asuflyer
Russia denies entry to AF and OS flights to SVO and DME
Thu May 27, 2021 2:11 pm
Russia has denied entrance to its airspace for 2 OS and AF flights bound for Moscow after they planned their routes bypassing Belarus, rapidly increasing diplomatic fallout from the Ryanair hijacking. The affected flights are OS601 from VIE to DME and AF1154 from CDG to SVO.
https://www.reuters.com/world/europe/ai ... 021-05-26/
Noshow
Re: Russia denies entry to AF and OS flights to SVO and DME
Thu May 27, 2021 2:56 pm
I hope we don't end up in some cold trade war fighting aviation.
DUSZRH
Thu May 27, 2021 3:00 pm
Apparently only affecting MOW flights. The new routes via the baltics need new approval. LED flights are hence not affected...
DocLightning
Thu May 27, 2021 3:08 pm
So this might not actually be diplomatic anything. I have to think that it would effect more flights if this was something coming from the level of the Kremlin. This might just be Russian bureaucracy being Russian bureaucracy.
While it's true that Russian airspace is valuable for Europe-Asia services, Russia would be wise not to overestimate its value. Certainly, in 1990 after the fall of the USSR, the 747-400 was the longest-range airliner and the opening of Russian airspace to these flights was invaluable.
But in 2021, while airlines don't want to have to go the long way around Russia, modern airliners absolutely can take such a route. From LHR to NRT it involves about a 20% longer distance. This would cost time and fuel, but it's not a complete show-stopper. And for routes to more southern Asian locations like SIN, avoiding Russian airspace would only add a trivial extra distance to the flight.
-Doc Lightning-
-Carl Sagan
hoons90
Thu May 27, 2021 3:54 pm
Indeed.
I recall KE was avoiding Russian airspace on routes as long as ICN-MAD/BCN in the past, presumably because they ran out of their overflight allotments.
LOT BUD-ICN and v.v. doesn't use Russian airspace either.
Flown: 2L 7C 9E 9L AA AB AC AF AY AZ BA BR BX B6 CA CO CP CX DL EK EY JL KE KL LA LH LX MQ NW OZ PD RW SQ TG TP TR TS US WG WN WS XE XJ
LAXintl
Thu May 27, 2021 4:02 pm
Russia overflights are routing-specific and have entry and exit points and generally applied for months in advance.
If you show up at a different location than intended in approval, then the respective ATC unit will rightfully deny entry.
N757ST
Thu May 27, 2021 4:08 pm
Is this true? That’s some wicked inflexibility and it’s the only country then that I’ve heard of doing that. What happens if there is weather over that routing? The flight cancels? What if there’s severe turbulence? Cancel? Flight plans are filed a couple hours in advance, not days, weeks, or months.
UPlog
Thu May 27, 2021 4:32 pm
Yes many nations have specific route approval for overflight. Two big ones being Russia and China, but they also exist in parts of Middle East, Africa and Latin America. You need to enter and exit at defined points.
Minor weather deviations are allowed with approval, but you are expected to largely maintain your approved routing for which you applied for in advance.
I fly your boxes
holczakker
Thu May 27, 2021 4:40 pm
With all respect, is wicked inflexibility of Russia a new thing for you? You submit a request with the desired routing, you get permission for that route, you file it and fly it. The same for Ukraine and a quite couple of eastern countries. If you want to change anything you need a lot of time. If you want a change within a day you need someone who speaks russian and has friends at the authorities. If you want a last minute change (or anything out of office hours), forget it, no chance. If you change the routing on your own, you refused to enter their airspace.
slcdeltarumd11
Thu May 27, 2021 6:08 pm
The key word is they "may" not grant you access. If there is a storm or something then they can allow you access etc etc.
DocLightning
Thu May 27, 2021 7:14 pm
Have you ever been to Russia? Have you ever dealt with a Russian bureaucrat? (hint, you will meet one at the border). Russian bureaucracy is world-renowned. Russian bureaucrats make the Vogons look like sloppy laggards.
The only country I've ever encountered with a more onerous bureaucracy is India. Although I once almost got detained in Mexico solely because the cruise line lost my exit form. I've never been to China (other than Hong Kong), but I have heard that their bureaucracy is also quite...arduous.
