CapStar362
Location of this Incident
Tue Nov 23, 2021 2:31 am
hey yall, long time viewer, never really been here on the forums.
a recent discussion has brought up this incident:
https://www.youtube.com/watch?v=IRIqZfqru2o
can anyone tell me where this happened and when?
I cannot find a single shred of evidence on this tug jack knifing and causing the nose wheel to be forcibly replaced.
Even ASN does not have this one logged.
guppyflyer
Re: Location of this Incident
Tue Nov 23, 2021 3:43 am
JFK
airsmiles
Tue Nov 23, 2021 6:42 am
That A380 livery doesn’t look right. Has this video been edited from one showing another similar incident?
VirginFlyer
Tue Nov 23, 2021 8:03 pm
Looks like the standard old Lufthansa livery to me?
V/F
Tue Nov 23, 2021 9:13 pm
I don’t think it is real, the nose gear has tow angle limits, that shows something that has exceeded those limits significantly which will damage the nose gear.
airsmiles
Tue Nov 23, 2021 10:17 pm
V/F
Maybe it’s the light but it looks photoshopped to me.
WayexTDI
Tue Nov 23, 2021 10:23 pm
Can the nose gear exceed the tow limit, suffer significant damage that will require its replacement yet remain structurally sound enough to support the weight of the plane and the force of the traction? I don't recall anything that would prevent that, I somehow remember the steering mechanism to be able to sheer off the center tube in such cases.
guppyflyer
Wed Nov 24, 2021 1:31 am
The A320 fleet has had a number of landing incidents with the nose gear turned 90 degrees.....not saying this video is real, but it is possible for the nose gear to go beyond the towing limits. https://www.youtube.com/watch?v=epKrA8KjYvg
SMYD
Wed Nov 24, 2021 3:35 am
The MD11/DC10 is particularly susceptible to this type of tug jackknifing. The steering actuators and torque linkage are typically destroyed when this happens but the nose gear typically doesn't collapse. The aircraft can usually be towed a hangar for repair/nose gear replacement.
Wed Nov 24, 2021 8:09 am
You would need to stop and do and inspection, there is a procedure in the AMM for it. You dont continue on like nothing happened.
Keep in mind there is also someone in the cockpit during towing, there is an indicator on the overhead panel for the exceedance.
WayexTDI
Wed Nov 24, 2021 3:20 pm
That's exactly what I asked, thanks for this info. Not sure if it applies to the A380 though, per zeke.
WayexTDI
Wed Nov 24, 2021 3:21 pm
If this happens on an active runway, you block it then?
I agree there is plenty of inspection and repair that's needed; but the plane can't even be towed to a hangar for that? It has to be done on site?
PSAatSAN4Ever
Wed Nov 24, 2021 4:18 pm
From one of the comments on YouTube:
This was at JFK, that camera is one of the ramp control cameras for Terminal 7. This was several years ago.
I can't confirm. Can someone else?
twincommander
Wed Nov 24, 2021 4:52 pm
Yes, they should have stopped and done a visual of the whole nose gear and surrounding structure prior to continuing. The nose gear could have collapsed, then it would be a much bigger blockage to deal with than possibly losing a runway and taxiway for an hour.
TUGMASTER
Wed Nov 24, 2021 5:03 pm
Absolutely you stop / inspect etc, and everybody in the world would be out their too.
If you’re using a TBL type of tug, brake riders no longer needed in the flight deck.They were only there for a towbar break/Shear, to literally stop the aircraft.
Fixinthe757
Wed Nov 24, 2021 6:14 pm
Going out on a limb here and say the video is not real. The tow bar would no longer be usable as it has shear bolts that would pretty much render it useless for towing. The amount that tug turned around and the tow bar still attached is impossible. In my 30 years of towing aircraft, yes you can exceed the limits, but no the gear wont collapse. Depending on how much it gets exceeded the steering actuators can be damaged, resulting in hyd leakage once hydraulics were turned on. The scissor links would also be damaged in that they can only turn so much as well. Also in exceeding the limits the risk is very high in doing internal damage to the strut centering cam. The cam causes the strut to center when fully extended. I also dont that type of tug able to go the speed it "appeared" to be going towing an A380, nor turning completely around. Notice too how the plane started moving backwards as soon as the tug started turning. With a sheared/destroyed tow bar, that isnt happening. And no Ive never exceeded the limits on a plane Ive towed (before anyone ask) 8-)
WayexTDI
Wed Nov 24, 2021 6:43 pm
I agree the video doesn't look real.
But this is a towbarless tug, that lifts the nose wheel and straps it; so, all the discussion about tow bars is moot.
jimmy9irons
Wed Nov 24, 2021 7:03 pm
Comments state the nose gear was replaced
