TC957 wrote:Good idea - thanks for starting this topic thread. Is Airbus still formally offering new-build A332F's ? Any unfulfilled orders ?
PM wrote:This should be an interesting thread. Thanks.
For the record (rather a depressing record) I thought I'd give what I believe are the final numbers on the A330F.
38 planes were built and delivered.
Flying-Tiger wrote:- CMA CGM seems to be getting one A330-200 P2F, to be operated by Air Belgium (assumed)
PM wrote:Airbus received orders for 107 A330Fs. Many were from leasing companies. (Avion, Guggenheim, Intrepid, Flyington, AirCastle MatlinPaterson, BOC)
29 were converted to passenger airframes.
40 were cancelled. (Mostly by the leasing companies.)
Bottom line ... 107 orders received; 38 planes delivered.
MD80MKE wrote:Flying-Tiger wrote:- CMA CGM seems to be getting one A330-200 P2F, to be operated by Air Belgium (assumed)
This is interesting. Any idea on the timeline and the lessor behind (if any)?
MD80MKE wrote:Thanks author for creating this thread, we kinda needed this for a while.
A status update on the A330P2F program.
Currently EFW has delivered 3 A330-200P2F and 10 A330-300P2F to date.
600 A330-243(P2F) EgyptAir SU-GCE 04-08-2018
610 A330-243(P2F) EgyptAir SU-GCF 09-11-2019
709 A330-243(P2F) EgyptAir SU-GCJ 02-02-2019
116 A330-322(P2F) DHL EI-HEA/B-LDO 05-12-2017
127 A330-322(P2F) DHL EI-HEB 01-03-2018
231 A330-322(P2F) DHL EI-HEC 24-09-2019
713 A330-343(P2F) GEODIS G-EODS 27-08-2021
777 A330-343(P2F) DHL B-LDR 14-06-2020
781 A330-343(P2F) DHL B-LDQ 23-08-2020
879 A330-343(P2F) MNG TC-MCM 17-11-2021
1107 A330-343(P2F) DHL D-ACVG 06-05-2021
1124 A330-343(P2F) DHL B-LDT 07-01-2021
1477 A330-343(P2F) DHL D-AJFK 30-09-2021
Currently in conversions are
868 A330-243(P2F) ex-Etihad Airways A6-EYQ MasAir XA- Entered DRS 13-06-2021
958 A330-343(P2F) ex-China Southern Airlines B-6502 CDB Aviation Entered DRS 23-04-2021
964 A330-343(P2F) ex-China Southern Airlines B-6501 CDB Aviation Entered DRS 06-08-2021
1401 A330-343(P2F) ex-Hi Fly 9H-HFC DHL Entered DRS 13-08-2021
There are two recent arrivals at DRS MSN 1357 and 1378, both ex-Avianca frames and currently less than 9 years old that are expected to entered conversion soon and the expectation is that both will go to DHL. Both of the CDB frames will go to MasAir.
Source
https://a380.boards.net/thread/1044/a330p2f
WayexTDI wrote:MD80MKE wrote:Thanks author for creating this thread, we kinda needed this for a while.
Source
This list begs the question: did Airbus make a mistake in picking the A330-200 as its freighter basis? Should they have picked the A330-300 since it seems to be a bigger success in P2F conversion?
SteelChair wrote:And in the 330 the door is ahead of the wing!
SteelChair wrote:I still don't see any compelling reason why anyone would spend 3-4x as much for a new A350 over a modified A330. According to my calculations the payback on the fuel savings is 46 years.
Spacepope wrote:MD80MKE wrote:Flying-Tiger wrote:- CMA CGM seems to be getting one A330-200 P2F, to be operated by Air Belgium (assumed)
This will be where sources would be helpful. We already cover a lot of this in the Air Cargo megathread.
LDRA wrote:SteelChair wrote:I still don't see any compelling reason why anyone would spend 3-4x as much for a new A350 over a modified A330. According to my calculations the payback on the fuel savings is 46 years.
What is the utilization?
SteelChair wrote:LDRA wrote:SteelChair wrote:I still don't see any compelling reason why anyone would spend 3-4x as much for a new A350 over a modified A330. According to my calculations the payback on the fuel savings is 46 years.
I assume you mean in my amateur analysis.
4,700 hours per year.
WayexTDI wrote:This list begs the question: did Airbus make a mistake in picking the A330-200 as its freighter basis? Should they have picked the A330-300 since it seems to be a bigger success in P2F conversion?
“The mistake Airbus made [with the A330-200F] was to say, ‘Look, we don’t have an airplane that is really capable of that having density, but we want that range.’ We developed the 330 freighter on the basis of the -200, and that was the mistake. We should have done it on the -300, because the 200, even though it’s got a little better structural capability than the -300 still doesn’t have the structural capability for the heavy freight. We should’ve gone for volumetric payload, as opposed to trying to compromise between structural payload and volume. We’re not making that same mistake [with the A350] because we’re starting with the bigger module.”
