LAXdenizen
Would US Military Ever Sell C-5 to the Civilian Cargo Market?
Fri Apr 09, 2021 7:10 pm
In reading about the Volga-Dnepr An-124 at AUS today, I just wondered if the US military would ever sell C-5's to the civilian cargo market (at least to a US-based operator).
The An-124 was made for exclusive Soviet military use and is now in 'private' hands. There also seems to be large market for this type of cargo service as evidenced by the Ruslan being in high demand.
ILNFlyer
Re: Would US Military Ever Sell C-5 to the Civilian Cargo Market?
Fri Apr 09, 2021 7:21 pm
I believe the 747 started out originally as a military project that was subsequently picked up by the civilian market but never the military.
LAXdenizen
Fri Apr 09, 2021 7:29 pm
Yes, that's how I understand it.
The ability to drop the nose and drive in large cargo without the use of lifts, plus the anhedral wing and subsequent wider fuselage at the base of the An-124 & C-5, gives them carrying capacity the 747 cannot match.
Antarius
Fri Apr 09, 2021 7:31 pm
I don't think any cargo operator would want it. The military has a basically unlimited budget and they can use this to keep ancient aircraft flying and do modernization projects with it.
Civilian operators don't have this kind of budget or strategic need to keep specific types flying.
Militant Centrist
Let's all just use some common sense
LAXdenizen
Fri Apr 09, 2021 7:38 pm
Volga-Dnepr seems to be making it work with the exact same challenges, with far fewer Ruslans, parts, knowledgeable technicians, etc.
TWA772LR
Fri Apr 09, 2021 7:45 pm
Volga-Dnepr is. Avery big fish in a very small pond. They can charge almost anything and the customers that need that kind of service are willing and able to pay for it. Plus, not to sound jingoist, I'm sure labor in Russia is a lot cheaper than labor in the west.
When wasn't America great?
Phosphorus
Fri Apr 09, 2021 7:46 pm
If there were a C-5 fleet in private hands, operated cheaper and more efficiently, than USAF fleet of C-5's, it would raise all kind of inconvenient questions.
If the root of the problem turned out to be the OEM and contractors overbilling their government customer vs. commercial customers - it'd be a scandal, everyone concerned would lose money and face.
AN4 A40 L4T TU3 TU5 IL6 ILW I93 F50 F70 100 146 ARJ AT7 DH4 L10 CRJ ERJ E90 E95 DC-9 MD-8X YK4 YK2 SF3 S20 319 320 321 332 333 343 346 722 732 733 734 735 73G 738 739 744 74M 757 767 777
Ceterum autem censeo, Moscovia esse delendam
MO11
Fri Apr 09, 2021 7:48 pm
The C-5 has no civilian type certificate - so someone would have to convince L-M to spend the money on certification. And then the issue of parts and support.
Polot
Fri Apr 09, 2021 7:53 pm
Volgna-Dnepr is not the only operator of the An-124. One other major operator is Antonov Airlines, owned by Antonov...the original designer of the aircraft. The other big operator? The Russian Air Force.
Both those operators ensure there are parts and knowledgeable technicians to keep the plane flying.
Antarius
Fri Apr 09, 2021 8:01 pm
Also the An-124 is almost 20 years newer than the C5.
Volga Dnepr does have Il76s though that are of the same vintage as the C5s. But as you and others have mentioned, labor is cheaper and there is a historic infrastructure present to support these Russian jets.
Militant Centrist
GalaxyFlyer
Fri Apr 09, 2021 8:11 pm
The plane we know as the B747 was never a military project. The HL C-X RFP from the Pentagon resulted in a bid by Lockheed and Boeing, which looked fairly similar as you’d expect. Lockheed won, Boeing went to build a passenger/cargo plane which looked entirely different than their C-X bid-low wing instead of high, high cockpit, forward or side loading instead of Ro-Ro. Of course, Boeing learned a lot from the design process, engines were designed that went on to become the GE CF-6 or the P&W JT-9D. The C-5 and the 124 are broadly similar in size and capability, but the M model is probably superior in many ways especially the engines, cargo loading (roller bed capability).
