ikolkyo
Air Baltic A223 - Both engines automatically shutdown on touchdown
Thu Jul 15, 2021 2:14 pm
An Air Baltic Bombardier C-Series CS-300, registration YL-AAQ performing flight BT-139 from Riga (Latvia) to Copenhagen (Denmark), landed on Copenhagen's runway 04L when both engines automatically shut down automatically. The aircraft rolled out, the crew managed to steer the aircraft clear of the runway. The aircraft was subsequently towed to the apron.
The aircraft is still on the ground in Copenhagen about 4 days later.
http://avherald.com/h?article=4ea5172d&opt=0
Reminds me of this ANA 788 incident a couple years ago.
http://avherald.com/h?article=4c2fe53a&opt=0
VV
Re: Air Baltic A223 - Both engines automatically shutdown on touchdown
Thu Jul 15, 2021 2:26 pm
That's the automatic shutdown feature.
TerminalD
Thu Jul 15, 2021 2:31 pm
If Breeze flies these transatlantic that auto-shutdown feature could really make the trip exciting.
Blankbarcode
Thu Jul 15, 2021 2:50 pm
That's fairly alarming, not gonna lie. I can't really imagine this being an actual automatic feature, and I'd probably say it's more likely to be a failure of sorts that was brought on by the landing knocking a component loose? This is just pure guesswork of course, I'd love to hear any insights.
SEU
Thu Jul 15, 2021 3:40 pm
How are the engine issues on the A220s now? They were quite bad at the start.
Revelation
Thu Jul 15, 2021 3:45 pm
Indeed. Someone probably hasn't read the manual.
IMO it's probably better to refer to this as an "uncommanded" rather than an "automatic" shutdown.
lightsaber
Thu Jul 15, 2021 3:47 pm
Prior shutdown due to water in electronics bay:
https://simpleflying.com/airbus-a220-ra ... -shutdown/
I need far more information to make a decision on severity. In particular, so far only on the ground.
I do not believe, at this point, this is engine related. Instead, it seems engines are responding to a valid command.
Revelation
Thu Jul 15, 2021 3:58 pm
The article suggests water ingress causes a short circuit in the avionics that leads to an engine shutdown.
Not sure if it's an orderly shutdown or not.
Seems there's an AD out on the water ingress already, with 12 months to comply.
It might be time to re-evaluate that AD.
peterinlisbon
Thu Jul 15, 2021 4:00 pm
That sounds like a great feature. They should add it to more aircraft. It's just what you need when over central London on approach to Heathrow, for example.
KGarc21
Thu Jul 15, 2021 4:02 pm
Yeah, it sounds alright!
LDRA
Thu Jul 15, 2021 4:04 pm
That's an optional feature. Air Baltic, being cheap, did not order that software license
Nomadd
Thu Jul 15, 2021 4:05 pm
Could it be a result of going to a different law once it's on the ground? Some condition that would shut engines down on deck but not in the air?
lightsaber
Thu Jul 15, 2021 4:24 pm
It could be. I do not know enough of the A220, I suspect weight on wheels and an estimated velocity below some threshold. Annoying, needs to be fixed, but not as alarming as some here suggest after initial review.
Lightsaber
avier
Thu Jul 15, 2021 4:32 pm
I'm guessing it's the new fuel saving technique. The last I heard, they were shutting down one engine after vacating the runway. Now, shutdown both engines right when the wheel comes in contact with the runway surface.
DFW17L
Thu Jul 15, 2021 4:40 pm
Reminds me of my childhood, living on a hill. Our home was uphill from the local doctor — a Radiologist. When he was coming home, and was at the top of the hill, he’d turn off the engine and coast down the street. In summertime when we played outside on the street, he ran silent and frequently honked his horn to warn us of his stealthy approach. He would have liked that automatic shutdown feature.
VV
Thu Jul 15, 2021 7:21 pm
Next time they will add the message, "Are you sure you want to shutdown both engines now?"
sgbroimp
Thu Jul 15, 2021 7:29 pm
This fuel savings business is really getting extreme, no? First taxi on one engine, now taxi on none!
tjwgrr
Thu Jul 15, 2021 7:43 pm
So Airbus is now installing the same irritating idle stop feature found on most new automobiles?
freakyrat
Thu Jul 15, 2021 7:45 pm
It is an on-ground command only
freakyrat
Thu Jul 15, 2021 7:55 pm
Lightsaber
I read on the comments to the incident report that it has to do with the Thrust Control Logic with relation to a percentage of N1 in the Fadec with the thrust levers in the Idle or reverse position and only on the ground. It was a valid command from the computers. I'm sure someone who is familiar with the GTF engine will explain it here. It also applies to the LEAP engines.
A320B737NGCapt
Thu Jul 15, 2021 8:00 pm
This has happened to JQ and JL on the 787. Both engines rolled back just after touch down.
IFlyVeryLittle
Thu Jul 15, 2021 8:13 pm
"As occurred in this incident, that could lead to short-circuiting, the loss of air data sources, a reduction in functional capabilities, and an increase in crew workload." Captain to FO: Your turn to push.
Ziyulu
Thu Jul 15, 2021 8:33 pm
So this plane cannot land from the bay at SFO since it is overwater?
cschleic
Thu Jul 15, 2021 8:34 pm
What if the crew decided, for whatever reason, after touching down, that they needed a go around?
vhtje
Thu Jul 15, 2021 8:41 pm
That is a man who will willingly spend a pound to save a penny. Was he from Yorkshire?
