flyinggoat wrote:Personally, I think Embrear is positioning the E3 to be the E175 replacement, and I wouldn’t be surprised if we see engine options other than the turboprops (like open rotor)
docmtl wrote:No change in Scope Clause in new United's pilot contract that would have allowed E175-E2 or else. Delta and AA will follow suit shortly:
"United was the first carrier to negotiate a new agreement with pilots. American Airlines also negotiated a new agreement, following UAL. There were no changes to Scope weights, either. UAL’s union, ALPA, only today confirmed no change to its contract. It is now highly unlikely Delta Air Lines or Alaska Airlines, whose pilots are also represented by ALPA, will change."
https://leehamnews.com
So, how will Regional Carriers deal with no new scope clause compliant regional jet to replace E1-175s after the 2027 ?
docmtl
Velocirapture wrote:docmtl wrote:No change in Scope Clause in new United's pilot contract that would have allowed E175-E2 or else. Delta and AA will follow suit shortly:
docmtl
That's incorrect. In the UAL TA, there is a proposed weight change as the CRJ-550 weight would increase 4,750 pounds. I'm surprised (not to mention, disappointed) that UAL ALPA agreed to such a change give the rare leverage the pilots have right now.
Velocirapture wrote:That's incorrect. In the UAL TA, there is a proposed weight change as the CRJ-550 weight would increase 4,750 pounds. I'm surprised (not to mention, disappointed) that UAL ALPA agreed to such a change give the rare leverage the pilots have right now.
WayexTDI wrote:flyinggoat wrote:Personally, I think Embrear is positioning the E3 to be the E175 replacement, and I wouldn’t be surprised if we see engine options other than the turboprops (like open rotor)
But what's really the difference between a turbo-prop and an open rotor? Number and shapes of the blades, but the principal is the same.
I'd say a turbo-prop and an open rotor are as similar as a regular turbofan and a geared turbofan.
If the public is scared of turbo-props, they'll be scared of open rotors.
Avatar2go wrote:WayexTDI wrote:flyinggoat wrote:Personally, I think Embrear is positioning the E3 to be the E175 replacement, and I wouldn’t be surprised if we see engine options other than the turboprops (like open rotor)
Difference between open rotor and turboprop, is the speed range possible for the rotor is much higher than for a prop. By using rotor technologies without the enclosure, the rotor diameter can be expanded while both rotational and forward speed are enhanced, without loss of fuel efficiency.
The rotor technology is more similar to a turbofan, than a turboprop. So it represents an intermediate technology.
The latest GE turbofans are optimized for thermal efficiency, while the P&W geared turbofans are optimized for propulsive efficiency. The overall engine efficiency is the product of the two. The open rotor is a compromise solution that optimizes both at the same time.
What kind of speed ranges does an open rotor have compared to turboprops? I find the idea of it being implemented on future aircraft interesting and wonder why it hasn't taken off yet ( yeah, pun intended ).
mikejepp wrote:With the way things are going with oil prices and the pilot shortage, it may be a stretch to assume that regional airlines even exist in 2027....
At some point its just going to be cheaper to fly less frequencies with a 319, 737, 190, 220, etc. If a market is too small to be able to support 2x mainline aircraft a day, its probably too small to be worth serving at all.
Could we see them shut down with a small portion of their fleets... say 50-100 planes per major (such as the newest build CRJ-700s or E175s)... being folded into mainline for service to small premium heavy airports that need that type? For example, ASE and HHH.
docmtl
Yossarian22 wrote:Why not bring these operations in house? Why do American legacies need a third party company to operate smaller aircraft? Mom-American carriers such as Ethiopian Airlines operate everything from prop jets to 777s.
It would seem that both sides would benefit. The pilots wouldn’t be competing with pilots from other companies. The airlines would have a signal large pool of pilots which could be scheduled more efficiently than several smaller pools of pilots who are walled off from operating flights that have been contracted to different companies. Not to mention, the poor operational reliability of many regional airlines.
