ikolkyo
UA B739 tail tip incident
Sat Sep 18, 2021 5:01 pm
A B739 taking USC football up to Washington State had a tail tip incident with people still onboard. Reg: N78448
https://twitter.com/DSJR1/status/143903 ... airport%2F
flightwriter
Re: UA B739 tail tip incident
Sat Sep 18, 2021 5:04 pm
Cause and effect, all in one photo.
airlinepeanuts
Sat Sep 18, 2021 5:13 pm
That’s why they have a tail stand for the 739. Very prone to tipping.
JohanTally
Sat Sep 18, 2021 5:20 pm
Is the Max 9 less likely with the engines further forward or do they still employ the tail stand?
alasizon
My guess is they didn't ship a tail stand to PUW in advance and the ramp was a little to quick at offloading
Sig56
Sat Sep 18, 2021 5:23 pm
Should of been using a tailstand and/or properly download/deplane the aircraft.
MIflyer12
Sat Sep 18, 2021 5:27 pm
Operator error.
ikolkyo
Sat Sep 18, 2021 5:30 pm
You can see they clearly emptied the front hold and left the back completely full while deplaning. That's a no go.
airlinepeanuts
Sat Sep 18, 2021 5:34 pm
Could’ve dual deplaned too.
FlyingElvii
Sat Sep 18, 2021 5:36 pm
Bags from the front unloaded before the pax. OOPS….
SB for tail stand installation inbound from the FAA? It will only end up costing a couple of hundred thousand dollars each, by the time the FAA is done with it.
Ossyoos
Sat Sep 18, 2021 5:40 pm
Just an observation. I wonder why they used KLWS instead of KPUW which is the same city the game is being played in. I think the KPUW runway is longer too.
CALTECH
#448 -900ER, Lewiston Idaho, No one injured. Air Stairs at L1 door, Fwd Cargo Door Wide Open, No tail stand, Charter, do not regularly fly into LWS. Unloaded from the front result. SEAMX supporting on scene.
Bad offloading.
Heinkel
Sat Sep 18, 2021 5:42 pm
Question: Is there no idication / warning to the crew, when the load on the front landing gear becomes too light? Before it tips.
Are there any load sensing devices in the front landing gear?
CALTECH
Sat Sep 18, 2021 5:51 pm
No.
No.
Computer Load Program sends out a notice that a certain flight is at risk of being tail heavy and tail stand should be used.
Two compressed sensors are on each landing gear.
Cubsrule
Sat Sep 18, 2021 5:54 pm
At this point, don’t all US 739 operators use tail stands at all airports that see the 739 on a regular basis? Heck, some use them on 738s.
Sig56
Sat Sep 18, 2021 5:57 pm
Who ground handles in PUW for UA charters like this? Either QX or an FBO.
BowlingShoeDC9
Sat Sep 18, 2021 5:59 pm
What sort of checks does a plane have to go through after that happens? I’d imagine it has to be more than just a visual inspection…
CALTECH
Sat Sep 18, 2021 6:03 pm
Didn't happen in PUW. Skywest OO, SKW, as UAX flies into LWS from DEN for United, but it is not a mainline station.
CALTECH
Sat Sep 18, 2021 6:04 pm
If the damage is minor, temp repair will be performed and it will probably be ferried back to a MX Station. There is a ongoing inspection being performed. Inspect tail area, emphasis on the pressure dome.
CALTECH
Sat Sep 18, 2021 6:06 pm
Some ramp crews use them all the time, others do not. Usually there is a warning put out that a flight is at risk of tail tipping, but it's computer generated.
Adipocere
Sat Sep 18, 2021 6:09 pm
How did the pax get off if this happened with people inside? I don’t see a slide deployed.
CALTECH
Sat Sep 18, 2021 6:13 pm
Heard the passengers slowly walked forward until the nose gently came back down. No injuries reported, on the ramp or in the aircraft.
codc10
Sat Sep 18, 2021 6:42 pm
That usually does the trick for a tail tip.
I assume a tail stand will be loaded as standard equipment on 739 charters to offline stations going forward…
jayunited
Sat Sep 18, 2021 7:02 pm
I've been able to get some information on this incident, the aircraft involved was tail number N78448, it is still grounded at LWS and from the pictures seen internally the external damage is pretty severe.
