barefootchris
EK Incident at Brisbane: debris causes hole in wing join fairing
Sat Jul 02, 2022 5:39 pm
Reason: Title edited for clarity
boacvc10
Re: EK Incident at Brisbane: Hole in Fuselage
Sat Jul 02, 2022 6:49 pm
The flight crew would not have been able to see any hole at that position so what do you think could have alerted them?
Per the pax report, one bang and that's it nothing else.
barefootchris
Sat Jul 02, 2022 6:51 pm
Would a hole like that not have caused some performance degradation?
lightsaber
Looks interesting, but as the fairing is outside the pressure vessel and not structural, a scarier title than reality. I would understand passengers near the hole needing a clothing change. But from an airworthiness perspective, I wonder if there if there is a standard process to secure cracks (drill them out) and fly back
barefootchris
Sat Jul 02, 2022 6:58 pm
Do you mean my title? I actually took it back a notch from the linked article which called it a "large hole." I mean, it's certainly eye-catching..but I do understand that it isn't significant enough to be a major threat.
So, how will a repair for something like that work? And how much will it cost?
codc10
Sat Jul 02, 2022 7:08 pm
Scary-looking, but it’s not part of the pressure vessel and should be a relatively straightforward fix. Very similar to damage suffered by the UAL 777 in the DEN-HNL cowl failure from last year, for which some observers initially declared the aircraft a w/o!!
flyingclrs727
Sat Jul 02, 2022 7:10 pm
Wouldn't the hole cause more drag? I would think EK would want to put some speed tape over it before flying back to DXB. Sounds like they are being more conservative than that by getting repairs done in Brisbane before returning to DXB
barefootchris
Sat Jul 02, 2022 7:24 pm
On that note, the report say that the damage was caused by a bolt coming off the landing gear. I suspect that's a bigger potential issue than the hole?
Weatherwatcher1
Sat Jul 02, 2022 7:40 pm
I think the biggest risk is when the fairing came apart, it could have hit the horizontal stabilizer depending on the airflow.
It isn’t primary structure so not really a big problem from a safety of flight perspective unless it hit something more important
lightsaber
Sat Jul 02, 2022 7:47 pm
Since those fairings are extremely optimized to reduce aerodynamic drag, yes, a performance hit. It is one area of any aircraft extensively analyzed for one is adding weight to cut drag. The damaged part has no other purpose (other than creating a protected volume for plumbing and piping, for why waste the space?)
I would expect a .75% increase in fuel burn (aerodynamically, a really bad place to add a hole, in my opinion).
lightsaber
Sat Jul 02, 2022 7:51 pm
Yes, the risk is now fatigue damage. Hence why I ask on standard repairs. Every single crack must be addressed and it could be too large a hole to fly with. Two options:
Fly without (It can fall off, so aircraft must be certified to fly without it, I doubt with passengers, but I do not know).
Some ugly patch repair where the quart cans of epoxy are inadequate.
Lightsaber
flyPIT
Sat Jul 02, 2022 7:59 pm
Reiterating the point that the bolt came off the nose gear, and looking at the pic and the hole's location, I'm wondering if that is an exit hole? If so this could have potentially been much worse.
I imagine the crew's decision to continue flying 13 hours also exasperated the size of the hole.
MDC862
Sat Jul 02, 2022 8:29 pm
Would the crew even know of the puncture? Its a non-pressurized area, so I would be surprised if a warning light would alert them to a puncture, or even if there were sensors in that part of plane.
Theseus
Sat Jul 02, 2022 8:33 pm
If this was an exit hole, it would also have caused pressurisation loss.
flyPIT
Sat Jul 02, 2022 8:44 pm
As stated up thread, the hole is outside the pressure vessel. Therefore pressurization loss would depend on the location of the (hypothetical) entrance hole.
Also, I don’t think a small entrance hole would cause loss of pressurization. After all, outflow valves are holes in the pressure vessel.
ReverseFlow
Sat Jul 02, 2022 8:49 pm
It looks like the hole is in the BLG bay. I find it odd that it is there - the only thing I can think of is that the BLG went over it and threw it up and out.
