LBBflyer wrote:Don't forget that part of BA (and others) moving to T8 is that T7 is being torn down to make room for the new T6. The current final configuration will be T1, T4, T5, T6, and T8. I agree that some form of renumbering is probably in order once all the terminal development is complete.
avianca707359b wrote:I vote for:
New-T1 > to "Terminal A"
Old-T4 > to "Terminal B",
Old-T5 > to "Terminal C",
New-T6 > to "Terminal D" and
Old-T8 > to "Terminal E".
This is simple, keeps them in physical order, as well as removing any historical reference to older and long-gone terminals......
ContinentalEWR wrote:LBBflyer wrote:Don't forget that part of BA (and others) moving to T8 is that T7 is being torn down to make room for the new T6. The current final configuration will be T1, T4, T5, T6, and T8. I agree that some form of renumbering is probably in order once all the terminal development is complete.
T7 will remain operational until T6 is complete. T6 is not being built on the footprint of T7, but rather in the aircraft parking lot between T5 and T7.
N757ST wrote:ContinentalEWR wrote:LBBflyer wrote:Don't forget that part of BA (and others) moving to T8 is that T7 is being torn down to make room for the new T6. The current final configuration will be T1, T4, T5, T6, and T8. I agree that some form of renumbering is probably in order once all the terminal development is complete.
This isn’t true. T6 phase 1 will encompass the parking area, but phase 2 will take over all the real estate between T5 and the JFK expressway including the current t7 air train station.
BOACJrJet wrote:Let's not forget that British Airways T7 was originally BOAC T5. I remember when it opened. Prior to T5 BOAC flights arrived at the International Arrivals Building - IAB.
Polot wrote:The terminal was known as the BOAC Terminal then later T7. It was never at any point T5. BOAC terminal was the newest one until the redevelopment of JFK began again with the new T1 and T4 in the late 90s.
BA178 wrote:An appendix from the updated JFK Redevelopment Environmental Assessment--published on December 16th--confirms the terminals will be given letter designations. Additionally, the two south terminals (A, B) and three north terminals (C, D, E) will each be accessed exclusively by the Van Wyck and JFK Exp respectively, I assume in an effort to take some pressure off the former. It'll be interesting to see whether this actually works.
Lettered terminal designations at a major international airport servicing speakers of myriad languages, with the added complication of separate motorway access for different terminals, seems to be a poor choice. Particularly English "A" and other languages' "E" are pronounced the same. Communicating your destination terminal number to your driver can be done with fingers. Perhaps this letter designation and motorway scheme will be thrown in the waste bin where it belongs.
IADCA wrote:BA178 wrote:An appendix from the updated JFK Redevelopment Environmental Assessment--published on December 16th--confirms the terminals will be given letter designations. Additionally, the two south terminals (A, B) and three north terminals (C, D, E) will each be accessed exclusively by the Van Wyck and JFK Exp respectively, I assume in an effort to take some pressure off the former. It'll be interesting to see whether this actually works.
That looks like a typical NY construction-for-the-sake-of-construction plan. Why remove highway access to given terminals such that you now need to pick either the JFK or Van Wyck depending on your terminal? What's the benefit?
questions wrote:Currently T4 has A and B concourses: T4A and T4B.
Will the concourses remain the same: TBA and TBB?
Will the concourses be numbered: TB1 and TB2?
Will the concourses not be named and only gates referred to: TB2-7 and TB20-55?
luckyone wrote:Could it be to avoid backups or shorten the approach time? For passengers going to one of the higher numbered/lettered terminals, not having to be part of the traffic going round to the earlier terminals would be nice -- that was always a major irritant of mine when picking up/dropping off at airports like ORD or MIA.