-Doc Lightning-
-Carl Sagan
oldJoe
Thu May 27, 2021 7:27 pm
Really ? The reality tells me something complete different. One example of many BA 257 which is currently underway and clearly didn`t fly over Belarus
https://www.flightradar24.com/BAW257/27d91000
If you check the same flight from Saturday 22nd May you can see they flew straight through Belarus ! This is only one example of many airlines doing the same
Given the large number of airlines that currently avoid Belarus and then fly via Russia, this cannot be the truth
oldJoe
Thu May 27, 2021 8:35 pm
Yes, I've even been to Russia very often and I think, if you understand the Russian mentality, everything is very easy in this country.
To be fair, I have to say that I can speak Russian and my wife is Russian too. As my father-in-law always says: This is Russia and everything is possible here.
Or: one hand washes the other and then both are dirty if you understand what I mean !?
I can't say anything about the bureaucratic hurdles that airlines have to overcome with Russia.
WayexTDI
Thu May 27, 2021 9:01 pm
That's the official reason that was given: flight plans needed to be modified to avoid Belarus airspace, changing the point of entry into Russian airspace. Russia had not given clearance on the new flight plans by the time the flights were about to take off and the flights were cancelled.
oldJoe
Thu May 27, 2021 9:14 pm
And how do you explain how so many other airlines can sort it out in a very short time
WayexTDI
Thu May 27, 2021 9:17 pm
Russia supports Belarus, France prevented yesterday an aircraft from Belarus to enter French airspace: you cannot see the retaliation?
Russian authorities decided to drag their feet on AF application, as retaliation, but to expedite others; how's that the airline's fault?
oldJoe
Thu May 27, 2021 9:28 pm
How you explain OS601 ? Retaliation for what ?
mercure1
Thu May 27, 2021 9:32 pm
Depending on the nations involved, overflight permits are often something airlines apply for months in advance and are not something that can be changed on a whim.
A single desired routing change may impact planned airspace transit in several nations, so all must be coordinated and updated which may take days to accomplish.
mercure f-wtcc
DaCubbyBearBar
Thu May 27, 2021 10:41 pm
For some reason I am seeing John Malkovich and Matt Damon sitting across from each other at a poker table.....
I am me and no one else...so my opinions are mine
LTEN11
Thu May 27, 2021 10:53 pm
Yet in other parts of the world, airspace can be closed due to heightened political tensions, as happened when Iran and the U.S. had their last tiff and the airlines managed to get rerouted around the troubled areas with no obvious problems.
This is purely tit for tat.
tu204
Thu May 27, 2021 11:27 pm
As many have stated here, there is nothing but a formality.
You apply for overflight/entrance/exit to the Russian Federation 72hours (preferred, but 24hours minimum) before you plan to enter. You file this to the Ministry of Transport (Rosaviatsiya), this request for and then the permission includes some flight information including the intersection (point) where you enter. Then within whatever time your local authority requires (several hours or whatever) you file a flight plan. If your flight plan's entry point is different from what you applied for (and were approved) in your permission that you originally asked for, well your flight plan gets denied as soon as the Russian side receives it (hopefully before you take off btw).
Annoying, but makes perfect sense.
A flight plan is not a permission of entry into the Russian Federation. You file for permission, then based on that you file a flight plan. Maybe OS and AF filed for blanket permissions for a month worth of flights back in April for all of May and forgot to modify them once the ban was put in place.
Plainly their fault or whomever they use for handling. Others didn't have this problem and they had several days to notify of change of entry point before they filed their flightplans.
I do not dream about movie stars, they must dream about me for I am real and they are not. - Alexander Popov
WayexTDI
Ask Vlad', I don't know.
Do you really believe one of the (if not THE) closest ally to Belarus would not retaliate against an entity (Europe) that's considering banning Belarus within its airspace?
WayexTDI
Thu May 27, 2021 11:30 pm
You apply for overflight/entrance/exit to the Russian Federation 72hours before you plan to enter. You file this to the Ministry of Transport (Rosaviatsiya), this request for and then the permission includes some flight information including the intersection (point) where you enter. Then within whatever time your local authority requires (several hours or whatever) you file a flight plan. If your flight plan's entry point is different from what you applied for (and were approved) in your permission that you originally asked for, well your flight plan gets denied as soon as the Russian side receives it (hopefully before you take off btw).
