Scoreboard wrote:This is for an incident in 2011 and a report issued in 2014 - sounds like somebody is trying to resurrect a story to make Air France look bad.
The report, in my reading, shows that the crew were monitoring the situation.
cedarjet wrote:Such a shocking safety culture. Speaking French on the radio at an international airport so every other plane on the frequency has no idea what’s going on, that alone is just ridiculous. I know it’s one of the ICAO languages but you don’t get MEA speaking Arabic in Beirut. As for the incident itself, reminds me of a similar situation with badly mishandled automation on an AF 777 landing at CDG that nearly led to a crash.
https://news.aviation-safety.net/2014/0 ... oeing-777/
airbuster wrote:Avherald is reporting the aircraft didn’t follow commands.
Revo1059 wrote:Search didn't show this as already having been posted.....
(edited) Apparently the didn't follow commands as they tried to land at CDG and had to initiate a go-around and were able to land on the 2nd attempt.
https://youtu.be/avVvgYQtDiI
Dutchy wrote:Revo1059 wrote:Search didn't show this as already having been posted.....
Sound like quite an incident. Question: did the air controller treat this as a mayday even though the pilots didn't call it out as such. The controller must have heard all the bells and whiles and must have known something was seriously wrong.
hitower3 wrote:Can someone with knowledge in the 777 systems please give us a hint what is the signification of the alarm sounds in the flight deck which can be heard in the video?
AllNippon767 wrote:hitower3 wrote:Can someone with knowledge in the 777 systems please give us a hint what is the signification of the alarm sounds in the flight deck which can be heard in the video?
Autopilot disconnect wailer.
Revo1059 wrote:(edited) Apparently the didn't follow commands as they tried to land at CDG and had to initiate a go-around and were able to land on the 2nd attempt.
Dear allnippon767,
The sound at 0:43 is similar to a configuration warning sound. Could you confirm this?
D L X wrote:This sounds like a big deal!
What engines do the AF 777s use?
AllNippon767 wrote:D L X wrote:This sounds like a big deal!
It's a 777-300ER so it is only powered by the GE90-115B. Their -200ERs are also GE powered with the -90B2 variant if I'm not mistaken.
sekant wrote:Revo1059 wrote:Search didn't show this as already having been posted.....
No, this is a bad reading and understanding of what happened and what was said.
They aborted the landing because they flight controls (commandes de vol) were not responding as they should, pilot indicated that flight controls were erratic.
gadFly wrote:As for the language issue, it is common, though not ideal that locals speak in their native language to ground control. And yes, ICAO includes French as an official language. I recall crew speaking Schwizertütsch in Zurich (very rarely, mind you) and French in Geneva (less rarely) to GC. I do agree English as a standard is better to keep others appraised of the situation.
MrBretz wrote:The plane landed safely. Does anyone know why the flight controls were unstable?
zeke wrote:gadFly wrote:As for the language issue, it is common, though not ideal that locals speak in their native language to ground control. And yes, ICAO includes French as an official language. I recall crew speaking Schwizertütsch in Zurich (very rarely, mind you) and French in Geneva (less rarely) to GC. I do agree English as a standard is better to keep others appraised of the situation.
It is absolutely normal for French airlines to speak to ATC in French in France. This is done every day.
DCA350 wrote:Wow, sounds scary.. I'm not a pilot, but I thought automation systems disengage immediately in the event of a fault. Sounds like this plane momentarily took on a mind of its own.
AllNippon767 wrote:Dear allnippon767,
Yes that alarm at 0:43 accompanies the Master Warning (not be confused with Master Caution which is 4 beeps). Master Warnings would have also displayed in red whereas Cautions would be in yellow.
seat55a wrote:Maybe a bit more talkative than most english language comms?
