JonesNL wrote:Mentioned in the 777XF Specification thread by Morrisond;
Boeings forecast predicts 500-600 planes to be sold in the 767F segment in the next 20 years.
That is quite a lot of metal for a derivative and the question is will either A or B develop a MoM with a freighter derivative. And what should an ideal 767F replacement look like?
Seeing the latest comments from Calhoun, the tech is not there yet to warrant EIS this decade…
reidar76 wrote:When the final 767F is delivered in 2027 there won't be any direct replacement available, is my guess. Some might not know, but it is the engines on the 767 (and the 777) that is so outdated that these aircraft will not be allowed for further sale. This has been know for quite some time.
It is only 5 years to 2027. Since neither OEM have announced any intention for a new freighter in this class, we can assume there won't be any direct replacement available when 767 production has ended. Production of the military tanker that is based on the 767-2C, the KC-46, might continue, but that is pending on Boeing winning the KC-Y competition against the Lockheed Martin LXMT (Airbus A330).
The only new built freighter that have been rumored is an A321F. A freighter derivative of the A321 might be available for sale in 2027, but it will be smaller and carry less than the 767F.
I think pax to freighter conversions, especially of the A330 and 777 will be what replaces the 767. Of these two, the A330 is closest in size to the 767, but still significantly larger. And of course there will be lots of A321 pax to freighter conversions.
I don't think Boeing will consider an 787-8F nor will Airbus consider an A330-800F.
UPS757Pilot wrote:More 767s. Boeing will lobby for relief from impending engine restrictions and may buy some time for a future engine option that is approved.
flyingclrs727 wrote:JonesNL wrote:Mentioned in the 777XF Specification thread by Morrisond;
Considering the 767 shares an assembly line with the KC-46, there are benefits to continuing to build 767F variants. If Boeing were to build a 767-400F reengined with the GEnx-2B67B used on the 747-8, the 767 could continue to be used as a freighter platform as it would meet the updated environmental regulations that will be in place at the end of the decade.
JayinKitsap wrote:flyingclrs727 wrote:JonesNL wrote:Mentioned in the 777XF Specification thread by Morrisond;
Yes the 764 has a higher MTOW, a bit bigger wing but still within the 767 size (by inches) but most importantly taller gear that has enough clearance for the GEnX-2B67B, this has about 10% more thrust than the current 763 engines. GE would love to sell more GEnX and end production of the older, this is basically the current GE engine on the 787 except a smaller fan. A stretch of the 763, with these engines it has a good match. As the 744 and the 763 used the exact same engines, much of the tech has been done.
It's a relatively low cost update that will fill in the line around the KC-Y, it might be the frame offered with the KC-Y as well. I don't expect this freighter to proceed until & unless Boeing wins the KC-Y. If they lose it, the 767 line will close.
reidar76 wrote:I find it highly unlikely at Boeing would spend a few billons reviving the 767-400. The 767-400 was a total flop, with only 37 aircraft delivered. It is now about 20 years since production ended. There are many parts that are -400 specific, parts that have been out of production for decades.
It doesn't make sense to: 1) revive a derivative of an aircraft that was originally designed in the 1970s, 2) invest in re-engine this old design, 3) start development of a freighter derivative of the revived 767-400 (flop) derivative, 4) spend years and several more billions trying to get the old thing certified. If Boeing would be able to pull that of, it would be about 50 years after first flight of the 767 this frankenstein monster would enter service. There isn't any future in that kind of investments.
And all this just to sell the 764F at a loss. The reason the 763F is selling, is because it is the cheapest thing available. This 764F thing would be very old and expensive.
ben7x wrote:reidar76 wrote:I find it highly unlikely at Boeing would spend a few billons reviving the 767-400. The 767-400 was a total flop, with only 37 aircraft delivered. It is now about 20 years since production ended. There are many parts that are -400 specific, parts that have been out of production for decades.
Why should a 767-400ER MAX F (= 767-500F or 767-8F ?) should cost „billions“ and „more billions“ of dollars? The A330neo has cost Airbus something around 1.5 billion dollars. If Boeing does the exact same - a simple re-engine - it wont cost „billions“ and „more billions“ of dollars.