A flight plan is not a permission of entry into the Russian Federation. You file for permission, then based on that you file a flight plan. Maybe OS and AF file blanked permissions for a month worth of flights back in April for all of May and forgot to modify them once the ban was put in place.
So, you're saying that, in the event of bad weather around Russia's borders, an airline has the choice between flying through that bad weather or scrapping the flight altogether?
tu204
Thu May 27, 2021 11:43 pm
Nope. Because you file the flight plan as your original route, then enroute you start diverting due to weather, once tou are already enroute and talking to ATC.
Lets say you are flying from Turkey into Russia. Entry point is "TUDEK" (south of Sochi). You file the flight plan as per permission from Turkey, and while speaking to Ankara Control, you see some shit and wanna go 50nm West. You tell this to Ankara, who are talking to Rostov Control and they notify/request, Rostov grants it, Ankara grants you and hands you off to Rostov when you hit the FIR boundary.
What's important here is that the flight plan you FILED corresponds to your permission. In this case "TUDEK" as the entry point. Enroute you can change. But let's say if you file a flight plan with entry through "BALUM" (next entry point over to the West from TUDEK), well, don't be surprised if your flight plan doesn't go through. Change in the air, sure, but file as permitted.
WayexTDI
Thu May 27, 2021 11:48 pm
So, you file your scheduled route, knowing you cannot fly it because of the weather, and divert in-route? Sounds like classic bureaucracy shenanigans
tu204
Fri May 28, 2021 12:02 am
Yup. Pretty much. Realistically through you are not gonna divert 100nm+ on a regular basis unless you have some tropical storm in the way (it's not like entry points are every 20nm), so it's a non issue.
Plus I don't know how the Russian ATC system handles foreign flight plans when they are filed (when I fly abroad company handles that), but for internal Russian IFR plans you file through their website (at least 30 minutes in advance) first it goes through a computer, which can automatically reject it before a person even sees it. When I fly private I file my own plans.
Heck just yesterday I was flying with a buddy on his piston twin from UWKD to a private strip near UWGG and I got 2 rejects due to a conflict in the plan (in the decent, through restricted airspace which I knew and confirmed wouldn't be active at the time of arrival).
Call Moscow center, ask why I got a reject, flight planning specialists is pissed, he understands but he never even for the plan, computer rejected something like 8 seconds after I filed. Took us 5-10 minutes on the phone for me to re-file and him to block computer from rejecting it immediately.
Could be same here. But more inclined to believe that since it was only two flights that someone in dispatch "did everything as they usually do" without realising that they had to do some double checking and making sure. Nothing political.
peterinlisbon
Fri May 28, 2021 12:45 am
I was once on a flight from Hong Kong to London that was denied permission to fly over Russia. We waited 4 hours at the gate, then they had to take everyone off the plane and put them in a hotel for the night. What made it worse was that this was the first flight ever for a brand new airline. Even the CEO was on board. The next day we flew the route avoiding Russian airspace and it took 13 hours.
I don´t know if that was bureaucracy or politics but the pilot explained to me that it was only when they tried to get clearance that they found out there was a problem, as each ATC authority contacts the next one to check that they can pass the flight on. So maybe something similar is happening here.
cschleic
Fri May 28, 2021 1:00 am
Wonder if this is having much of an impact on Finnair which has a lot of flights over Russia. Or maybe many of those flights aren't operating right now? Either way, it's a big revenue source for Russia.
schernov
Fri May 28, 2021 2:45 am
The interesting bit is that after that AF flight was cancelled, AF arranged for SU to send a 777 to CDG and fly all of the passengers to SVO.
Although AF and SU are both skyteam, it was not a regularly scheduled SU flight.
https://m.gazeta.ru/politics/2021/05/27 ... 0348.shtml
Insertnamehere
Fri May 28, 2021 3:17 am
As a Russian, the one key component you’re leaving out is greasing officials palms. While it’s not as common as in the past, it’s absolutely possible to get expedited if you’re giving a “convenience fee” to the right people. Have experience with that personally with consulate staff back when Russia had a consulate in Houston and needed to get my passport renewed.
