AirDO
Re: Updated: Used Delta Aircraft Purchase A359/737-900ER
Mon Nov 29, 2021 2:15 am
PK-LSG of Lion appear to fly back to CGK on 25 November. It appeared this one is bound for DL fleet next. So VP-CIC must be ex PK-LBJ as stated by dalmit.
https://www.flightradar24.com/data/airc ... g#29f7d405
timf
Tue Nov 30, 2021 1:41 pm
I was away for a few days but concur with dalmit's analysis.
Remaining aircraft and their projected Cayman registrations:
PK-LQS -> VP-CEF
PK-LSG -> VP-CEI
PK-LBM -> VP-CFB
9M-LNG -> VP-CF_ (could be I,J,L,M,N,Q)
PK-LBO -> VP-CFT
AirDO
Wed Dec 01, 2021 3:52 am
Updated: PK-LSG just returned back to CGK last night 30/11/2021 at around 7:37 PM WIB. As stated before, this aircraft should be ready to be ferried in couple of days or weeks to USA via HNL and GUM which this aircraft will be solded to DL next. There are 5 more B739 due for DL which they are stated by timf before.
https://www.flightradar24.com/data/airc ... g#2a080980
AirDO
Wed Dec 01, 2021 3:54 am
PK-LQS -> VP-CEF
PK-LSG -> VP-CEI
PK-LBM -> VP-CFB
PK-LBO -> VP-CFT
I've add all of them to my notepad now.
AirDO
Wed Dec 01, 2021 3:29 pm
B739 ex PK-LHW is now registered as N935DH.
https://www.planespotters.net/airframe/ ... nes/e22n24
RoyalBrunei757
Thu Dec 02, 2021 7:39 am
Time to run a summary:
New Registration / MSN /Line No./ Previous Registration
1. N932DS 37290 / 3918 PK-LQU
2. N933DJ 37291 / 3966 PK-LJP
3. N935DH 38302 / 3753 PK-LHW
4. N936DU 38304 / 5162 HS-LTK
5. N937DM 38313 / 3936 PK-LJM
6. N938DB 38315 / 3954 PK-LJO
7. N939DG 38684 / 4266 PK-LKO
8. N940DJ 38687 / 4368 9M-LNF
9. N941DB 38688 / 4414 PK-LBG
10. N943DB 38690 / 4495 9M-LNJ
11. N944DR 38720 / 4056 PK-LJT
12. N946DC 38730 / 4430 PK-LBH
13. N948DJ 38732 / 4484 9M-LNH
14. N949DK 38736 / 4592 9M-LNL
15. N950DA 38737 / 4600 9M-LNK
16. N951DA 38739 / 4657 HS-LTH
17. N952DJ 38741 / 4679 PK-LOF
18. N954DJ 38743 / 4711 PK-LBI
19. N955DE 38748 / 4822 HS-LTL
20. N956DD 39823 / 5070 HS-LTJ
21. N957DR 39824 / 5088 PK-LSQ
22. N958DJ 39878 / 5096 PK-LPH
23. N959DV 39880 / 5081 PK-LPF
Source: airfleets.net
Six more to go to complete the delivery. atcpilot_photography in Instagram managed to capture this amazing image of the above 22 B737-9GP/ER presently stored at San Bernardino.
https://www.instagram.com/p/CWm6mp8LYC-/
AirDO
Thu Dec 02, 2021 12:58 pm
VP-CFH today is making it's path to USA now and just landed in GUM. This is possibly an ex Batik Air aircraft to me and is ex PK-LBM.
https://flightaware.com/live/flight/VPCFH
AirDO
Thu Dec 02, 2021 12:59 pm
I can see clearly their US registered aircraft in this IG picture. But still in JT livery. Hope it gets painted and configured soon.
timf
Thu Dec 02, 2021 1:40 pm
Also add
N953DC 38742 / 4726 PK-LBJ
timf
Thu Dec 02, 2021 1:48 pm
This is most likely 9M-LNG (38729/4380), the one I had as VP-CF_. I did not list H as a possibility because I skipped a letter for PK-LJT which never was reported with a Cayman registration, but it's possible they had already ferried that aircraft before they started the intermediate registrations.
Prost
Thu Dec 02, 2021 7:14 pm
Does door two get changed to the type of door that Delta normally has plugged on their 737-900? The LionAir planes have porthole windows versus Deltas regular cabin windows.
Thu Dec 02, 2021 7:34 pm
When will the first 73J and 359 be put in service ?
Polot
Thu Dec 02, 2021 7:40 pm
Yes, it’s just a simple plug (very noticeable from outside of plane) that replaces the exit door. The regular size cabin window is part of the plug.
SXDFC
Thu Dec 02, 2021 7:54 pm
I’ve always wondered why they can’t make a MAX9 (since the 900ER is no longer sold) without the plug if the customer doesn’t want to or need to have an exit door there..