EWRflyr wrote:Velocirapture wrote:That's incorrect. In the UAL TA, there is a proposed weight change as the CRJ-550 weight would increase 4,750 pounds. I'm surprised (not to mention, disappointed) that UAL ALPA agreed to such a change give the rare leverage the pilots have right now.
Yes, there is a weight increase along with a new hard flight distance cap of 900 miles to prevent the allowed increased weight from being used to fly longer routes. Passenger weights went up resulting in weight restrictions on these aircraft. In theory that’s a good thing, but the company is not going to stop flying these planes for now. The increased passenger weights and weight restrictions have resulted in numerous UAL pilots being denied the jumpseat when these aircraft are put on a route. The TA language weight increase will allow for 50 passengers as intended plus a jumpseat rider without an increase in flight length.
The latest GE turbofans are optimized for thermal efficiency, while the P&W geared turbofans are optimized for propulsive efficiency. The overall engine efficiency is the product of the two. The open rotor is a compromise solution that attempts to optimize both at the same time, but for a lower cruise speed range, that is still well above that of a turboprop.
USAirKid wrote:Yossarian22 wrote:Why not bring these operations in house? Why do American legacies need a third party company to operate smaller aircraft? Mom-American carriers such as Ethiopian Airlines operate everything from prop jets to 777s.
I'm pondering if this might happen in a few years with AA and their wholly owned regionals. Given that the rumor (or announced) info is that they're increasing pilot wages at the wholly owned regionals. I could those merging with AA at some point, but the company would want the ability to outsource some of those planes.
Now the question is, you'll still have "walled off" pilots, since there are type ratings and the like. What I'm curious if there really is enough cost in the wholly owned regionals that would be able to be cut out? There probably is some, but probably not a lot.
docmtl
eeightning wrote:
Difference between open rotor and turboprop, is the speed range possible for the rotor is much higher than for a prop. By using rotor technologies without the enclosure, the rotor diameter can be expanded while both rotational and forward speed are enhanced, without loss of fuel efficiency, AND AT THE COST OF HIGHER NOISE LEVELS.
fixed it for you
amcnd wrote:docmtl wrote:No change in Scope Clause in new United's pilot contract that would have allowed E175-E2 or else. Delta and AA will follow suit shortly:
docmtl
The E1’s are brand new!! They will fly way past 2027. Ive heard the E175 is a 30+ year aircraft..
fixed it for you
That is an important point, the noise levels. The known issues with open rotors. There are still 3 unresolved technical issues:
https://asmedigitalcollection.asme.org/ ... n-Question
In my opinion of the challenge diffiulty
1. Blade containment. Passengers must be protected from a lost fan blade. It will happen. Hence the mass inefficient concepts of putting open rotors at the tail. The engines may be more efficient, but as the article notes the engines will weight as much as a turbofan and the packaging requires less optimal propulsion and structural placement. This takes back some of the engine gains.
2. Noise. As the link notes, open rotors can wail like a siren.
3. Diameter makes mounting a challenge. Double the problem as the easy places to place these heavy engines are prohibited by passenger safety.
Why haven't they done prototype open rotors with differing blade counts in each row? Did I miss that? We always design engines with incompatible multiples of prime numbers of blades to keep from having acoustic coupling. However, the noise is a complex enough issue that every fan concept will have to be tested early in the engine design.
Open rotors are 3 years away, at least, from launching a program. That means 11 years away from entry into service. Like the GTF engines, they will require a very long development timeline. By then, the answer on US regional fly will already be answered.
I see no scope change. By the time a new aircraft, even Embraer's turboprop enters service, most of the decisions will have been made. That is why I propose less than daily service with mainline aircraft for those airports that cannot support mainline gauge. Something will have to be done for out-station ground handling though.
