Cubsrule
Re: Chicago Aviation Thread - 2022
Mon Sep 19, 2022 10:31 pm
drdisque wrote:
Cubsrule wrote:
Sevensixtyseven wrote:
I think one of the old DL gates on T2..maybe E11? E15? can take a widebody aircraft. I'm not sure who's getting the rest of T2 once Delta is finally off to T5, but I'm sure UA wouldn't mind some extra real estate to help smooth out the peaks of their operation, or having some breathing room for bad weather days.
I can’t speak to any reconfiguration that may have occurred in the past decade or so, but NW parked 744s on E15.
The hold areas at the end of E aren't really big enough to handle a widebody anymore. Maybe a 787-8 if the adjacent gate was blocked. Of course they could do the 767-300 with the high J config but since those are premium flights and because they can put them on the center gates on B or C in the alley, I doubt they would put it out in E.
No, the hold rooms are insufficient but they were also insufficient when NW ran TYO out of there.
se210
Mon Sep 19, 2022 11:51 pm
se210 wrote:
se210 wrote:
Noticed Qatar Executive A7-CGH G-VI flew into ORD around 10:30pm on 9/15/2022 as QQE894 (parked at Signature ORD). The ADS-B/transponder log for Qatar Airways Cargo accident aircraft A7-BFH B777-FDZ was turned on the next morning (9/16/2022) around 10:15am CST at the American Airlines Hanger 3 (previous ADS-B/transponder log for A7-BFH was 8/29/2022). A7-CGH then left Signature ORD at 1:26pm CST as QQE894 for TEB (Teterboro,NJ) and then back to DIA (Doha,Qatar) the next day (9/17/2022) as QQE229.
Wondering if A7-CGH came in with Qatar Airways officials for an inspection of A7-BFH? Anybody know the current status of the A7-BFH?
Per this ADS-B Exchange log, A7-BFH taxied from American Airlines Hanger 3 over to the North East Cargo Ramp at ORD this afternoon (9/19/2022).
A7-BFH estimated to depart at 9:10PM CDT tonight (9/19/2022) as QR8871 ORD-LGG (Liege, Belgium).
Sevensixtyseven
Tue Sep 20, 2022 4:31 am
The 767 has plenty of capable gates already, as it's a size down from 747/777/787.
How many 767’s can fit into T1 without taking up any 777/787 gates?[/quote]
You can put a 767 on C9/11/15/19/21 and 23, all simultaneously, if you needed to. C23 was supposed to be 787 capable, but it was a tight squeeze.
sz1998
Thu Sep 22, 2022 3:34 pm
Per OAG -- ORD is the world's most internationally connected airport. Good for Chicago and ORD. Things will only get better as the expansions come online and capacity skyrockets.
Oceanic
Thu Sep 22, 2022 3:44 pm
Here's a link so others don't have to try and find if this was legit or not like I did...
https://www.oag.com/megahub-airports-2022
and here's a press release from the mayor's office:
https://www.chicago.gov/city/en/depts/d ... 12022.html
scaledesigns
Thu Sep 22, 2022 4:28 pm
That is true, but they can't spin the fact that ORD is down 10,000 domestic pax per month compared to 2019 and the southern hubs are almost at 2019 domestic levels. Everyone has the same problem with the decline of business travel including the southern hubs. Could it be that it is alot cheaper to operate from the southern hubs than ORD....Yes it it!!!
The out of town poster was right and wrong. There is a decline at ORD, but not because people don't want to connect and come here.
Manderson12
Thu Sep 22, 2022 5:17 pm
I don't believe that ORD is concerned about southern hubs domestic increases in passenger counts. We live in a global society and ORD is focused on markets worldwide. As ORD continues its international ascension the domestic will take care of itself.
WN732
Thu Sep 22, 2022 6:04 pm
That's 7 full CRJ-200's every day.
scaledesigns
Thu Sep 22, 2022 6:30 pm
ORD has expanded and spent alot of money to take on ATL and other southern hubs with new runways and plans for huge new terminals. The city dreams of more flights, maybe getting larger than ATL even some day. If they can't get costs under control it will never happen.
emcm541
Fri Sep 23, 2022 1:10 am
A couple minor service changes to report.
