DaCubbyBearBar wrote:So, is there the possibility of closing those airports? Will flights to/from HNL or OGG be affected by this...delays as well?
MIflyer12 wrote:DaCubbyBearBar wrote:So, is there the possibility of closing those airports? Will flights to/from HNL or OGG be affected by this...delays as well?
Depends on how big the plume becomes, the direction it spreadsand and how that impinges on HNL/OGG-XXX routes. ATC game-day calls, I believe.
mga707 wrote:MIflyer12 wrote:DaCubbyBearBar wrote:So, is there the possibility of closing those airports? Will flights to/from HNL or OGG be affected by this...delays as well?
Correct me if I'm wrong, but prevailing winds in Hawai'i are normally NE to SW (hence the 'windward' and 'leeward' sides of the five largest islands), so unless the winds are unusual I don't think it should affect airports on the other islands.
Boeing757100 wrote:It doesn’t say how high the ash cloud is erupting to. It’s been a few hours since the eruption started so when should we expect this information to leak out?
747-600X wrote:Here's what the experts are thinking about this eruption's impact on aviation. If airlines are cancelling flights from the US, it may be due to the 45,000-foot volcanic ash cloud lingering to the northeast of the islands. That covers most of the normal routes into and out of Hawai'i from the mainland.
https://www.ssd.noaa.gov/VAAC/ARCH22/GFX/MAUN0005.jpg
https://www.ssd.noaa.gov/VAAC/messages.html
Spacepope wrote:Boeing757100 wrote:It doesn’t say how high the ash cloud is erupting to. It’s been a few hours since the eruption started so when should we expect this information to leak out?
Geologist here. The ash cloud won’t be much of an issue since this is a classic Shield Volcano eruption over a mantle hot spot. These generate very little ash compared to those subduction zone stratovolcanoes (Pinatubo, Caribbean or Japan) or the mid-ocean rift volcanoes (Iceland) with their giant ash plumes from wet low temperature melts. This volcano has very high temp mafic magma/lava that is very fluid and flows very well. There may be immediate local ash impacts to airports, but the plume will disperse very easily with the winds. Most of the warnings, delays or cancellations will be the result of erring on the side of safety.
All islands everywhere have 'windward' and 'leeward' sides.