As I wouldn't think there is a direct trajectory from the NLG to here?
And if it were an entry hole the bit would have come in an odd curveball.
The aircon would probably regulate a hole the size of a window out to keep the cabin pressurised enough.
The pax sitting near would still notice of course!
Noshow
Sat Jul 02, 2022 8:58 pm
What exactly happened? Did a tyre "explode" or did they roll over something that got blown up to hit the fairing? Can tyres still cause damage like this? I thought these are near zero growth NZG tyres now?
DH106
Sat Jul 02, 2022 9:01 pm
I think the rear pair of wheels on each body gear have no brakes fitted, so presumably they spin for some time once retracted (or perhaps they have snubbers similar to how most nose gear wheels are braked?). Perhaps something was flung from one of those wheels - location looks about right.
flyingclrs727
Sat Jul 02, 2022 9:32 pm
If you could find the passenger to interview.
edealinfo
Sat Jul 02, 2022 10:11 pm
Lightsaber
How did such a small part cause such a large hole in the fuselage? It doesn't make sense.
scbriml
Sat Jul 02, 2022 10:22 pm
Tell us you didn't read the linked article without telling us.
scbriml
Sat Jul 02, 2022 10:26 pm
Lightsaber
It's not a hole "in the fuselage", it's just a hole in the rather flimsy fairing over the wing join. It's aerodynamic, not structural.
smi0006
Re: EK Incident at Brisbane: debris causes hole in wing join fairing
Sun Jul 03, 2022 1:28 am
Interesting - I’m not quite sure I follow the timeline (may need more coffee)- the suggestion is a bolt from the landing gear caused the puncture. But pax report the bang was 30mins after take off, and EK report the damage occurred in cruise? Did the bolt puncture hole, which then expanded due to fatigue from ongoing drag to the damage? Presumably 30mins after take off unless for landing gear issues they are well and truly stowed away?
I assume the bolt came loose during takeoff, lucky it didn’t cause more debris on the runway that went unnoticed.
smi0006
Interesting - I’m not quite sure I follow the timeline (may need more coffee)- the suggestion is a bolt from the landing gear caused the puncture. But pax report the bang was 30mins after take off, and EK report the damage occurred in cruise? Did the bolt puncture a hole, which then expanded due to fatigue from ongoing drag to the damage- causing a bang 30mins after the damage occurred? Presumably 30mins after take off (unless for landing gear issues) they are well and truly stowed away? Otherwise a bolt from stowed landing gear isn’t going to come loose and puncture anything, is it?
Assuming the bolt came loose during takeoff, lucky it didn’t cause more debris on the runway that went unnoticed.
Fuling
Sun Jul 03, 2022 3:32 am
For those interested, it's also on AvHerald.
https://www.avherald.com/h?article=4fb1cbea&opt=0
Noshow
Sun Jul 03, 2022 4:09 am
Us? You are one aren't you?
You didn't even understand the question? The damage looks like some tyre blew up inside the left main gear compartment. Not like some loose part having hit it from the outside. I wonder why a tyre releasing pressure can cause a damage like this after the lessons learned from Concorde?
BoeingVista
Sun Jul 03, 2022 4:37 am
Was there actually a puncture? Report is aircraft towed to terminal with PAX still onboard, wouldn't they have used stairs if there was a puncture.
The entry hole is not entirely hypothetical, report says 2 holes were found.
hitower3
Sun Jul 03, 2022 7:11 am
Dear all,
Here is my take on this occurrence, in the form of a hypothetical sequence of events:
- A bolt detaches from the nose landing gear during take off roll.
- The bolt rolls over the runway surface and hits the rearmost outer tire of the left body gear, wich receives damage in the process.
- The gear is retracted, the spinning damaged tire (no brakes on this axle) damages the fairing from the inside.
- 30 minutes into the flight, the initial damage is aggravated by the air flow, noticed by the passengers, the hole gets bigger.
Does this sound reasonable?
Hendric
DL757NYC
Sun Jul 03, 2022 7:41 am
Repair? Isn’t there a fleet of them being scrapped. Order a fairing from a boneyard. Throw some paint on it. If even needed and call it a day.
jetmech
Sun Jul 03, 2022 8:05 am
I guess they knew they had a tyre let go from the TPIS on ECAM. Probably had no idea about the hole in the fairing though.
