jplatts wrote:Here are the remaining DL nonstop routes out of CVG to non-DL hub destinations:
CVG-AUS/DEN/FLL/RSW/LAS/EWR/MCO/CDG/TPA/DCA
CVG-AUS/EWR/DCA are also the only remaining DL Connection routes out of CVG that aren't to a DL hub.
Are any of the above nonstop routes out of CVG at risk of getting dropped by DL? If so, which of the above nonstop routes would most likely be dropped by DL out of CVG?
DL can likely remain relevant in the CVG market without DL nonstop service to Florida out of CVG with the connecting options that would still be there through the ATL hub to Florida from CVG on DL.
Here were the DL nonstop routes out of CVG that were completely dropped by DL during the last 3 years:
CVG-BWI/CLT/ORD/DFW/BDL/IAH/MCI/PHL/PHX/RDU/STL/SFO
Any possibility of DL resuming any of the above routes out of CVG? If so, which of the above routes would be most likely to see nonstop service re-added by DL?
BWIAirport wrote:I always thought DL maintained a small base (including the CDG) flight almost as a courtesy to Cincinnati as to not entirely abandon the city. But as we see from the cuts, it's difficult to make it work and is rendered almost entirely redundant with DTW right to the north. The hub conflict arose because DTW was a NorthWest Airlines hub. Nearly identical situation to UA eliminating the legacy Continental CLE hub with ORD and EWR sandwiching it.
Poor Ohio. At least LCK has a huge cargo presence.
TWA772LR wrote:BWIAirport wrote:I always thought DL maintained a small base (including the CDG) flight almost as a courtesy to Cincinnati as to not entirely abandon the city. But as we see from the cuts, it's difficult to make it work and is rendered almost entirely redundant with DTW right to the north. The hub conflict arose because DTW was a NorthWest Airlines hub. Nearly identical situation to UA eliminating the legacy Continental CLE hub with ORD and EWR sandwiching it.
I wish airlines kept hubs open as a courtesy but unfortunately that's not the case. CDG is/was kept as a courtesy for P&G due to a lucrative contract.
cv5880 wrote:In the 1990's and early 2000's CVG was quite the operation. Comair had their separate terminal with then then new CRJ's providing service that complimented DL's hub. To me Cincinnati and the surrounding areas is a more economically vibrant than Detroit. Still a SMH mystery why Delta would discard CVG for DTW.
usflyer msp wrote:CVG seems to be trending towards AA. They have almost the same # of flights but DL has significantly more mainline.
cv5880 wrote:The merger with NW created what looks like DINO (Delta in name only). Northwest fleet management took over in ATL and DL switched from a reliable Boeing (Supporting US manufacturing) to Airbus. Northwest was only ordering Airbus before the merger and this bias transferred to Delta after the merger. Northwest MO was to update the interiors in their old DC-9's and DC-10's and fly them until the rivets fell out. Same thing today with very old A320's and 763's that have nice interiors but are ready for retirement. I still think not buying a fleet of 787's with GE engines will bite Delta one day.
cledaybuck wrote:TWA772LR wrote:BWIAirport wrote:I always thought DL maintained a small base (including the CDG) flight almost as a courtesy to Cincinnati as to not entirely abandon the city. But as we see from the cuts, it's difficult to make it work and is rendered almost entirely redundant with DTW right to the north. The hub conflict arose because DTW was a NorthWest Airlines hub. Nearly identical situation to UA eliminating the legacy Continental CLE hub with ORD and EWR sandwiching it.
I don't think I would call that a courtesy.
MIflyer12 wrote:usflyer msp wrote:CVG seems to be trending towards AA. They have almost the same # of flights but DL has significantly more mainline.
That just points to the weakness of using departures rather than ASMs as a measure of size.
Delta is farther along replacing regionals with mainline jets, and that's good for reliability and CASM.
STT757 wrote:BWIAirport wrote:I always thought DL maintained a small base (including the CDG) flight almost as a courtesy to Cincinnati as to not entirely abandon the city. But as we see from the cuts, it's difficult to make it work and is rendered almost entirely redundant with DTW right to the north. The hub conflict arose because DTW was a NorthWest Airlines hub. Nearly identical situation to UA eliminating the legacy Continental CLE hub with ORD and EWR sandwiching it.
