mpgunner
ASA 164 SEA to PDX delay today - 5/27/2021
Fri May 28, 2021 3:42 am
My wife was on this flight today. They pushed off on time but then waited for 50 minutes before taking off. The captain came on and said the delay was due to construction at PDX and there was only 1 runway available. She said he sounded like he didn't believe this explanation but had to say it.
It was strange to watch FlightAware after the push back for about 10 minutes it was "on time" but then a 50 minute delay was showing up.
Does anyone know why or was the delay actually due to construction.
ATCJesus
Re: ASA 164 SEA to PDX delay today - 5/27/2021
Fri May 28, 2021 3:53 am
PDX - RWY 10R/28L CLOSED UNTIL 05/28/21 2200Z
Depends on demand at the airport. But looks real.
atcsundevil
Fri May 28, 2021 3:57 am
FAA OIS says PDX - RWY 10R/28L CLOSED UNTIL 05/28/21 2200Z
I don't work on the west coast, so I don't have firsthand knowledge with PDX, but generally the closer you are to the destination that's being metered, the more likely you are to get the shaft. There's already an enroute flow to an airport with aircraft that are airborne, and for obvious reasons, they get priority over aircraft sitting on the ground. The Traffic Management Unit (TMU) will issue an Expect Departure Clearance Time (EDCT) based on that enroute flow. The computer essentially tells the TMU controller when a gap will exist and when the aircraft should be released. The closer you are to the destination, the smaller those gaps are likely to be. In cases like this, pilots love to blame ATC, but it's just common sense — you're not going to delay an aircraft in the air to make room for one on the ground.
https://www.fly.faa.gov/adv/adv_spt.jsp
DLASFlyer
It was also very windy today.
airlinepeanuts
Fri May 28, 2021 4:17 am
Why would she not believe this excuse?
JakeWelty
Fri May 28, 2021 5:54 am
Work in ATC & we get call for releases or ground delay programs for the PDX rwy construction...
DaCubbyBearBar
Fri May 28, 2021 6:52 am
Got to fly LASPDX about 15 years ago, the parallel runways were open, and we had a 2 hour 30 minute flow delay into PDX due to the winds. Granted in was a 6pm scheduled departure, so the delays had been building up. But it was just due to the winds up in PDX. It was a NASTY approach when we got there. So anything is always possible. Why would the pilot lie about the delay?? In today’s day and age it only takes a minute to find information on anything and everything
I am me and no one else...so my opinions are mine
