MSJYOP28Apilot wrote:SERMN routes have been published as a route option for short hauls leaving the NYC airports most days during the past week for thunderstorms and ATC staffing. The altitude restriction is meant to keep the aircraft in less busy airspace. Usually SERMN and related tunneling playbook routes like DUCT, LIMBO and PHLYER are optional routings and can save the airline filing it a significant amount of time waiting on metering and other flow delays.
FlyHossD wrote:I’ve done the same in a 737, but that was years ago. Back then, this was known as Tower-to-Tower Enroute.
catiii wrote:Saw it depart EWR for RIC and, at least at about 4000’ the gear was still down. Climbed to 8000’, but it Looks like they descended and went the whole way down to RIC at 6000’. Anyone know why?
filbrkz wrote:Here's a SERMN reroute advisory from yesterday that would have applied to that flight. This gets flights out quicker if the Dispatcher and the Captain agree on the low altitude. Less competition for airspace down low.
And, great for sightseeing!
https://www.fly.faa.gov/adv/adv_otherdi ... e=07/02/22
Weatherwatcher1 wrote:filbrkz wrote:Here's a SERMN reroute advisory from yesterday that would have applied to that flight. This gets flights out quicker if the Dispatcher and the Captain agree on the low altitude. Less competition for airspace down low.
Am I reading this correctly when I assume they are dispatching from New York to as far as Charleston (which is over 600 Miles) at 8000 ft? That’s a long way to fly in VFR airspace at 250 knots. Do they get to climb at some point?
GalaxyFlyer wrote:Weatherwatcher1 wrote:filbrkz wrote:Here's a SERMN reroute advisory from yesterday that would have applied to that flight. This gets flights out quicker if the Dispatcher and the Captain agree on the low altitude. Less competition for airspace down low.
It’s not “VFR airspace”; it’s mostly Class C or D with a tower enroute clearance. Anything below 17,999’ could have VFR traffic not operating without an ATC clearance. Class A is the positive IFR only airspace above F180.
I thought the same thing, even with admonishment above not asking for higher. That’s, one a long leg; the weather constraints on ATC will certainly change; and three, I’ve done it, asked for received higher levels and re-routes once out of ZNY airspace. It’s likely more flexible than the document.
CRJ200flyer wrote:catiii wrote:Saw it depart EWR for RIC and, at least at about 4000’ the gear was still down. Climbed to 8000’, but it Looks like they descended and went the whole way down to RIC at 6000’. Anyone know why?
Regarding the gear, I flew the CRJ-200 for many years, and a few times we had our landing gear bay fire detection system deferred. We were required to fly with our gear down for a certain period of time after takeoff. It was loud as heck but the point was to blow out any fire before bringing the gear up since we wouldn’t be able to detect it.
Weatherwatcher1 wrote:Am I reading this correctly when I assume they are dispatching from New York to as far as Charleston (which is over 600 Miles) at 8000 ft? That’s a long way to fly in VFR airspace at 250 knots. Do they get to climb at some point?
GalaxyFlyer wrote:There’s more room for flexibility than often thought. I was headed from the Northeast to NAS Mayport, IIRC. Summer time, lots of weather, 90 minute hold for release on the filed routing, which was “optimized” by flying inland over the moutains I asked for HTO J121 SIE, some jet routes to CHS. Tower came back in minutes with cleared as re-filed, expect relapse in 5 minutes. Gone. I’ve seen similar routing problems dozens of times. The crew has to flexible, willing to change up the plan. Coming out of CYUL, Boston gave some crazy routing that instantly upon loading said CHK FUEL ALTN. Oops. Get handed off to New York, ask for something more in line with the original plan “cleared as requested”.
In the airline, rightly, changes usually get coordinated with the dispatcher, in my world we could just make the changes.
Hey there, yes, you are reading it correctly. These are called escape routes, and they help funnel traffic in and out of busy airports when there may be significant weather buildups blocking the normal filed routings, when there's a lot of air traffic buzzing around, or both.