The two hubs Delta ditched, Cincinnati and Memphis, have large cargo/parcel/freight operations to support jobs. LCC and ULCC's have back filled into CVG to leisure destinations. CVG fared okay considering the loss of the hub, they still are growing jobs at the airport through the cargo operations and ULCCs have lowered fares for families and leisure travelers. Overall CVG has fared much better than MEM, STL, CLE and PIT.
cv5880 wrote:Northwest fleet management took over in ATL and DL switched from a reliable Boeing (Supporting US manufacturing) to Airbus.
PSU.DTW.SCE wrote:I feel like the CVG vs DTW narrative gets beaten to death on a.net, but it wasn't necessarily just a one or the other.
pmanni1 wrote:STT757 wrote:BWIAirport wrote:I always thought DL maintained a small base (including the CDG) flight almost as a courtesy to Cincinnati as to not entirely abandon the city. But as we see from the cuts, it's difficult to make it work and is rendered almost entirely redundant with DTW right to the north. The hub conflict arose because DTW was a NorthWest Airlines hub. Nearly identical situation to UA eliminating the legacy Continental CLE hub with ORD and EWR sandwiching it.
WN is up to 58 destinations at STL. This is miles ahead of CVG.
PSU.DTW.SCE wrote:DL coming out of the pandemic still is a "smaller airline". Both due to the decisions they made during the pandemic and now amplified by the staffing issues at the regional airlines.
CVG has not seem some of those resume two to the factors:
1) RJ routes that were heavily reliant upon business travel; that is still well off of what it was pre-pandemic
2) Utilization of scare resources to restore the network and gain marketshare in coastal hubs
3) Lack of RJ feed due to staffing
DL is a resourced constrained airline currently, and in Summer 2022 was only operating around 85% of pre-pandemic capacity.
They will eventually get back to 100% of capacity but its not going to be exactly how it was pre-pandemic.
DL obviously seems some value in maintaining non-hub service from CVG is certain markets.
Its always possible they could add back more as resources (aircraft, staffing) allow, but that remains to be seen.
DL has said they are going to start restoring more capacity in their core hubs in 2023. Once they do that they maybe they will revisit more capacity in prior focus city markets.
rbavfan wrote:STT757 wrote:BWIAirport wrote:I always thought DL maintained a small base (including the CDG) flight almost as a courtesy to Cincinnati as to not entirely abandon the city. But as we see from the cuts, it's difficult to make it work and is rendered almost entirely redundant with DTW right to the north. The hub conflict arose because DTW was a NorthWest Airlines hub. Nearly identical situation to UA eliminating the legacy Continental CLE hub with ORD and EWR sandwiching it.
Everyone puts down STL. WN has a very large operation there and has added more gates over the years. The planse always seem to have high load factors as well. AA killed of TWA ops in STL after they claimed they would keep the hub. WN expanded and does great. Family back there does not like AA for the way they treated TWA employees.
IND96 wrote:It surprises me that CVG-EWR has held on as long as it has, considering that CVG is well connected to the DL hubs at LGA and JFK. Is there a contract/some other reason why this route stays while others like ORD, IAH, PHX, SFO have gone away?
STT757 wrote:IND96 wrote:It surprises me that CVG-EWR has held on as long as it has, considering that CVG is well connected to the DL hubs at LGA and JFK. Is there a contract/some other reason why this route stays while others like ORD, IAH, PHX, SFO have gone away?
Proctor and Gamble has two facilities in Northern New Jersey, a Sales office and a production plant. Perhaps that's what's driving it?
https://www.pglocations.com/
lightsaber wrote:PSU.DTW.SCE wrote:DL coming out of the pandemic still is a "smaller airline". Both due to the decisions they made during the pandemic and now amplified by the staffing issues at the regional airlines.
Business travel is expected to recover between 2023 and 2025:
https://www.financialexpress.com/lifest ... w/2856547/
I personally see a slow recovery. For example, we're having a major workshop with a vendor on what I consider a good size contract with them (several hundred million USD) and instead of flying a team of 20 to 30 like we did in the past. Most will call into a Zoom call. We'll fly one person, myself as the technical lead only as there is some "hands on" stuff only for the technical people.
