4>1.2[0.7]
AA IND-ORD MAR 1.3>3[5]
AA IND-PHL MAR 1.0>2[5]
AA IPT-PHL MAR 0>0.7[0]
AA ISP-PHL MAR 1.0>1.5[0.9]
AA JAC-ORD MAR 0.8>1.0[0.9]
AA JAX-MIA MAR 2>3[4]
AA JAX-ORD MAR 0.5>0.9[2]
AA JAX-PHL MAR 0.8>1.5[2]
AA JFK-LAX APR 9>10[11]
AA JFK-MIA MAR 3>4[3] APR 7>8[6] MAY 7>8[5]
AA JFK-PHX MAR 0.6>1.0[3]
AA JFK-PIT APR 0.8>1.0[1.0] MAY 0.5>1.0[1.2] AUG 0.8>1.0[2]
AA JFK-RDU JUN 1.3>2[0] SEP 1.1>2[3]
AA JFK-SFO MAR 0.7>1.9[2]
AA LAP-PHX MAR 0.1>0.4[0.4]
AA LAS-LAX MAR 2>3[6]
AA LAX-ORD MAR 2>3[7]
AA LAX-SFO MAR 1.1>1.7[6] APR 6>8[8]
AA LAX-SLC MAR 1.6>3[2]
AA LEX-ORD MAR 0.8>1.1[1.9]
AA LEX-PHL MAR 0.3>0.6[0.6]
AA LGA-ORD MAR 2>3[9]
AA LGB-PHX APR 2>3[3] MAY 2>3[3]
AA LIT-ORD MAR 0.2>0.8[1.4]
AA LSE-ORD MAR 1.4>1.9[1.9]
AA MCI-MIA MAR 1.5>1.9[1.3]
AA MCI-ORD MAR 0.9>3[4] MAY 5>7[4] JUN 6>7[1.3]
AA MCI-PHL MAR 0.2>1.7[2]
AA MCO-ORD MAR 2>3[3]
AA MDT-ORD MAR 0.6>1.0[2]
AA MDT-PHL MAR 1.3>2.0[2]
AA MEM-ORD MAR 1.0>1.8[1.5] MAY 4>5[3]
AA MHH-MIA MAR 0.5>0.9[0.5]
AA MHT-PHL MAR 1.3>2[3]
AA MIA-NAS MAR 3>4[5]
AA MIA-OMA MAR 0.6>1.0[0.3]
AA MIA-ORD MAR 4>5[7]
AA MIA-ORF MAR 1.4>1.9[2]
AA MIA-PIT MAR 0.9>1.1[2]
AA MIA-PNS MAR 0.4>1.0[1.5]
AA MIA-RDU MAR 2>3[4]
AA MIA-RIC MAR 0.7>1.0[1.5]
AA MIA-RTB MAR 0.9>1.1[1.0]
AA MIA-SAV MAR 0.8>1.0[1.2]
AA MIA-SDQ APR 6>7[4] MAY 6>7[0] JUN 6>7[1.5] JUL 6>7[1.7] AUG 5>6[3] SEP 4>5[3]
AA MIA-SEA MAR 0.5>0.7[0.7]
AA MIA-SFO MAR 2>3[3]
AA MIA-SKB MAR 0.4>0.5[0.9]
AA MIA-SVD MAR 0.1>0.3[0]
AA MIA-TLH MAR 1.1>1.9[2]
AA MKE-ORD MAR 1.5>1.9[3]
AA MKE-PHL MAR 0.8>1.4[1.7]
AA MLI-ORD MAR 0.6>0.9[1.1]
AA MSP-ORD MAR 1.3>3[4]
AA MSP-PHL MAR 0.3>0.5[3]
AA MSY-ORD MAR 0.3>1.0[1.1]
AA MSY-PHL MAR 0.9>1.7[3]
AA MYR-PHL MAR 0.6>1.2[1.2]
AA NAS-PHL MAR 0.5>0.7[1.1]
AA OKC-ORD MAR 0.6>1.0[1.8]
AA OMA-ORD MAR 1.3>1.9[3]
AA ORD-ORF MAR 1.3>1.7[1.5]
AA ORD-PBI MAR 1.9>2[1.4]
AA ORD-PDX MAR 0.5>0.9[1.5]
AA ORD-PHL MAR 3>4[10]
AA ORD-PHX MAR 5>6[8]
AA ORD-PIA MAR 0.6>0.9[2]
AA ORD-PIT MAR 1.1>1.9[3]
AA ORD-PNS MAR 0.5>0.8[0.4] APR 0.3>1.0[0.1] MAY 0.3>1.0[0.1]
AA ORD-PSP APR 0>1.0[2] MAY 0>1.0[1.8]
AA ORD-PVD MAR 0.7>1.0[1.7] JUN 2>3[0.7]
**AA ORD-PVR JUN 0>0.9[0.1] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
AA ORD-RDU MAR 1.2>1.7[3]
AA ORD-RIC MAR 0.7>0.9[3]
AA ORD-ROC MAR 0.4>0.9[3] JUN 3>4[0.7]
AA ORD-SAN MAR 1.4>1.9[3]
AA ORD-SDF MAR 0.9>1.8[3]
AA ORD-SGF MAR 0.6>1.8[3]
AA ORD-SJD JUN 0.3>0.9[0] JUL 0.3>1.0[0.1] AUG 0.3>1.0[0.3]
AA ORD-SLC MAR 1.3>1.9[1.4] MAY 2>3[3]
*AA ORD-SRQ MAR 1.2>1.9[1.0] APR 0.1>1.0[1.0] MAY 0>1.0[0.3]
AA ORD-STL MAR 1.3>3[3] MAY 6>7[5]
AA ORD-SUX MAR 0.5>0.9[1.9]
AA ORD-SYR MAR 1.2>1.9[3]
AA ORD-TUL MAR 0.4>1.7[0.9]
AA ORD-TUS MAR 0.7>0.9[1.5]
AA ORD-TYS MAR 0.3>0.9[1.9]
AA ORD-VPS APR 0.3>1.0[0.1] MAY 0.3>1.0[0.2]
AA ORD-XNA MAR 0.3>0.8[3]
AA ORD-YYZ MAY 4>5[3]
AA ORF-PHL MAR 1.3>2[4]
AA PBI-PHL MAR 1.3>3[4]
AA PHL-PIT MAR 1.2>2[5]
AA PHL-PLS MAR 0>0.4[0.2]
AA PHL-PNS MAR 0.4>0.7[0.2]
AA PHL-PVD MAR 0.9>2[3]
AA PHL-PWM MAR 1.0>2[4]
AA PHL-RDU MAR 0.6>2[6]
AA PHL-RIC MAR 1.3>2[5]
AA PHL-ROA MAR 0.5>1.4[0.5]
AA PHL-ROC MAR 1.0>2[3]
AA PHL-RSW MAR 1.5>3[4]
AA PHL-SAV MAR 1.2>1.5[0.5]
AA PHL-SBY MAR 0.7>1.4[1.4]
AA PHL-SCE MAR 0.7>1.5[2]
AA PHL-SDF MAR 0.3>0.6[2]
AA PHL-SDQ APR 0.1>0.5[0.1] MAY 0.2>0.6[0] JUN 0.1>0.6[0] JUL 0.2>0.6[0] AUG 0.1>0.3[0]
AA PHL-SJU SEP 1.2>2.0[2.0]
*AA PHL-SLC MAR 0.5>0.7[0.6] JUN 0>0.9[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
**AA PHL-STI APR 0>0.4[0] MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.2[0]
AA PHL-STL MAR 0.8>2[4]
AA PHL-SWF MAR 0>0.7[0]
AA PHL-SYR MAR 1.1>2[2]
AA PHL-TPA MAR 1.2>3[5]
AA PHL-TVC JUN 0.1>0.9[0] JUL 0.2>1.0[0] AUG 0.1>1.0[0.1] SEP 0>1.0[0]
AA PHL-TYS MAR 0.8>1.5[1.0]
AA PHL-YUL MAR 0.4>0.7[1.8]
AA PHL-YYZ MAR 1.0>1.5[1.5]
AA PHX-SFO APR 3>4[4]
Surprising given Canada's stepped up restrictions
*AA PHX-YVR APR 0>1.0[0] MAY 0>1.0[0]
AA PVG-SEA APR 1.0>0[0]
AC BOS-YYZ MAR 0.8>1.0[0.8]
AC DEN-YYZ MAR 0.3>0.5[0.3]
AC FLL-YOW APR 0.4>0[1.0]
AC HNL-YVR APR 1.3>0[1.0]
AC MCO-YHZ APR 0.6>0[1.1]
AC MCO-YOW APR 0.6>0[1.0]
AC OGG-YVR MAR 0.2>0[0.2] APR 1.1>0[1.0]
AC OGG-YYC MAR 0.4>0[0.4] APR 0.3>0[0.5]
AC RSW-YUL APR 0.6>0[1.0]
AC SRQ-YYZ APR 0.4>0[1.0]
AC TPA-YHZ APR 0.4>0[1.0]
AN ABQ-SVC MAR 0>0.9[0]
AN BUR-HHR MAR 0>0.3[0]
AN BUR-MMH MAR 0>0.5[0]
AN CLD-MMH MAR 0>0.5[0]
AN HHR-MMH MAR 0>0.4[0]
AN PHX-SVC MAR 0>0.5[0]
AS ABQ-SEA MAR 1.3>1.0[1.1]
AS ADQ-ANC MAR 2>3[2]
AS ANC-BRW MAR 0.8>1.0[0.8]
AS ANC-HNL MAR 0.6>0.4[0.6]
AS ANC-JNU MAR 3>2[3]
**AS ANC-KOA APR 0.4>0[0.4] MAY 0.4>0[0] JUN 0.4>0[0] JUL 0.5>0[0] AUG 0.4>0[0]
AS ANC-LAX MAR 0.7>0.9[0.6] MAY 1.0>1.4[1.0] JUN 1.0>2[1.0] JUL 1.0>2[1.0] AUG 1.0>2[2] SEP 0.9>1.2[0.7]
*AS ANC-ORD MAY 0.4>0.8[0.3] JUN 1.0>2[0] JUL 1.0>2[0] AUG 1.0>2[1.3] SEP 1.0>1.2[0]
AS ANC-PDX MAR 1.8>1.0[1.9]
AS ANC-SEA MAR 10>12[10] SEP 14>15[14]
AS ATL-SEA MAR 1.9>1.4[1.9]
AS AUS-SJC MAR 1.1>0.7[1.1]
AS BIL-PDX MAR 1.5>1.0[1.5]
AS BOI-GEG MAR 3>2[3]
**AS BOI-PAE MAR 0.5>0[0.5] APR 1.0>0[0] MAY 1.0>0.4[0]
AS BOI-PDX MAR 5>3[5]
AS BOI-SAN MAR 1.4>1.0[1.4]
AS BOI-SEA MAR 9>10[9]
AS BOI-SFO MAR 1.4>1.0[1.3]
AS BOI-SJC MAR 1.4>1.0[1.4]
AS BOS-LAX MAR 0.5>0[0.5]
AS BOS-PDX MAR 0.4>0[0.4]
AS BOS-SFO MAR 1.0>0.3[1.0]
AS BRW-FAI MAR 0.2>0[0.2]
AS BRW-SCC MAR 0.5>0[0.5]
AS BUR-PDX MAR 1.9>1.0[1.9]
AS BZN-LAX MAY 1.0>1.4[0] JUN 1.0>2[0] JUL 1.0>2[0] AUG 1.0>2[0] SEP 1.0>1.2[0]
AS BZN-SEA MAR 3>4[3]
AS DAL-PDX MAR 1.3>0[1.3]
AS DAL-SEA MAR 2>1.5[2]
AS DAL-SFO MAR 1.5>0.9[1.5]
AS DEN-PDX MAR 1.5>1.0[1.5]
AS DEN-SEA JUN 5>6[3] JUL 5>6[3] AUG 5>6[6]
AS EUG-PDX MAR 1.4>0[1.3]
AS EWR-LAX MAR 1.6>0.8[1.6]
AS EWR-PDX MAR 0.4>0[0.4]
AS EWR-SEA MAR 1.3>1.0[1.3]
AS EWR-SFO MAR 1.6>0.9[1.6]
This seemed doomed from day 1
**AS EWR-SJC MAR 0.4>0[0.4] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0] JUL 0.8>0[0] AUG 0.9>0[0.8] SEP 0.8>0[0]
AS FAI-SEA MAR 3>2[3]
AS FAT-PDX MAR 1.4>1.0[1.4]
AS FAT-SAN MAR 2>1.0[2]
AS FCA-PDX MAR 0.5>0[0.5]
**AS FLL-SAN APR 0.7>0.1[0] MAY 0.7>0[0] JUN 0.7>0[0] JUL 0.7>0[0] AUG 0.7>0[0] SEP 0.7>0[0]
AS FLL-SFO APR 0.7>0.1[0.6] MAY 0.4>0[0.5]
AS GDL-LAX MAR 0.7>1.0[1.0]
AS GEG-PAE MAR 0.5>0[0.5] APR 1.0>0[1.0] MAY 1.0>0.4[1.0]
AS GEG-PDX MAR 5>3[5]
AS GEG-SAN MAR 1.4>1.0[1.4]
AS GEG-SFO MAR 1.4>1.0[1.4]
AS HNL-OAK MAR 0.2>0[0.2]
AS HNL-SAN MAY 1.0>1.4[1.0] JUN 1.0>2[0.6] JUL 1.0>2[1.0] AUG 1.0>2[1.0] SEP 1.0>1.2[0.7]
AS HNL-SFO MAR 0.5>0[0.5]
AS IAD-LAX MAR 0.9>0[0.9]
AS IAD-SEA MAR 1.8>1.0[1.8]
*AS IAD-SFO MAR 0.8>0[0.8] APR 2.0>0[1.7] MAY 2.0>0.4[0.8] JUN 2>1.0[1.0] JUL 2>1.0[1.0] AUG 2>1.0[2]
AS IAH-SEA MAR 1.4>1.0[1.4]
**AS JAC-SAN JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0]
AS JAC-SEA MAR 0.5>0.7[0.5]
AS JFK-LAX MAR 2>0.4[2]
AS JFK-PDX MAR 0.5>0[0.5]
AS JFK-SEA MAR 1.9>1.0[1.9]
AS JFK-SFO MAR 2>0.8[2]
AS JNU-SIT MAR 1.3>1.0[1.3]
AS KOA-OAK MAR 0.3>0[0.3]
AS KTN-SIT MAR 0.5>0[0.5]
AS LAS-LAX MAR 2>3[3]
AS LAS-SFO MAR 2>4[2]
AS LAX-LIH MAR 0.2>0[0.2]
**AS LAX-ORD MAR 0.5>0[0.5] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0.8[0]
AS LAX-PAE MAR 0.8>0.4[0.9]
AS LAX-RDM MAR 1.4>1.0[1.4]
AS LAX-RNO JUN 2>3[0] JUL 2>3[0] AUG 2>3[0]
AS LAX-SEA MAR 10>12[11]
AS LAX-SJO MAR 0.4>0[0.4]
AS LAX-STS MAR 1.5>1.0[1.5]
AS LIH-OAK MAR 0.2>0[0.2]
AS LIH-PDX MAR 0.5>0[0.5]
AS LIH-SAN MAR 0.5>0[0.5]
AS LIH-SEA MAR 1.2>1.4[1.2]
AS LIH-SJC MAR 0.5>0[0.5] APR 1.0>0[0.8] MAY 1.0>0.4[1.0]
AS MCI-PDX MAR 0.5>0[0.5]
AS MCO-SAN MAR 1.1>0.8[1.1]
AS MFR-PDX MAR 4>2[4]
AS MFR-SEA MAR 5>6[5]
AS MRY-SAN MAR 1.4>1.0[1.4]
AS MSO-PDX MAR 0.5>0[0.5]
AS MSO-SEA MAR 3>4[3]
AS MSP-PDX MAR 0.5>0[0.5]
AS MSP-SEA MAR 1.5>1.9[1.5]
AS MSY-SEA MAR 1.4>1.0[1.4]
AS OAK-OGG MAR 0.3>0[0.3]
AS OAK-PDX MAR 1.9>1.0[1.9]
AS OGG-SAN MAY 1.0>1.4[1.0] JUN 1.0>2[0.6] JUL 1.0>2[0.7] AUG 1.0>2[1.5] SEP 1.0>1.2[1.0]
AS OGG-SFO MAR 0.4>0[0.4]
AS OME-OTZ MAR 0.2>0[0.2]
AS ONT-PDX MAR 1.9>1.0[1.9]
AS ORD-PDX MAR 1.2>0.8[1.2]
AS ORD-SFO MAR 0.9>0.5[0.9]
*AS PAE-PDX MAR 0.9>0[0.9] APR 2>0[3] MAY 2>0[3] JUN 2>0[0] JUL 2>0[0] AUG 2>0[2] SEP 2.0>1.5[0]
AS PAE-PHX MAR 1.3>1.0[1.3]
*AS PAE-PSP MAY 1.0>0.6[1.0] JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0.8[0]
AS PAE-SAN MAR 0.9>0.5[0.9]
AS PAE-SFO MAR 0.8>0[0.8] APR 1.9>0[2] MAY 1.9>0.8[1.9]
AS PAE-SJC MAR 0.9>0[0.9] APR 2>0[2] MAY 2>0.8[1.9]
AS PDX-RDM MAR 2>1.0[2]
AS PDX-RNO MAR 3>2.0[3]
AS PDX-SEA MAR 13>15[13] MAY 16>17[14]
AS PDX-SFO MAR 4>5[4]
AS PDX-SJC MAR 4>3[4]
AS PDX-SLC MAR 3>2[3]
AS PDX-STS MAR 0.9>0.5[0.9]
AS PDX-TUS MAR 0.7>1.0[0.7] MAY 0.8>1.0[1.6]
AS PHL-SEA MAR 1.4>1.0[1.4]
**AS PHL-SFO MAR 0.5>0[0.5] APR 1.0>0[0] MAY 1.0>0[0] JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[1.0] SEP 1.0>0[0]
AS PHX-SEA MAR 9>10[9]
AS PHX-SFO MAR 1.4>1.0[1.4]
AS PSC-SEA MAR 5>6[5]
AS PSP-SFO MAR 2>3[2]
AS RDM-SFO MAR 1.4>1.0[1.4]
*AS RDM-SJC MAR 0.5>0[0.5] APR 1.0>0[0] MAY 1.0>0[0] JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0.8[0]
AS RDU-SEA MAR 1.4>1.0[1.4]
AS SAN-SFO MAR 4>6[4]
AS SAN-SLC MAR 1.3>1.0[1.3]
AS SAT-SEA MAR 1.4>1.0[1.4]
AS SBP-SEA MAR 0.9>1.5[0.9] APR 1.0>2[1.0] MAY 1.0>2[1.0] JUN 1.0>2[1.0] JUL 1.0>2[1.0] AUG 1.0>2[1.0] SEP 1.0>2[1.0]
AS SEA-SFO MAR 8>9[8]
AS SEA-SNA MAR 7>8[7]
AS SEA-YEG APR 2>0[3] MAY 3>1.2[1.0]
AS SEA-YLW APR 1.8>0[2] MAY 2>0.8[1.0]
AS SEA-YYC APR 3>0[2] MAY 3>1.2[1.0]
AS SEA-YYJ APR 4>0[3] MAY 4>1.5[1.0]
B6 ATL-EWR MAR 3>1.5[3]
B6 AUA-EWR MAR 0.8>0.5[0.8]
B6 AUS-BOS MAR 1.1>0.7[1.0]
B6 AUS-EWR MAR 1.0>0.7[1.0]
B6 AUS-JFK MAR 1.5>0.7[1.6]
B6 AUS-MCO MAR 0.9>0.5[0.9]
B6 AUS-RDU MAR 0.7>0.3[0.7]
B6 AUS-SFO MAR 1.0>0.5[1.0]
B6 BDL-CUN MAR 0.4>0.2[0.4]
