Ishrion
Garuda Indonesia Orders Four A330-800neos
Tue Mar 09, 2021 9:55 pm
Kind of surprised to see this. Garuda Indonesia placed an order for four Airbus A330-800neos, which appears to be the undisclosed order from 2019, so it's not exactly a pandemic order. I don't think there's been any formal announcement or coverage on this order?
Could this be how they manage to launch nonstop Bali to LAX/SFO from those recent reports?
https://airwaysmag.com/airlines/garuda- ... 30-800neo/
TC957
Re: Garuda Indonesia Orders Four A330-800neos
Tue Mar 09, 2021 10:24 pm
Nice....hopefully they'll restore the DPS - LHR service as well.
TeamLH
Tue Mar 09, 2021 11:01 pm
Long live the dead!
Devilfish
Tue Mar 09, 2021 11:07 pm
I'm probably the staunchest champion of the A338 here but even for me, a ~500nm difference in brochure distance from actual is too little allowance across the Pacific unless it's flown very lightly loaded. GA might be better off using their A339 and stopping at HNL enroute. Even flying the A338 on MNL-LAX would be cutting it very closely (assuming normal loads and typical winds). :airplane:
http://www.gcmap.com/mapui?P=DPS-LAX/SF ... /SFO&DU=nm
TeamLH wrote:
Long live the dead!
Couldn't have put it much better! :bigthumbsup:
Antarius
Tue Mar 09, 2021 11:13 pm
If they want to light money on fire, there are easier ways to do it.
Militant Centrist
Let's all just use some common sense
filipinoavgeek
Wed Mar 10, 2021 1:02 am
Can it even fly that far? Our resident A338 fan previously it could (perhaps barely) fly MNL-LAX, but that's a shorter distance than DPS-LAX by about 1,000 nmis and other people here have suggested that the A338 (and the A330neo as a whole) is a poor fit for transpacific flights compared to the 787 and A350.
Devilfish wrote:
TeamLH wrote:
Long live the dead!
Given how much you stan for the A338 on A.net I do wonder how you'd react if the whole project was shut down and if you'd continue to post here.
RIP 9V-SKA
2007 - 2019
Ishrion
Wed Mar 10, 2021 2:47 am
Airbus says the standard range of the A338 is 15,094 kilometers. DPS-LAX is 13,893 kilometers and DPS-SFO is 13,446 kilometers. Both routes are within the range, but that isn't taking into account what Devilfish mentioned, such as configuration and winds.
flee
Wed Mar 10, 2021 3:31 am
Congratulations to Garuda - the A338 will integrate seamlessly into their A330 fleet. Now, lets see what routes they would fly.
sfojvjets
Wed Mar 10, 2021 3:32 am
I see this order happening to fulfill one of two possible scenarios:
1. Garuda is simply planning accordingly for the lower passenger volumes it expects on DPS long haul routes (especially SFO/LAX) and does not care about the range that comes with the aircraft since they plan to stopover at an intermediary point anyway (most likely scenario IMO)
2. Garuda wants to squeeze as much range as it can out of the A330neo family while maintaining commonality with their existing -900 fleet, so they plan to fly DPS-SFO-LAX and vice versa (likely not 5th Freedom)*
*As has been stated in this thread already though, it remains to be seen whether the -800 can even make it to the US West Coast from DPS when taking into account headwinds, possibly a more leisure-oriented config, etc. so this is why I believe the first option to be the more likely of the two.
Thoughts?
Devilfish
Wed Mar 10, 2021 5:02 am
I even wished PR had ordered the 747SP instead of the DC-10 to avoid the GUM tech stop! But couldn't you man up and put forth your own convictions instead of hiding behind others' opinions all the time?
This is the second time (or third?) you had asked that. Considering my favorites (-SP, 764, A318) have gone or very nearly did and I'm still here after 15 years - barring any life changing event - I most probably would still be pestering you with A338 posts. OTOH, I worry that you would lose your sense of purpose if I stopped contributing here as largely everyone else ignores you and you'd no longer have someone to stalk! In just a bit over two years at that. :old:
MrHMSH
Wed Mar 10, 2021 6:21 am
I thought the 251T A338 had comparable range to the 787? Surely MNL-LAX is well within its capabilities?