Polot
Thu Dec 02, 2021 7:55 pm
Resale.
AirDO
Fri Dec 03, 2021 1:19 am
Most likely the first one will enter around February and final by around September or December of next year.
jbs2886
Fri Dec 03, 2021 1:47 am
What is your support for that? IIRC Delta specifically said into 2023.
AirDO
Fri Dec 03, 2021 3:01 am
Usually, DL 738 they got from 2016. They modified it and take just less than a year to modified. Look at N377DE, it was brought by DL in July 2016 and enter in May 2017. Most of the B739 should enter around that time.
jbs2886
Fri Dec 03, 2021 3:30 am
That was 4 aircraft, not 40+. Either way, don’t say they will definitely enter by a time if you don’t know, say you think and provide your basis.
Boof02671
Fri Dec 03, 2021 11:20 am
Delta has stated that they hope to have the first plane in service summer of 2022
AirDO
Sat Dec 04, 2021 12:44 am
And the interior of these B739 will be the same as existing B739 or it's going to be like the A220's?
PSU.DTW.SCE
Sat Dec 04, 2021 3:57 am
DL has said that it will take through Summer 2023 to induct these aircraft.
The reality is there are capacity / throughput for TechOps/MRO work & mods, lead times and availability of seats/interior fittings, and other aspects, along with their planned deliveries of new aircraft in 2022 & 2023 that also require induction activities.
Realistically, I would anticipate them to enter the fleet at about a rate of 2-3 739s per month and an A359 every other month starting in mid-2022.
RoyalBrunei757
Mon Dec 06, 2021 5:20 am
Running an update, thank you to AirDo and timf input.
18. N953DC 38742 / 4726 PK-LBJ
19. N935DH 38302 / 3753 PK-LHW
20. N954DJ 38743 / 4711 PK-LBI
21. N955DE 38748 / 4822 HS-LTL
22. N956DD 39823 / 5070 HS-LTJ
23. N957DR 39824 / 5088 PK-LSQ
24. N958DJ 39878 / 5096 PK-LPH
25. N959DV 39880 / 5081 PK-LPF
Source: planespotters.net, airfleets.net
N952DC and N953DH identities are now confirmed, leaving four more frames to complete 29 B739ER leases.
Waiting for VP-CFH (suspected PK-LBM) and 9M-LNG new identity confirmation, once confirmed, leaving two more deliveries.
jeffrey0032j
Mon Dec 06, 2021 6:43 am
You have a double count for PK-LHW.
RoyalBrunei757
Mon Dec 06, 2021 7:38 am
In dire need to coffee on Monday morning. 24 frames confirmed identities, leaving five frames (VP-CFH (suspected PK-LBM) and 9M-LNG confirmation pending).
19. N954DJ 38743 / 4711 PK-LBI
20. N955DE 38748 / 4822 HS-LTL
21. N956DD 39823 / 5070 HS-LTJ
22. N957DR 39824 / 5088 PK-LSQ
23. N958DJ 39878 / 5096 PK-LPH
24. N959DV 39880 / 5081 PK-LPF
AirDO
Tue Dec 07, 2021 12:40 am
9M-LNG still reported stored in SZB.
AirDO
Wed Dec 08, 2021 2:45 am
timf wrote:
Also add
And also N942DC fmr PK-LBM is just registered yesterday
timf
Wed Dec 08, 2021 2:16 pm
That's interesting. Has that plane ferried from Asia yet or is this the first one they've registered in the U.S. prior to ferrying?
AirDO
Wed Dec 08, 2021 3:50 pm
This one was brought by Castlelake as VP-CFH before registered to DL. Now 155/159. Next 4 is: PK-LQS (still stored in BTH and should be ferried to CGK soon), PK-LSG (Currently in maintenance at CGK before joining DL), PK-LBO (Currently stored in CGK) and 9M-LNG (Currently stored in SZB).
timf
Wed Dec 08, 2021 6:53 pm
VP-CFH should have been 9M-LNG (the eventual N945D_), so if it really got assigned to PK-LBM then they went out of sequence for the first time. I see now that since it was a Batik aircraft there's no way it ever could have been 9M-LNG.
res77W
Wed Dec 08, 2021 10:26 pm
Why all of these crazy registration suffixes for the used 739s? I searched the FAA registry and a good portion of DZ and DU registrations were not assigned. Is this to distinguish the used jets from the factory-built -932s?
