panam330
FedEx Requests Approval to Install Anti-Missile Laser Systems
Fri Jan 14, 2022 7:11 pm
https://gizmodo.com/fedex-asks-faa-to-let-it-install-anti-missile-lasers-on-1848361044
https://public-inspection.federalregister.gov/2022-00505.pdf
FedEx has filed with the FAA to install anti-missile systems onboard A321-200 aircraft. But it doesn't have A321s, unless I missed an order for some P2Fs...
Reason: Title updated
Newark727
Re: FedEx Asks the FAA to Install Anti-Missile Systems
Fri Jan 14, 2022 7:13 pm
Installing systems for a third party perhaps?
GalaxyFlyer
Re: FedEx Asks the FAA to Install Anti-Missile Laser Systems
Fri Jan 14, 2022 7:15 pm
All rather strange, FDX doesn’t own A320s, no apparent threat updates.
panam330
Fri Jan 14, 2022 7:16 pm
GalaxyFlyer wrote:
It’s Gizmodo.
Yes, agreed, but there's an attached FAA filing in my post (also in the Gizmodo article) that repeatedly states A321s.
UPlog
Fri Jan 14, 2022 7:25 pm
FedEx has been testing various IR anti-missle systems for more than a decade including deploying it on an MD-10
https://en.m.wikipedia.org/wiki/Northro ... n_Guardian
We've had discussions about it in previous threads over the years.
I would not read anything into the A321. Likely just want to get STC approval, same they did for the 747 which FedEx does not operate either.
MO11
Fri Jan 14, 2022 7:38 pm
:checkmark: Yes.
majano
Fri Jan 14, 2022 7:49 pm
MO11 wrote:
:checkmark: Yes.
Would FedEx be the best party to install such a system? Either for themselves or a third party? Is it not better perhaps if a military systems integrator such Lockheed or even Boeing does the installation?
FLYFIRSTCLASS
Fri Jan 14, 2022 8:05 pm
IIRC didn't AA do a trial experimental anti missile system on a 767 around 2010?
32andBelow
Fri Jan 14, 2022 8:59 pm
majano wrote:
MO11 wrote:
:checkmark: Yes.
What’s the difference? Are the mechanics and engineers at FedEx worse?
WeatherPilot
Fri Jan 14, 2022 9:28 pm
It’s likely FedEX wants them installed for potential use throughout other less civilized parts of the world but needs the FAA’s blessing in order for the planes to operate in the US when not in those otherwise less civilized parts.
wjcandee
Fri Jan 14, 2022 9:29 pm
32andBelow wrote:
majano wrote:
MO11 wrote:
:checkmark: Yes.
The difference is that a military integrator would charge 10 times as much, just because that's who they are. Nothing wrong with FedEx doing this as a side business.
SteelChair
Fri Jan 14, 2022 9:36 pm
:checkmark:
And holding other contractors accountable.
GlobalAirways
Fri Jan 14, 2022 11:15 pm
They should have it for flights that go into more hostile areas. I would feel safer knowing my plane had extra safety features for these types of threats. Makes me think of the DHL incident over Iraq.
TheZ
Fri Jan 14, 2022 11:33 pm
Are they ill-tempered?
Fixinthe757
Sat Jan 15, 2022 12:28 am
32andBelow wrote:
majano wrote:
MO11 wrote:
:checkmark: Yes.
Talk about a can of worms youre opening there!! :rotfl:
AntonioMartin
Sat Jan 15, 2022 1:20 am
El Al has a similar system (if not the same actually)...If it wasn't so expensive, I would love to see more airlines add this to their airplanes...airlines from countries at war, for example...
JetBuddy
Sat Jan 15, 2022 1:46 am
A good Warzone article on this:
https://www.thedrive.com/the-war-zone/4 ... ermeasures
I find it interesting that they've specifically chosen the A321-200, not an A320 or 737.
Gemuser
Sat Jan 15, 2022 2:08 am
This is incorrect. They need FAA approval to install the system on "N" registered aircraft, to operate in any part of the world [AFAIK all their aircraft are N registered]. Theoretically they could have installed it on an aircraft registered in another country, with the approval of the authority in that country, and operate that aircraft in US airspace PROVIDED it was engaged in "International Civil Aviation", not US domestic service. I certainly can not think of any reason why they would do so but it is possible.
Gemuser
sxf24
Sat Jan 15, 2022 2:22 am
Especially since FX doesn’t have A321s?
32andBelow
Sat Jan 15, 2022 2:44 am
They prolly have a customer?
Spacepope
Sat Jan 15, 2022 3:02 am
Yes, clearly for all the A321s that FX flies all over “those” places. Oh wait…
Some of us old timers on the site distinctly remember the “FedEx Hushkit” for the 727that they developed and installed all over the fleet 30 odd years ago. They are clearly applying to install their new protective technology on aircraft for a customer. Dollars to donuts not even a freight customer.
DL_Mech
Sat Jan 15, 2022 3:09 am
From what I understand, once FedEx is the STC holder of this system they will get paid each time this system is installed on a A321 installed by an airline or MRO.
I remember when Delta traded all of their A310-200s to FedEx in exchange for 727 hushkits. It was a win-win for both companies.
JetBuddy
Sun Jan 16, 2022 2:45 am
Obviously.
That's why I'm wondering who it's for.
Has FedEx done aircraft modifications for external customers since the 727 hushkits?
Francoflier
Sun Jan 16, 2022 2:54 am
FX A321-200 P2F?
:duck:
astuteman
Sun Jan 16, 2022 10:21 am
32andBelow wrote:
majano wrote:
MO11 wrote:
:checkmark: Yes.
There are usually a lot of differences between Military Engineering and Commercial Engineering that are usually nothing to do with the "engineering" per se, but the uniqueness of the requirements and standards applied to Military hardware, that are fundamentally different to commercial standards, and amongst other things usually lead to a much more difficult and complex (arcane) supply chain and supply solutions.
For most commercial businesses, setting up a business architecture to cope with these differences for a niche, small volume business stream is prohibitively expensive. Which is why you typically get an "either-or" in the supply chain - either dedicated to military work, or dedicated to commercial work.
I would be wary of underplaying the complexities of a commercial firm playing in the military environment. That path is minefield
USAirKid
Sun Jan 16, 2022 11:16 am
This is a good point. It's also shown in Boeing's civilian derived military planes. While the 737s and 767s are unique builds for the military, BCA first delivers the plane to Boeing's military arm, then Boeing military finishes outfitting the plane before it is delivered to the customer.
bluecrew
Mon Jan 17, 2022 10:12 pm
Obviously.
A321s that need missile defense.
Arkia jumps to mind here!
panam330
Mon Jan 17, 2022 10:36 pm
Funny, I was thinking MEA myself, if indeed FedEx didn’t inadvertently reveal future fleet plans. Though with the financial state of Lebanon and the companies within, who knows about that one.