While I’m not saying the airlines need to bribe Russian officials. I’m sure if this turns into needing more paperwork, I’m sure there’s an official somewhere in Russia who would grant more leniency to an airline if their family were more likely to receive an upgrade the next few times their families decide to travel to France or Spain once Europe opens up to Russians.
RoyalBrunei757
Fri May 28, 2021 3:21 am
Sounds like Oasis Hong Kong Airlines (RIP).
Max Q
Fri May 28, 2021 3:40 am
Anyone see a cheesy movie ‘white knights’ ?
The opening scene involves a 747 having to divert and make an unplanned emergency landing at a Russian airport
Unfortunately for him a Russian defector is on board and spends the last few minutes of the flight trying to remove all his identifying information including flushing his US passport down the toilet after tearing it into pieces
Didnt work though, they knew who he was
This whole episode reminds me of that movie
GGg
hoons90
Fri May 28, 2021 3:53 am
While not ideal from an economic standpoint, Finnair can operate Helsinki-East Asia flights non-stop, at least with A350s. In fact, Finnair has operated Helsinki-Tokyo nonstop for several years while avoiding Soviet airspace, with DC-10-30ERs.
Such a detour could make some routes to lower margin secondary cities unprofitable, though.
hooverman
Fri May 28, 2021 5:04 am
Let’s see what happens coming days but my gut feeling says this is retaliation.
Kikko19
Fri May 28, 2021 5:39 am
Indeed.
Sure but if they close their airspace to someone and not to others 20% will make the difference and the competition would end on those routes with ticket prices and freight prices increase. I would expect then some reply from EU.
VSMUT
Fri May 28, 2021 6:01 am
I can definitely believe the apparatchik explanation. I've had the misfortune of dealing with the types before, they are the types who will tell an ATR to climb to FL400, and insist it is your problem that the aircraft can't do it.
KLM managed to fly to Moscow tonight and back in the morning, touring north of Belarus, so they definitely aren't forcing European airlines to do it. It probably just means KLM has more experienced people on the ground in Russia to push the papers and grease the right hands.
Aeroflot has been operating non-scheduled 777 and A330 flights to Europe throughout the Covid-19 outbreak.
stl07
Fri May 28, 2021 6:40 am
THAT explains it! When I landed in Goa, all the American/British tourists coming for the music festivals and beach resorts seemed extremely frustrated at Indian customs but the Russians seems completely unfazed by it
Instead of typing in "mods", consider using the report function.
Love how every "travel blogger" says they will never fly AA/Ethihad again and then says it again and again on subsequent flights.
EFHK
Fri May 28, 2021 8:01 am
So far this issue has concerned two single flights from two different airlines that normally operate over Belarus, so let's not get ahead of ourselves here. 99% of flights to/from/over Russia are operating perfectly normally at the moment. Also, AY has practically no flights that would fly over both Belarus & Russia under normal circumstances.
It's interesting info that has been presented in this thread that the overfly permits would specify a certain point of entry. I assume that this can differ per permit, or then long-haul flights may have e.g. two separate entry points, since at least AY flights (e.g. to HKG) regularly enter/leave Russian airspace through two different waypoints - one around LED and one in Karelia.
Now, if the situation would escalate much further and Russia would start revoking overflight permits for example from all EU airlines, it would be interesting to see whether we'd see AY taking up the polar route again to Japan. It could be feasible, but also the airlines having still the overflight permits granted and e.g. the ME3 could probably rather easily snatch up most of the traffic rather cost-efficiently. Essentially, if one doesn't play by Russia's rules, it'll be a lose-lose situation.
Noshow
Fri May 28, 2021 8:10 am
It's a two way street and Russia wants traffic and income too and has to play by the rules itself.
VSMUT
Fri May 28, 2021 9:06 am
Finnair AY715 has landed in Moscow without issues.
LOT 675, Swiss 1326, Austrian 601 and Lufthansa 1444 are all underway to Moscow right now, all circumventing Belarus, with LOT about to land right now.
