LAX772LR
VIDEO: landing gear from roll to retraction, from inside bay
Sun May 01, 2022 9:10 am
Seen plenty of landing gear cams before, but never one from this perspective.
Figured some of you may enjoy it!
https://www.youtube.com/watch?v=7Y3lpgbTu6k
PeteKMCFC
Re: VIDEO: landing gear from roll to retraction, from inside bay
Sun May 01, 2022 10:10 am
Thanks for sharing! Fascinating to see from that angle
Gr8Circle
Sun May 01, 2022 12:44 pm
Interesting to see how the wheels stop spinning seconds before retraction....I always thought that they continue spinning for a while even after fully retracted....
jetskipper
Sun May 01, 2022 1:07 pm
Depending on the aircraft, most apply brake pressure to the main gear wheels when selected up. There are a lot of systems with components in the wheel well, for instance: fuel lines, hydraulic lines and accumulators, flap motors, flight control cables, fire bottles, just to name a few. The threat is that a damaged tire is still spinning while it is retracted into the well and wreaks havoc on the accessible systems. The nose wheel on the other hand usually just comes in contact with a rubber brake or snubber when retracted which stops rotation mechanically.
ReverseFlow
Sun May 01, 2022 1:37 pm
It's also the gyroscopic effects.
I was wondering - the 737 and ithers don't retract the wheels fully into the bay and have a door close on it.
On this video you can see the right gear doesn't seal fully as you can see a bit if light.
How much drag and especially noise does this make?
Obviously not enough to change the design (that would be a huge change)
889091
Sun May 01, 2022 2:46 pm
Looks scary, even on video.
Which makes this even scarier!
https://interestingengineering.com/a-st ... wheel-well
I guess desperate people will do desperate things.
wingman
Sun May 01, 2022 3:11 pm
I noticed that too. It can't be the spec as designed so I'm guessing it's some bits that need replacing causing that imperfect seal.
slvrblt
Sun May 01, 2022 3:54 pm
Cool video! thanks, LAX772LR
B757Forever
Sun May 01, 2022 4:03 pm
Those flap seals on the 737 are a common replacement item for aircraft during scheduled checks.
SEAorPWM
Sun May 01, 2022 4:36 pm
Being someone who has delved into the joys of EWIS in the past, the biggest thing that blows my mind is how solid those hydraulic lines and hoses seem to be. I can't even detect the slightest hint of vibration in those or any wire bundles routed around them. :veryhappy:
LAX772LR
Sun May 01, 2022 8:09 pm
No prob.
Here's the landing, from the same cam, if y'all wanted to see. It's pretty cool, seeing as the approach is over the Indian Ocean.
https://www.youtube.com/watch?v=9w6HOT35JMA
B757Forever
Sun May 01, 2022 8:45 pm
All the plumbing in the wheel well is designed to withstand a tire that explodes after retraction. Oddly enough, bias ply and radials tires exert forces differently when they explode. When we converted our 737-800 fleet from bias to radial tires, a part of the mod was to replace specific hydraulic lines in the wheel wells with heavier wall tubing to be compatible with the radial tire failure characteristics.
nstampede002
Sun May 01, 2022 9:03 pm
Just to expound a bit more: there is a frangible fitting on the bottom of the wing-to-body fairing on the B737 (NG at least) that in the event a tire is experiencing tread separation AND still makes it near the wheel well, that spinning tire tread will shear the fitting off and that will remove hydraulic power from the retract cylinder (slight amount of fluid overboard - a hydraulic fuse isolates the rest of the system) to prevent the landing gear from retracting any further (gravity takes over and that landing gear assumes down and locked position). This would prevent said tire from getting into the wheel well and possibly ending up stuck due to the tire tread trying to liberate itself.
Fixinthe757
Sun May 01, 2022 9:08 pm
Another reason the brakes are applied at gear retraction (~500 psi) is the tires expand while rolling, so stopping the tires brings them back to their normal size so they can enter the wheel well without contact with anything
F9Animal
Mon May 02, 2022 7:20 am
That is awesome! Gets me to thinking. I wonder if airlines would consider doing cameras like this that pilots can access when troubleshooting a problem? This view would be great for a situation the gear doesn't show down.
Technology is just still blowing me away.
LAX772LR
Mon May 02, 2022 8:43 am
That's actually a pretty good idea... I wonder why they don't.
That could've been extremely helpful in an incident like FX1026:
https://www.youtube.com/watch?v=4IgAbGk7Jy4
RobertS975
Mon May 02, 2022 11:02 pm
Visually down doesn't mean locked!
basspaul
Mon May 02, 2022 11:14 pm
It's not designed to be a perfect seal, it's a brush seal. Just there to help smooth the surface by filling in the gap from the belly fairing to the wheels.