Usually our dispatch release will have a remark along the lines of "Do not request a higher altitude," indicating that this is one of those special routings that have a tight altitude constraint, and that us trying to work a higher altitude out of habit will invalidate the whole process.
The good news is that you'll be able to get out of the airspace and on your way; the bad news is that because of the lower altitude, you'll be cruising slower (remember, 250 max under 10,000 as you said), and could be subject to a few more bumps along the way. It's not super common, but it's not a cosmic rarity either. As a PHL-based RJ pilot, I flew them a few times from PHL to SYR, RIC, and PIT. Not super long routes anyway, but long enough that we definitely would've normally been cruising at least up in the low/mid 20s.
However, as someone else did comment, these flights are still indeed handled under Instrument Flight Rules. All airline operations have to be under IFR, regardless of what altitude they're being flown at.
Hope this helps!
atcsundevil wrote:MSJYOP28Apilot wrote:SERMN routes have been published as a route option for short hauls leaving the NYC airports most days during the past week for thunderstorms and ATC staffing. The altitude restriction is meant to keep the aircraft in less busy airspace. Usually SERMN and related tunneling playbook routes like DUCT, LIMBO and PHLYER are optional routings and can save the airline filing it a significant amount of time waiting on metering and other flow delays.
Sometimes it can be for ATC staffing, but this past week it's only been because of the weather, volume, and other playbooks in effect. SERMN South is generally dependent on ZDC's ability to handle the traffic since it flows directly from N90, and ZDC hasn't any notable staffing issues recently (unlike ZNY or ZJX).FlyHossD wrote:I’ve done the same in a 737, but that was years ago. Back then, this was known as Tower-to-Tower Enroute.
It's still called Tower Enroute, but SERMN is a specific plan into and out of the NY Metros going south, north, and east. The specific one being discussed here is SERMN South.Weatherwatcher1 wrote:Am I reading this correctly when I assume they are dispatching from New York to as far as Charleston (which is over 600 Miles) at 8000 ft? That’s a long way to fly in VFR airspace at 250 knots. Do they get to climb at some point?
SERMN actually can be implemented as far south as SAV. They can be filed for anything between 6,000-10,000, and sometimes approach will climb as high as 12,000. Tower enroute actually ends in Central VA — there's a large gap in approach airspace between PCT, ORF, RDU, and ROA that is controlled by ZDC to the ground. ZDC has discretion to climb once the aircraft are south of RIC for aircraft headed for GSO, RDU, CHS, or SAV. Pilots accept the route knowing the limitations, and ZDC is not required to offer climbs or shortcuts (although it's typically offered in most cases). Pilots aren't always able to accept though because they need to burn fuel in some cases.GalaxyFlyer wrote:There’s more room for flexibility than often thought. I was headed from the Northeast to NAS Mayport, IIRC. Summer time, lots of weather, 90 minute hold for release on the filed routing, which was “optimized” by flying inland over the moutains I asked for HTO J121 SIE, some jet routes to CHS. Tower came back in minutes with cleared as re-filed, expect relapse in 5 minutes. Gone. I’ve seen similar routing problems dozens of times. The crew has to flexible, willing to change up the plan. Coming out of CYUL, Boston gave some crazy routing that instantly upon loading said CHK FUEL ALTN. Oops. Get handed off to New York, ask for something more in line with the original plan “cleared as requested”.
Approach controls are not given any flexibility on SERMN routes. They cannot climb out of their stratum, and they can't issue reroutes beyond shortcuts within their airspace. On SERMN South, only ZDC has discretion to climb and reroute since ZDC TMU implements the plan.
Caspian27 wrote:I have flown a 737 from EWR-SAV filed at 7000. Once we got out of New York Approach airspace and with the center they asked us if we really wanted to fly to Savannah at 7000 and we promptly got a climb to 410.