ZK-NBT
Wed Mar 10, 2021 6:55 am
How many A338s have been ordered? And how many built?
FluidFlow
Wed Mar 10, 2021 7:00 am
Boeing gives the range for the 787-9 at 7,530 nmi (13,950 km) (https://www.boeing.com/commercial/787/)
Airbus gives the range of the A338 at 8150 nmi (15'094km) (https://www.airbus.com/aircraft/passenger-aircraft/a330-family/a330-800.html)
So given that DPS-LAX is roughly 13'900km the 787-9 might be a bit short legged if the conditions (wind and weather) are not favourable. The A338 on the other hand should have more than enough range. And also the 787-9 might be too much aircraft for such a route most of the time (load wise).
HB-IWC
Wed Mar 10, 2021 7:43 am
I have no doubt about the seamless integration but I wonder what Garuda will actually do with all of these widebodies. Even before the pandemic struck, the A330 fleet was terribly underused. Garuda still operates the 6 original 24+ year old A333 in a mono class layout (they used to be mainly deployed for Jeddah services from secondary destinations and for Hajj purposes as well as between Bali and secondary China destinations), and then has 7 A332s, 11 A333s and 3 A339s in operation with another 3 A339s being prepared for delivery at Airbus. Then there is the 10-strong fleet of B77Ws. There is simply not enough long- and medium-haul potential to keep such a large widebody fleet busy with acceptable utilization rates.
raylee67
Wed Mar 10, 2021 7:46 am
Despite what is said by Boeing on 789's range, it's definitely not 13,950km. Notice that QANTAS is flying 789 on PER-LHR with full load both direction all-year. The GC distance is 14,499km. The actual flight distance is for sure longer than that, and you need to factor in wind and extra fuel for holding, etc. So 789's effective range is probably at least 1,000km more than the stated range.
Airbus also has a tendency to overstate the range of its aircraft. May be it's using the most favorable weather condition to state the range? Or it doesn't include the extra fuel requirement? e.g. A330-300 has a stated range of 11,300km. HKG-AKL has a distance of 9,155km and CX was not able to use its A330-300 to fly to AKL all the time. It has been used once or twice but CX needed to use A340-300 before and then switched to A350-900 immediately when those are delivered.
So while A330-800 definitely has a range higher than A330-200, I am a bit skeptical that it can fly a route that is really over 15,000km both-direction year-round full-load.
For GA, may be A330-800 would be more optimal than 777-300ER to fly CGK-AMS or CGK-LHR/LGW. They don't need the capacity of a 77W on those routes. They also have difficulties with the runway at CGK given the weight of the 77W. If they switches to the lighter and smaller A338 for European flights, they may be able to fly to Europe non-stop from CGK without any improvement on runway condition. The 77W can then be used primarily on Asia routes when hopefully tourists can return to Bali.
319/20/21 332/33 342/43/45 359/51 388 707 717 732/36/3G/38/39 74R/42/43/44/4E/48 757 762/63 772/7L/73/7W 788/89 D10 M80 135/40/45 175/90 DH1/4 CRJ/R7 L10
AY LH OU SR BA FI LX
AA DL UA NW AC CP WS FL NK PD
CI NH SQ KA CX JL BR OZ TG KE CA CZ NZ JQ RS
FluidFlow
Wed Mar 10, 2021 8:05 am
Thank you for the info. Do you know which A333 CX used? I do not think all the A333 CX has are 251t. Some are relatively old and the lower MTOW variants definitely are not able to make HGK-AKL but the 251t should be.
ZK-NBT
Wed Mar 10, 2021 8:51 am
It was a years ago in NZ winter on a day with low loads IIRC. Some of the newest versions now could probably make it, CZ did use A333s CAN-AKL at one point.
MrBryan86
Wed Mar 10, 2021 9:01 am
The 251t MTOW is only available on the Neo. Considering the Cathay examples are some of the earliest built, I’m guessing they are 217t variants.
