xwb777
Gulf Air A321 engine fire upon landing at Kuwait
Mon Jul 05, 2021 3:47 pm
Gulf Air flight GF215 from Bahrain to Kuwait, operates by an A321. One of the engines was on fire upon landing. All 7 crew members and 62 passengers were evacuated safely.
ikolkyo
Re: Gulf Air A320 engine fire upon landing at Kuwait
Mon Jul 05, 2021 3:59 pm
Definitely an A321, looks like it’s V2500 powered as well.
xwb777
Mon Jul 05, 2021 4:10 pm
Yes it is! My mistake :)
xwb777
Re: Gulf Air A321 engine fire upon landing at Kuwait
Mon Jul 05, 2021 4:12 pm
PANAMsterdam
Mon Jul 05, 2021 4:47 pm
“On fire upon landing”
Does that mean the built in fire suppression system didn’t work? Or did the engine catch fire after touchdown?
Every country has an airline. The world has Pan Am.
Mon Jul 05, 2021 5:07 pm
Looks like it was the left engine, the slides forward and aft of the engine are not deployed.
Engine fires are detected between the area where there is supposed to be combustion and the outer nacelle, where the systems run. It is possible to have a failure inside the engine which should stop once the fire bush button is pushed.
If you have a fire indication close to landing there are different schools of thought on what do, some advocate delay the landing and sort the problem out, others advocate continue the landing and sort it out on the ground.
“Don't be a show-off. Never be too proud to turn back. There are old pilots and bold pilots, but no old, bold pilots.” E. Hamilton Lee, 1949
AustrianSimon
Mon Jul 05, 2021 8:13 pm
Landing was entirely normal, aircraft vacated the runway without any distress, received taxi clearance, taxied and about 2 minutes after vacating the runway stopped and evacuated. As the crew reported their problem speaking Arabic, I can't tell what the nature of the problem was indeed, however, given how the slides were deployed a left engine fire warning appears possible.
basspaul
Mon Jul 05, 2021 8:24 pm
It seems a very tragic lesson learned was forgotten, don't assume you don't have a fire if you have the warning for a fire. Land and stop, don't go for a joyride around the airport. Messed up ops at an airport is always the better choice than risking lives.
https://en.wikipedia.org/wiki/Saudia_Flight_163
I remember seeing that burnt airframe as a kid.
AustrianSimon
Mon Jul 05, 2021 8:48 pm
Just to avoid any misunderstanding: there was no problem until 2 minutes after vacating the runway, then the indication started, they stopped, informed ATC and emergency services and evacuated.
xwb777
Mon Jul 05, 2021 9:45 pm
I think the emergency has started on approach to the airport. Emirates B777 has been instructed to enter a holding pattern to give way to the GF A321.
Tue Jul 06, 2021 3:07 am
Maybe, they will also routinely delay other airlines airlines landing and departing. Gulf Air always gets priority there in my experience.
I remember calling for a push there and I had to wait for the Gulf Air next to me to push first, and they still had cargo doors open. Often got holds on downwind to make room for Gulf Air.
What you also don’t see in that FR24 is the US military run a lot of helicopters and ospreys to the northern part of the runway.
n797mx
Tue Jul 06, 2021 3:44 am
Is it me, or does it look like the R2 door would hurt to evacuate through with that slope?
Clear skies and strong tail winds.
Tue Jul 06, 2021 4:21 am
There is always a risk with any evacuation that limbs will be broken, a decision to evacuate is not one that is taken lightly.
rida79
Tue Jul 06, 2021 6:18 am
Actually the radar system at KWI was out yesterday for almost an hour, and airplanes were instructed to either divert or go around until the issue was fixed. Talk about a coincidence!!
Aesma
Wed Jul 07, 2021 1:15 am
Was the evacuation really necessary in the end ? Not saying it was a bad call but there doesn't seem to be a major fire either.
9252fly
Wed Jul 07, 2021 1:28 am
That's something easy to say in hindsight after the fact.
Avgeek21
Wed Jul 07, 2021 4:25 am
Not true regarding Gulf Air. I flew for them for a number of years. Great outfit but we never got priority other than at times at Bahrain airport itself. But that’s understandable as it was our home base.
Wed Jul 07, 2021 4:29 am
That is my personal experience, I have had to hold and delayed from pushing for that very reason.
All I can think of is when you were there they were out of flavour, it’s not like states over there to have petty grudges against each other and then kiss and make up.