Lightsaber
fixed it for you
Lightsaber
Safran claims noise levels on par with the CFM Leap engines
https://mentourpilot.com/safran-open-ro ... sign-leap/
fixed it for you
Lightsaber
lightsaber wrote:JohanTally wrote:lightsaber wrote:That is an important point, the noise levels. The known issues with open rotors. There are still 3 unresolved technical issues:
Lightsaber
Fascinating read. If the noise is controlled over the entire operating range (tough and expensive to test), this is a breakthrough. Kudos. Now to launch the engine (which needs 2 to 3 years more development time) then the aircraft. What thrust range?
Lightsaber
bluecrew wrote:JohanTally wrote:lightsaber wrote:That is an important point, the noise levels. The known issues with open rotors. There are still 3 unresolved technical issues:
Lightsaber
I would imagine it's sort of a "phases of flight" thing - I would imagine the E2 has the same issue with that as the A220.
The A220 on paper is quieter, but during taxi and the initial takeoff roll the engine whines and wails and vibrates so significantly that basically, everything attached to the wing box rattles uncomfortably. Try sitting over the wing, I have 3 times so far and I've noticed it twice - with AirPods in and on noise cancel mode.
It seems silly, but things like this, as well as a turboprop or anything with propellers being seen as "outdated" (which is laughable when you compare the Q400 with say, an early CRJ) and you can see it in passenger experience scores specifically in the US - I'm sure the trend is universal but it is certainly very pronounced here. Now stick two rearward-facing contra-rotating propellers that look scary as heck on each wing, it's gonna land with the public as well as a flying potato.
I think the predictions of the death of the regional airline are, as they have been previously, a bit overblown. There are still Skywest and Envoy lifers (god I don't know why), Mesa is a cockroach that will outlive them all, and we'll see how AA throwing money at the problem with Piedmont and PSA influences Delta's future with Endeavor. Air Wisconsin is just f'd.
So no, maybe they don't get scope relief, and maybe we never see the E2 in a major US airline's colors, but the E175s bouncing around the whole country with their funky new winglets and weird nose-high taxi still have a lot of life left in them. They've clearly worked quite well for United in testing and proving new route opportunities out of DEN.
There's still a market and still demand, so if in 5 years they have to start charging $600 for a 90 mile flight on a 15 year old E175 because labor costs to keep pilots, flight attendants, airport ops and ground ops personnel have skyrocketed, they will. The 50 seat RJ is a fundamentally dead concept though, and it has had a clear exit from the market since the E170 and CRJ7 were adopted in large numbers.
Ultimately I would imagine they'd do better with new frames and making the labor concessions necessary to get them on property... but that's not how airlines think when it comes to labor relations.
fixed it for you
Lightsaber
fixed it for you
Lightsaber
I politely wonder if you're wrong.
It seems an engine maker could offer a turbo prop engine with a smaller, more bladed, faster spinning propeller. And call it a propeller. And get it certified under propeller rules. Which do not require blade containement and such.
Certainly one can certify an 8 blade prop as a propeller.
FLALEFTY wrote:I really think the pilot unions are approaching the whole scope clause issue from the wrong angle. They focus on limiting the number of seats and MTOWs of regional jets, but they ignore the fact that the big airlines are using 76 and even 50-seaters to perform trunk routes, some exceeding 1,000nm.
For example, Envoy flies E145s for American Eagle on the ORD-YYZ, ORD-YUL, ORD-CVG, ORD-DTW and ORD-MSP routes. SkyWest flies E175s for Delta Connection on routes such as SLC-IAH, SLC-ORD, SLC-LAX, SLC-SEA, et. al. These are routes that should easily support mainline ops, but in the name of capacity optimization, cost reduction & adding frequencies to their hubs, the parent airlines use their regionals instead.
1-C-1-b At least eighty percent (80%) of all United Express Flights each month shall be under 900 statute miles.
