x1234 wrote:NZ is proving pre-COVID lucrative North America routes yields to return. I hope AKL-EWR/JFK happens one day so NZ can take SYD-AKL-EWR/JFK traffic. NZ was the carrier of choice for IAH-AKL-PER energy/oil travel before UA started IAH-SYD. I also hope AKL-EZE returns too.
ZK-NBT wrote:Plenty of Freighter action for the spotters going on ATM bringing in RATS.
CX 2X 748
National Airways 5x 744BCF
SQ 2-3 additional 744F
I believe there are more to come.
QR have changed to a DOH-ADL-AKL routing on the A359 3x weekly on the PAX side.
zkncj wrote:ZK-NBT wrote:Plenty of Freighter action for the spotters going on ATM bringing in RATS.
CX 2X 748
Now that Passengers can flow both ways on the Tasman (well not Australian Passports just yet), if CI will bring back the AKL-BNE-TPE service? currently they are running AKL-TPE non-stop. Think that might an an freight only service?
zkncj wrote:Now that Passengers can flow both ways on the Tasman (well not Australian Passports just yet), if CI will bring back the AKL-BNE-TPE service? currently they are running AKL-TPE non-stop. Think that might an an freight only service?
ZK-NBT wrote:
They were planned to return to CHC via SYD, not 100% sure what the latest date for that is. CHC might be interesting going forward as to what they do wi the it, pre covid I thought a 77L non stop from DXB might be looked at, maybe a service through Asia somewhere like KUL/BKK might be considered?
I dont think CHC market was big enough even prior to Covid to justify a non-stop. Remember it took EK many years of flying via Australia into AKL to give them the confidence to do it. Combining CHC with another market is still the best way, either with SYD, or as you say somewhere in Asia. They used to serve DXB-BKK-SYD-CHC back in the day so maybe a DXB-BKK-CHC?
Otherwise other option might be to link CHC with WLG as a DXB-WLG-CHC-DXB triangle. Combing two markets should give them enough demand to link directly to DXB hub. And CHC + WLG markets complimentary - CHC has volume over the summer but lacks yield, WLG has a more even though lower profile throughout the year but higher yielding helps the low season. Gives both ports non-stop DXB in one direction, and same country transit in the other (which avoids the third country issues you face in Australia or Asia).
Flying via Australia for many years wasn’t to “give them confidence” it wasn’t by choice. It was only when they had suitable aircraft to operate the non-stop ULH flight that they started it.
If EK drops Tasman flights then absolutely CHC can handle and sustain a direct flight to DXB.
Crewing might be hard that way, given it is such a long flight? I thought maybe initially extend AKL to CHC. WLG is interesting would have to be a 77L as that is the biggest WLG could take and the only aircraft that could do non stop inbound only obviously.
Most of EK flights are daily although I think there were a few sub daily flights within Asia or more 10/12 weekly rather than double daily. Maybe a second AKL flight that could be extended, weather it is via Asia or non stop DXB-AKL maybe 4 weekly AKL-CHC and 3 weekly AKL-WLG, again WLG needs a 77L.
They may go back to SYD-CHC on an A380, I always thought the 77W would be better for CHC given it is a lot more efficient especially on a route like SYD-CHC smaller pax capacity and larger freight capacity which the South Island often seems to need. They get what SYD gets at the end of the day.
I am sure years ago they looked at AKL-NAN on an A345? Along with AKL-LAX/EZE.
I think CHC is probably best served via Asia somewhere like BKK/KUL that isn’t served from CHC on a 77W?
And I don’t imagine they will go back to the Tasman ex AKL given QF can operate it for them. I always thought the first route would actually be AKL-PER given PER was fairly new and was less than daily when it first started, they never flew that ever, perhaps PER-CHC? NZ fly or flew that seasonally.
I can't ever see EK going non stop DXB to CHC too long and thin market for them . It will most likely return a tag on from SYD plus they bring a lot of freight in from Aust which makes it worth while.
EK has had the A380 since 2008 and the 200LR for even longer so they had the aircraft capability almost 10 years before they started DXB-AKL. CHC has a very small European market. Its outbound market is smaller than WLG, but its does get a lot of inbound visitors but its very peaky with a high concentration over the summer. Even then its yields are the lowest of the 3 main airports and would be unlikely to support what is an extremely expensive sector to fly.
zkncj wrote:Busy day on MEL-AKL? two flights this afternoon both by 789s only half and hour apart (NZ124, NZ128).
Both an normal flight numbers, so assuming these are both passenger flights?
https://www.flightradar24.com/ANZ124/2b076559
https://www.flightradar24.com/ANZ128/2b075122
NZ801 wrote:I’m hearing that EK have cancelled all A380 services from CHC for the remainder of the year. An update will be provided in December.
Is this also true for AKL?
Can anyone confirm?
NZ801 wrote:EZE won’t be back
planemanofnz wrote:NZ801 wrote:EZE won’t be back
Now LA is out of oneWorld (happened in 2020) and is re-starting AKL, what about NZ slapping its code on their SCL service?
SFwatchTower wrote:ZK-NZK did not make the return trip SFO-AKL as NZ1007 last night March 8, 2022 20:30 SFO time.
ZK-NZN is making the return trip as NZ6177 - https://www.flightradar24.com/ANZ6177/2b122728
Hopefully NZ Kilo is okay.
