  • 1
  • 2
  • 3
  • 4
  • 5
  • 9
Noshow
Re: Boeing confirms higher gross weight 787-10
Wed Jan 05, 2022 5:19 pm
Not really as parts previously made/stuffed in Charleston no longer have to be transported to 2 a second assembly line & efficiencies of not having to sets of final assembly workers will more than make up for the commonality issue.
Are the production problems solved? Is the existing fleet repaired? As long as deliveries are paused any talk about efficiencies feels premature.
Opus99
Wed Jan 05, 2022 5:24 pm
The aim of consolidation was for efficiency
rbavfan
Wed Jan 05, 2022 5:27 pm
Opus99 wrote:
I only see this as a good thing for the -10. It makes it more marketable and I think customers are asking for it. Let’s see what Boeing goes but even the 6T upgrade is good. 5500NM to 6000NM with full load is good and covers most routes. It becomes a question of asking customers do you need the extra capabilities of the 350? But matching the 350-900 in capabilities is not worth the money if you can do just enough to reduce its USP. I agree with revelation they should throw in a PIP though. But depends on the engine manufacturers
It also pushes the 787-10 closer to the 777-200ER range that BA & UA are both interested in. BA has to be interested in the -10 . It will be able to cover all their current 777-200ER routes they have in operation at lower cost. With the A350-1000 being able to replace the older 777-300ER it could remove a airframe type & improve crew ops.
Opus99
Wed Jan 05, 2022 5:35 pm
Exactly. I see it making a strong case at BA, UA and KLM. All of which have strong 200ER fleets. Maybe even AA?
Also the MTOW increase should help is hot conditions performance. So I would expect Saudia to acquire more as they are in talks for more widebodies
Sooner787
Wed Jan 05, 2022 6:19 pm
I'm betting AA would pony up for these as ideal 77E replacements.
the 78J would look great in AA colors :)
oldJoe
Wed Jan 05, 2022 6:35 pm
I understand that BA and UA have strong 777-200ER fleets but KLM ? Even AF has more of them in fleet and I remember Ben Smith saying : At AF in the future the A350 will be the biggest aircraft ! Let`s not forget the last order he made for the group and how he think about ........ ?
Opus99
Wed Jan 05, 2022 6:49 pm
The 350-1000 is still bigger than the 787-10.
KLM already operates 5 787-10 with another 10 on order
enzo011
Wed Jan 05, 2022 6:52 pm
Rifitto wrote:
The -10 has 214 order not 123 ,and that's pretty good for a simple derivative that share +90% with it's smaller siblings ,
it entered services 3 years ago ,
61 frames delivered is not bad considering the pandemic and the production issues
Boeing lists 123 unfilled orders for the 78X and 61 delivered. They list 214 ordered, so I guess we need to settle on 184 ordered and delivered so far? I am not sure if the 214 ordered excludes cancellations or ASC 606 on the books.
oldJoe
Wed Jan 05, 2022 6:53 pm
Why you mention the A350-1000 ? AF/KLM group does not have any A350-1000 on order to start with.
Opus99
Wed Jan 05, 2022 6:57 pm
I’m just saying when Ben says A350. He could also mean the 350-1000 as well.
If he means only the 350-900 then he’s wrong because KLM operates 5 787-10 with 10 on order for a total of 15 by 2025
Max Q
Wed Jan 05, 2022 7:13 pm
If this new 787 variant can match the A359 performance that will be the end of the latter’s prospects at UA
Opus99
Wed Jan 05, 2022 7:14 pm
I don’t think it can match it but it can make the 359s use at United extremely remote to the point where it does not make sense to acquire them
oldJoe
Wed Jan 05, 2022 7:17 pm
Why he is wrong ? He told at AF the biggest aircraft will be the A350 !!! I`ve heard of insiders of the group that they are not really happy with the actual situation how Boeing is handling it.
By the way AF is replacing 777-200ER`s with A350-900`s for a reason
Opus99
Wed Jan 05, 2022 7:26 pm
You don’t need insiders to tell you that. It’s been reported. And of course they are not. Boeing keeps delaying their Remaining 787s. BTW. The same ben smith recently eluded to ordering more 787s from Boeing to replace the a330-200s at Air France. They love it.