And of course it would be quite old. But isn’t the A330neo also quite old? I mean its based on the A300/310… The 767 re-engine would play in a class, where age and efficiency are not really the number one problems (for now). So IMO, if they get KC-Y, a 767-500F or -8F is not very unlikely.
ben7x wrote:But isn’t the A330neo also quite old? I mean its based on the A300/310…
ben7x wrote:Why should a 767-400ER MAX F (= 767-500F or 767-8F ?) should cost „billions“ and „more billions“ of dollars? The A330neo has cost Airbus something around 1.5 billion dollars. If Boeing does the exact same - a simple re-engine - it wont cost „billions“ and „more billions“ of dollars.
Northwest1988 wrote:I may be overlooking something obvious…. But what about a 787F? Much closer in size to a 767 than a 777 and a proven aircraft that can meet all future emissions regulations.
reidar76 wrote:ben7x wrote:Why should a 767-400ER MAX F (= 767-500F or 767-8F ?) should cost „billions“ and „more billions“ of dollars? The A330neo has cost Airbus something around 1.5 billion dollars. If Boeing does the exact same - a simple re-engine - it wont cost „billions“ and „more billions“ of dollars.
The A330 was a clean-sheet fly-by-wire aircraft when it entered service in 1994, 13 years after the 767. These are different aircraft belonging to different generations. The 767 couldn't compete with the newer A330 and the 767 as a passenger aircraft went out of production. Boeing found a niche in cheap freighters. Just as the 767 and 777 share some parts, like the same nose section, so does the A330 and A300. These aircraft families are all different types. The A330 might have more in common with the A320, like fly-by-wire systems etc.
The A330ceo to A330neo was a minimal change of an in-production aircraft. The ceo variants are still in production.
There isn't any engine available for a re-engine of the current 767F. That's why someone was suggesting 764F with the 747-8 engine. Doing that means reviving an old derivative of the 767 that has been out of production for 20 years, making a new freighter derivate of the derivative, and getting everything certified. When all this is done (9 years), if possible at all, if would be 50 years since the 767 first entered service. This is nothing like the A330neo, which entered service 23 years after the A330ceo. Even 77W to 77X might be less work.
morrisond wrote:
Boeing has 68 767F in the backlog. I suspect Fedex and UPS could order another 30-50 each before 2027. They both have lots of frames (mainly A300-600) to replace, however I think the regs say you just have to order by 2027 - you can deliver after 2027 which is no problem if KC46a is still in production. Then UPS and Fedex may take a pause in this size category and focus on A350F/777xF to replace early 747's and MD-11/10's. That potentially takes care of say Medium Widebody 150 in the Boeing market forecast - so then you are left with another 350-450 frames.
Not to nitpick, but production will cease at the end of 2027, orders unbuilt by then will not be able to be built at all.
The recent 19 for UPS was reported to be all of the freighter production slots available till then that FX didn't already have options on. So you may see a FX order in the near future for those options, but there's a firm number of airframes that can be produced and they are already seemingly all spoken for. So there's a hard constraint on the number of new 767Fs that can possibly be assembeled until then.
Keep an eye out on the used/converted freighter market. Already over 200 767s have been converted, and there is a wave of 762s coming that are hitting their cycle limits. In the next 5-7 years you'll definitely see demand on the bottom end as well from these converted aircraft hitting LOV. And that's not even taking attrition into account. Plus the MD-11 aging issues. Plus the A300 retirements.
Not all of this can be solved by jut saying "just ungauge to 777/A350F.' A similar-sized (especially in span) and capable freighter will be needed as a like for like replacement
morrisond wrote:So if you don't need to worry about the US Military or UPS or Fedex and wingspan isn't the issue - who is the customer? The obvious one is the Package freight business where volume trumps density. The Amazon freighter.
Then cost of the airframe and fuel burn become the big issue. A350F and 777xF are overkill for this market.
The real competition is 777-300P2F and 330P2F. Boeing is assuming over 1,000 conversions get done in it's market forecast - however if you do something relatively inexpensive you could take a good part of that market. In addition to the 350-450 new builds required in the other part of the forecast.
That is where an 787-9 or -10F could become really interesting. Also an A330-300F-NEO if they launch one.
Compared to an 77F which can take 27 pallets up top and 10 in the belly an 789F should be able to take about the same number up top (maybe more contoured though) as it's about the same length but it can take 11 in the belly. An 787-10F should be able to hold 31 up top and it takes 13 in the belly.
But how much could both of them lift if they take advantage of the new potential 265T MTOW?