B6 BDL-LAS MAR 0.5>0[0.5]
B6 BDL-LAX MAR 0.9>0.0[0.9]
B6 BDL-SFO MAR 0.6>0[0.6]
B6 BGI-JFK MAR 0.9>0.4[0.9]
B6 BNA-BOS MAR 0.8>0.4[0.8]
B6 BNA-JFK MAR 0.5>0.3[0.5]
B6 BOS-BUF MAR 0.7>0.3[0.7]
B6 BOS-CHS MAR 1.5>0.9[1.6]
B6 BOS-CLE MAR 0.9>0.5[1.0]
B6 BOS-CLT MAR 1.0>0.3[1.0]
B6 BOS-DCA MAR 4>1.5[4] APR 13>12[13]
B6 BOS-DTW MAR 0.9>0.4[0.9]
B6 BOS-EWR MAR 2>0.5[2]
B6 BOS-IAH MAR 0.8>0.4[0.7]
B6 BOS-JFK MAR 3>2[3] SEP 1.1>1.4[6]
B6 BOS-LAS MAR 1.7>1.0[1.6]
B6 BOS-LGA MAR 1.2>0[1.0] APR 9>8[5]
B6 BOS-NAS MAR 0.5>0.3[0.5]
B6 BOS-ORD MAR 1.1>0.7[1.0]
B6 BOS-PHL MAR 1.5>0[1.5] APR 7>6[7]
B6 BOS-PIT MAR 1.0>0.3[1.0] SEP 0.9>1.1[5]
B6 BOS-RDU MAR 2>1.5[2]
B6 BOS-RIC MAR 0.9>0.3[0.9]
B6 BOS-SAN MAR 1.1>0.7[1.1]
B6 BOS-SEA MAR 0.8>0.4[0.8]
B6 BOS-SFO MAR 2>1.5[2]
B6 BUF-FLL MAR 0.7>0.2[0.7]
B6 BUF-JFK MAR 1.3>1.0[1.3]
B6 BUF-MCO MAR 0.9>0.6[0.9]
B6 BZN-LAX MAR 0.8>0[0.8]
B6 CHS-EWR MAR 0.8>0.5[0.8]
B6 CHS-FLL MAR 0.9>0.5[0.9]
B6 CUN-EWR MAR 1.3>1.0[1.3]
B6 CUN-LAX MAR 1.1>0.3[1.1]
B6 CUN-RDU MAR 0.4>0.1[0.4]
B6 CUN-SFO MAR 0.5>0.1[0.5]
B6 DCA-FLL MAR 2>1.6[2]
B6 DCA-MCO MAR 2>1.5[2]
B6 DCA-PBI MAR 1.0>0.5[1.0]
B6 DCA-RSW MAR 1.1>0.9[1.1]
B6 DCA-TPA MAR 0.9>0.6[0.9]
B6 DEN-JFK MAR 1.0>0.7[1.0]
B6 DFW-JFK MAR 1.0>0.6[1.0]
B6 DTW-JFK MAR 1.0>0.2[1.0]
B6 EWR-JAX MAR 0.8>0.3[0.8]
B6 EWR-LAX MAR 3>2[3]
B6 EWR-PHX MAR 1.0>0.8[1.0]
B6 EWR-PLS MAR 0.5>0.2[0.5]
B6 EWR-PUJ MAR 0.5>0.3[0.5]
B6 EWR-RDU MAR 3>0.7[3]
B6 EWR-SAN MAR 0.9>0.3[0.9]
B6 EWR-SFO MAR 1.0>0[1.0]
B6 EWR-SXM MAR 0.5>0.1[0.5]
B6 FLL-GCM MAR 0.8>0[0.8]
B6 FLL-GYE MAR 1.0>0.5[1.0]
B6 FLL-JAX MAR 1.2>0.8[1.2]
B6 FLL-PAP MAR 3>2[3]
B6 FLL-PIT MAR 0.9>0.7[0.9]
B6 FLL-PSP MAR 0.2>0[0.2]
B6 FLL-PVD MAR 0.9>0.5[0.9]
B6 FLL-SAN MAR 0.9>0.3[0.9]
B6 FLL-SFO MAR 1.9>1.0[1.9]
B6 FLL-SLC APR 1.0>1.2[1.0]
B6 FLL-UIO MAR 0.9>0.5[0.9]
B6 HPN-MCO MAR 1.9>1.0[1.9]
B6 HPN-TPA MAR 1.0>0.8[1.0]
B6 JAX-LAX MAR 0.8>0.1[0.8]
B6 JAX-RDU MAR 0.8>0.3[0.8]
B6 JFK-LAS MAR 1.9>1.2[1.9]
B6 JFK-LAX MAR 5>3[5]
B6 JFK-MSY MAR 1.1>0.5[1.1]
B6 JFK-NAS MAR 0.8>0.1[0.8]
B6 JFK-ORD MAR 1.0>0.2[1.0]
B6 JFK-PAP MAR 1.8>1.2[1.8]
B6 JFK-PHX MAR 0.9>0.6[0.9]
B6 JFK-PLS MAR 0.5>0.2[0.5]
B6 JFK-POS MAR 0.4>0.0[0.4]
B6 JFK-PSP MAR 0.7>0.3[0.7]
B6 JFK-RDU MAR 1.2>0.6[1.2]
B6 JFK-ROC MAR 0.9>0.5[0.9]
B6 JFK-RSW MAR 2>1.6[2]
B6 JFK-SAN MAR 1.1>0.6[1.1]
B6 JFK-SFO MAR 3>1.9[3]
B6 JFK-SJO MAR 0.4>0.2[0.4]
B6 JFK-SLC MAR 1.7>1.0[1.7]
B6 JFK-SYR MAR 0.9>0.6[0.9]
B6 JFK-UVF MAR 0.7>0.4[0.7]
B6 LAS-RDU MAR 0.9>0.3[0.9]
B6 LAS-RIC MAR 0.8>0.1[0.8]
B6 LAX-PBI MAR 0.9>0.3[0.9]
B6 LAX-RDU MAR 0.9>0.3[0.9]
B6 LAX-RIC MAR 0.9>0.3[0.9]
B6 LAX-RNO MAR 0.9>0.5[0.9]
B6 LAX-SFO MAR 0.3>0[0.3]
B6 LAX-SLC MAR 1.1>0.3[1.1]
B6 LGA-RSW MAR 0.8>0.5[0.8]
B6 LGA-TPA MAR 1.0>0.6[1.0]
B6 MBJ-MCO MAR 0.8>0.4[0.8]
B6 MCO-NAS MAR 0.6>0[0.6]
B6 MCO-RDU MAR 1.0>0.7[1.0]
B6 MCO-RIC MAR 1.1>0.8[1.1]
B6 MCO-SFO MAR 0.8>0.4[0.8]
B6 PBI-PHL MAR 1.0>0.6[1.0]
B6 PVD-RSW MAR 0.9>0.7[0.9]
B6 PVD-TPA MAR 0.9>0.6[0.9]
B6 RDU-RSW MAR 0.9>0.4[0.9]
B6 RDU-SFO MAR 0.6>0.1[0.6]
B6 RDU-TPA MAR 1.0>0.4[1.0]
B6 RIC-TPA MAR 1.0>0.5[1.0]
BA ATL-LHR MAR 0.5>0.1[0.5]
BA DEN-LHR MAR 0.5>0.1[0.5]
BA IAH-LHR MAR 1.0>0.5[1.0]
BA JFK-LHR MAR 2>1.4[2]
BA LAS-LHR MAR 0.5>0.1[0.5]
BA LHR-MCO MAR 0.5>0.1[0.5]
BA LHR-MIA MAR 2>1.1[2]
BA LHR-ORD MAR 1.1>0.3[1.1]
BA LHR-PHL MAR 0.5>0.2[0.5]
BA LHR-PHX MAR 0.5>0.1[0.5]
BA LHR-SEA MAR 1.1>0.7[1.1]
BA LHR-SFO MAR 1.1>0.6[1.1]
CA JFK-PEK APR 1.0>0[0.6] MAY 1.0>0[0.7]
CA LAX-PEK APR 1.0>0.1[0.8] MAY 1.0>0.2[0.8]
CX HKG-JFK MAR 1.0>0.8[1.0]
CX HKG-LAX MAR 1.2>0.9[1.2]
CX HKG-SFO MAR 0.9>0.7[0.9]
DL ABQ-ATL MAR 1.5>1.0[2.0]
DL AEX-ATL MAR 3>4[3]
DL AGS-ATL MAR 5>7[7] APR 8>9[8]
DL AMS-ATL APR 3>2[2]
DL AMS-BOS MAR 1.0>0.7[1.0]
DL AMS-DTW APR 2>1.0[3]
DL AMS-JFK MAR 1.0>0.7[1.0] APR 1.7>1.0[3]
DL AMS-MSP MAR 1.0>0.7[1.0] APR 1.7>1.0[2]
DL AMS-SEA MAR 1.0>0.6[1.0]
DL ATL-ATW MAR 0.9>2.0[1.9]
DL ATL-AVL MAR 5>6[7]
DL ATL-BDA MAR 0.6>0.4[0.6]
DL ATL-BHM MAR 6>7[9]
DL ATL-BTR MAR 4>5[5]
DL ATL-CAE MAR 5>7[7]
DL ATL-CDG MAR 1.0>1.5[1.0]
DL ATL-CHA MAR 5>7[6] APR 8>10[10] SEP 9>10[8]
DL ATL-CHO MAR 1.9>3[4]
DL ATL-CHS MAR 8>9[10]
DL ATL-CUN MAR 6>5[6]
DL ATL-DAY MAR 3>4[4]
DL ATL-DSM MAR 3>4[3]
DL ATL-FAY MAR 3>4[4]
DL ATL-FCO MAR 0.4>0.8[0.5] APR 1.0>2[0.8] MAY 1.0>2[0] JUN 1.0>2[0]
*DL ATL-FSD APR 0>0.6[1.0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
DL ATL-GIG MAR 0.6>0[0.6]
DL ATL-GNV MAR 3>4[6]
DL ATL-GSO MAR 5>6[7]
DL ATL-GSP MAR 6>7[7]
DL ATL-GTR MAR 1.9>3[3] APR 3>4[4]
DL ATL-HND APR 1.0>0.7[0.1]
DL ATL-HSV MAR 5>6[7]
DL ATL-IAD MAR 4>5[7]
DL ATL-JAN MAR 4>5[7]
*DL ATL-JNB APR 1.0>0[1.0] MAY 1.0>0[0.8]
DL ATL-KIN MAR 1.0>0.7[1.0]
DL ATL-LEX MAR 5>7[7]
DL ATL-LFT MAR 3>4[3]
DL ATL-LIR MAR 1.5>1.1[1.5]
DL ATL-LIT MAR 4>6[6]
DL ATL-MBJ MAR 3>2[3]
DL ATL-MEX MAR 6>5[6]
DL ATL-MOB MAR 3>4[6] APR 6>7[7]
DL ATL-MYR MAR 3>4[4]
DL ATL-OAJ MAR 3>5[4] APR 3>4[4]
DL ATL-OKC MAR 4>6[6]
DL ATL-OMA MAR 4>5[4]
DL ATL-ORD MAR 6>7[8]
DL ATL-SAV MAR 7>9[9]
DL ATL-SDF MAR 6>7[8]
DL ATL-SJD MAR 2>1.2[2]
DL ATL-SJO MAR 1.5>1.1[1.5]
DL ATL-SJU MAR 2.9>4.0[2.9]
DL ATL-STT MAR 3.0>4.0[3.0]
DL ATL-TRI APR 6>7[6]
DL ATL-TYS MAR 7>8[8]
DL ATL-VPS MAR 6>7[6]
DL ATL-YUL MAR 0.8>1.0[0.8]
DL AUS-RDU MAR 0.8>1.0[1.0]
DL AUS-SEA MAR 0.5>1.0[1.8]
DL AUS-SLC MAR 2>3[3]
DL AZO-MSP APR 0.5>0.9[1.5]
DL BDL-RDU APR 0.8>1.0[0.9]
DL BIS-MSP APR 6>7[6]
DL BNA-LAX MAR 1.4>1.7[1.7]
DL BNA-SEA MAR 0.5>1.0[0.8]
DL BOI-LAX MAR 1.2>1.9[1.0] APR 1.6>1.9[2.0]
DL BOS-BUF APR 2>3[3]
DL BOS-CMH APR 2>3[3]
DL BOS-DUB APR 0.8>0[0.7]
DL BOS-JFK MAR 1.7>3[6]
DL BOS-LAX MAR 2>3[3]
DL BOS-LGA MAR 2>3[13]
DL BOS-PIT MAR 0.4>1.0[3] APR 4>5[4]
DL BOS-RDU MAR 1.9>3[5]
DL BOS-RIC MAR 0.4>1.0[1.2] APR 2>3[3]
DL BOS-STT MAR 0.5>1.0[0.5]
DL BTV-DTW APR 2>3[3]
DL BUF-JFK MAR 2>3[4]
DL BZN-MSP MAR 1.6>2[3]
DL CAE-LGA APR 1.5>1.9[1.8]
DL CDG-JFK APR 1.7>1.0[1.0]
DL CDG-SEA MAR 0>0.4[0]
DL CID-DTW APR 2>3[4]
DL CLE-DTW APR 6>7[5]
DL CMH-DTW APR 6>7[6]
DL CUN-RDU MAR 1.0>0.4[1.0]
DL CVG-ORD APR 3>4[4]
DL CWA-DTW APR 1.5>1.9[1.9]
DL DTW-EWR MAR 3>4[5]
DL DTW-GSP MAR 1.2>1.5[3]
DL DTW-HND APR 1.0>0.7[0.1]
DL DTW-HPN APR 3>4[4]
DL DTW-IAD APR 3>4[5]
DL DTW-ICN APR 1.0>1.3[1.0]
DL DTW-JFK MAR 1.9>3[3]
DL DTW-LEX APR 3>4[4]
DL DTW-LHR APR 0.8>0[1.0]
DL DTW-MBS APR 4>5[5]
DL DTW-MCI MAR 2>3[4]
DL DTW-MKE MAR 2>3[5]
DL DTW-MQT APR 1.5>1.9[1.6]
DL DTW-MTY MAR 0.8>0[0.8]
DL DTW-ORF APR 3>4[3]
DL DTW-PUJ MAR 1.0>0.4[1.0]
DL DTW-PVG APR 1.0>0[0]
DL DTW-SAV APR 0.8>1.0[0.7]
DL DTW-SDF APR 4>5[5]
DL DTW-SJD MAR 1.0>0.4[1.0]
DL DTW-TYS MAR 1.3>1.5[4]
DL FLL-RDU MAR 2>3[2]
DL GEG-LAX MAR 0.7>1.0[0.8]
DL GFK-MSP APR 4>6[5]
DL GRR-MSP MAR 2>3[4]
DL GRU-JFK MAR 1.0>0.6[1.0]
DL HND-HNL APR 1.0>0[0.1]
DL HND-LAX APR 1.0>0.4[1.0]
DL HND-MSP APR 0.7>0[1.0]
DL HND-PDX APR 0.7>0[0.1]
DL HND-SEA APR 1.0>0.7[0.1]
DL IAD-JFK APR 2>3[4]
DL IAH-SLC MAR 2>3[3]
DL ICN-MSP APR 0.7>0[1.0]
DL ICN-SEA MAR 0.9>0.6[0.9]
DL JAX-JFK MAR 1.5>2.0[3]
DL JFK-LAS MAR 1.5>2.0[4]
DL JFK-SFO MAR 2>3[6]
DL JFK-SXM MAR 1.0>0.5[1.0]
DL LAN-MSP APR 0.6>1.0[1.0]
DL LAS-LAX MAR 3>6[4] APR 6>7[7]
DL LAX-LIH MAR 0.9>0.5[1.0]
DL LAX-MSY MAR 1.5>2[3]
DL LAX-PDX MAR 3>4[4]
DL LAX-PHX MAR 3>5[4] APR 5>6[5]
DL LAX-PVG APR 1.0>0[0]
DL LAX-PVR MAR 1.9>1.0[1.9]
DL LAX-RDU MAR 0.5>1.3[0.9]
DL LAX-SFO MAR 3>5[6]
DL LAX-SJC MAR 1.9>3[4] APR 6>7[6]
DL LAX-SJD MAR 3>2[3]
DL LAX-SMF MAR 3>4[3] APR 5>6[5]
DL LAX-TPA MAR 1.4>1.0[1.7]
DL LAX-TUS MAR 1.8>3[1.6]
DL LGA-MCO MAR 6>5[6]
DL LHR-MSP APR 0.8>0[1.0]
DL LIH-SEA MAR 1.0>0.4[1.0]
DL MKE-MSP MAR 3>4[5]
DL MKE-SLC APR 0.8>1.0[1.0]
DL MSP-ORD MAR 3>4[6]
DL MSP-SJU MAR 0>0.6[0]
DL MSP-STT MAR 0.4>1.0[0.4]
DL OMA-SLC MAR 1.9>3[1.7]
DL PKX-SEA APR 1.0>0[0]
DL PVG-SEA APR 1.0>0[0]
DL PVR-SLC MAR 1.9>1.0[1.9]
DL RDU-SEA MAR 0.5>0.8[1.0]
DL SJD-SLC MAR 1.9>1.0[1.9]
*EK DXB-MCO JUN 0>0.6[0]
F2 KIS-MDR MAR 0.5>1.0[0] APR 0.6>1.0[0] MAY 0.6>1.0[0] JUN 0.5>1.0[0] JUL 0.6>1.0[0] AUG 0.6>1.0[0] SEP 0.5>1.0[0]
F2 MDR-MUZ MAR 0>0.5[0] APR 0>0.4[0] MAY 0>0.4[0] JUN 0>0.5[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.5[0]
F9 ALB-DEN MAY 0.3>0.1[0]
F9 ALB-MCO APR 0.9>0.7[0.6]
**F9 ALB-TPA APR 0.6>0[0] MAY 0.6>0[0] JUN 0.5>0[0] JUL 0.6>0[0] AUG 0.2>0[0]
**F9 ATL-AUS APR 0.4>0[0] MAY 0.6>0[0.1] JUN 0.6>0[0] JUL 0.6>0[0] AUG 0.5>0[0] SEP 0.4>0[0]
F9 ATL-CVG APR 0.7>0.4[0]
F9 ATL-DEN APR 1.3>1.7[1.0]
F9 ATL-EWR APR 1.0>0[1.0] MAY 1.0>0.2[1.0]
**F9 ATL-ISP APR 0.5>0[0.5] MAY 0.6>0[0.4]
F9 ATL-LAX APR 0.6>0[0.5] MAY 1.0>0.2[0.4]
**F9 ATL-SAT APR 0.3>0[0] MAY 0.4>0[0.1] JUN 0.4>0[0] JUL 0.4>0[0] AUG 0.5>0[0] SEP 0.4>0[0]
F9 ATL-SLC APR 0.5>0[0.5] MAY 0.6>0.1[0.4]
F9 ATL-TPA APR 1.0>0[0.5] MAY 1.0>0.2[0.5]
F9 ATL-TTN APR 1.0>0.7[1.0]
**F9 AUS-IAD APR 0.3>0[0.4] MAY 0.4>0[0.4] JUN 0.4>0[0] JUL 0.4>0[0.1] AUG 0.4>0[0] SEP 0.3>0[0]
F9 AUS-MCO APR 1.0>0.8[0.5]
**F9 AUS-MIA APR 0.4>0[0] MAY 0.3>0[0.1] JUN 0.3>0[0.3] JUL 0.3>0[0.1] AUG 0.3>0[0.2] SEP 0.3>0[0.2]
**F9 AUS-ORD APR 0.3>0[0] MAY 0.4>0[0.1] JUN 0.4>0[0.3] JUL 0.4>0[0.1] AUG 0.4>0[0.4] SEP 0.3>0[0.4]
**F9 AUS-PHL APR 0.4>0[0] MAY 0.6>0[0.1] JUN 0.6>0[0] JUL 0.6>0[0] AUG 0.4>0[0] SEP 0.3>0[0]
**F9 AUS-SAN APR 0.5>0[0.5] MAY 0.6>0[0.5] JUN 0.6>0[0] JUL 0.6>0[0.1] AUG 0.4>0[0.4] SEP 0.3>0[0.4]
F9 AUS-SLC APR 0.2>0[0.6]
**F9 AUS-TPA APR 0.4>0[0] MAY 0.6>0[0.1]
F9 BKG-DEN APR 0.2>0[0]
F9 BNA-MCO APR 0.6>0.4[1.0]
**F9 BNA-ORD APR 0.3>0[0] MAY 0.5>0[0]
F9 BOI-DEN MAY 0.3>0[0.3]
**F9 BOS-PHL APR 0.4>0[0] MAY 0.7>0[0] JUN 1.0>0.7[0]
F9 BOS-RSW APR 0.6>0.3[0]
**F9 BTV-DEN APR 0.2>0[0] MAY 0.3>0[0.1]
**F9 BUF-MIA APR 0.4>0[0] MAY 0.5>0[0] JUN 0.4>0[0] JUL 0.4>0[0]
F9 CLE-RDU APR 0.3>0[0] MAY 0.5>0.1[0.1]