On topic: if this is indeed a feature of this aircraft, why would this happen on this particular aircraft and flight, and it be unexpected? Configuration error?
metaldirtnskin
Thu Jul 15, 2021 9:05 pm
Or it's like Windows, which just decides it's time to restart the system when "not in use" (i.e. wheels on ground).
All joking aside, the more complex the software that governs these systems, the easier it is for the manufacturer to do things without oversight from regulators/operators/etc and then hide behind the claim that the system is working as designed. It's much too soon to know if this is one of those issues, but as a general statement I think that's true.
LDRA
Thu Jul 15, 2021 9:10 pm
Software on aircraft are highly regulated. They're major part of certification activities. You have to show full traceability between function intent(requirements), code and validations. Definitely not hidden
ratp101
Thu Jul 15, 2021 9:43 pm
Hence the LionAir/Ethiopian crashes?
NWAROOSTER
Thu Jul 15, 2021 9:50 pm
Chip malfunction. Aircraft now rely on too much electronics which the flight crew cannot control or it may be difficult to override. :old:
LDRA
Thu Jul 15, 2021 10:05 pm
What??? Both pilots ate from the same bag of contaminated chips and fell ill?
Oh you meant computers. All the important computations are done by redundant hardwares. The critical systems are designed with failure in mind
Jshank83
Thu Jul 15, 2021 10:14 pm
I guess it is better than a shutdown on take off.
Revelation
Thu Jul 15, 2021 10:40 pm
Definitely not hidden till DoJ or Congress comes around, then hidden.
mxaxai
Thu Jul 15, 2021 11:15 pm
The MCAS software worked exactly as intended. It was just based on a flawed design due to flawed assumptions.
This case here could be similar if the designers simply assumed that there would never be water in the electronics bay (or that any components damaged on the ground would be detected and repaired prior to the next flight). Nothing wrong with the code per se.
seat55a
Fri Jul 16, 2021 12:50 am
What year? Had he read/seen The World According to Garp or was it just foreshadowing?
(Obligatory aviation/Garp related content: "We'll take the house. Honey, the chances of another plane hitting this house are astronomical. It's been pre-disastered. We're going to be safe here."
Fri Jul 16, 2021 1:10 am
This is not uncommon on FADEC engines or APU on the ground, if they sense a failure the more conservative action is to auto shutdown or to go back to idle. Despite what was written above the engines did not shutdown on the immediate landing, it was during the landing roll.
Just to be clear, these computers (FADEC) are located on the engine, water will not get in them.
a36001
Fri Jul 16, 2021 1:22 am
Good question! anyone care to share their thoughts on this?? I guess start looking for the PANIC button!
freakyrat
Fri Jul 16, 2021 1:23 am
Zeke Thank You for explaining things.
DL757NYC
Fri Jul 16, 2021 2:01 am
Maybe it’s a new fuel saving feature. Then the tugs pull the plane into the gate.
UA748i
Fri Jul 16, 2021 2:21 am
TBH, thats actually not a bad idea.
I suspect that could work for smaller airports.
Fri Jul 16, 2021 2:31 am
I suspect if it’s a rejected landing, I.e. take off again before selecting reverse they would be able to do so. If it’s after selecting reverse, then no, however all manuals say that a takeoff should never be attempted after selecting reverse as there can e asymmetric thrust reverser deployment and retraction resulting in loss of control.
amcnd
Fri Jul 16, 2021 2:59 am
Pretty typical not to go-around after main wheel touch down, as the ground lift dump system would have deployed..
FlapOperator
Fri Jul 16, 2021 4:49 am
If this is a pilot un-commanded software issue, it’s significant.
PowerJet
Fri Jul 16, 2021 6:08 am
Advancement of the throttles cancels any lift dumping. Go-arounds after touchdown are not unheard of. Glad they didn't need to go around. Could have ended in disaster.
whiplash
Fri Jul 16, 2021 7:04 am
Incorrect. You are allowed to go around after touchdown if you have not deployed the thrust reversers.
oldannyboy
Fri Jul 16, 2021 9:21 am
I had a car, a lovely one at that (and yes, a Mercedes, not a Yugo!), with that same clever fuel-saving 'auto cut-off' system....it liked to shut itself off when going downhill, if the a/c was on. I have some really interesting memories of losing engine, power assisted steering, and servo-braking, all in one go while cruising at 150km/h on a motorway....
BrianDromey
Fri Jul 16, 2021 10:59 am
zeke wrote:
These sort of things happen...
Lauda Air 004 being one of the most deadly. I don't think it has ever been certain, but it is presumed that the left thrust reverser deployed in flight.
https://en.wikipedia.org/wiki/Lauda_Air_Flight_004
VV
Fri Jul 16, 2021 11:48 am
I do not think it is considered as severe enough to trigger a grounding by EASA.
armagnac2010
Fri Jul 16, 2021 12:14 pm
Transport Canada is in charge of the Airbus A220, not EASA.
Polot
Fri Jul 16, 2021 12:20 pm
That doesn’t prevent EASA from grounding the plane if they want (they are not going to).
Transport Canada just has the lead over certification. EASA is still in charge of the A220’s airworthiness in Europe.
