9252fly wrote:There has been talk of a A350-2000, how much capacity would that version hypothetically have? I was under the impression it would be trading payload for range.
atcsundevil wrote:The title has been updated accordingly.
✈️ atcsundevil
Dominion301 wrote:Hey EK could have kept on ordering 380s to keep the line open at a half dozen frames a year and choose to.
Pellegrine wrote:That the A350-1000 has been to small to be Airbus' top offering for EK and other carriers that deal with slot-restricted high-demand prime routes has been known for a while. A350-1100/A350-2000 isn't really viable without having a complementary range to the A350-1000.
Is Airbus going to cede the upper-capacity end of the market to Boeing's 777-9X? I don't see anyone making a new VLA for a ~250 aircraft market. Is Airbus going 10-abreast in Y with the A350 via thinner sidewalls & new floor placement à la the rumored EY study? That wouldn't even help capacity much, and would do nothing for J/W capacity...you need a longer fuselage.
Is Boeing going to come out with a 777-10X eventually? Again, similarly to the Airbus situation, it would have to have comparable range to the 777-9X to be given the best chance at being successful. Guess we will see.
JohanTally wrote:Pellegrine wrote:That the A350-1000 has been to small to be Airbus' top offering for EK and other carriers that deal with slot-restricted high-demand prime routes has been known for a while. A350-1100/A350-2000 isn't really viable without having a complementary range to the A350-1000.
Not many airlines are looking for aircraft with the A35K 8700nm range. A stretched A35K that still has a 7500nm brochure range would check most of the boxes.
Pellegrine wrote:JohanTally wrote:Pellegrine wrote:That the A350-1000 has been to small to be Airbus' top offering for EK and other carriers that deal with slot-restricted high-demand prime routes has been known for a while. A350-1100/A350-2000 isn't really viable without having a complementary range to the A350-1000.
Quoting range without mentioning payload is a simplistic argument and one I see way too often on this forum. A35K can carry 26-27t max 8700nm. And that's at max fuel.
ObadiahPlainman wrote:So that thing would be too small, but the A380--which is being parked everywhere--is too big?
Someone please given Tim Clark some smelling salts.
Polot wrote:Pellegrine wrote:JohanTally wrote:Not many airlines are looking for aircraft with the A35K 8700nm range. A stretched A35K that still has a 7500nm brochure range would check most of the boxes.
That really doesn’t change the point of his comment much. Most airlines have little need to carry 26-27t 8700nm.
Point taken. EK might see a need to send 50-60t 6500nm though (DXB-SYD). Extrapolate those numbers to a heavier aircraft (OEW) with more payload capacity (seats and cargo) and you'll see that more needs to be done than "lengthen the aircraft, keep MTOW the same, and you're golden". Do that and you get the 787-10.
Polot wrote:I agree.
That then becomes a question of how much should OEMs cater to the ME3. I think the golden age of OEMs going out of their way to woo them has come to end, as it has resulted in tons of headaches.
DLHAM wrote:Well he is right, but the larger space is already occupied by the 777-9 and two aircraft this size make no sense, the market in that segment is not big enough.
32andBelow wrote:Well he can prolly order a spec built aircraft and pay for all the R and D
S0Y wrote:The A380 could fly for years to come. There is no law that says you must retire them at 10yrs of age. For example DL have shown that if you maintain them properly, aircraft can fly a long long time and still deliver a quality product.
The other point (noted above) is EK basically killed the A380 program. They knew there was no replacement, but declined to purchase any more. Surely the math that suggested 777/787/350 are enough still holds true. So its a bit rich to complain that there are no VLA to buy now
S0Y wrote:He basically had one with the A380, but decided there were better economics with other aircraft, so now there is no more A380
Aseem747 wrote:A350-1000 not carrying even as much as a typical 777-300ER nowadays is definitely a factor that's greatly limiting it's sales and will continue to do so in the future. 10 abreast 77W has worked out wonderfully for everyone who has implemented it so why would they down size to an aircraft with a capacity of 9 abreast 77W instead of just ordering a negligible 773 stretch that's optimized well for 10 abreast?
xwb777 wrote:Sir Tim Clark has also expressed his opinions on the A350-1000 saying that its a great airplane but lacks range.
LAX772LR wrote:xwb777 wrote:Sir Tim Clark has also expressed his opinions on the A350-1000 saying that its a great airplane but lacks range.
It should give you pause to write this, considering that the A35K is the currently-produced airliner with the longest standard (and extended) range.Aseem747 wrote:A350-1000 not carrying even as much as a typical 777-300ER nowadays is definitely a factor that's greatly limiting it's sales and will continue to do so in the future.
Nonsense.
The primary thing "limiting" the A35K's sales is timing: it came too late to finish off the last of the passenger 747s, and is "early" in that the 77W replacement cycle has not begun in earnest-- a process which likely won't be in full swing for another half decade, seeing as the eldest among them is only 18-yrs-old.
NWAROOSTER wrote:Tim Clark missed his chance. He could have ordered the 747-8i but he did not.
DaCubbyBearBar wrote:Sir Tim must have very specific wants if 350 is too small and the 380 is too big.
“What it will do is put the cost of air travel up through the roof, if you’re not careful,” Clark suggests. “So you’ve got to find a way, and I fret with this one. “Somebody’s got to do something, honestly.” Clark jokes that he has a new – three-engined – A380 “on the drawing board” but that he has not shown it to Airbus chief executive Guillaume Faury yet.