- Eva to increase ORD to Taipei from 2x to 3x on 773ER effective 11/7/22 - https://www.aeroroutes.com/eng/220922-brnov22lh
- Turkish to reduce ORD to Istanbul from 12x to 10x for basically months of November 2022 and February 2023 - https://www.aeroroutes.com/eng/220919-tknw22inc
Additionally, I've been a fly on the wall in the Delta network thread, and it sounds like DL to announce some new routes out of LAX in the coming weeks. ORD to LAX was mentioned more than a couple times in the rumor mill. viewtopic.php?p=23472663#p23472663
Planeboy17
Fri Sep 23, 2022 1:13 am
IMHO, I think it has more to do with ATL, DFW, IAH and CLT essentially being non competitive hubs than costs. No doubt that costs play a factor but the UA/AA dual hub is much stronger than any, including WN at ATL.
kordcj
Fri Sep 23, 2022 2:44 am
I’m shocked but also proud at the same time. Of all the things Chicago govt does wrong, they always seem to get it right most (looking at you ATS) of the time with the airports.
scaledesigns
Fri Sep 23, 2022 12:19 pm
One other thing you are not taking into account, much higher a percent of pax are going to other hubs such as DEN, DFW, ATL, CLT to connect than they used to, feeding those hubs.
sz1998
Fri Sep 23, 2022 2:00 pm
...and ORD remains in the same grouping as those airports. Not sure what point you're trying to make? ORD, DEN, ATL, CLT, DFW are all US mega-hubs. ORD has not -- and will not -- fall out of that grouping.
yeogeo
Sun Sep 25, 2022 5:17 pm
The CDA has now advertised a Bid Opportunity for the next phase of the reconfiguration of taxiways Alpha and Bravo consisting of…
“Demolition of existing pavements and utilities, site preparation & site drainage, new concrete and bituminous pavements…taxiway and roadway lighting and signage…and final grading associated with the tie-in of the new taxiway systems.”
"Taxiways A and B Reconfiguration would replace sections of two (2) existing taxiways with new taxiway pavement, increasing centerline separation to provide parallel Airplane Design Group V/ Taxiway Design Group 6 taxiways."
Below, the project is indicated with the heading "#29 Taxiways A and B Reconfiguration". Note the faint dashed lines indicating the centerlines of the new A&B
(not the bold dashed lines, which represent the Satellites/Main Global Terminal tunnel).
current FAA ORD chart and the schematic from the May ’21 “Description of Proposed Projects”
The latter is from the 2021 Environmental Assessment for the OGT and satellites, among other projects. This document has been converted into a YouTube video:
https://www.youtube.com/watch?v=lhvlSv6euyI
or copy to google: Project Description: O’Hare Terminal Area Plan Env. Assessment Scoping
(see 1’35” to 2’30”)
ILikeTrains
Sun Sep 25, 2022 6:43 pm
Have they considered installing an EMAS off the end of 22R? The satellite terminal being off the end of the runway seems concerning at first look.
yeogeo
Sun Sep 25, 2022 11:11 pm
From the diagram seems there'd be room for it. I agree it would be prudent!
A separate budget item once Sat 2 construction begins?
yeogeo
Mon Sep 26, 2022 12:05 am
Passed through T-5 last Friday at 16:00 hrs returning from Europe.
The place was jumping but flowing nicely for all categories of incoming pax.
Face recognition Global Entry took less than a minute from beginning the process at the kiosk to baggage claim
Something I’ve never seen before: the crew line was probably 50 deep and not moving.
Trains were full but no delay in either FIS or TSA.
One thing about T-5 that is only get worse as international recovers, is the inadequate lobby space between the FIS exit and the escalators up to the ATS. Really tight with a mass of greeters meeting the flow of transiting pax. The train platform is pretty tight as well.
Did my good samaritan O’Hare transfer ambassador for two parties of Japanese men - one who didn’t understand the PA announcement at baggage claim that NRT bags had been massed off-carousel and another couple of guys who were looking for C gates in the lower B’s. Once I pointed out the C gates out the windows in the distance they took off in a run: “to the dinosaur and take a left!”.
emcm541
Mon Sep 26, 2022 1:12 pm
As always, thanks for always providing to us. Curious as to what those small expansions in B and C will entail (#33 and #4 on the map - cut off in the screen shot). The areas by north B and the banana gates is always crowded and could use small space. Additionally, the Lufthansa and ANA check-in area is vastly undersized and that could use some expansion as well.
