turjo101
French Bee: PPT-YYZ?
Sat Sep 18, 2021 3:55 am
https://www.flightradar24.com/FBU719/292fad6e
Any idea why the French Bee is flying to YYZ?
ryan78
Re: French Bee: PPT-YYZ?
Sat Sep 18, 2021 4:08 am
Interesting routing for sure! Searched the flight number and it looks to be a scheduled service, ORY-YYZ-PPT-YYZ-ORY. It is bookable on French Bee's website, a whopping 21hrs15min on board with a fuel stop in YYZ.
Unfortunately YYZ-PPT-YYZ is not bookable.
adamblang
Sat Sep 18, 2021 4:58 am
First result in Google for "french bee toronto":
French Bee moves Canadian stopover to Toronto - ch-aviation
French Bee (BF, Paris Orly) has announced that all of its flights between Paris Orly and Papeete will operate with a refuelling stopover at Toronto Pearson airport rather than the usual Vancouver Int'l through October 4, 2021.
The carrier did not provide any rationale for the change. Flightradar24 ADS-B data indicates the first flight to use the new routing did so on July 30, 2021.
raylee67
Sat Sep 18, 2021 5:05 am
Are passengers allowed to get off the plane during the tech stop at YYZ? Which terminal does the plane park at? Does it actually park at the terminal or at a remote stand?
hoons90
Sat Sep 18, 2021 6:46 am
They park at T3 C gates. All pax remain on board. Unlike at LAX (AF, TN) or SFO (BF), pax don't have to clear immigration at YYZ enroute to PPT v.v.
Anyone can just walk out of the departure lounge at YYZ out onto the street, so deplaning wouldn't be permissible without requiring all pax to clear immigration.
HBJZA
Sat Sep 18, 2021 8:40 am
Does anyone know how they change crew en-route and how long each crew is staying at each station? Does the crew stopping in YYZ get the same plane they left that turned in PPT? This kind of flight is not really crew efficient for the airline.
COA75
Sat Sep 18, 2021 9:24 am
I have no idea what the situation is like in YYZ, but apparently I'm YVR there is (was?) a part at the end of the internal terminal partitioned off so pax get off there. There are a few YouTube videos online showing this, this one was the first I found: https://youtu.be/q9ID0mouy2g (check out from app. 1:30:00)
mooseofspruce
Sat Sep 18, 2021 10:10 am
The YVR technical stops moved to YYC initially on a temporary basis supposedly because of fueling issues at YVR, whether it was a fuel shortage or something else. French bee's COVID-19 page by late July specified all PPT flights would stop at YYZ each way, but as noted there was no specific reason given, so we can only speculate.
Polot
Sat Sep 18, 2021 10:20 am
Almost 20 hours on a French Bee A350 without any ability to get off the plane must be pure torture, although I’m sure they are not filled to capacity at the moment.
9252fly
Sat Sep 18, 2021 6:54 pm
The tech stop in YVR was better as it is exactly mid-point on the routing. To be more precise the difference is 42nm.
http://www.gcmap.com/mapui?P=CDG-YVR-PP ... =wls&DU=nm
CanadianNorth
Sat Sep 18, 2021 7:47 pm
YVR makes more sense on a map, but I've heard they've been having issues with their supply of JET-A lately.
The rumor I've heard is fuel there is available, but they're having issues with transporting it to the airport, so the supply on hand is not as much as usual and thus it's being priced accordingly, so operators have been trying to uplift some extra fuel at other stops and only buy what they really need at the Vancouver stops.
mercure1
Sat Sep 18, 2021 8:07 pm
Air France and Air Tahiti Nui do the same via Canada as they cannot operate via historic LAX stopover during COVID times.
Thenoflyzone
Sat Sep 18, 2021 11:38 pm
This is correct.
They should move the stopover point to YUL, as it can accomodate the transiting passengers in a partitioned off section as well, same as YVR. It already does so with RJ on the DTW tag, and did with CA when they flew from YUL to HAV. Plus no JET-A issues.
YVR seems to be having a lot of issues lately, not just fuel. Standby power for runway ops has been unserviceable for several months now as well, rendering their runways as "non precision only". Meaning higher minimums on final approach, and no CAT II/III approaches available.
https://extranetapps.navcanada.ca/ois/ois.aspx
Scroll down to "outages and runway closures" section.
Last edited by Thenoflyzone on Sat Sep 18, 2021 11:55 pm, edited 2 times in total.
TWA772LR
Sat Sep 18, 2021 11:46 pm
I saw that exact flight fly over me in Moab,UT a few days ago.
CrewBunk
Sun Sep 19, 2021 1:06 am
Or just move to Terminal One in YYZ.
In transit International to International connections are common. A large transit lounge with dozens of restaurants, stores, bars, etc make the transit very comfortable.
Thenoflyzone
Sun Sep 19, 2021 2:06 am
The fact they’re not in T1 already probably means AC or the GTAA isn’t letting them. Lack of avbl gates at that time maybe?
MIflyer12
Sun Sep 19, 2021 1:32 pm
That may be best for fuel efficiency but it's not necessarily otherwise ideal. Sleep timing, for example. An A350 ought to have LOTS of flexibility in where they position a fuel stop.
According to Great Circle Mapper, Winnipeg is only a 1 mile diversion from a great circle route. How many occasions do the French get to visit Winnipeg? :)
CrewBunk
Sun Sep 19, 2021 1:55 pm
Something evil within me would love to see a French Bee crew (or an Air Tahiti Nui crew going the other way) enjoying a long layover in Winnipeg in February when it’s -40°. ;)
raylee67
Sun Sep 19, 2021 3:51 pm
Similar situation was unfortunately quite routine back in the early 2000s. Back then, non-stop flight between East Coast and East Asia beyond Korea and Japan was impossible. Cathay Pacific flew its HKG-YYZ route with a tech stop at ANC. After 9/11, passengers were no longer allowed to deplane at ANC for a few years. I flew that route a lot, on an A340-300. It took over 19 hrs westbound. The plane leaves YYZ at around 1am local time, arrives at ANC about 5 hrs later. You are tired and mostly asleep, and you are woken up for the landing to adjust your seats, etc. The A/C is then turned off for the refueling but the cabin light would be all turned on. The air is stuffed with the smell of gas with minimal circulation. You are sleepy but you can't sleep because of the light and you know the plane will leave in about 90 min. The worst part is you know there is still 12 hrs ahead!
hoons90
Sun Sep 19, 2021 4:37 pm
It was worse when CX829 was routed via YVR for a short time back in 2004, adding an extra 600km or so to the journey compared to the ANC stop. Despite YVR being in the same country as YYZ, we did not deplane. And those late 90's era CX Y seats with the 1st gen PTVs were rock hard.
Polot
Sun Sep 19, 2021 4:41 pm
My statement was less being stuck on any aircraft that long but on French Bee’s specifically. They are one of the operators that configures their A350s with 10Y 16” seats instead of the standard 18” 9Y product.
Aesma
Mon Sep 20, 2021 6:38 pm
How about this one ?
https://www.flightradar24.com/data/flights/tx5717
PPT-PTP-ORY
Flight chartered to evacuate 8 ventilated COVID patients, with 37 medical staff and 2 tons of medical hardware over 16000Km, a record. The PTP stop was not needed for fuelling reasons but to replace 18 oxygen cylinders with a 60 000 litres capacity. The cost is eye watering.
MIflyer12
Mon Sep 20, 2021 6:48 pm
Oh, I remember YYZ-YVR-HKG. Not fondly. At least I was doing it in J. Breaking up sleep at 3 or 4 in the morning is just brutal.