The OEW weights of the 789 and 781 are 129 and 135T respectively. Let's take 5% off this to get a reasonable OEW for freighter versions - that takes us to about 122T and 129T. MLW weights for both are 193 and 201T - it's not inconceivable that they can get to say 210T like what happens on almost all other freighters.
Basically then they could lift about 80T and 73T respectively - with more volume than 77F and still have enough lift for 55T of fuel. At 787 consumption levels that should mean about 4,500-5,000nm of range.
That's probably about 75% of the density of A350F/777XF and 85-90% density of 777-300P2F with radically less fuel burn.
It's not inconceivable that the capital cost of an 789F or 781F is within 30% of an 777-300P2F - say $85-95 Million vs $60-70.
Boeings cost of designing 789F or 781F would be very low, maybe a billion or two. Apparently it's already baked into the design. It's worth it to generate another 400-500 frames as it helps to keep line rates up on 787.
I can't see them not doing it and they don't need the US military, UPS or Fedex to buy it.
Eventually UPS or Fedex may be able to get over the ramp space issues by the time they need it (after 2035) as fuel costs (due to carbon taxes) may necessitate the need to begin to replace oldest frames with more efficient ones - and single pilot operations being allowed. You could see them buying out the end of the line just like they are with 767F and 77F.
JonesNL wrote:morrisond wrote:So if you don't need to worry about the US Military or UPS or Fedex and wingspan isn't the issue - who is the customer? The obvious one is the Package freight business where volume trumps density. The Amazon freighter.
787F would probably be too close to the 777xf and too big to replace the 767f.
I think the possible route is a clean sheet with derivative freighter version that can close its business case.
Spacepope wrote:There's really only 2 ways Boeing can go, based on their biggest operator's constraints:
1: 764F with GenX engines. Fairly simple rework of existing aircraft, and many -400 parts still in production for the KC-46 wing.
2: 788/9F but with reworked folding wingtips to fit into current 767 gates. Whatever it takes to get the wings down to 783 span on the ground.
argentinevol98 wrote:Spacepope wrote:There's really only 2 ways Boeing can go, based on their biggest operator's constraints:
On this second point, would it be possible for Boeing to just use the 783 wing? I imagine that most of the engineering work was completed on it and I'm sure they still have all the data/proposed specs. If you did a 788F with the proposed 783 wing that could maybe be a winner. Fitting into the gates and roughly appropriately sized (at least in volume terms). I'm not an engineer however, would the 783 wing have a major impact on MTOW? The 783 was, after all, designed to be a lower MTOW aircraft compared the 788 and I imagine a 787F would aim for a significantly higher MTOW than the current 788. If any engineer knows a bit about that it would be great if they could share.
MIflyer12 wrote:Northwest1988 wrote:I may be overlooking something obvious…. But what about a 787F? Much closer in size to a 767 than a 777 and a proven aircraft that can meet all future emissions regulations.
Well, that's a good question - spend the money on a 764F, or a 787F?
But the first question: Does Boeing see a place in the market for two of its own widebody freighters?
As for the 764 being a failure, yes, as a passenger frame. That 767Fs continue to sell well suggest there's some life in those bones still.
Noshow wrote:There will be the 777XF for much of the 767F business. With more volume which can be well used for all the internet consumer packages shipping. The market below can be well covered by thousands of used cheap A321s converted to freighters.
Noshow wrote:Boeing would need some 787 freighter then. Would this technically work with the CFRP sections, frames and stuff? Plus wouldn't a 787-9 be too much internal competition to the 777XF? Some NMA freighter might be perfect and help the NMA business case.
CoThG wrote:Boeing has trademarked "Dreamfreighter". If that's not tipping your hand, I don't know what is.
32andBelow wrote:If they needed smaller freighters why couldn’t they make one based on the 787-8?
DenverTed wrote:32andBelow wrote:If they needed smaller freighters why couldn’t they make one based on the 787-8?
With the A321 at 200K MTOW and a 787F freighter at 500K MTOW, is there a need for a 300K or 400K freighter that fits in a code D 52m wingspan?
I think a MoM freighter or 764F is a better size than a 787F.
Noshow wrote:Will a non FBW aircraft like the trusted 767 still work in the future environment with future FBW-pilots? I like the 767 but won't it be jurassic by then? Think about new built frames being used for tens of years between scheduled mars flights.
