drdisque wrote:When I was there this past winter, most UA flights were operating from H.
zippyjet wrote:drdisque wrote:When I was there this past winter, most UA flights were operating from H.
When I flew in and out of MIA this past September. DL had the Lion's Share of flights on H Concourse. And flying home to BWI a week later on us WN out of G I swore I saw a UA flight or two at the G Gates. I believe Frontier also operates flights out of G. Air France I believe had a flight or two out of H. H IMO is holding its own. I believe DL concourse at MIA got an extreme makeover back in 1998. I like the contemporary design with the glass windows which gives it an art decco feel at the same time. I'm guessing it's been painted and re-carpeted at least once since.
drdisque wrote:zippyjet wrote:drdisque wrote:When I was there this past winter, most UA flights were operating from H.
The concessions in H are pretty awful.
The UA gates are all the way at the end of H.
itripreport wrote:
Now I do have a question about H. The delta gates feel as if they were designed for wide body double decker use, as there's roped off escalators leading up to a second level (not the sterile walkway), and now-filled openings right above were the current jetways are, does anyone have any more information regarding this?
cosyr wrote:I think MIA is missing an opportunity. I think a Y shaped concourse to replace F and G would fit in the space well and replace the most number of gates. Something similar to EWR C1 concourse. If they did that and redeveloped E, they could maximize space for aircraft movement, without losing many gates in the process.
itripreport wrote:Frontier has since gone all to F
UA's main area are the end of H, however as an overflow they do tend to use J1-J5, I've had my fair share of flights out of here.
Frontier has since gone all to F, meanwhile Spirit and Southwest have found home in G. Unfortunately it feels as if the end of H (UA gates) feels more as a temporary overflow than an actual part of the terminal.
zippyjet wrote:My educated guess regarding Concourse H with the escalators. When H opened in 1961 props were still a mainstay of air travel even at MIA. So the lower level led to old school hard stand boarding stairs. Jetways (originally the Mini Mes) handled the first generation of jets. So, I'm thinking the escalators and lower levels were incorporated in the 1998 redo out of cost savings, and convenience/construction time. My other theory, at least into the 90's when US shared H there were a lot of puddle jumpers turbo props and Barbie Jets (RJ's) so the same real estate could handle to short hop flights or mainline birds. For its age, I feel H still looks current and spiffy. I agree, the food choices in F,G, H/J could stand improvement but, you have La Caretta on D and their smaller satellite food stand in the South Terminal baggage claim. Another side note. Originally when we entered MIA SWA we were going to use at least gates H-11 and H-15 but maybe because of more flights we went to G with more available gate space. I wouldn't have minded being in H. From what I've read and garnered from the links to the shared articles plans are vague about the Central Terminal. F getting the makeover and G demolished but that's about it and ain't happening anytime soon.
zippyjet wrote:
F was remodeled expanded after G. Low G is basically 1959 era with the extension (our WN Gates) added on in the 70's or 80's.
FlyingSquirrel3 wrote:(Note: Concourse B at DTW's old Smith terminal had an express walkway on the lower level for arrivals, and rumor has it ATL once planned an upper level above Concourses A and B with moving walkways.)
phatfarmlines wrote:There is another remodel that is supposed to be taking place, which will remove the third-level walkway and TSA checkpoints and bring those to the 2nd level. Recent YouTube trip report videos still show these areas as untouched.