This is a classic report though perhaps not quite standard phraseology:
"l'avion a fait à peu près n'importe quoi"
"the plane did whatever"
Then the controller catches himself babbling and cuts off with "enfin bref" = "Anyhoo..."
cedarjet wrote:Latest from an inside source:
- Wrong approach selected in the FMC (common)
- Autopilot left engaged for far too long in the approach (habitual)
- Trying to overcome the autopilot without disconnecting it (common)
- Hasty and embarrassed go-around causes gear to be retracted before flaps (a quarter of all go-arounds) which triggers the config warning audible on the RT
- Rapid return to the airport because the pilot knows there’s nothing wrong with the aeroplane. If he genuinely thought there was a defect there would have been a lengthy hold.
In other words, another day at the office for Air Chance
zeke wrote:cedarjet wrote:Latest from an inside source:
Unreliable source, you don’t get a “config warning” for gear being retracted before flap.
With it being broken at 300 ft, tempo of broken at 200 ft with a 1 degree temp split, that is weather for an autoland, the statement that the “ Autopilot left engaged for far too long” has no credibility with me.
I would not be surprised if this will be a case of a ground vehicle or aircraft interfering with the ILS transmission.
zeke wrote:Tell me one reason why a 777 cannot fly with landing flap and gear up ?
GPWS will give a warning around 750 ft for gear not being down, “too low gear”
wjcandee wrote:So here's how I think this is going to play out.
(1) They're coming in fully-coupled on automation with all 3 autopilots engaged; if they do nothing, the thing will autoland and roll out. Of course, most crews take over manually for the landing. With the low cloud deck, however, not gonna be easy to see the runway, so maybe they're doing a full-on autoland. Either way, they're rocking down the glideslope in full automation in weather.
(2) An anomaly occurs causing a small deviation off course. Some kind of momentary localizer interruption, perhaps. In this circumstance, any such deviation requires a go-around. So they initiate one. Pop the TOGA switch and hang on.
(3) Pilot error. Perhaps someone doesn't realize the autopilot is still on and they wrestle with the flight controls, which they really have to fight to override. Perhaps there's a somatogravic illusion. Perhaps not. But something causes someone to feel like they need to actively-manipulate the flight controls while the aircraft is still in automation. We hear what sounds like an autopilot disconnect late in the sequence, after the heavy-breathing from the freaked-out, transmitting pilot, which would be consistent with this. And someone yelling STOP STOP, as if to say "stop what you're doing". And/or, perhaps, as Juan Browne notes, they screwed up the sequence of things you need to do on a go-around in autoflight; he mentions lifting the gear out of sequence or not properly-configuring flaps, triggering the master warning that we hear. I would note that you have a sense that everybody relaxes after that sequence, which suggests that they realize that they f-ed up, even if they don't say it. And they told the pax there was a plane on the runway, which was total BS. If they didn't at least have a sense of what went wrong, they'd be more likely to be concerned that they're going to be fighting it again, not acting relaxed and relieved..
Anyway, I'll stake that on the table. Could be wrong but it seems like a sensible theory. What's a bit surprising about this, of course, is that this exact scenario should be something they train on regularly; it would be a surprising mistake. But then again, given the excellent safety records of carriers like AF, it stands to reason that what went wrong will be something surprising.
Polot wrote:The warning is not there to tell you that you are immediately about to fall out of the sky, but to remind you not to forget to retract the flaps (or extend gear) as there are few times you need to be flying in such a configuration.
DL_Mech wrote:Would the Gear Override switch have silenced the Master Warning?
zeke wrote:Polot wrote:The warning is not there to tell you that you are immediately about to fall out of the sky, but to remind you not to forget to retract the flaps (or extend gear) as there are few times you need to be flying in such a configuration.
So tell me what is the EICAS message produced fir this warning ? Just looked up the FCOM and didn’t see this nonsense.
It does not pass the smell test to generate a mater warning for that, master warning are for significant things like overspeed, stall, fire. Not for flying around in a perfectly acceptable configuration.
How do you know it’s not flap overspeed ?