The Economy Act prevents the use of it for civilian operations, unless there’s a declared emergency and only to meet the immediate needs. That’s why, and cost, even FEMA use the AN-124.
JannEejit
Fri Apr 09, 2021 8:45 pm
There was if course the civilian L-500 proposal from Lockheed, that saw no takers when offered. I'm surprised one or two didn't end up with some commercial cargo lifter for specialised load uplifting.
DocLightning
Fri Apr 09, 2021 8:59 pm
Didn't McD try to offer an MD-17, which was a civilian-configured C-17? They got no bites.
-Doc Lightning-
-Carl Sagan
SL1200MK2
Fri Apr 09, 2021 9:10 pm
I do remember seeing a photo of a Delta C-130, but I may just be getting old and not remembering things properly.
ADent
Fri Apr 09, 2021 9:18 pm
Spacepope
Fri Apr 09, 2021 9:36 pm
Yes, though they planned to power that one with Pratts.
Lockheed also were certifying the C-141 as the L-300
Polot
Fri Apr 09, 2021 9:42 pm
Noshow wrote:
That still belongs to the Qatari Air Force. They just have it in QR’s livery to promote the airline especially when doing humanitarian work with the aircraft. Their other C-17s painted in standard military grey for use on missions where they might want more discretion.
Antaras
Fri Apr 09, 2021 9:44 pm
Noshow wrote:
Technically it belongs to Qatari AF, and in fact, QRAF operates many aircraft in QR livery.
If you disagree with my statement, assume that it was just a joke :duck:
Antaras
Fri Apr 09, 2021 9:46 pm
If Lockheed tried to offer the Galaxy as a civilian type, I don't know if I need a "NEO" option (for example: powered by GENx, Trent 1K).
And offer the NEO to both the military and commercial operator? Is it worth the R&D cost?
GalaxyFlyer
Fri Apr 09, 2021 9:50 pm
It’s done—CF-6 repowering to M model.
aeromoe
Fri Apr 09, 2021 9:54 pm
Just to be precise: the An-124 design is newer than the C-5 design. The C-5B airframes date from the 1980s...same time period as the An-124.
Since 60s: AA AC AS BA BD BF BN BR(85) BY B6 CO CZ(16) DG DL EA EI EN FI FL FT F9 HA HP ICX JI JQ J7 KE KL KS LH MC NW OC OO OZ(87) OZ(88) PA PI PN(97) PT QF QQ RM RO RV(99) RV(16) RW SK SM SQ S4 TI TS TW UA UK US UZ VS VX WA WN WS W7 XV YV YX(13) ZZ 9K
aeromoe
Fri Apr 09, 2021 9:55 pm
ADent wrote:
Technically it is an L-100. There are some physical differences.
Devilfish
Fri Apr 09, 2021 10:07 pm
Polot wrote:
Noshow wrote:
There is a C-17 in Qatar Airways colors isn't it? Said to sometimes be some transport for race horses?
It likely also accompanies the Emir's Flight when the latter is on official missions and there are lots to carry..... :weightlifter: .....
WayexTDI
Fri Apr 09, 2021 10:21 pm
aeromoe wrote:
What are the differences between the L-100 and the C-130?
WayexTDI
Fri Apr 09, 2021 10:23 pm
The C-5Bs were produced between 1986 and 1989, the An-124 between 1982 and 2004 (with an introduction in 1986, so most of the production is 1986 and later); the bulk of the An-124s are newer than the C-5Bs.
WayexTDI
Fri Apr 09, 2021 10:47 pm
Keep in mind that the civilian operators of the An-124 are Volga-Dnepr Airlines (Russia) and Antonov Airlines (Ukraine); while the latter is a division of the Antonov State Enterprise (designer of the An-124), the former was started as a joint-venture in which the Antonov State Enterprise is also a major shareholder (I cannot find their current stake in it). Later, in 2005, both companies formed a partnership called Ruslan Salis. So, basically, the civilian An-124s are operated by companies in which Antonov have financial interests (a "politically correct" way to say that the OEM is operating them in commercial operation).
