JAmie2k9 wrote:New Runway to become operational on 24th August. Hours will be 07:00-18:00 after phased operations over the first few weeks.
Full parallel and dual departures from start of Summer 2023 when slot limits are lifted.
ClassicLover wrote:Meanwhile, how up to date is the Aer Lingus system online? I have a flight next month and it's listed as Airbus A321 NEO but I've been moved from my seat 3K to 1F, which would mean the aircraft has been swapped for a standard A320. If so, how come the system hasn't updated for new reservations? Is this normal behaviour?
ClassicLover wrote:JAmie2k9 wrote:New Runway to become operational on 24th August. Hours will be 07:00-18:00 after phased operations over the first few weeks.
Interesting how long the process takes, what with the phased operations and all the rest of it. I would have thought they would have trained to be ready for near enough full operations from the start. Still, this is going to bode very well for Dublin's capacity in the future.
3D101CA wrote:Are there any plans to expand T2 at DUB in the future?
kaitak wrote:Not a good start to the day for poor old EI. Computer system which produces load sheets seems to be out of action. Several flights delayed. I'm on the 152 and we've been told is likely to be after 7 before we get it, if we're lucky.
EI321 wrote:DL are upgrading BOS-DUB to 767-400ER from Oct 22nd.
ClassicLover wrote:EI321 wrote:DL are upgrading BOS-DUB to 767-400ER from Oct 22nd.
I have to get on one of these 767-400ERs one day, I can't imagine they'll be around that many more years.
HTCone wrote:ClassicLover wrote:EI321 wrote:DL are upgrading BOS-DUB to 767-400ER from Oct 22nd.
Quite, only 2 operators (UAL and DAL), although both are fond of sending them to DUB.
OA260 wrote:SNN not that bad :
Shamrock Rovers' European opponents vow to avenge the 'evil' of being forced to fly via Shannon Airport
https://www.the42.ie/shkupi-5832944-Aug2022/
3D101CA wrote:Why does EI serve SNN-BOS/JFK? To me it makes no sense, moving the flights over to DUB would be better it seems.
BrianDromey wrote:3D101CA wrote:Why does EI serve SNN-BOS/JFK? To me it makes no sense, moving the flights over to DUB would be better it seems.
On the face of it you are probably right. Long-time readers of the forums will know that I had hoped these services would move to Cork, or that EI would launch transatlantic services from Cork with the introduction of the LR. That hasn’t happened as yet. Even closing the SNN cabin crew base has not dented the routes fortunes. In the depths of the pandemic MAN was supposed to get 2x A321LR’s, one for JFK and one for BOS. It looked like SNN would be the donor for these routes. In the end SNN-JFK/BOS survived and MAN-BOS was dropped. While SNN-JFK/BOS may make no sense to you, the place clearly makes sense to route planners and revenue departments.
What is the purpose of the seasonal EWR-SNN seasonal service on UA? Lack of capacity at DUB for additional EWR service? You also had AA flying PHL-SNN at one point. I wonder if three daily EWR-DUB on a seasonal basis would work better. Or even double daily PHL-DUB on a seasonal basis.
ei737ng wrote:Due to fly to Faro in the morning and I think it’s on A330. It’ll be my first time on one, so looking forward to the experience. I’m thinking of dropping off the checked bags this evening rather than in the morning. I know EI have their problems with lost luggage recently. Good idea or not?
nickya340 wrote:Has there ever been any talk of a ORK runway extension? I can’t recall ever hearing anything.
ClassicLover wrote:nickya340 wrote:Has there ever been any talk of a ORK runway extension? I can’t recall ever hearing anything.
Probably not worth it.
The Kerry, Cork, Shannon triangle is definitely overkill when it comes to facilities.
KIR is 70km from SNN and 97km from ORK.
ORK is 100km from SNN.
Does any country require three major airports that close together, especially one with a population of around 5 million people?
You'd probably keep SNN and do away with the rest. Hell, even NOC is only 135km from SNN, so that could be made redundant also. Though, as ORK is actually has more passenger traffic than SNN and a larger city beside it, the argument could be to keep ORK and close SNN and KIR.
ClassicLover wrote:The Kerry, Cork, Shannon triangle is definitely overkill when it comes to facilities.
Avoation1091 wrote:Does anyone know what way EI work a/c swaps between the a/c based in SNN, ORK, DUB.? LRC and LRF switched on Sunday and went back to SNN and DUB respectively from LHR. They switched again in LHR this morning. Is this a maintenance issue? Seems to be a waste of time to switch them on Sunday only to switch them back today
alancostello wrote:The A321LR wouldn’t make it transatlantic off the runway in ORK without a significant weight penalty. The A321LR can’t fly to MSP out of DUB because of runway restrictions (thankfully soon to be lifted with the new runway) and that’s 1600+ft longer. An A321LR at MTOW requires a balanced field length (BFL) often in excess of 9,000 feet and Cork is under 7,000. Yes I know Norwegian flew 737 MAXs of ORK but it’s a smaller plane.
AmricanShamrok wrote:Off topic but I wonder if EI would ever consider reinstating the daytime eastbound JFK-DUB service? Curious to know how this performed a few years back when it last operated; I think it ran for more than one season which indicates it didn't do too badly (initially at least).
JAmie2k9 wrote:AmricanShamrok wrote:Off topic but I wonder if EI would ever consider reinstating the daytime eastbound JFK-DUB service? Curious to know how this performed a few years back when it last operated; I think it ran for more than one season which indicates it didn't do too badly (initially at least).
If 2020 had opereated as planned, I think BOS was to go x18 weekly peak season. No changes to JFK that summer.
I am not sure it will return. New expensive fleet of A321LRs this service would be poor utilization of the fleet unltess it was a top performer. 3/5 LR operate Euro routes this summer in between T/A.
Avoation1091 wrote:JAmie2k9 wrote:AmricanShamrok wrote:Off topic but I wonder if EI would ever consider reinstating the daytime eastbound JFK-DUB service? Curious to know how this performed a few years back when it last operated; I think it ran for more than one season which indicates it didn't do too badly (initially at least).
Its just 2 X LR operating morning DUB-LHR before they go to YYZ/PHL. No euro routes are covered except for some DUB FCO runs lately. The other 3 LR are on the ground in DUB.
