PatrickZ80 wrote:Probably crew training. Touch&go's are usually done at remote airport to not waste prescious slots at primary airports.
davidjohnson6 wrote:Touch & go would not happen at BUD. However, why a military airbase instead of a quiet civilian airport like Balaton or Gyor ?
davidjohnson6 wrote:Air France has good connections with the French military. Doesn't mean they can put trainee FOs in A220s to fly in/out of French air force bases
I don't know of many air forces in the world that happily open up a base with fighter jets stationed there unless there is a good reason. Hungary has plenty of quiet airports where A320 training flights can take place
holczakker wrote:Free of charge. The pilot base training is done at Papa or Kecskemet (if Papa is unavailable), training for the local military ATC as well (as the government is pushing the civilian use of Kecskemet, which is bollocks). If the military airports are not available, Sarmellek, Debrecen or Kosice is used. Gyor has a narrow (30m) and shortish runway which is not OK for base training.
Alsatian wrote:Some rumours about Wizz Air plans to move its Hahn operations to Saarbrücken. About 110km between the two airports and 1h40 drive.
myki wrote:Looks like AUH has lost a few Wizz destinations - I will presume these were operated by 5W and not W6.
KIV, LCA, ODS, RHO, SKG
Also LXR has been removed as a destination but I believe this had never started.
krizzzy wrote:myki wrote:Looks like AUH has lost a few Wizz destinations - I will presume these were operated by 5W and not W6.
Hi, I just checked on flightconnections and this does not seem to be accurate. All destinations still have flights for months still. Also, Kiev is KBP.
Hope that helped.
Hope that helped.
PatrickZ80 wrote:krizzzy wrote:myki wrote:Looks like AUH has lost a few Wizz destinations - I will presume these were operated by 5W and not W6.
Hope that helped.
The Greek islands are likely to be summer seasonal destinations, not much to do there in the winter.
As for Kiev, is it possible that they're shifting this flight over from KBP to IEV? Wizzair has a big base in IEV while the AUH flight is the only one using KBP for Kiev. What could make more sense than to pull that one flight out of KBP and operate it out of IEV instead?
xwb777 wrote:Wizz Air Abu Dhabi announces flights to Mattala, Sri Lanka.
Source: Wizz Air Linkedin Page
atal17 wrote:Since India will revert to the bilaterals from end of March - they should have some opportunities coming, won’t they?
TIA wrote:Wizzair is basing a ninth aircraft (A321ceo) in TIA this summer and starting LYS, WAW and NUE, all 2 weekly.
According to an interview by W6 rep in the local media, they want to grow to 19 aircraft by 2025.
https://wizzair.com/en-gb/information-a ... -to-tirana
jmmadrid wrote:
such a small city, in a small and almost irrelevant economy as the albanian, with very little inbound/outbound tourism
Wow... continue please...
NeperQiell wrote:In that case i must go tell them to stop speaking such nonsense because an airliners.net expert concluded that it would impossible. Imagine if i told you back in 2020 that Wizz would have 9 aircraft based in TIA by 2022.
jmmadrid wrote:TIA wrote:Wizzair is basing a ninth aircraft (A321ceo) in TIA this summer and starting LYS, WAW and NUE, all 2 weekly.
It's amazing that such a small city, in a small and almost irrelevant economy as the albanian, with very little inbound/outbound tourism could sustain profitably a 19 airplane base! Guess it's all about the diaspora...
Is there even room at TIA for 19 planes at the same time?
MalevTU134 wrote:NeperQiell wrote:In that case i must go tell them to stop speaking such nonsense because an airliners.net expert concluded that it would impossible. Imagine if i told you back in 2020 that Wizz would have 9 aircraft based in TIA by 2022.
If this was in reply to my post, then I'm still awaiting your factual reply to it. And WizzAir are (in)famous for announcing new destinations, new bases and base increases that then don't materialize, so we shall see how much of this actually survives the news release stage.
Tunnelvision wrote:Hey does anyone know the reason Wizz has no spanish bases? Or if this is on the cards?
Tia
Blerg wrote:MalevTU134 wrote:NeperQiell wrote:In that case i must go tell them to stop speaking such nonsense because an airliners.net expert concluded that it would impossible. Imagine if i told you back in 2020 that Wizz would have 9 aircraft based in TIA by 2022.
From what I remember, when Wizz Air announced TIA they said it was because the airport had a new incentive scheme for new routes where they would even get money for marketing purposes. I guess that is still in place.
Also, don't forget that they might be using some of the 9 planes that are based in Tirana for W pattern flights. Albania is not a developed country so their costs are probably low making their operations over there quite lucrative.
Why, is he incorrect in any way? On a European scale, it's an observation that is spot on. To have 19 aircraft based there,
each carrying 200 pax, seems overkill. Or do you have the numbers to show regarding the huge size of Tirana, or the big important economy of Albania, or the millions and millions of tourists visiting every year? Mind you, at 200 pax/aircraft, 3 roundtrips/day per aircraft, with 19 aircraft that is a capacity of almost 12,000 seats/day each way. Or if you want, over 4 million seats/year, per way. So, do you have the numbers for that? ...continue please...