TC957
Wed Mar 10, 2021 9:17 am
Why do you say that ? A high-end leisure route like this would do well 2 or 3 times a week. Only negative I can foresee is GA's recent history of stop-starting London which may put some tour operators off using them. Bali has always been a favourite for UK holiday makers seeking long-haul luxury.
emre787
Wed Mar 10, 2021 9:18 am
787-9s range is 8,300nm / 15,400km https://www.flightglobal.com/boeing-add ... 53.article
enzo011
Wed Mar 10, 2021 9:56 am
Ah, yes, Boeing is realistic with its assumptions but Airbus isn't. Another a-net myth. Both are optimistic when they publish their data for their aircraft by using optimal flight conditions. There is no way the 789 gets anywhere near PER-LHR at its full load. If you take out seats then you can make it and fanboys can claim that this is proof that Boeing underestimates its range. Qatar has 232 Y seat in its 788, QF has 236 total seats in its 789. That is the longer 789 that has 4 more total seats than the 788.
tommy1808
Wed Mar 10, 2021 9:57 am
A338 (and the A330neo as a whole) is a poor fit for transpacific flights compared to the 787 and A350..
The A338 in its 251t incarnation flies just as far as the 787-9 and a lot further than the 787-8.
best regards
Thomas
MrHMSH
Wed Mar 10, 2021 10:11 am
If you gave an A338 the same cabin density as QF's 789 I suspect it would make 15,000km without too much difficulty or restrictions. QF's configuration is an outlier amongst 787 operators as being able to make that nonstop significantly improves the premium QF can charge, enough to overcome the lower passenger numbers.
Seen many times how Airbus overstates the range of its aircraft, but very little in the way of substantial evidence. One airline using aircraft on one route can't tell us that the entire catalogue overpromises on range.
If GA (for some reason) used a low density cabin the aircraft could make LAX from DPS, economics aside. Europe should be no problem for a more high density A338.
eta unknown
Wed Mar 10, 2021 10:44 am
I'd bet the A338 is a full or partial 77W replacement for Europe. LAX wont happen in the near future- and no way via MNL- impossible to get traffic rights.
Opus99
Wed Mar 10, 2021 11:05 am
Or the a330-200s that they have?
eta unknown
Wed Mar 10, 2021 11:15 am
Could be... or also some of the -300's that are getting old.
VSMUT
Wed Mar 10, 2021 11:23 am
Although possible, Garuda has notably had issues with its 777-300ER fleet. Initially too heavy for Jakarta, they are also too big for the airline, they seem to have problems filling them profitably. Indonesia might have a massive population and a big economy, but other airlines have struggled to fill big aircraft to Indonesia as well. KLM runs a mix of 777-200ER and 777-300ER to Jakarta and Bali, but with stops in Kuala Lumpur and Singapore on the way. Qatar Airways uses the 787-8. Emirates ran the 777-300ER, but continued on to Australia or New Zealand on the Bali route.
Opus99
Wed Mar 10, 2021 11:29 am
Very true. You have a good pony there
flee
Wed Mar 10, 2021 11:30 am
They have six A333s that are over 20 years old. The rest of the A332/A333 fleet is relatively young.
BrianWilkes
Wed Mar 10, 2021 11:45 am
Interesting they could even use their 777's to their full potential even though some problems where out of their hands!
CRJ900
Wed Mar 10, 2021 12:30 pm
Great news that GA goes for the A338, the aircraft needs to prove what it can do in airline service and GA is an experienced A330 operator. The engines on the A338 will burn 15-20% less fuel than the engines on the A332/A333 so it is a good investment for the future even if they operate flights shorter than 7,000nm every now and then.
Come, fly the prevailing winds with me
trent768
Wed Mar 10, 2021 2:29 pm
Rumors on the local forum said that the A332s are on their way out. They still have the original HU IFE system and cmiiw, they didn't even care to change the UI to GA's standard. Still red and yellow with GA's logo slapped on top. Some even said that they also considered to return some of the overpriced newer 333 and replace it with the 339.
But I agree with you, GA's wide body utilization is not very good. Most days, you could see 10-12 330s/77Ws chilling around GMF's ramp and that's even before covid.