NZ801 wrote:SFwatchTower wrote:ZK-NZK did not make the return trip SFO-AKL as NZ1007 last night March 8, 2022 20:30 SFO time.
It’s not yet 20:30 on March 8 in SFO.
seat55a wrote:Hoping someone here remembers this. At Polynesian Pools in Rotorua there is an artwork said to be originally from NZ DC10. It's a painted bas relief of sailing canoes. It's two pieces mounted together and is about 4m total width x 1.8m high. I don't see where this could have fit in the cabin. Definitely too wide for between aisles. This bugs me every time I see it (mildly obsessive)
nz2 wrote:seat55a wrote:Hoping someone here remembers this. At Polynesian Pools in Rotorua there is an artwork said to be originally from NZ DC10. It's a painted bas relief of sailing canoes. It's two pieces mounted together and is about 4m total width x 1.8m high. I don't see where this could have fit in the cabin. Definitely too wide for between aisles. This bugs me every time I see it (mildly obsessive)
Old family friends ran the Poly Pools back in the 70's and yes I recall when it was revamped with the "DC-10" mural, I spent a couple of school holidays working there and used to marvel at the mural, imagining being on the big 10! Cant vouch for the authenticity claim but certainly that was the story at the time by very learned people. Possibly it was across the front of the main cabin and aisles were cut out of it? At 4m wide it certainly can fit ...
ZKaviation News
Emirates are looking at doing a Dubai-Wellington-Christchurch-Dubai service with their Boeing 777-200(LR) aircraft. No idea yet of the frequency of the service, or when it might begin. 9MAR22
ZaphodHarkonnen wrote:Interesting rumor from ZKAviation that Emirates is investigating a Dubai-Wellington-Christchurch-Dubai service. https://www.facebook.com/ZKaviation/pos ... 8911591444ZKaviation News
Mr AirNZ wrote:ZaphodHarkonnen wrote:Interesting rumor from ZKAviation that Emirates is investigating a Dubai-Wellington-Christchurch-Dubai service. https://www.facebook.com/ZKaviation/pos ... 8911591444ZKaviation News
The sceptic in me says this is one of those classic A.Net examples of someone reading something on here, posting it somewhere else and then A.Net "grabs" that post as validation of the initial idea.
ZaphodHarkonnen wrote:WIAL taking NZTA and WCC to court over a pedestrian crossing as WCC and NZTA decided not to burden taxpayers with an expensive overbridge. https://www.stuff.co.nz/dominion-post/n ... n-crossing
I know I'll probably be in the minority here. But if 15 or so seconds are so vital to WIAL then they probably shouldn't be in business. Or they can pay for the construction, maintenance, and future removal of a proper flyover.
a7ala wrote:Mr AirNZ wrote:ZaphodHarkonnen wrote:Interesting rumor from ZKAviation that Emirates is investigating a Dubai-Wellington-Christchurch-Dubai service. https://www.facebook.com/ZKaviation/pos ... 8911591444
Interesting they say its from a confidential source so doesnt sounds like it came from here. Will wait and see.
ZaphodHarkonnen wrote:a7ala wrote:Mr AirNZ wrote:The sceptic in me says this is one of those classic A.Net examples of someone reading something on here, posting it somewhere else and then A.Net "grabs" that post as validation of the initial idea.
Yeah, it passes the plausibility test so I'm happy to sit and wait. We know SQ was able to operate into and out of WLG with such an aircraft. And it would be nice to have such a connection through to Europe and elsewhere as I'm in Welly.
planemanofnz wrote:Is there really enough demand for EK at WLG? SQ was subsidized by WCC and couldn't make it work (though I appreciate there would be some differences with the EK service).
a7ala wrote:planemanofnz wrote:Is there really enough demand for EK at WLG? SQ was subsidized by WCC and couldn't make it work (though I appreciate there would be some differences with the EK service).
Why do you say SQ couldnt make WLG work? Prior to Covid they upgraded the aircraft to the A350-900, then increase frequency from 4 to 5pw saying they planned to go daily. They withdrew from WLG because of Covid as there was no market to serve flying via Australia and consolidated on AKL/CHC (mostly for cargo) where they could fly non-stop and avoid Australia.
And as for subsidised by council - it was a small amount of money used for marketing as all regions do to support new services. Nothing out of the ordinary apart from someone in the council wanted to make abig deal about it!
NZ6 wrote:I find this obsession (not just on a.net) for WLG to have long-haul flights just crazy. It's been muted for a number of years and I've always dismissed it. In my opinion there's just no need. We've done it once and with it being subsidized. Let's see how fast (or slow) SQ are to return.
Ultimately - I'm struggling to see where the need for long haul is and why anyone would want to invest serious money into it, because that's what this would take.
AKL is 60 minutes away and in the medium term future all flight operations will be under one roof. Serious investment is required on the runway for any outbound leg over 10hrs which is needed for SIN and beyond.
CHC is the Southern Tourism gateway and catchment population not that different.
WLG isn't on the tourism radar and outside of government agencies isn't home home to many major corporations. Heck, if we're honest. WLG struggles to pull more than a couple A320's to SYD daily.
a7ala wrote:Why do you say SQ couldnt make WLG work?
NZ6 wrote:Let's see how fast (or slow) SQ are to return.
