LAXintl
Viva Aerobus A320 nose gear collapse at PVR
Thu Mar 18, 2021 9:35 pm
Antarius
Re: Viva Aerobus A320 nose gear collapse at PVR
Thu Mar 18, 2021 9:41 pm
I don't believe I've ever heard of a nose gear collapse on takeoff.
Don't speak spanish, so not sure what the statement says. Anyone who can help?
Militant Centrist
Let's all just use some common sense
hic787
Thu Mar 18, 2021 9:51 pm
Looks like the plane was doing a 180 turn at the end of the runway for takeoff when it happened
toobz
Thu Mar 18, 2021 9:54 pm
Omg seems very lucky that it didn’t happen when rolling down the runway
ikolkyo
Thu Mar 18, 2021 10:12 pm
Wow, just falls right off. Wild.
KFLLCFII
Thu Mar 18, 2021 10:23 pm
If you turn the tiller too far, it will unscrew right off the strut.
"About the only way to look at it, just a pity you are not POTUS KFLLCFII, seems as if we would all be better off."
A320B737NGCapt
Thu Mar 18, 2021 10:57 pm
Yep oversteer whilst do a backtrack and lineup, technically not taking off as has been stated by several news sources, “preparing to takeoff/departure” would be more appropriate.
DLASFlyer
Thu Mar 18, 2021 11:07 pm
Is the frame a write off?
rojo
Thu Mar 18, 2021 11:43 pm
I flew on VB last week PVR-TIJ and for the a.net community not familiar with the current operation at PVR, the airport is currently resurfacing the taxiway leading to the threshold of runway 22. Because of the constructions, planes have to taxi using the actual runway and do a 180 turn on the threshold of runway 22. From the pictures provided looks like the nose gear of XA-VAZ collapsed during this maneuver
barney captain
Thu Mar 18, 2021 11:49 pm
Southeast Of Disorder
Flow2706
Thu Mar 18, 2021 11:52 pm
It's not possible to "unscrew" the nose wheel by tiller movement. There is a mechanical stop on the tiller, the nose wheel movement is limited. No authority would certify an aircraft that could suffer a nose gear collapse when the tiller is moved.
KFLLCFII
Fri Mar 19, 2021 12:05 am
During the factory tour, they were lifting the front of the aircraft to screw the wheel assemblies on.
nm2582
Fri Mar 19, 2021 12:07 am
Well, they DID drive it 'till the wheels fell off.....
:D
flight152
Fri Mar 19, 2021 12:09 am
I have no idea how the nose assembly is attached to the aircraft but I will tell you with 100% certainty that your first comment is totally bogus. There are zero limitations with the nose wheel tiller or notes mentioning that it may fall off of you go too far in the flight manual.
freakyrat
Fri Mar 19, 2021 12:16 am
VIVA AEROBUS INFORMS
Flight VIV4343 Puerto Vallarta - Monterrey
• Today March 18 2021 at 1:40 p.m., our aircraft XA-VAZ - flight VIV4343 from Puerto Vallarta to Monterrey, was involved in an incident when aligning to the runway prior to takeoff, the nose landing gear collapsed.• All 127 passengers and crew onboard are safe.• All safety protocols were activated immediately, in coordination with aeronautical authorities and the airport administration, guaranteeing the safety of all passengers and crew members at all times.• Viva Aerobus is finding alternatives to protect our passengers on flight VIV4343, so they can travel to their destination as soon as possible.• The aircraft is under review by our engineering teams with the support of the OEMs and the aeronautical authorities.• We are sorry for the inconvenience this incident may have caused. We reaffirm our commitment to safety on each of our flights, as safety is Viva Aerobus’ number one priority.
iamlucky13
Fri Mar 19, 2021 12:19 am
(Senator Collins:)Well, I’m not saying it wasn’t safe, it’s just perhaps not quite as safe as some of the other ones.
(Interviewer:) Why?
(Senator Collins:) Well, some of them are built so the wheel doesn’t fall off at all.
(Interviewer:) Wasn’t this built so the wheel wouldn’t fall off?
(Senator Collins:) Well, obviously not.
(Interviewer:) “How do you know?”
(Senator Collins:) Well, ‘cause the wheel fell off
(Interviewer:) But Senator Collins, why did the wheel fall off?
(Senator Collins:) Well, the pilot did a turn.
(Interviewer:) Is that unusual?
(Senator Collins:) Oh, yeah… on a taxiway? …Chance in a million
11C
Fri Mar 19, 2021 12:29 am
Darn, and I thought you were kidding...
Weatherwatcher1
Fri Mar 19, 2021 1:19 am
Not a good week for A320 nose gears. I wonder if this gear failed at 90 degrees before sheering of since the A320 has a failure mode where the gear turns sideways
viewtopic.php?f=3&t=1458449
LimaFoxTango
Fri Mar 19, 2021 2:25 am
I guess the joke flew right over, huh --> :duck:
You are said to be a good pilot when your take-off's equal your landings.
TUSAirliner
Fri Mar 19, 2021 3:03 am
I was on UA flt 304 IAH-PVR. Just about 1/2 way we returned to IAH as when the flight was dispatched it was understood the runway would be cleared.
All crew amazing. Can’t get upset about this.
OTOH. UA could not issue a refund from being downgraded from a revenue F fare to Y tomorrow morning.I either have to call or email. I was given a $75 travel voucher. Paid hotel and $40 in meal vouchers. They were not obligated to do this
Just the hassle of a refund
LAXintl
Fri Mar 19, 2021 4:07 am
Picture posted by PVR as they work to restore airfield operations
https://pbs.twimg.com/media/Ewz3ZWjW8AE ... name=large
Spacepope
Fri Mar 19, 2021 4:22 am
Yeesh, that’s gonna be a spendy repair.