I'll help you out: in 2019, there were 2.9 million foreign visitors to Albania for leisure purposes. However, most of them came from Kosovo, Macedonia, Montenegro and Greece, in that order, so they didn't fly in. That same year, according do its Wikipedia page, Tirana Nëne Tereza Airport has 3.3 million passengers in total (arriving, departing and transferring, in total). So, assuming every passenger arrived and departed (or the other way around), that's less than 1.7 million people actually travelling, or less than half the capacity WizzAir is throwing at the airport, only counting aircraft based there. Plus all other airlines operating there, of course....
Well, let me help you there. How many tourists were in Albania in 2017, what about 2018? Now, how does the growth look like? See where I'm going with this? The growth at TIA is not due to the diaspora. After all that doesn't grow steadily. I'm not saying that the new routes don't have any VFR on them, but they need more than just them to support them. Otherwise, how does WAW or AUH work?
Albania is the only country in Europe showing growth on the 2019 numbers. Now you can say it's all due to the diaspora, or you can stop letting your biases cloud your judgment and realise that tourism in Albania is skyrocketing. Part of that success story have no doubt been the lower airport fees and fares. Two years ago there were no W6 aircraft based in TIA, this summer there will be nine. What's so strange to believe that there could well be 19 in three years. No, Albania is not going to be Croatia or Greece in 2025, but enough with this bs that only Albanians go to Albania. After all the numbers speak for themselves.
TIA wrote:Blerg wrote:MalevTU134 wrote:If this was in reply to my post, then I'm still awaiting your factual reply to it. And WizzAir are (in)famous for announcing new destinations, new bases and base increases that then don't materialize, so we shall see how much of this actually survives the news release stage.
The airport is run by a private company which did introduce lower fees, which until then had been significantly higher than in neighbouring airports. But no, this private company is not paying airlines to fly there, unless I'm missing anything on how private entrepreneurship works. They're also expanding the airport, so obviously whatever they're doing is working.
And if it was all about W patterns, then why not keep the planes in SKP or BEG, especially since they were already there. It's not like the crews in Albania are being paid less than in those countries.
MalevTU134 wrote:But, as has been pointed out by another poster, the fact that these aircraft are based in Tirana doesn't necessarily mean that they will only fly flights to/from Tirana, but could do W patterns or circle flights (for example TIA-WAW-LTN-BGY-TIA). The fact that they're based in Tirana could be due to the cost benefit of doing so.
MalevTU134 wrote:TIA wrote:MalevTU134 wrote:Why, is he incorrect in any way? On a European scale, it's an observation that is spot on. To have 19 aircraft based there,
I suggest you re-read my post...and indicate to me where I stated anything that even resembles "only Albanians go to Albania"? Of course there's tourism to Albania. And rightfully so; it's a delightful country. But as I pointed out, current total departing (or arriving) passengers total no more than 1.7 million (tourists + VFR) per year. WizzAir would unleash capacity that is 250% of this. In only 3 years' time, as you pointed out. There's no way international tourism in Albania will increase by that number, or more, in 3 years. You wouldn't even want that to happen, it would wreak havoc on the tourism infrastructure. Hence my initial skepticism. But, as has been pointed out by another poster, the fact that these aircraft are based in Tirana doesn't necessarily mean that they will only fly flights to/from Tirana, but could do W patterns or circle flights (for example TIA-WAW-LTN-BGY-TIA). The fact that they're based in Tirana could be due to the cost benefit of doing so.
TIA wrote:MalevTU134 wrote:TIA wrote:Well, let me help you there. How many tourists were in Albania in 2017, what about 2018? Now, how does the growth look like? See where I'm going with this? The growth at TIA is not due to the diaspora. After all that doesn't grow steadily. I'm not saying that the new routes don't have any VFR on them, but they need more than just them to support them. Otherwise, how does WAW or AUH work?
Again look at the growth trajectory. Why are you fixating on the 2019 numbers in isolation? In 2019 there were ZERO aircraft based there, this year there will be NINE! Look also at the 2021 numbers. It's a bigger feat going from zero to nine in two years in the middle of covid, then from nine to 19 three years from now. You're speaking of this growth as impossible when it's already been happening. As I said, Albania has been surpassing its 2019 numbers, since last July. The only country to do so. Kosovo is the only other country that comes close to it. TIA in the first two months of this year has surpassed even BEG, despite having no transfer passengers.
Regarding your last question, yes the bases in other countries like Serbia and N Macedonia have been scaled down in recent years with capacity being transferred to new bases like TIA. So TIA must bring in more than just cheap labour to justify moving aircraft over. After all, there is no pilot pool in Albania for W6 to take advantage of. They need to transfer staff over from abroad. And that's not dirt cheap. Anecdotal, but some of the highest paid people on the govt payroll in Albania are the foreign pilots of Air Albania.