F9 CLE-TPA APR 1.4>1.0[1.7]
**F9 CLT-LAS APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0.7[0]
F9 CLT-TTN APR 0.6>0[0.6] MAY 0.6>0.1[0.6]
F9 CUN-EWR APR 0.6>0[0.7] MAY 0.6>0.1[1.0]
**F9 CVG-DFW APR 0.7>0[0] MAY 0.7>0[0.1] AUG 0.2>0.6[1.0] SEP 0>0.6[0.7]
**F9 CVG-LAX APR 0.6>0[0] MAY 1.0>0[0.1] JUN 1.0>0[0] JUL 1.0>0[0] AUG 0.4>0[0]
**F9 CVG-PHL APR 0.4>0[0] MAY 0.6>0[0] JUN 0.5>0[0] JUL 0.6>0[0] AUG 0.2>0[0]
**F9 DEN-HSV APR 0.2>0[0] MAY 0.3>0[0] JUN 0.3>0[0] JUL 0.3>0[0.1]
**F9 DEN-JAN APR 0.2>0[0] MAY 0.3>0[0] JUN 0.3>0[0] JUL 0.3>0[0.1] AUG 0.3>0[0] SEP 0.3>0[0]
F9 DEN-MSO APR 0.2>0[0]
F9 DEN-MSP MAR 0.7>0.9[0.9]
F9 DEN-RNO APR 0.2>0[0] MAY 0.3>0.1[0]
F9 DEN-SNA APR 0.4>0.8[1.0]
F9 DEN-STL MAR 0.7>0.9[0.8]
F9 DEN-SYR MAY 0.3>0.1[0]
F9 DFW-PHL APR 0.4>0[0.5]
F9 DTW-PHX APR 0.4>0[0.6]
F9 DTW-TTN MAY 0.3>0[0.1]
F9 ELP-ORD APR 0.3>0[0]
**F9 EWR-MYR APR 0.4>0[0] MAY 0.4>0[0] JUN 0.4>0[0] JUL 0.4>0[0] AUG 0.5>0[0.4] SEP 0.4>0[0]
**F9 EWR-ONT APR 0.6>0[0] MAY 1.0>0[0.3] JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0]
**F9 EWR-ORD APR 0.6>0[0] MAY 1.0>0[0.3] JUN 1.0>0.7[0]
**F9 EWR-PBI APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[0] JUL 1.0>0[0] AUG 0.4>0[0.4]
F9 EWR-PHX APR 0.4>0[1.0]
**F9 EWR-RSW APR 0.4>0[0] MAY 0.4>0[0] JUN 0.4>0[0] JUL 0.4>0[0]
F9 IAH-PHL APR 0.2>0[0]
F9 IND-MCO APR 0.6>0.4[0.6]
F9 ISP-LAS APR 1.0>0[0] MAY 1.0>0[0] JUN 1.0>0.4[0] JUL 1.0>0.6[0] SEP 0>0.6[0]
F9 ISP-MCO MAR 1.6>1.1[3] APR 3>2[1.9]
F9 ISP-PBI MAR 0.8>0.5[1.7] APR 1.6>1.1[1.0]
F9 ISP-TPA MAR 0.6>0.4[1.5] APR 1.6>1.0[1.0]
F9 JAN-MCO APR 0.3>0[0] MAY 0.4>0.1[0]
F9 LAS-LAX APR 0.7>1.2[1.0]
F9 LAS-PHL APR 1.0>0.4[1.0] MAY 1.0>0.2[1.0]
F9 LAS-SAN APR 0.7>1.2[1.0]
F9 LAS-SJC MAR 0.6>0.4[1.7] APR 1.2>0.6[0.8]
F9 LAS-SLC APR 1.2>0.8[1.0]
**F9 LAX-MCO APR 1.0>0[0] MAY 1.0>0[0] JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[1.0] SEP 1.0>0[0.1]
**F9 LAX-PHL APR 0.6>0[0] MAY 1.0>0[0.3] JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0]
**F9 MCI-PHL APR 0.3>0[0] MAY 0.4>0[0] JUN 0.4>0[0] JUL 0.4>0[0]
F9 MCO-MEM APR 0.5>0.3[0.4]
F9 MCO-MIA APR 1.0>1.4[0]
F9 MCO-MKE MAR 1.1>1.5[0.9] APR 0.6>1.0[1.0]
F9 MCO-MSP APR 0.4>0.6[0.6]
F9 MCO-MSY APR 0.6>0.4[0.5]
F9 MCO-ONT MAY 0.6>0.4[0.7]
F9 MCO-PHL APR 6>5[3]
F9 MCO-PVD APR 1.6>1.3[1.0]
F9 MCO-RDU APR 1.0>1.4[1.0]
F9 MCO-SDF APR 0>0.2[0.5]
F9 MCO-STL APR 1.4>1.0[1.0]
F9 MCO-SYR APR 0.4>0.6[0.6]
F9 MIA-ONT APR 0.4>0[0] MAY 0.6>0.1[0.3]
F9 MIA-PHL MAR 1.3>0.9[3] APR 3>2[1.4]
**F9 MIA-PVD APR 0.7>0[0] MAY 0.7>0[0] JUN 0.7>0[0] JUL 0.7>0[0] AUG 0.2>0[0]
F9 MIA-TTN APR 0.6>0.4[0]
F9 MKE-RSW MAR 0.7>0.9[0.5] APR 0.2>0.4[1.0]
F9 MKE-TPA APR 0.2>0.4[1.0]
F9 ORD-PHL APR 0.4>0[0] MAY 0.7>0.2[0]
F9 ORD-SJU APR 1.0>0.4[0] MAY 1.0>0.6[0]
F9 ORD-TTN APR 0.6>0[0] MAY 1.0>0.2[0.3]
**F9 PBI-PHL APR 1.0>0.1[0.6] MAY 1.0>0[0.6] JUN 1.0>0[0] JUL 1.0>0[0.0] AUG 0.6>0[0.3] SEP 0.4>0[0]
**F9 PHL-PHX APR 1.0>0[0] MAY 1.0>0[0] JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0]
F9 PHL-TPA MAR 1.4>1.1[3] APR 3>2[2]
F9 PHX-SFO APR 0>0.4[0]
F9 PWM-RSW APR 0.2>0.4[0.6]
F9 RDU-TTN APR 0.6>0[0.6] MAY 0.6>0.1[0.5]
F9 SRQ-TTN APR 0.2>0[0.6]
F9 TPA-TTN APR 0.7>0.5[1.0]
G4 ABE-BNA JUN 0.1>0.3[0]
G4 ABE-FLL MAR 0>0.3[0]
G4 ABE-MYR JUN 0.3>0.6[0]
G4 ABE-PGD MAR 0.2>0.6[0.2] APR 0.2>0.5[0.6] JUN 0.1>0.6[0] JUL 0.5>0.7[0.3]
G4 ABE-PIE JUN 0.5>0.9[0]
G4 ABE-SFB APR 1.4>1.8[2] MAY 1.4>1.7[2.0] JUN 1.1>1.8[0] AUG 0.7>1.0[1.5]
G4 ATW-AZA MAR 0.2>0.7[0.2] APR 0.2>0.4[0.6] JUN 0.1>0.3[0]
G4 ATW-PGD MAR 0.2>0.5[0.2]
G4 ATW-PIE MAR 0.2>0.4[0.2] APR 0.1>0.3[0.4]
G4 ATW-SFB MAR 0.2>0.8[0.2] APR 0.2>0.5[0.8] JUN 0.1>0.3[0]
G4 AUS-LAS MAY 0.1>0.4[0.3]
G4 AVL-BWI JUN 0.1>0.3[0]
G4 AVL-FLL MAR 1.6>3[1.6] APR 1.7>2[3] MAY 1.3>1.8[2] AUG 0.7>1.0[1.6]
G4 AVL-PGD MAR 0.2>0.5[0.2] JUN 0.2>0.5[0] JUL 0.4>0.6[0.4]
G4 AVL-PIE MAR 0.7>1.3[0.7] APR 0.9>1.1[1.3] MAY 0.7>0.9[1.2] JUN 1.0>1.4[0] JUL 1.3>1.6[0.7] AUG 0.4>0.8[1.4]
G4 AVL-SFB MAR 1.0>1.5[1.0] APR 1.0>1.4[1.9] MAY 1.0>1.3[1.8] JUN 0.9>1.9[0] JUL 1.5>2[0.8] AUG 0.4>0.8[1.6]
G4 AZA-BIL MAR 0.4>0.7[0.4] APR 0.1>0.4[0.7] JUN 0.2>0.4[0]
G4 AZA-BIS MAR 0.2>1.0[0.2] APR 0.2>0.5[1.1]
G4 AZA-BLI MAR 0.3>0.7[0.3] APR 0.2>0.4[0.7]
G4 AZA-BLV MAR 0.1>0.3[0.1]
G4 AZA-BOI MAR 0.1>0.3[0.1] MAY 0.1>0.3[0.1]
G4 AZA-CID MAR 0.3>1.0[0.3] APR 0.2>0.4[1.2] MAY 0.1>0.3[0.4] JUL 0.4>0.6[0.4]
G4 AZA-CVG MAR 0.3>0.5[0.3]
G4 AZA-DSM MAR 0.1>0.7[0.1] JUL 0.2>0.4[0.4]
G4 AZA-EUG MAR 0.2>0.5[0.2] APR 0.1>0.3[0.6] MAY 0.1>0.3[0.3] JUL 0.2>0.4[0.3]
G4 AZA-FAR MAR 0.3>1.4[0.3] APR 0.3>1.1[1.7] MAY 0.2>0.7[0.7] JUN 0.3>0.6[0] JUL 0.4>0.7[0.4] AUG 0.1>0.3[0.5]
G4 AZA-FCA MAR 0.1>0.3[0.1]
G4 AZA-FSD MAR 0.2>1.4[0.2] APR 0.1>0.9[1.6] MAY 0.1>0.3[0.8] JUN 0.2>0.7[0]
G4 AZA-FWA MAR 0>0.3[0] JUL 0.1>0.3[0.3]
G4 AZA-GFK MAR 0.1>0.5[0.1] APR 0.1>0.4[0.6]
G4 AZA-GJT MAR 0.1>0.3[0.1]
G4 AZA-GRI MAR 0.1>0.4[0.1] APR 0.1>0.3[0.4]
G4 AZA-GRR MAR 0.5>0.8[0.5] APR 0.3>0.6[0.9] MAY 0.2>0.5[0.5] JUN 0.3>0.5[0]
G4 AZA-GTF APR 0.1>0.3[0.4] MAY 0.1>0.3[0.3]
G4 AZA-IDA MAR 0.2>0.5[0.2] APR 0.3>0.5[0.6]
G4 AZA-JAC JUN 0>0.3[0] JUL 0>0.3[0]
G4 AZA-LAS MAR 0.1>0.6[0.1] APR 0.1>0.3[0.6]
G4 AZA-MLI MAR 0>0.3[0] APR 0.1>0.3[0.3] JUN 0.1>0.3[0]
G4 AZA-MOT MAR 0.1>0.5[0.1] APR 0.2>0.4[0.9]
G4 AZA-MSO APR 0.1>0.3[0.4] JUN 0.1>0.3[0]
G4 AZA-OAK MAR 0.1>0.4[0.1] APR 0.1>0.3[0.4] MAY 0.1>0.4[0.4]
G4 AZA-PIA MAR 0.2>0.7[0.2] APR 0.1>0.5[0.9] MAY 0.2>0.5[0.4] JUN 0.3>0.6[0]
G4 AZA-PSC MAR 0.2>0.5[0.2] APR 0.1>0.4[0.5] MAY 0.1>0.3[0.4]
G4 AZA-PVU MAR 0.8>1.7[0.8] APR 0.8>1.8[1.8] MAY 0.6>1.7[1.7] JUN 1.2>1.8[0] JUL 1.2>1.9[0.8] AUG 0.6>1.0[1.8]
G4 AZA-RAP MAR 0.1>0.7[0.1] JUL 0.4>0.6[0.4]
G4 AZA-RDM MAR 0.1>0.3[0.1] APR 0.1>0.3[0.3] MAY 0.1>0.3[0.3]
G4 AZA-RFD MAR 0.2>0.9[0.2]
G4 AZA-SBN MAR 0.1>0.5[0.1] APR 0.1>0.4[0.4]
G4 AZA-SCK APR 0.1>0.3[0.3] JUN 0.2>0.4[0]
G4 AZA-SGF MAR 0.2>0.5[0.2] APR 0.1>0.3[0.5] MAY 0.1>0.3[0.3] JUN 0.3>0.6[0] JUL 0.3>0.6[0.4]
G4 AZA-SMX APR 0.1>0.3[0]
G4 AZA-STC MAR 0.1>0.6[0.1] APR 0>0.4[0.7]
G4 BGR-SFB MAR 0.3>1.0[0.3] APR 0.4>0.9[1.0] JUN 0.1>0.5[0] JUL 0.3>0.7[0.4] AUG 0.1>0.3[0.5]
G4 BIL-LAS MAR 0.2>0.5[0.2]
G4 BIS-LAS MAR 0.5>0.7[0.5] APR 0.2>0.5[0.7] JUN 0.1>0.3[0]
G4 BIS-SFB MAR 0>0.3[0] JUL 0.1>0.3[0.3]
G4 BLI-LAS MAR 1.0>1.7[1.0] AUG 0.6>0.8[1.6]
G4 BLI-PSP APR 0.3>0.5[0.9]
G4 BLV-CHS JUN 0>0.3[0] JUL 0>0.3[0]
G4 BLV-FLL JUL 0.1>0.3[0.3]
G4 BLV-JAX JUN 0.1>0.3[0]
G4 BLV-MYR JUN 0>0.4[0] JUL 0.1>0.5[0.3]
G4 BLV-PGD MAR 0.3>0.6[0.3] JUN 0.3>0.8[0] JUL 0.5>0.9[0.6] AUG 0.1>0.4[0.6]
G4 BLV-PIE MAR 0.2>0.5[0.2] JUN 0.4>0.8[0] JUL 0.6>0.9[0.7]
G4 BLV-SFB MAR 0.2>0.5[0.2] MAY 0.1>0.4[0.3] JUN 0.0>0.7[0] JUL 0.1>0.7[0.4] AUG 0.1>0.3[0.4]
G4 BLV-VPS MAR 0.5>0.8[0.5] APR 0.8>1.0[0.9] MAY 0.9>1.1[0.9] JUN 0.8>1.8[0] JUL 1.3>1.9[0.7] AUG 0.5>0.9[1.4]
G4 BMI-SFB MAR 0.1>0.5[0.1] JUN 0>0.4[0]
G4 BNA-CID JUL 0.2>0.4[0.3]
G4 BNA-EYW JUN 0>0.3[0] JUL 0>0.3[0]
G4 BNA-GSO JUN 0>0.3[0] JUL 0>0.3[0]
G4 BOI-LAS APR 0.1>0.3[0.3]
G4 BOI-SNA MAY 0.1>0.3[0]
G4 BWI-PGD JUN 0>0.3[0] JUL 0>0.3[0]
G4 BWI-TYS JUN 0.1>0.3[0]
G4 BZN-LAS APR 0.1>0.3[0.3]
G4 CHA-PIE MAR 0.1>0.3[0.1]
G4 CHS-IND MAR 0.1>0.3[0.1]
G4 CHS-PGD JUN 0>0.3[0]
G4 CHS-SDF JUN 0>0.3[0] JUL 0>0.3[0]
G4 CID-LAS MAR 0.1>0.7[0.1] APR 0.1>0.3[0.7] MAY 0.1>0.3[0.3]
G4 CID-PGD MAR 0.4>0.8[0.4]
G4 CID-SFB MAR 0.2>0.6[0.2] JUL 0.2>0.4[0.3]
G4 CKB-SFB MAR 0.0>0.4[0.0] JUN 0.1>0.4[0] JUL 0.2>0.4[0.3]
G4 CLE-PGD MAR 0.2>0.4[0.2]
G4 CLE-PIE MAR 0>0.3[0]
G4 CLE-SAV JUL 0.8>1.0[0.3]
G4 CVG-FLL MAR 0.8>1.5[0.8] APR 1.1>1.5[1.6] MAY 1.0>1.5[1.6] JUN 1.1>1.7[0] JUL 1.4>1.7[0.8] AUG 0.5>0.8[1.2]
G4 CVG-JAX MAR 0.1>0.4[0.1] JUN 0.1>0.3[0]
G4 CVG-LAS MAY 0.4>0.6[0.6] AUG 0.1>0.3[0.5]
G4 CVG-PGD MAR 1.2>1.8[1.2] APR 1.0>1.4[1.9] MAY 0.8>1.1[1.6] JUN 0.8>1.4[0] JUL 1.0>1.5[0.7] AUG 0.3>0.6[1.0]
G4 CVG-PIE MAR 0.9>1.8[0.9] APR 1.3>1.8[1.9] MAY 1.4>1.7[1.7] JUN 1.0>1.7[0] JUL 1.3>1.7[0.7] AUG 0.3>0.7[1.2]
G4 CVG-SAV MAY 0.4>0.6[0.5] JUN 0.8>1.0[0] JUL 0.6>1.0[0.4]
G4 CVG-SFB MAR 0.7>1.6[0.7] APR 0.7>1.5[1.6] MAY 1.0>1.5[1.5] JUN 1.3>1.5[0] JUL 1.1>1.6[0.8] AUG 0.3>0.7[1.3]
G4 CVG-SRQ JUL 0.7>1.0[0.6]
G4 CVG-VPS MAR 0.5>0.9[0.5] APR 0.8>1.0[0.9] MAY 0.8>1.2[1.0] JUN 1.4>1.9[0] JUL 1.1>2[0.8] AUG 0.7>1.0[1.6]
G4 DEN-PIA JUN 0>0.3[0] JUL 0>0.3[0]
G4 DSM-LAS MAR 0.3>0.8[0.3] APR 0.2>0.6[0.8] MAY 0.3>0.5[0.7] JUN 0.5>0.8[0] JUL 0.6>0.9[0.7]
G4 DSM-PGD MAR 0.5>0.8[0.5] JUN 0.2>0.4[0]
G4 DSM-PIE MAR 0.2>0.6[0.2] JUN 0.3>0.6[0]
G4 DSM-SFB MAR 0.4>0.7[0.4] JUN 0.0>0.5[0] JUL 0.3>0.6[0.7] AUG 0>0.3[0.5]
G4 DSM-VPS JUL 0.1>0.3[0.3]
G4 ELM-PIE MAR 0.2>0.4[0.2] APR 0.2>0.4[0.3] JUN 0.1>0.3[0]
G4 ELM-SFB MAR 0>0.6[0] APR 0.2>0.5[0.7] JUL 0.3>0.7[0.4] AUG 0.1>0.4[0.6]
G4 ELP-LAS JUN 0.1>0.3[0]
G4 ELP-SAN JUN 0.0>0.3[0]
G4 ELP-SFB JUN 0>0.3[0]
G4 EUG-LAS APR 0.1>0.3[0.3]
G4 EUG-OAK APR 0.1>0.3[0.4]
G4 EUG-PSP APR 0>0.2[0]
G4 EYW-SFB JUN 0>0.3[0] JUL 0>0.3[0]
G4 FAR-LAS MAR 0.3>0.8[0.3] APR 0.1>0.5[0.9]
G4 FAT-LAS MAR 0.8>1.7[0.8] APR 1.2>1.6[1.8] MAY 1.1>1.7[1.7] JUN 1.2>1.7[0] JUL 1.3>1.7[0.8] AUG 0.5>0.9[1.6]
G4 FLL-GRR MAR 0>0.3[0]
G4 FLL-IND MAR 0.5>1.2[0.5] APR 0.4>0.7[1.2] MAY 0.4>0.6[0.8] JUN 0.7>1.0[0] JUL 0.7>1.0[0.7]
G4 FLL-LEX JUN 0.2>0.6[0] AUG 0>0.2[0.4]
G4 FLL-MEM JUL 0.5>0.7[0.4]
G4 FLL-PBG MAR 0.3>0.5[0.3] JUL 0.5>0.7[0.3]
G4 FLL-SDF JUN 0.5>0.7[0] JUL 0.3>0.7[0.4]
G4 FLL-TYS MAR 0.5>1.0[0.5] MAY 0.5>0.7[0.8] JUL 0.6>0.9[0.7] AUG 0.1>0.3[0.7]
G4 FLL-USA MAR 1.3>1.7[1.3] APR 1.3>1.6[1.8] MAY 1.2>1.6[1.6] JUN 0.8>1.5[0] JUL 1.2>1.5[0.7] AUG 0.4>0.6[1.2]