Antarius
Wed Mar 10, 2021 2:35 pm
Their stop starting is a result of their eyes being bigger than their wallets - they have delusions of grandeur, launch the flight, take a beating and stop. Then someone wakes up with the same idea and starts all over again.
Bali is certainly a top vacation destination, but between GA's execution and the fact that a lot of vacation travelers (including premium flyers) don't require non-stops and aren't willing to pay the premium, I do not see how this goes differently than the last set of times.
Militant Centrist
WayexTDI
Wed Mar 10, 2021 2:38 pm
Well, maybe most people trust the manufacturer's specs listed today on its website rather than those found in an article that's almost 7 years old?
WayexTDI
Wed Mar 10, 2021 2:46 pm
Didn't QF fly non-stop LHR-SYD in a 787-9 a little over a year ago? That was a 19+-hour, 10,500-NM flight; way past the published range. Oh yeah, it was a test with a handful of journalists and "passengers", tanks filled to the rim and no cargo...
In special conditions, some planes can exceed their manufacturer's stated range; but those special conditions are unrealistic of the real operating conditions and would be bleeding cash if operated as such.
filipinoavgeek
Wed Mar 10, 2021 3:19 pm
Anyway, I'd take this opportunity to apologize to Devilfish over my bothering of him and his A338 fandom, and I'll try to avoid it from now on.
As for CGK's runway issues, is there a reason why they were built that way and why the runways weren't strengthened? And how come the airport has had troubles with the 777W when Garuda used to operate 747s in the past and to my knowledge didn't have issues with them?
RIP 9V-SKA
2007 - 2019
Polot
Wed Mar 10, 2021 3:23 pm
Iirc the issue is with pavement load. The 747 may be heavier but it has more tires spread across a larger area to distribute the weight around.
NZ321
Wed Mar 10, 2021 3:51 pm
Thoughts?
Well,for one, GA don't fly passenger service to SFO or LAX or any other point in the greater Americas - North, Central or South. This is not a new situation. And the A338 or A339 would certainly not have the payload/range combo to deliver a consistent solution in both directions even if they were mad enough to commence this soon. Just not happening. Perhaps the 77W are history.... and the A339 will standardise the medium-long haul wide body offering.
Plane mad!
Chaostheory
Wed Mar 10, 2021 4:07 pm
Probably built that way due to corruption and lack of funds. Most airport infrastructure in Indonesia is sub-standard.
The 77W has fewer tyres to spread the weight which means potentially more damage to airport surfaces.
Devilfish
Wed Mar 10, 2021 4:30 pm
We only assumed GA ordered the 251T version because of the OP's question about its usefulness on DPS-LAX/SFO. I hadn't seen it categorically stated that GA actually did.
The issue is on the westbound LAX-MNL where it could take 15 hours doglegging across the puddle. Additionally, the trip costs on this very long oceanic flying could only be spread among a fewer number of passengers. Raising fares would not sit well with price-sensitive VFRs and would drive customers towards the competition - thus impacting yields. A potential route for the A338 is CEB-LAX-CEB should it resume after the pandemic...as traffic wouldn't be higher than MNL and the passengers might be swayed into paying a little premium for the nonstop flight to CEB. Of course, this is predicated on the A359s going back to the lessors.
No apologies necessary...just keep it about the aircraft and not make it personal.
sfojvjets
Wed Mar 10, 2021 6:48 pm
Thoughts?
Of course they do not fly to any point in the Americas yet. I think maybe you've forgotten the long-haul aspirations they've announced for DPS. This is in fact a new situation - they announced last year (during COVID) that they had plans to launch DPS-SFO/LAX/CDG/BOM/DEL to increase tourist expenditure in the Bali region. They have acknowledged that the flights will be loss-making. I do agree with you, maybe the 77w indeed are history despite their youth since they are leased but at the same time, the A338 would not make any sense to be the replacement for them. Considering the long-haul aspirations they have had for Bali, the 4 A338s are probably for this. And yes, as I said earlier, I do not believe they can consistently expect the range to be enough to reach LAX/SFO, so what's probably likely is that they have got these -800s since they know that the DPS routes will be lower capacity.
