VS4ever wrote:iyerhari wrote:VS4ever wrote:Well while they have jettisoned their TATL operation to E (with the exception of DUB), they have 20 gates available. A1 is still used for Westjet I believe for the most part.
So if you assume 10 turns a day off of that, then you are looking at a max of 200 per day. Realistically probably around 180 to 190. Even though the European operation is growing its not really big enough for banking. I mean you can argue that a bunch go out at around 4 to 5 and another from 7-8 with a few stragglers but I would hardly call that banked.
Connections are a little more complicated than normal as you would arrive domestically at A and have to walk over to E to reclear security (via Central Parking walkways) takes about 10 minutes and Vice versa on the way back. It’s far from seamless but BOS isn’t the only place that does that on the return, having experienced that at PHL where you go through immigration and then transfer to a different terminal for the domestic leg.
Hope that helps
Well, if you see this, for the DL expansion:
https://simpleflying.com/delta-air-line ... gest-user/This just shows that the ask is going to get higher - but I think the constraint has been available gate space and there just isn't enough to expand. At the end, Massport can maneuver with multi-million dollar Capex spend but that can only get so far. There is a limit or a ceiling to how much you can expand with the footprint. This just is not going to become ATL or a ORD where there was land available to construct or add to the footprint.
Interestingly, 4,042 equates to an average of 134 a day departures and with the current staffing issues etc, I can't see that getting to 180+ for a while yet and do DL really want to run an operation with every gate at 8-9 turns without International (which has ben discussed separately) still being in E, if it comes back to A, no way are they getting those kind of numbers unless they push the other gates to 10+, that's WN territory (who at BOS used to do 10-11 a day), so you are right Gate Space is absolutely limited, maybe they kick WS out of A1, and grab themselves another 8-9 there, but they are going to be constrained, the only way from there is to go from frequency to size of plane to grow.
You beat me to the math. I wonder if part of the problem is the size of the planes - those 321s and 739s can pack a lot of people in, but it makes it a lot harder to do quick turns.
I also noticed that some of my precovid regular routes that frequency is still not fully returned.
ORD is running 3 flights a day when it used to run 5.
SEA is running 2 when it used to run 3
CMH is running 2 when it used to run at least 3 and sometimes 4
No surprises, and maybe they don’t return given BOS is already driving 15% growth in seats out of BOS. However, the int’l expansion could account for a lot of those seats. Just the TLV and ATH flights at 3x per week account for close to 7k seats per month.
Based on the airfare on ATH, I wouldn’t be surprised if they bump that to 7x/week next summer. Sounds like demand for that flight is exploding. TLV isn’t doing too poorly either - economy tickets between 1500 and 2000. Terminal E can handle two more 333/339s every night, right?
