Heavierthanair wrote:I take it the max. payload will be in the area of 115 - 125 tonnes. But being considerably heavier than the A350F the fuel consumption will also be proportionally higher, reducing potential max. range and raising operating i.e. tonne per kilometer costs. Plus it comes at a higher initial investment. Time will tell if it will be able to carry a 109 tonne load as far as an A350F. All assumptions thus far, all we can base this on is on the respective passenger versions until we have detailed specs
744SPX wrote:If they keep it at 778 length, they will have no problem with 120t at 5000nmi. They stretch it by 13' to 773 length and it will cost them. I don't see how the extra space would be worth the extra OEW. 12-15t (I'm guessing) for that kind of a stretch, and that's going to come right off max payload. To compete best with the A350 it should be focusing on max payload rather than max volume.
I mean jeez, the 778 is already a 20' stretch over the 772.
B777LRF wrote:The most basic of problems is that we don’t know which frame it will be based on or, indeed, if they’re going to opt for a “-8,5” length. However, with a much heavier frame they need a considerable volume and payload delta to the A350F, so with that in mind I’d inclined to go for the -9. Payload will need to be in the 120-125 tons bracket, so we can start calculating back from that
It might come out with an OEW of 160-165 tons. 120 tons of payload and 5 tons minimum fuel would require a MZFW of 275-280 tons and a MLW of 280-285 tons. It should be able to go for 11 hours / 5000NM at MZFW, which is around 80 tons of fuel and equals a TOW of 360-365 tons. Which are all big numbers, and I’m not sure (for any number of reasons) they are realistic.
For a -8 based solution, reduce OEW, MZFW and MTOW by 10 tons, keeping max payload at 120-125 tons but with 4 fewer positions on the main-deck. While that presents a sizeable max payload advantage over the A350F, volume wise there’s not much daylight between them, and with a heavier frame and all the costs that comes with that, it’s probably not that competitive. The numbers seem more achievable though.
For a “-8.5" everything would be somewhere in the middle of the two, and that might actually be the sweet spot.
Not an easy nut to crack.
morrisond wrote:Heavierthanair wrote:I take it the max. payload will be in the area of 115 - 125 tonnes. But being considerably heavier than the A350F the fuel consumption will also be proportionally higher, reducing potential max. range and raising operating i.e. tonne per kilometer costs. Plus it comes at a higher initial investment. Time will tell if it will be able to carry a 109 tonne load as far as an A350F. All assumptions thus far, all we can base this on is on the respective passenger versions until we have detailed specs
It has a bigger wing and more efficient engines - the fuel burn my not be hugely different, and if it lifts more Tonnes - the Tonne per kilometer could be better.
We have no idea what the actual transaction prices are. All we think we know is that the A350 is expensive to build. The 777X may not be as expensive to build and hence why it is so much heavier - as its probably using heavier but less expensive materials and the new wing factory could have removed a lot of labour costs as it is so automated.
flipdewaf wrote:morrisond wrote:Heavierthanair wrote:I take it the max. payload will be in the area of 115 - 125 tonnes. But being considerably heavier than the A350F the fuel consumption will also be proportionally higher, reducing potential max. range and raising operating i.e. tonne per kilometer costs. Plus it comes at a higher initial investment. Time will tell if it will be able to carry a 109 tonne load as far as an A350F. All assumptions thus far, all we can base this on is on the respective passenger versions until we have detailed specs
Whilst it may be more expensive to have the lighter materials it doesn’t then hold true that because it’s heavier it indicates less expensive. The 777X is heavier because it’s bigger, there may be some other factors but those are just noise.
The cost of the airframe is driven primarily by the weight and the manufacturing rate. If an aircraft (or any other product for that matter) has common parts the particular parts have a cost associated with the manufacturing rate of that part, likewise for low rate parts. This is really where the 35k suffers and the 789 and 10 shine.
The bulk of the performance is relatively easy to model/calculate/estimate however there is an anomaly in the 777 lineup and depending on how that turns out will make a big difference as to how the 77XF performs.
The anomaly is the weight of the 777f. We would normally expect that the deletion of the pax cabin and associated ancillary equipment as well as the window belt and safety equipment to give a significant reduction in the empty weight of the aircraft. For the 777f we would expect this weight change to be much higher than it is suggesting that there were structural changes required which normally aren’t. I think it’s reasonable to assume these could be to do with floor strengthening as the original 777 floor was not great for the high loading required for a freighter. How well the 77XF handles such changes may determine the overall empty weight and therefore overall performance.
The empty weight estimates I use have it 156-171t based on the above uncertainty.
Fred
Sent from my iPad using Tapatalk
morrisond wrote:The 779 has an MLW of 266T. That grew by 15T over 77W. A350F is also about 14T over A351, at 250T.
77F has a MLW of 261T. Something around 275-280T doesn't seem impossible especially if they do bump the MTOW and beef up the structure.