Looks like a storm in a teacup by the hawks IMHO.
Edit: Now the Lufthansa plane is also in Russian airspace.
TRC
Fri May 28, 2021 9:14 am
In the case of AF it is clearly an indirect political retaliation after Belavia flight from MSQ to BCN was denied entering French airspace.
The 2 AF flights to Mosciw SVO, past Wednesday and yesterday (operated in Boeing 787-9) were cancelled and today (Airbus A319) as well. AF requests to change flight plans were perfectly sent ontime to the Russian authorities but so far until now... still no reply from their side since....Tuesday! Purely political black mailing ignoring AF demand.
Yes AF and SU found a common arrangement by sending yesterday to CDG an SU 77W and today an SU A333 (instead of the usual SU A320/A321 5-6 times per week).
AF flights to LED (twice per week A319) seem not be affected for the moment: AF aircraft flew to LED on Wednesaday and next flight is still planned for tomorrow.
Las but not least AF is supposed to start flying next week to SVO with A350 if situation allows it.
hooverman
Fri May 28, 2021 9:45 am
I guess I have to eat my words by saying it could be retaliation. :white:
EFHK
Fri May 28, 2021 10:22 am
Yes, hence lose-lose-situation. I still don't believe that Russia wouldn't be ready to put themselves in such situation under certain circumstances though.
I don't think you have to, it most certainly is retaliation! But not full on - just enough that they got to make a point and push it through in the Western media, without really causing any big problems (yet).
peterinlisbon
Fri May 28, 2021 11:14 am
Yes, it was. That was a great airline, actually, and they gave everyone on that flight a free return so I was able to go back again to Hong Kong the next year.
VSMUT
Fri May 28, 2021 5:25 pm
The Belavia flight was denied by Poland, not France. It didn't even leave Belarusian airspace. KLM is the same company and is still allowed to fly. As you yourself wrote, it is clear that only flights that were previously filed through Belarus are affected, since St. Petersburg doesn't go via Belarus. But nice try.
TRC
Fri May 28, 2021 6:04 pm
Not at all, today Belarussian Prime Minister Roman Golovchenko met in Minsk Russian Prime Minister Mikhail Mishustin.
Golovchenko declared "An outrageous incident took place on a Minsk-Barcelona flight yesterday. As our airplane was gaining altitude, we received information on the closing of the airspace over France in violation of all aviation regulations and rules. As a result, our plane had to return to Minsk."
So the reason why the flight to BCN did not go out of Belarus airspace is because France closed its airspace to Belavia.
Pure Russian political decisions against AF and OS!
Full declaration is here: http://government.ru/en/news/42330/
artflyer
Fri May 28, 2021 9:47 pm
Nope. That particular Belavia flight was not denied by Poland. At that time there was no notam prohibiting Belavia access to Polish airspace as evidenced by the fact that on that very day other Belavia flights still used Polish airspace, and Belavia even made the flight to WAW on that date (the EU council agreed that the sanctions on Belavia will enter into force only from the next day onwards).
So why that plane did not enter Polish airspace? I guess they did not want to pay for overflight to Poland after they realised they may have difficulty to reach the final destination and decided to stay circiling in the Belarussian airspace until finally confirmed that they should head back to MSQ.
tu204
Fri May 28, 2021 11:33 pm
Making absolutely no sense here...read this thread more thoroughly.
32andBelow
Sat May 29, 2021 12:59 am
It’s 2021 wtf are they doing with their airspace. We let Antoine cross the US in a direction they want.
Sat May 29, 2021 2:21 am
China is worse, very strict entry and exit points, internal airways are for Chinese mainland carriers only. For weather deviation ATC will often deny any request or limit to 6-10 nm, and you declare and emergency and do it anyway.
Russia is better than China, my experience with Russian ATC has always been positive, in an emergency very good as well.
I think what would have happened in this case is Russian ATC was not given enough notice, normally they want 48 hrs notice particularly when changing the control zone entering the FIR. The reason for this is many routes have capacity limits.
“Don't be a show-off. Never be too proud to turn back. There are old pilots and bold pilots, but no old, bold pilots.” E. Hamilton Lee, 1949