I think Boeing should use what it knows to build some badass future aircraft not revamped oldies.
wjcandee wrote:Noshow wrote:There will be the 777XF for much of the 767F business. With more volume which can be well used for all the internet consumer packages shipping. The market below can be well covered by thousands of used cheap A321s converted to freighters.
Seriously? Some of the thoughts in this thread are just astounding. We're gonna substitute 777XFs for 767s? When Boeing itself estimates a market for a buttload of frames in the 767 (not 777) size range?
Current market conditions, and likely future conditions, are based on many things nobody in this tread has even mentioned.
morrisond wrote:It sounds like the 767 is going to die. However it looks like Boeing may be trying to get exemption for deliveries to FEDEX and UPS beyond 2027. 787F may wait until a re-engine.
From this article. https://www.seattletimes.com/business/b ... to-airbus/
"Since the 767F for the past decade has been delivered exclusively to just two customers, FedEx and UPS, both American companies, the U.S. government might grant such a waiver. Boeing could argue that delivering a new 767F to FedEx to replace one of its ancient MD-10 tri-jets would substantially reduce carbon emissions.
CEO Dave Calhoun said in July that the government should accommodate such a request “in some way, shape or form.”
However, an exemption for the 777F is highly unlikely. Because it’s a long-haul international freighter sold globally, it could not be solely a U.S. decision; other countries would have to agree.
Longer term, even with a 767F exemption for a couple of years, Boeing will need to replace that jet. Hermesmeyer said at that point a freighter version of the Dreamliner, a 787F, “would be the natural place for us to go.”
Hermesmeyer is in charge of Freighters at Boeing - I think he would have pretty good insight on what will replace 763F.
32andBelow wrote:They are also being delivered in large numbers to the us government itself
32andBelow wrote:morrisond wrote:It sounds like the 767 is going to die. However it looks like Boeing may be trying to get exemption for deliveries to FEDEX and UPS beyond 2027. 787F may wait until a re-engine.
morrisond wrote:32andBelow wrote:morrisond wrote:It sounds like the 767 is going to die. However it looks like Boeing may be trying to get exemption for deliveries to FEDEX and UPS beyond 2027. 787F may wait until a re-engine.
Yes - however I assume the Military is exempted from the regulations.
Spacepope wrote:2: 788/9F but with reworked folding wingtips to fit into current 767 gates. Whatever it takes to get the wings down to 783 span on the ground.
argentinevol98 wrote:On this second point, would it be possible for Boeing to just use the 783 wing? I imagine that most of the engineering work was completed on it and I'm sure they still have all the data/proposed specs. If you did a 788F with the proposed 783 wing that could maybe be a winner. Fitting into the gates and roughly appropriately sized (at least in volume terms). I'm not an engineer however, would the 783 wing have a major impact on MTOW? The 783 was, after all, designed to be a lower MTOW aircraft compared the 788 and I imagine a 787F would aim for a significantly higher MTOW than the current 788. If any engineer knows a bit about that it would be great if they could share.
INFINITI329 wrote:Spacepope wrote:2: 788/9F but with reworked folding wingtips to fit into current 767 gates. Whatever it takes to get the wings down to 783 span on the ground.
26.7 ft is the difference between the wingspans of 783 and 788. Just for reference, the 777X reduces its wingspan from 235.5 ft to 212.9 ft which is a difference of 22.6 ftargentinevol98 wrote:On this second point, would it be possible for Boeing to just use the 783 wing? I imagine that most of the engineering work was completed on it and I'm sure they still have all the data/proposed specs. If you did a 788F with the proposed 783 wing that could maybe be a winner. Fitting into the gates and roughly appropriately sized (at least in volume terms). I'm not an engineer however, would the 783 wing have a major impact on MTOW? The 783 was, after all, designed to be a lower MTOW aircraft compared the 788 and I imagine a 787F would aim for a significantly higher MTOW than the current 788. If any engineer knows a bit about that it would be great if they could share.
783
MTOW: 374,782 lbs
Wingspan: 170.6 ft
Range: 3,050 NM
Length: 186.1 ft
788
MTOW: 502,500 lbs
Wingspan: 197.3 ft
Range: 7,355 NM
Length: 186.1 ft
Could a mix of 788 and a reworked 783 be beneficial for FX and UPS? 788 seems like overkill for their domestic runs. I'm skeptical that a 764F is the answer.