Now. That’s at AF. At KLM the biggest aircraft is obviously the 787-10 and the 787-10 is bigger than the 350-900. I think you misunderstand me. As a whole group. The 787-10 will still be the biggest aircraft if they retire the 300ER and do not order the 350-1000
oldJoe
Wed Jan 05, 2022 7:46 pm
And what tells you they don`t order the -1000 ? It only makes the 787-10 more attractive in your opnion ? Wishfull thinking at the best
Opus99
Wed Jan 05, 2022 7:48 pm
I’m not saying they won’t. I am saying that Bens statement on the A350 being the biggest aircraft in the fleet will depend on if they order the 1000
Taxi645
Wed Jan 05, 2022 10:33 pm
https://leehamnews.com/2022/01/05/hotr- ... more-38199
According to LNA:
- 787-9HGW as well
- no increase in empty weight or thrust.
Seems MTOW increase will be limited but welcome none the less.
tomcat
Wed Jan 05, 2022 10:36 pm
If you consider the MTOW - and I think it's a reasonable metric - the A359 is a bigger aircraft than the 787-10. And what about the max payload?
Opus99
Wed Jan 05, 2022 10:47 pm
“Here’s what Boeing is sharing today:
787-9 and -10 additional capabilities with Increased Gross Weight
More range and payload for both 787-9 and 787-10
Complete operational commonality with existing 787 fleet and family, with no additional empty weight or thrust changes
787-10 comparisons with increased capabilities:
777-200ER replacement with the same range, up to 42 extra seats, and more than 25% better fuel per seat
Even larger payload advantage over A350-900, along with 19 more seats, 2% lower trip, and 8% lower per-seat cost
60 more seats, more than 20% more cargo, and the same range as the A330-900, with 17% lower operating cost per seat”
Boeing is saying that the -10 will match the range of the a330-900
And the -9 will have 1000 nautical miles higher than the 330-900
“Here’s what Boeing released to LNA:
787-9 comparisons with increased capabilities
20 more seats and 1,000nm more range than A330-900, with a 12% lower operating cost per seat
8% lower trip cost vs. the A350-900, with 400 miles more range”
Opus99
Wed Jan 05, 2022 10:49 pm
If Boeing says they’ll match the range of the 777-200ER that is a massive bump without increasing the empty weight? Wow
DavidByrne
Wed Jan 05, 2022 11:07 pm
rbavfan wrote:
Opus99 wrote:
Revelation wrote:
I don't have all the info so answering questions with questions is about the best I can do.
Will a MTOW bump that adds a few hundred NM to the 787-10's range change its competitive position much if at all? My guess is no. Maybe it gets a check mark for ANZ's TPAC use case, but how many more use cases or potential wins are in the queue?
If it is a pre-cursor to an engine PIP or half-generation "leap", why not do both at the same time and avoid tying up FAA resources till you have something that can really change the competitive balance?
Could the engineering or regulatory resources be applied to anything that could improve the MAX's competitive position? A MAX-10ER would move the needle more than a 787-10ER, IMO.
I have a feeling no more can be gotten out of the MAX in general.
Customers may be asking for the bump. It could very well be coming with an engine PIP. We don’t know. That would be for engine manufacturers to let us know. There is definitely a PIP in-line for the GENx it may be part of the reason ANZ chose GE over RR. But it only improves the competitive landscape. How many more business? Well it’s better than no business.
On thé other hand, a pip also depends on the engine manufacturers appetite to put more money into a widebody engine at the moment.
ANZ changed engines during the RR engine issues. It had zero to do with a pip. IIRC ANZ noted that was reason for the change & ANZ was not the only one that did that.
My recollection of what the airline said at the time of the change was that the GE powered aircraft had a slight range lead over the RR-powered, and NZ needed that for the (now-delayed) AKL-EWR route, which is stretching the 789's capabilities to close to the limit.
Opus99
Wed Jan 05, 2022 11:18 pm
Okay so. Let’s look at the merits of that.
Boeing has release some figures but nothing specific yet. Probably closer to EIS they will.
But the 787-10 will match the range of 200ER and 330-900.
No increase in empty weight and no thrust change.