The rising pilot costs will kill RJs. In particular as RJs are stuck on prior generation aircraft while mainline narrowbodies advanced with the NEO, MAX, and in particular the A220. For DL at CVG, this means quite the contraction. It is my opinion CVG could only grow big again with a massive improvement in RJ economics (newer generation RJ) and I just do not see anything on the horizon.
We're talking about a once hub that has seen 9 constant years of decline before 2022:
https://www.wcpo.com/news/transportatio ... eos-vision
McGraw’s plan to turn around an airport that had seen nine consecutive years of passenger decline was complex.
Honestly, the link notes the airport has become an Amazon super-hub and that seems like the best role going forward. The greater Ohio Valley is being served by DTW, MSP, and to a lesser extent ATL.
https://www.flightconnections.com/route-map-delta-dl
Zoom in for the above link around Ohio and it really looks like CVG has just become a feeder to other DL hubs with some added flights to Florida (a big market for DL).
It will be slow growth for DL at CVG and with WN and NK dug in, very likely to remain with MEM, PIT, and STL as "once upon a time hubs." The only out is far lower cost 76 seat RJs and none have been launched and I personally am not a fan of turboprops.
Lightsaber
foxecho wrote:cv5880 wrote:The merger with NW created what looks like DINO (Delta in name only). Northwest fleet management took over in ATL and DL switched from a reliable Boeing (Supporting US manufacturing) to Airbus. Northwest was only ordering Airbus before the merger and this bias transferred to Delta after the merger. Northwest MO was to update the interiors in their old DC-9's and DC-10's and fly them until the rivets fell out. Same thing today with very old A320's and 763's that have nice interiors but are ready for retirement. I still think not buying a fleet of 787's with GE engines will bite Delta one day.
Very well put...(retired 22 years ACS)
Andrew
kavok wrote:I think what also gets overlooked in the whole CVG dehub discussion is that DTW never really became a significantly larger hub due to CVG’s demise. If anyone, ATL did. CVG’s “loss” was actually ATL’s gain, not DTW’s gain.
diverdave wrote:kavok wrote:I think what also gets overlooked in the whole CVG dehub discussion is that DTW never really became a significantly larger hub due to CVG’s demise. If anyone, ATL did. CVG’s “loss” was actually ATL’s gain, not DTW’s gain.
An excellent point, which IMO also applies to MEM.
David
Vctony wrote:diverdave wrote:kavok wrote:I think what also gets overlooked in the whole CVG dehub discussion is that DTW never really became a significantly larger hub due to CVG’s demise. If anyone, ATL did. CVG’s “loss” was actually ATL’s gain, not DTW’s gain.
David
Honestly while ATL benefitted somewhat the main beneficiaries of the CVG / MEM shutdown was JFK / LGA, BOS and SEA.
WidebodyPTV wrote:Maybe, but they used a lot of the RJ’s from CVG to fund places like NY.Vctony wrote:diverdave wrote:
David
ATL was, by far, the biggest beneficiary. DL added more passengers at ATL in the 2010s, than JFK/LGA, BOS & SEA combined BOS & SEA were also largely based on new traffic flows, whereas much of ATL's growth was from cannibalizing CVG, MEM, MSP & DTW.
AWACSooner wrote:cv5880 wrote:The merger with NW created what looks like DINO (Delta in name only). Northwest fleet management took over in ATL and DL switched from a reliable Boeing (Supporting US manufacturing) to Airbus. Northwest was only ordering Airbus before the merger and this bias transferred to Delta after the merger. Northwest MO was to update the interiors in their old DC-9's and DC-10's and fly them until the rivets fell out. Same thing today with very old A320's and 763's that have nice interiors but are ready for retirement. I still think not buying a fleet of 787's with GE engines will bite Delta one day.
Been saying this for years...just like when the McD bean-counters took over Boeing after the merger, I think the worse management company ultimately won out
LAX772LR wrote:cv5880 wrote:Northwest fleet management took over in ATL and DL switched from a reliable Boeing (Supporting US manufacturing) to Airbus.
You mean the Airbus that actively employs US workers to manufacture aircraft in the US, from US materials, while paying US taxes... that Airbus? Or were you thinking of another one?
cledaybuck wrote:Looking at what has been cut and what remains, I can't help but notice that the majority of the cuts are to other airline's hubs. Based on that, it would seem EWR and DEN could be at risk.
