argentinevol98 wrote:Does anyone know if this E175 had the larger winglets added aftermarket or straight from factory? It is a relatively young frame.
KCaviator wrote:argentinevol98 wrote:Does anyone know if this E175 had the larger winglets added aftermarket or straight from factory? It is a relatively young frame.
There are no aftermarket winglets for the 175. All new 175s have the extended winglet straight from Brazil.
kabq737 wrote:From The Aviation Herald:
“An Envoy Embraer ERJ-175, registration N233NN performing flight MQ-3729/AA-3729 from Charleston,SC to Dallas Ft. Worth,TX (USA), was enroute at FL360 almost overhead Birmingham,AL (USA) when the aircraft encountered moderate to severe turbulence, the crew subsequently issued a pilot's report and advised ATC they had lost part of a wing. The crew decided to divert to Birmingham for a safe landing on runway 24 about 35 minutes after leaving FL360.”
https://avherald.com/h?article=4f84e603&opt=0
This is certainly an interesting one. Makes me wonder how heavy the turbulence was. I’m sure there will be a lot of investigation in the coming days.
LAX772LR wrote:Regardless of whether there was a mtx fault, or if somehow the winglet's ultimate loads were indeed exceeded.... it's worth noticing how cleanly it was designed to sheer off. That's a pretty significant accomplishment, in favor of safety.
JohanTally wrote:I wonder if these winglets have a designed fail point when overstressed. These winglets are most likely CFRP with a metal leading eage.
Web500sjc wrote:KCaviator wrote:argentinevol98 wrote:Does anyone know if this E175 had the larger winglets added aftermarket or straight from factory? It is a relatively young frame.
At least 1xE175 was retrofitted with the larger winglets after delivery (N103SY). None of the American Eagle ones were retrofitted to my knowledge.
trexel94 wrote:kabq737 wrote:From The Aviation Herald:
That must have been unsettling to see as a passenger.
KCaviator wrote:trexel94 wrote:kabq737 wrote:From The Aviation Herald:
Not going to lie, I'm a pilot on the 175, and if I was in a window seat and saw that I also would've sh** my pants.
JoseSalazar wrote:KCaviator wrote:trexel94 wrote:That must have been unsettling to see as a passenger.
Why? It’s just a winglet…not like it keeps the plane in the air. I’d be more concerned about what/who it might have landed on.
Ok
spottingBOG wrote:Wow. Never saw an aircraft lose a winglet mid-air before. Will be interesting to see how this goes for Embraer or whoever designed/installed them.
Enviado desde mi SM-G780G mediante Tapatalk
FlyingElvii wrote:KCaviator wrote:JoseSalazar wrote:Why? It’s just a winglet…not like it keeps the plane in the air. I’d be more concerned about what/who it might have landed on.
Ok
He’s partially correct.
It is not a control or lift surface area.
I remember correctly, there were many articles talking about this possibility when winglets started to appear, that were dismissed because it is not a lift or control surface. That if one did go on a flight of its own, that it was something easily handled by just a little more rudder.
This could be the result of nothing more than an old, undetected (or improperly inspected) bird strike.
Cayden wrote:I flew into BHM this afternoon and saw it
https://photos.google.com/photo/AF1QipN ... GHh55i6kcm
gdavis003 wrote:Cayden wrote:I flew into BHM this afternoon and saw it
The link for the picture isn't working, but is it still parked at gate B5?
Cayden wrote:https://www.flickr.com/photos/[email protected]/52051249366/in/dateposted-public/
https://www.flickr.com/photos/195575321 ... ed-public/
zeke wrote:spottingBOG wrote:Wow. Never saw an aircraft lose a winglet mid-air before. Will be interesting to see how this goes for Embraer or whoever designed/installed them.
The China Southern 738 crash had its winglet depart the aircraft as well.
Fixinthe757 wrote:The China Southern 738 had both its entire wings depart while in a nose dive!! Not exactly the same
zeke wrote:Fixinthe757 wrote:The China Southern 738 had both its entire wings depart while in a nose dive!! Not exactly the same
That is not true, just a winglet was found 10 km from the crash site.
Jfoxwi78 wrote:I previously worked for the carrier that was flying the first 20 American Eagle 175s before they went to Envoy.
argentinevol98 wrote:Cayden wrote:https://www.flickr.com/photos/[email protected]/52051249366/in/dateposted-public/
Thanks for linking these photos. That's about as clean a break as possible. Certainly looks like it broke as likely designed to so as not to further damage the wing. I don't know enough about metalurgy or engineering to gather much else or clues to why it broke. Would be interesting if anyone has such insight based on the photos.
rexchase12 wrote:Have they found the winglet?
LTEN11 wrote:zeke wrote:Fixinthe757 wrote:The China Southern 738 had both its entire wings depart while in a nose dive!! Not exactly the same
I thought it was just a metal strip off the winglet, not the whole winglet.
It was China Eastern, not China Southern.
MLIAA wrote:Embraer issued a service bulletin about winglet spar fatigue in 2018, it was slowly being complied with and Envoy had roughly 40 airplanes left to modify. These mods are now being sped up after this incident.
The theory is that the turbulence was caused by the winglet failing, not the weather.
battlegroup62 wrote:MLIAA wrote:Embraer issued a service bulletin about winglet spar fatigue in 2018, it was slowly being complied with and Envoy had roughly 40 airplanes left to modify. These mods are now being sped up after this incident.
I'd imagine if the failure was due to fatigue cracking in the winglet spar there will be fleetwide inspections due asap since it was a known issue, or the sb will become an AD.
MLIAA wrote:
They are ramping up inspections on these spurs, and replacing the remaining 40. This airplane was one of those.
GalaxyFlyer wrote:A missing winglet can be MEL’d, I’ve flown a couple planes configured that way. I’ve seen worse things.
