seat1a wrote:In Seattle today and watching a DL A220 on approach, writing this at 2:36pm PST. Flight coming in from Austin.
What's causing the howling sound during approach? It last for a few seconds, but happens every time. Thoughts welcome. Thanks!
N766UA wrote:I was actually going to ask the same thing about A*3*20's. Whenever a 320 series jet flies over, the moment it comes into hearing range it sounds like a landing UFO. "Beeeyoooooooo." Engine inlet shape or something? No other airplane does that and it's loud and distinct every time.
hayzel777 wrote:N766UA wrote:I was actually going to ask the same thing about A*3*20's. Whenever a 320 series jet flies over, the moment it comes into hearing range it sounds like a landing UFO. "Beeeyoooooooo." Engine inlet shape or something? No other airplane does that and it's loud and distinct every time.
Probably the airline didn’t install the fuel vent sound reduction device.
N766UA wrote:hayzel777 wrote:N766UA wrote:I was actually going to ask the same thing about A*3*20's. Whenever a 320 series jet flies over, the moment it comes into hearing range it sounds like a landing UFO. "Beeeyoooooooo." Engine inlet shape or something? No other airplane does that and it's loud and distinct every time.
Fuel vents! Interesting. It seems that every US-based airline's 320's make the "UFO" noise.
https://www.oharenoise.org/noise-manage ... -2020/file
B6JFKH81 wrote:N766UA wrote:hayzel777 wrote:Probably the airline didn’t install the fuel vent sound reduction device.
It depends on the age of the aircraft. Newer aircraft typically come with the fuel vent vortex generators installed/service bulletin applied at delivery from Airbus. The SB can be retrofitted, and is being applied to many older A320s out there in the US. B6 is doing this SB during C-checks, others airlines I do not know as some A320s in DL/UA/AA are old and may be getting retired so it may not be worth modifying those aircraft.
seat1a wrote:Heard a similar sound on a PrimeAir 767 a few minutes later. Same fuel vents?! LOL
orlandocfi wrote:N766UA wrote:I was actually going to ask the same thing about A*3*20's. Whenever a 320 series jet flies over, the moment it comes into hearing range it sounds like a landing UFO. "Beeeyoooooooo." Engine inlet shape or something? No other airplane does that and it's loud and distinct every time.
The sound I *think* you’re describing is caused by the speed brakes being open (beeeyooooooo) or closed (whoooop). It is not unique to the A32X but is definitely pronounced! Any jet with speedbrakes makes this sound to varying degrees.
The whistling sound on approach from older A32X is from air blowing across underwing fuel vents.
The howling sound described by the original poster is also heard on the Embraer E2 jets, which also have geared turbofans. I suppose we will be hearing more of these interesting sounds in the coming years!
CriticalPoint wrote:[url][/url]N766UA wrote:I was actually going to ask the same thing about A*3*20's. Whenever a 320 series jet flies over, the moment it comes into hearing range it sounds like a landing UFO. "Beeeyoooooooo." Engine inlet shape or something? No other airplane does that and it's loud and distinct every time.
I have been told that that is the speed brakes being stowed......
Also the The PW 777s howl exactly like that.
D L X wrote:https://twitter.com/flightradar24/status/1335965511293825026?s=21
Podcast on the noise.