Rl12383
Mon Sep 26, 2022 2:25 pm
Looks like TP 32 and 34 is for moving gates away from the C terminal in preparation for one of the new satellite terminals. A little detail on those projects from the contact in link below:
https://www.tpapord.com/projects/
emcm541
Mon Sep 26, 2022 2:36 pm
Wow. That TP34 is quite the interesting proposed set-up for the next few years.
yeogeo
Mon Sep 26, 2022 4:39 pm
Thanks for that link from Paschen, Rl1! Had seen the project of the temporary T-2 C gates waay upthread and we touched on it briefly, but hadn't seen it in such detail... thought I'd bring it forward here.
In the top right quarter of the illustration is a void which represents the construction site of Satellite 1.
sz1998
Mon Sep 26, 2022 5:58 pm
Great to see!! Do we have an idea on timing when the Sats will fully kick off?
United787
Mon Sep 26, 2022 8:17 pm
Looks like it is getting closer and a great sign that all of the preconstruction infrastructure work is in full swing. If I had to guess, this would mean that they are at least 50%+ completed with Construction Documents for the terminal and satellites if not 75%+.
yeogeo
Mon Sep 26, 2022 11:02 pm
A recent addition to the FAA ORD Diagram
Compared to the previous FAA chart, the most recent diagram on the right show new taxiways & ramp associated with the third and final phase of the NE Cargo Project, a 120,000 sf warehouse with 10,000 sf of office, and an adjacent ~200,000 sf aircraft apron that accommodates two group VI aircraft (747 cargo aircraft).
http://www.communities4construction.com ... y-project/
After Phase III is complete, the northeast cargo facility [in total] will have more than 900,000 square feet of warehousing and about 1.1 million square feet of apron pavement, including enough space for 13 wide-body aircraft to unload at any given time. According to estimates from the Chicagoland Chamber of Commerce, the average payload of each 747-8 is worth about $3 million.
https://airportimprovement.com/article/ ... -warehouse
Building the new cargo facility became possible when Scott Air Force Base relocated from the north side of ORD to southern Illinois during the late 1990s.
Looking northeast from what is now the T-1 Banana Peel, you used to have a view of the airbase, here in 1997:
Here's a history of the O’Hare Air Reserve Station and the United States Air
Force base before it:
https://military-history.fandom.com/wik ... ve_Station
muralir
Tue Sep 27, 2022 3:29 am
No, everyone doesn't have the same problem with decline in business travel. It depends on how much business travel existed in the first place. Business heavy airports will be affected more than leisure-heavy airports. I honestly don't know what percentage of Chicago's travel is business vs. leisure. My point in bringing it up is that there are several factors that affect passenger traffic, and if you're going to assert that landing costs are the main factor, then it's on you to explain why other factors are not equally or more important.
Another factor to consider is transit traffic vs O&D. During the pandemic, most airlines consolidated a lot of flying into their hubs, and lots of P2P flights were changed to hub connecting flights to save money. As a result, airports that are more dependent on transit traffic are probably having a rebound in traffic faster than airports more reliant on O&D traffic. O'Hare, as big of a transit airport as it is, has a higher percentage of O&D traffic than places like ATL and DFW. So while traffic is returning, if more of that traffic is directed to hub-and-spoke connections, then airports more reliant on transit traffic will see a correspondingly faster / larger rebound.
You seem to keep jumping to landing fees as the sole factor, without any acknowledgement of other factors in play. If landing fees were the sole consideration, every airline would move to Gary or Rockford or Milwaukee. And JFK, EWR, and IAD would be ghost towns. For that matter, O'hare's 2019 traffic should be lower than it was. It's not like landing fees were more competitive then they are are now.
jcwr56
Tue Sep 27, 2022 11:44 am
Most, if not all of the tunnel sections are being repurposed from T5.
emcm541
Tue Sep 27, 2022 12:48 pm
I know this has been shared previously, but I do not remember what page of the thread it is on or if it's from years prior. So for the ease of those who wish to review, here's the link to the OGT design info on Studio Gang's website: https://studiogang.com/project/ohare-global-terminal
yeogeo
Tue Sep 27, 2022 1:07 pm
Nice detail! :thumbsup:
...and since I have your attention, jcwr, how's things in T-5?
Is Delta going to make their October date for the move? :hyper:
yeogeo
Tue Sep 27, 2022 2:26 pm
emcm541 wrote:
...for the ease of those who wish to review, here's the link to the OGT design info on Studio Gang's website: https://studiogang.com/project/ohare-global-terminal
That’s great you brought this link up, emcm! Sorry if this is old news - it’s been a while since I’ve seen Studio Gang’s work on the project, and I can’t help but putting up a few images.
Hadn’t seen before this general use and flow diagram of the main terminal:
The section drawing I've seen before but hadn't noticed many of the interesting details, here’s a portion.