1-C-1-d Hubs In any Rolling Twelve-Month Period, the number of block hours of United Express Flying operated by United Express Carriers as a group non-stop between current or future Company Hubs may not exceed five percent (5%) of all United Express Flying as a percentage of the total block hours of United Express Flying. A pair of Flights by a United Express Carrier operated under a single flight number in which one Flight is scheduled to originate at a Company Hub and the second Flight is scheduled to terminate at a second Company Hub shall be included within the five percent (5%) limitation, unless the Company imposes an IATA Standard Schedules Information Manual Type “A” Traffic Restriction Code on the through itinerary that shall suppress the display of such itinerary.
1-C-1-e Connecting Operations United Express Carriers as a group shall Schedule at least ninety percent (90%) of their United Express Flying Non-Stops into or out of the following airports: IAD, DCA, MIA, LGA, EWR, JFK, ORD, DEN, LAX, SFO, SEA, BOS, PDX, PHX, LAS, SJC, SAN, IAH, CLE, GUM, any airport within thirty (30) statute miles of any of the foregoing, any other airport with fifty (50) or more scheduled daily departures of Company Flying, and any other airport that the parties later agree to add to this list. Up to five percent (5%) of United Express Flying flights may be applied toward satisfying this requirement even if such flights include multiple stops, as long as such flights i) originate or terminate at one of the foregoing airports, ii) maintain a single flight number on a single aircraft for all the legs of such flight to or from such airport, and iii) operate with scheduled intermediate stops of less than two (2) hours
jbs2886 wrote:docmtl wrote:No change in Scope Clause in new United's pilot contract that would have allowed E175-E2 or else. Delta and AA will follow suit shortly:
docmtl
Well, AS doesn’t have a scope clause…so this is questionable.
ikolkyo wrote:[code][/code]FLALEFTY wrote:I really think the pilot unions are approaching the whole scope clause issue from the wrong angle. They focus on limiting the number of seats and MTOWs of regional jets, but they ignore the fact that the big airlines are using 76 and even 50-seaters to perform trunk routes, some exceeding 1,000nm.
Isn’t that a key part of regional jets? Providing frequency throughout the day to give passengers options?
EssentialBusDC wrote:Not quite true at UAL at least. There are restrictions on mileage, percentages of hub to hub flying, and percentages on designated cities that United Express must comply with in addition to the passenger and weight limits.
superbizzy73 wrote:jbs2886 wrote:docmtl wrote:No change in Scope Clause in new United's pilot contract that would have allowed E175-E2 or else. Delta and AA will follow suit shortly:
docmtl
This is another reason why I always thought AS was prime for obtaining the E2. They're getting rid of the Q400 (at QX), and they already operate the E1. Seems like a somewhat no-brainer move in efficiency.
Unfortunately for Embraer, the E175E2 only has 6% better fuel efficiency than the E1 due to its over 5t higher weight and additional aerodynamic drag caused by the higher bypass engines. Throw in the higher book prices for the E175E2 and it will likely take years of service to see a financial advantage for any airline. Also, Embraer has put this aircraft's test & certification program on hold until 2024 and even then the restart will be contingent on receiving firm orders for the type (currently there are none).
bluecrew wrote:There are still Skywest and Envoy lifers (god I don't know why), Mesa is a cockroach that will outlive them all, and we'll see how AA throwing money at the problem with Piedmont and PSA influences Delta's future with Endeavor. Air Wisconsin is just f'd.
superbizzy73 wrote:This is another reason why I always thought AS was prime for obtaining the E2. They're getting rid of the Q400 (at QX), and they already operate the E1. Seems like a somewhat no-brainer move in efficiency.