As others have already pointed out this was a charter flight, there was nothing loaded in the rear compartment of the aircraft, so for those wondering why the rear compartment door is not open there was no need to open the rear as all the bags and equipment fit in the forward compartment. The issue started when some of the team buses was late arriving to the airport. According to the report this was a nearly full flight passengers seated forward of the wing disembarked as their were some buses there to take them but the passengers from the emergency exit row 21 and back remained onboard while waiting for more buses to arrive.
The problem is this there were 95 football players seated aft of the emergency exit row and no one stop the ramp from downloading the forward compartment which had enough weight to counter the weight of the players. However once ramp downloaded enough cargo out of the forward compartment their was nothing upfront to stop the tail tip from taking place at that moment.
There are two things that could have prevented this tail tip the first indicated in the report is why wasn't a tail stand loaded in the pit when the flight left LAX? The second issue raised is this why didn't the charter representative who works for United (actual United ramp employee part of United's Charter Operation) stop the ramp for offloading the forward compartment the moment it became clear there were buses running late and 95 players would have to remain onboard until the buses showed up?
There is a huge multi layer investigation taking place at this time because the as far as United is concerned this never should have happened because we have procedures in place to prevent this type of event from happening. Looking at emails all I can say is there are quite a few people running for cover on this one trying to blame others but in my opinion there is no place these people to hide.
ikolkyo
Sat Sep 18, 2021 7:33 pm
Nothing in the rear hold on a Football charter on a narrow body? I'm surprised to hear that with all the equipment needed.
SFOtoORD
Sat Sep 18, 2021 7:37 pm
Really embarrassing for United. The worst kind of advertisement for the company.
sagechan
Sat Sep 18, 2021 7:41 pm
It's usually just player gear, team gear is usually trucked in beforehand.
sprxUSA
Sat Sep 18, 2021 7:43 pm
Maybe they should deplane only from the rear from now on lol.
atrude777
Sat Sep 18, 2021 8:24 pm
It's my understanding that UA does not start service to LWS until October 5th...
SkyWest COULD have ground handled it anyway but they are there on the Delta Side, not UA.
Definitely a big Oops all around! Unfortunate this happened even with procedures in place.
Alex
mcg
Sat Sep 18, 2021 8:29 pm
I've watched a number of football charters off load at BJC and often there is nothing in any of the luggage holds. The football equipment is trucked to the game site.
CALTECH
Sat Sep 18, 2021 8:32 pm
The damage is not really all that bad even though it looks that way. The way they shined the lighting on it makes it worse than it is. Rivets and some skin change or doublers and she should be good to go. Hearing it will be MX ferried pressurized to IAH for repair.
DrPaul
Sat Sep 18, 2021 8:33 pm
How much and what sort of damage could an accident such as this do to an aeroplane?
pdxswa
Sat Sep 18, 2021 8:39 pm
Tail stands on the 738, and 739 are only necessary to tell if the plane is balanced while unloading. If indeed the bags were all up front as was mentioned. And there was a delay in getting the passengers off the plane. The bags should not have been taken off. The passengers should have gotten off then the bags should have been downloaded. If the ramp had no clue as to what was going on. The ops agent or whomever was in charge of the communication with the ramp and the crew on the plane. Should have informed the ramp to not download the plane until the passengers had gotten off. A clear breakdown in communication. This is unfortunate and could have been easily preventable.
alfa164
Sat Sep 18, 2021 9:07 pm
Isn't there a third simple solution? Ask the players in the back to move up front as the people ahead of them get off of the plane. A little foresight might have prevented this damage.
jacrowley48
Sat Sep 18, 2021 9:14 pm
The event was obviously traumatic judging by their play on the field. :duck: And I am a USC fan! :fight:
Wingtips56
Sat Sep 18, 2021 10:11 pm
USC seems to have shaken it off. 28 unanswered points currently. Looks like more on the verge.
zuckie13
Sat Sep 18, 2021 10:12 pm
https://www.espn.com/college-football/s ... taff-board
Apparently the coaches and staff were in the back The big guys were up front.
RR757
Sat Sep 18, 2021 10:33 pm
Surprised the 737-900 doesn’t have a retractable ‘on the ground’ anti-tailstrike appliance like the 727, 767, Concorde etc.
9252fly
Sat Sep 18, 2021 10:35 pm
Well, the picture will certainly help the uninitiated appreciate the aviatoin term 'Weight & Balance' if they ever hear it mentioned on future flights.
DKNEF
Sat Sep 18, 2021 10:41 pm
Mabe all the buff football players were seated in the rear..
