enilria
OAG Changes 3/2/2021:AA+ORD-BIL/FAT/GEG/ONT/SBA; B6+BOI,LGADEN,EWR-ACK/ANU/BQN/MVY/POP/SEA/STT/UVF; DL+CNY/DRO/LNK
Tue Mar 02, 2021 2:27 pm
FAQ
SOURCE: OAG
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
3M FLL-MHH APR 0.5>0.2[0.6]
9K ACK-HPN JUL 4>5[0.4] AUG 4>5[1.1] SEP 4>5[1.0]
9K ACK-HYA APR 5>6[4]
AA ABQ-ORD APR 1.5>1.1[1.5]
AA ACK-PHL JUN 0.9>0.2[0]
*AA AVL-DCA JUN 0>0.9[0] JUL 0>1.0[0] AUG 0>1.0[0.1] SEP 0>0.2[0.1]
AA BGR-ORD JUN 0.9>1.2[0] JUL 1.0>1.3[0] AUG 1.0>1.3[1.0]
**AA BIL-ORD JUN 0>0.9[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
AA BOS-PHL APR 4>3[4]
AA BOS-RDU SEP 5>4[3]
AA CMH-JFK MAY 0.8>0.6[0.2] JUN 1.0>0.8[0] OCT 1.0>0.7[1.6]
AA CRP-DFW OCT 8>7[7]
AA DAB-DFW APR 0.8>0.6[1.0]
AA DCA-JFK MAY 3>2.0[1.9]
AA DFW-GRK JUN 7>6[2] OCT 7>6[7]
AA DFW-LGB MAY 0.9>0.5[0] JUN 0.9>0.6[0] AUG 0.9>0.5[0] OCT 0.9>0.5[0]
AA DFW-STS JUN 0.8>0.5[1.0] AUG 0.8>0.6[1.0]
AA DFW-VPS APR 4>3[5] JUL 6>7[2]
AA EYW-MIA OCT 4>3[4]
*AA EYW-ORD JUN 0.1>0.6[0.7] JUL 0>0.8[0.7] AUG 0>0.5[0.3] SEP 0>0.8[0.1] OCT 0.0>0.6[0.1]
**AA FAT-ORD JUN 0>0.9[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
**AA GEG-ORD JUN 0>0.9[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
AA GGT-MIA JUL 2>1.3[0] AUG 2>1.4[1.0] SEP 1.0>0.7[1.0] OCT 1.0>0.7[1.0]
AA HHH-ORD JUN 0.1>0.4[0] JUL 0.2>0.4[0] AUG 0.1>0.4[0.2]
AA IAH-MIA APR 5>4[5]
AA IAH-ORD APR 1.9>1.5[2]
AA LHR-SEA APR 1.0>0.4[1.0] MAY 1.0>0.4[0]
AA MHH-MIA JUL 1.0>0.7[0]
AA MIA-OKC SEP 1.0>0.8[1.0] OCT 1.0>0.6[0.8]
AA MIA-PNS APR 1.0>0.7[1.0]
AA MSO-ORD JUN 0.9>0.5[0] AUG 0.9>0.6[1.0]
AA MSP-ORD JUN 7>6[1.3] JUL 7>6[1.4] AUG 7>6[6]
AA MYR-ORD JUN 0.1>1.1[0] JUL 0.2>1.3[0] AUG 0.1>1.2[0.3]
**AA ONT-ORD AUG 0>1.0[0] SEP 0>2[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0]
AA ORD-PNS MAY 0.9>0.7[0.1] JUN 0.3>0.9[0] JUL 0.3>1.0[0] AUG 0.2>0.8[0.3]
AA ORD-RSW MAY 2>3[3] JUN 2>3[0.6] JUL 2>3[0.7] AUG 2>3[1.1] SEP 2>3[1.2] OCT 2>3[1.8]
**AA ORD-SBA MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0]
*AA ORD-SRQ JUN 0.1>1.1[0] JUL 0>1.2[0] AUG 0>1.1[0] SEP 0>1.0[0] OCT 0.0>1.0[0]
AA ORD-VPS APR 1.0>0.7[1.0]
AC LAX-YYZ APR 0.4>0[0.4]
AT CMN-JFK MAY 0.9>0.7[0.8]
AZ BOS-FCO DEC 0>0.7[0]
AZ FCO-IAD DEC 0>0.4[0]
AZ FCO-JFK DEC 0>2[0.7]
AZ FCO-LAX DEC 0>0.5[0]
AZ FCO-MIA DEC 0>1.0[0]
AZ JFK-MXP DEC 0>1.0[0]
B6 ABQ-JFK APR 1.0>0.3[1.0]
**B6 ACK-EWR JUL 0>1.5[0] AUG 0>1.4[0] SEP 0>0.3[0]
B6 ACK-JFK APR 0.4>0[0.4]
**B6 ANU-EWR JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0]
B6 ANU-JFK APR 0.4>0.1[0.4]
B6 ATL-BOS APR 3>0.7[3]
B6 ATL-EWR APR 3>1.6[3]
B6 ATL-JFK APR 3>1.6[3]
B6 ATL-MCO APR 0.6>0[0.6]
B6 AUA-EWR APR 1.0>0.8[1.0]
B6 AUS-BOS APR 2>1.0[2]
B6 AUS-EWR APR 1.8>0.7[1.8]
B6 AUS-JFK APR 1.5>0.8[1.5]
B6 AUS-LAX APR 1.2>1.6[1.2]
B6 AUS-MCO APR 1.0>0.6[1.0]
B6 AUS-RDU APR 1.0>0.3[1.0]
B6 AUS-SFO APR 1.0>0.6[1.0]
B6 BDA-JFK APR 0.6>0.3[0.6]
B6 BDL-CUN APR 0.9>0.3[0.9]
B6 BDL-FLL APR 2>1.5[2]
B6 BDL-LAS APR 0.9>0.4[0.9]
B6 BDL-LAX APR 1.0>0[1.0]
B6 BDL-SFO APR 1.0>0[1.0]
B6 BDL-SJU APR 1.9>1.5[1.9]
B6 BGI-JFK APR 1.9>0.3[1.9]
B6 BNA-BOS APR 1.8>0.5[1.8]
B6 BNA-CUN APR 0.4>0.2[0.4]
B6 BNA-JFK APR 1.4>0.4[1.4]
B6 BOG-JFK APR 1.0>0.4[1.0]
**B6 BOI-JFK JUL 0>0.6[0] AUG 0>0.5[0]
B6 BOS-BUF APR 3>0.7[3]
B6 BOS-CLE APR 3>0.4[3]
B6 BOS-CLT APR 4>0.4[4]
B6 BOS-CUN APR 1.1>0.7[1.1]
B6 BOS-DCA APR 12>3[12] MAY 15>13[7]
B6 BOS-DEN APR 1.9>0.3[1.9]
B6 BOS-DFW APR 2>0.4[2]
B6 BOS-DTW APR 3>0.5[3]
B6 BOS-EWR APR 6>2[6]
B6 BOS-EYW APR 0.6>1.1[0.6]
B6 BOS-IAH APR 1.0>0.3[1.0]
B6 BOS-JFK APR 6>3[6]
B6 BOS-LAS APR 3>1.8[3]
B6 BOS-LAX APR 4>3[4]
B6 BOS-LGA APR 8>0[8] MAY 8>7[3]
B6 BOS-MBJ APR 0.4>0.2[0.4]
B6 BOS-MSP APR 1.8>0.3[1.8]
B6 BOS-MSY APR 1.7>0.3[1.7]
B6 BOS-NAS APR 0.7>0.0[0.7]
B6 BOS-ORD APR 4>0.7[4] MAY 6>5[3]
B6 BOS-PAP APR 0.4>0.1[0.4]
B6 BOS-PBI APR 6>5[6]
B6 BOS-PDX APR 0.2>0[0.2]
B6 BOS-PHL APR 6>0[6] MAY 8>6[4]
B6 BOS-PHX APR 1.1>0.6[1.1]
B6 BOS-PIT APR 4>0.4[4]
B6 BOS-PUJ APR 0.6>0.1[0.6]
B6 BOS-RDU APR 5>1.6[5]
B6 BOS-RIC APR 3>0.3[3]
B6 BOS-ROC APR 0.8>0[0.8]
B6 BOS-SAN APR 3>1.0[3]
B6 BOS-SAV APR 2>1.5[2]
B6 BOS-SDQ APR 1.5>2[1.5]
B6 BOS-SEA APR 1.8>0.6[1.8]
B6 BOS-SFO APR 4>1.6[4]
B6 BOS-SJU APR 3.0>2.4[3.0]
B6 BOS-SLC APR 1.0>0.7[1.0]
B6 BOS-SXM APR 0.5>0.2[0.5]
B6 BOS-SYR APR 0.8>0[0.8]
**B6 BQN-EWR JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0]
B6 BQN-FLL APR 0.8>0[0.8]
B6 BQN-MCO APR 1.2>0.7[1.2]
B6 BTV-JFK APR 3>0.3[3]
B6 BUF-FLL APR 1.0>0.4[1.0]
B6 BUF-JFK APR 4>1.6[4]
B6 BUF-LAX APR 0.6>0[0.6]
B6 BZN-LAX APR 0.4>0[0.4]
B6 CHS-EWR APR 1.0>0.6[1.0]
B6 CHS-FLL APR 1.0>0.7[1.0]
B6 CHS-JFK APR 1.9>1.0[1.9]
B6 CHS-LAX APR 0.9>0.3[0.9]
**B6 CHS-LGA JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0]
B6 CLE-RSW APR 0.8>0[0.8]
B6 CTG-JFK APR 0.9>0.3[0.9]
B6 CUN-EWR APR 1.9>0.9[1.9]
B6 CUN-FLL APR 1.4>1.7[1.4]
B6 CUN-LAS APR 0.4>0.1[0.4]
B6 CUN-LAX APR 1.8>0.1[1.8]
B6 CUN-MCO APR 1.1>0.6[1.1]
B6 CUN-RDU APR 0.9>0.1[0.9]
B6 CUN-SFO APR 1.7>0.1[1.7]
B6 CUN-TPA APR 1.0>0.7[1.0]
B6 CUR-JFK APR 0.3>0.1[0.3]
B6 DCA-FLL APR 5>1.7[5]
B6 DCA-MCO APR 4>1.7[4]
B6 DCA-PBI APR 1.8>0.4[1.8]
B6 DCA-RSW APR 2>0.8[2]
B6 DCA-TPA APR 1.0>0.6[1.0]
B6 DEN-JFK APR 1.8>0.6[1.8]
Wow
**B6 DEN-LGA JUL 0>2[0] AUG 0>2[0] SEP 0>2[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0]
B6 DFW-JFK APR 1.8>0.7[1.8]
B6 DTW-JFK APR 1.8>0.7[1.8]
B6 EWR-FLL APR 5>4[5]
B6 EWR-JAX APR 1.0>0.6[1.0]
B6 EWR-LAS APR 1.8>0.6[1.8]
B6 EWR-LAX APR 5>3[5]
B6 EWR-MBJ APR 0.9>0.1[0.9]
B6 EWR-MCO APR 6>5[6]
**B6 EWR-MVY JUL 0>1.5[0] AUG 0>1.4[0] SEP 0>0.3[0]
B6 EWR-NAS APR 0.9>0.0[0.9]
**B6 EWR-PAP JUL 0>0.6[0] AUG 0>0.5[0] SEP 0>0.6[0] OCT 0>0.6[0] NOV 0>0.6[0] DEC 0>0.6[0]
B6 EWR-PBI APR 3>1.7[3]
B6 EWR-PHX APR 1.8>0.8[1.8]
B6 EWR-PLS APR 0.9>0.1[0.9]
**B6 EWR-POP JUL 0>0.7[0] AUG 0>0.7[0] SEP 0>0.7[0] OCT 0>0.7[0] NOV 0>0.7[0] DEC 0>0.7[0]
B6 EWR-PUJ APR 0.9>0.3[0.9]
B6 EWR-RDU APR 3>0.6[3]
B6 EWR-RSW APR 2>1.7[2]
B6 EWR-SAN APR 1.0>0.6[1.0]
B6 EWR-SDQ APR 1.3>2[1.3]
**B6 EWR-SEA JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
B6 EWR-SFO APR 1.7>0.5[1.7]
B6 EWR-SRQ APR 0.9>0.4[0.9]
**B6 EWR-STT JUL 0>0.6[0] AUG 0>0.6[0] SEP 0>0.6[0] OCT 0>0.6[0] NOV 0>0.6[0] DEC 0>0.5[0]
B6 EWR-SXM APR 0.9>0.1[0.9]
**B6 EWR-UVF JUL 0>0.5[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0]
**B6 FCA-JFK JUL 0>0.4[0] AUG 0>0.5[0]
B6 FLL-GYE APR 1.0>0.5[1.0]