The departures overlook should be a great view!
Interesting to see where/how the Automated People Mover Station (to/from the Satellites) and the main concourse interact.
Notice also the sterile glass corridors connecting international arrivals to the FIS, above the main “neighborhood”.
Hadn’t seen before how they make the connection between the southern end of T-1, C concourse, and the north end of Sat 1. It’s essentially a long corridor with gates which opens up into the higher ceiling of Sat 1. Maybe SOM* will be putting out images of their plans? Has anyone come across any?
(Sat 1 in the foreground with its connector to T-1, and Sat 2 in the distance).
* Skidmore, Owings & Merrill, the Chicago architectural firm, chosen to design the two Satellite Terminals.
scaledesigns
Tue Sep 27, 2022 2:33 pm
All your points are well taken, but landing fees are only part of the cost. ORD's per pax costs are some of the highest in the nation for a hub. All the large southern hubs are much lower including Atlanta. If I was an airline with limited crew availability to operate flights I would pick the cheapest hub to operate from and feed pax into them also wich is what they are doing. That problem will continue for several more years, but if ORD wishes to increase and take on ATL, DFW ect they will have to be more in line with those hubs costs. If they don't want to take on those hubs and be the biggest why did we bother to spend billions of dollars with this huge expansion?
emcm541
Tue Sep 27, 2022 2:58 pm
I actually checked SOM's website this morning before posting to see if they had any updates and I couldn't find anything. I would venture a guess that they will be releasing something soon, since we're pretty much getting ready for groundbreaking in the next year or so.
muralir
Tue Sep 27, 2022 8:45 pm
ORD's per pax costs are definitely high right now and expected to go higher with the completion of the terminals. And I agree, that is an important consideration for flights, especially marginal ones where the profit may only be $20-30 per seat in the first place. But it's not the only one. Even from a financial consideration, the streamlining of operations where flights won't have to be towed from T5 reduces costs. Reducing weather delays, reducing delays from gate availability, decreasing taxi times with all of the taxiway work being done, these all go to reducing costs for airlines. They probably won't compensate entirely for the increased pax costs but they do make it better than it initially appears.
What's more, ORD's peer airports are also expected to increase their per pax costs pretty significantly. ORD has traditionally been in the middle of costs. Places like JFK are much higher, and ATL is much lower. It so happens that ORD will likely finish their terminal stuff sooner than the others -- not to mention the runway work for the past decade -- and so temporarily, ORD's ranking will be much higher than usual. But JFK is in the midst of a large-scale terminal reconstruction program, LAX just completed their TBIT satellite and is working on a massive plan to reconfigure their roadways, EWR is building a new terminal. Denver is expanding their concourses and renovating their main terminal, etc. etc. All of these airports are expected to raise their landing fees and their overall per-pax costs significantly over the next decade, while ORD's should stabilize within a few years (once all the borrowing is done for the terminal project). The only major airport that's not planning to raise their costs significantly, I believe, is ATL, as they don't have much expansion plans on the table. With that, I expect that within a decade or less, ORD's costs will go back to being average/above-average compared to peers rather than abnormally high. That's still a disadvantage, of course, but not as bad as it might first seem.
And finally, I think you neglect the non-cost side of the equation: when ORD is done with its terminal expansion, it will have more runways than any civilian airport in the world, and a massive amount of new terminal space and gates. Among US airports, I can't think of any that have added, or will add in the next decade, as much capacity as ORD. If you're United and looking to expand, regardless of the marginally higher cost, you have no choice but to do it at ORD given that EWR and SFO and even IAD are so capacity constrained. The only airport with significant spare capacity is DEN, which is why they've gotten so much new traffic. Airports are a bit of a "build it and they will come" phenomenon (not always, witness the mid-America airport :-). When airlines want to grow, the airports with spare capacity is where the growth goes, regardless of whether some other airport might be more "optimal" financially or not. Despite the high prices, airlines are still clamoring for gates. Not just United and American, but international carriers, ULCCs, heck even Delta wants to add a few flights after they move to T5. It really doesn't seem like the per-pax costs are hindering the airport's ability to fill itself to the brim.
emcm541
Wed Sep 28, 2022 12:53 pm
For those of you who have Google Earth Pro downloaded to a desktop/laptop, google has satellite imagery for ORD/MDW from June 2022 if you use the time lapse feature. Regular google maps still shows the 2021 views. The time lapse feature in Earth is tricky to use and doesn't have the best images, but for those who want to play around with it, you can see the latest aerial images of ORD/MDW and get some images going back to 1985. Again this is for Google Earth pro, not regular google maps.
