UPlog
LATAM to expand freighter capacity with 8 additional B767s
Mon Mar 01, 2021 6:14 pm
The 763 sure has become a hot model for cargo.
https://www.aircargonews.net/airlines/l ... nversions/
LATAM Airlines will expand its freighter capacity by as much as 80% through the addition of up to eight B767-300ER conversions.
The Santiago-headquartered airline group said the conversion plan will be implemented between 2021-2023.
Upon completion, LATAM will operate a total of 19 767-300ER freighters. “The addition of these aircraft would consolidate LATAM Group as the leading group of cargo operators in South America,” per Andrés Bianchi, LATAM Cargo’s chief executive
I fly your boxes
bennett123
Re: LATAM to expand freighter capacity with 8 additional B767s
Mon Mar 01, 2021 7:08 pm
Where are they coming from?.
TC957
Mon Mar 01, 2021 7:12 pm
Delta or United ? Shame they aren't ordering new ones.
Weatherwatcher1
I’d assume they were coming from the passenger operation. There probably is slack in their 787 fleet utilization
Jomar777
Mon Mar 01, 2021 7:21 pm
It might depend on where they will be based, maybe. They already have 5 parked on their Chilean and a further 10 in use. If they convert from these, then their passenger operations will be catered by their B787s
But LATAM Chile has been transferring several of theirs to LATAM Brazil for passenger use. If they now decide to convert those, then either they will transfer them back to Chile or leave them in Brazil.
The other issue is, if they do indeed use their LATAM Brazil's ones, given that LA BR does not use B787s, I wonder what they would use instead...
Weatherwatcher1
Mon Mar 01, 2021 7:28 pm
Upgauging the Brazil flights from 767 to 777/A350 may be a bit too much, but may work for a few routes. The 767 passenger fleet has been shrinking since LATAM sold some to UPS, Atlas, Cargojet and SF. Gently used 767s have a pretty high market value since they are great for freighter conversions
MatheusLPV
Tue Mar 02, 2021 1:16 am
What about the 777F ? I remember that LATAM Brasil(JJ) had an extra pair(or just 1) of 777-300ER on order and later converted it to the 777F . This order still shows up in the Boeing's backlog ...Maybe they will use this frame as a bargain for a new wide body order to replace those 767's being converted ?
MrBryan86
Tue Mar 02, 2021 10:11 am
Anyone has any idea where will these conversions carried out? Looking at the recent and planned activities for the various B767 conversion lines, all seems to be booked out in the near future for DHL and Amazon.
a2b7
Tue Mar 02, 2021 12:15 pm
It is true that Bedek / IAI seems to be booked out in the near future.
LATAM has ordered BCF conversions, see https://ajot.com/news/latam-announces-t ... freighters , so there must have been some conversion slots available. They will likely go to QPG, because all recent 767 BCF conversions are performed there as far as I am aware of.
FLALEFTY
Tue Mar 02, 2021 4:50 pm
Thanks for posting that article link. While it did not specify which B763ER's would be converted, the 2-phase plan (4 soon and another 4 later) seems to point to these aircraft coming from their current B767ER fleet. It is also notable that LATAM has the youngest passenger B767's in the world. These were obtained as compensation when Boeing delayed B787 deliveries of their original order.
Under their bankruptcy reorganization, LATAM returned 4 B789's to lessors, who have placed them in storage in the US. Once LATAM emerges from Chapter 11, I imagine the lessors will be more than glad to work out new leases for these same aircraft?
LATAM had 3 B777F's (2 leased, 1 owned), but they apparently moved them on after obtaining 10 B77W's from the merger with TAM. I surmise that at the time, LATAM felt that the substantial underfloor cargo capacity of the B77W's adequately compensated for their lift requirements making the B777F's redundant?
https://www.planespotters.net/airline/L ... ines-Group
LAXintl
Sat Mar 06, 2021 4:53 am
Per LATAM Cargo CEO Andres Bianchi:
“We let the 777 go because it does not fit our network,” he said. “The 767 does fit – we can push it on the longhaul side and, if needed, it can also be deployed in domestic markets.”
https://theloadstar.com/unexpected-rise ... ter-fleet/
wjcandee
Sat Mar 06, 2021 5:57 am
Boeing has two contractors currently that do touch labor on the 767-300BCF. The first, as you note, is ST Aero at QPG. The second is EGAT at TPE.
EGAT initially was the expansion line, but recently has been putting out significant volume, leading to ST Aero having to expand the number of lines available at QPG.
Tiredofhumanity
Sat Mar 06, 2021 8:13 pm
Most aren't even 10 yet. What a waste...
Spacepope
Sat Mar 06, 2021 8:37 pm
Whyso? This will ensure they have a much longer life than their non-converted brethren.
Tiredofhumanity
Sat Mar 06, 2021 9:36 pm
It just seems wasteful to convert a 7/ 8 year old airframe from an environmental perspective - freighter conversion is a much more invasive process than, say, an HMV check and generates a lot of landfill waste (miles of wiring, insulation, etc...).
Polot
Sat Mar 06, 2021 9:54 pm
If you are looking at it from an environmental prospective then converting is greener than buying new build freighters.
HPRamper
Mon Mar 08, 2021 9:09 pm
It depends on how you look at it. Greener from a solid waste perspective, or from a long-term emissions perspective. I don't believe the emissions difference between a 742 and a 744 is all that substantial, but from 744 to 748 is a bit more measurable. Obviously we aren't arguing converted 4-holer compared to a large twin.