B6 FLL-HAV APR 3>0.2[3]
B6 FLL-JAX APR 3>0.9[3]
B6 FLL-JFK APR 8>5[8]
B6 FLL-LAS APR 1.8>1.0[1.8]
B6 FLL-LAX APR 5>4[5]
B6 FLL-LGA APR 1.8>1.1[1.8]
B6 FLL-LIM APR 1.0>0.5[1.0]
B6 FLL-MBJ APR 1.4>1.7[1.4]
B6 FLL-MSY APR 1.2>1.7[1.2]
B6 FLL-NAS APR 3>1.7[3]
B6 FLL-PDX APR 0.3>0[0.3]
B6 FLL-PHX APR 0.8>0.3[0.8]
B6 FLL-PIT APR 1.0>0.7[1.0]
B6 FLL-PLS APR 1.0>0.4[1.0]
B6 FLL-POS APR 0.5>0.3[0.5]
B6 FLL-PUJ APR 0.5>0.7[0.5]
B6 FLL-PVD APR 1.0>0.7[1.0]
B6 FLL-SAN APR 1.0>0.3[1.0]
B6 FLL-SEA APR 0.4>0[0.4]
B6 FLL-SFO APR 3>1.6[3]
B6 FLL-UIO APR 1.0>0.6[1.0]
B6 GND-JFK APR 1.0>0.1[1.0]
B6 GYE-JFK APR 1.0>0.7[1.0]
B6 HPN-MCO APR 3>2[3]
B6 HPN-TPA APR 1.7>1.3[1.7]
B6 IAH-JFK APR 1.7>0.6[1.7]
B6 JAX-JFK APR 3>1.0[3]
B6 JAX-LAX APR 0.9>0.3[0.9]
B6 JAX-RDU APR 1.0>0.3[1.0]
B6 JFK-KIN APR 2>1.0[2]
B6 JFK-LAS APR 4>1.5[4]
B6 JFK-LAX APR 9>4[9] MAY 10>9[8]
B6 JFK-LIR APR 0.7>0.3[0.7]
B6 JFK-MBJ APR 3>1.6[3]
B6 JFK-MCO APR 8>5[8]
B6 JFK-MIA APR 4>5[4]
B6 JFK-MSP APR 1.7>0[1.7]
B6 JFK-MSY APR 1.8>0.4[1.8]
B6 JFK-MVY APR 0.2>0[0.2]
B6 JFK-NAS APR 2>0.1[2]
B6 JFK-ORD APR 3>0.8[3]
B6 JFK-PAP APR 1.3>1.0[1.3]
B6 JFK-PBI APR 4>3[4]
B6 JFK-PDX APR 1.0>0.6[1.0]
B6 JFK-PHX APR 1.7>0.9[1.7]
B6 JFK-PLS APR 0.9>0.5[0.9]
B6 JFK-POP APR 1.1>0.7[1.1]
B6 JFK-POS APR 1.0>0[1.0]
B6 JFK-PSE APR 0.8>0[0.8]
B6 JFK-PSP APR 0.7>0.5[0.7]
B6 JFK-PUJ APR 2>1.6[2]
B6 JFK-PWM APR 0.3>0[0.3]
B6 JFK-RDU APR 4>0.6[4]
B6 JFK-RNO APR 0.5>0[0.5]
B6 JFK-ROC APR 3>0.7[3]
B6 JFK-RSW APR 4>2[4]
B6 JFK-SAN APR 3>1.0[3]
B6 JFK-SAV APR 1.8>1.0[1.8]
B6 JFK-SEA APR 1.7>0.6[1.7]
B6 JFK-SFO APR 6>3[6]
B6 JFK-SJO APR 0.5>0.1[0.5]
B6 JFK-SLC APR 1.8>0.8[1.8]
B6 JFK-SMF APR 1.3>0.3[1.3]
B6 JFK-SRQ APR 1.1>1.6[1.1]
B6 JFK-SXM APR 0.9>0.4[0.9]
B6 JFK-SYR APR 1.8>0.7[1.8]
B6 JFK-TPA APR 3>2[3]
B6 JFK-UVF APR 1.1>0.7[1.1]
B6 LAS-LAX APR 1.8>0.6[1.8]
B6 LAS-RDU APR 1.0>0.3[1.0]
B6 LAS-RIC APR 1.0>0[1.0]
B6 LAX-LIR APR 0.3>0[0.3]
B6 LAX-MCO APR 1.0>0.8[1.0]
B6 LAX-PBI APR 0.9>0.3[0.9]
B6 LAX-RDU APR 1.0>0.3[1.0]
B6 LAX-RIC APR 1.0>0[1.0]
B6 LAX-RNO APR 0.9>0.3[0.9]
B6 LAX-SEA APR 0.8>0[0.8]
B6 LAX-SFO APR 1.7>0[1.7]
B6 LAX-SJO APR 0.9>0[0.9]
B6 LAX-SLC APR 1.7>0.3[1.7]
B6 LGA-MCO APR 1.8>1.1[1.8]
**B6 LGA-MVY JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
B6 LGA-PBI APR 1.8>0.9[1.8]
B6 LGA-RSW APR 1.0>0.6[1.0]
B6 LGA-TPA APR 1.8>1.0[1.8]
B6 MBJ-MCO APR 0.9>0[0.9]
B6 MBJ-RDU APR 0.9>0.1[0.9]
B6 MCO-NAS APR 0.6>0[0.6]
B6 MCO-PHL APR 1.8>1.1[1.8]
B6 MCO-PSE APR 1.1>0.6[1.1]
B6 MCO-PVD APR 1.7>1.0[1.7]
B6 MCO-RDU APR 1.0>0.5[1.0]
B6 MCO-RIC APR 1.8>0.9[1.8]
B6 MCO-SDQ APR 1.2>0.6[1.2]
B6 MCO-SFO APR 1.0>0[1.0]
B6 MCO-SJO APR 1.0>0.5[1.0]
B6 ORD-PBI APR 0.8>0[0.8]
B6 PBI-PHL APR 1.8>0.7[1.8]
B6 PBI-PIT APR 0.8>0[0.8]
B6 PVD-TPA APR 1.0>0.8[1.0]
B6 RDU-RSW APR 1.0>0.6[1.0]
B6 RDU-SFO APR 1.0>0[1.0]
B6 RDU-SJU APR 1.0>0.5[1.0]
B6 RDU-TPA APR 1.0>0.6[1.0]
B6 RIC-TPA APR 0.9>0.4[0.9]
B6 SJU-TPA APR 1.1>0.6[1.1]
BA LAS-LHR APR 1.0>0[1.0]
BW JFK-KIN APR 1.0>1.8[1.0] MAY 1.0>1.9[1.0] JUN 1.0>1.8[1.0] JUL 1.0>1.5[0.9]
CM BOS-PTY APR 0.4>0[0.4]
CM LAX-PTY APR 1.5>0.9[1.5]
CM ORD-PTY APR 0.5>0[0.6]
CM PTY-SFO APR 0.4>0[0.4]
DL APN-DTW MAY 0.9>1.7[1.0] JUN 1.0>1.7[1.0] JUL 1.0>1.7[1.0] AUG 1.0>1.7[1.0] SEP 1.0>1.7[1.0] OCT 1.0>1.7[0.7] NOV 1.0>1.7[1.7] DEC 1.0>1.7[1.1]
*DL APN-PLN MAY 0.7>0[0.7] JUN 0.7>0[0.7] JUL 0.7>0[0] AUG 0.7>0[0.7] SEP 0.7>0[0.7] OCT 0.7>0[1.0] NOV 0.7>0[0] DEC 0.7>0[0.6]
DL ATL-CUN MAY 6>5[3]
DL ATL-MEX MAY 6>5[3]
DL ATL-MTY MAY 1.8>0.8[1.0]
DL BDL-MSP APR 3>1.8[3]
DL BOS-CUN MAY 1.0>0.2[1.0]
DL BOS-JAX APR 0.4>0[2]
DL BOS-LAS APR 1.0>0.7[1.0]
DL BOS-RSW APR 0.7>0.3[0.7]
DL CIU-DTW MAY 0.8>1.0[0.8]
**DL CNY-SLC MAY 0>0.9[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0]
DL COS-SLC MAY 1.9>3[1.0] JUN 2>3[2] JUL 2>3[1.9] AUG 2>3[3] SEP 2>3[3] OCT 2>3[3] NOV 2.0>3[3] DEC 2>3[2]
DL CUN-RDU MAY 1.0>0.2[0.1]
DL CVG-SEA JUN 0.7>1.0[0] JUL 0.7>1.0[0] AUG 0.7>1.0[0] SEP 0.7>1.0[0] OCT 0.7>1.0[1.0] NOV 0.7>1.0[0.6] DEC 0.7>1.0[0.7]
DL CWA-DTW APR 1.6>1.0[1.5]
DL DAY-DTW APR 2>1.8[3]
DL DFW-SLC MAY 4>5[4] JUN 4>5[1.5] JUL 4>5[1.9] AUG 4>5[4] SEP 4>5[4] OCT 4>5[5] NOV 4>5[4] DEC 4>5[4]
**DL DRO-SLC MAY 0>0.8[0] JUN 0>2[0] JUL 0>2[0] AUG 0>2[0] SEP 0>2[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0]
DL DTW-FWA MAY 3>2.0[1.0]
DL DTW-HSV APR 0>0.4[0.6]
DL DTW-PLN JUN 2>4[1.7] JUL 2>4[1.1] AUG 2>3[3] SEP 2>3[3]
DL DTW-YYZ APR 3>2[4]
DL ESC-MSP MAY 1.0>0.7[0]
DL FLL-LAX APR 1.0>0.7[1.0]
DL HLN-MSP JUN 0.9>0.6[0]
DL HLN-SLC JUN 3>2[1.5]
DL INL-MSP APR 1.3>1.7[1.7]
DL JFK-PLS MAY 0.2>1.0[0.9] JUN 0.1>0.9[0] JUL 0.2>1.0[0] AUG 0.1>0.9[0]
DL LAS-RDU APR 1.0>0.7[1.0]
DL LIH-SEA APR 0.6>0.4[0.8]
Back
**DL LNK-MSP MAY 0>0.4[3] JUN 0>2[1.5] JUL 0>2[1.0] AUG 0>2[0] SEP 0>2[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0]
DL MCO-SEA JUN 1.4>1.9[0] JUL 1.5>2[0] AUG 1.4>2[1.0] SEP 1.4>2[0] OCT 1.5>2[1.0] NOV 1.4>2[0.8] DEC 1.5>2[1.3]
DL MSP-RHI JUN 2>3[2] JUL 2>3[1.0] AUG 2>3[2]
DL PHX-SLC MAY 5>6[5] JUN 5>6[3] JUL 5>6[3] AUG 5>6[4] SEP 5>6[4] OCT 5>6[5] NOV 5>6[5] DEC 5>6[5]
DL SGU-SLC MAY 4>5[1.0] OCT 4>5[4] NOV 4>5[5]
EI BOS-DUB APR 1.7>0.9[1.7]
EI DUB-JFK APR 2>1.2[2]
EI DUB-MCO APR 0.4>0.1[0.4]
EI DUB-SFO APR 1.0>0.2[1.0]
EW ANC-FRA JUN 0.4>0.2[0] OCT 0.4>0.0[0]
EW FRA-LAS MAY 0.7>0[0.2] JUN 0.7>0[0.3] JUL 0.7>0.4[0.4] AUG 0.7>0.5[0.7] SEP 0.7>0.4[0] OCT 0.7>0.4[0]
EY AUH-IAD APR 1.0>0.4[1.0]
I don't follow G4, but looks like some interesting new stuff
G4 ABE-PIE AUG 0.5>0.7[0.7] SEP 0>0.4[0.3] NOV 0>0.2[0.4]
G4 ABE-SFB AUG 1.0>1.5[1.5] NOV 0>0.7[1.1]
G4 ABQ-AUS OCT 0>0.3[0.4]
G4 ABQ-LAS OCT 0>0.3[0.4]
G4 ALB-BNA MAY 0>0.2[0] JUN 0>0.3[0] JUL 0>0.3[0]
G4 ATW-BNA SEP 0>0.3[0] OCT 0>0.3[0]
G4 ATW-SAV JUN 0>0.3[0] JUL 0>0.3[0]
G4 AUS-BZN JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0]
G4 AUS-IND OCT 0>0.2[0.3]
G4 AUS-XNA JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0]
G4 AVL-DEN OCT 0>0.2[0.3]
G4 AVL-EWR SEP 0>0.3[0.5] OCT 0>0.5[0.6]
G4 AVL-FLL AUG 1.0>1.5[1.6] SEP 0>1.5[1.6] OCT 0>1.7[2] NOV 0>0.6[1.9]
G4 AVL-LAS SEP 0>0.3[0] OCT 0>0.3[0]
G4 AVL-PGD SEP 0>0.3[0.4] OCT 0>0.6[0.7]
G4 AVL-PIE AUG 0.8>1.2[1.4] SEP 0>0.7[1.0] OCT 0>1.4[1.9] NOV 0>0.7[1.3]
G4 AVL-SFB AUG 0.8>1.3[1.6] OCT 0>1.6[1.7] NOV 0>0.7[1.2]
G4 AVL-VPS JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0]
G4 AZA-BIL NOV 0>0.2[0.4]
