720B
LATAM B787 Dreamliner Suffers Gear Damage In Santiago International Airport
Wed Jun 09, 2021 12:31 am
ClipperYankee
Re: LATAM B787 Dreamliner Suffers Gear Damage In Santiago International Airport
Wed Jun 09, 2021 1:51 am
That does look quite bent up. Is this the first major landing gear damage on a 787? I don't recall reading of others.
SRQLOT
Wed Jun 09, 2021 1:55 am
I thought hard landings in the 787 were difficult to do, so yeah haven’t seen that yet. 787 were some of the smoothest landings for me.
Weatherwatcher1
Wed Jun 09, 2021 1:58 am
Looks like an axle failure. Here is a picture from a 777 when an axle failed
https://aviation-safety.net/wikibase/wiki.php?id=212714
A hard landing can cause an axle to fail, but so can stress corrosion cracking. If there is improper maintenance (such as an incorrect solvent being used on the axle) or a manufacturing defect, it can lead to a premature failure.
Weatherwatcher1
Wed Jun 09, 2021 2:03 am
I haven’t seen an axle failure in a 787 before, but have seen it on other airplanes. Here is a thread with an example of it happening on an A320 at the gate
viewtopic.php?t=1362391
https://mobile.twitter.com/AielloTV/sta ... 6555496449
VMCA787
Wed Jun 09, 2021 6:42 am
Of course, you do realize the tire standing on its own is a replacement? So, take that out of the picture and I wouldn't say there was damage at all, certainly not "mangled"!
7673mech
Mon Jul 26, 2021 3:06 am
Did you guys read the report? A tire blew. No catastrophic failure, no cracks, no bad maintenance.
JohanTally
Mon Jul 26, 2021 3:35 am
That was my first thought. MTC will often lean the replacement tire against the gear during a tire change.
Mon Jul 26, 2021 5:38 am
Where I work they are kept in the transport cage until needed.
JohanTally
Mon Jul 26, 2021 5:18 pm
Although not SOP it is quite common practice
https://youtu.be/UQObeXnSDzc