Jon Ostrower said MTOW bump and fuel modifications.
On thé topic of pavement loading. The 787-9 or -10 according to Leeham can go up by about 15 tonnes and will have lower pavement loading than the 300ER
“Can the 787-10 landing gear take the extra load? The gear itself with wheels can be beefed up, it’s not a problem. It’s rather the pavement loading from a heavier aircraft which is problematic. Boeing documents show there is some margin for the 787-10 pavement loading before it reaches the values for 777-300ER and the new 777X. But it will mean the apron and taxiway restrictions for the 777-300ER will also apply for a 787-10ER.“
LAX772LR
Wed Jan 05, 2022 11:26 pm
And lest anyone forget, the A339's range is now at 7,200nm... the same as a 744's!
ElroyJetson
Wed Jan 05, 2022 11:33 pm
If true, the 787-10 will be a very formidable aircraft. I could certainly see AA ordering down the line as a 77E replacement. Ditto BA. I think the threshold might be flying a 38 ton payload 6,000 nmi. That would be full pax and bags with meaningful cargo.
tealnz
Wed Jan 05, 2022 11:47 pm
It will be interesting to see how Boeing gets to “400 miles more range” for 789 in comparison to A359. My recollection is that integral fuel volume for the 359 in ULR version is a lot higher than B789. And 359 has MTOW headroom to take advantage of it (especially after today’s of an MYOW increase to 283 tonnes). Any guesses as to the assumptions behind Boeing’s claim?
Opus99
Wed Jan 05, 2022 11:52 pm
Might be referring to the basic one that has a range of about 15K. The 787-9 listed range now is about 14K
LAX772LR
Wed Jan 05, 2022 11:54 pm
There's only seven -ULRs in commercial service (all with SQ) and a few government VIP versions (e.g. Germany) as well.
It's not a popular offering, as it requires the forward cargo bay to be sealed and therefore unusable. But there's so little reason for any other airline to buy one, as it's made largely redundant by this increase (and the previous) MTOW increases in the standard A359.
Heck, SQ has flown LAX-SIN now with the updated standard A359, longer than it did with the A359ULR.
lightsaber
Thu Jan 06, 2022 12:14 am
Please post respectfully.
Do not discuss other users.
Keep on topic.
tealnz
Thu Jan 06, 2022 12:33 am
Sure. My point is that I can’t see how the 789 can end up with a range advantage over the 359 under any reasonable assumptions. The 359 has a bigger and highly efficient wing, a lot more tank capacity and MTOW to let it take full advantage of the fuel volume. So let’s wait to see what assumptions sit behind the Boeing claim…
Polot
Thu Jan 06, 2022 12:44 am
So in other words…not an issue. Apron/taxiway restrictions really didn’t hurt the 77W, and a plane the size of the 787-10 will be sticking to major airports that see plenty of 77Ws anyways.
While I agree 100% with you that Boeing’s claim doesn’t really make a lot of sense, I will note that Boeing would probably argue that the ULR is a different variant not in competition with the 787-9 (which on some level makes sense, eg you can’t use the front cargo hold of a ULR) and would only compare against base A359 fuel capacity.
Cerecl
Thu Jan 06, 2022 1:03 am
Wouldn't surprise me if Boeing is comparing 789/7810HGW to 268T A350-900. In any event, we all know this kind of marketing comparison is meaningless when one uses the most favourable condition of its own product against the least favourable of its rival.
Revelation
Thu Jan 06, 2022 1:48 am
Taxi645 wrote:
https://leehamnews.com/2022/01/05/hotr-boeing-works-on-hgw-787-10-and-the-787-9/#more-38199
According to LNA:
- 787-9HGW as well
TFA says:
It’s known that Boeing committed in 2019 to adding some gross weight and range to the 787-10 to win an order from Air New Zealand. ANZ needs the boost for its US services and demand for cargo. ANZ is replacing its aging 777 fleet.
“As part of the Air New Zealand commitment to purchase eight Boeing 787-10s, Boeing and General Electric are increasing the maximum takeoff weight to add more range,” LNA reported in August 2019. It’s unclear whether the HGW version Deal told The Times about is this model or an even higher HGW. A Boeing spokeswoman said the company doesn’t discuss customer specifications, adding that the company isn’t ready to reveal technical details.