G4 AZA-BIS NOV 0>0.3[0.5]
G4 AZA-BLI NOV 0>0.2[0.4]
G4 AZA-CID OCT 0>0.5[0.4] NOV 0>0.2[0.5]
G4 AZA-EUG OCT 0>0.3[0.4]
G4 AZA-FAR AUG 0.3>0.5[0.5] NOV 0>0.5[0.7]
G4 AZA-FCA OCT 0>0.2[0.3]
G4 AZA-FSD AUG 0.2>0.4[0.5] NOV 0>0.3[0.5]
G4 AZA-GRR OCT 0>0.4[0.5]
G4 AZA-HOU SEP 0>0.3[0] OCT 0>0.3[0]
G4 AZA-MOT OCT 0>0.3[0.4]
G4 AZA-OAK OCT 0>0.3[0.4]
G4 AZA-PIA OCT 0>0.5[0.4]
G4 AZA-PVU AUG 1.0>1.6[1.8] SEP 0>1.4[1.5] NOV 0>0.7[1.5]
G4 AZA-RAP OCT 0>0.3[0.4]
G4 AZA-RDM OCT 0>0.3[0.2]
G4 AZA-RFD OCT 0>0.3[0.4]
G4 AZA-SAN JUN 0>0.5[0] JUL 0>0.6[0] AUG 0>0.3[0]
G4 AZA-SBN OCT 0>0.4[0.3]
G4 AZA-SMX SEP 0>0.3[0] OCT 0>0.3[0]
G4 BGR-FLL JUN 0>0.3[0] JUL 0>0.3[0]
G4 BGR-PIE SEP 0>0.3[0.4] NOV 0>0.2[0.4]
G4 BGR-SFB AUG 0.3>0.5[0.5] OCT 0>0.6[0.5] NOV 0>0.3[0.5]
G4 BIL-PDX MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0]
G4 BIS-LAS OCT 0>0.3[0.6]
G4 BLI-LAS AUG 0.8>1.5[1.6] SEP 0>1.1[1.5] NOV 0>0.8[1.4]
G4 BLI-OAK SEP 0>0.3[0.4] OCT 0>0.3[0.4]
G4 BLI-PSP OCT 0>0.5[0.6] NOV 0>0.3[0.5]
G4 BLV-CHS OCT 0>0.3[0]
G4 BLV-LAS SEP 0>0.3[0] OCT 0>0.3[0]
G4 BLV-PIE OCT 0>0.4[0.5]
G4 BLV-VPS AUG 0.9>1.4[1.4] SEP 0>1.0[1.1] OCT 0>1.1[0.9] NOV 0>0.4[0.6]
G4 BNA-BOI JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0]
G4 BNA-EYW SEP 0>0.3[0] OCT 0>0.3[0]
G4 BNA-FAR OCT 0>0.3[0.4]
G4 BNA-GSO SEP 0>0.3[0] OCT 0>0.3[0]
G4 BNA-MDT OCT 0>0.2[0.3]
G4 BNA-MFE JUN 0>0.3[0] JUL 0>0.3[0]
G4 BNA-PGD OCT 0>0.4[0.3]
G4 BNA-PSM JUN 0>0.3[0] JUL 0>0.3[0]
G4 BNA-SRQ OCT 0>0.2[0.3]
G4 BOI-PSP OCT 0>0.3[0]
G4 BOI-SNA SEP 0>0.3[0] OCT 0>0.3[0]
G4 BOS-GRR SEP 0>0.3[0] OCT 0>0.3[0]
G4 BOS-IND JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0]
G4 BOS-ORF JUN 0>0.3[0] JUL 0>0.3[0]
G4 BOS-SRQ SEP 0>0.3[0] OCT 0>0.3[0]
G4 BZN-OAK JUN 0>0.3[0] JUL 0>0.3[0]
G4 BZN-SAN JUN 0>0.3[0] JUL 0>0.3[0]
G4 CHS-IND SEP 0>0.3[0] OCT 0>0.3[0]
G4 CKB-MDW JUN 0>0.3[0] JUL 0>0.3[0]
G4 CKB-VPS JUN 0>0.3[0] JUL 0>0.3[0]
G4 CLE-SRQ OCT 0>0.2[0.3]
G4 CVG-DEN SEP 0>0.3[0] OCT 0>0.3[0]
G4 CVG-EYW JUN 0>0.2[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0]
G4 CVG-FLL AUG 0.8>1.1[1.2] SEP 0>0.6[0.7] OCT 0>0.7[0.9] NOV 0>0.3[1.0]
G4 CVG-JAX OCT 0>0.3[0.4]
G4 CVG-LAS OCT 0>0.5[0.4]
G4 CVG-PGD AUG 0.6>0.9[1.0] NOV 0>0.5[1.1]
G4 CVG-PIE AUG 0.7>1.0[1.2] NOV 0>0.4[1.0]
G4 CVG-SAV OCT 0>0.5[0.6]
G4 CVG-SFB AUG 0.7>1.0[1.3] SEP 0>0.8[0.7] NOV 0>0.4[0.9]
G4 CVG-SRQ OCT 0>0.5[0.6]
G4 CVG-VPS AUG 1.0>1.6[1.6] SEP 0>1.2[1.4] OCT 0>1.2[1.4] NOV 0>0.4[0.8]
G4 DEN-PIA SEP 0>0.3[0] OCT 0>0.3[0]
G4 DEN-PVU SEP 0>0.3[0] OCT 0>0.3[0]
G4 DEN-TYS SEP 0>0.3[0] OCT 0>0.2[0]
G4 DSM-HOU JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0]
G4 DSM-LAS NOV 0>0.3[0.5]
G4 DSM-LAX SEP 0>0.3[0] OCT 0>0.3[0]
G4 DSM-PDX JUL 0>0.3[0]
G4 DSM-SAN JUL 0>0.3[0]
G4 ELP-LAS OCT 0>0.3[0.4]
G4 EVV-SFB OCT 0>0.4[0.3]
G4 EWR-GRR SEP 0>0.3[0] OCT 0>0.3[0]
G4 EWR-SAV OCT 0>0.2[0.3]
G4 EWR-TYS OCT 0>0.4[0.5]
G4 EYW-PIT JUN 0>0.3[0] JUL 0>0.3[0]
G4 EYW-SFB SEP 0>0.3[0] OCT 0>0.3[0]
G4 FAR-PIE OCT 0>0.3[0]
G4 FAT-LAS AUG 0.9>1.6[1.6] SEP 0>1.6[1.7] OCT 0>1.8[1.7] NOV 0>0.9[1.3]
G4 FCA-SAN JUN 0>0.3[0] JUL 0>0.3[0]
G4 FLL-IND OCT 0>0.5[0.6]
G4 FLL-ORF OCT 0>0.2[0.3]
G4 FLL-PBG MAY 0.3>0[0.4] JUN 0.4>0.2[0] OCT 0>0.3[0.4]
G4 FLL-SYR OCT 0>0.2[0.3]
G4 FLL-TYS AUG 0.3>0.6[0.7] SEP 0>0.6[0.7] OCT 0>0.8[0.9] NOV 0>0.4[0.7]
G4 FLL-USA AUG 0.6>0.9[1.2] SEP 0>0.6[0.7] OCT 0>0.7[0.9] NOV 0>0.3[0.7]
G4 FNT-LAS SEP 0>0.3[0] OCT 0>0.3[0]
G4 FNT-PGD NOV 0>0.3[0.5]
G4 FNT-PIE NOV 0>0.2[0.5]
G4 FSD-LAS OCT 0>0.3[0.4]
G4 FWA-LAS SEP 0>0.3[0] OCT 0>0.3[0]
G4 FWA-PGD NOV 0>0.3[0.5]
G4 FWA-PIE NOV 0>0.3[0.4]
G4 FWA-SFB OCT 0>0.4[0.5]
G4 FWA-SRQ OCT 0>0.2[0.3]
G4 GEG-LAS SEP 0>0.3[0] OCT 0>0.3[0]
G4 GEG-SNA SEP 0>0.3[0] OCT 0>0.3[0]
G4 GJT-SNA SEP 0>0.3[0] OCT 0>0.3[0]
G4 GPT-SFB OCT 0>0.3[0.2]
G4 GRR-LAS AUG 0.3>0.6[0.6] SEP 0>0.6[0.5] NOV 0>0.3[0.5]
G4 GRR-LAX SEP 0>0.3[0] OCT 0>0.3[0]
G4 GRR-PDX JUN 0>0.3[0] JUL 0>0.3[0]
G4 GRR-PGD NOV 0>0.3[0.6]
G4 GRR-PIE AUG 0.4>0.6[0.9] SEP 0>0.6[0.7] OCT 0>0.8[0.9] NOV 0>0.4[0.7]
G4 GRR-SFB AUG 0.6>0.9[1.2] SEP 0>0.6[0.5] OCT 0>0.6[0.7] NOV 0>0.3[0.8]
G4 GRR-SRQ OCT 0>0.2[0.3]
G4 GRR-VPS SEP 0>0.3[0] OCT 0>0.3[0]
G4 GSO-PIE OCT 0>0.2[0.3]
G4 HOU-LEX JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0]
G4 HOU-PGD OCT 0>0.2[0]
G4 HOU-SGF JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0]
G4 HTS-SFB OCT 0>0.5[0.6] NOV 0>0.2[0.5]
G4 HTS-VPS OCT 0>0.2[0.3]
G4 IAG-PGD NOV 0>0.2[0.4]
G4 IAG-SFB OCT 0>0.2[0.3]
G4 IDA-PDX SEP 0>0.3[0] OCT 0>0.3[0]
G4 IND-LAS OCT 0>0.2[0.4]
G4 IND-LAX JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0]
G4 IND-PGD OCT 0>0.8[0.9]
G4 IND-PIE AUG 0.5>0.7[0.8] SEP 0>0.6[0.7] OCT 0>0.9[1.0] NOV 0>0.3[0.7]
G4 IND-SAV SEP 0>0.3[0] OCT 0>0.2[0]
G4 IND-SFB OCT 0>0.8[0.9]
G4 IND-VPS SEP 0>0.3[0] OCT 0>0.2[0]
G4 JAX-LCK SEP 0>0.3[0] OCT 0>0.3[0]
G4 JAX-ORF OCT 0>0.2[0.3]
G4 LAS-LAX JUN 0.6>0[0] JUL 0.6>0[0] AUG 0.3>0[0.2]
G4 LAS-MEM AUG 0.5>0.8[0.9] SEP 0>0.6[0.8] OCT 0>0.6[0.8] NOV 0>0.3[0.6]
G4 LAS-MFE AUG 0.7>1.1[1.2] SEP 0>1.1[0.8] OCT 0>1.0[0.9] NOV 0>0.5[0.7]
G4 LAS-MFR SEP 0>0.3[0.5] OCT 0>0.5[0.6] NOV 0>0.3[0.5]
G4 LAS-MOT NOV 0>0.2[0.5]
G4 LAS-OAK AUG 0.3>0.6[0.9] SEP 0>0.6[0.7] OCT 0>0.6[0.8] NOV 0>0.3[0.6]
G4 LAS-RNO AUG 0.5>1.0[1.4] OCT 0>1.1[1.3] NOV 0>0.5[1.1]
G4 LAS-SAT OCT 0>0.2[0.3]
G4 LAS-SCK AUG 0.8>1.3[1.6] SEP 0>1.2[1.7] OCT 0>1.6[1.7] NOV 0>0.9[1.4]
G4 LAS-SDF SEP 0>0.3[0] OCT 0>0.3[0]
G4 LAS-SGF OCT 0>0.4[0.3]
G4 LAS-SMX AUG 0.4>0.6[0.5] SEP 0>0.4[0.6] NOV 0>0.2[0.5]
G4 LAS-SNA AUG 0.2>0.4[0] SEP 0>0.6[0] OCT 0>0.6[0] NOV 0>0.3[0]
G4 LAX-OMA JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0]
G4 LAX-RAP JUN 0>0.3[0] JUL 0>0.3[0]
G4 LAX-SHV JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0]
G4 LCK-MYR AUG 0.5>0.7[0.8]
G4 LCK-PGD NOV 0>0.2[0.4]
G4 LCK-SAV OCT 0>0.4[0.3]
G4 LCK-VPS OCT 0>0.2[0.4]
G4 LEX-PGD NOV 0>0.3[0.5]
G4 LEX-SFB NOV 0>0.3[0.5]
G4 LIT-PIE JUN 0>0.3[0] JUL 0>0.3[0] OCT 0>0.2[0]
G4 MCI-PGD OCT 0>0.2[0.3]
G4 MDT-PGD OCT 0>0.3[0.4]
G4 MDT-PIE OCT 0>0.3[0.4]
G4 MDT-SFB SEP 0>0.3[0.4] OCT 0>0.9[0.7] NOV 0>0.4[0.7]
G4 MDW-PGD SEP 0>0.3[0] OCT 0>0.3[0]
G4 MFR-SNA SEP 0>0.3[0] OCT 0>0.3[0]
G4 MLI-PGD OCT 0>0.2[0]
G4 MRY-PDX SEP 0>0.3[0] OCT 0>0.3[0]
G4 MSO-PDX MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0]
G4 MSO-SNA SEP 0>0.3[0] OCT 0>0.3[0]
G4 MSY-USA OCT 0>0.2[0.3]