G4 FNT-PGD MAR 0.4>1.2[0.4] APR 0.4>0.8[1.4]
G4 FNT-PIE MAR 0.4>1.2[0.4] APR 0.5>0.9[1.2]
G4 FNT-SFB MAR 0.3>1.3[0.3] APR 0.5>0.8[1.3] JUN 0.2>0.6[0] JUL 0.2>0.7[0.4]
G4 FSD-LAS MAR 0.3>0.8[0.3] APR 0.4>0.7[0.9] MAY 0.4>0.5[0.8]
G4 FSD-SFB JUN 0.2>0.4[0] JUL 0.1>0.4[0.4]
G4 FWA-PGD MAR 0.8>1.1[0.8] APR 0.4>0.8[1.3] JUN 0.2>0.6[0] JUL 0.3>0.6[0.4]
G4 FWA-PIE MAR 0.4>0.7[0.4] APR 0.3>0.6[0.8] JUN 0.3>0.6[0]
G4 FWA-SFB MAR 0.1>0.7[0.1] APR 0.2>0.4[0.7] JUN 0.1>0.6[0] JUL 0.1>0.6[0.4] AUG 0>0.2[0.4]
G4 GFK-SFB MAR 0.1>0.3[0.1]
G4 GPT-SFB MAR 0.1>0.3[0.1] JUN 0.1>0.3[0]
G4 GRR-LAS MAR 0.4>0.5[0.4]
G4 GRR-PGD MAR 0.7>1.1[0.7] APR 0.5>0.8[1.3]
G4 GRR-PIE MAR 1.1>1.5[1.1] APR 0.7>1.2[1.7] MAY 0.6>0.9[1.2]
G4 GRR-SFB MAR 1.3>1.8[1.3] APR 0.8>1.5[1.9] MAY 0.7>1.3[1.7] JUN 0.7>1.3[0] JUL 1.1>1.5[0.7] AUG 0.3>0.6[1.2]
G4 GRR-SRQ MAR 0.3>0.6[0.3]
G4 HGR-SFB MAR 0.1>0.3[0.1]
G4 HTS-MYR JUL 0.4>0.5[0.4]
G4 HTS-PIE MAR 0.2>0.5[0.2] JUN 0.8>1.1[0] JUL 0.9>1.2[0.7]
G4 HTS-SFB MAR 0.2>0.7[0.2] APR 0.2>0.5[0.7] MAY 0.2>0.5[0.7] JUN 0.4>0.7[0] JUL 0.5>0.7[0.4]
G4 HTS-VPS JUN 0.2>0.4[0]
G4 IAG-PGD MAR 0.4>1.0[0.4] APR 0.3>0.5[1.1] JUL 0.3>0.6[0.3]
G4 IAG-PIE APR 0.3>0.6[0.5]
G4 IAG-SFB MAR 0.1>0.5[0.1]
G4 ICT-LAX JUL 0.1>0.3[0.3]
G4 ICT-SFB JUL 0.1>0.3[0.3]
G4 IDA-PDX JUN 0>0.3[0] JUL 0>0.3[0]
G4 IND-JAX JUN 0.1>0.3[0]
G4 IND-MYR JUN 0.1>0.3[0]
G4 IND-PGD MAR 0.4>1.1[0.4] APR 0.5>0.7[1.4] JUL 0.5>0.7[0.4]
G4 IND-PIE MAR 0.3>1.3[0.3] APR 0.6>0.9[1.3] JUL 0.8>1.0[0.7]
G4 IND-SFB MAR 0.3>1.2[0.3] APR 0.3>0.5[1.2] JUN 0.3>0.7[0]
G4 IND-SRQ MAR 0.2>0.7[0.2]
G4 JAC-LAS JUN 0>0.3[0] JUL 0>0.3[0]
G4 JAC-LAX JUN 0>0.3[0] JUL 0>0.3[0]
G4 JAC-RNO JUN 0>0.3[0] JUL 0>0.3[0]
G4 JAX-LCK JUN 0>0.3[0] JUL 0.1>0.3[0.3]
G4 LAS-LAX JUL 0.3>0.6[0]
G4 LAS-LRD MAY 0.1>0.3[0.3] JUN 0.1>0.3[0]
G4 LAS-MEM MAR 0.3>0.5[0.3] APR 0.3>0.6[0.6] MAY 0.4>0.6[0.5] JUN 0.4>0.8[0] JUL 0.5>0.9[0.7]
G4 LAS-MFE MAR 0.4>0.7[0.4] APR 0.4>0.7[1.0] MAY 0.4>0.8[1.0] JUN 0.5>1.1[0] JUL 1.0>1.4[0.7] AUG 0.5>0.7[1.2]
G4 LAS-MFR MAR 0.2>0.5[0.2] MAY 0.3>0.5[0.4]
G4 LAS-MOT MAR 0.2>0.6[0.2] APR 0.2>0.4[0.6] JUN 0.4>0.6[0]
G4 LAS-OAK MAR 0.4>0.7[0.4] APR 0.3>0.7[0.8] JUN 0.3>0.5[0]
G4 LAS-OMA MAR 0.1>0.3[0.1]
G4 LAS-PIA MAR 0>0.3[0] APR 0.1>0.3[0.3] MAY 0.1>0.3[0.3]
G4 LAS-PSC MAR 0.1>0.3[0.1]
G4 LAS-RAP APR 0.1>0.3[0.3]
G4 LAS-RFD JUN 0.1>0.3[0]
G4 LAS-RNO MAR 0.6>1.0[0.6] APR 0.7>1.0[1.0] MAY 0.7>1.0[1.0] JUN 0.7>1.0[0] JUL 0.8>1.0[0.8] AUG 0.3>0.5[1.4]
G4 LAS-SAN AUG 0.1>0.3[0.5]
G4 LAS-SBN MAR 0.1>0.3[0.1]
G4 LAS-SCK MAR 0.9>1.7[0.9] APR 0.8>1.6[1.8] MAY 1.0>1.7[1.7] JUN 1.1>1.7[0] JUL 1.4>1.7[0.8] AUG 0.5>0.8[1.6]
G4 LAS-SDF MAR 0.1>0.3[0.1]
G4 LAS-SHV MAR 0.1>0.3[0.1]
G4 LAS-SMX MAY 0.2>0.5[0.4] JUN 0.4>0.7[0]
G4 LAS-XNA JUN 0.1>0.4[0]
G4 LCK-MYR MAY 0.2>0.4[0.2] JUN 0.5>1.1[0] JUL 0.9>1.2[0.7]
G4 LCK-ORF JUN 0>0.3[0] JUL 0>0.3[0]
G4 LCK-PGD MAR 0.2>0.7[0.2] JUN 0.1>0.7[0] JUL 0.4>0.7[0.4]
G4 LCK-PIE MAR 0.3>0.5[0.3] JUN 0.3>0.7[0] AUG 0.1>0.3[0.5]
G4 LCK-SAV JUN 0.4>0.6[0]
G4 LCK-SFB MAR 0.1>0.6[0.1] JUN 0.1>0.7[0] JUL 0.4>0.7[0.5]
G4 LCK-VPS JUN 0.2>0.4[0]
G4 LEX-MYR JUN 0>0.3[0]
G4 LEX-PGD MAR 0.5>0.9[0.5] JUN 0.2>0.6[0] JUL 0.2>0.6[0.4]
G4 LEX-PIE JUN 0.6>0.8[0] JUL 0.6>0.9[0.6]
G4 LEX-SFB MAR 0.2>0.7[0.2] APR 0.3>0.5[0.7] MAY 0.3>0.5[0.6] JUN 0.4>1.0[0] JUL 0.5>1.0[0.7] AUG 0.1>0.4[0.5]
G4 LEX-VPS JUN 0.2>0.4[0]
G4 LIT-SFB JUN 0.0>0.4[0] JUL 0.2>0.4[0.3]
G4 MCI-PGD JUN 0>0.3[0]
G4 MCI-VPS JUN 0.2>0.4[0]
G4 MDT-MYR JUN 0.1>0.4[0]
G4 MDT-PGD MAR 0.2>0.5[0.2]
G4 MDT-PIE MAR 0.2>0.6[0.2] APR 0.2>0.4[0.6]
G4 MDT-SFB MAR 0.2>1.1[0.2] APR 0.6>1.0[1.1] MAY 0.6>0.9[1.0] JUN 0.4>1.1[0] JUL 0.6>1.2[0.7] AUG 0.3>0.5[0.7]
G4 MEM-SFB JUN 0.1>0.4[0] JUL 0.2>0.4[0.3]
G4 MEM-VPS JUN 0.0>0.3[0]
G4 MFE-SFB JUN 0.0>0.7[0] JUL 0.4>0.7[0.4] AUG 0.1>0.3[0.3]
G4 MLI-PIE MAR 0>0.3[0] APR 0.1>0.3[0.5]
G4 MLI-SFB MAR 0.1>0.5[0.1] JUN 0>0.3[0]
G4 MRY-PDX JUN 0>0.3[0] JUL 0>0.3[0]
G4 MSO-OAK JUN 0.1>0.3[0]
G4 MSY-USA MAR 0.1>0.3[0.1]
G4 MYR-PIT JUN 0.3>0.5[0] JUL 0.5>0.7[0.4]
G4 MYR-SDF JUN 0.1>0.3[0]
G4 MYR-TYS JUN 0>0.3[0] JUL 0>0.3[0]
G4 OKC-SFB JUN 0.1>0.3[0]
G4 OKC-VPS JUN 0.4>0.6[0] JUL 0.4>0.6[0.4]
G4 OMA-PIE MAR 0>0.2[0] JUN 0.1>0.3[0]
G4 OMA-SFB JUN 0>0.4[0] JUL 0.2>0.4[0.3]
G4 ORF-PIT JUN 0>0.3[0] JUL 0>0.3[0]
G4 OWB-SFB MAR 0.1>0.3[0.1] JUN 0.2>0.4[0]
G4 PBG-PGD MAR 0.1>0.3[0.1]
G4 PBG-PIE MAR 0.1>0.4[0.1]
G4 PBG-SFB MAR 0.5>1.0[0.5] APR 0.4>0.6[1.2] JUL 0.4>0.6[0.3]
G4 PDX-SMX MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0]
G4 PGD-PIA MAR 0.2>0.9[0.2] APR 0.2>0.4[0.9] JUL 0.2>0.4[0.3]
G4 PGD-PIT JUL 0.4>0.6[0.4]
G4 PGD-PSM APR 0.4>0.7[0.7] MAY 0.2>0.4[0.8]
G4 PGD-PVD JUL 0.3>0.5[0.3]
G4 PGD-RDU MAR 0.1>0.3[0.1]
G4 PGD-RFD MAR 0.5>0.9[0.5]
G4 PGD-ROC MAR 0.1>0.4[0.1]
G4 PGD-SBN MAR 0.3>1.1[0.3] APR 0.2>0.5[1.1]
G4 PGD-SDF MAR 0.3>0.6[0.3] JUL 0.2>0.4[0.3]
G4 PGD-SPI MAR 0.4>0.6[0.4]
G4 PGD-STC MAR 0.1>0.3[0.1]
G4 PGD-TOL MAR 0.2>0.8[0.2] APR 0.1>0.4[0.8]
G4 PGD-TYS MAR 0.2>0.6[0.2] JUL 0.2>0.4[0.4]
G4 PIA-PIE MAR 0.2>0.5[0.2] JUN 0.4>0.6[0]
G4 PIA-SFB MAR 0.2>0.5[0.2] APR 0>0.2[0.5] JUN 0>0.3[0] JUL 0.1>0.3[0.3]
G4 PIA-SRQ JUN 0>0.3[0] JUL 0>0.3[0]
G4 PIE-PIT JUL 0.4>0.6[0.4]
G4 PIE-RFD MAR 0.1>0.6[0.1]
G4 PIE-SBN MAR 0.2>0.6[0.2] JUN 0.1>0.3[0]
G4 PIE-SDF MAR 0.3>0.5[0.3]
G4 PIE-SGF MAR 0.2>0.5[0.2] JUN 0.6>1.0[0] JUL 0.8>1.0[0.7]
G4 PIE-SWF JUN 0.1>0.3[0]
G4 PIE-SYR MAR 0.4>0.8[0.4] JUL 0.5>0.7[0.4]
G4 PIE-TOL MAR 0.3>0.6[0.3]
G4 PIE-TYS MAR 0.6>1.0[0.6] MAY 0.7>1.0[1.0] JUN 0.5>1.2[0] JUL 1.0>1.3[0.7]
G4 PIE-USA MAR 0.4>0.8[0.4] JUN 0.9>1.3[0] JUL 1.0>1.3[0.7]
G4 PIT-SFB MAR 0.3>0.5[0.3] APR 0.1>0.4[0.6]
G4 PIT-SRQ JUL 0.2>0.5[0.4]
G4 PSM-SFB MAR 0.2>0.5[0.2] APR 0.2>0.8[0.5]
G4 PVU-SNA MAY 0.1>0.3[0]
G4 PVU-TUS MAR 0.1>0.3[0.1] APR 0.1>0.3[0.3] MAY 0.1>0.3[0.3]
G4 RDU-SFB MAR 0.1>0.3[0.1]
G4 RFD-SFB MAR 0.3>0.5[0.3] JUN 0.1>0.6[0] JUL 0.1>0.5[0.4]
G4 RIC-SFB JUN 0>0.3[0]
G4 ROA-SFB MAR 0.0>0.4[0.0] JUN 0.2>0.5[0] JUL 0.3>0.5[0.4]
G4 SBN-SFB MAR 0>0.7[0] APR 0.2>0.4[0.7] JUL 0.3>0.6[0.4]
G4 SCE-SFB MAR 0.1>0.3[0.1] JUL 0.1>0.3[0.3]
G4 SDF-SFB MAR 0.2>0.5[0.2] APR 0.2>0.4[0.5] JUN 0.1>0.7[0] JUL 0.3>0.6[0.4]
G4 SFB-SGF MAR 0.2>0.5[0.2] JUN 0.3>0.7[0] JUL 0.3>0.7[0.4]
G4 SFB-SYR JUN 0.0>0.3[0]
G4 SFB-TOL MAR 0.2>0.6[0.2] APR 0.1>0.4[0.6]
G4 SFB-TRI JUN 0>0.3[0]
G4 SFB-TUL MAR 0.1>0.3[0.1] JUN 0.2>0.6[0] JUL 0.2>0.5[0.4]
G4 SFB-TYS MAR 0.8>1.7[0.8] APR 1.2>1.5[1.8] MAY 1.1>1.5[1.5] JUN 1.2>1.7[0] AUG 0.3>0.6[1.1]
G4 SFB-USA MAR 0.3>0.8[0.3] APR 0.4>0.7[0.8] MAY 0.4>0.6[0.8] JUN 0.3>0.9[0] JUL 0.1>0.9[0.7]
G4 SFB-XNA JUN 0>0.6[0] JUL 0.2>0.6[0.4] AUG 0.1>0.3[0.4]
G4 SRQ-TYS JUN 0.0>0.3[0]
G4 SWF-VPS JUL 0>0.3[0]
G4 TYS-VPS JUN 0.1>0.4[0]
G4 VPS-XNA JUN 0.3>0.6[0] JUL 0.5>0.7[0.4]
GV AKN-KLL MAR 0.7>1.6[0.7] APR 0.7>1.6[1.7] MAY 0.7>1.5[1.7] JUN 0.7>1.6[1.6] JUL 0.7>1.5[1.5] AUG 0.7>1.5[1.5] SEP 0.7>1.6[1.6]
GV ANC-ENA MAR 8>10[8] APR 8>10[11] MAY 8>10[10] JUN 8>10[10] JUL 8>10[10] AUG 8>10[10] SEP 8>10[10]
GV AUK-KOT MAR 0.9>1.1[0.9] APR 0.9>1.1[1.9] MAY 0.8>1.2[1.8] JUN 0.9>1.1[1.4] JUL 0.9>1.1[1.8] AUG 0.9>1.1[1.9] SEP 0.9>1.1[1.9]
GV BET-KOT MAR 0.9>1.1[0.9] APR 0.9>1.1[1.9] MAY 0.8>1.2[1.8] JUN 0.9>1.1[1.2] JUL 0.9>1.1[1.8] AUG 0.9>1.1[1.9] SEP 0.9>1.1[1.9]
GV BET-MLL MAR 0>0.4[0] APR 0>0.4[0] MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.5[0] AUG 0>0.4[0] SEP 0>0.4[0]
GV BET-OOK MAR 0.5>0.7[0.5] APR 0.5>0.7[1.0] MAY 0.5>0.7[0.9] JUN 0.5>0.7[1.1] JUL 0.5>0.7[1.1] AUG 0.5>0.7[1.1] SEP 0.5>0.7[1.2]
GV BET-PQS MAR 0>0.4[0] APR 0>0.4[0] MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.5[0] AUG 0>0.4[0] SEP 0>0.4[0]
GV BET-WTL MAY 2>3[1.4] JUL 2>3[1.4] AUG 2>3[1.4]
GV CDB-DUT MAR 0>1.5[0] APR 0>1.3[0] MAY 0>1.5[0] JUN 0>1.5[0] JUL 0>1.5[1.2] SEP 0>1.5[1.4]
GV CDB-NLG MAR 0>0.3[0] APR 0>0.4[0.6] MAY 0>0.3[0.4] JUN 0>0.3[0.4] JUL 0>0.4[0.3] SEP 0>0.4[0.3]
GV CLP-DLG MAR 0>0.5[0] APR 0>0.4[1.0] MAY 0>0.4[0.9] JUN 0>0.4[0.7] JUL 0>0.4[0.9] AUG 0>0.4[0.9] SEP 0>0.4[0.9]
GV CLP-KMO MAR 0>0.5[0] APR 0>0.4[1.0] MAY 0>0.4[0.9] JUN 0>0.4[0.7] JUL 0>0.4[0.9] AUG 0>0.4[0.9] SEP 0>0.4[0.9]
GV DLG-KEK MAR 0>0.6[0] APR 0>0.6[1.5] MAY 0>0.6[1.4] JUN 0>0.6[1.1] JUL 0>0.6[1.4] AUG 0>0.5[1.4] SEP 0>0.6[1.4]
GV DLG-KMO MAR 0>0.5[0] APR 0>0.4[1.8] MAY 0.8>1.4[1.9] JUN 0.9>1.4[1.3] JUL 0.9>1.4[1.9] AUG 0.8>1.4[1.9] SEP 0.9>1.4[1.9]
GV DLG-KNW MAR 0>0.6[0] APR 0>0.6[1.6] MAY 0>0.6[1.4] JUN 0>0.6[1.1] JUL 0>0.6[1.4] AUG 0>0.5[1.4] SEP 0>0.6[1.4]
GV DLG-TOG MAR 0>0.4[0] APR 0>0.4[1.0] MAY 0>0.4[1.0] JUN 0>0.4[0.7] JUL 0>0.5[1.0] AUG 0>0.4[1.0] SEP 0>0.4[1.0]
GV DLG-TWA MAR 0>0.4[0] APR 0>0.4[1.0] MAY 0>0.4[1.0] JUN 0>0.4[0.7] JUL 0>0.5[1.0] AUG 0>0.4[1.0] SEP 0>0.4[1.0]
GV DUT-KQA MAR 0.9>1.7[0.9] APR 0.9>1.7[1.7] MAY 0.8>1.7[1.7] JUN 0.9>1.7[1.7] JUL 0.9>1.7[1.7] AUG 0.8>1.7[1.7] SEP 0.9>1.7[1.7]
GV DUT-STG MAR 0>0.4[0] JUL 0>0.5[0.3] AUG 0>0.4[0.3] SEP 0>0.4[0.3]
GV KEK-KNW MAR 0>0.6[0] APR 0>0.6[1.5] MAY 0>0.6[1.4] JUN 0>0.6[1.1] JUL 0>0.6[1.4] AUG 0>0.5[1.4] SEP 0>0.6[1.4]
GV MLL-PQS MAR 0>0.4[0] APR 0>0.4[0] MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.5[0] AUG 0>0.4[0] SEP 0>0.4[0]
GV SNP-STG MAR 0>0.4[0] JUL 0>0.5[0.3] AUG 0>0.4[0.3] SEP 0>0.4[0.3]
GV TOG-TWA MAR 0>0.4[0] APR 0>0.4[1.0] MAY 0>0.4[1.0] JUN 0>0.4[0.7] JUL 0>0.5[1.0] AUG 0>0.4[1.0] SEP 0>0.4[1.0]
HA HNL-PPG MAR 0.3>0[0.3] APR 0.3>0[0.2]
HI GCN-GCW MAR 0>0.7[0]
HZ RZH-VVO MAY 0.4>0.7[0] JUN 0.4>0.7[0] JUL 0.5>0.7[0] AUG 0.4>0.7[0] SEP 0.4>0.7[0.7]
J5 JNU-KAE MAR 1.0>1.3[1.0]
J5 JNU-PEC MAR 0>0.7[0] APR 0>0.7[0.9] MAY 0>0.7[0.8] JUN 0>0.7[1.7] JUL 0>0.7[0.5] AUG 0>0.7[2] SEP 0>0.7[0]