In 2019, LNA predicted Boeing would develop a 787-10ER (Extended Range) version, which is another way of saying High Gross Weight. In a three-part series, LNA’s analysis concluded Boeing could add 1,000nm to the advertised range of 6,430nm.
Earlier I was talking about having a hard time seeing how a few hundred NM would change the way we view the -10 very much if at all, but 1,000 nm is something that one could see as making a big change.
Ref: http://www.gcmap.com/mapui?R=6430nm%40AKL,7430nm%40AKL
ILikeTrains
Thu Jan 06, 2022 4:36 am
Great move to capture 77E & 77W replacements that will be needed very soon. This project has been going on a few years judging by the Air NZ order, and a few peoples Linkedin pages.
I’m curious what more will need to be done to get the 787 up to 260T and beyond. I imagine thrust increases, and possibly increasing wing dimensions to keep T/O performance from getting out of hand.
A 787-10ER would be a solid 77E replacement for that airframes major users (UA, BA, AA, etc) but would also be a great airframe for 77W users looking to downsize. A 787-9ER would make for an interesting ULH plane too.
Really fun to see Boeing working on projects instead of fixing mistakes.
Taxi645
Thu Jan 06, 2022 6:49 am
Again why are we hearing about a HGW version (which is obviously good news against the A350), but nothing about future proof engines? It's about the right time in the 787 life cycle to start hearing rumblings about it, it would fit in with the 77W replacement cycle, the 787 lower weight could make excellent use of it and future fuel cost and environmental concerns make it even more urgent.
The only explanation I would find reassuring is that the MTOW increase is indeed very limited, part of the range boost is from new engines but Boeing just does not wants to let anyone look into their cards yet.
I hope that is the case, but I am a bit sceptical on that.
NZ321
Thu Jan 06, 2022 7:19 am
zeke wrote:
Opus99 wrote:
I asked you for their ATO announcement. Since that’s what you asked me for. Not whether they exist.
Airbus had formally published the new figures, the link to the Airbus document was given in the OP of the thread three years ago.
Opus99 wrote:
Boeing did not mention any figures.
We have had multiple threads on this topic over the past 3 years with conspicuously little corroboration of the sort you would expect if Boeing was talking to airlines generally about this.
Nothing has been published by Boeing, yet I can point to where Airbus has published specifications for their yet to be certified weight variants.
Last year we discussed on this site the NZ results and the fleet plan contained therein. There was a very real possibility in that document that 787-10s may never enter the NZ fleet. We also had a thread discussing the possibility of NZ replacing their 77Ws with 787-9s.
Fully endorse your comments Zeke. I was one of the contributors expressing concern about the lack of detail on the up-spec 787-10.
XT6Wagon
Thu Jan 06, 2022 7:21 am
Economics on the engines is why you aren't hearing about it. I expect they are still paying off the costs in designing and certifying the engines for the 787. Certainly not looking to dump a billion or more into capturing the market they already have.
That said, continuous improvements that can be put into packages to sell to existing customers for engine rebuilds and new engine sales will remain popular with engineers and bean counters alike. So 2025 787 will be better engine side than 2015 787 left the factory with.
Taxi645
Thu Jan 06, 2022 7:43 am
Yes, but will it be enough? Higher fuel cost will mean an efficiency advantage in the future will provide a larger competitive advantage. If your competitor does upgrade and you don't you are in even bigger trouble than you used to be. Bad luck you spend a lot in the past, but airlines will choose what is the cheapest to run and if your offer is not competitive, customers will increasingly look elsewhere.
Quite interesting that Airbus has postponed EIS of the ultrafan and Boeing is being silent on their future engine plans for the 787, while future SAF paying airlines and the world in general are strongly needing the opposite. A strange dissonance in my book.
FluidFlow
Hot performance and high performance have nothing to do with MTOW. It is limited by lift and thrust. You need more thrust to reach take off speed (assuming you have the same runway lenghts) or you need a bigger wing to be able to take off with less speed as you thrust is lower due to the conditions.
