davidjohnson6 wrote:I realise for a bus manufacturer, this is a niche area, but why do Cobus have such high market share of airside buses for bulk passenger transport ? It doesn't seem like a particularly demanding design requirement for a bus manufacturer... so wondering why other companies's buses are rarely seen airside
ScottB wrote:davidjohnson6 wrote:I realise for a bus manufacturer, this is a niche area, but why do Cobus have such high market share of airside buses for bulk passenger transport ? It doesn't seem like a particularly demanding design requirement for a bus manufacturer... so wondering why other companies's buses are rarely seen airside
I'd imagine you identified it already -- it's a niche market. The Cobus 3000 is a fair bit wider than your typical city bus or motorcoach, and it's designed with far more standing/luggage space than a typical bus. Other companies aren't likely to compete aggressively in the space just because the market is so small; I'd be surprised if they sold more than a couple hundred a year.
Ziyulu wrote:Does any US airport use remote stand boarding on a daily basis which require use of these buses?
EL-AL wrote:Surprisingly in Frankfurt Germany, which looks like the natural Cobus-land, they are using mostly articulated Mercedes Citaro buses to transport passengers. But yes indeed, Cobus 3000 is the most common airport bus to be found. Those buses are lower and wider than regular city buses therefore can only be used in airports, thus the small market. In Tel Aviv, Neoplan airport buses replaced with Cobus since 2010, pre-covid Tel Aviv city buses (usually MAN NL-263) were used in peak days. I was always wondering why articulated buses aren't in winder use in airports.
N766UA wrote:They used to have COBUS 3000’s at CVG. I believe they could only turn left, though.
CrimsonNL wrote:AMS now has a fully electric bus fleet of BYO buses from China
I remember riding some kind of replica Cobus variant in THR. I believe it was a Chinese brand but the styling inside and the logo looked just like Cobus, maybe like a bootleg version..
shamrock137 wrote:ScottB wrote:davidjohnson6 wrote:I realise for a bus manufacturer, this is a niche area, but why do Cobus have such high market share of airside buses for bulk passenger transport ? It doesn't seem like a particularly demanding design requirement for a bus manufacturer... so wondering why other companies's buses are rarely seen airside
This might be a good thread for Tech Ops. A Cobus might look the same as a city bus, but they actually pack a bunch of features that make it pretty specialized. They are very low to the ground. Unlike a city bus which has to navigate potholes, bumpy roads, or snow in cold climates, a Cobus will only be used on the airport, which is surface wise is much better maintained then a city road. This allows them to be loaded faster since its a smaller step up into the bus. They also have way more doors, a 45ft Cobus 3000 has 6 doors, 3 on each side. A 40ft city bus would have 2. There are also no steps inside a Cobus. the floor is completely flat from front to rear. Most busses have steps in the rear. This again adds to it being much faster to load and unload. Lastly, and this is country / airport specific, but a Cobus can be ordered with a completly separate driver cab, where the driver has no access to the passenger compartment. This is important in some countries that have specific rules about airport employees interacting with customers arriving from foreign countries.
Could another manufacturer make a bus just like this? Sure, but the return on investment for producing such a specialized product would probably be pretty low if your main focus is on manufacturing normal city busses.
harleydriver wrote:I'm curious what bus manufacture makes the buses for PHL from the main terminal to Terminal F.
AirKevin wrote:N766UA wrote:They used to have COBUS 3000’s at CVG. I believe they could only turn left, though.
How and why.
niagara484 wrote:AirKevin wrote:N766UA wrote:They used to have COBUS 3000’s at CVG. I believe they could only turn left, though.
How and why.
N766UA was joking. The buses at CVG ran on a counter-clockwise loop between B and C so they were mostly turning left on the ramp. But yes, they could turn both right and left as they navigated off the active ramp up to the doors at C.
niagara484
seansasLCY wrote:I remember when London sold off their “bendy buses” it was also said they were going to Malta Airport.
airlinepeanuts wrote:SEA has Cobus buses as well. I believe Cobus is a division of or at least affiliated with Mercedes Benz.
Noris wrote:They also had a tendency to burst into flames.
AirKevin wrote:Noris wrote:They also had a tendency to burst into flames.
How and why.
