Max Q wrote:if that approach was promising why didn’t Boeing go ‘all the way’ with the 777-8–9 and incorporate a 787 like composite fuselage ?
Max Q wrote:I’m starting to think the whole composite experiment was and is just that, the massive investment by B and A doesn’t seem to have paid off as far as composites are concerned
Max Q wrote:These two aircraft pushed the limits in airframe and engine technology, the gains in efficiency and performance have been really impressive
But has the switch to substantially more composites in both types really been worth it ?
I read that most of the gains in efficiency on both types are mostly due to their new, far more efficient engines, the empty weight of both aircraft doesn’t appear to be far lighter than a conventional, all metal construction equivalent airframe
There are advantages to composite construction to be sure, corrosion is no longer an issue and it allows for a higher pressure differential, lower cabin altitude and more humidity improving passenger comfort
But Boeing is doing that anyway with the new 777-9 and it’s conventional, aluminum fuselage
The composite fuselage is apparently very strong with impressive hour and cycle limits but is that worth it too ?
If these airframes can endure a lot longer is that a real benefit ? In 20 years there will be new technologies enabling even greater efficiencies
I always thought the 787 was going to be the base model of a whole new mostly composite family of Boeing aircraft
I don’t see that at all now, I think the 737 / 757 and 767 replacements will all be of conventional aluminum construction
An eventual clean sheet replacement for the 777 thats modeled on the 787 seems doubtful, if that approach was promising why didn’t Boeing go ‘all the way’ with the 777-8–9 and incorporate a 787 like composite fuselage ?
I’m starting to think the whole composite experiment was and is just that, the massive investment by B and A doesn’t seem to have paid off as far as composites are concerned although AB seems to have executed it better I don’t think this is leading to a whole new family of similar types from either manufacturer
LAX772LR wrote:Max Q wrote:if that approach was promising why didn’t Boeing go ‘all the way’ with the 777-8–9 and incorporate a 787 like composite fuselage ?
Because they then wouldn't be 777s, and thus would have to go through the far more extensive+expensive approval process for all-new aircraft.Max Q wrote:I’m starting to think the whole composite experiment was and is just that, the massive investment by B and A doesn’t seem to have paid off as far as composites are concerned
High on supposition, low on tangible data.
Without the real financial numbers, plus an accurate simulation to calculate the opportunity cost + likely performance of a conventional build of the same type/class..... none of which we here have or would be privy to, there's no way to *accurately* come to the conclusion you seek, one way or another.
Opus99 wrote:LAX772LR wrote:Max Q wrote:if that approach was promising why didn’t Boeing go ‘all the way’ with the 777-8–9 and incorporate a 787 like composite fuselage ?
Might I also add. That very expensive development may very well not have paid off because the market for that size of aircraft exists but not big enough to justify a clean sheet
AndoAv8R wrote:I can see this both ways
From one aspect, aircraft will have to evolve due to increased demand in reducing the emissions/carbon footprint and increased efficiency, and this will require a lot of necessary research/development/change since currently no current design can really handle the requirements.
The other aspect is have we reached a peak in aircraft design/functionality? I use for example the basic Diesel-electric locomotive used primarily in the US. They have evolved a bit but the basic running gear/design is overall the same basic design/concept from the 1950's from Electro-Motive
Max Q wrote:I read that most of the gains in efficiency on both types are mostly due to their new, far more efficient engines, the empty weight of both aircraft doesn’t appear to be far lighter than a conventional, all metal construction equivalent airframe
Max Q wrote:Opus99 wrote:LAX772LR wrote:Because they then wouldn't be 777s, and thus would have to go through the far more extensive+expensive approval process for all-new aircraft.
Well, exactly !
Goes to my point
ClassicLover wrote:You're right on this. This is why Airbus and Boeing are always going on about the engines - the vast majority of the efficiency comes from the powerplant. This is why the step change is always engines... neos and so on, with just tweaks to the airframe. The real people who should be credited are the engineers and designers at Rolls-Royce, Pratt & Whitney and General Electric. They're the ones responsible for most of the efficiency, though the airframe manufacturers are the ones who are always crowing about how good their product is as though they built the engines too.
I personally don’t work in composites as a profession (so someone who does feel free to correct me) but I have been involved with several projects including it and have several friends who do it for a living/masters thesis. Composites can save an extraordinary amount of weight and still be exceptionally stiff and strong. But there are a couple of key disadvantages when comparing it to metals. The most significant of which is that composite materials are generally not isotropic, meaning they are not the same strength when loaded in different directions. They are also, from my understanding, much more sensitive to cracks and damage than metals. Extremely sensitive to manufacturing processes. With that in mind, I’m really not surprised that the safety margins for the first generation of something as structurally complex as a fuselage are probably higher than they need to be. Unless there is some breakthrough in aluminum or steel alloys, or even some other metal, composites are definitely the present and future.
Overall, it seems hard to expect a fuselage of a traditional cross section narrow body airliner to be CFRP, unless the cost of making CFRP has dropped significantly in the last decade. It seems metal is easier to mass produce for constant cross sections. It is somewhat labor intensive but in at least some cases robots can be used to reduce the labor cost.
CaptainHaresh wrote:Max Q wrote:These two aircraft pushed the limits in airframe and engine technology, the gains in efficiency and performance have been really impressive
The experiment is still ongoing.
We don't know how large CFRP structures will behave over time and NDT of large CFRP surfaces is very difficult such that accidents will eventually occur due to undetected fatigue.
Max Q wrote:Interesting replies, I guess my question remains though, does anyone think Boeing or Airbus will build a new aircraft model using the 787 or A350 as a template, or indeed a new airframe using mostly composite?
CaptainHaresh wrote:We don't know how large CFRP structures will behave over time and NDT of large CFRP surfaces is very difficult such that accidents will eventually occur due to undetected fatigue.
ELBOB wrote:CaptainHaresh wrote:We don't know how large CFRP structures will behave over time and NDT of large CFRP surfaces is very difficult such that accidents will eventually occur due to undetected fatigue.
The all-composite B-2 has been in service since 1997, the Premier I since 2001, the A300 has had an all-composite fin since 1985. What exactly do you think we still need to learn?
rigo wrote:LAX772LR wrote:Max Q wrote:if that approach was promising why didn’t Boeing go ‘all the way’ with the 777-8–9 and incorporate a 787 like composite fuselage ?
It is with noting though that the A220 and the MC21 are post 787/A350, they are both considered state of the art and both went for aluminium/alloy fuselage.