J5 JNU-PSG APR 0>1.7[0] MAY 0>2[0] JUN 0>2[0] JUL 0>2[0] AUG 0>2[0] SEP 0>2[0]
J5 JNU-SIT MAR 1.6>2[1.6]
JL HND-HNL MAR 0.8>0.1[0.8] APR 2>1.1[0.3]
JL HNL-KIX MAR 0.4>0[0.4] APR 1.0>0.5[1.0]
JL HNL-NGO MAR 0.4>0[0.4] APR 1.0>0.5[1.0]
JL HNL-NRT MAR 0.7>0[0.7] APR 2>1.0[4]
JL KOA-NRT MAR 0.4>0[0.4] APR 1.0>0.5[1.0]
JN MCG-NIB MAR 0>0.3[0] APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0]
JN MRI-NIB MAR 0>0.3[0] APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0]
JN MRI-TEK MAR 0>0.2[0] APR 0>0.2[0] MAY 0>0.2[0] JUN 0>0.2[0] JUL 0>0.2[0] AUG 0>0.2[0] SEP 0>0.2[0]
JN TCT-TLI MAR 0>0.3[0] APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0]
JQ HNL-MEL MAR 0.4>0[0.4]
JQ HNL-SYD MAR 0.5>0[0.5]
K2 BET-PQS MAR 0>0.4[0] APR 0>0.4[0] MAY 0>0.3[0] JUN 0>0.4[0.2] JUL 0>0.4[0.2] AUG 0>0.4[0.2] SEP 0>0.4[0.2]
K2 BET-RSH MAR 0>0.4[0] APR 0>0.4[0] MAY 0>0.3[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0]
K2 MLL-PQS MAR 0>0.4[0] APR 0>0.4[0] MAY 0>0.3[0] JUN 0>0.4[0.2] JUL 0>0.4[0.2] AUG 0>0.4[0.2] SEP 0>0.4[0.2]
K2 MLL-RSH MAR 0>0.4[0] APR 0>0.4[0] MAY 0>0.3[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0]
K3 CGA-KLW MAR 0>1.7[0] APR 0>1.7[1.5] MAY 0>1.7[1.3] JUN 0>1.7[1.3] JUL 0>1.7[1.3] AUG 0>1.7[1.3] SEP 0>1.7[1.3]
K3 CGA-KTB MAR 0>1.7[0] APR 0>1.7[0.6] MAY 0>1.7[0.5] JUN 0>1.7[0.5] JUL 0>1.7[0.5] AUG 0>1.7[0.5] SEP 0>1.7[0.5]
K3 KLW-KTN MAR 0>0.9[0] APR 0>0.9[0.6] MAY 0>0.8[0.5] JUN 0>0.9[0.5] JUL 0>0.9[0.5] AUG 0>0.8[0.5] SEP 0>0.9[0.5]
K3 KTB-KTN MAR 0>0.9[0] APR 0>0.9[1.3] MAY 0>0.8[1.3] JUN 0>0.9[1.3] JUL 0>0.9[1.3] AUG 0>0.8[1.3] SEP 0>0.9[1.3]
KE BOS-ICN MAR 0.7>0.5[0.7]
KE HNL-ICN MAR 1.0>0.1[1.0]
KE HNL-NRT MAR 1.0>0.1[1.0]
KE IAD-ICN MAR 1.0>0.6[1.0]
KE ICN-JFK MAR 2.0>1.1[2.0]
KE ICN-LAS MAR 0.7>0.1[0.7]
KE ICN-ORD MAR 1.0>0.5[1.0]
KE ICN-SEA MAR 0.7>0.5[0.7]
KE ICN-SFO MAR 2>0.9[2]
KG AIA-DEN MAR 1.3>1.7[1.3] APR 1.3>1.7[1.8] MAY 1.3>1.7[1.7]
KG DEN-TEX APR 0.8>1.2[1.7]
LF BNA-TUP MAR 1.5>2.0[1.5]
LF PGA-PHX MAY 0>1.1[1.0] JUN 0>1.8[1.2] JUL 0>2[1.9] AUG 0>2[1.7] SEP 0>2[1.6]
LO JFK-WAW MAR 0.7>0.4[0.7]
LO ORD-WAW MAR 0.7>0.5[0.7]
LY BOS-TLV MAR 0.4>0.1[0.4]
LY JFK-TLV MAY 2>3[0.6] JUN 2>3[0.9] JUL 2>3[3] AUG 2>3[3] SEP 1.4>1.9[3]
LY ORD-TLV MAR 0.4>0.1[0.4]
LY SFO-TLV MAR 0.4>0.1[0.4]
M5 BFI-FRD MAR 0.9>1.1[0.9] MAY 0>0.3[1.5]
M5 ESD-FRD MAR 0>0.2[0]
NH HND-HNL MAR 1.0>0.3[1.0] APR 1.0>0.5[1.0]
NH HND-IAD MAR 1.0>0.5[1.0] APR 1.0>0.6[0.1]
NH HND-IAH MAR 1.0>0.4[1.0] APR 1.0>0.7[0.1]
NH HND-JFK MAR 1.0>0.6[1.0] APR 1.0>0.7[1.0]
NH HND-LAX MAR 2>1.0[2] APR 2>1.4[1.1]
NH HND-ORD MAR 1.0>0[1.0] APR 1.0>0.4[1.0]
NH HND-SEA MAR 1.0>0.1[1.0] APR 1.0>0.4[0.1]
NH HND-SFO MAR 1.0>0.4[1.0] APR 1.0>0.6[0.0]
NH HND-SJC MAR 1.0>0[1.0] APR 1.0>0.4[0.1]
NH HNL-NRT MAR 2>0[2] APR 2>0.8[2]
NH JFK-NRT MAR 1.0>0[1.0] APR 1.0>0.4[1.0]
NH LAX-NRT MAR 1.0>0.6[1.0] APR 1.0>0.7[2.0]
NH NRT-SFO MAR 1.0>0[1.0] APR 1.0>0.4[1.0]
NK LAS-SNA MAR 1.9>0.5[1.9]
NK LAX-SJD MAR 0.9>0[0.9]
NK OAK-SNA MAR 1.7>0[1.7] APR 2>1.0[0] MAY 2>1.0[0] JUN 2>1.0[0] JUL 2>1.0[0] AUG 2>1.0[0] SEP 0.5>0.2[0]
NK PHX-SNA MAR 1.0>0[1.0] APR 0.7>1.0[0] MAY 0.5>1.0[0]
NK SMF-SNA MAR 1.0>0[1.0]
OZ ICN-JFK MAR 2.0>0.8[2.0]
OZ ICN-LAX MAR 2>1.4[2]
OZ ICN-SEA MAR 0.9>0.5[0.9]
OZ ICN-SFO MAR 1.0>0.6[1.0]
PD BOS-YTZ MAR 0>0.3[0] APR 4>5[4] MAY 3>5[0] JUN 5>6[0] SEP 4>6[6]
PD EWR-YTZ MAR 0>0.7[0] APR 8>10[9] MAY 7>11[0] JUN 11>12[0] SEP 8>11[11]
PD IAD-YTZ APR 2>3[1.4] MAY 1.6>3[0] SEP 2>3[3]
PD MDW-YTZ MAR 0>0.2[0] MAY 3>5[0] JUN 4>5[0] SEP 4>5[5]
PY GEO-MIA MAR 0.1>0.4[0.1]
Q5 FAI-HKB MAR 0>0.7[0] APR 0>0.7[0.4] MAY 0>0.6[0.4] JUN 0>0.7[0.4] JUL 0>0.6[0.4] AUG 0>0.6[0.4] SEP 0>0.7[0]
Q5 HKB-TKJ MAR 0>0.2[0] APR 0>0.2[0.4] MAY 0>0.2[0.4] JUN 0>0.2[0.4] JUL 0>0.2[0.4] AUG 0>0.2[0.4] SEP 0>0.2[0]
RJ AMM-ORD MAR 0.7>0.5[0.7]
SK ARN-EWR MAR 1.0>0.1[1.0]
SK ARN-MIA MAR 0.4>0.1[0.4]
SK ARN-ORD MAR 1.0>0.1[1.0]
SK BOS-CPH MAR 0.9>0.1[0.9]
SK CPH-IAD MAR 1.0>0.5[1.0]
SK CPH-LAX MAR 1.0>0.1[1.0]
SK CPH-MIA MAR 0.5>0.1[0.5]
SK CPH-SFO MAR 1.0>0.5[1.0]
SK EWR-OSL MAR 1.0>0.1[1.0]
SU JFK-SVO MAR 0.8>0.5[0.8] APR 3>0.6[2]
SU LAX-SVO APR 1.0>0.3[1.0]
SU MIA-SVO APR 0.6>0.3[0.7]
SV JED-JFK APR 0.6>0.2[0.6] MAY 0.6>0.4[0.6]
SV JFK-RUH APR 0.4>0.2[0.5]
**SY BDL-MSP JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0]
SY BNA-LAX JUN 0.3>0.1[0.2]
SY BNA-MSP SEP 0>0.5[0.4]
SY BWI-MSP SEP 0>0.6[0.5]
SY BZN-MSP SEP 0>0.2[0.3]
SY CUN-DFW AUG 1.0>1.4[1.3]
**SY CUN-IAH JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0]
**SY CUN-SAT JUN 0>0.3[0] JUL 0>0.3[0]
**SY CVG-MSP MAY 0>0.2[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0]
SY DFW-LAS SEP 0>0.6[0.3]
SY DFW-MSP SEP 0>0.4[0.3]
**SY DFW-PVR JUN 0>0.3[0] JUL 0>0.3[0]
SY DFW-SNA MAY 0>0.3[0]
**SY FCA-MSP JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0]
**SY IAH-MSP MAY 0>0.2[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0]
**SY IND-MSP JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0]
**SY JAC-MSP JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0]
SY MSP-ORD SEP 0>0.6[0.5]
SY MSP-PDX AUG 0.8>1.0[1.0] SEP 0>0.6[0.8]
SY MSP-PHX AUG 0.6>0.8[0.8] SEP 0>1.0[1.1]
**SY MSP-RDU MAY 0>0.2[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0]
SY MSP-SAN SEP 0>0.4[0.5]
SY MSP-SEA AUG 1.6>2[2] SEP 0>1.0[1.3]
SY MSP-SFO AUG 1.3>1.6[1.7] SEP 0>1.0[1.2]
**SY MSP-SNA MAY 0>0.5[0] JUN 0>0.5[0] JUL 0>0.6[0] AUG 0>0.6[0] SEP 0>0.6[0]
TI CXY-FLL MAR 0>0.4[0]
TJ ACK-HPN APR 0>0.6[0] MAY 0>1.3[0.6] JUL 0>5[1.7] SEP 0>2[3]
TJ ACK-TEB APR 0>0.4[0] MAY 0>1.1[0.4] JUN 0>1.4[1.6] JUL 0>3[1.3] AUG 0>3[4] SEP 0>1.7[2]
TJ HPN-MVY MAY 0>0.3[0] JUN 0>1.4[0.7] JUL 0>1.8[1.2] AUG 0>1.8[2] SEP 0>0.8[0.9]
TJ MVY-TEB MAY 0>0.3[0] JUN 0>1.0[0.5] JUL 0>1.5[0.9] AUG 0>1.5[1.7] SEP 0>0.6[0.7]
UA ABE-ORD MAR 2>0.8[2]
UA ABQ-DEN MAR 4>2[4]
UA ABQ-IAH MAR 4>2[4]
UA ABQ-SFO MAR 1.7>0.7[1.6]
UA ACA-IAH MAR 0.5>0.9[0.5]
UA ACV-DEN MAR 0.8>0[0.8]
UA ACV-LAX MAR 1.9>0.9[1.9]
UA ACV-SFO MAR 3>1.7[2]
UA AEX-IAH MAR 3>1.5[2]
UA AGU-IAH MAR 1.9>1.0[1.9]
*UA AKL-SFO APR 1.0>0[1.0] MAY 1.0>0[0] JUN 1.0>0[0]
UA ALB-EWR MAR 3>1.0[3]
UA ALB-IAD MAR 3>1.9[3]
UA ALB-ORD MAR 4>1.1[4]
UA AMA-DEN MAR 1.8>1.0[1.8]
UA AMS-EWR MAR 0.9>0.7[0.9]
UA AMS-IAH MAR 0.9>0[0.9]
UA AMS-ORD MAR 0.9>0[0.9]
*UA ANU-EWR MAR 0.2>0[0.2] APR 0.4>0[0.4] MAY 0.2>0[0.1]
UA ASE-DEN MAR 8>6[8]
UA ASE-IAH APR 0>0.2[3]
UA ASE-ORD MAR 4>2[4] APR 0>0.3[5]
UA ASE-SFO MAR 1.6>1.3[1.6] APR 0>0.2[1.9]
UA ATL-DEN MAR 4>3[4]
UA ATL-EWR MAR 7>3[7]
UA ATL-IAD MAR 3>1.9[3]
UA ATL-IAH MAR 7>4[7]
UA ATL-ORD MAR 7>3[7]
UA ATL-SFO MAR 1.8>0[1.8]
UA ATW-DEN MAR 0.9>0.1[0.9]
UA ATW-ORD MAR 9>5[9]
UA ATY-ORD MAR 0.9>0.7[0.9]
UA AUS-DEN MAR 5>4[5]
UA AUS-EWR MAR 5>1.8[5]
UA AUS-IAD MAR 3>1.0[3]
UA AUS-IAH MAR 8>5[8] APR 9>10[9] MAY 9>10[8] JUN 9>10[9] JUL 9>10[1.9] AUG 9>10[9] SEP 9>10[8]
UA AUS-ORD MAR 4>1.7[4]
UA AUS-SFO MAR 4>1.5[4]
UA AVL-EWR MAR 0.9>0[0.9]
UA AVL-IAD MAR 3>1.7[3]
UA AVL-ORD MAR 4>1.5[3]
UA AVP-ORD MAR 1.7>1.0[1.5]
UA AZO-ORD MAR 3>1.0[3]
UA BDL-DEN MAR 1.9>1.0[1.9]
UA BDL-IAD MAR 4>1.9[4]
UA BDL-IAH MAR 1.8>0[1.8]
UA BDL-ORD MAR 3>1.9[3]
UA BFL-DEN MAR 1.6>1.0[1.6]
UA BFL-SFO MAR 0.9>0.7[0.8]
UA BGR-EWR MAR 1.8>0[1.8]
UA BHM-ORD MAR 3>1.0[3]
UA BIS-ORD MAR 1.8>0[1.8]
UA BJX-IAH MAR 4>3[4]
UA BNA-DEN MAR 5>3[5]
UA BNA-EWR MAR 5>1.9[5]
UA BNA-IAD MAR 3>1.9[3]
UA BNA-IAH MAR 5>4[5]
UA BNA-ORD MAR 6>4[6]
UA BNA-SFO MAR 1.7>0[1.7]
UA BOG-EWR MAR 1.0>0.6[1.0]
UA BOG-IAH MAR 1.9>1.1[1.9]
UA BOI-DEN MAR 5>4[5]
UA BOI-IAH MAR 1.9>1.0[1.9]
UA BOI-LAX MAR 1.8>1.0[1.8]
UA BOI-ORD MAR 3>2[3]
UA BOI-SFO MAR 5>3[5]
UA BOS-EWR MAR 11>3[11]
UA BOS-FLL MAR 0.9>0.6[0.9]
UA BOS-IAD MAR 4>1.9[4]
UA BOS-IAH MAR 4>2[4]
UA BOS-LAX MAR 1.8>0[1.8]
UA BOS-MCO MAR 0.9>0.6[0.9]
UA BOS-ORD MAR 7>3[7]
UA BOS-RSW MAR 0.9>0.6[0.9]
UA BOS-SFO MAR 6>0.6[6]
UA BOS-TPA MAR 0.9>0[0.9]
UA BQN-EWR MAR 0.6>0[0.6]
UA BRU-EWR MAR 0.9>0.4[0.9]
UA BTR-IAH MAR 6>4[5]
UA BTV-EWR MAR 3>0.6[3]
UA BTV-IAD MAR 4>1.9[4]
UA BTV-ORD MAR 4>1.7[4]
UA BUF-EWR MAR 4>1.7[4]
UA BUF-IAD MAR 3>1.9[3]
UA BUF-ORD MAR 3>1.1[3]
UA BUR-DEN MAR 3>1.0[3]
UA BUR-SFO MAR 5>0[5]
UA BWI-DEN MAR 1.9>1.5[1.9]
UA BWI-LAX MAR 0.9>0[0.9]
UA BWI-ORD MAR 4>3[4]
UA BWI-SFO MAR 1.6>0[1.6]
UA BZE-IAH MAR 2>1.3[2]
UA CAE-IAD MAR 3>1.9[3]
UA CAE-IAH MAR 0.8>0[0.8]
UA CAE-ORD MAR 3>1.1[2]
UA CAK-IAD MAR 3>1.1[3]
UA CAK-IAH MAR 0.9>0[0.9]
UA CAK-ORD MAR 4>1.6[3]
UA CDG-EWR MAR 0.9>0.5[0.9]
UA CHA-ORD MAR 4>1.0[4]
UA CHO-IAD MAR 3>1.9[3]
UA CHO-ORD MAR 3>0.1[2]
UA CHS-EWR MAR 4>2[4]
UA CHS-IAH MAR 3>2[3]
UA CHS-ORD MAR 3>1.7[3]
UA CID-DEN MAR 4>2[4]
UA CID-ORD MAR 7>3[6]
UA CLE-DEN MAR 3>1.9[3]
UA CLE-EWR MAR 7>3[7]
UA CLE-IAD MAR 4>1.9[4]
UA CLE-IAH MAR 5>2[5]
UA CLE-LAX MAR 1.7>0[1.7]
UA CLE-ORD MAR 8>3[8]
UA CLE-SFO MAR 1.8>0[1.8]
UA CLL-IAH MAR 2>1.4[2]
UA CLT-EWR MAR 5>3[5]
UA CLT-IAD MAR 3>1.9[3]
UA CLT-IAH MAR 4>3[4]
UA CLT-ORD MAR 4>3[4]
UA CMH-EWR MAR 7>1.9[7]
UA CMH-IAD MAR 3>1.9[3]
UA CMH-IAH MAR 4>2[4]
UA CMH-ORD MAR 7>3[7]
UA CMH-SFO MAR 0.9>0[0.9]
UA COD-DEN MAR 1.5>1.0[1.7]
UA COS-DEN MAR 8>6[8]
UA COS-IAH MAR 3>2.0[3]
UA COS-LAX MAR 1.6>1.0[1.7]
UA COU-DEN MAR 0.9>0[0.9]
UA COU-ORD MAR 3>1.0[3]
UA CPR-DEN MAR 6>3[6]
UA CRP-IAH MAR 6>4[5]
UA CRW-ORD MAR 3>1.5[2]
UA CTU-SFO MAR 0.4>0[0.4]
UA CUN-IAD MAR 3>1.0[3]
UA CUN-LAX MAR 2.0>1.1[2.0]
UA CUN-SFO MAR 3>1.3[3]
UA CVG-EWR MAR 4>1.7[4]
UA CVG-IAD MAR 3>1.9[3]
UA CVG-ORD MAR 6>3[6]
UA CWA-ORD MAR 3>1.0[2]
UA DAY-DEN MAR 1.7>0[1.7]
UA DAY-IAD MAR 2>1.7[3]
UA DAY-ORD MAR 6>5[6]
UA DCA-EWR MAR 11>1.5[11]