G4 MYR-PIT AUG 0.4>0.5[0.6]
G4 OKC-VPS OCT 0>0.3[0.4]
G4 OMA-SFB OCT 0>0.3[0]
G4 OWB-SFB OCT 0>0.2[0.3]
G4 PDX-SMX SEP 0>0.3[0] OCT 0>0.3[0]
G4 PGD-PIA SEP 0>0.4[0.3] NOV 0>0.2[0.4]
G4 PGD-PIT OCT 0>0.3[0.4]
G4 PGD-RAP JUN 0>0.3[0] JUL 0>0.3[0]
G4 PGD-RFD NOV 0>0.3[0.5]
G4 PGD-RIC OCT 0>0.3[0.2]
G4 PGD-SDF NOV 0>0.2[0.5]
G4 PGD-SWF OCT 0>0.2[0.3]
G4 PGD-USA OCT 0>0.3[0.4]
G4 PIA-SRQ OCT 0>0.3[0]
G4 PIE-PSM JUN 0>0.3[0] JUL 0>0.3[0]
G4 PIE-SDF OCT 0>0.4[0.5]
G4 PIE-SGF OCT 0>0.4[0.5] NOV 0>0.2[0.4]
G4 PIE-SYR NOV 0>0.2[0.4]
G4 PIE-TUL OCT 0>0.3[0]
G4 PIE-TYS AUG 0.5>0.8[0.8] NOV 0>0.5[0.7]
G4 PIE-USA AUG 0.5>0.8[0.9] SEP 0>0.6[0.5] NOV 0>0.4[0.7]
G4 PIT-SAV OCT 0>0.2[0.3]
G4 PSC-SAN JUN 0>0.3[0] JUL 0>0.3[0]
G4 PVU-SNA SEP 0>0.3[0] OCT 0>0.3[0]
G4 RIC-SFB OCT 0>0.3[0.2]
G4 RNO-SNA SEP 0>0.3[0] OCT 0>0.3[0]
G4 SAV-SWF OCT 0>0.2[0.3]
G4 SBN-SRQ OCT 0>0.2[0]
G4 SCE-SFB OCT 0>0.2[0.1]
G4 SDF-VPS OCT 0>0.5[0.6]
G4 SFB-SGF SEP 0>0.3[0.4] OCT 0>0.3[0.4]
G4 SFB-SWF OCT 0>0.2[0.3]
G4 SFB-TOL OCT 0>0.2[0.3]
G4 SFB-TYS AUG 0.6>1.0[1.1] SEP 0>0.9[1.0] OCT 0>1.3[1.7] NOV 0>0.5[1.3]
G4 SFB-USA AUG 0.3>0.6[0.7] SEP 0>0.6[0.5] NOV 0>0.3[0.5]
G4 SGF-VPS OCT 0>0.2[0.3]
G4 SRQ-USA JUN 0>0.3[0] JUL 0>0.3[0] OCT 0>0.2[0]
G4 STC-VPS JUN 0>0.2[0] JUL 0>0.3[0]
G4 TYS-VPS OCT 0>0.3[0.4]
G4 USA-VPS OCT 0>0.2[0.3]
IB BCN-BOS APR 0.6>0[0.6] MAY 0.6>0[0.4]
IB BCN-SFO APR 0.4>0[0.4] MAY 0.4>0[0.3]
KE BOS-ICN APR 0.7>0.4[0.7] MAY 1.0>0.7[0.1] JUN 1.0>0.7[0] JUL 1.0>0.7[0] AUG 1.0>0.7[0.1] SEP 1.0>0.7[1.0] OCT 1.0>0.7[0.9]
KE DFW-ICN APR 0.7>0.4[0.7]
KE HNL-ICN APR 1.0>0[1.0]
KE HNL-NRT APR 1.0>0[1.0]
KE IAD-ICN APR 1.0>0.6[1.0]
KE ICN-JFK APR 2>1.0[2]
KE ICN-LAS APR 0.7>0[0.7]
KE ICN-LAX APR 2>1.6[2]
KE ICN-ORD APR 1.0>0.4[1.0]
KE ICN-SEA APR 1.0>0.4[1.0]
KE ICN-SFO APR 2>0.7[2]
KL AMS-IAH APR 1.0>1.2[1.0]
LF CEC-OAK MAY 0>1.1[1.0] JUN 0>1.2[1.0] JUL 0>1.3[1.0] AUG 0>1.3[1.0] SEP 0>1.2[1.0]
LH ATL-FRA MAY 1.0>0.4[0.5] JUN 1.0>0.4[0.5] JUL 1.0>0.4[0.5] AUG 1.0>0.4[1.0] SEP 1.0>0.4[0] OCT 1.0>0.5[0.2]
LH AUS-FRA MAY 0.7>0[0.4] JUN 0.7>0.4[0.3] JUL 0.7>0.4[0.4] AUG 0.7>0.4[0.7] SEP 0.7>0.4[0] OCT 0.7>0.5[0.2]
LH BOS-FRA MAY 1.7>1.0[0.6] JUN 2>1.0[0.9] JUL 2>1.0[1.0] AUG 2>1.0[2] SEP 2.0>1.0[1.0]
LH BOS-MUC MAY 1.0>0.4[0.6] JUN 1.0>0.7[0.5]
LH CLT-MUC MAY 1.0>0.5[0.5] JUN 1.0>0.7[0.5] JUL 1.0>0.7[0.5] AUG 1.0>0.7[1.0] SEP 1.0>0.7[0.4] OCT 1.0>0.7[0.6]
LH DEN-FRA MAY 1.0>0.7[0.6] JUN 1.0>0.7[0.5] JUL 1.0>0.7[0.5] AUG 1.0>0.7[1.0] SEP 1.0>0.7[0] OCT 1.0>0.7[0.2]
LH DEN-MUC MAY 1.0>0.4[0.6] JUN 1.0>0.7[0.5] JUL 1.0>0.7[0.5] AUG 1.0>0.7[1.0] SEP 1.0>0.7[0.7] OCT 1.0>0.7[0.8]
LH DFW-FRA MAY 1.0>0.5[0.5] JUN 1.0>0.7[0.5] JUL 1.0>0.7[0.5] AUG 1.0>0.7[1.0] SEP 1.0>0.7[0.4] OCT 1.0>0.7[0.5]
LH DTW-FRA MAY 1.0>0.4[0.5] JUN 1.0>0.7[0.5] JUL 1.0>0.7[0.5] AUG 1.0>0.7[1.0] SEP 1.0>0.7[0.4] OCT 1.0>0.7[0.5]
LH EWR-MUC MAY 1.0>0.7[0.6]
LH FRA-IAD MAY 2>1.0[0.8] JUN 2>1.0[0.9] JUL 2>1.0[1.0] AUG 2>1.0[2] SEP 2>1.0[0.7] OCT 1.3>1.0[0.8]
LH FRA-JFK MAY 2>1.0[1.2] JUN 2>1.0[0.9] JUL 2>1.0[1.0] AUG 2>1.0[2] SEP 2>1.0[1.0] OCT 2>1.1[1.3]
LH FRA-LAX MAY 2>1.0[0.6] JUN 2>1.0[0.9] JUL 2>1.0[1.0] AUG 2>1.0[2] SEP 2>1.0[1.0] OCT 1.9>1.0[1.0]
LH FRA-MCO MAY 1.0>0[0.6] JUN 1.0>0.4[0.5] JUL 1.0>0.7[0.5] AUG 1.0>0.7[1.0] SEP 1.0>0.7[0.4] OCT 1.0>0.7[0.5]
LH FRA-ORD MAY 2>1.0[1.5] JUN 2>1.0[1.2] JUL 2>1.0[1.2] AUG 2>1.0[2] SEP 2>1.0[1.0] OCT 2>1.1[1.3]
LH FRA-PHL MAY 1.0>0.4[0.5] JUN 1.0>0.7[0.5] JUL 1.0>0.7[0.5] AUG 1.0>0.7[1.0] SEP 1.0>0.7[0.4] OCT 1.0>0.7[0.5]
LH FRA-SAN MAY 0.7>0[0.4] JUN 0.7>0.4[0.3] JUL 0.7>0.4[0.4] AUG 0.7>0.5[0.7] SEP 0.7>0.4[0] OCT 0.7>0.4[0.2]
LH FRA-SEA MAY 1.0>0.7[0.6]
LH FRA-SFO MAY 1.0>0.7[0.6]
LH FRA-TPA MAY 0.9>0[0.5] JUN 0.8>0[0.4] JUL 0.9>0.4[0.5] AUG 0.9>0.5[0.9] SEP 0.8>0.4[0] OCT 0.9>0.4[0.2]
LH IAD-MUC MAY 1.0>0.4[0.6] JUN 1.0>0.7[0.5] JUL 1.0>0.7[0.5] AUG 1.0>0.7[1.0] SEP 1.0>0.7[0] OCT 1.0>0.7[0.2]
LH JFK-MUC MAY 1.0>0[0.6] JUN 1.0>0.4[0.5] JUL 1.0>0.4[0.5] AUG 1.0>0.4[1.0] SEP 1.0>0.4[0] OCT 1.0>0.5[0.2]
LH LAX-MUC MAY 1.0>0.7[0.6] JUN 1.0>0.7[0.5]
LH MUC-ORD MAY 2>0.7[0.8] JUN 2>1.0[0.9] JUL 2>1.0[1.2] AUG 2>1.0[2] SEP 2>1.0[1.0] OCT 2.0>1.0[1.0]
LH MUC-SFO MAY 1.0>0.4[0.6] JUN 1.0>0.7[0.5] JUL 1.0>0.7[0.5] AUG 1.0>0.7[1.0] SEP 1.0>0.7[0.7] OCT 1.0>0.7[0.8]
LX BOS-ZRH MAY 1.0>0.4[0.5] JUN 1.4>0.7[0.5] JUL 2>1.0[1.0] AUG 2>1.0[2] SEP 2>1.0[0.4] OCT 1.9>1.0[0.6]
LX EWR-ZRH MAY 1.0>0.7[1.0]
LX GVA-JFK MAY 1.0>0[0.5] JUN 1.0>0[0.5] JUL 1.0>0[0.5] AUG 1.0>0[1.0] SEP 1.0>0[0] OCT 1.0>0.0[0.2]
LX JFK-ZRH MAY 2>1.0[1.2] JUN 2>1.0[0.9] JUL 2>1.0[1.3] AUG 2>1.0[2] SEP 2>1.0[0.7] OCT 2.0>1.0[1.0]
LX LAX-ZRH MAY 1.0>0.4[0.6] JUN 1.0>0.7[0.5] JUL 1.0>0.7[0.5] AUG 1.0>0.7[1.0] SEP 1.0>0.7[0.4] OCT 1.0>0.7[0.6]
LX MIA-ZRH MAY 1.7>0.5[0.9] JUN 1.0>0.7[0.6] JUL 1.0>0.7[0.5] AUG 1.0>0.7[1.0] SEP 1.0>0.7[0.4] OCT 1.0>0.8[0.8]
LX ORD-ZRH MAY 1.0>0.7[0.9] JUN 1.7>1.0[0.6] JUL 1.7>1.0[1.0] AUG 1.7>1.0[1.7] SEP 1.7>1.0[0.7] OCT 1.5>1.0[0.8]
LX SFO-ZRH MAY 1.0>0.4[0.6] JUN 1.0>0.7[0.5] JUL 1.0>0.7[0.6] AUG 1.0>0.7[1.0] SEP 1.0>0.7[0.4] OCT 1.0>0.7[0.6]
M5 BFI-ESD APR 0>1.0[0] MAY 0>1.1[1.5] JUN 0>1.0[3] AUG 0>3[4] SEP 0>0.9[3]
M5 BFI-FRD MAY 0>1.8[1.5] JUN 0>1.8[3] JUL 0>2[4] AUG 0>2[5] SEP 0>1.4[4]
M5 BFI-PAE APR 0.5>0[0.5]
M5 ESD-FRD APR 0>2[0] MAY 0>2[1.9] JUN 0>2[4] JUL 0>3[4] AUG 0>3[4] SEP 0>1.7[3]
M5 FRD-PAE APR 0.5>0[0.5]
NH HND-HNL APR 0.5>0.3[0.5] MAY 1.0>0.3[0.3] JUN 1.0>0.3[0.5]
NH HND-IAD APR 0.6>0.4[0.6] MAY 1.0>0.5[0.6] JUN 1.0>0.4[0.5]
NH HND-IAH APR 0.7>0.5[0.7] MAY 1.0>0.5[1.0] JUN 1.0>0.4[0.5]
NH HND-JFK MAY 1.0>0.6[0.3] JUN 1.0>0.6[0.5]
NH HND-ORD APR 0.4>0[0.4] MAY 1.0>0[0.2] JUN 1.0>0[0.5]
NH HND-SEA APR 0.4>0.1[0.4] MAY 1.0>0[0.6] JUN 1.0>0[0.5]
NH HND-SFO APR 0.6>0.4[0.6] MAY 1.0>0.4[0.4] JUN 1.0>0.4[0.3]
NH HNL-NRT APR 0.8>0[0.8] MAY 2>0[1.9] JUN 2>0[1.1]
NH LAX-NRT MAY 1.0>0.6[1.0] JUN 1.0>0.6[1.0]
**NK FLL-SDF JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
NK IAH-SAP APR 0.8>0.6[0.8]
NK IND-RSW APR 0.8>1.1[0.8]
**NK LAS-MKE JUN 0>0.2[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
**NK LAS-SDF JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
**NK LAX-MKE JUN 0>0.2[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
**NK LAX-SDF JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
**NK MCO-MKE JUN 0>0.2[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
**NK MCO-SDF JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
NK MSP-RSW APR 0.4>0.7[0.4]