Revelation wrote:WayexTDI wrote:This list begs the question: did Airbus make a mistake in picking the A330-200 as its freighter basis? Should they have picked the A330-300 since it seems to be a bigger success in P2F conversion?
Airbus's COO agrees with that idea:“The mistake Airbus made [with the A330-200F] was to say, ‘Look, we don’t have an airplane that is really capable of that having density, but we want that range.’ We developed the 330 freighter on the basis of the -200, and that was the mistake. We should have done it on the -300, because the 200, even though it’s got a little better structural capability than the -300 still doesn’t have the structural capability for the heavy freight. We should’ve gone for volumetric payload, as opposed to trying to compromise between structural payload and volume. We’re not making that same mistake [with the A350] because we’re starting with the bigger module.”
Ref: https://leehamnews.com/2021/11/11/airbu ... fications/
Articuno wrote:A freighter the size of an A332F could not be commercially successful without orders from FedEx or UPS. That is where the 763F beats the A332F. Currently, 224 out of the 251 orders (89.24%)for the 763F are from FedEx and UPS.
Revelation wrote:Whether you intended to or not, this tends to support the skeptical outlook for the lease orders for A350F, IMO.
smartplane wrote:SteelChair wrote:I still don't see any compelling reason why anyone would spend 3-4x as much for a new A350 over a modified A330. According to my calculations the payback on the fuel savings is 46 years.
If the comparison is with an A350, then surely ditto and more for the 777X.
flee wrote:TC957 wrote:Good idea - thanks for starting this topic thread. Is Airbus still formally offering new-build A332F's ? Any unfulfilled orders ?
Why would anyone buy a new build A332F when there are so many A332 and A333 P2F conversions available? I think that in the next 5 years, a lot of A330s that are coming off leases will be converted into freighters - and most of them will be A333P2Fs.
SYD330 wrote:Are there going to be plans to use the NEO engine option on the A350 Freighter's?
Revelation wrote:PM wrote:Airbus received orders for 107 A330Fs. Many were from leasing companies. (Avion, Guggenheim, Intrepid, Flyington, AirCastle MatlinPaterson, BOC)
Scoreboard wrote:PM wrote:
And the breakdown of orders was
3 Sichuan AL (1350, 1386, 1408)
Polot wrote:I think A333P2F can have a role in FX/UPS’s fleet- it is a much larger aircraft than the 763F. The A332P2F not so much.
flee wrote:Polot wrote:I think A333P2F can have a role in FX/UPS’s fleet- it is a much larger aircraft than the 763F. The A332P2F not so much.
I am not so sure as they already operate the B777F - why have another type of aircraft to complicate matters?
Polot wrote:flee wrote:Polot wrote:I think A333P2F can have a role in FX/UPS’s fleet- it is a much larger aircraft than the 763F. The A332P2F not so much.
Any A330P2F would be for regional use while the 777F’s primary focus would be long haul. See DHL for example. UPS also doesn’t have any 777Fs.
BHRN wrote:flee wrote:Polot wrote:I think A333P2F can have a role in FX/UPS’s fleet- it is a much larger aircraft than the 763F. The A332P2F not so much.
I agree with Polot. A333P2F can have a different role at FX with their 777s, which is currently being undertaken by their MD11s. It's too much a gap capacity-wise between their 767F and 777F.
That said, this wouldn't happen unless FX is able to sort out the wingspan/gate issue at their US hubs.
HPRamper wrote:That said, this wouldn't happen unless FX is able to sort out the wingspan/gate issue at their US hubs.
They aren't going to redo the gates at the hubs. It's a nonstarter.
The capacity gap is solved with more frames, which they have options for anyway. FX wants factory freighters now, I give them a sub-10% chance of doing an about face and picking up P2F Airbus frames, when they very openly want to replace the A300s and move to an all-Boeing fleet. More likely they pressure Boeing on a 764F which will almost exactly match the capacity of the MD11F.
BHRN wrote:HPRamper wrote:That said, this wouldn't happen unless FX is able to sort out the wingspan/gate issue at their US hubs.
Agree...A330P2F just wouldn't happen. Otherwise, we could have seen new builds A332F rather than 767F in the first place.
But again, 764F doesn't seem to be the solution either. Being 6.4m longer than the 763F, I will give it max 4pos/8LD2 extra capacity. That is still far from what FX is carrying on the MD11. Using more frames might work for domestic, but wouldn't work for international markets where there are frequency/traffic rights cap.
Perhaps there will be a place for a 772P2F one day.
Already, we have deposits from customers for 14 of the 20 A330s that we have previously committed to convert. I'm confident by the end of this year, our order book will include customer commitments for all of the first 20 A330s we plan to deploy.
In light of that strong customer interest for an aircraft still two years away from delivery, we have boosted our conversion slot commitment by nine to 29 A330s for delivery over the next five years.
We also made our first or secured access to our first feedstock for the A330. We have deposit on the first five of the 20 aircraft.