jcwr56
Wed Sep 28, 2022 1:00 pm
Progressing... :D
Still plenty to be done over the couple of years and of course. Everyone's excited.
jcwr56
Wed Sep 28, 2022 1:05 pm
Well said...Especially your last sentence.
scaledesigns
Wed Sep 28, 2022 3:17 pm
That was well said. I do agree with you on many points but beating ATL will be very hard. JFK is not a domestic hub like ATL, CLT, DTW ect., so I don't think that is a good comparison. NYC splits everything up so it will always be harder to make a mega hub there. I hope ORD can do it, but there might be some painful adjustments required before they are as big as ATL. One thing to also keep in mind, ATL, DEN, DTW, DFW, MSP, CLT ect are mainly one airline hubs.
elbandgeek
Wed Sep 28, 2022 4:00 pm
I remember the bridge configuation being weird when I flew through in March. Are these extra long ones supposed to be temporary? The plan that was posted a few pages back showed that the low Ms would lose FIS access, presumably to open up more holdroom space without the sterile corridors which explains the temporary walls that were up and I guess would necessitate the zig zagging bridges. It'd just be nice to see what the final configuration is actually supposed to be.
yeogeo
Wed Sep 28, 2022 4:45 pm
Honestly, I don't know about those domestic T5 gates, but if you're referring to jcwr's post about repurposing gate tunnels for this Project in T-1...
yeogeo wrote:
...I'm pretty sure he was referring to these temporary tunnels from hell you see on the south side of the unfinished T-5 extension below. Could be wrong.
SurfandSnow
Wed Sep 28, 2022 7:04 pm
I flew out of Terminal 5 yesterday and have to say, the new gates look great! WN is now using gates located in the center of the terminal, by the security checkpoint and central food court/shopping area. The bright, clean, spacious and airy hold rooms for M14 and M15 are a *HUGE* improvement from the cramped, drab older gates that remind you of Terminals 1-3. The eastern terminal extension to M40 is now open for pax to walk through, although with no concessions and much work remaining to be done. Nothing is open past the Burger King at M7 (temporary white construction walls block you from walking any further), so it's clear the new Delta gates aren't ready yet. However, when all is said and done the airside will be virtually unrecognizable from the relic of the early 90s that was there before. This long overdue renovation is wonderful to see. I never thought I would say this, but the future is bright for ORD!
sz1998
Wed Sep 28, 2022 7:08 pm
T5 really does look incredible -- and it is probably only 75% done. The entire structure is getting a gut job.
sz1998
Wed Sep 28, 2022 8:35 pm
Also -- at ORD right now. Did something happen to the crown of the T5 ramp tower? It looks like they removed the cladding to various parts of the tower/
AmricanShamrok
Wed Sep 28, 2022 8:54 pm
Agreed the T5 renovations will be much improved and needed but in a nostalgic way, I'll miss the old T5. It was weird seeing so many domestic flights departing from there when I last passed through earlier this year.
scaledesigns
Wed Sep 28, 2022 9:42 pm
Very nice clear skies today at ORD. Saw the ANA 787 9 land around an hour ago.
https://www.airlinefan.com/airline-phot ... A/5961624/
yeogeo
Wed Sep 28, 2022 11:00 pm
! Haven't seen a 787 of ANA on the field before - are they new to O'Hare?
emcm541
Wed Sep 28, 2022 11:11 pm
Flew out of ORD about 2 hours ago... From our previous discussions up thread, I can confirm C29 is widebody capible as my 789 flight departed from that gate.
I wish I could have grabbed a picture, but LH was departing a 350 and a 748 out of B16/17. Didn't know those gates could do widebodies at same time.
scaledesigns
Thu Sep 29, 2022 12:02 am
Daily cargo charters from northeast cargo. They use both 787 8 and 9.
dopplerd
Thu Sep 29, 2022 12:52 am
I don't know what this removal was for but I hope it was to align the panels. The panel gaps were very uneven and looked really amateur hour.
se210
Thu Sep 29, 2022 10:00 am
Cargojet Airways CJT1791/W81791 B757 C-GIAJ due in ORD just after 07:00AM today (9/29/2022) from YHZ.
jcwr56
Thu Sep 29, 2022 11:40 am
They needed to go back in for a short time for repairs. However, it's all sealed up and back to looking normal. The tower itself isn't operational yet, that happens sometime in November.