OS EWR-VIE MAY 1.0>0.7[0.6]
OS IAD-VIE MAY 1.0>0.7[0.5]
OS JFK-VIE MAY 1.0>0.4[0.6] JUN 1.0>0.4[0.5] JUL 1.0>0.5[0.7] AUG 1.0>0.4[1.0] SEP 1.0>0.4[0] OCT 1.0>0.5[0.2]
OS LAX-VIE MAY 0.7>0[0.4] JUN 0.7>0[0.3] JUL 0.7>0[0.5] AUG 0.7>0[0.7] SEP 0.7>0[0] OCT 0.7>0[0]
OS ORD-VIE MAY 1.0>0.7[0.9]
OZ HNL-ICN APR 1.0>0[1.0]
OZ ICN-JFK APR 2.0>1.0[2.0]
OZ ICN-LAX APR 2>1.3[2]
OZ ICN-SEA APR 1.0>0.4[1.0]
OZ ICN-SFO APR 1.0>0.6[1.0]
PR CEB-LAX APR 0.4>0[0.4] MAY 0.4>0[0] JUN 0.4>0[0.4] JUL 0.5>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0] OCT 0.4>0[0.1]
PR MNL-SFO JUN 0.7>1.0[0.8] JUL 0.7>1.0[1.9] AUG 0.7>1.0[2]
PS JFK-KBP MAY 0.9>0[0.7]
PY GEO-MIA DEC 0.4>0[0.6]
QF BNE-LAX APR 1.0>0[1.0] MAY 1.0>0[1.1] JUN 1.0>0[0.0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0.0[0.2]
QF BNE-ORD APR 0.6>0[0.6] MAY 0.6>0[0] JUN 0.6>0[0] JUL 0.6>0[0] AUG 0.5>0[0] SEP 0.6>0[0] OCT 0.6>0[0.1]
QF BNE-SFO APR 0.4>0[0.4] MAY 0.4>0[0.3] JUN 0.4>0[0] JUL 0.4>0[0] AUG 0.5>0[0] SEP 0.4>0[0] OCT 0.4>0[0.1]
QF DFW-SYD APR 1.0>0[1.0] MAY 1.0>0[0.8] JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0.0[0.2]
QF HNL-SYD APR 0.7>0[0.7] MAY 0.7>0[0.7] JUN 0.7>0[0] JUL 0.7>0[0] AUG 0.7>0[0] SEP 0.7>0[0] OCT 0.7>0.0[0.2]
QF JFK-LAX APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0.0[0.2]
QF LAX-MEL APR 1.2>0[1.2] MAY 1.1>0[1.1] JUN 1.1>0[0] JUL 1.2>0[0.0] AUG 1.1>0[0] SEP 1.2>0[0] OCT 1.1>0.0[0.3]
QF LAX-SYD APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0.0[0.2]
QF MEL-SFO APR 0.6>0[0.6] MAY 0.6>0[0.3] JUN 0.6>0[0] JUL 0.6>0[0] AUG 0.5>0[0] SEP 0.6>0[0] OCT 0.6>0.0[0.1]
QF SFO-SYD APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0.0[0.2]
QG TRT-UPG APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0] NOV 0>0.3[0] DEC 0>0.3[0.4]
S4 BOS-PDL JUN 1.0>0.6[0] SEP 1.0>0.7[0.5]
SN BRU-IAD APR 1.0>0[1.0] MAY 1.0>0[0.4] JUN 1.0>0.6[0.6]
SN BRU-JFK APR 1.0>0[1.0] MAY 1.0>0[0.4] JUN 1.0>0.6[0.6]
SQ FRA-JFK MAY 1.0>0[0]
SQ JFK-SIN MAY 0>1.0[0]
SQ SFO-SIN MAY 1.4>2[1.4]
SU IAD-SVO MAY 0.5>0[0] JUN 0.4>0[0.2] JUL 0.5>0[0.4] AUG 0.4>0[0] SEP 0.3>0[0.1]
SU JFK-SVO MAY 3>1.0[1.9] JUN 3>1.0[1.6] JUL 3>1.0[3] AUG 3>1.0[2] SEP 3>1.0[2] OCT 3>1.0[3]
SV IAD-RUH APR 0.6>0.3[0.6]
SY BOS-MSP APR 0.4>0[0.4]
SY CUN-MSP APR 1.1>0.9[1.1]
SY EWR-MSP APR 0.5>0.0[0.5]
SY LAX-MSP APR 1.2>0.8[1.2]
SY MSP-PSP APR 0.7>0.5[0.7]
SY MSP-PVR APR 0.6>0.3[0.6]
SY MSP-SEA APR 0.5>0.2[0.5]
TK ATL-IST APR 0.7>0.4[0.7]
TK BOS-IST APR 1.0>0.4[1.0]
TK IAD-IST APR 1.4>1.0[1.4]
TK IAH-IST APR 1.0>0.6[1.0]
TK IST-JFK APR 3>2[3]
TK IST-LAX APR 1.6>1.0[1.6]
TK IST-MIA APR 1.0>0.6[1.0]
TK IST-ORD APR 1.4>1.0[1.4]
TK IST-SFO APR 1.0>0.6[1.0]
TP BOS-LIS APR 1.0>0.6[1.0] MAY 1.0>0.6[0.3]
TP EWR-LIS APR 2>1.0[2] MAY 2>1.0[0.8]
TP IAD-LIS APR 1.0>0.4[1.0] MAY 1.0>0.4[0.0]
TP LIS-MIA APR 1.0>0.4[1.0] MAY 1.0>0.5[0.3]
TP LIS-ORD APR 0.7>0[0.7] MAY 0.7>0[0]
TP LIS-SFO APR 0.6>0[0.6] MAY 0.6>0[0]
UA DEN-HLN MAY 2>0.7[1.9] JUN 1.4>1.1[2.0]
UA DEN-PNS MAY 0.1>0.7[0]
**UA EGE-IAH JUN 0.3>0[0] JUL 0.3>0[0]
**UA EGE-ORD JUN 0.3>0[0] JUL 0.3>0[0] AUG 0.3>0[0.5]
UA HHH-ORD MAY 0.3>0.8[0.2] JUN 0.3>1.0[0.1] JUL 0.3>1.0[0] AUG 0.3>1.0[0.3]
UA IAH-POS APR 1.0>0[1.0]
UP FLL-FPO APR 0.3>0.5[0.4]
UP MCO-NAS MAY 0.4>0.1[1.5]
UP MHH-PBI APR 0>0.3[0]
UP MIA-NAS APR 0.5>0.1[0.4] MAY 0.7>0.2[3]
WK LAS-ZRH SEP 0.5>0.3[0.1]
WK SAN-ZRH JUL 0.3>0[0] AUG 0.3>0[0]
WN ABQ-BWI APR 0.8>0.1[0.8] MAY 1.2>0.9[1.5]
WN ABQ-DAL APR 4>3[4]
WN ABQ-LAS APR 3>2.0[3]
WN ABQ-LAX APR 0.6>0[0.6] MAY 1.0>0.7[2]
WN ABQ-SAN APR 0.9>0.3[0.9] MAY 1.0>0.7[1.7]
WN ALB-DEN APR 0.6>0[0.6] MAY 1.0>0.7[0.8]
WN ALB-MDW APR 1.6>0.9[1.6]
WN AMA-DAL APR 3>2[3]
WN ATL-AUS APR 2>1.1[2]
WN ATL-BWI APR 5>4[5]
WN ATL-CLE APR 1.6>1.0[1.6]
WN ATL-CMH APR 2>1.9[2]
WN ATL-DAL APR 5>4[5]
WN ATL-DCA APR 3>1.9[3]
**WN ATL-ECP APR 0.4>1.0[0.4] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>0.5[0]
WN ATL-GSP APR 3>2[3]
WN ATL-IAD APR 2>1.4[2]
WN ATL-IND APR 3>2.0[3]
WN ATL-JAX APR 2>1.7[2]
WN ATL-MCI APR 2>1.1[2]
WN ATL-MCO APR 5>4[5]
WN ATL-MDW APR 6>4[6]
WN ATL-MKE APR 1.6>1.0[1.6]
WN ATL-MSY APR 3>1.9[3]
WN ATL-OAK APR 1.0>0.4[1.0]
WN ATL-OMA APR 2>1.7[2]
WN ATL-PHL APR 2>1.0[2]
WN ATL-PIT APR 1.6>1.0[1.6]
**WN ATL-PNS APR 0.4>1.0[0.4] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>0.5[0]
WN ATL-RDU APR 3>1.9[3]
WN ATL-RIC APR 3>2[3]
WN ATL-SAN APR 1.0>0.4[1.0]
WN ATL-SAT APR 1.6>1.0[1.6]
WN ATL-SDF APR 2>1.9[2]
WN ATL-STL APR 3>2[3]
WN ATL-TPA APR 5>4[5]
WN AUS-BWI APR 2>1.9[2]
WN AUS-DAL APR 6>5[6]
WN AUS-ELP APR 0.8>0.1[0.8] MAY 1.2>0.9[1.9]
WN AUS-IND APR 0.9>0.7[0.9]
WN AUS-LAS APR 3>2[3]
WN AUS-MCI APR 0.6>0[0.6] MAY 1.0>0.7[1.0]
WN AUS-MCO APR 3>1.5[3]
WN AUS-MDW APR 4>3[4]
WN AUS-MSY APR 1.6>0.8[1.6]
WN AUS-RDU APR 0.6>0[0.6] MAY 0.8>0.6[0.2]
WN AUS-SAN APR 1.6>1.0[1.6]
WN AUS-SJC APR 1.5>0.9[1.5]
WN AUS-STL APR 1.6>1.0[1.6]
WN BDL-BWI APR 4>3[4]
WN BDL-DEN APR 0.6>0[0.6] MAY 1.0>0.7[0.9]
WN BDL-MDW APR 1.6>0.9[1.6]
WN BDL-STL APR 0.6>0[0.6] MAY 1.0>0.7[0.5]
WN BHM-BWI APR 0.6>0[0.6] MAY 1.0>0.7[1.2]
WN BHM-HOU APR 0.6>0[0.6] MAY 1.0>0.7[1.8]
WN BHM-MDW APR 1.6>1.0[1.6]
WN BNA-BOS APR 3>1.7[3]
WN BNA-BUR APR 0.9>0.7[0.9]
WN BNA-BWI APR 5>4[5]
WN BNA-CLT APR 1.6>1.0[1.6]
WN BNA-CMH APR 1.6>1.0[1.6]
WN BNA-DAL APR 5>4[5]
WN BNA-ECP APR 3>2[3]
WN BNA-FLL APR 4>3[4]
WN BNA-LAS APR 3>2[3]
WN BNA-LAX APR 3>1.7[3]
WN BNA-LGA APR 3>2[3]
WN BNA-MDW APR 6>4[6]
WN BNA-MSP APR 1.3>0.1[1.3] MAY 1.8>1.5[1.1]
WN BNA-MSY APR 3>2[3]
WN BNA-OKC APR 0.6>0[0.6] MAY 1.0>0.7[1.0]
WN BNA-PNS APR 3>2[3]
WN BNA-RDU APR 3>2[3]
WN BNA-RSW APR 0.6>1.2[0.6] MAY 0.2>0.4[0.8]
WN BNA-SAN APR 1.6>1.0[1.6]
WN BNA-SJC APR 0.9>0.7[0.9]
WN BNA-VPS MAY 0>3[0] JUN 0>3[0] JUL 0>3[0] AUG 0>1.5[0]
WN BOI-DEN APR 3>2[3]
WN BOI-PHX APR 1.6>1.1[1.6]
WN BOI-SAN APR 0.6>0[0.6] MAY 1.0>0.7[0.9]
WN BOI-SJC APR 0.6>0[0.6] MAY 1.0>0.7[1.2]
WN BOS-BWI APR 7>4[7] MAY 9>7[8]
WN BOS-DEN APR 1.9>1.3[1.9]
WN BOS-MDW APR 3>2[3]
WN BOS-STL APR 1.7>1.0[1.7]
WN BUF-MCO APR 2>1.4[2]
WN BUF-MDW APR 2>0.9[2]
WN BUF-PHX APR 0.7>0.2[0.7]
WN BUR-DAL APR 1.0>0.4[1.0] MAY 1.0>0.7[1.0]
WN BUR-HOU APR 0.6>0[0.6] MAY 1.0>0.7[0.6]
WN BUR-LAS APR 7>4[7] MAY 8>7[9]
WN BUR-MDW APR 1.2>0[1.2] MAY 1.8>1.4[0.5]
WN BUR-OAK APR 6>3[6] MAY 7>6[11]
WN BUR-PHX APR 5>3[5]