-Rowen
AirDO
Thu Dec 09, 2021 12:17 am
It's per Planespotters source.
https://www.planespotters.net/airframe/ ... air/ey125k
AirDO
Wed Dec 15, 2021 12:25 pm
PK-LQS has made air test over Batam on Sunday. Sounds like this one is going to DL next.
https://www.flightradar24.com/data/airc ... s#2a2916f8
Wed Dec 15, 2021 12:41 pm
DL is the expert in getting used aircraft fit and running - same with the MD90/B717 used sub-fleet. Given LionAir poor reputation in maintenance and operations, I still ask myself, in what conditions the planes actually are... Anyone with more insight?!
dalmit
Wed Dec 15, 2021 2:41 pm
Flightaware is listing VP-CFT going through Guam. https://flightaware.com/live/flight/VPCFT
If that's a 737-900ER it could line up between VP-CFD 38690 and VP-CFU 38732
So, 38729 or 38731 (N945xx or N947xx)
Or VP-CFT could be something else entirely.
timf
Wed Dec 15, 2021 4:25 pm
PK-LBO (38731/4463) is the logical aircraft.
MIflyer12
Wed Dec 15, 2021 4:52 pm
Unless we see a significant induction delay, or DL takes a write-down, I don't think anything other than anecdotal info will come out. Look at the variety of carriers from whom they got MD-90s, either to be inducted to the fleet or for parts.
AirDO
Sat Dec 18, 2021 3:40 am
or 9M-LNG. VP-CFH/N942DC is confirmed as ex PK-LBM per FAA site.
AirDO
Sat Dec 18, 2021 3:41 am
Update: PK-LQS is not going to DL. Maybe PK-LQT instead? Or PK-LJF which is leased from Aircastle, likely now leased from Castlelake. Or any other replacement?
AirDO
Sun Dec 19, 2021 12:08 am
PK-LQS -> VP-CEF
PK-LSG -> VP-CEI
PK-LBM -> VP-CFB
PK-LBO -> VP-CFT
PK-LQS has returned to service already. The replacement to PK-LQS is PK-LQT to me. Your suggestion?
AirDO
Mon Dec 20, 2021 2:33 pm
The next B739: VP-CEI (ex PK-LSG as stated by timf or 9M-LNG) has been ferried today from CGK-SZB-GUM-HNL-SBD. So they have 157/159 in fleet. 2 more to go left. (PK-LSG if not 9M-LNG) and PK-LJF? will be next one to go for DL.
https://flightaware.com/live/flight/VPCEI
timf
Mon Dec 20, 2021 2:42 pm
PK-LQS -> VP-CEF
PK-LSG -> VP-CEI
PK-LBM -> VP-CFB
PK-LBO -> VP-CFT
I'm struggling to find another aircraft leased from Castlelake. All the other candidates (not to mention PK-LQS itself) indicate a lessor other than Castlelake. There is one, PK-LJZ, which does not list a lessor but also does not fit the sequence. PK-LQT is showing a different lessor as well.
AirDO
Mon Dec 20, 2021 2:46 pm
timf wrote:
PK-LQS -> VP-CEF
PK-LSG -> VP-CEI
PK-LBM -> VP-CFB
PK-LBO -> VP-CFT
If not LJZ, the nearest aircraft I found is PK-LJF which like PK-LHW was leased from Aircastle and can be solded to Castlelake afterward.
timf
Mon Dec 20, 2021 2:52 pm
Good catch. PK-LJF's leasing history is very similar to PK-LWH. I'll go with that for now.
AirDO
Mon Dec 20, 2021 3:30 pm
Just 2 more B739. The next one is set to be 9M-LNG and PK-LJF (likely) at the moment I add. VP-CEI is likely PK-LSG as you said before now position to US via GUM/HNL.
Speedy752
Mon Dec 20, 2021 11:02 pm
I notice none of these aircraft appear to have the split wingtips but I believe all the new DL ones do, are these all older than Deltas legacy planes or was that an extra cost option? I assume it’s not worth the expense to retrofit this?
papatango
Mon Dec 20, 2021 11:09 pm
Is Delta finished with the ore owned aircraft purchases or could we see more A350s etc in the future?
Speedy752
Mon Dec 20, 2021 11:20 pm
I’d imagine they are always looking for opportunistic aircraft buy opportunities. Their fleet still has a lot of older aircraft and with COVID they retired a good chunk. I’d bet they don’t have plans but are probably in constant discussions if the right opportunity arises. Like UA they didn’t go all new with their fleet yet, but unlike UA their outstanding orders aren’t in the multiple hundreds but are in a similarly stable position given domestic demand unlike many airlines globally that are still suffering.
AirDO
Tue Dec 21, 2021 3:41 am
Also VP-CFQ is the last B739 of OD and was formerly 9M-LNG now flying from SZB-GUM-HNL-SBD.
https://flightaware.com/live/flight/VPCFQ
AirDO
Tue Dec 21, 2021 10:45 am
Correct. Now stored in SBD. As of Dec 21/2021, 158/159 in DL fleet. One more to go.