WayexTDI
Fri Mar 19, 2021 5:50 am
Cue the obligatory: is it a write-off?
Wrinkled skin, might not be far from it.
Scarebus34
Fri Mar 19, 2021 5:57 am
The runway has reopened.
Aesma
Fri Mar 19, 2021 7:29 am
Some speedtape and it will be fine !
It'll buff right out !
ClipperMonsoon
Tue Mar 23, 2021 2:29 am
They better stock up on speed tape then, seems to keep happening
The true Queen of the Skies the Boeing 707-321B
FlyingElvii
Tue Mar 23, 2021 2:48 am
Ummm... it isn’t supposed to fail like that.....
Chemist
Tue Mar 23, 2021 4:54 am
Nose gear doesn't seem to be an A320 strong point.
INFINITI329
Tue Mar 23, 2021 7:06 am
Impossible, it never took off :D
T prop
Tue Mar 23, 2021 7:29 am
[photoid] I[/photoid]
Gotta be careful on those left turns, the nose gear is left hand thread so when they turned sharply they unscrewed the nose gear! :lol:
UA748i
Tue Mar 23, 2021 8:44 am
Ouch! Glad no one was hurt.
Hardly superficial damage, but I suspect the aircraft will return to service.
Spacepope
Tue Mar 23, 2021 1:02 pm
There’s some better discussion on another site on this.
One report is that the pilots applied a lot of thrust after the wheels fell off toco tinge the turn, since they noticed steering had become, um, problematic. This is when the remaining g gear parts dug in. The continued movement happened as the gear structure tried to tear itself free of the fuselage.
Scuttlebutt is there is a lot of structural damage up in the gear Bay Area (and of course all the fuselage creasing we see here) and this airframe maybe a goner.
Aesma
Tue Mar 23, 2021 2:09 pm
@ Spacepope can you edit your sentence, it's not clear (toco tinge ?).
Was the main gear stuck or the nose gear ? Did they exit the pavement ?
Time for enveloppe protections for taxiing ?
Spacepope
Tue Mar 23, 2021 2:44 pm
Too late. Sorry, was typing on an ipad this morning and sometimes this site doesn't play nice. Apparently "Toco tinge" is autocorrect for "during".
The remains of the nose gear was the one that was stuck (like, literally, in the pavement)
Aesma
Tue Mar 23, 2021 5:59 pm
OK I get it. Both nose wheels failing is surprising though. Trying to taxi once that happened, yeah, not a great idea !
ghost77
Tue Mar 23, 2021 6:44 pm
It most probably is, LN 2576., mfd. 03.10.2005. It is the 2nd oldest frame in the fleet. Right now, many frames are grounded, no worries this is one stays forever in PVR. It's gonna be a good aircraft for parts!
g77
santi319
Tue Mar 23, 2021 7:53 pm
Yes, several Mexican Aviation posts indicated passengers reported the aircraft exited the runway to the grass and came back to the runway when doing the 180 turn.
Aesma
Tue Mar 23, 2021 8:53 pm
OK, now we have the full picture and it exonerates the aircraft. Putting the tiny nose gear in grass is not a good idea.
Antarius
Wed Mar 24, 2021 2:02 am
Possibly. Need to see what an investigation says. Could be an MX issue coupled with circumstance. Could just be the situation or something else.
Militant Centrist
LTEN11
Wed Mar 24, 2021 2:17 am
The photos don't show the nose anywhere near the grass and if it had been on the grass, surely there would be a dirt trail on the runway to the point of the failure.
santi319
Wed Mar 24, 2021 4:38 am
https://twitter.com/pilotshopmexico/sta ... 39140?s=21
Several passengers said the plane left the runway and came back. There is construction in PVR and most aircraft are backtracking in the runway and doing a 180 for take off. Seems very plausible.
LTEN11
Wed Mar 24, 2021 6:45 am
Sure it sounds plausible, but the photographic evidence really doesn't support it.
WayexTDI
Wed Mar 24, 2021 2:48 pm
If the grass and soil are dry, there would not necessarily be dirt on the wheels: think about sand, you can drive on it, have no sand left on your tires (it would actually clean them) yet could damage your wheels/axles/suspension.
We don't see the area surrounding the point of u-turn; there might very well be evidence of the plane leaving the hard surface.
Antarius
Wed Mar 24, 2021 3:31 pm
Definitely possible. I think the point is that some are declaring this to be the definitive cause - we don't have enough information to say for sure.
Could be a combination of factors too.
Militant Centrist
Aesma
Wed Mar 24, 2021 4:32 pm
They might have dragged it for some distance before it broke completely.
Weatherwatcher1
Wed Mar 24, 2021 7:18 pm
It would be very strange for an airplane to be doing a 180 prior to takeoff since PVR has a full length taxiway, but I guess stranger things have happened.
Antarius
Thu Mar 25, 2021 2:04 am
The Taxiways are closed. NOTAM below
A0617/21 - MMPR (Mexico): Taxiway(s) Closed
AERODROME
Period: 2021-02-09T12:00:00.000Z - 2021-04-11T12:00:00.000Z
Q-Code (MXLC): AGAMovement and landing areaTaxiway(s)ClosedLimitations
TWY A BTN TWY G AND THR RWY 22 CLSD CREATED: 06 Feb 2021 00:55:00 SOURCE: MMMXYNYX
Militant Centrist