UA DCA-IAH MAR 7>3[7]
UA DCA-ORD MAR 12>3[12]
UA DCA-SFO MAR 0.9>0[0.9]
UA DEN-DFW MAR 6>5[6]
UA DEN-DRO MAR 7>6[7]
UA DEN-DSM MAR 6>4[6]
UA DEN-EAR MAR 1.7>1.0[1.7]
UA DEN-ECP MAR 0.7>0.5[0.7] APR 0>1.0[0.1]
UA DEN-ELP MAR 4>3[4]
UA DEN-FAT MAR 4>3[4]
UA DEN-FCA MAR 2>3[2]
UA DEN-FLG MAR 1.8>1.1[1.8]
UA DEN-FRA MAR 0.9>0.7[0.9]
UA DEN-FSD MAR 4>2[4]
UA DEN-GEG MAR 3>2[3]
UA DEN-GJT MAR 6>4[6]
UA DEN-GSP MAR 0.9>0[0.9]
UA DEN-HLN MAR 1.7>1.0[1.7]
UA DEN-HSV MAR 1.9>1.0[1.9]
UA DEN-IAD MAR 6>5[6]
UA DEN-IAH MAR 10>8[10]
UA DEN-ICT MAR 4>3[4]
UA DEN-IND MAR 3>2[3]
UA DEN-LAS MAR 6>5[6]
UA DEN-LAX MAR 7>5[7]
UA DEN-LBB MAR 1.7>1.0[1.7]
UA DEN-LGA MAR 7>3[7]
UA DEN-LHR MAR 0.9>0[0.9]
UA DEN-LIH MAR 0.9>0.5[0.9]
UA DEN-LIT MAR 3>2.0[3]
UA DEN-LNK MAR 3>1.0[3]
UA DEN-MAF MAR 4>2[4]
UA DEN-MCI MAR 5>4[5]
UA DEN-MCO MAR 5>4[5]
UA DEN-MEM MAR 3>2.0[3]
UA DEN-MOT MAR 3>2[3]
UA DEN-MRY MAR 1.7>1.0[1.7]
UA DEN-MSN MAR 4>2[4]
UA DEN-MSP MAR 4>2[4]
UA DEN-MSY MAR 3>2[3]
UA DEN-NRT MAR 0.9>0[0.9]
UA DEN-OKC MAR 6>3[6]
UA DEN-OMA MAR 5>4[5]
UA DEN-ONT MAR 3>1.0[3]
UA DEN-ORD MAR 9>7[9]
UA DEN-PAE MAR 3>1.0[3]
UA DEN-PBI MAR 0.8>0.6[0.8]
UA DEN-PDX MAR 5>3[5]
UA DEN-PHL MAR 3>2[3]
UA DEN-PIT MAR 3>2[3]
UA DEN-PNS MAR 0.8>0.5[0.8]
UA DEN-PSC MAR 3>2[3]
UA DEN-RAP MAR 6>3[6]
UA DEN-RDM MAR 3>1.9[3]
UA DEN-RIC MAR 1.9>0.8[1.9]
UA DEN-RIW MAR 1.5>1.9[1.5]
UA DEN-SAF MAR 4>1.0[4]
UA DEN-SAT MAR 4>3[4]
UA DEN-SBA MAR 4>1.7[4]
UA DEN-SBP MAR 3>1.7[3]
UA DEN-SDF MAR 1.7>1.0[1.7]
UA DEN-SEA MAR 6>4[6]
UA DEN-SFO MAR 8>5[8]
UA DEN-SHV MAR 0.9>0[0.9]
UA DEN-SJC MAR 4>2[4]
UA DEN-SLN MAR 0.9>0.7[0.9]
UA DEN-SMF MAR 5>4[5]
UA DEN-SNA MAR 4>2[4]
UA DEN-STL MAR 5>3[5]
UA DEN-SYR MAR 0.8>0.1[0.8]
UA DEN-VPS MAR 0.8>0.5[0.8]
UA DEN-XNA MAR 3>1.1[3]
UA DEN-XWA MAR 3>2[3]
UA DEN-YVR MAR 1.8>0.4[1.8]
UA DEN-YYC MAR 3>1.7[3]
UA DEN-YYZ MAR 0.3>0[0.3]
UA DFW-EWR MAR 6>2[6]
UA DFW-IAD MAR 3>1.0[3]
UA DFW-IAH MAR 7>5[7]
UA DFW-ORD MAR 7>3[7]
UA DFW-SFO MAR 3>0.9[3]
UA DLH-ORD MAR 3>1.5[3]
UA DSM-IAH MAR 3>1.7[3]
UA DSM-ORD MAR 5>3[5]
UA DTW-EWR MAR 6>3[6]
UA DTW-IAD MAR 3>1.9[3]
UA DTW-IAH MAR 4>3[4]
UA DTW-ORD MAR 7>3[6]
UA DTW-SFO MAR 0.9>0[0.9]
UA DUB-EWR MAR 1.0>0.6[1.0]
UA ECP-IAH MAR 1.8>3[1.8]
UA ECP-ORD MAR 0>0.6[0] APR 0>1.0[0.1]
UA EGE-SFO MAR 0.9>0.7[0.9]
UA ELP-ORD MAR 0.9>0[0.9]
UA ERI-ORD MAR 3>0.1[2]
UA EUG-LAX MAR 1.8>0.7[1.8]
UA EUG-ORD MAR 0.9>0[0.9]
UA EUG-SFO MAR 3>1.7[3]
UA EVV-ORD MAR 3>1.0[2]
UA EWR-EYW MAR 1.8>3[1.8]
UA EWR-FCO MAR 0.9>0[0.9]
UA EWR-FLL MAR 7>5[7]
UA EWR-GCM MAR 0.9>0[0.9]
UA EWR-GRR MAR 3>0[3]
UA EWR-GSO MAR 3>0[3] APR 3>4[4]
UA EWR-GSP MAR 2>0[2]
UA EWR-HKG MAR 0.2>0[0.2]
UA EWR-HND MAR 0.9>0[0.9]
UA EWR-HNL MAR 0.9>0.1[0.9]
UA EWR-IAD MAR 6>3[6]
UA EWR-IAH MAR 8>6[8]
UA EWR-IND MAR 6>3[6]
UA EWR-JAX MAR 4>3[4]
UA EWR-LAS MAR 5>3[6]
UA EWR-LAX MAR 11>3[11]
UA EWR-LHR MAR 3>1.0[3]
UA EWR-LIR MAR 1.0>0.4[1.0]
UA EWR-MBJ MAR 1.9>1.5[1.9]
UA EWR-MCI MAR 4>1.0[4]
UA EWR-MCO MAR 10>5[10]
UA EWR-MEM MAR 3>0[3]
UA EWR-MEX MAR 3>2[3]
UA EWR-MIA MAR 5>4[5]
UA EWR-MKE MAR 4>0[4]
UA EWR-MSN MAR 1.6>0[1.6]
UA EWR-MSP MAR 5>1.0[5]
UA EWR-MSY MAR 4>1.6[4]
UA EWR-MUC MAR 0.7>0[0.7]
UA EWR-MXP MAR 0.9>0[0.9]
UA EWR-NAS MAR 1.9>0.9[1.9]
UA EWR-NRT MAR 1.0>0.7[1.0]
UA EWR-OKC MAR 0.9>0[0.9]
UA EWR-OMA MAR 1.7>0[1.7]
UA EWR-ORD MAR 11>4[10]
UA EWR-ORF MAR 5>2[5]
UA EWR-PBI MAR 7>5[7]
UA EWR-PDX MAR 1.8>0[1.8]
UA EWR-PEK MAR 0.9>0[0.9]
UA EWR-PHX MAR 4>2[4]
UA EWR-PIT MAR 9>3[9]
UA EWR-POP MAR 0.9>0.5[0.9]
UA EWR-PQI MAR 0.6>0.3[0.6]
UA EWR-PTY MAR 1.4>1.0[1.4]
UA EWR-PVD MAR 4>1.0[4]
UA EWR-PVG MAR 0.9>0[0.9]
UA EWR-PVR MAR 0.8>0.1[0.8]
UA EWR-PWM MAR 6>1.9[6]
UA EWR-RDU MAR 7>3[7]
UA EWR-RIC MAR 6>1.5[6]
UA EWR-ROC MAR 3>1.5[4]
UA EWR-RSW MAR 5>4[5]
UA EWR-SAN MAR 4>2[4]
UA EWR-SAP MAR 0.9>0.5[0.9]
UA EWR-SAT MAR 1.7>0[1.7]
UA EWR-SAV MAR 4>2[4]
UA EWR-SDF MAR 2>0[2.0]
UA EWR-SEA MAR 3>0.5[3]
UA EWR-SFO MAR 13>3[13]
UA EWR-SJD MAR 0.8>0.5[0.8]
UA EWR-SJO MAR 1.9>1.0[1.9]
UA EWR-SJU MAR 3.7>1.9[3.7]
UA EWR-SMF MAR 0.9>0[0.9]
UA EWR-SNA MAR 2>0[2]
UA EWR-SRQ MAR 3>1.7[3]
UA EWR-STL MAR 4>1.5[4]
UA EWR-SYR MAR 1.7>0.6[1.8]
UA EWR-TLV MAR 1.9>1.5[1.9]
UA EWR-TYS MAR 0.5>0[0.5]
UA EWR-XNA MAR 0.6>0[0.6]
UA EWR-YHZ MAR 0.4>0[0.4]
UA EWR-YQB MAR 0.4>0[0.4]
UA EWR-YUL MAR 0.4>0[0.4]
UA EWR-YYZ MAR 0.4>0[0.4]
UA EYW-IAD MAR 0.9>1.2[0.9]
UA EYW-ORD MAR 0.9>1.4[0.8]
UA EZE-IAH MAR 1.0>0.7[1.0]
UA FAR-ORD MAR 3>1.1[3]
UA FAT-LAX MAR 3>1.7[3]
UA FAT-ORD MAR 0.9>0[0.9]
UA FAT-SFO MAR 3>1.7[3]
UA FLL-LGA MAR 0.9>0.7[0.9]
UA FLL-SFO MAR 0.9>0[0.9]
UA FNT-ORD MAR 3>1.5[2]
UA FSD-ORD MAR 4>3[4]
UA FWA-ORD MAR 3>1.5[3]
UA GCM-IAD MAR 0.8>0[0.8]
UA GCM-IAH MAR 0.9>0[0.9]
UA GEG-ORD MAR 0.9>0[0.9]
UA GEG-SFO MAR 3>0.7[2]
UA GIG-IAH MAR 1.0>0.6[1.0]
UA GPT-IAH MAR 4>2[4]
UA GRB-ORD MAR 4>3[4]
UA GRR-IAH MAR 0.9>0[0.9]
UA GRR-ORD MAR 6>3[6]
UA GSO-IAD MAR 3>1.7[3]
UA GSO-ORD MAR 3>0.9[3]
UA GSP-IAD MAR 3>1.9[3]
UA GUA-IAD MAR 1.0>0.7[1.0]
UA GUA-IAH MAR 3>2[3]
UA GUA-LAX MAR 1.4>0.8[1.4]
UA HDN-LAX MAR 0.5>0.3[0.5]
UA HKG-SFO MAR 1.1>0[1.1]
UA HND-LAX MAR 0.9>0[0.9]
UA HND-ORD MAR 0.9>0[0.9]
UA HND-SFO MAR 0.9>0[0.9]
UA HNL-LAX MAR 4>2[4]
UA HNL-MAJ MAR 0.4>0.0[0.4]
UA HNL-NRT MAR 0.9>0[0.9]
UA HNL-SFO MAR 4>3[4]
UA HOB-IAH MAR 1.7>0.6[1.7]
UA HPN-ORD MAR 2>0[2]
UA HRL-IAH MAR 4>3[4] JUL 4>5[1.5]
UA HSV-IAD MAR 3>1.9[3]
UA HSV-IAH MAR 3>1.7[3]
UA HSV-ORD MAR 3>0.1[3]
UA IAD-ILM MAR 3>1.9[3]
UA IAD-IND MAR 3>1.9[3]
UA IAD-ITH MAR 0.5>0[0.5]
UA IAD-JAX MAR 3>1.9[3]
UA IAD-JST MAR 0.6>0.9[0.6]
UA IAD-LAS MAR 3>1.7[3]
UA IAD-LAX MAR 6>3[6]
UA IAD-LEX MAR 1.8>0[1.8]
UA IAD-LGA MAR 4>1.9[4]
UA IAD-LHR MAR 1.3>0.7[1.3]
UA IAD-LWB MAR 0.5>0.1[0.5]
UA IAD-MBJ MAR 0.8>0.5[0.8]
UA IAD-MCI MAR 3>1.0[3]
UA IAD-MCO MAR 4>1.9[4]
UA IAD-MDT MAR 4>1.7[4]
UA IAD-MHT MAR 0.3>0[0.3]
UA IAD-MSN MAR 1.8>0[1.8]
UA IAD-MSP MAR 1.8>1.0[1.8]
UA IAD-MSY MAR 3>1.9[3]
UA IAD-MUC MAR 0.9>0.5[0.9]
UA IAD-NAS MAR 0.8>0.5[0.8]
UA IAD-OKC MAR 1.8>0[1.8]
UA IAD-ORD MAR 5>4[5]
UA IAD-ORF MAR 3>1.9[3]
UA IAD-PBG APR 1.9>0.7[1.8] MAY 1.9>0[1.8] JUN 1.8>0.5[2]
UA IAD-PBI MAR 0.9>1.9[0.9]
UA IAD-PDX MAR 0.8>0[0.9]
UA IAD-PHL MAR 4>1.7[4]
UA IAD-PHX MAR 0.9>1.8[0.9]
UA IAD-PIT MAR 3>1.9[3]
UA IAD-PQI MAR 0.5>0.7[0.5]
UA IAD-PUJ MAR 0.9>0.7[0.9]
UA IAD-PVD MAR 4>1.9[4]
UA IAD-PWM MAR 4>1.9[4]
UA IAD-RDU MAR 3>1.9[4]
UA IAD-RIC MAR 3>1.9[3]
UA IAD-ROA MAR 4>1.7[4]
UA IAD-ROC MAR 3>1.9[3]
UA IAD-SAL MAR 1.9>1.1[1.9]
UA IAD-SAN MAR 3>1.8[3]
UA IAD-SAT MAR 3>1.0[3]
UA IAD-SAV MAR 3>1.9[3]
UA IAD-SCE MAR 3>1.7[3]
UA IAD-SDF MAR 3>1.9[3]
UA IAD-SEA MAR 3>1.0[3]
UA IAD-SFO MAR 6>3[6]
UA IAD-SHD MAR 1.8>0.7[1.8]
UA IAD-SJU MAR 1.7>0.9[1.7]
UA IAD-SMF MAR 0.9>0.1[0.9]
UA IAD-STL MAR 2>1.0[2]
UA IAD-SYR MAR 3>1.9[3]
UA IAD-TLV MAR 0.4>0[0.4]
UA IAD-TPA MAR 3>1.9[3]
UA IAD-TYS MAR 3>1.9[3]
UA IAD-YOW MAR 0.4>0[0.4]
UA IAD-YYZ MAR 1.3>1.0[1.3]
UA IAD-ZRH MAR 0.9>0.4[0.9]
UA IAH-ICT JUL 3>4[1.9]
UA IAH-IND MAR 5>3[5]
UA IAH-JAN MAR 4>3[4]
UA IAH-LAS MAR 6>5[6]
UA IAH-LAX MAR 8>6[8]
UA IAH-LCH MAR 3>1.7[3]
UA IAH-LEX MAR 0.9>0[0.9]
UA IAH-LGA MAR 7>3[7]
UA IAH-LHR MAR 1.1>0[1.1]
UA IAH-LIM MAR 1.0>0.7[1.0]
UA IAH-LIR MAR 2>1.5[2]
UA IAH-LIT MAR 5>3[5]
UA IAH-MAF MAR 6>5[6]
UA IAH-MEM MAR 5>4[5]
UA IAH-MFE MAR 6>5[6]
UA IAH-MGA MAR 0.9>0[0.9]
UA IAH-MIA MAR 4>6[4]
UA IAH-MID MAR 0.9>0.5[0.9]
UA IAH-MKE MAR 1.7>1.0[1.7]
UA IAH-MLM MAR 0.9>0.4[0.9]
UA IAH-MLU MAR 1.6>1.0[1.6]
UA IAH-MSP MAR 4>2[4]
UA IAH-MSY MAR 7>5[7]
UA IAH-MTY MAR 6>2[6]
UA IAH-NRT MAR 0.9>0[0.9]
UA IAH-OAX MAR 0.9>0.4[0.9]
UA IAH-OKC MAR 6>5[7]
UA IAH-ORD MAR 9>7[9]
UA IAH-ORF MAR 1.8>0.9[1.8]
UA IAH-PDX MAR 3>1.1[3]
UA IAH-PHL MAR 4>2[4]
UA IAH-PIT MAR 5>2[5]
UA IAH-POS MAR 0.9>0[0.9]
UA IAH-PTY MAR 3>1.7[3]
UA IAH-PUJ MAR 1.0>0.5[1.0]
UA IAH-RDU MAR 4>3[4]
UA IAH-RIC MAR 3>0[3]
UA IAH-RTB MAR 1.0>0.5[1.1]
UA IAH-SAN MAR 5>3[5]
UA IAH-SAP MAR 3>1.1[3]
UA IAH-SAT MAR 7>5[7]
UA IAH-SCL MAR 0.9>0.7[0.9]
UA IAH-SDF MAR 3>1.0[3]
UA IAH-SEA MAR 4>1.9[5]
UA IAH-SFO MAR 8>6[8]
UA IAH-SGF MAR 1.8>0.9[1.8]
UA IAH-SHV MAR 3>1.8[3]
UA IAH-SJC MAR 1.9>1.0[1.9]
UA IAH-SJO MAR 3>2[3]
**UA IAH-SJT APR 0>0.7[0] MAY 0>2[0] JUN 0>2[0] JUL 0>2[0] AUG 0>2[0] SEP 0>2[0]
UA IAH-SJU MAR 2.7>1.9[2.7]
UA IAH-SMF MAR 3>2[3]
UA IAH-SNA MAR 3>2[3]
UA IAH-STL MAR 4>3[4]
UA IAH-SYD MAR 0.2>0[0.2]
UA IAH-TAM MAR 0.8>1.0[1.0]
UA IAH-TUL MAR 6>4[6]
UA IAH-TUS MAR 3>2[3]
UA IAH-VPS MAR 1.5>2[1.6]
UA IAH-XNA MAR 4>3[4]
UA IAH-YYC MAR 0.3>0[0.3]
UA IAH-YYZ MAR 0.4>0[0.4]
UA IAH-ZIH MAR 0.9>0.5[0.9]
UA ICN-SFO MAR 1.0>1.3[1.0]
UA ICT-ORD MAR 3>2.0[3]
UA ILM-ORD MAR 1.8>0[1.6]
UA IND-ORD MAR 9>4[9]
UA IND-SFO MAR 1.7>0[1.6]
UA ITO-LAX MAR 0.9>0.4[0.9]
UA JAC-SFO MAR 1.6>0.7[1.6]
UA JAN-ORD MAR 0.9>0[0.8]
UA JAX-ORD MAR 3>2[2]
UA KOA-LAX MAR 1.8>1.1[1.8]
UA LAN-ORD MAR 3>1.0[2]
UA LAS-LAX MAR 4>3[4]
UA LAS-ORD MAR 4>3[4]
UA LAS-SFO MAR 7>4[7]
UA LAX-LIH MAR 1.0>0.7[1.0]
UA LAX-LIR MAR 0.4>0.2[0.4]
UA LAX-MEL MAR 0.2>0[0.2]
UA LAX-MFR MAR 1.7>1.0[1.7]
UA LAX-MRY MAR 3>1.0[4]
UA LAX-MSN MAR 0.9>0[0.9]
UA LAX-NRT MAR 0.9>0[0.9]
UA LAX-OGG MAR 2>1.3[2]
UA LAX-ORD MAR 9>4[9]
UA LAX-PHX MAR 3>1.7[3]
UA LAX-PVG MAR 0.9>0[0.9]
UA LAX-PVR MAR 1.2>0.5[1.2]
UA LAX-RDM MAR 1.0>0.8[1.0]
UA LAX-SAL MAR 1.4>1.1[1.4]
UA LAX-SAN MAR 3>1.7[3]
UA LAX-SAP MAR 0.4>0[0.4]
UA LAX-SAT MAR 1.7>0[1.7]
UA LAX-SBA MAR 2>0[1.9]
UA LAX-SBP MAR 2>0[3]
UA LAX-SEA MAR 1.7>0.7[1.7]
UA LAX-SFO MAR 11>4[11]
UA LAX-SJD MAR 1.4>1.0[1.4]
UA LAX-SJO MAR 0.9>0.5[0.9]
UA LAX-SLC MAR 1.7>1.0[1.7]
UA LAX-SMF MAR 2>0.7[2]
UA LGA-MCO MAR 0.9>0.7[0.9]
UA LGA-ORD MAR 12>3[12]