ThePointblank
Fri Apr 09, 2021 11:37 pm
WayexTDI wrote:
On the current L-100J and C-130J, the most obvious visual difference would be the lack of lower windows under the windscreen, which allows the C-130J pilots to look ahead and down to see drop zones.
Another less obvious distinguishing feature is eighteen small, lightweight, strake-like devices on each side of the aircraft's aft fuselage near the cargo ramp door and horizontal tail on the C-130J, which the L-100J doesn't have. Finally, externally, the low voltage formation lights and the station keeping equipment on the C-130J are also not installed as you won't be flying a L-100 in tight formation flying.
Internally, various military specific bits of hardware are deleted or disabled, mostly surrounding the ability to air drop cargo, and of course, the air countermeasures suite. The flush toilet is also removed in the L-100J, as it is deemed that most flights with the L-100J are fairly short in length. The rear passenger doors also won't serve as paratrooper doors, and the deflectors in front of the doors are also disabled.
Also, the LOX system is also replaced by a gaseous oxygen system with two walk-around oxygen bottles for emergencies.
DaCubbyBearBar
Fri Apr 09, 2021 11:44 pm
I think that other than cost of acquisition would be spare parts! What operator could afford to buy just a few parts here and there. The price would be astronomical I believe
I am me and no one else...so my opinions are mine
N766UA
Fri Apr 09, 2021 11:59 pm
Who would want a C-5?! Fully loaded, it only has a 2500 mile range. It requires over a week of maintenance for every hour of flight. It's a completely useless airplane except in the hands of a military with an effectively unlimited budget and a fleet of tanker planes.
B595
Sat Apr 10, 2021 12:35 am
There’s a reason the C-5 got the nickname FRED: F* Ridiculous Economic Disaster. As others have already said, it would likely be cost-prohibitive for a civil operator. Both its development and operation have proven exorbitant
GalaxyFlyer
Sat Apr 10, 2021 1:00 am
I don’t where you got that info, but a C-5M will carry 125,000# non-stop LTAG, westbound to KDOV easily, that’s 4,900 nautical great circle. Even an A would take a full load of pallets, ETAR to KDOV, both without refueling. The AN stops are PIK and YQX, so I’m betting their range isn’t a lot better. An M with a 200k load can fly 8+30 at M.79. Maintenance-intensive? Sure, but it’s pretty complicated machine, worked on inexperienced techs right out of tech school. I’ve gone 3 years without a broken jet. Once flew 13.4 hours of beating up the traffic pattern, three days on a row. Not easy on the plane, for sure.
Antaras
Sat Apr 10, 2021 1:22 am
Actually, if I could choose a military workhorse to be commercialized, I would choose the C-17 but not the C-5
GalaxyFlyer
Sat Apr 10, 2021 1:44 am
Not if you flew them, you wouldn’t. The C-5M has so many more load carrying options for heavy or out-sized cargo.
MohawkWeekend
Sat Apr 10, 2021 2:18 am
I recall seeing C-133's parked at Anchorage (C-133's were big airplanes). Weren't those along with the C-119K's operated in Alaska?
    300 319 320 321 707 717 720 727 72S 737 73S 734 735 73G 738 739 747 757 762 ARJ B11 C212 CRJ CR2 CR7 CR9 CV5 D8S DC9 D9S D94 D95 D10 DH8 DTO EMB EM2 E135 E145 E190 FH7 F28 F100 FTRIMTR HRN L10 L15 M80 M90 SF3 SWM YS11
    GalaxyFlyer
    Sat Apr 10, 2021 2:27 am
    Drill pipe for pipeline, I think. 133s were built to hail ICBMs. Lot of mysterious crashes in them, too.