FLALEFTY wrote:Unfortunately for Embraer, the E175E2 only has 6% better fuel efficiency than the E1 due to its over 5t higher weight and additional aerodynamic drag caused by the higher bypass engines. Throw in the higher book prices for the E175E2 and it will likely take years of service to see a financial advantage for any airline.
lightsaber wrote:kitplane01 wrote:lightsaber wrote:That is an important point, the noise levels. The known issues with open rotors. There are still 3 unresolved technical issues:
Lightsaber
Pratt still has PW4000 engines grounded due to fan blade containment failure:
https://aviationweek.com/air-transport/ ... blade-loss
Could a larger propeller be certified? Yes. The first blade out event would ground the type. The reasons turboprops are not grounded is the relative stress at the propellers root is low enough to ensure finding failures far before a blade out event. The higher mach numbers of open rotors ensure more blade stress. Turbofans mitigate that risk by shroud fan blade protection. Pratt failing that resulted in their 777 engines being grounded. If a turboprop has a blade failure risk that exceeds FAA or EASA safety guidelines, it to will be grounded. Hence why the mitigation of off engine mounting locations.
I'd love to be proven wrong. But propfans will have higher stress on the fan blades (as would a higher rpm turboprop). If the risk of ice, bird strike, FOD, or fatigue failure becomes too high, as there certainly is in turbofan engines, some form of mitigation must occur.
The FAA/EASA have shown with the MAX and Pratt 777s, they will ground whole types over excessive risk. Propfans will mitigate the risk, but that takes years of R&D.
However, for this thread a moot point. There will not be an open rotors aircraft within to the next decade, there is just too much tech to develop. Heck, Embraer needs more time to develop to their turboprop concept.
The fate of US regional flying will be determined on the currently available aircraft. The window to develop a new type before the fuel regulation changes has passed, even for a new turboprop. I expect no scope change and the economics of regional flying is so marginal, only a well optimized airframe will thrive.
That doesn't mean no possible regional solution. Airline branded buses and less than daily service on larger narrowbody aircraft can fill most of the niche, in my opinion.
In 18 months when Delta cuts 50 seat service (link above on CR2 retirement) is when we see the transition. This isn't some academic discussion anymore; there will be a huge industry shift with DL's 50 seater retirement. In 5.5 years with the tightening fuel burn requirements, another shift.
I see no reason buses and less than daily service couldn't fill the need.
Lightsaber
FLALEFTY wrote:I really think the pilot unions are approaching the whole scope clause issue from the wrong angle. They focus on limiting the number of seats and MTOWs of regional jets...
ScottB wrote:I think the most important focus for the pilot unions ought to be limiting the overall ratio of regional flying vs. mainline in their respective airline networks. It shouldn't matter if a RJ flies ORD-MSP if that frees up mainline aircraft for other markets. As long as mainline pilot work grows more rapidly than the outsourced jobs, it's still a win for the mainline pilots for career growth.
Velocirapture wrote:FLALEFTY wrote:I really think the pilot unions are approaching the whole scope clause issue from the wrong angle. They focus on limiting the number of seats and MTOWs of regional jets...
That's not correct. Rather, the unions are quite OK with the airlines operating more of these aircraft as long as the pilots from the major fly them.
strfyr51 wrote:especially since UAALPA has had the pilot pay scales in place for every UAX fleet model for over 10 years. AND? they could pull the trigger Tomorrow if UAL agreed to do it! they have No reason to hinder UAL about it. This is a matter of "business"..
kitplane01 wrote:Quick scope question: Are there large-ish airlines with either no union, or no scope clause? And do these airlines have a significant competetive advantage of scope-clause airlines?
FLALEFTY wrote:
Now as for your comment, it has been stated before by the major airlines that due to higher labor costs they cannot use mainline pilots & crews to support flying 50~76 seat regional jets. What the major airline unions said about their willingness to fly regional jets is just a fantasy. Or as they say in the South, "That dog won't hunt".
It is simple, UAL farms the 50~76 seat regional jets to contractors because they are substantially cheaper when it comes to labor costs.
airtran737 wrote:As a United pilot, I want to see the 175's that we own flown by our pilots. I held the same view as a regional pilot. No waivers on scope and work to make it advantageous for all parties to have us fly them.
