audidudi wrote:Latest movement for 22 March 2022:
MSN 1999 Delta Air Lines A339 F-WWKT/N416DX, third test and first customer acceptance flight at TLS:
https://aibfamily.flights/A330/1999
UAEflyer wrote:audidudi wrote:Latest movement for 22 March 2022:
How many more to go for Delta ?
WayexTDI wrote:UAEflyer wrote:audidudi wrote:Latest movement for 22 March 2022:
DL ordered 35 A330-900s; they have received 13 of them. MSN 1999 would make that 14, so 21 more to go.
godsbeloved wrote:WayexTDI wrote:UAEflyer wrote:How many more to go for Delta ?
Total should be 37
Total should be 37
MIflyer12 wrote:godsbeloved wrote:WayexTDI wrote:DL ordered 35 A330-900s; they have received 13 of them. MSN 1999 would make that 14, so 21 more to go.
Total should be 37
Two of those 37 are leased, not acquired from Airbus.
godsbeloved wrote:MIflyer12 wrote:godsbeloved wrote:
Total should be 37
Where are they coming from then? Boeing? Embraer?
Do you really believe Boeing or Embraer is going to order an A330neo straight from Airbus???
OK, so, final tally is that DL will operate 37 A330-900s, 35 owned and 2 leased; 13 already delivered, 1 in delivery process; 23 more to go. Is that correct?
TC957 wrote:Flight time was 15 hrs 15 mins. One of the longest ever A330 flights ?
At which point Delta could operate 79 A330s.
Or are some of the -900s going to replace older frames?
Scotron12 wrote:
Wouldn't be the 1st airline to operate that many aircraft type. IIRC, JAL had almost 100 x B747s and BA topped out at around 57 x B744s.
DL seems to like the A330
JerseyFlyer wrote:I wonder if these two announcements are connected.
"Lebanese carrier Middle East Airlines has pushed back delivery of its four Airbus A330neos until 2026 as it bids to recover from the dual challenges of the pandemic and economic crisis in Lebanon."
https://www.flightglobal.com/strategy/l ... 61.article
"Indonesia's Black Stone Airlines to add four A330neo" - a bit strange for a freight airline, but may work as a short term pfreighter.
https://www.ch-aviation.com/portal/news ... ur-a330neo
DrunkFunk wrote:I noticed the first A339 for Virgin yesterday ! unpainted, but recognizable thanks to the winglets
MrHMSH wrote:DrunkFunk wrote:I noticed the first A339 for Virgin yesterday ! unpainted, but recognizable thanks to the winglets
Were you passing by TLS or did you see a photo somewhere?
For some reason I thought VS' A339s were due in 2024, but nice to see they're on the horizon.
Polot wrote:MrHMSH wrote:DrunkFunk wrote:I noticed the first A339 for Virgin yesterday ! unpainted, but recognizable thanks to the winglets
First one is due towards the end of this year.
audidudi wrote:Latest movement for 4 May 2022:
MSN 2013 Starlux Airlines A339 F-WWKM/B-58303, taxi check and RTO at TLS:
https://aibfamily.flights/A330/2013