Apparently there was nothing wrong with the nose gear at all. A BLG tyre burst in cruise which resulted in the fairing puncture.
Regards, JetMech
JLGordon
Sun Jul 03, 2022 8:16 am
Remove the fairing, make an inspection for further damages and repair them if there are any. Get a servicable fairing, install it, item closed.
That is it. The only issue is that it is a very huge fairing, so a big box of cargo.
LoganTheBogan
Sun Jul 03, 2022 8:25 am
The aircraft was repaired overnight. Couldn’t tell there was a hole if you were a normal, unsuspecting passenger.
JannEejit
Sun Jul 03, 2022 9:33 am
According to a comment from passenger"Chris" in the Simple Flying article, the loud bang occurred 30-45 minutes into the flight. I'm curious therefore how anything exiting the gear could which would be elevated into its respective gear bays and effectively contained, could cause this ? I agree the hole looks like an exit hole, so could some piece of released debris travel through the aircraft internally, exiting at the fairing ?
Vicenza
Sun Jul 03, 2022 10:04 am
Regards, JetMech
Surely the MLG and tyre would be fully stowed and enclosed long before the aircraft reached cruise height, would it not?
jetmech
Sun Jul 03, 2022 11:47 am
Yep, that's apparently what happened.
Landing gear was retracted with the tyre bursting 30-40 minutes after TO according to passengers on board.
What the root cause of the tyre failing is the mystery.
Regards, JetMech
Vicenza
Sun Jul 03, 2022 2:25 pm
Regards, JetMech
Yes, but I would have thought the real mystery would surely be how did the debris from the tyre bursting escape from the wheel well to cause the puncture. Am I incorrect in thinking the wheel well is enclosed?
JetBuddy
Sun Jul 03, 2022 6:18 pm
I think the reason the hole looks like it came from inside, is just due to the air flow over the hole during flight. It's going to tug on the edges of the hole.
What I want to know is why the landing gear was retracted only 35 minutes into the flight? Do I understand the situation correctly if the crew thought a tire blew, and that's why they were late with the gear retraction? On approach to Brisbane they did advise they thought they had a tire blown.
There was a missing bolt from the landing gear as well, from the front I think.
Spacepope
Sun Jul 03, 2022 7:07 pm
Where are you seeing landing gear retraction 35 minutes after takeoff?
It appears the gear was retracted normally, and the tire burst at altitude.
jetmech
Sun Jul 03, 2022 9:10 pm
jetmech wrote:
The punctured panel in question is the wall of the wheel well itself.
As far as I understand it, the landing gear was retracted as normal after TO. About 30 to 45 minutes after TO, a BLG tyre burst.
I suspect this BLG tyre was the outboard aft one, which is adjacent to the panel. As such, the debris from the bursting tyre punctured the panel.
Regards, JetMech
teachpdx
Sun Jul 03, 2022 9:17 pm
Tire is damaged due to FOD (nose gear bolt?) on takeoff roll.
As aircraft climbs the pressure differential between the inside of the tire and the unpressurized fairing increases.
This increased pressure differential causes the weakened tire to fail 35-40 mins into flight as they reach cruise altitude.
This failure punctures the fairing. Simple as that.
jetmech
Sun Jul 03, 2022 10:36 pm
Sounds plausible.
Apparently, if it was FOD, it was not from the nose gear.
A comment (now deleted??) in the Avherald article stated that the nose gear photo was actually taken in 2017 at Dusseldorf.
I also have it on good authority that there was no issues with the nose gear.
Regards, JetMech
jetmech
Sun Jul 03, 2022 10:48 pm
Sounds plausible.
A comment in the Avherald article states that the nose gear photo was actually taken in April 2017 at Dusseldorf.
Regards, JetMech
JannEejit
Mon Jul 04, 2022 8:52 am
Wouldn't a blown tyre be fairly obvious to anyone inspecting the aircraft after it landed though ? Has a blown tyre been confirmed.