UA LGA-PBI MAR 0.9>0[0.9]
UA LGA-RSW MAR 0.9>0[0.9]
UA LGA-TPA MAR 0.9>0[0.9]
UA LHR-ORD MAR 2>1.0[2]
UA LHR-SFO MAR 1.1>0[1.1]
UA LIH-SFO MAR 1.9>1.1[1.9]
UA LIT-ORD MAR 3>1.0[3]
UA LNK-ORD MAR 4>3[4]
UA LWB-SHD MAR 0>0.5[0]
UA MBJ-ORD MAR 1.0>0.5[1.0]
UA MBS-ORD MAR 3>1.0[2]
UA MCI-ORD MAR 5>3[5]
UA MCI-SFO MAR 1.8>0[1.8]
UA MCO-ORD MAR 8>3[8]
UA MCO-SFO MAR 3>0.7[3]
UA MEX-SFO MAR 2>1.3[2]
UA MFR-SFO MAR 4>2.0[3]
UA MIA-ORD MAR 4>2[4]
UA MKE-ORD MAR 8>5[7] JUN 8>9[9]
UA MKE-TPA MAR 0.5>0.0[0.5]
UA MLI-ORD MAR 5>1.5[4]
UA MRY-SFO MAR 1.8>0[1.6]
UA MSN-ORD MAR 7>3[7]
UA MSN-SFO MAR 0.9>0[0.9]
UA MSP-ORD MAR 8>3[8]
UA MSP-SFO MAR 1.8>0[1.8]
UA MSY-ORD MAR 2>1.7[2]
UA MSY-SFO MAR 0.9>0[0.9]
UA MTY-ORD MAR 1.9>1.0[1.9]
UA MUC-ORD MAR 0.5>0[0.5]
UA MUC-SFO MAR 0.7>0[0.7]
UA NAS-ORD MAR 1.1>0.6[1.2]
UA OGG-ORD MAR 0.6>0.4[0.6]
UA OGS-ORD MAR 0.6>0.9[0.6]
UA OKC-ORD MAR 4>2[4]
UA OKC-SFO MAR 0.9>0[0.9]
UA OMA-ORD MAR 4>3[4]
UA OMA-SFO MAR 1.7>0[1.7]
UA ONT-SFO MAR 4>2[4]
UA ORD-ORF MAR 3>2[3]
UA ORD-PBI MAR 3>1.7[3]
UA ORD-PDX MAR 3>1.0[3]
UA ORD-PEK MAR 0.2>0[0.2]
UA ORD-PHL MAR 6>3[6]
UA ORD-PIA MAR 5>1.0[4]
UA ORD-PIT MAR 6>3[6]
UA ORD-PNS MAR 0.9>1.1[0.8]
UA ORD-PSC MAR 0.9>0[0.9]
UA ORD-PUJ MAR 1.1>0.8[1.1]
UA ORD-PVD MAR 3>0.1[3]
UA ORD-PVG MAR 0.9>0[0.9]
UA ORD-PVR MAR 2>1.1[2]
UA ORD-PWM MAR 3>0.2[3]
UA ORD-RAP MAR 1.7>0.9[1.7]
UA ORD-RDU MAR 5>3[5]
UA ORD-RIC MAR 5>3[5]
UA ORD-RNO MAR 0.9>0.6[0.9]
UA ORD-ROA MAR 3>1.0[3]
UA ORD-ROC MAR 3>1.5[3]
UA ORD-SAN MAR 4>3[4]
UA ORD-SAT MAR 3>1.9[3]
UA ORD-SAV MAR 3>1.7[3]
UA ORD-SBA MAR 0.9>0[0.9]
UA ORD-SBN MAR 9>3[8]
UA ORD-SCE MAR 3>0.9[2]
UA ORD-SDF MAR 5>3[5]
UA ORD-SEA MAR 4>1.6[4]
UA ORD-SFO MAR 9>5[9]
UA ORD-SGF MAR 4>1.7[3]
UA ORD-SJC MAR 0.9>0[0.9]
UA ORD-SJD MAR 1.8>1.1[1.8]
UA ORD-SJU MAR 1.8>0.9[1.8]
UA ORD-SLN MAR 0.7>1.0[0.7]
UA ORD-SMF MAR 3>1.0[3]
UA ORD-SNA MAR 3>0.9[3]
UA ORD-SPI MAR 1.7>1.0[1.7]
UA ORD-STL MAR 7>4[7]
UA ORD-SYR MAR 4>1.6[4]
UA ORD-TLV MAR 0.4>0[0.4]
UA ORD-TUL MAR 4>1.5[3]
UA ORD-TVC MAR 4>3[3]
UA ORD-TYS MAR 4>1.7[4]
**UA ORD-VPS MAR 0>0.8[0] APR 0>1.0[0.1]
UA ORD-XNA MAR 4>0.9[4]
UA ORD-YOW MAR 0.3>0[0.3]
UA ORD-YUL MAR 0.4>0[0.4]
UA ORD-YVR MAR 0.2>0[0.2]
UA ORD-YWG MAR 0.3>0[0.3]
UA ORD-YYC MAR 0.4>0[0.4]
UA ORD-YYZ MAR 2>1.7[2]
UA PDX-SFO MAR 6>3[5]
UA PEK-SFO MAR 0.9>0[0.9]
UA PHL-SFO MAR 1.7>0[1.7]
UA PHX-SFO MAR 4>3[4]
UA PIT-RSW MAR 0.9>0.6[0.9]
UA PIT-SFO MAR 1.7>0[1.8]
UA PSC-SFO MAR 1.8>0[1.7]
UA PSP-SFO MAR 5>3[4]
UA PVG-SFO MAR 1.1>0[1.1]
UA RDD-SFO MAR 3>0.9[3]
UA RDM-SFO MAR 4>1.9[4]
UA RDU-SFO MAR 1.8>0[1.8]
UA RNO-SFO MAR 4>3[3]
UA SAN-SFO MAR 8>3[8]
UA SAT-SFO MAR 0.9>0[0.9]
UA SBA-SFO MAR 6>1.7[6]
UA SBP-SFO MAR 4>1.8[4]
UA SEA-SFO MAR 5>3[5]
UA SFO-SIN MAR 1.1>0[1.1]
UA SFO-SLC MAR 4>3[4]
UA SFO-SMF MAR 4>1.8[4]
UA SFO-SNA MAR 6>2[6]
UA SFO-STL MAR 0.9>0[0.9]
UA SFO-TLV MAR 0.9>0.4[0.9]
UA SFO-TPA MAR 0.9>0[0.8]
UA SFO-XNA MAR 0.9>0[0.9]
UA SFO-YVR MAR 2>1.0[2]
UA SFO-YYC MAR 0.3>0[0.2]
UA SFO-YYZ MAR 0.3>0[0.3]
UP FLL-FPO MAR 0.2>0.4[0.2] MAY 0>0.4[0.9]
UP FLL-NAS MAR 0.4>0.8[0.4] MAY 0.3>0.6[4]
UP MCO-NAS MAR 0>0.3[0] MAY 0>0.3[1.5]
UP MHH-PBI MAR 0>0.2[0] MAY 0>0.3[0.8]
UP MIA-NAS MAR 0.3>0.5[0.3] MAY 0.5>1.0[3]
UX MAD-MIA MAR 0.4>0.2[0.4]
**VR BOS-SID MAR 0.3>0[0.3] APR 0.3>0[0.3] MAY 0.3>0[0] JUN 0.3>0[0] JUL 0.3>0[0.1] AUG 0.3>0[0.3] SEP 0.3>0[0.3]
**VR IAD-SID MAR 0.4>0[0.4] APR 0.4>0[0.4] MAY 0.5>0[0] JUN 0.4>0[0] JUL 0.5>0[0] AUG 0.4>0[0.4] SEP 0.4>0[0]
WN ABQ-AUS MAR 0.6>0[0.6] APR 0.4>0.1[1.4]
WN ABQ-BWI MAR 0.6>0.1[0.6] APR 1.1>0.8[1.2]
WN ABQ-LAX MAR 0.6>0[0.6] APR 1.0>0.6[3]
WN ALB-DEN MAR 0.6>0[0.6] APR 0.9>0.6[0.7]
WN ALB-TPA MAR 0.8>0.2[0.8] APR 0.5>0.1[1.5]
WN AMA-DAL MAR 2>1.8[2]
WN ATL-AUS MAR 1.6>1.1[1.6]
**WN ATL-MIA MAR 0>1.4[0] APR 0>2[0] MAY 0>2[0] JUN 0>2[0] JUL 0>2[0] AUG 0>1.0[0]
WN ATL-MSY MAR 3>1.9[3]
**WN ATL-SRQ MAR 0>0.7[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>0.5[0]
WN ATL-STL MAR 1.9>3[1.9]
WN AUS-MCO MAR 1.9>0.9[1.9] APR 3>2[3]
WN AUS-RDU MAR 0.6>0[0.6] APR 0.9>0.6[0.1]
WN AUS-SAN MAR 1.3>0.8[1.3]
*WN AUS-SMF MAR 0.6>0[0.6] APR 0.3>0[0.9]
WN AUS-TPA MAR 1.3>0.7[1.3] APR 1.3>1.0[1.4]
WN BDL-DEN MAR 0.6>0[0.6] APR 1.0>0.6[0.7]
WN BDL-MCO MAR 1.8>1.3[1.8] APR 1.6>1.2[2]
WN BDL-MDW MAR 1.5>0.9[1.5]
WN BHM-HOU MAR 0.6>0.0[0.6] APR 1.0>0.6[1.9]
WN BNA-LGA MAR 2>1.8[2]
WN BNA-MSP MAR 0.6>0.1[0.6]
WN BOI-PHX MAR 1.5>1.0[1.5]
WN BOS-MDW MAR 2>1.9[2]
WN BUF-MCO MAR 1.9>1.4[1.9]
WN BUF-MDW MAR 1.5>0.9[1.5]
WN BUF-PHX MAR 0.6>0.1[0.6] APR 1.0>0.7[0.9]
WN BUF-RSW MAR 0.8>0.2[0.8] APR 0.4>0.1[1.0]
WN BUF-TPA MAR 1.8>1.2[1.8] APR 1.5>1.1[2]
WN BUR-HOU MAR 0.6>0[0.6] APR 1.0>0.6[0.5]
WN BUR-LAS MAR 5>4[5]
WN BUR-MDW MAR 0.6>0[0.6]
WN BUR-OAK MAR 5>4[5] APR 7>6[13]
WN BUR-SFO MAR 3>1.4[3] APR 5>4[6]
WN BUR-SJC MAR 4>3[4] APR 6>5[11]
WN BUR-SMF MAR 4>2[4] APR 6>4[10]
WN BWI-LAX MAR 1.3>1.0[1.3]
WN BWI-MCO MAR 9>7[9] APR 10>9[11]
WN BWI-MSP MAR 0.6>0.1[0.6]
WN BWI-MSY MAR 1.6>1.2[1.6]
WN BWI-SMF MAR 0.6>0[0.6] APR 0.9>0.6[0.7]
WN BWI-STL MAR 1.9>3[1.9]
WN BWI-TPA MAR 7>6[7]
WN CHS-MDW MAR 1.5>1.0[1.5]
WN CLE-LAS MAR 0.6>0.1[0.6] APR 0.4>0.1[0.3]
WN CLE-STL MAR 0.6>0[0.6] APR 1.6>1.2[2]
WN CMH-LAS MAR 1.3>0.8[1.3] APR 1.4>1.1[2]
WN CMH-PHX MAR 1.4>0.8[1.4] APR 2>1.6[1.5]
WN CMH-STL MAR 0.6>0[0.6] APR 1.0>0.6[1.0]
WN CMH-TPA MAR 1.5>1.1[1.5]
WN CVG-MDW MAR 1.6>1.0[1.6]
**WN DAL-MIA MAR 0>0.7[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>0.5[0]
WN DAL-MKE MAR 0.6>0[0.6] APR 0.9>0.6[1.0]
WN DAL-MSP MAR 0.6>0[0.6] APR 0.9>0.6[1.0]
WN DAL-MSY MAR 3>4[3]
WN DAL-PIT MAR 0.6>0[0.6] APR 1.0>0.6[1.0]
WN DAL-RDU MAR 0.6>0[0.6] APR 0.9>0.6[1.2]
WN DAL-SDF MAR 0.6>0[0.6] APR 0.9>0.6[1.0]
WN DAL-SJC MAR 1.3>0.7[1.3]
WN DAL-STL MAR 5>4[5]
WN DCA-FLL MAR 1.4>0.9[1.4]
WN DCA-STL MAR 1.6>1.0[1.6]
WN DEN-FLL MAR 2>1.7[2]
WN DEN-IAD MAR 1.6>1.0[1.6]
**WN DEN-ORF MAR 0>0.6[0] APR 0>0.3[0]
WN DEN-PHX MAR 10>8[10] APR 11>10[12]
WN DEN-RDU MAR 1.3>0.7[1.3]
**WN DSM-PHX MAR 0.6>0[0.6] APR 0.3>0[0.1]
WN DSM-STL MAR 1.6>1.1[1.6]
**WN ELP-SAN MAR 0.4>0[0.4] APR 0.2>0[0.9]
WN FLL-IND MAR 0.8>1.6[0.8] APR 1.3>1.6[2]
WN FLL-SAT MAR 0>0.7[0] APR 0.1>0.4[0.3]
WN FLL-TPA MAR 1.6>1.1[1.6]
WN HOU-IND MAR 0.9>1.5[0.9] APR 1.1>1.4[1.5]
WN HOU-LIT MAR 0.6>0[0.6] APR 1.0>0.6[1.0]
WN HOU-MSY MAR 3>4[3]
WN HOU-PHL MAR 0.6>0[0.6] APR 0.9>0.6[0.0]
WN HOU-PIT MAR 0>0.6[0] APR 0.6>0.9[0.9]
WN HOU-RDU MAR 0.6>0[0.6] APR 1.0>0.6[0.9]
WN HOU-STL MAR 1.9>3[1.9]
WN ICT-PHX MAR 0.6>0.1[0.6] APR 1.0>0.7[1.0]
WN ICT-STL MAR 1.6>1.1[1.6]
WN IND-LAS MAR 1.4>0.9[1.4] APR 1.4>1.1[3]
WN IND-STL MAR 1.2>0[1.2] APR 1.9>1.2[0]
WN ISP-MCO MAR 1.6>1.1[1.6]
WN ISP-PBI MAR 1.4>0.8[1.4] APR 1.4>1.1[2]
WN ISP-TPA MAR 0.6>0.1[0.6] APR 0.4>0.1[1.1]
WN JAX-MDW MAR 0.6>0.1[0.6] APR 1.0>0.7[1.0]
WN LAS-OAK MAR 6>5[6]
WN LAS-ONT MAR 4>3[4]
WN LAS-RDU MAR 0.6>0.0[0.6] APR 0.4>0.1[0.3]
WN LAS-SDF MAR 0.6>0.0[0.6] APR 0.4>0.1[0.5]
WN LAS-SEA MAR 1.6>1.1[1.6]
WN LAS-SFO MAR 3>1.7[3]
WN LAS-SJC MAR 5>4[5]
WN LAX-OAK MAR 7>4[7] APR 9>7[12]
WN LAX-RNO MAR 1.3>0.7[1.3]
WN LAX-SAT MAR 0.6>0[0.6] APR 0.9>0.6[1.7]
WN LAX-SFO MAR 5>3[5] APR 6>5[8]
WN LAX-SJC MAR 5>3[5] APR 7>5[10]
WN LAX-SMF MAR 6>4[6] APR 7>6[8]
WN LAX-TUS MAR 0.6>0[0.6] APR 1.1>0.7[3]
WN LGB-OGG MAR 0>0.7[0] APR 0>1.0[0] MAY 0>1.0[0]
WN LIT-STL MAR 1.5>1.0[1.5]
WN MCI-SAN MAR 0.6>0[0.6] APR 1.0>0.6[1.9]
WN MCI-TPA MAR 1.4>0.9[1.4] APR 1.6>1.2[2]
WN MCO-MHT MAR 1.6>1.1[1.6] APR 1.5>1.1[2]
WN MCO-MSY MAR 3>2[3]
WN MCO-PVD MAR 2>1.9[2]
WN MCO-RDU MAR 1.6>1.0[1.6]
WN MCO-ROC MAR 0.7>0.1[0.7] APR 0.4>0.1[1.3]
WN MDW-MHT MAR 0.6>0.0[0.6]
WN MDW-PHL MAR 1.6>1.0[1.6]
WN MDW-PHX MAR 8>7[8]
WN MDW-PVD MAR 0.7>0.1[0.7] APR 1.6>1.3[1.1]
WN MDW-SAN MAR 3>2[3]
WN MDW-SJC MAR 1.5>1.0[1.5]
WN MDW-SMF MAR 1.5>1.0[1.5]
Well, it was pretty questionable, no surprise.
**WN MIA-TPA MAR 1.9>0.6[1.9] APR 2>0[0] MAY 2>0[0] JUN 2>0[0] JUL 2>0[0] AUG 1.0>0[0]
WN MSY-RDU MAR 0.6>0[0.6] APR 0.9>0.6[0.0]
WN MSY-STL MAR 0.6>0.1[0.6]
WN OAK-ONT MAR 4>3[4]
WN OAK-SAN MAR 6>4[6] APR 8>7[12]
WN OAK-STL MAR 0.6>0[0.6] APR 0.9>0.6[0.8]
WN OMA-STL MAR 1.6>1.2[1.6]
WN ONT-SMF MAR 5>4[5] APR 7>6[7]
WN ORF-SAN MAR 0.6>0[0.6] APR 1.0>0.6[0]
**WN PDX-SAN MAR 0.4>0[0.4] APR 0.2>0[0.5]
**WN PHL-PHX MAR 0.6>0[0.6] APR 0.3>0[0.6]
WN PHX-SDF MAR 0.6>0.1[0.6] APR 1.1>0.8[0.9]
WN PHX-SEA MAR 2>1.8[2]
WN PHX-TPA MAR 1.4>0.9[1.4] APR 1.4>1.1[1.3]
WN PIT-STL MAR 0.6>0[0.6] APR 1.0>0.6[1.0]
WN PIT-TPA MAR 1.6>1.2[1.6]
WN RDU-TPA MAR 0.6>0.1[0.6] APR 1.0>0.7[1.4]
WN RNO-SAN MAR 1.2>0.7[1.2]
WN SAN-SFO MAR 4>3[4] APR 6>5[7]
WN SAN-SJC MAR 7>4[7] APR 9>7[15]
WN SAN-SMF MAR 7>5[7] APR 9>8[14]
WN SAT-TPA MAR 0.6>0[0.6] APR 0.9>0.6[1.0]
WN SDF-TPA MAR 0.7>0.3[0.7]
WN SEA-STL MAR 0.6>0[0.6] APR 0.9>0.6[1.0]
WN SLC-SMF MAR 0.6>0[0.6] APR 0.4>0.1[1.0]
WS LAS-YYZ APR 1.3>1.6[1.8] JUN 1.5>1.8[0] AUG 1.6>2[1.7]
WS LGA-YYZ MAR 0.3>0.9[0.3]
WS MCO-YYZ JUN 1.5>1.9[0] JUL 1.7>2[0.0]
WS PHX-YEG MAR 1.1>1.4[1.1]
WS SFO-YYC APR 0.1>0.4[0]
X4 GST-JNU JUN 0>0.5[1.6] JUL 0>0.5[3] AUG 0>0.5[2]
YR BLD-GCW MAR 0>0.4[0]
Z3 AKN-EGX MAR 0.4>0.7[0.4] APR 0.4>0.7[0] MAY 0.3>0.6[0.4] JUN 0.4>0.7[0.4] JUL 0.4>0.6[0.4] AUG 0.4>0.6[0.4] SEP 0.4>0.7[0.7]
Z3 AKN-IGG MAR 0.4>0.6[0.4] APR 0.4>0.6[0.7] MAY 0.3>0.5[0.4] JUN 0.4>0.6[0.4] JUL 0.4>0.6[0.4] AUG 0.4>0.6[0.4] SEP 0.4>0.6[0.6]
UALFAson
Re: OAG Changes 2/2/2021:AA DABPHL;AS Cuts EWRSJC,LAXORD,PHLSFO,PAE-BOI/PDX,More;F9 Axes 31 Routes;SY Expands;UA SJT;WN
Tue Feb 02, 2021 3:32 pm
Wow, the report is out early this week! Thanks, as always, for your work on this, enilria!