WN BUR-SFO APR 4>1.3[4] MAY 5>4[4]
WN BUR-SJC APR 5>2[5] MAY 6>5[10]
WN BUR-SLC APR 0.6>0[0.6] MAY 1.0>0.7[0.9]
WN BUR-SMF APR 4>2[4] MAY 6>5[9]
WN BWI-CHS APR 3>2[3]
WN BWI-CLT APR 3>1.9[3]
WN BWI-CVG APR 3>2[3]
WN BWI-DAL APR 5>4[5]
WN BWI-FLL APR 8>6[8]
WN BWI-HOU APR 4>3[4]
WN BWI-LAX APR 2>1.0[2]
WN BWI-LGA APR 1.8>0[1.8] MAY 3>2[0]
WN BWI-MCO APR 10>7[10] MAY 10>9[10]
WN BWI-MDW APR 7>5[7]
WN BWI-MEM APR 0.6>0.1[0.6]
WN BWI-MSP APR 1.3>0.1[1.3] MAY 1.8>1.4[1.5]
WN BWI-MSY APR 3>1.4[3]
WN BWI-OAK APR 1.0>0.4[1.0] MAY 1.0>0.7[1.0]
WN BWI-RDU APR 4>3[4]
WN BWI-ROC APR 3>2[3]
WN BWI-RSW APR 6>5[6]
WN BWI-SAN APR 1.9>1.3[1.9]
WN BWI-SMF APR 0.6>0[0.6] MAY 1.0>0.7[0.9]
WN BWI-TPA APR 7>6[7]
**WN BWI-VPS MAY 0>0.8[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>0.5[0]
**WN BZN-DEN MAY 0>0.3[0] JUN 0>4[0] JUL 0>4[0] AUG 0>2[0]
**WN BZN-LAS MAY 0>0.3[0] JUN 0>2[0] JUL 0>2[0] AUG 0>1.0[0]
WN CHS-DEN APR 0.4>1.0[0.4] MAY 0.2>0.4[0.1]
WN CHS-MDW APR 2>1.1[2]
WN CLE-DEN APR 1.6>1.1[1.6]
WN CLE-MDW APR 3>2[3]
WN CLE-PHX APR 1.1>0.8[1.1]
WN CLE-STL APR 1.2>0[1.2] MAY 1.8>1.4[1.5]
WN CLT-HOU APR 0.6>0[0.6] MAY 1.0>0.7[1.0]
WN CLT-MDW APR 2>0.4[2] MAY 3>2[2]
WN CMH-DAL APR 0.9>0.7[0.9]
WN CMH-DCA APR 0.6>0[0.6] MAY 1.0>0.7[1.2]
WN CMH-FLL APR 1.2>0.9[1.2]
WN CMH-MDW APR 4>2[4]
WN CMH-PHX APR 2>1.4[2]
WN CMH-STL APR 0.6>0[0.6] MAY 1.0>0.7[1.0]
WN CRP-HOU APR 3>2[3]
WN CUN-DEN APR 2>1.4[2]
WN CVG-MDW APR 3>1.0[3]
WN DAL-DCA APR 4>2[4]
WN DAL-ELP APR 4>3[4]
WN DAL-HOU APR 11>8[11] MAY 12>11[17]
WN DAL-IAH APR 4>3[4] MAY 6>5[0] JUN 6>5[0] JUL 6>5[0]
WN DAL-IND APR 1.6>0.8[1.6]
WN DAL-LAX APR 5>3[5]
WN DAL-LBB APR 4>3[4]
WN DAL-LGA APR 3>2[3]
WN DAL-MAF APR 4>2[4]
WN DAL-MCI APR 4>3[4]
WN DAL-MDW APR 7>6[7]
WN DAL-MEM APR 1.6>1.0[1.6]
WN DAL-MKE APR 0.6>0[0.6] MAY 1.0>0.7[1.0]
WN DAL-MSP APR 0.6>0[0.6] MAY 1.0>0.7[1.0]
WN DAL-MSY APR 6>4[6]
WN DAL-OAK APR 1.9>1.3[1.9]
WN DAL-OMA APR 0.9>0.7[0.9]
WN DAL-PDX APR 0.7>0.1[0.7]
WN DAL-PHL APR 0.6>0[0.6] MAY 0.8>0.6[1.0]
WN DAL-PIT APR 0.6>0[0.6] MAY 1.0>0.7[1.0]
WN DAL-PNS APR 1.9>1.3[1.9]
WN DAL-RDU APR 0.6>0[0.6] MAY 1.0>0.7[1.1]
WN DAL-RNO APR 0.4>1.0[0.4] MAY 0.2>0.4[0.1]
WN DAL-SAN APR 4>2[4]
WN DAL-SAT APR 6>5[6]
WN DAL-SDF APR 0.6>0[0.6] MAY 1.0>0.7[1.0]
WN DAL-SEA APR 0.6>0[0.6] MAY 1.0>0.7[0]
WN DAL-SLC APR 1.3>1.7[1.3]
WN DAL-SMF APR 0.9>0.4[0.9]
WN DAL-STL APR 5>4[5]
**WN DAL-VPS MAY 0>0.8[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>0.5[0]
WN DCA-FLL APR 1.8>1.1[1.8]
WN DCA-HOU APR 3>1.4[3]
WN DCA-MCI APR 1.6>0.4[1.6] MAY 1.8>1.4[1.8]
WN DCA-MDW APR 5>3[5]
WN DCA-MKE APR 1.6>1.0[1.6]
WN DCA-MSY APR 1.6>0.4[1.6] MAY 2>1.5[2]
WN DCA-OKC APR 0.6>0[0.6] MAY 1.0>0.7[1.0]
WN DCA-PVD APR 1.6>0.4[1.6] MAY 2>1.5[1.8]
WN DCA-STL APR 3>1.0[3]
WN DCA-TPA APR 2>1.4[2]
WN DEN-DTW APR 1.6>1.0[1.6]
WN DEN-GEG APR 3>2[3]
WN DEN-IAD APR 2>1.0[2]
WN DEN-IAH APR 1.9>1.3[1.9] MAY 3>2[0] JUN 3>2[0] JUL 3>2[0] AUG 1.5>1.0[0]
WN DEN-LAS APR 8>7[8]
WN DEN-LAX APR 6>4[6]
WN DEN-LGA APR 3>1.9[3]
WN DEN-MCI APR 6>4[6]
WN DEN-MDW APR 9>7[9]
WN DEN-MKE APR 4>3[4]
WN DEN-MSP APR 4>3[4]
WN DEN-MSY APR 4>3[4]
WN DEN-OAK APR 5>4[5]
WN DEN-PDX APR 4>3[4]
WN DEN-PHL APR 3>1.9[3]
WN DEN-PHX APR 10>8[10]
WN DEN-RDU APR 1.6>1.0[1.6]
WN DEN-RSW APR 0.4>0.8[0.4]
WN DEN-SAN APR 6>4[6]
WN DEN-SAT APR 4>3[4]
WN DEN-SFO APR 3>2[3]
WN DEN-SMF APR 5>4[5]
WN DEN-SNA APR 5>4[5]
WN DEN-STL APR 5>4[5]
WN DEN-TUL APR 3>1.9[3]
WN DEN-TUS APR 3>2[3]
WN DSM-LAS APR 0.7>0.1[0.7]
WN DSM-STL APR 1.6>1.0[1.6]
WN DTW-MDW APR 3>2[3]
WN DTW-STL APR 0.6>0[0.6] MAY 1.0>0.7[1.6]
WN ECP-HOU APR 1.4>1.8[1.4]
WN ECP-MDW APR 0.6>1.2[0.6] MAY 0.2>0.4[0.1]
WN ELP-HOU APR 3>2[3]
WN ELP-LAS APR 1.8>1.1[1.8]
WN ELP-LAX APR 0.6>0[0.6] MAY 1.0>0.7[1.5]
WN ELP-PHX APR 4>3[4]
WN ELP-SAT APR 0.7>0.1[0.7]
WN FLL-ISP APR 0.4>1.0[0.4] MAY 0.2>0.4[1.0]
WN FLL-MKE APR 0.6>1.1[0.6] MAY 0.3>0.5[0.7]
WN FLL-MSY APR 1.6>1.0[1.6]
WN FLL-PHX APR 0.4>0.8[0.4]
WN FLL-PVD APR 0.4>1.0[0.4] MAY 0.2>0.4[1.2]
WN FLL-SAT APR 0.4>0.9[0.4]
WN FLL-TPA APR 1.6>1.0[1.6]
WN GEG-SJC APR 0.6>0[0.6] MAY 0.8>0.6[1.0]
WN GRR-MCO APR 0.6>1.1[0.6]
WN GRR-RSW APR 0.5>1.0[0.5] MAY 0>0.2[0.4]
WN HOU-HRL APR 3>2[3]
WN HOU-LGA APR 2>1.1[2]
WN HOU-LGB APR 1.6>1.0[1.6]
WN HOU-LIT APR 0.6>0[0.6] MAY 1.0>0.7[1.0]
WN HOU-MAF APR 3>2[3]
WN HOU-MCI APR 2>1.5[2]
WN HOU-MDW APR 6>5[6]
WN HOU-OAK APR 1.9>1.4[1.9]
WN HOU-ONT APR 0.9>0.3[0.9] MAY 1.0>0.7[0]
WN HOU-PHL APR 0.6>0[0.6] MAY 0.8>0.6[0]
WN HOU-PIT APR 0.9>0.3[0.9] MAY 1.0>0.7[0.9]
WN HOU-PNS APR 1.6>1.0[1.6]
WN HOU-RDU APR 0.6>0[0.6] MAY 1.0>0.7[1.0]
**WN HOU-RSW APR 0.4>1.0[0.4] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>0.5[0]
WN HOU-SAN APR 3>2[3]
WN HOU-SDF APR 0.6>0[0.6] MAY 1.0>0.7[1.0]
WN HOU-SJC APR 1.0>0.4[1.0] MAY 1.0>0.7[0.5]
WN HOU-SMF APR 1.0>0.4[1.0]
WN HOU-STL APR 3>2[3]
WN HOU-TPA APR 3>2[3]
WN IAH-MSY APR 3>1.8[3] MAY 4>3[0] JUN 4>3[0] JUL 4>3[0] AUG 2>1.5[0]
WN ICT-PHX APR 0.7>0.1[0.7]
WN ICT-STL APR 1.6>1.0[1.6]
WN IND-RSW APR 2>3[2]
WN IND-STL APR 1.2>0[1.2] MAY 1.8>1.4[0]
WN ISP-MCO APR 1.7>1.1[1.7]
WN JAX-MDW APR 0.7>0.1[0.7]
WN LAS-LAX APR 7>5[7]
WN LAS-LGB APR 5>4[5]
WN LAS-MDW APR 9>7[9] MAY 10>9[8]
WN LAS-MSP APR 0.3>0.9[0.3] MAY 0>0.2[0]
WN LAS-MSY APR 1.0>0.7[1.0]
WN LAS-OAK APR 7>6[7]
WN LAS-ONT APR 4>3[4]
WN LAS-PHX APR 8>6[8]
WN LAS-RNO APR 7>6[7]
WN LAS-SAN APR 7>6[7]
WN LAS-SAT APR 3>2[3]
WN LAS-SFO APR 3>1.8[3]
WN LAS-SJC APR 7>4[7] MAY 8>7[10]
WN LAS-SLC APR 4>3[4]
WN LAS-SMF APR 7>6[7]
WN LAS-TUS APR 3>2[3]
WN LAX-MDW APR 5>3[5]
WN LAX-MSY APR 1.5>0.9[1.5]
WN LAX-OAK APR 7>3[7] MAY 9>7[11]
WN LAX-PHX APR 6>4[6]
WN LAX-RNO APR 1.6>0.8[1.6]
WN LAX-SAT APR 0.6>0[0.6] MAY 1.0>0.7[1.5]
WN LAX-SFO APR 5>2[5] MAY 6>5[6]
WN LAX-SJC APR 5>2[5] MAY 7>6[9]
WN LAX-SLC APR 1.6>0.8[1.6]
WN LAX-SMF APR 6>3[6] MAY 7>6[7]
WN LAX-STL APR 1.6>1.0[1.6]
WN LAX-TUS APR 0.7>0[0.7] MAY 1.2>0.8[2]
WN LGA-MCI APR 0.6>0[0.6] MAY 1.0>0.7[1.3]
WN LGA-MDW APR 5>3[5]
WN LGA-MSY APR 0.6>0[0.6] MAY 0.8>0.6[1.0]
WN LGA-STL APR 3>1.3[3]
WN LGA-TPA APR 1.9>1.1[1.9]
WN LGB-MDW APR 1.6>1.0[1.6]
WN LGB-OAK APR 4>2[4]
*WN LGB-OGG JUN 0.2>1.0[0] JUL 0>1.0[0] AUG 0>0.5[0]
WN LGB-RNO APR 1.0>0.7[1.0]
WN LGB-SJC APR 3>1.0[3] MAY 3>2[4]
WN LGB-SMF APR 4>2[4]
WN LGB-STL APR 1.0>0.7[1.0]
WN LIT-STL APR 1.6>1.0[1.6]
WN MBJ-MDW APR 1.0>0.4[1.0]
WN MCI-MDW APR 5>3[5]
WN MCI-MKE APR 0.6>0[0.6] MAY 0.8>0.6[1.0]