T5towbar
Sat Sep 18, 2021 10:44 pm
A tail stand is standard practice on any 900 we handle. There are procedures in the RSM to handle a 900 without a tail stand though.
If we don't have a tail stand, we cannot unload the forward pit until all passengers have deplaned. This is much easier because there is no jetbridge involved, (you can see the deplaning process) and all you had to do was wait till the buses arrived. If nothing is in the back, you must not offload the forward pit. Moving the weight up forward (players) would not have worked. You have to wait until mostly everybody is off the plane, and a 900 is not the fastest airplane to deplane from. This is against policy. Before the use of the tailstands, I've seen the nose jack up like a rocketship as we tried to download front and back at the same time. Usually most places we fly have a tail stand on hand. This is a charter, so procedures should have been in place, and the handlers at that particular airport should have be notified. Also the handler or UA representative should have had access to UNIMATIC, and that would have gave a tail tip warning on the DASG (which is the offload) to have a tail stand on hand, even if they had to borrow one. Also the flight didn't needed to be scanned (bags), so you wouldn't have to have one. The scanner also have a tail tip warning also. This is one of the tools that we use to set up for an arrival.
Players football equipment (major college or professional) usually get trucked in ahead of the players. On Professional charters, there is some equipment on the flight, but not as much as you think.
Our Max 9's do not require the use of a tail stand.
Someone screwed up here..........
Aesma
Sat Sep 18, 2021 10:49 pm
There is a small tail skid.
jayunited
Sat Sep 18, 2021 11:07 pm
Oh okay because from the pictures and the damage it looks like the plane hit the pavement with some force. I was telling one of my coworkers this isn't the first tail tip for United but this is the worst damage I've ever seen from a tail tip on a 739ER.
MIflyer12
Sat Sep 18, 2021 11:10 pm
Deplane by highest row number first - everyone in rows 1-20 stay seated?
Practices that don't rely on passenger behavior would be better, of course.
Weatherwatcher1
Sat Sep 18, 2021 11:30 pm
Thanks for the explanation. 90 large men behind the window exits and no one in the front explains it. Looks like bad luck combined with a ground crew that isn’t familiar with the airplane.
At least it isn’t as bad as when United tipped a 747 on its tail a while back
Neither event compares to Frontier who perfectly balanced an A320 with the nose gear up off the ground but without having the tail hit the ground
Source
https://www.aviation24.be/airlines/fron ... -stepping/
Sat Sep 18, 2021 11:44 pm
wjcandee wrote:
Patroni1 wrote:
No tail stand on the MAX.At least on the -8.
I'm not sure if you were just making an observation, but this is a -900ER, not a MAX.
But curious to know, if this is a common problem only on the -900?
What about the FR B737MAX200 and MAX9/10, do these planes need a tail stand as well?!
wjcandee
Sat Sep 18, 2021 11:46 pm
I believe that no tail stand is required for the MAX9. Dunno about the 10. Sometimes also an issue on the -800.
Natflyer
Sun Sep 19, 2021 12:06 am
I don’t fly the MAX, but my airline has warned that tail tipping is a possibility on both MAX 8 and 9.
CALTECH
Sun Sep 19, 2021 12:36 am
Alex
And this happened in Lewiston which Horizon Air , QX, no longer serves (?)
Went by
"Find Your Flights to Lewiston LWS
Cheap flights to Lewiston (LWS)
Airlines that fly to Lewiston (LWS)
You have several options for which airline you choose to travel with to Lewiston. There are 10 airlines flying into LWS: Alaska Airlines, United, Delta......."
"United Cheap Flights to Lewiston from $310 | United Airlines
Search domain united.comhttps://www.united.com/en-us/flights-to-lewiston
Book cheap flights to Lewiston (LWS) with United Airlines. Enjoy all the in-flight perks on your Lewiston flight, including speed Wi-Fi. "
Didn't go any further with UAX...
CALTECH
Sun Sep 19, 2021 1:04 am
Haven't seen one used on the MAX8 MAX9s coming to MCO.
zuckie13 wrote:
https://www.espn.com/college-football/story/_/id/32230018/usc-trojans-team-plane-tips-backward-tarmac-coaches-staff-board
Preliminary reports say the big guys were in back behind the emergency exits, about 95 of them. Usually have seen the coaches and staff up front along with some MVPs.
It is one of the worst ones I have seen also. Last I heard it was going to MX ferry at noon tomorrow.
If one really tries, any airliner could be tipped back on it's tail.....