What is the OEW weight? That is the hardest to figure out. A350F seems to be about 135T (250T MLW - 109T Cargo, minus Crew/minimum Fuel, 77F is 144T, 779 is rumoured to be somewhere between 180-195T.
zeke wrote:morrisond wrote:The 779 has an MLW of 266T. That grew by 15T over 77W. A350F is also about 14T over A351, at 250T.
We have been given a few data points here.
Leeham says the A350F OEW is 30 tonne below the A350-1000, that makes it around 125 tonnes.
“ the aircraft is shortened, a whopping 30t is removed from the empty weight of the A350-1000.”
From https://leehamnews.com/2021/11/11/airbu ... fications/
Airbus has said an OEW 37 tonnes lower than the 744F and 13 tonnes lighter than the 77F
From https://aircraft.airbus.com/en/a350f
The A35F must OWE to be in the range of 125-129 tonnes based off those figures, which puts MZFW at around 238 tonnes which is pretty close to what it is on the -1000.
For the 77F OWE I used the Polar payload of 105,233 kg ( https://www.polaraircargo.com/wp-conten ... 319-v2.pdf) and MZFW of 248115 kg, OWE of 142882 kg. That also fits with the A35F payload being 3 tonnes more than the 77F.
So in summary A350F
OEW 125-129,000 kg
MZFW 238,000 kg
Payload 109,000 kg
MLW 243,000 kg
MTOW 317,000 kg
Now for the 77XF starting at the 77F base (Polar)
OEW 143000 kg
MZFW 248,000 kg
Payload 105,000 kg
MLW 260,000 kg
MTOW 348,000 kg
Now for the 77XF at 125,000 kg of payload
OEW 163,000 kg
MZFW 288,000 kg
Payload 125,000 kg
MLW 294,000 kg
MTOW 351,000 kg
If the 77XF was increased to a MTOW of 360 tonnes, that puts it at a 43,000 kg (95,000 lb) higher MTOW.
Is this reasonable ?
The 744F to 748F saw an increase of around 20 tonnes of payload
744F 112,000 kg https://www.atlasair.com/wp-content/upl ... 012418.pdf
748F 132,000 kg https://www.atlasair.com/wp-content/upl ... 012418.pdf
A350F 77F 744F 748F 77XF
OEW 129 143 180 206 163
MZFW 238 248 293 338 288
Payload 109 105 112 132 125
MLW 243 260 302 346 294
MTOW 317 348 396 447 351
I think MTOW of the 77XF needs to increase a lot to have range with 125,000 kg payload.
B777LRF wrote:I think Boeing might have some challenges reaching the maximum weights estimated. MZFW can be traded off against MTOW, sacrificing range. But otherwise it’s tough number to raise, as it’s governed by the strength of the wiwgbox. Beefing up that structure is of course possible, but it increases the OEW and starts eating into the maximum payload.
MLW is a bit easier to deal with, essentially requiring a stronger gear and brakes. Which again increases the OEW, but it’s relatively easy compared to the MZFW.
The MTOW might actually be the biggest challenge. If memory serves me right the -300ER is already at the PCN limit, and it’s my impression the -8 and -9 will retain the more or less the same MTOW. Raising the MTOW from 350 tons to 365 tons would require larger tires and changes to the gear, which all adds to the OEW.
I don’t believe a 155T OEW, 350T MTOW -8F with a payload of 110 tons and a MZFW range of 5000NM is a viable proposition; range, volume and payload will be almost identical to the A350F, but with an aircraft that’s 15-20 tons heavier and requiring a MTOW that’s 35 tons more. That spells “stillborn” to me.
So with that in mind, Boeing do have some work cut out for them in order to create a much more capable platform in order to justify the large weight delta.
As for the market, the big orders are bound to come from the Big 3 integrators; Yellow, Purple and Brown. They like range, volume and low fuel burn - a fully loaded FX or DHL 777F or 747F bulks out way before reaching payload maximum. Would a large volume delta -9F solution be more attractive than a lighter and lower volume A350F? I don’t have a crystal ball that can answer that, but looking at the ordering history of Big 3 they are clearly much more into lighter, lower volume, longer range (777F) than high payload, high volume, shorter range (747-8F). Looking the the rear view mirror to gauge whether the next turn is to the left or wright is wrought with danger, and I for one wouldn’t care to guess which way the market will move.
DenverTed wrote:What if they go in the other direction with a -9F or -10F, and go for maximum volume at lower densities? 250' or 260' length with a 365 MTOW and 120t payload and reduced range at full payload.
744SPX wrote:DenverTed wrote:What if they go in the other direction with a -9F or -10F, and go for maximum volume at lower densities? 250' or 260' length with a 365 MTOW and 120t payload and reduced range at full payload.
I don't think it could have any meaningful range at that length and with 120t payload. At 229' (778 length), I think you could do 120-125 t at 5000 nmi.
I don't think they can go any longer than the -8X if they want to have a meaningful payload advantage over the A350 at similar range.
At -8X length you effectively get a 1-for-1 744ER replacement both in terms of max payload, cargo volume, and range. Any longer (773 length or more) and you will be sacrificing payload, and even then you can only use the extra volume by flying almost exclusively with low density cargo. No way can you guarantee every flight will be maxed out on volume, and so you are flying dead weight. It will be easier to max out volume and maximize revenue with the 229' version.
morrisond wrote:
All the extra weight in the 777X must be coming from somewhere.
