zeke wrote:Seems like an overreaction to me, the engine/airframe combination has significant history.
dik909 wrote:What would cause the failure of a turbine blade ? The composite material ? Or the EDM'ed cooling holes ? Or something else, perhaps ??
flee wrote:dik909 wrote:What would cause the failure of a turbine blade ? The composite material ? Or the EDM'ed cooling holes ? Or something else, perhaps ??
IIRC the PW4077 engine uses hollow titanium blades, not composite.
TC957 wrote:Yet more trouble for Boeing. I'm surprise there are ( were ) as many as 69 of these elderly 772's still in service.
JannEejit wrote:TC957 wrote:Yet more trouble for Boeing. I'm surprise there are ( were ) as many as 69 of these elderly 772's still in service.
I know these motors are attached to Boeing product, but would it be considered more a P&W issue or are OEM's happy to remain relatively anonymous to the travelling public at large, in terms of how these incidents are reported in the media ?
In other words does Boeing deflect the flak (no pun intended) or roll with it ?
LAX772LR wrote:UA has grounded 24 ships as well.
Man, PW4000 has given operators so much grief over the years on larger frames.... no wonder neither Boeing nor Airbus has allowed a PW-only powerplant on new widebody design, in 24yrs+
"While [an] investigation is ongoing, we recommended suspending operations of the 69 in-service and 59 in-storage 777 aircraft powered by Pratt & Whitney 4000-112 engines," the company said in a statement.
JibberJim wrote:https://www.bbc.co.uk/news/world-us-canada-56149894 Says that Boeing recommended the grounding"While [an] investigation is ongoing, we recommended suspending operations of the 69 in-service and 59 in-storage 777 aircraft powered by Pratt & Whitney 4000-112 engines," the company said in a statement.
Given the relatively low impact of the grounding and the PR situation, I don't think that's a surprising conclusion to make, makes it seem more likely that it wasn't a bird strike, or some other obvious "normal" flaw.
journeyperson wrote:
The most interesting thing about that BBC article about a Pratt and Witney engine failure is that it links to two stories about the 737 Max saga..
That's purely down to an algorithm that links "similar" stories together.
hotelbravo wrote:The Longtail 744 involved in the recent incident had PW4000-series engines. Did this play a part in the 777 PW4000 grounding?
https://www.theguardian.com/business/2021/feb/22/dutch-investigate-boeing-747-after-engine-parts-drop-after-takeoff-netherlands
flee wrote:How are the fan blades inspected? Is it done visually, using ultrasound, xrays or some other technique?
GCT64 wrote:Looks like 3 blade failure incidents in 3 years (UA approaching HNL in 2018, JL leaving Okinawa in 2020, UA leaving DEN in 2021) from a fleet of 70 or so relevant 777s. That's about a 5% rate, I can understand the rationale for a grounding.
Polot wrote:GCT64 wrote:Looks like 3 blade failure incidents in 3 years (UA approaching HNL in 2018, JL leaving Okinawa in 2020, UA leaving DEN in 2021) from a fleet of 70 or so relevant 777s. That's about a 5% rate, I can understand the rationale for a grounding.
That’s only a ~5% rate if those 777s only flew a total of ~70 flights in the past 3 years.
Opus99 wrote:TC957 wrote:Yet more trouble for Boeing. I'm surprise there are ( were ) as many as 69 of these elderly 772's still in service.
Is it really trouble for them?
In cases like this what are they supposed to do. I understand liaise with the OEM. But they stopped building this jet almost 20 years ago so I’m not sure if this will add to the pile of problems
Antarius wrote:Opus99 wrote:TC957 wrote:Yet more trouble for Boeing. I'm surprise there are ( were ) as many as 69 of these elderly 772's still in service.
It's not trouble at all. Other than just bad press and that will die out.
PW on the other hand...
kalvado wrote:Antarius wrote:Opus99 wrote:Is it really trouble for them?
I assume 20 year old engines are not under any warranty by now. Would be interesting to see hours/major rebuilds data on these engines, especially fan blades.
End-of-life fatigue is not a totally unexpected problem...
Not necessarily warranty, but it will use PW's time and resources to investigate and mitigate. Additionally, these engines must be under the expected service life.
pugman211 wrote:That's the beauty about traceability! Each engine has/had an inspection. Some would of been rebuilt with new blades, each blade should have a service start date technically so you can track the no. of days vs flight hours.
My question is, did all 3 failures happen at the same stage of a flight? 2 happened just after take off correct? What about the third?
keesje wrote:Who remembers just 2 months ago. https://www.flightglobal.com/safety/jal ... 74.article
Was Boeing /FAA take initiative to ground this sub fleet, or did they after the Japanese authorities did so?
AECM wrote:pugman211 wrote:That's the beauty about traceability! Each engine has/had an inspection. Some would of been rebuilt with new blades, each blade should have a service start date technically so you can track the no. of days vs flight hours.
UA328 in 2018 was cruising at FL360
JA8978 in 2020 was climbing and stopped at FL190
UA1175 in 2021 was climbing and stopped at FL130
LAX772LR wrote:Total guess on my part, but I'm betting the inability to douse that fire (and pending investigations as to what may have prevented it), is playing a big part in this sudden rush to ground.
....imagine if that had occurred in an ETOPS diversion, and they'd had to fly like that for 2.5hrs+