AS' hacking away at the former VX route network continues. So much for synergies and offering consumers a better competitor to the Big 4 that they promised with the merger.
Encouraging to see AA with so many March adds. Although, as I think I posted in last week's thread, with many schools cancelling Spring Break, I'm not sure how much of that demand will still exist this year.
enilria
Tue Feb 02, 2021 3:40 pm
This is when it is supposed to be out, but it's been late upstream from me
I think AS accomplished nothing with the VX buy except community service for the industry of eliminating competition. If they really bought it to stop B6 from growing I think that failed pretty miserably as AS is ceding the transcons bit by bit and B6 is taking them.
Nicknuzzii
Tue Feb 02, 2021 3:43 pm
F9 really seems to like how AUS and EWR are doing...
ContinentalEWR
Tue Feb 02, 2021 3:56 pm
As always, thanks for all the effort to put this out each week. The AS transcon cuts are not surprising and seem to suggest a potential for more and a realignment of the strategy once AS enters OW. I can see them axe LAX and SFO out of JFK completely down the road, but maintain and grow SEA, PDX, and the recently announced SAN route which would better complement AA's offering. SJC-EWR always seemed like an odd-ball route for AS.
USAirALB
Tue Feb 02, 2021 4:15 pm
On the contrary, I had really expected AS (and it looked like they were going to, for a while) to build up SJC at a similar level to SAN at one point. I expected EWR would have been followed by BOS/WAS/MCO but I guess AS had other plans.
Nicknuzzii
Tue Feb 02, 2021 4:20 pm
SJC-EWR did okay, not great before Covid. It was almost all business driven demand though. The route performed a bit better once UA left. A route with no leisure demand isn’t going to work anytime in the near future.
airlinepeanuts
Tue Feb 02, 2021 4:24 pm
AA removing SEA-PVG for April? Does this delay it?
MIflyer12
Tue Feb 02, 2021 4:27 pm
The F9 cuts at AUS, CVG and EWR seem... comprehensive?
pmanni1
Tue Feb 02, 2021 4:32 pm
I was always skeptical how low cost F9 could make high cost EWR work.
Ishrion
Stopover in Seoul + the limited frequencies for U.S. carriers
AA ICN-SEA APR 0>0.3[0]
SANFan
Tue Feb 02, 2021 4:42 pm
enilria wrote:
AS BOI-SAN MAR 1.4>1.0[1.4]
AS GEG-SAN MAR 1.4>1.0[1.4]
I thought I'd point out that although these 2 routes indicate a decrease in frequency, it is because both routes are upgraded to mainline service; from 2 EMJs/day to 1 739 in one case and to an A320 in the other. In other words, it's not all reductions in service and cutting this and that. I feel that we are just starting to see some positive indications at last!
I have no idea about other routes in AS's network but I'm sure there are many similar cases.
Also, keep in mind that most of the fractional numbers shown for AS in March are due to the March schedule being effective on the 18th of the month this year.
Thank you Enilria for all the effort you put in to keeping this great thread coming to us week after week. It is very much appreciated!
bb
LCDFlight
Tue Feb 02, 2021 4:49 pm
Wow, this looked like a very impressive step up in capacity for AA, middling for DL and a step back for UA.
As COVID death rates structurally decline in the USA (hopefully), we may be on the brink of a major capacity boost in the US. My guess is international stuff only begins to recover deep into July, with major recovery happening by October.
nkops
Tue Feb 02, 2021 4:52 pm
Can't seem to find it anywhere, but who is 4P?
MAH4546
Tue Feb 02, 2021 4:57 pm
AS isn’t exiting JFKLAX/SFO. They don’t have antitrust and that would only raise suspicions. They are in fact already adding JFKSAN. On their earnings call they even mentioned how the lack of a high-CASM lie flat plane is to their advantage right now on these routes, which is absolutely true. JFKLAX is essentially a leisure market this summer.
dolphinflyer
Tue Feb 02, 2021 5:27 pm
Spirit deferred launch of SMF-SNA service by one month; will now begin April 1st.
MaxTrimm
Tue Feb 02, 2021 5:47 pm
Really strong (relatively) March for PHX/AZA. I assume combining international travel restrictions with Spring Break bodes well for Arizona, since the states pretty well opened up. Really surprised to see YEG-PHX on WS back at 1.4 for March, I assume that will be chopped back a bit.
phatfarmlines
Tue Feb 02, 2021 5:50 pm
enilria wrote:
3M CHS-MCO MAR 0.3>0.5[0.3]
3M CHS-TPA MAR 0.2>0.5[0.2]
3M ELH-FLL MAR 0.2>0.9[0.2]
3M EYW-FLL MAR 0.5>1.1[0.5]
3M EYW-MCO MAR 1.0>1.4[1.0]
3M EYW-TPA MAR 0.8>1.8[0.8]
3M FLL-GGT MAR 0.3>0.5[0.3]
3M FLL-JAX MAR 0.1>0.4[0.2]
3M FLL-MCO MAR 1.1>1.3[0.9]
3M FLL-MHH MAR 0>0.5[0] APR 0.3>0.6[0.9] MAY 0.3>0.6[0.4] JUN 0.3>0.5[0.5] JUL 0.3>0.6[0.4] AUG 0.3>0.5[0.8] SEP 0.3>0.6[0.1]
**3M FLL-SAV APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0]
3M FLL-TLH MAR 0.3>0.5[0.3]
3M FLL-TPA MAR 0.7>1.0[0.7]
3M JAX-TPA MAR 0>0.4[0.2]
3M MCO-PNS MAR 0.8>1.0[0.8]
3M NAS-TPA MAR 0>0.2[0]
3M PNS-TPA MAR 0.3>0.8[0.3]
**3M SAV-TPA APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0]
3M TLH-TPA MAR 0>0.4[0]
Two themes from 3M: Slow return of Bahamas service, especially to MHH, and continued expansion of Florida-Southeast markets with the addition of SAV.
enilria wrote:
*4P ACY-AVP MAR 0>0.7[0] APR 0>0.7[0] MAY 0>0.7[0] JUN 0>0.7[0] JUL 0>0.7[0] AUG 0>0.7[0] SEP 0>0.7[0]
*4P AVP-BWI MAR 0>0.7[0] APR 0>0.7[0] MAY 0>0.7[0] JUN 0>0.7[0] JUL 0>0.7[0] AUG 0>0.7[0] SEP 0>0.7[0]
New EAS markets? BWI seems to be a favorite for these EAS carriers.
enilria wrote:
9X DSI-TPA MAR 0>0.3[0]
9X PBI-TPA MAR 0>2[0]
I think PBI is a resumption of service for Southern Airways Express, though I think Destin (DSI) is new.
Addendum:
enilria wrote:
**AS FLL-SAN APR 0.7>0.1[0] MAY 0.7>0[0] JUN 0.7>0[0] JUL 0.7>0[0] AUG 0.7>0[0] SEP 0.7>0[0]
**AS PHL-SFO MAR 0.5>0[0.5] APR 1.0>0[0] MAY 1.0>0[0] JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[1.0] SEP 1.0>0[0]
**AS LAX-ORD MAR 0.5>0[0.5] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0.8[0]
Overlap reductions with AA/B6 :D ?
Last edited by phatfarmlines on Tue Feb 02, 2021 5:57 pm, edited 2 times in total.
FATFlyer
Pre-COVID, Allegiant was operating about 12X per week (about 1.7).
Southwest is entering the route and there will be on-going COVID impacts, but it looks like Allegiant for now is not backing down.
alasizon
Tue Feb 02, 2021 6:05 pm
enilria wrote:
Increases to MAR schedule
AA
More like AA fixed their equipment issues that have been plaguing these threads - everything actually looks accurate to me.
PHX isn't just targeted at local demand - demand for the entire Mountain West is up as folks seek travel to the National Parks and "outdoorsy" areas.
YEG-PHX I would expect to drop back down to .4x or whatever they had been running YYC at - WS hasn't been updating their PHX transborder schedule until about 30 days before each month.
Seems like NK can't make up their mind on SNA.
enilria
Tue Feb 02, 2021 6:11 pm
It's interesting they haven't moved to collapse JFK. I assume the rivalry with B6 is big time at play and a reluctance to admit that the VX purchase with the goal to stave off B6 in transcon has completely failed.
I'm not sure I agree with that, but the COVID restrictions on the NY area are pretty tough. Without COVID it might be very different.
bb
I think the cuts AS has done in SAN recently have fairly little to do with SAN and a lot to do with intra-State Cali flying doing poorly in the COVID world and AS failing in non-SEA transcon post-VX merger.
I was just looking at TSA today, traffic is increasing a lot, but it tracks normal seasonality so we are still at about the same point from a year ago.
It doesn't seem to be helping them in all these dropped transcons, but it would not be the first time a CEO "perfumed the pig" in a quarterly call.
dfw88
Tue Feb 02, 2021 6:19 pm
4P is Public Charters, Inc. These flights have existed for a while. I guess they just changed frequency and that's why it hit the thread. Here's their website: https://publiccharters.com/ (no, I'm not affiliated with them in any way, just sharing because the question was asked).
Corpsnerd09
Tue Feb 02, 2021 6:23 pm
enilria wrote:
AA PVG-SEA APR 1.0>0[0]
Looks like it still begins on March 27 but goes down to 2x weekly (Friday/Saturday from SEA, Sunday/Monday from PVG) with a stopover in ICN for April and then goes nonstop again on May 8, daily. It also looks to go from 787-8 to 772.
drdisque
Tue Feb 02, 2021 6:42 pm
I think LAX-ORD on AS will be back at some point. VX struggled with the route and AS struggled with the route, there was no need to hold onto it during this crisis. Even today on a Tuesday in the depths of the pandemic and shoulder season, UA is flying it 3x B753, AA is flying it 3x (1xB738, 1xB772, 1xA321), and NK is flying it 1x A320. In addition WN is flying LAX-MDW 3x. There's just no room for a fourth/fifth player in this environment.
AVLAirlineFreq
Tue Feb 02, 2021 6:48 pm
3x/daily in March? That practically qualifies as hourly shuttle service on G4.
drdisque
Tue Feb 02, 2021 6:59 pm
The weird thing is that according to their website they're $1100+ roundtrip. That seems a bit excessive. Maybe that's enough to guarantee a profit if they get one booking. I know some commuter airlines in Africa are essentially charging the breakeven cost to go - if they get one pax, they ask the pax to pay the rest of what they need to break even or they don't go. I wonder if that's the same arrangement here. As far as I can tell none of these flights have operated in the past week.
Also, I wonder if they're using their King Air, their Mojave, or their Navajo (the Navajo was used when they briefly flew AVP-PIT in 2018), although they didn't have their King Air then. Also it looks like the B1900C Public Charters owns is going to end up on this certificate. It ferried CAK-AVP in October after flying MDW-MBL under the Ultimate Air Shuttle certificate this fall before the route was taken over by Cape Air.
drdisque
Tue Feb 02, 2021 7:15 pm
I did more research and they applied for the authority to operate the ACY flight with their Mojave (their Commuter authority had been revoked after being dormant for over a year after they stopped flying PIT-AVP. Their King Air and Navajo are essentially dormant (Navajo last flew FRG-AVP in December 2019 and the King Air hasn't flown since October 10). However, The Mojave has not been to either ACY or BWI any time recently. It has done a lot of training flights and a few charters to ABE, HEF, and several charters this month to HGR, but nothing to ACY or BWI..
ContinentalEWR
Tue Feb 02, 2021 7:16 pm
SJC to EWR is, as others have pointed out, overwhelmingly a business route, and business demand is all but dead. Generally, NYC to SJC has never really worked. it has been tried, stopped and re-started a number of times. It's a very thin route.
jayunited
Tue Feb 02, 2021 7:18 pm
There is no need in AA making the same mistake both DL and UA made by attempting to fly to PVG nonstop. It is still a nightmare scenario where at least in UA cases it was taking 4-5 additional hours after the flight arrived in PVG for the crews to be tested receive those results be escorted to there hotels. As if getting to the hotel wasn't nightmarish enough then there were the constant disruptions to their sleep as the hotel served meals on their schedule, their terms, which didn't mesh well with the crews trying to sleep.
It's best AA launch SEA-PVG with a stopover in ICN and avoid that situation altogether.
MO11
Tue Feb 02, 2021 7:19 pm
The OAG says "PA2". Probably the Navajo as primary and the Mojave as backup.
ContinentalEWR
Tue Feb 02, 2021 7:20 pm
bb
I agree with you @Enliria, re JFK. I think AS can make SEA, PDX, and SAN work, essentially doing that flying fro AA (AA would likely never start JFK-PDX and has suspended SEA and SAN a while back for a number of reasons). AS does not offer a compelling product on LAX/SFO where competition is fierce and all of the players (B6, DL, AA, UA soon) offer an elevated product in the premium cabin that AS cannot compete with, what is essentially standard domestic first.
LASVegan
Tue Feb 02, 2021 7:29 pm
Crazy for sure. I think their only other city pair that has seen frequencies like this is LAS-FAT. I believe in years past they may have had 3 or 4 daily.
maps4ltd
Tue Feb 02, 2021 7:43 pm
UA to SJT is an interesting development that keeps getting overlooked. Any more intra-TX possibilities for UA?
durangomac
Tue Feb 02, 2021 7:48 pm
AS has always said that while the transcons were a nice perk and had some good revenue from the merger, the purpose for the VX merger was to gain real-estate in LAX, SFO and JFK, not the specific routes. Many people keep saying that VX was great and all which they were a hip airline and had some neat touches, in reality they were barely profitable and in 10 years didn't really keep innovating with their onboard product. The value of the company was the people and the real-estate (including slots) and that the routes and aircraft were basically zero value because either not profitable or leased in the case of the aircraft.
AS hasn't argued their first class cabin competes with B6's mint, UA/AA/DL's first/business class cabins, they weren't going for that market and it appears to be good move at the moment not to invest in the more expensive first class cabin.
I suspect because of CASM all or most of the transcons are loosing money with little to no business travel currently, probably good idea to trim the worst performing transcons.
flyCMH
Tue Feb 02, 2021 7:52 pm
Quite a few updates this week. Thank you, @enliria, for always taking the time to compile this information and share it with the community, as well as your insight.
The Frontier cuts seem pretty extensive. Any ideas as to what's provoking them?
drdisque
Tue Feb 02, 2021 8:03 pm
They could bring back Tyler, Longview and Wichita Falls and add Texarkana,
I don't see any of those being high priorities.
USAirALB
Tue Feb 02, 2021 8:22 pm
I never said SJC-NYC wasn't a business route (most anyone could figure that out)...
My post was entirely related to the AS buildup of SJC and how starting the route signaled to me that they intended a couple of years back to make it a mini-SAN...
phxa340
Tue Feb 02, 2021 8:32 pm
Even before Covid, I gave up an AS an SAN due to their launching and cancelling routes constantly. I get that Covid made things worse but it’s hard to stay loyal to AS if you are San Diego based, as much as I would love to.
klm617
Tue Feb 02, 2021 8:40 pm
Great to see Flint doing so well.
BoeingGuy
Tue Feb 02, 2021 9:19 pm
    AS has been doing the same thing with SJC, even before COVID.
    TUS had come and gone twice. SNA and BUR come and gone. RNO come and gone. AUS started, cut, and back again. Same with SJD and PVR. JFK was short lived. Now EWR gone at least for now. GEG was added and cut; I think it’s back again. EUG didn’t last long. Looks like RDM may be cut already. DAL was short-lived. This is at least the third time they’ve started SJC-PSP. I hope SJC-MSO sticks, but I’ll believe it when I see it. They even did SJC-SMF as a triangle with BOI and advertised it, IIRC.
    ContinentalEWR
    Tue Feb 02, 2021 9:26 pm
    All valid points. Not sure AS was looking at JFK specifically as a major source of assets when they decided to buy VX although VX did have LAX/SFO/LAS and a weekly PSP. I think AS will retain a presence at JFK, but it will shift dramatically in terms of focus.
    sprxUSA
    Tue Feb 02, 2021 9:39 pm
    Well any other TX city that wants to pay for UA service, like SJT, probably could get it.
    F9 finally giving up on a BOI resumption . I hope, they are a non-factor there it seems.
    aaway
    Tue Feb 02, 2021 9:44 pm
    enilria wrote:
    AN ABQ-SVC MAR 0>0.9[0]
    AN BUR-HHR MAR 0>0.3[0]
    AN BUR-MMH MAR 0>0.5[0]
    AN CLD-MMH MAR 0>0.5[0]
    AN HHR-MMH MAR 0>0.4[0]
    AN PHX-SVC MAR 0>0.5[0]
    Advanced Air (AN) has announced that MMH will not fly until Winter 2021/2022.
    DeltaRules
    Tue Feb 02, 2021 10:22 pm
    AA extending DAB-PHL not long after extending DAB-DFW is HUGE.
    dfw88
    Tue Feb 02, 2021 11:01 pm
    Not that I necessarily doubt it because they keep pushing it back, but in a quick Google search I didn't see anything about them giving up for this year. Can you link to a source?
    enilria
    Tue Feb 02, 2021 11:19 pm
    pmanni1 wrote:
    *F9 EWR-MYR APR 0.4>0[0] MAY 0.4>0[0] JUN 0.4>0[0] JUL 0.4>0[0] AUG 0.5>0[0.4] SEP 0.4>0[0]
    **F9 EWR-ONT APR 0.6>0[0] MAY 1.0>0[0.3] JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0]
    **F9 EWR-ORD APR 0.6>0[0] MAY 1.0>0[0.3] JUN 1.0>0.7[0]
    **F9 EWR-PBI APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[0] JUL 1.0>0[0] AUG 0.4>0[0.4]
    F9 EWR-PHX APR 0.4>0[1.0]
    **F9 EWR-RSW APR 0.4>0[0] MAY 0.4>0[0] JUN 0.4>0[0] JUL 0.4>0[0
    bb
    I think SAN is more of a challenge because the geography means no connections to speak of, but generally agree. It's the pre-merger strengths.
    Knowing them it is a precursor to reshuffling the deck. I did see that the Director of Network Planning job is open which might be connected.
    NK has reduced a lot in Michigan creating some room.
    While good news I don't think it sticks post-Covid.
    hpff
    Wed Feb 03, 2021 12:25 am
    The other thing is that VX would have almost certainly merged with someone. AS was not only in the best position to do so at the time, but by doing so prevented B6 from growing in key west coast markets. B6 would have a lot more LAX real estate right now if AS hadn't purchased them. The current problem AS has is that they're the odd airline out anywhere but the Pacific Northwest. It will be interesting to see how they do once they exit COVID.
    ChaseCLT
    Wed Feb 03, 2021 12:29 am
    DC took such a hard hit during Covid and at least in the case of IAD, it just gets worse and worse
    aaway
    Wed Feb 03, 2021 1:26 am
    https://info.advancedairlines.com/mammo ... -postponed
    klm617
    Wed Feb 03, 2021 2:24 am
    Actually NK is operating around 65% of it pre covid flight schedule out of DTW. The flights that are not operating are the non leisure destinations. So I'd say the demand from Southeast Michigan to Florida is pretty strong and it's good to see G4 stepping up and filling the void. I am sure now that G4 is the number one carrier at both FNT and GRR.