So if the -10 can not take off at MTOW due to hot/high, increasing MTOW will not help at all. So if the -10 does not perform well in hot/high, the 10ER will be even worse if you look at the ratio of possible take off weight vs MTOW in hot/high.
Taxi645
Thu Jan 06, 2022 7:46 am
Unless they also use a larger wing of course like the one originally planned for the 9.
tommy1808
Thu Jan 06, 2022 7:50 am
essentially not being able to take off at MTOW from anything but a runway at sea level if it got even mildly hot didn´t stop the 77W from selling like fresh bread though. Not even to airlines with hubs where it tends to be hot.
best regards
Thomas
FluidFlow
Thu Jan 06, 2022 7:54 am
best regards
Thomas
No argue with that, I just wanted to state that a simple MTOW increase will not in any way help the performance of the aircraft. The marketability increase is huge and a great move from Boeing. It will still not increase the performance in hot/high though.
Stretches without thrust/wing increase tend to have worse performance. Hence why the 77L was used for hot/high if the 77W could not fly a meaningful load.
MileHFL400
Thu Jan 06, 2022 8:26 am
I think this title is a little misleading. Has Boeing actually officially offered this product to buyers or is this just internal speculation?
Revelation
Thu Jan 06, 2022 4:23 pm
I think an increase in wing dimensions would help, but of course it's very costly. It's interesting to me to see how 767 and A321 gained so much thrust over their life spans yet did not change the wing dimensions much if at all. It seems A321 re-designed the high lift devices a few times from -100 to XLR. I don't know if such an option would exist or be helpful for 787. One does also wonder if the original designers put any time into studying what they could do to help enable future HGW options.
morrisond
Thu Jan 06, 2022 4:29 pm
I think I recall that the wing is good for 280T - I think that came from Lightsaber?
Taxi645
Thu Jan 06, 2022 4:35 pm
You have what the wingbox can bare and what provides efficiency at the higher end of TOW capability. It may be able to carry 280T, but doesn't mean you will be competitive against a 65m wing with significant winglets.
At a certain point, to fly efficient enough and thus be competitive you will need a larger wing(span).
rbavfan
Thu Jan 06, 2022 5:31 pm
The fwd cargo hold has to be blocked if it's configured in the SQ layout. All those Suites take add a lot of dead weight fwd. Adding cargo with them is the issue. T-O weight increases with standard seating could easily increase range.
LH707330
Thu Jan 06, 2022 5:40 pm
IINM the A321 only had the one change to the XLR layout, but I stand to be corrected. The 767, meanwhile, was a bet on bigger engines coming along to make the platform more sellable in larger versions. That obviously paid off for the 300ER.
Regarding the wing dimensions and relative optimality of the wing size, keep in mind that most of the 359 and 78X fleets are probably being used on 3-5k nm routes 90% of the time. I've read that the tradeoff point between the "78X better" to "359 better" scenario is somewhere around 4k nm (though that shifts around with engine PIPs and whatnot), beyond which the 359's bigger wing pays for its weight in better aero. As such, having a 78X that can pinch hit on a longer segment like 6k nm with worse fuel burn than a 359 is still a better buy if the remaining 90% of the network is <4k nm.
Another thing to keep in mind when comparing brochure ranges of newer aircraft with older ones is the slope on the payload/range curve. As planes get more efficient, the slope shallows out, meaning you lose more range when you take out a tonne of fuel to fit an additional tonne of cargo. It's worth pointing out that the range at MZFW for many of the newer dedicated long-haul types is still in the 5500-6000 neighborhood, although the brochure range had crept up.
meh130
Thu Jan 06, 2022 6:23 pm
The 787-10 has more underfloor cargo volume than a 747-8i. An increase in MTOW could benefit the air cargo side of passenger airlines.
JohanTally
Thu Jan 06, 2022 7:54 pm
It's wild to think that the 26 foot shorter aircraft would have a larger cargo hold, the 747 must really taper and not utilize the full length of the aircraft. I wonder if the limited operators of the 748i ever have cargo capacity constraints during normal non-pandemic operations?
Polot
Thu Jan 06, 2022 7:58 pm
The 747’s wing and multiple main landing gear do it no favors in the underfloor cargo department.
  • 1
  • 2
  • 3
  • 4
  • 5
  • 9