The only obstacle would be that as Garuda management keeps changing, the airline often falls prey to whims of its new management. But the reason that I think that these are long-term plans is the fact that they are now introducing a whole new type to their fleet - and moreover, they have only ordered 4 of them - too much to only replace larger equipment on current service from CGK to AMS/LHR and too little to replace the entire 77w fleet (of 10 I think). But this number is perfect for flying low-frequency DPS long-haul. Of course... whether this actually comes to fruition will be interesting.
https://airlinegeeks.com/2020/07/08/gar ... and-india/
Polot
Wed Mar 10, 2021 7:45 pm
They are not introducing a whole new type to their fleet. The A338s will have full commonality with their A339s...they are just shorter.
TC957
Wed Mar 10, 2021 8:50 pm
I feel that with good marketing Bali will become a favourite future stop-over point for Brits going to / from Australia in addition being a dream destination of it's own. The A338 should be far more suited to an LHR service than a 77W. And trust me, the cabin will fill from the front first - It's a 14 -15 hr flight and people will go for the premium cabin. Look at BA's Male Maldives flight - done with a 4-class 77W due to premium demand, when there's loads of TK and ME3 one-stop alternatives.
Antarius
Wed Mar 10, 2021 9:28 pm
LHR-MLE is 2200 nm less than LHR-DPS. And BA has much stronger point of sale presence in the UK than GA.
Both are significant differences.
Militant Centrist
VSMUT
Wed Mar 10, 2021 10:53 pm
The airport is from 1985. Big twins that could go halfway around the world weren't envisaged at the time. At the same time it was so new that it hadn't had major refurb and rework done yet.
Rajahdhani
Thu Mar 11, 2021 12:18 am
To add to the logic here, is that if GA can command local O/D from Bali, or take advantage of the airport (as prescribed, as a connector point), it could flourish quite well.
If so - adding a decent premium cabin would not only increase the performance of the A338, but also said premium (less dense) cabin, may allow some breathing room for cargo, potentially. Additionally, there need not necessarily be a need to support the small A338 fleet with further A338 replacements right away. Basing 738s there could put a lot of destinations at the upper ranges of the aircraft, however in the same vein as with the A338, premium cabins can increase performance. Similarly, upgrading to the MAX 8 (and/or discussing discounts with Boeing, and/or perhaps shopping for potential A321NEO/LRs, for spicy measure) - would give them comfort to operate year round, and with greater densities. So, start small and work up if/when able.
http://www.gcmap.com/mapui?P=DPS-BOM,+DPS-DEL,+DPS-SYD,+DPS-SYD,+DPS-ICN,+DPS-PEK,+DPS-NRT&R=3112nm%40DPS
x1234
Thu Mar 11, 2021 1:00 am
I was told GA was losing money flying 77W's to Europe. They should replace it with the A330neo (smallest wide-body).
AECM
Thu Mar 11, 2021 1:17 am
Garuda widebodies fleet seat count
B77W C26Y367
A332 C36Y186 or C18Y242
A333 C36Y215 or C24Y263 or Y360
A339 C24Y277
In wich routes did Garuda get money with their 10 B77W before the Pandemic?
HB-IWC
Thu Mar 11, 2021 4:46 am
B77W C26Y367
A339 C24Y277
There are still 2 B77W aircraft that have the initial 8F/38C layout. These were last deployed on the CGK HND and DPS NRT routes. I think the high density 26C/367Y layout only ever worked on the JED and MED routes, and then only seasonally. The aircraft was otherwise too large for the network and the initial premium heavy configuration obviously failed miserably.
I would expect that the B77W fleet will be disposed off as they come up for lease renewal, but if these aircraft are on a typical 12-year lease, then we are still 4 years away from the first aircraft due for renewal.
smartplane
Thu Mar 11, 2021 5:09 am
This may come as a surprise, but OEM's and customers DO NOT contract on the basis of catalogues.
The customer provides say the last 12 months actual route data, including turnaways if a larger aircraft is being considered, weather, and other factors. The OEM models various aircraft configurations and LF's, including interiors, which form part of the sale / purchase contract, together with an agreed performance erosion / decay formula, and penalties if more than X% of flights don't conform.