WN MCI-MSY APR 0.6>0.1[0.6] MAY 0.8>0.6[1.1]
WN MCI-RSW APR 0.6>1.1[0.6]
WN MCI-SAN APR 0.6>0.1[0.6]
WN MCI-STL APR 2>1.0[2]
WN MCO-MDW APR 8>7[8]
WN MCO-MSY APR 3>2[3]
WN MCO-PIT APR 3>2[3]
WN MCO-RDU APR 2>1.3[2]
WN MDW-MHT APR 1.3>0[1.3] MAY 2>1.5[1.0]
WN MDW-MSP APR 5>4[5]
WN MDW-MSY APR 3>2[3]
WN MDW-OAK APR 3>1.9[3]
WN MDW-OMA APR 3>1.9[3]
WN MDW-ONT APR 1.0>0.4[1.0] MAY 1.0>0.7[1.0]
WN MDW-PDX APR 1.6>1.0[1.6]
WN MDW-PHL APR 4>1.0[4] MAY 6>4[4]
WN MDW-PHX APR 9>8[9]
WN MDW-PIT APR 4>1.9[4]
WN MDW-PVD APR 1.3>0[1.3] MAY 2>1.5[2.0]
WN MDW-RDU APR 3>1.9[3]
**WN MDW-RIC APR 0>0.4[0] MAY 0>0.9[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>0.5[0]
WN MDW-SAN APR 3>2[3]
WN MDW-SAT APR 2>1.0[2]
WN MDW-SDF APR 2>1.7[2]
WN MDW-SEA APR 2>1.0[2]
WN MDW-SFO APR 2>1.0[2]
WN MDW-SJC APR 2>1.0[2]
WN MDW-SLC APR 3>2[3]
WN MDW-SMF APR 2>1.0[2]
WN MDW-SRQ APR 1.4>1.9[1.4]
WN MDW-STL APR 5>3[5]
WN MDW-TPA APR 6>5[6]
**WN MDW-VPS JUN 0>0.8[0] JUL 0>1.0[0] AUG 0>0.5[0]
WN MKE-STL APR 1.9>1.3[1.9]
WN MKE-TPA APR 1.7>2[1.7]
WN MSP-STL APR 0.6>0[0.6] MAY 1.0>0.7[1.6]
WN MSY-OAK APR 0.6>0[0.6] MAY 1.0>0.7[1.0]
WN MSY-RDU APR 0.6>0[0.6] MAY 0.8>0.6[0]
WN MSY-SAT APR 0.6>0[0.6] MAY 1.0>0.7[1.2]
WN MSY-STL APR 1.3>0.1[1.3] MAY 1.8>1.5[1.6]
WN OAK-ONT APR 4>3[4]
WN OAK-PDX APR 4>3[4]
WN OAK-RNO APR 1.6>1.0[1.6]
WN OAK-SAN APR 7>4[7] MAY 8>7[10]
WN OAK-SEA APR 4>3[4]
WN OAK-SLC APR 3>1.9[3]
WN OAK-STL APR 0.6>0[0.6] MAY 0.8>0.6[0.8]
WN OKC-STL APR 1.6>1.0[1.6]
WN OMA-STL APR 1.7>1.1[1.7]
WN ONT-PHX APR 4>3[4]
WN ONT-SJC APR 3>2[3]
WN ONT-SMF APR 6>3[6] MAY 7>6[6]
WN ORF-SAN APR 0.6>0[0.6] MAY 1.0>0.7[0]
WN PDX-SJC APR 3>1.4[3]
WN PDX-SMF APR 3>2[3]
WN PDX-STL APR 0.6>0[0.6] MAY 1.0>0.7[1.0]
WN PHL-STL APR 1.6>0.4[1.6] MAY 1.8>1.4[2]
WN PHX-RNO APR 3>2[3]
WN PHX-SAN APR 6>5[6]
WN PHX-SDF APR 0.8>0.2[0.8] MAY 1.2>0.9[1.0]
WN PHX-SFO APR 4>2[4]
WN PHX-SJC APR 5>3[5]
WN PHX-SLC APR 5>4[5]
WN PHX-SNA APR 7>5[7]
WN PIT-RSW APR 1.5>2[1.5]
WN PIT-STL APR 0.6>0[0.6] MAY 1.0>0.7[1.0]
WN RDU-STL APR 1.6>0.9[1.6]
WN RDU-TPA APR 0.7>0.1[0.7]
WN RNO-SAN APR 1.6>0.8[1.6]
WN RNO-SJC APR 0.6>0[0.6] MAY 1.0>0.7[1.8]
WN RSW-STL APR 2>3[2]
WN SAN-SAT APR 0.7>0.1[0.7] MAY 1.0>0.7[1.5]
WN SAN-SFO APR 5>2[5] MAY 6>5[6]
WN SAN-SJC APR 7>3[7] MAY 9>7[14]
WN SAN-SMF APR 8>5[8] MAY 9>8[13]
WN SAN-STL APR 1.7>1.0[1.7]
WN SAN-TUS APR 0.8>0.1[0.8] MAY 1.2>0.8[1.9]
WN SAT-STL APR 0.8>0.1[0.8] MAY 1.2>0.9[1.4]
WN SAT-TPA APR 0.6>0.1[0.6]
WN SDF-TPA APR 1.0>0.3[1.0] MAY 1.3>1.0[1.2]
WN SEA-SJC APR 3>1.4[3]
WN SEA-SMF APR 3>1.7[3]
WN SEA-STL APR 0.6>0[0.6] MAY 1.0>0.7[1.0]
WN SFO-STL APR 0.6>0[0.6] MAY 1.0>0.7[0.5]
WN SJC-SLC APR 0.6>0[0.6] MAY 1.0>0.7[1.2]
WN SJC-SNA APR 8>5[8] MAY 8>7[10]
WN SJC-STL APR 1.0>0.4[1.0] MAY 1.0>0.7[0.5]
WN STL-TUL APR 1.6>1.0[1.6]
enilria
Re: OAG Changes 3/2/2021:AA+ORD-BIL/FAT/GEG/ONT/SBA;B6+BOI,LGADEN,EWR-ACK/ANU/BQN/MVY/POP/SEA/STT/UVF;DL+CNY/DRO/LNK;NK;
Tue Mar 02, 2021 2:34 pm
I don't know if this stuff had been announced or not. With all the silo'd threads on a.net now it is hard to find route news, but even though they gutted EWR close in, the route adds in the Summer are stunning. This is a major deal. B6 could end up with a significant share of EWR. Part of what enabled this is UA moving a lot of their connecting feed to IAD and of course the loss of international due to covid. Those two coupled together make it MUCH easier for B6 to get traction in EWR where normally invading a legacy hub is near impossible because the legacy can add a bunch of extra flights and fill them with connects. UA has limited ability to do any of that, so you see them adding BOS-LHR in seeming retaliation instead. One wonders how much of this was a message for that route.
DEN-LGA is also super-interesting, and another gut punch at UA. Has F9 been suspending that route lately? They only had 1x per day last I looked.
AVLAirlineFreq
Tue Mar 02, 2021 2:47 pm
Thanks as always for doing this, enilria!
Chuska
Tue Mar 02, 2021 2:50 pm
Thanks for the back up when BZN and VPS were announced in a separate thread the other day. As you know it created a debate that these new cities should just be announced on the Southwest Fleet/Network thread which is miles long and which most of us don't check regularly. I too prefer to read about breaking news when it happens and have it reported separately. That separate thread was erased a few hours later, hope everyone caught it while it was up. Thanks again Enilria.
Chuska
Tue Mar 02, 2021 2:57 pm
Wow, on top of the OO/UA* CNY-DEN EAS service. High expectations for Moab this summer. Arches Natl Park has already been near gridlock in years past.
Glad to see DRO-SLC coming back too. DL* tried that back in 2007/2008, hope it works this time.
orlandocfi
Tue Mar 02, 2021 3:12 pm
Agreed. I think we are seeing the LCCs taking the opportunity to “kick ‘em while they’re down” and B6 in EWR is really going for the jugular, it seems.
Chuska
Tue Mar 02, 2021 3:15 pm
Yep, G4 sure is doing some interesting stuff. OO/UA* does CKB-ORD but gets paid for it (EAS).
tphuang
Tue Mar 02, 2021 3:18 pm
yep, this came out here http://blueir.investproductions.com/inv ... -160050512
There were some obvious holes in the combined AA/B6's network out of NYC pre-COVID. They had very few flights to Denver and Houston. AA didn't fly there at all. JetBlue did well on the couple of JFK flights they had, but not with business schedule. So it makes sense for them to add LGA-DEN. I'm waiting to see if they add EWR-DEN. Without WN in EWR, there are some non-UA ff on the other end that they could pick up. Since COVID hit, AA hasn't flown LGA-ATL/DTW/MSP. B6 has ATL covered pretty well now out of EWR/JFK. DTW is pretty week with just 4x weekly in April. IAH is pretty weak with just 4x weekly in April. MSP is not flown at all. So, if they want to be competitive in NYC, AA either need to return to those markets or B6 needs to add them from LGA or EWR.
As for EWR, AA really isn't going to help B6 here. At some point, JetBlue needs to enter markets like EWR-ORD/DEN/BNA/IAH if they want to be a truly competitive second option. If they add these, they'd get over 100 flight a day and have the top 20 domestic markets covered pretty well. A lot really depends on how many gates they will have in the new T-1.