    MohawkWeekend
    Sat Apr 10, 2021 2:58 am
    Good looking planes with weird face - believe they were actively involved in supporting the war in se Asia. I wonder who operated the aircraft in Alaska? Unless it was a Govt Agency, that would be a precedent to use C-5's in a civilian capacity. How about a water bomber?
      Spacepope
      Sat Apr 10, 2021 3:01 am
      Pipeline doesn’t use drill pipe. Oil wells do though. Lots of it. In the conus it gets hauled by semi though, getting it to remote drill sites in Alaska takes airlift though. What ever happened to that swing tail cone MD-80 proposal for drill pipe from a few years back?
      Antarius
      Sat Apr 10, 2021 3:58 am
      Depends on the cargo. That's the point made above - there's a market for Volga with their small fleet and then there is the military with endless budgets.
      It isn't like there is endless demand for outsized cargo that needs to be transported on an aircraft. Otherwise there would be an economically viable option.
      Militant Centrist
      TWA772LR
      Sat Apr 10, 2021 5:38 am
      Fun fact: Lockheed actually did build an L300 and put it on an around the world sales your. The one example ended up at NASA to become the Kuiper Airborne Observatory, the forerunner to today's SOFIA.
      hawaiian717
      Sat Apr 10, 2021 6:07 am
      Boeing tried too as the BC-17. Nether sold. The market for such an aircraft is limited and the cost of owning a commercial C-17 variant was unattractive compared to the cost of chartering an An-124 when needed.
      Chasensfo
      Sat Apr 10, 2021 6:46 am
      At one point, a civilian version was considered for The Flying Tiger Line, and desk top models for them, but it never went beyond that.
      ELBOB
      Sat Apr 10, 2021 7:00 am
      I don't think the original poster meant "sell" as much as "charter", so spares and maintenance would remain with the USAF.
      As an aside, Lockheed sketched some commercial versions of the Galaxy seating up to 1,033 passengers!
      cougar15
      Sat Apr 10, 2021 7:18 am
      There is a rare 1/144 scale model of an L500 out there somewhere in Pan Am colours, so the wishful thinking was there at the time.
      some you lose, others you can´t win!
      TWA772LR
      Sat Apr 10, 2021 7:38 am
      I found this after reading your post.
      https://www.aviationmegastore.com/c5a-g ... art=116864
      VSMUT
      Sat Apr 10, 2021 7:44 am
      A more significant reason is that it lacks the overhead gantry crane. A family member worked in the heavy lift industry (heavy lift ships to be fair, but there is actually a fair bit of overlap). The crane is central to loading these aircraft with commercial loads to the extent that these niche operators won't even consider aircraft that don't have it.
      WIederling
      Sat Apr 10, 2021 8:51 am
      how long would a C5 take the hard use that the An-124 get?
      and capabilities aren't the same.
      Internal infrastructure and the demand on external infrastructure are far apart, aren't they?
      C5 is a box carrier,
      The Antonov a tramp freighter with heavy duty autonomous loading equipment.
      Murphy is an optimist
      Noshow
      Sat Apr 10, 2021 8:57 am
      Box carrier? The C-5 is made to carry even main battle tanks.
      Polot
      Sat Apr 10, 2021 10:30 am
      Calling a C5 a “box carrier” is really underselling the aircraft. I don’t know many box carriers that allow you to roll tanks and helicopters into them. The An-124 was basically designed to be the USSR’s equivalent to the C-5 with similar roles in the military fleet.
      Fully loaded the An-124 has similar range. Most commercial operations of the An-124 are taking advantage of its ability to fit large/oversized cargo that cannot fit in regular commercial freighters, not the plane’s max payload capability. If all you are doing is carrying a lot of stuff that can fit in a normal freighter it is usually cheaper to just charter multiple ones of those then a An-124.
      rbavfan
      Sat Apr 10, 2021 10:37 am
      The C-5 has always been a maintenance hog. It would not work for civilian markets do to op cost vs 747-400R/777F.