FluidFlow wrote:What we know is, the 350F can no lift very heavy nor very much volume but it is really good overall. So if you need more payload or volume there are other options but if you just need something that is good enough for most missions it is the perfect aircraft.
FluidFlow wrote:Now it is up to Boeing and their customers to find a solution where to place the 777XF in the market. I tend towards payload because the volume part can be filled from 300ER conversions.
744SPX wrote:At -8X length you effectively get a 1-for-1 744ER replacement both in terms of max payload, cargo volume, and range.
AECM wrote:My feeling is that Boeing will target the B77XF to be closer to the B748F specs and therefore based on the -9 version.
B777LRF wrote:AECM wrote:My feeling is that Boeing will target the B77XF to be closer to the B748F specs and therefore based on the -9 version.
Agreed, that looks like the best option if they want to carve out a niche which isn’t already occupied by the much lighter A350F.
tvh wrote:It has already been said it will be based on the -8. For the -9 an even higher raise in MTOW would be needed to make good use of the extra volume.
B777LRF wrote:tvh wrote:It has already been said it will be based on the -8. For the -9 an even higher raise in MTOW would be needed to make good use of the extra volume.
True, but that was before the A350F came along and torpedo’d that idea.
Longer wing. The maximum loads carried in the wings fundamentally scale with (span^2 * MZFW) which means a 779x wing is dealing with approximately 30% higher loads than a 77W.
Fred
zeke wrote:AECM wrote:My feeling is that Boeing will target the B77XF to be closer to the B748F specs and therefore based on the -9 version.
The 779 main deck is about 483”/12.28m longer than the 77F. It should accommodate around 14 96x125 pallets below the deck and 35 contoured 96x125 pallets above deck, 49 total. The 748F is 12 below the deck and 34 96x125 contoured pallets above the deck, 46 total.
Even if it carried the same payload mass, the density would be lower than the 748F.
Fred
Yes - got it - I was being a little facetious, the other poster was asking if the Wingbox was stronger - and yes it is - which is what may allow the much higher required MZFW weights.
What do you guess it could lift?
par13del wrote:Seems to me based on a lot of post, folks already know its limitations within a fixed range based on what we already know of the 777X, so can they really design based on requirements, or will the user just have to adjust their requirements to fit what the a/c can do, somewhat like abusing a widebody frame on a narrow body route because a perfect a/c does not exist?
Opus99 wrote:It didn’t torpedo the idea. It might have changed the length but it won’t take it to the -9 length. Still in between the two
flipdewaf wrote:par13del wrote:Seems to me based on a lot of post, folks already know its limitations within a fixed range based on what we already know of the 777X, so can they really design based on requirements, or will the user just have to adjust their requirements to fit what the a/c can do, somewhat like abusing a widebody frame on a narrow body route because a perfect a/c does not exist?
https://1drv.ms/x/s!AiAyKIX6pnf6ij6DcBY ... h?e=bg5WNr
This was my best guess on performance that I put in a previous thread. Basically still holds.
If we assume the MZFW is somewhere between 11t higher (as in the 77W->77F) to 17t higher than the pax version (as in the A35k->A35F) then we can make some assessments on max payload.
If we take a low ball figure of 156t for the OWE and a high figure of 17t higher for the MZFW (272t)then we have a payload figure of 116t. If we go for the other end of the spectrum of 171t OWE and a low MZFW figure (11t increase) of 266t then we get a max payload figure of 95t.
I'm inclined to believe it'll be the top end of that.
Fred
JonesNL wrote:flipdewaf wrote:par13del wrote:Seems to me based on a lot of post, folks already know its limitations within a fixed range based on what we already know of the 777X, so can they really design based on requirements, or will the user just have to adjust their requirements to fit what the a/c can do, somewhat like abusing a widebody frame on a narrow body route because a perfect a/c does not exist?
Fred
So, in best case it’s going to carry 10% more payload with 20% higher OEW. Wonder what the fuel burn per ton will be…
I posted above my reasoning behind an OEW of 143 tonnes for the 77F based upon polar airlines published information, I do not think it is reasonable to suggest an OEW of 156 tonnes unless the fuselage was only around 5 meters longer than the 77F.
The fuselage alone I would suggest would be around 2 tonnes per meter, with heavier engines and heavier wing.
DenverTed wrote:If the 777-F and 777-200LR were about the same empty weight, the trade of removing windows for floor beams is about equal. The 777-9 empty is listed as 400Klb or 182t. If they go with a 230' fuselage, that shaves off 22' x 1500lb, leaving 367klb or 166t empty. At -300ER length to add another pallet, add 7t of fuselage and that goes up to 173t.
As pointed out in the above post, maybe lighter ribs at the window belt on the freighter.
Revo1059 wrote:Has B looked into adding a flip up nose like the 747Fs? Seems like that's a useful feature that will go away as the 747s do.