Scarebus34
Tue Mar 02, 2021 3:33 pm
B6 is trying to take advantage of UAs ultra-conservative approach. UA was content with sitting back and watching them bleed to death. However, with loads/bookings increasing not so sure that’s going to play out anymore. UA is going to be at a real risk of giving up market share if they don’t start offering more competitive schedules that people want to fly.
tphuang
Tue Mar 02, 2021 3:47 pm
I don't agree with that. NYC demand has been down anywhere from 75% to almost 100% in this past year. UA did not cut EWR more than their competitors out of LGA/JFK. They just get the short end of the stick here because the other 2 airports are protected by those slot waivers. B6 has been looking to add at EWR since the slot constraints went away, but was recently not able to do so due to EWR effectively been slot constrained during peak hours. It seems to me that JetBlue "got lucky" here by a confluence of factor:
- WN leaving making Terminal A really empty
- New terminal 1 opening up offering possibility of more gates
- suddenly have a lot of aircraft sitting around
- International demand down, which hurts UA more than anyone else, since a lot of the short haul stuff connects to international flights
- UA looking to get back into JFK (IIRC B6 got gates at T-A in exchange for that)
AAguy1992
Tue Mar 02, 2021 3:57 pm
Thank you for doing this!
AAGuy 1992 :D
maps4ltd
Tue Mar 02, 2021 4:10 pm
Delta return to Moab is nice to see.
Next flights:
Who knows? :/
MIflyer12
Tue Mar 02, 2021 4:15 pm
DL+CNY in the thread title had me do a double-take, checking the airport code.
a320flyer
Tue Mar 02, 2021 4:32 pm
DL finally responding to AS...
SteveXC500
Tue Mar 02, 2021 4:46 pm
Oh good, I can hop on the CRJ to LNK again.
freakyrat
Tue Mar 02, 2021 4:55 pm
G4 is banking on increased leisure traffic and the pandemic under control by starting their seasonal SRQ flights One month early. They are also resuming other flights.
panam330
Tue Mar 02, 2021 5:38 pm
B6 JFK-BOI. Never thought I’d see that one.
B6BOSfan
Tue Mar 02, 2021 5:48 pm
With all the cuts continually being made to their BOS service, B6 has a lot of aircraft to move elsewhere. Guessing they're just relying on O&D for all that traffic, since you can't make a lot of BOS-NYC connections.
MIflyer12
Tue Mar 02, 2021 5:50 pm
If it appeals to you, get it quick, before it's gone.
alohashirts
Tue Mar 02, 2021 5:56 pm
Great news for the people of Moab and southeastern Utah with the resumption of SLC-CNY. Utah airports such as CNY, PVU, SGU, and of course SLC have really been staying strong and seeing growth compared to many other airports. Great to see it happen.
flyfresno
Tue Mar 02, 2021 5:57 pm
I think it has a chance to do well seasonally (summer + maybe three weeks around Christmas). I wouldn't write it off so quickly...
tphuang
Tue Mar 02, 2021 6:01 pm
Keep in mind that B6 has actually cut Boston a lot less than DL. DL is at around 50 flights a day on peak days in April and B6 is about twice that. BOS has seen a larger cut than JFK, but that's due to lack of demand on the shorthaul business traffic which they are not involved in out of JFK.
Also, they are averaging around 3x on both BOS-EWR/JFK in April vs 3x between the two airports in march. So there will be quite a bump in connection options in the event of schedule cuts.
Wneast
Tue Mar 02, 2021 6:08 pm
I wouldn’t be surprised to see JetBlue add a seasonal flight to FLL and flights to lax if this flight does well
B6BOSfan
Tue Mar 02, 2021 6:28 pm
Very true, but I look at schedules in term of functionality. Although Delta has made tons of BOS cuts, they have maintained a system of funneling passengers to key hubs to keep ability to fly with minimal disruption going. ATL, DTW, SLC. They are also well timed, with connections typically 90 minutes or less.
JetBlue - which I get is totally dependent on O&D traffic, is a mess when it comes to that. Great examples: BOI and FCA -- all require layovers at JFK well over 3 hours. And that is one of the few times you can connect. JetBlue's website typically doesn't allow connections if the dwell time is beyond a certain period of time. The fares are usually cost prohibitive too.
AC4500
Tue Mar 02, 2021 6:31 pm
I mean.... they did add FLL-BZN/PSP. In this day in age, any route is possible it seems. ;)
AmericanAir88
Tue Mar 02, 2021 6:32 pm
Still no UA adjustments for April.
Wneast
Tue Mar 02, 2021 6:36 pm
I
Your not wrong that’s why I see Geg being added In the near future
Nicknuzzii
Tue Mar 02, 2021 6:37 pm
Wneast wrote:
I
There are no major service changes coming to GEG in the near future.
Wneast
Tue Mar 02, 2021 6:39 pm
Nicknuzzii wrote:
Wneast wrote:
I
You don’t see JetBlue coming there or more flights to other places on existing airlines ?
tphuang
Tue Mar 02, 2021 6:51 pm
Well, let's see how long BOI and FCA last first. Look, I know the current situation is rough, but as demand comes back, a lot of these problems and lack of stable schedule will be less problematic. Of course, that doesn't lessen the inconveniences of those who did book early on JetBlue and then got canceled.
The biggest issue with JetBlue has always been its lack of options when flights get cancelled and its lack of destinations. The NEA with AA should allow them to interlining/reprotection that get you to where you need to go in the event of a cancellation. Of course given the reduced spending from airlines, it's hard to say how long hte implementation with take. In the future, if you get cancelled, I think you will be well served to ask helpline if they can put you on AA flights to get to where you need to go.
AC4500
Tue Mar 02, 2021 7:02 pm
Nicknuzzii wrote:
Wneast wrote:
I
It doesn't do anyone any good to be so pessimistic around here. The chances of B6 coming to Spokane are slim, even after traffic begins to return to normal. But that doesn't mean we can't speculate on what could possibly happen based on the airlines' current and future strategies going forward.
As for jetBlue, I honestly wouldn't be shocked to see them pull out of PDX for good. If that were to happen, there's no way GEG would get B6 service.
enilria
Tue Mar 02, 2021 11:27 pm
Agreed. Siloing is not good for social media and forum sites.
Yeah, there are so many changes I have to do a lot of abbreviations to fit.
jasoncrh
Tue Mar 02, 2021 11:39 pm
There’s nothing “gut punchy” about JetBlue going on den-lga against UA. The den-lga market is nothing but trash low fares. JetBlue has to rely on that to fill the planes. United can take some of that, but United also has a huge hub in Denver, with service to several markets that generate high fares and that are popular with New Yorkers. Places like Aspen. Vail. Telluride. Sun valley. Tons of places in Montana. All of those destinations generate $800 plus round trip fares from nyc that United can partake in, while JetBlue will have to make due with the $200 fares from Nyc to Denver only. Do some analysis before you post such drivel.
Also, those flights were all announced nearly 2 weeks ago and have been discussed at length here.
Finally, your pull missed ACK-ORD on AA for this summer. Which was announced this weekend as well.
quote="enilria"]
DEN-LGA is also super-interesting, and another gut punch at UA. Has F9 been suspending that route lately? They only had 1x per day last I looked.[/quote]
wedgetail737
Tue Mar 02, 2021 11:45 pm
DL flew the CVG-SEA route prior to the pandemic with 1X daily flight.
portcolumbus
Tue Mar 02, 2021 11:53 pm
Joplin Globe reporting Skywest/UAx will be starting EAS service from JLN to DEN and ORD starting 6/1
Chuska
Wed Mar 03, 2021 1:50 am
Yes, AA had agreed to do JLN and ALO for free but now AA wants out and both cities are being allowed back onto the EAS program. That makes no sense when an EAS rule was revised back in 2012 stating "when your out, your out", but it only applied to cities being served for free during a one year time frame back then. Thanks to Great Lakes, several cities in Wyoming plus FMN, NM got stung bad and now must fend for themselves. Since then cities, like JLN and ALO, can get back on EAS. Thanks to SkyWest for taking on the Wyoming cities and FMN should be back on the map soon even though they're not EAS anymore.
RJNUT
Wed Mar 03, 2021 3:45 am
UA is starting to develop critical mass feed on the EAS service system wide. DL and AA seem to have marginal appetite, at best.
wedgetail737
Wed Mar 03, 2021 3:54 am
I'm beginning to wonder if ANA is going to discontinue HND-SEA permanently.
KarlB737
Wed Mar 03, 2021 4:55 am
This kinda surprises me. It almost looks like Allegiant is merely sticking their toe in the water to see if this will work.
alasizon
Wed Mar 03, 2021 6:02 am
It matches their scope models, UA is reliant on 50 seat lift which is the only thing profitable or close to it in the EAS markets. AA and DL don't have that same problem.
ADent
Wed Mar 03, 2021 7:08 am
Someone on the UA thread said to expect that Saturday.
BoeingGuy
Wed Mar 03, 2021 7:52 am
This isn’t the first time this route has been flown. I believe UA flew it briefly in the 1970s with a 727.
NWAESC
Re: OAG Changes 3/2/2021:AA+ORD-BIL/FAT/GEG/ONT/SBA; B6+BOI,LGA,DEN,EWR-ACK/ANU/BQN/MVY/POP/SEA/STT/UVF; DL+CNY/DRO/LNK
Wed Mar 03, 2021 1:29 pm
It's nice to see points being added back into the network.
"Nothing ever happens here, " I said. "I just wait."
N292UX
Re: OAG Changes 3/2/2021:AA+ORD-BIL/FAT/GEG/ONT/SBA; B6+BOI,LGADEN,EWR-ACK/ANU/BQN/MVY/POP/SEA/STT/UVF; DL+CNY/DRO/LNK
Wed Mar 03, 2021 9:49 pm
JFK-BOI is certainly bold but I imagine B6 will make it work. If they have been able to get routes like JFK-TUS/RNO/BUR/ONT/PSP work, I feel like BOI should do fine. Meanwhile B6's EWR push is impressive. They're really getting on UA's nerves with the new addition. I certainly think there's room for a focus city operation at EWR. UA basically runs the place so competition should help.
Happy to see DL returning to places like LNK. I know they cut cities like CAK/AVP/FNT/MHT from their route network too. Hopefully some of those return in the future too.
oosnowrat
Thu Mar 04, 2021 1:07 am
From the news coverage of CNY it sounds like OO is adjusting the EAS contract and the SLC flight will come at the expense of a DEN flight.
Not sure about DRO. It smells like a OO prorate route, but the news reports don't really say.
Chuska
Thu Mar 04, 2021 12:38 pm
I was thinking that adjusting the EAS may be the case with CNY. UA hasn't updated their schedules beyond Apr 1 yet so when they do (Saturday 3/6?), their may be a reduction in CNY-DEN from 2 to 1. Although SkyWest will operate both CNY-DEN and CNY-SLC, it is rather odd that the EAS routes would be split between two major partners, UA and DL.
knope2001
Fri Mar 05, 2021 1:02 am
It is indeed an alternate service pattern
https://www.regulations.gov/document/DO ... -2827-0209
It's not common to have a split between branded carriers but the contract is with Skywest (not United) so the split is a notch easier. I think Cody had both SLC and DEN in summer but that may have been an added unsubsidized flight to the "other" hub.
What is even more noteworthy to me is this is the first addition to Delta's EAS network in many years. Just being a single flight it may not represent anything new, but who knows. If Skywest would be allowed to bid new EAS markets into Delta hubs that could further expand their potential penetration of the nation's EAS system.
Cubsrule
Fri Mar 05, 2021 2:12 am
The biggest cons for DL to allowing EAS under its banner are scope issues and the opportunity cost of doing the flying rather than something to a larger market. Both of those are significantly smaller issues in the pandemic, unfortunately.
Chuska
Sat Mar 06, 2021 12:06 pm
UA did load their April adjustments today (Saturday 3/6). The schedules are basically the same as what they had previously loaded for Mar 28-31.
aemoreira1981
Sat Mar 06, 2021 4:58 pm
On SQ...I have to wonder if the ULR flight that used to be SIN-EWR will become SIN-JFK permanently, with SQ25/6 becoming SIN-FRA terminator permanently. The regular arrival could be shifted to the old SQ26 slot, with a departure close to midnight from JFK. (The existing cargo flights have been flying with the A359ULR to JFK.)
Other things:
1. Is PS planning to end all wide-body services and become a regional 737 carrier only? They have parked all of their 777s
2. QF will not immediately return to JFK or KIX, and ORD is postponed indefinitely. To hold the slot at JFK, could they lease that slot out to AA on a temporary basis? AA could find it useful for its upcoming announced JFK-TLV flight, for instance (I see Project Sunrise as their return to JFK.)
Users browsing this forum: 817Dreamliiner, Aquila3, autopiloton, BrianDromey, FlyingHonu001, Google [Bot], Google Adsense [Bot], keenaz28, LTU1011, mrsmiley2345, musapapaya, nicode, rhysflies, sfojvjets, The777Man, Toenga, tvh and 302 guests
