mercure1 wrote:Reportedly, the labels will use high-speed trains as a benchmark for consumer which seems to me to be short-sighted as rail travel not always an option for many city pairs, and also becomes less optimal when distances start getting over 500km (~300miles)
mercure1 wrote:The environmental war against aviation continues in Europe.
The EU is preparing an eco-label system for air travel, with the European Union Aviation Safety Agency (EASA) putting out a tender for a classification system. The EASA system would be for "providing reliable, comparable and verifiable information" for consumers on airlines and flight-routes' CO2-emissions footprints to enable customers to choose green options.
https://www.reuters.com/article/us-eu-a ... SKBN2AK0RK
https://www.engadget.com/europe-is-plan ... 55032.html
GalaxyFlyer wrote:Virtue signaling of the worst kind. Bosses insisted on a “green” offset program for the company bizjet. Nicely affixed label by the entry door showing the greed creds. Boss smiles approvingly to me upon seeing it, boards solo for a trip NYC-LON. Don’t, for an instant, think these people actually believe this narrative.
LAXintl wrote:Comparing air to rail is not exactly an apples to apples comparison.
Air routes exist not only for point to point journeys but broader network connectivity, so shorter segments exist to offer links into global networks via hubs.
Also, rail indeed does lose its appeal as distances grow, so even if the air is more pollutant, it's far more efficient to the consumer than expect them to take rail journey from one end of the EU to the other.
Lets also not also forget the huge sunk cost and loss-making reality associated with rail, while airlines seek to turn a profit via commercial cost recovery realities.
seahawk wrote:...says the 16-year member of an aviation fansite...Long overdue, people need to understand that flying is bad for the environment.
tomcat wrote:The leading low cost airlines with their young fleets, high seat densities and high load factors will come out on top.
sirloin wrote:...says the 16-year member of an aviation fansite....
davidjohnson6 wrote:I've just spent the last 10 mins trying to see how much CO2 would be emitted for 1 seat on a 1000 km trip for different aircraft types - never mind worrying about seats per aircraft, load factor, circling due to ATC delays, noise, airframe recycling, etc...
The best data I could find was something that included Concorde and DC-10s as commonly used aircraft - clearly so old as to be useless.
If an a.netter can't easily find data to show that flying an E145 is worse than flying a fully loaded 737-800, then the average non-avgeek hasn't got a hope of figuring this out independently of corporate bullsh*t
WayexTDI wrote:The mistake made by both sides is to peg rail versus air; they can (and do) complement each other.
mercure1 wrote:.
Arion640 wrote:Will there be a huge difference in comparing an A320 NEO to a 737MAX?
787 v A350 v 777?
They’re all pretty efficient now the 747’s have gone, not much to compare and not much choice of alternatives either!
tomcat wrote:mercure1 wrote:.
There are indeed only a few countries within EU where proper HST services are available and even less countries which have good HST connections with other countries. Most of the time, traveling by train across Europe is not much faster than traveling by bus (which is also very energy efficient). On the other hand, where convenient HTS services become available, the air travel rapidly looses a significant market share. This label will actually be of little use for most of the travelers.
Also, a recent data snapshot from Eurocontrol reported that in 2019 (*) the flights shorter than 500 km in Europe made up 24% of all the flights while they were only responsible for 3.8% of the CO2 emissions of the European air transport. This reinforces the impression that this label will only be cosmetic (unless the actual mid-term goal is to create a tax related to this label) and that the focus should be on investing for improving the energy efficiency of the air transport.
(*) the 2019 figures are mentioned in the text below the chart:
https://www.eurocontrol.int/sites/default/files/2021-02/eurocontrol-data-snapshot-co2-by-distance.pdf
tomcat wrote:davidjohnson6 wrote:I've just spent the last 10 mins trying to see how much CO2 would be emitted for 1 seat on a 1000 km trip for different aircraft types - never mind worrying about seats per aircraft, load factor, circling due to ATC delays, noise, airframe recycling, etc...
Ryanair is now publishing their average CO2 emission per passenger.km. Last time I checked their were at 66g of CO2 per passenger.km and this is before the MAX200 joins the fleet.
willfinn wrote:Here "investment" sure sounds like "tax euros".
willfinn wrote:This scheme is a front to enable more taxation, pure and simple. It will provide a tailor-made excuse, where you will hear political mouthpieces argue the following: "As these flights are energy efficiency E-rated, it is only fitting that those passengers using said flights are a subject to a higher Environmental Flight Tax (EFT) than those using high-speed rail."
davidjohnson6 wrote:If an a.netter can't easily find data to show that flying an E145 is worse than flying a fully loaded 737-800, then the average non-avgeek hasn't got a hope of figuring this out independently of corporate bullsh*t
VSMUT wrote:willfinn wrote:This scheme is a front to enable more taxation, pure and simple. It will provide a tailor-made excuse, where you will hear political mouthpieces argue the following: "As these flights are energy efficiency E-rated, it is only fitting that those passengers using said flights are a subject to a higher Environmental Flight Tax (EFT) than those using high-speed rail."
What's wrong with asking the biggest polluters to contribute more towards fixing the problem? It's obviously not a burden that should rest on the shoulders of people who don't fly or otherwise pollute.
The rapid penetration of electric vehicles (cars, buses, trucks and two/three-wheelers), which the IEA projects to rise to 30% of the global fleet by 2040 in its “Stated policy scenario”, leads to the need to identify alternative tax-base to fossil fuel use in transport.
VSMUT wrote:What's wrong with asking the biggest polluters to contribute more towards fixing the problem?
VSMUT wrote:willfinn wrote:Here "investment" sure sounds like "tax euros".
Duh. That's how states work. In other news, it gets dark when the sun sets and bears relieve themselves in the forest.willfinn wrote:This scheme is a front to enable more taxation, pure and simple. It will provide a tailor-made excuse, where you will hear political mouthpieces argue the following: "As these flights are energy efficiency E-rated, it is only fitting that those passengers using said flights are a subject to a higher Environmental Flight Tax (EFT) than those using high-speed rail."
WayexTDI wrote:tomcat wrote:mercure1 wrote:.
That chart is comparing apples to oranges: shorter intra-european flights keep the CO2 within European airspaces. However, a long-haul flight (say, Europe to Japan) will spread the CO2 over several continents.
Saying that all the CO2 produced on a long-haul flight is concentrated in Europe, and then pegging that against a short intra-european flight, is a big mistake; it basically renders the study flawed, hence useless.
tomcat wrote:European people took centuries to more or less free themselves from an aristocratic society, the green agenda will send us back to that kind of world within a few decades.
janders wrote:VSMUT wrote:What's wrong with asking the biggest polluters to contribute more towards fixing the problem?
As the linked article states study indicates aviation contributes to 3.5% of global greenhouse gasses.
How about focus on the real sources - heck agriculture and lifestock contribute 24%! All of industry is 21%, while electricity and heat production is 25%.
Seems the focus on airlines is largely wasting time on an inconsequential producer.
PA727 wrote:Because, in this case, it's not asking the biggest polluters to contribute. If it were, it would be listed on every private/corporate jet as well, along with a corresponding cost/tax. But that isn't the case here. As of now, it is a labeling system - only for airlines. The tax will most likely come later, which is why there should be a discussion around how it will work for corporate/private transport happening now.
VSMUT wrote:Every sector needs to contribute. Reality is that those 3.5% are spent by less than 1% of the global population.
Aither wrote:VSMUT wrote:Every sector needs to contribute. Reality is that those 3.5% are spent by less than 1% of the global population.
Air traffic is not only about passengers. Over 100 million jobs depend directly or indirectly from aviation.
mxaxai wrote:mercure1 wrote:Reportedly, the labels will use high-speed trains as a benchmark for consumer which seems to me to be short-sighted as rail travel not always an option for many city pairs, and also becomes less optimal when distances start getting over 500km (~300miles)
This is a purely informative label for consumers. They can choose to either care or not.
One motivation is to "reduce the risk of 'greenwashing'" and provide a common labeling system. There are three different classes planned, for regional aircraft, narrowbodies and widebodies.
The original "Welt am Sonntag" article also states that CO2 emissions will be just one among several criteria that the new label evaluates. Other engine emissions, as well as noise and the amount of waste the airlines generate (through catering etc.) shall be considered.
https://www.welt.de/wirtschaft/article2 ... zeuge.html [German]
VSMUT wrote:tomcat wrote:European people took centuries to more or less free themselves from an aristocratic society, the green agenda will send us back to that kind of world within a few decades.
And Antifa is waiting around every corner, right?
Taxes aren't dumped into a black hole. They are in this case going to be invested into technology and jobs.
Where does it state that the CO2 is concentrated in Europe? It shows CO2 in produced in general and obviously it doesnt always matter where the CO2 is produced as it can the potential to affect the ecosystem at the other end of the planet.
tomcat wrote:VSMUT wrote:tomcat wrote:European people took centuries to more or less free themselves from an aristocratic society, the green agenda will send us back to that kind of world within a few decades.
I don't see what you mean with that Antifa sentence. I'm not familiar with that person.
About the use of the taxes, I have provided you a link to an OECD document which illustrates that such taxes are not used to fixing any specific issue.
Galwayman wrote:tomcat wrote:The leading low cost airlines with their young fleets, high seat densities and high load factors will come out on top.
Yes thats perfect - and the half empty, space wasting airlines with older aircraft like United airlines will be shown up for their sloppiness. It's win win ....
WayexTDI wrote:Draken21fx wrote:WayexTDI wrote:That chart is comparing apples to oranges: shorter intra-european flights keep the CO2 within European airspaces. However, a long-haul flight (say, Europe to Japan) will spread the CO2 over several continents.
Of course CO2 rejected in the atmosphere affects everybody on Earth.
But how can you compare intra-European flights and CO2 rejection with extra-European flights and CO2 rejection, and then peg them against each other?
